[U-Boot-Users] MPC8272ADS & U-Boot 1.1.1 (Second Try)
its the second try without base64, sorry for that (I hate Outlook grrr).
Currently I am using U-Boot 1.0.0/Linux 2.4.22 with an MPC8272ADS-Board without any problems. Now I wanna upgrade to U-Boot Version 1.1.1 and I run into the following problem:
U-Boot starts up without any problems, it loads the linux kernel image (uImage) via TFTP. The checksum of the imgae is correct, uncompressing works fine, but than the kernel does not start up. All I get is a immediate reboot into U-Boot. Cause is a CHECKSTOP EXCEPTION. Its the same kernel image which works great under U-Boot 1.0.0. Any ideas? Here is the log:
U-Boot 1.1.1 (Jun 23 2004 - 13:24:00)
MPC8272 Reset Status: External Soft, External Hard
MPC8272 Clock Configuration - Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300 - dfbrg 1, corecnf 0x0a, busdf 3, cpmdf 1, plldf 0, pllmf 3 - vco_out 400000000, scc_clk 100000000, brg_clk 25000000 - cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000 - pci_clk 66666666
CPU: MPC8272 (HiP7 Rev 13, Mask 0.0 0K50M) at 400 MHz Board: Motorola MPC8272ADS DRAM: 64 MB FLASH: 8 MB In: serial Out: serial Err: serial Net: FCC1 ETHERNET Hit any key to stop autoboot: 3-2-1-0 Using FCC1 ETHERNET device TFTP from server 10.0.0.136; our IP address is 10.0.0.201 Filename 'uImage'. Load address: 0x400000 Loading: ################################################################# ################################################################# ######### done Bytes transferred = 709133 (ad20d hex) ## Booting image at 00400000 ... Image Name: Linux Kernel Image Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 709069 Bytes = 692.5 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
--- NOW A RESET OCCURS ---
MPC8272 Reset Status: Check Stop, External Soft, External Hard
Thanx -- Juergen Selent Elmeg Communcation Systems GmbH Development Office Berlin Alt-Moabit 96c 10559 Berlin
Juergen Selent
