[PATCH v2 0/8] riscv: Add AST2700 platform support
AST2700 is the 7th generation of Aspeed BMC SoCs.
A 32-bits Ibex RISC-V core is integrated as the boot MCU to run the first stage bootloader, SPL, for the platform initialization.
This patch series starts by revising RISC-V common code to relax certain restrictions for finer platform resource tuning. As this MCU adopts the "small" configuration provided by Ibex and has limited SRAM space.
In addition to the RV common code revision, the other patches provides the basic AST2700 platform code and DRAM/Timer drivers to succuessfully boot SPL and U-Boot on this Ibex-based MCU.
v2: - collect Reviewed-by and Acked-by tags - add the build document for ibex-ast2700 board as suggested
Chia-Wei Wang (8): riscv: Make A ISA extension selectable riscv: Make stack size shift configurable riscv: u-boot-spl.lds: Remove _image_binary_end alignment riscv: Add AST2700 SoC initial platform support timer: Add AST2700 IBEX timer support board: ibex_ast2700: Add FMC header support ram: ast2700: Add DRAM controller initialization configs: ibex-ast2700: Enable DRAM and timer driver
arch/riscv/Kconfig | 12 +- arch/riscv/cpu/ast2700/Kconfig | 6 + arch/riscv/cpu/ast2700/Makefile | 1 + arch/riscv/cpu/ast2700/cpu.c | 23 + arch/riscv/cpu/u-boot-spl.lds | 2 - arch/riscv/dts/Makefile | 1 + arch/riscv/dts/ast2700-ibex.dts | 22 + arch/riscv/dts/ast2700-u-boot.dtsi | 40 + arch/riscv/dts/ast2700.dtsi | 76 + arch/riscv/include/asm/arch-ast2700/fmc_hdr.h | 52 + arch/riscv/include/asm/arch-ast2700/scu.h | 145 + arch/riscv/include/asm/arch-ast2700/sdram.h | 137 + arch/riscv/include/asm/arch-ast2700/sli.h | 82 + board/aspeed/ibex_ast2700/Kconfig | 21 + board/aspeed/ibex_ast2700/MAINTAINERS | 7 + board/aspeed/ibex_ast2700/Makefile | 3 + board/aspeed/ibex_ast2700/fmc_hdr.c | 64 + board/aspeed/ibex_ast2700/ibex_ast2700.c | 85 + board/aspeed/ibex_ast2700/sli.c | 72 + configs/ibex-ast2700_defconfig | 94 + doc/board/aspeed/ibex-ast2700.rst | 26 + doc/board/aspeed/index.rst | 9 + doc/board/index.rst | 1 + drivers/ram/Makefile | 2 +- drivers/ram/aspeed/Kconfig | 27 +- drivers/ram/aspeed/Makefile | 1 + ..._ddrphy_phyinit_ddr4-3200-nodimm-train2D.c | 2700 +++++++ ..._ddrphy_phyinit_ddr5-3200-nodimm-train2D.c | 6930 +++++++++++++++++ drivers/ram/aspeed/sdram_ast2700.c | 1036 +++ drivers/timer/Kconfig | 6 + drivers/timer/Makefile | 1 + drivers/timer/ast_ibex_timer.c | 45 + include/configs/ibex_ast2700.h | 12 + 33 files changed, 11732 insertions(+), 9 deletions(-) create mode 100644 arch/riscv/cpu/ast2700/Kconfig create mode 100644 arch/riscv/cpu/ast2700/Makefile create mode 100644 arch/riscv/cpu/ast2700/cpu.c create mode 100644 arch/riscv/dts/ast2700-ibex.dts create mode 100644 arch/riscv/dts/ast2700-u-boot.dtsi create mode 100644 arch/riscv/dts/ast2700.dtsi create mode 100644 arch/riscv/include/asm/arch-ast2700/fmc_hdr.h create mode 100644 arch/riscv/include/asm/arch-ast2700/scu.h create mode 100644 arch/riscv/include/asm/arch-ast2700/sdram.h create mode 100644 arch/riscv/include/asm/arch-ast2700/sli.h create mode 100644 board/aspeed/ibex_ast2700/Kconfig create mode 100644 board/aspeed/ibex_ast2700/MAINTAINERS create mode 100644 board/aspeed/ibex_ast2700/Makefile create mode 100644 board/aspeed/ibex_ast2700/fmc_hdr.c create mode 100644 board/aspeed/ibex_ast2700/ibex_ast2700.c create mode 100644 board/aspeed/ibex_ast2700/sli.c create mode 100644 configs/ibex-ast2700_defconfig create mode 100644 doc/board/aspeed/ibex-ast2700.rst create mode 100644 doc/board/aspeed/index.rst create mode 100644 drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr4-3200-nodimm-train2D.c create mode 100644 drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr5-3200-nodimm-train2D.c create mode 100644 drivers/ram/aspeed/sdram_ast2700.c create mode 100644 drivers/timer/ast_ibex_timer.c create mode 100644 include/configs/ibex_ast2700.h
Make the Atomic (A) ISA extension selectable. Thus CPUs such as Ibex without the A extension can be supported.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/Kconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fa3b016c527..c5859c5c541 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -308,7 +308,10 @@ config TPL_USE_ARCH_STRNCMP endmenu
config RISCV_ISA_A - def_bool y + bool "Standard extension for Atomic Instructions" + default y + help + Adds "A" to the ISA string passed to the compiler.
config DMA_ADDR_T_64BIT bool
Add prompt for STACK_SIZE_SHIFT to make it configurable. The default value remains 14 as usual.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index c5859c5c541..d0476f975c2 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -453,7 +453,7 @@ config RISCV_PRIV_1_9 memory is configured was also changed.
config STACK_SIZE_SHIFT - int + int "Stack size shift" default 14
config OF_BOARD_FIXUP
The _image_binary_end symbol was aligned to the 8-bytes boundary. However, the SPL device tree (u-boot-spl.dtb) is concatenated right after the binary (u-boot-spl-nodtb.bin) wihtout the consideration of the 8-bytes alignment restriction.
After then, for the SPL_SEPARATE_BSS case, fdtdec_setup() searching for the DTB by _image_binary_end will return the "Missing DTB" error. As the real DTB starting point does not align to a 8-bytes address like _image_binary_end does.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/u-boot-spl.lds | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/riscv/cpu/u-boot-spl.lds b/arch/riscv/cpu/u-boot-spl.lds index d1113a59aa6..907094620bd 100644 --- a/arch/riscv/cpu/u-boot-spl.lds +++ b/arch/riscv/cpu/u-boot-spl.lds @@ -44,8 +44,6 @@ SECTIONS __binman_sym_end = .; } > .spl_mem
- . = ALIGN(8); - _end = .; _image_binary_end = .;
AST2700 SoCs integrates a Ibex 32-bits RISC-V core as the boot MCU for the first stage bootloader execution, namely SPL.
This patch implements the preliminary base to successfully run SPL on this RV32-based MCU to the console banner message.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/Kconfig | 5 + arch/riscv/cpu/ast2700/Kconfig | 6 + arch/riscv/cpu/ast2700/Makefile | 1 + arch/riscv/cpu/ast2700/cpu.c | 23 ++++ arch/riscv/dts/Makefile | 1 + arch/riscv/dts/ast2700-ibex.dts | 22 ++++ arch/riscv/dts/ast2700-u-boot.dtsi | 40 ++++++ arch/riscv/dts/ast2700.dtsi | 76 ++++++++++++ arch/riscv/include/asm/arch-ast2700/scu.h | 145 ++++++++++++++++++++++ arch/riscv/include/asm/arch-ast2700/sli.h | 82 ++++++++++++ board/aspeed/ibex_ast2700/Kconfig | 21 ++++ board/aspeed/ibex_ast2700/MAINTAINERS | 7 ++ board/aspeed/ibex_ast2700/Makefile | 2 + board/aspeed/ibex_ast2700/ibex_ast2700.c | 85 +++++++++++++ board/aspeed/ibex_ast2700/sli.c | 72 +++++++++++ configs/ibex-ast2700_defconfig | 92 ++++++++++++++ doc/board/aspeed/ibex-ast2700.rst | 26 ++++ doc/board/aspeed/index.rst | 9 ++ doc/board/index.rst | 1 + include/configs/ibex_ast2700.h | 12 ++ 20 files changed, 728 insertions(+) create mode 100644 arch/riscv/cpu/ast2700/Kconfig create mode 100644 arch/riscv/cpu/ast2700/Makefile create mode 100644 arch/riscv/cpu/ast2700/cpu.c create mode 100644 arch/riscv/dts/ast2700-ibex.dts create mode 100644 arch/riscv/dts/ast2700-u-boot.dtsi create mode 100644 arch/riscv/dts/ast2700.dtsi create mode 100644 arch/riscv/include/asm/arch-ast2700/scu.h create mode 100644 arch/riscv/include/asm/arch-ast2700/sli.h create mode 100644 board/aspeed/ibex_ast2700/Kconfig create mode 100644 board/aspeed/ibex_ast2700/MAINTAINERS create mode 100644 board/aspeed/ibex_ast2700/Makefile create mode 100644 board/aspeed/ibex_ast2700/ibex_ast2700.c create mode 100644 board/aspeed/ibex_ast2700/sli.c create mode 100644 configs/ibex-ast2700_defconfig create mode 100644 doc/board/aspeed/ibex-ast2700.rst create mode 100644 doc/board/aspeed/index.rst create mode 100644 include/configs/ibex_ast2700.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index d0476f975c2..6b854cc0b65 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -46,6 +46,9 @@ config TARGET_TH1520_LPI4A config TARGET_XILINX_MBV bool "Support AMD/Xilinx MicroBlaze V"
+config TARGET_ASPEED_AST2700_IBEX + bool "Support Ibex RISC-V cores on Aspeed AST2700 SoC" + endchoice
config SYS_ICACHE_OFF @@ -81,6 +84,7 @@ config SPL_ZERO_MEM_BEFORE_USE
# board-specific options below source "board/andestech/ae350/Kconfig" +source "board/aspeed/ibex_ast2700/Kconfig" source "board/emulation/qemu-riscv/Kconfig" source "board/microchip/mpfs_icicle/Kconfig" source "board/openpiton/riscv64/Kconfig" @@ -97,6 +101,7 @@ source "arch/riscv/cpu/andes/Kconfig" source "arch/riscv/cpu/cv1800b/Kconfig" source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/fu740/Kconfig" +source "arch/riscv/cpu/ast2700/Kconfig" source "arch/riscv/cpu/generic/Kconfig" source "arch/riscv/cpu/jh7110/Kconfig"
diff --git a/arch/riscv/cpu/ast2700/Kconfig b/arch/riscv/cpu/ast2700/Kconfig new file mode 100644 index 00000000000..b16f0fc7cad --- /dev/null +++ b/arch/riscv/cpu/ast2700/Kconfig @@ -0,0 +1,6 @@ +config RISCV_AST2700 + bool + imply CPU + imply CPU_RISCV + help + Run U-Boot on AST2700 with IBex RISC-V CPU integrated. diff --git a/arch/riscv/cpu/ast2700/Makefile b/arch/riscv/cpu/ast2700/Makefile new file mode 100644 index 00000000000..1f843c706ad --- /dev/null +++ b/arch/riscv/cpu/ast2700/Makefile @@ -0,0 +1 @@ +obj-y += cpu.o diff --git a/arch/riscv/cpu/ast2700/cpu.c b/arch/riscv/cpu/ast2700/cpu.c new file mode 100644 index 00000000000..c1540546a9a --- /dev/null +++ b/arch/riscv/cpu/ast2700/cpu.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + * Copyright (C) 2024, Aspeed Technology Inc. + */ + +#include <irq_func.h> +#include <asm/cache.h> + +/* + * cleanup_before_linux() is called just before we call linux + * it prepares the processor for linux + * + * we disable interrupt and caches. + */ +int cleanup_before_linux(void) +{ + disable_interrupts(); + + cache_flush(); + + return 0; +} diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 17cda483e12..c4c44057bad 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -11,6 +11,7 @@ dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb dtb-$(CONFIG_TARGET_STARFIVE_VISIONFIVE2) += jh7110-starfive-visionfive-2.dtb dtb-$(CONFIG_TARGET_TH1520_LPI4A) += th1520-lichee-pi-4a.dtb dtb-$(CONFIG_TARGET_XILINX_MBV) += xilinx-mbv32.dtb +dtb-$(CONFIG_TARGET_ASPEED_AST2700_IBEX) += ast2700-ibex.dtb
include $(srctree)/scripts/Makefile.dts
diff --git a/arch/riscv/dts/ast2700-ibex.dts b/arch/riscv/dts/ast2700-ibex.dts new file mode 100644 index 00000000000..f7a05e5771b --- /dev/null +++ b/arch/riscv/dts/ast2700-ibex.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) + +/dts-v1/; + +#include "ast2700.dtsi" + +/ { + chosen { + stdout-path = &uart12; + tick-timer = &ast_ibex_timer; + }; + + memory@0 { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; +}; + +&uart12 { + status = "okay"; + clock-frequency = <1846153>; +}; diff --git a/arch/riscv/dts/ast2700-u-boot.dtsi b/arch/riscv/dts/ast2700-u-boot.dtsi new file mode 100644 index 00000000000..ddc08a4bcef --- /dev/null +++ b/arch/riscv/dts/ast2700-u-boot.dtsi @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) + +/ { + cpus { + bootph-all; + }; + + memory@80000000 { + bootph-all; + }; + + soc0: soc@12000000 { + bootph-all; + + sdrammc: sdrammc@12c00000 { + bootph-all; + }; + + syscon0: syscon@12c02000 { + bootph-all; + }; + }; + + soc1: soc@14000000 { + bootph-all; + + syscon1: syscon@14c02000 { + bootph-all; + }; + + uart12: serial@14c33b00 { + bootph-all; + }; + + ast_ibex_timer: timer { + bootph-all; + }; + }; + +}; diff --git a/arch/riscv/dts/ast2700.dtsi b/arch/riscv/dts/ast2700.dtsi new file mode 100644 index 00000000000..9b482dfdd84 --- /dev/null +++ b/arch/riscv/dts/ast2700.dtsi @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + model = "Aspeed AST2700 Ibex BootMCU"; + compatible = "aspeed,ast2700-ibex"; + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "lowrisc,ibex"; + device_type = "cpu"; + reg = <0>; + comptaible = "riscv"; + riscv,isa = "rv32imc"; + }; + }; + + memory@80000000 { + reg = <0x80000000 0x80000000>; + }; + + soc0: soc@12000000 { + compatible = "aspeed,soc1","simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sdrammc: sdrammc@12c00000 { + compatible = "aspeed,ast2700-sdrammc"; + reg = <0x12c00000 0x3000>, <0x13000000 0x1000>; + aspeed,scu0 = <&syscon0>; + aspeed,scu1 = <&syscon1>; + }; + + syscon0: syscon@12c02000 { + compatible = "aspeed,ast2700-scu0", "syscon", "simple-mfd"; + reg = <0x12c02000 0x1000>; + ranges = <0 0x12c02000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + }; + }; + + soc1: soc@14000000 { + compatible = "aspeed,soc1","simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + syscon1: syscon@14c02000 { + compatible = "aspeed,ast2700-scu1", "syscon", "simple-mfd"; + reg = <0x14c02000 0x1000>; + ranges = <0 0x14c02000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + }; + + uart12: serial@14c33b00 { + compatible = "ns16550a"; + reg = <0x14c33b00 0x20>; + reg-shift = <2>; + no-loopback-test; + clock-frequency = <1846153>; + status = "disabled"; + }; + + ast_ibex_timer: timer { + compatible = "aspeed,ast2700-ibex-timer"; + clock-frequency = <200000000>; + }; + }; +}; diff --git a/arch/riscv/include/asm/arch-ast2700/scu.h b/arch/riscv/include/asm/arch-ast2700/scu.h new file mode 100644 index 00000000000..1aa7d38bace --- /dev/null +++ b/arch/riscv/include/asm/arch-ast2700/scu.h @@ -0,0 +1,145 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) Aspeed Technology Inc. + */ +#ifndef __ASM_AST2700_SCU_H__ +#define __ASM_AST2700_SCU_H__ + +/* SCU0: CPU-die SCU */ +#define SCU0_HWSTRAP 0x010 +#define SCU0_HWSTRAP_DIS_RVAS BIT(30) +#define SCU0_HWSTRAP_DIS_WDTFULL BIT(25) +#define SCU0_HWSTRAP_DISARMICE_TZ BIT(22) +#define SCU0_HWSTRAP_DISABLE_XHCI BIT(21) +#define SCU0_HWSTRAP_BOOTEMMCSPEED BIT(20) +#define SCU0_HWSTRAP_VGA_CC BIT(18) +#define SCU0_HWSTRAP_EN_OPROM BIT(17) +#define SCU0_HWSTRAP_DISARMICE BIT(16) +#define SCU0_HWSTRAP_TSPRSNTSEL BIT(9) +#define SCU0_HWSTRAP_DISDEBUG BIT(8) +#define SCU0_HWSTRAP_HCLKHPLL BIT(7) +#define SCU0_HWSTRAP_HCLKSEL GENMASK(6, 5) +#define SCU0_HWSTRAP_CPUHPLL BIT(4) +#define SCU0_HWSTRAP_HPLLFREQ GENMASK(3, 2) +#define SCU0_HWSTRAP_BOOTSPI BIT(1) +#define SCU0_HWSTRAP_HWSTRAP_DISCPU BIT(0) +#define SCU0_DBGCTL 0x0c8 +#define SCU0_DBGCTL_MASK GENMASK(14, 0) +#define SCU0_DBGCTL_UARTDBG BIT(1) +#define SCU0_RSTCTL1 0x200 +#define SCU0_RSTCTL1_EMMC BIT(17) +#define SCU0_RSTCTL1_HACE BIT(4) +#define SCU0_RSTCTL1_CLR 0x204 +#define SCU0_RSTCTL1_CLR_EMMC BIT(17) +#define SCU0_RSTCTL1_CLR_HACE BIT(4) +#define SCU0_CLKGATE1 0x240 +#define SCU0_CLKGATE1_EMMC BIT(27) +#define SCU0_CLKGATE1_HACE BIT(13) +#define SCU0_CLKGATE1_DDRPHY BIT(11) +#define SCU0_CLKGATE1_CLR 0x244 +#define SCU0_CLKGATE1_CLR_EMMC BIT(27) +#define SCU0_CLKGATE1_CLR_HACE BIT(13) +#define SCU0_CLKGATE1_CLR_DDRPHY BIT(11) +#define SCU0_VGA0_SCRATCH 0x900 +#define SCU0_VGA0_SCRATCH_DRAM_INIT BIT(6) +#define SCU0_PCI_MISC70 0xa70 +#define SCU0_PCI_MISC70_EN_PCIEXHCI0 BIT(3) +#define SCU0_PCI_MISC70_EN_PCIEEHCI0 BIT(2) +#define SCU0_PCI_MISC70_EN_PCIEVGA0 BIT(0) +#define SCU0_PCI_MISC80 0xa80 +#define SCU0_PCI_MISC80_EN_PCIEXHCI1 BIT(3) +#define SCU0_PCI_MISC80_EN_PCIEEHCI1 BIT(2) +#define SCU0_PCI_MISC80_EN_PCIEVGA1 BIT(0) +#define SCU0_PCI_MISCF0 0xaf0 +#define SCU0_PCI_MISCF0_EN_PCIEXHCI1 BIT(3) +#define SCU0_PCI_MISCF0_EN_PCIEEHCI1 BIT(2) +#define SCU0_PCI_MISCF0_EN_PCIEVGA1 BIT(0) +#define SCU0_WPROT1 0xe04 +#define SCU0_WPROT1_0C8 BIT(18) + +/* SCU1: IO-die SCU */ +#define SCU1_REVISION 0x000 +#define SCU1_REVISION_HWID GENMASK(23, 16) +#define SCU1_REVISION_CHIP_EFUSE GENMASK(15, 8) +#define SCU1_HWSTRAP1 0x010 +#define SCU1_HWSTRAP1_DIS_CPTRA BIT(30) +#define SCU1_HWSTRAP1_RECOVERY_USB_PORT GENMASK(29, 28) +#define SCU1_HWSTRAP1_RECOVERY_INTERFACE GENMASK(27, 26) +#define SCU1_HWSTRAP1_RECOVERY_I3C (BIT(26) | BIT(27)) +#define SCU1_HWSTRAP1_RECOVERY_I2C BIT(27) +#define SCU1_HWSTRAP1_RECOVERY_USB BIT(26) +#define SCU1_HWSTRAP1_SPI_FLASH_4_BYTE_MODE BIT(25) +#define SCU1_HWSTRAP1_SPI_FLASH_WAIT_READY BIT(24) +#define SCU1_HWSTRAP1_BOOT_UFS BIT(23) +#define SCU1_HWSTRAP1_DIS_ROM BIT(22) +#define SCU1_HWSTRAP1_DIS_CPTRAJTAG BIT(20) +#define SCU1_HWSTRAP1_UARTDBGSEL BIT(19) +#define SCU1_HWSTRAP1_DIS_UARTDBG BIT(18) +#define SCU1_HWSTRAP1_DIS_WDTFULL BIT(17) +#define SCU1_HWSTRAP1_DISDEBUG1 BIT(16) +#define SCU1_HWSTRAP1_LTPI0_IO_DRIVING GENMASK(15, 14) +#define SCU1_HWSTRAP1_ACPI_1 BIT(13) +#define SCU1_HWSTRAP1_ACPI_0 BIT(12) +#define SCU1_HWSTRAP1_BOOT_EMMC_UFS BIT(11) +#define SCU1_HWSTRAP1_DDR4 BIT(10) +#define SCU1_HWSTRAP1_LOW_SECURE BIT(8) +#define SCU1_HWSTRAP1_EN_EMCS BIT(7) +#define SCU1_HWSTRAP1_EN_GPIOPT BIT(6) +#define SCU1_HWSTRAP1_EN_SECBOOT BIT(5) +#define SCU1_HWSTRAP1_EN_RECOVERY_BOOT BIT(4) +#define SCU1_HWSTRAP1_LTPI0_EN BIT(3) +#define SCU1_HWSTRAP1_LTPI_IDX BIT(2) +#define SCU1_HWSTRAP1_LTPI1_EN BIT(1) +#define SCU1_HWSTRAP1_LTPI_MODE BIT(0) +#define SCU1_HWSTRAP2 0x030 +#define SCU1_HWSTRAP2_FMC_ABR_SINGLE_FLASH BIT(29) +#define SCU1_HWSTRAP2_FMC_ABR_CS_SWAP_DIS BIT(28) +#define SCU1_HWSTRAP2_SPI_TPM_PCR_EXT_EN BIT(27) +#define SCU1_HWSTRAP2_SPI_TPM_HASH_ALGO GENMASK(26, 25) +#define SCU1_HWSTRAP2_BOOT_SPI_FREQ GENMASK(24, 23) +#define SCU1_HWSTRAP2_RESERVED GENMASK(22, 19) +#define SCU1_HWSTRAP2_FWSPI_CRTM GENMASK(18, 17) +#define SCU1_HWSTRAP2_EN_FWSPIAUX BIT(16) +#define SCU1_HWSTRAP2_FWSPISIZE GENMASK(15, 13) +#define SCU1_HWSTRAP2_DIS_REC BIT(12) +#define SCU1_HWSTRAP2_EN_CPTRA_DBG BIT(11) +#define SCU1_HWSTRAP2_TPM_PCR_INDEX GENMASK(6, 2) +#define SCU1_HWSTRAP2_ROM_CLEAR_SRAM BIT(1) +#define SCU1_HWSTRAP2_ABR BIT(0) +#define SCU1_RSTLOG0 0x050 +#define SCU1_RSTLOG0_BMC_CPU BIT(12) +#define SCU1_RSTLOG0_ABR BIT(2) +#define SCU1_RSTLOG0_EXTRSTN BIT(1) +#define SCU1_RSTLOG0_SRST BIT(0) +#define SCU1_MISC1 0x0c0 +#define SCU1_MISC1_UARTDBG_ROUTE GENMASK(23, 22) +#define SCU1_MISC1_UART12_ROUTE GENMASK(21, 20) +#define SCU1_DBGCTL 0x0c8 +#define SCU1_DBGCTL_MASK GENMASK(7, 0) +#define SCU1_DBGCTL_UARTDBG BIT(6) +#define SCU1_RNG_DATA 0x0f4 +#define SCU1_RSTCTL1 0x200 +#define SCU1_RSTCTL1_I3C(x) (BIT(16) << (x)) +#define SCU1_RSTCTL1_CLR 0x204 +#define SCU1_RSTCTL1_CLR_I3C(x) (BIT(16) << (x)) +#define SCU1_RSTCTL2 0x220 +#define SCU1_RSTCTL2_LTPI1 BIT(22) +#define SCU1_RSTCTL2_LTPI0 BIT(20) +#define SCU1_RSTCTL2_I2C BIT(15) +#define SCU1_RSTCTL2_CPTRA BIT(9) +#define SCU1_RSTCTL2_CLR 0x224 +#define SCU1_RSTCTL2_CLR_I2C BIT(15) +#define SCU1_RSTCTL2_CLR_CPTRA BIT(9) +#define SCU1_CLKGATE1 0x240 +#define SCU1_CLKGATE1_I3C(x) (BIT(16) << (x)) +#define SCU1_CLKGATE1_I2C BIT(15) +#define SCU1_CLKGATE1_CLR 0x244 +#define SCU1_CLKGATE1_CLR_I3C(x) (BIT(16) << (x)) +#define SCU1_CLKGATE1_CLR_I2C BIT(15) +#define SCU1_CLKGATE2 0x260 +#define SCU1_CLKGATE2_LTPI1_TX BIT(19) +#define SCU1_CLKGATE2_LTPI_AHB BIT(10) +#define SCU1_CLKGATE2_LTPI0_TX BIT(9) +#define SCU1_CLKGATE2_CLR 0x264 + +#endif diff --git a/arch/riscv/include/asm/arch-ast2700/sli.h b/arch/riscv/include/asm/arch-ast2700/sli.h new file mode 100644 index 00000000000..42f0f9ac93d --- /dev/null +++ b/arch/riscv/include/asm/arch-ast2700/sli.h @@ -0,0 +1,82 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) Aspeed Technology Inc. + */ +#ifndef __ASM_AST2700_SLI_H__ +#define __ASM_AST2700_SLI_H__ + +#define SLI_CPU_ADRBASE 0x12c17000 +#define SLI_IOD_ADRBASE 0x14c1e000 +#define SLIM_CPU_BASE (SLI_CPU_ADRBASE + 0x000) +#define SLIH_CPU_BASE (SLI_CPU_ADRBASE + 0x200) +#define SLIV_CPU_BASE (SLI_CPU_ADRBASE + 0x400) +#define SLIM_IOD_BASE (SLI_IOD_ADRBASE + 0x000) +#define SLIH_IOD_BASE (SLI_IOD_ADRBASE + 0x200) +#define SLIV_IOD_BASE (SLI_IOD_ADRBASE + 0x400) + +#define SLI_CTRL_I 0x00 +#define SLIV_RAW_MODE BIT(15) +#define SLI_TX_MODE BIT(14) +#define SLI_RX_PHY_LAH_SEL_REV BIT(13) +#define SLI_RX_PHY_LAH_SEL_NEG BIT(12) +#define SLI_AUTO_SEND_TRN_OFF BIT(8) +#define SLI_CLEAR_BUS BIT(6) +#define SLI_TRANS_EN BIT(5) +#define SLI_CLEAR_RX BIT(2) +#define SLI_CLEAR_TX BIT(1) +#define SLI_RESET_TRIGGER BIT(0) +#define SLI_CTRL_II 0x04 +#define SLI_CTRL_III 0x08 +#define SLI_CLK_SEL GENMASK(31, 28) +#define SLI_CLK_500M 0x6 +#define SLI_CLK_200M 0x3 +#define SLI_PHYCLK_SEL GENMASK(27, 24) +#define SLI_PHYCLK_25M 0x0 +#define SLI_PHYCLK_800M 0x1 +#define SLI_PHYCLK_400M 0x2 +#define SLI_PHYCLK_200M 0x3 +#define SLI_PHYCLK_788M 0x5 +#define SLI_PHYCLK_500M 0x6 +#define SLI_PHYCLK_250M 0x7 +#define SLIH_PAD_DLY_TX1 GENMASK(23, 18) +#define SLIH_PAD_DLY_TX0 GENMASK(17, 12) +#define SLIH_PAD_DLY_RX1 GENMASK(11, 6) +#define SLIH_PAD_DLY_RX0 GENMASK(5, 0) +#define SLIM_PAD_DLY_RX3 GENMASK(23, 18) +#define SLIM_PAD_DLY_RX2 GENMASK(17, 12) +#define SLIM_PAD_DLY_RX1 GENMASK(11, 6) +#define SLIM_PAD_DLY_RX0 GENMASK(5, 0) +#define SLI_CTRL_IV 0x0c +#define SLIM_PAD_DLY_TX3 GENMASK(23, 18) +#define SLIM_PAD_DLY_TX2 GENMASK(17, 12) +#define SLIM_PAD_DLY_TX1 GENMASK(11, 6) +#define SLIM_PAD_DLY_TX0 GENMASK(5, 0) +#define SLI_INTR_EN 0x10 +#define SLI_INTR_STATUS 0x14 +#define SLI_INTR_RX_SYNC BIT(15) +#define SLI_INTR_RX_ERR BIT(13) +#define SLI_INTR_RX_NACK BIT(12) +#define SLI_INTR_RX_TRAIN_PKT BIT(10) +#define SLI_INTR_RX_DISCONN BIT(6) +#define SLI_INTR_TX_SUSPEND BIT(4) +#define SLI_INTR_TX_TRAIN BIT(3) +#define SLI_INTR_TX_IDLE BIT(2) +#define SLI_INTR_RX_SUSPEND BIT(1) +#define SLI_INTR_RX_IDLE BIT(0) +#define SLI_INTR_RX_ERRORS \ + (SLI_INTR_RX_ERR | SLI_INTR_RX_NACK | SLI_INTR_RX_DISCONN) + +#define SLIM_MARB_FUNC_I 0x60 +#define SLIM_SLI_MARB_RR BIT(0) + +#define SLI_TARGET_PHYCLK SLI_PHYCLK_400M +#define SLIH_DEFAULT_DELAY 11 +#if (SLI_TARGET_PHYCLK == SLI_PHYCLK_800M) || (SLI_TARGET_PHYCLK == SLI_PHYCLK_788M) +#define SLIM_DEFAULT_DELAY 5 +#define SLIM_LAH_CONFIG 1 +#else +#define SLIM_DEFAULT_DELAY 12 +#define SLIM_LAH_CONFIG 0 +#endif +#endif +int sli_init(void); diff --git a/board/aspeed/ibex_ast2700/Kconfig b/board/aspeed/ibex_ast2700/Kconfig new file mode 100644 index 00000000000..469cea58d12 --- /dev/null +++ b/board/aspeed/ibex_ast2700/Kconfig @@ -0,0 +1,21 @@ +if TARGET_ASPEED_AST2700_IBEX + +config SYS_BOARD + default "ibex_ast2700" + +config SYS_VENDOR + default "aspeed" + +config SYS_CPU + default "ast2700" + +config SYS_CONFIG_NAME + default "ibex_ast2700" + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select RISCV_AST2700 + select SUPPORT_SPL + imply SPL_DRIVERS_MISC + +endif diff --git a/board/aspeed/ibex_ast2700/MAINTAINERS b/board/aspeed/ibex_ast2700/MAINTAINERS new file mode 100644 index 00000000000..777f582a20d --- /dev/null +++ b/board/aspeed/ibex_ast2700/MAINTAINERS @@ -0,0 +1,7 @@ +AST2700 using Ibex RISC-V Core as the boot MCU +M: Chia-Wei, Wang chiawei_wang@aspeedtech.com +S: Maintained +F: arch/riscv/include/asm/arch-ast2700/ +F: board/aspeed/ibex_ast2700/ +F: configs/ibex-ast2700_defconfig +F: include/configs/ibex_ast2700.h diff --git a/board/aspeed/ibex_ast2700/Makefile b/board/aspeed/ibex_ast2700/Makefile new file mode 100644 index 00000000000..162f46fd46a --- /dev/null +++ b/board/aspeed/ibex_ast2700/Makefile @@ -0,0 +1,2 @@ +obj-y += ibex_ast2700.o +obj-y += sli.o diff --git a/board/aspeed/ibex_ast2700/ibex_ast2700.c b/board/aspeed/ibex_ast2700/ibex_ast2700.c new file mode 100644 index 00000000000..e697f9b8baa --- /dev/null +++ b/board/aspeed/ibex_ast2700/ibex_ast2700.c @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) Aspeed Technology Inc. + */ +#include <asm/io.h> +#include <asm/arch/sli.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + int ret; + struct udevice *dev; + struct ram_info ram; + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + printf("cannot get DRAM driver\n"); + return ret; + } + + ret = ram_get_info(dev, &ram); + if (ret) { + printf("cannot get DRAM information\n"); + return ret; + } + + gd->ram_size = ram.size; + + return 0; +} + +int spl_board_init_f(void) +{ + sli_init(); + + dram_init(); + + return 0; +} + +struct legacy_img_hdr *spl_get_load_buffer(ssize_t offset, size_t size) +{ + return (struct legacy_img_hdr *)CONFIG_SYS_LOAD_ADDR; +} + +void *board_spl_fit_buffer_addr(ulong fit_size, int sectors, int bl_len) +{ + return (void *)spl_get_load_buffer(sectors, bl_len); +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_RAM; +} + +int board_init(void) +{ + struct udevice *dev; + int i = 0; + int ret; + + /* + * Loop over all MISC uclass drivers to call the comphy code + * and init all CP110 devices enabled in the DT + */ + while (1) { + /* Call the comphy code via the MISC uclass driver */ + ret = uclass_get_device(UCLASS_MISC, i++, &dev); + + /* We're done, once no further CP110 device is found */ + if (ret) + break; + } + + return 0; +} + +int board_late_init(void) +{ + return 0; +} diff --git a/board/aspeed/ibex_ast2700/sli.c b/board/aspeed/ibex_ast2700/sli.c new file mode 100644 index 00000000000..7868111d844 --- /dev/null +++ b/board/aspeed/ibex_ast2700/sli.c @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) Aspeed Technology Inc. + */ +#include <asm/io.h> +#include <asm/arch/sli.h> +#include <asm/arch/scu.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> + +#define SLI_POLL_TIMEOUT_US 100 + +static void sli_clear_interrupt_status(uint32_t base) +{ + writel(-1, (void *)base + SLI_INTR_STATUS); +} + +static int sli_wait(uint32_t base, uint32_t mask) +{ + uint32_t value; + + sli_clear_interrupt_status(base); + + do { + value = readl((void *)base + SLI_INTR_STATUS); + if (value & SLI_INTR_RX_ERRORS) + return -1; + } while ((value & mask) != mask); + + return 0; +} + +static int sli_wait_suspend(uint32_t base) +{ + return sli_wait(base, SLI_INTR_TX_SUSPEND | SLI_INTR_RX_SUSPEND); +} + +/* + * CPU die --- downstream pads ---> I/O die + * CPU die <--- upstream pads ----- I/O die + * + * US/DS PAD[3:0] : SLIM[3:0] + * US/DS PAD[5:4] : SLIH[1:0] + * US/DS PAD[7:6] : SLIV[1:0] + */ +int sli_init(void) +{ + uint32_t value; + + /* The following training sequence is designed for AST2700A0 */ + value = FIELD_GET(SCU1_REVISION_HWID, readl(SCU1_REVISION)); + if (value) + return 0; + + /* Return if SLI had been calibrated */ + value = readl((void *)SLIH_IOD_BASE + SLI_CTRL_III); + value = FIELD_GET(SLI_CLK_SEL, value); + if (value) { + debug("SLI has been initialized\n"); + return 0; + } + + /* 25MHz PAD delay for AST2700A0 */ + value = SLI_RX_PHY_LAH_SEL_NEG | SLI_TRANS_EN | SLI_CLEAR_BUS; + writel(value, (void *)SLIH_IOD_BASE + SLI_CTRL_I); + writel(value, (void *)SLIM_IOD_BASE + SLI_CTRL_I); + writel(value | SLIV_RAW_MODE, (void *)SLIV_IOD_BASE + SLI_CTRL_I); + sli_wait_suspend(SLIH_IOD_BASE); + sli_wait_suspend(SLIH_CPU_BASE); + + return 0; +} diff --git a/configs/ibex-ast2700_defconfig b/configs/ibex-ast2700_defconfig new file mode 100644 index 00000000000..22629b90489 --- /dev/null +++ b/configs/ibex-ast2700_defconfig @@ -0,0 +1,92 @@ +CONFIG_RISCV=y +CONFIG_SYS_DCACHE_OFF=y +# CONFIG_SPL_USE_ARCH_MEMCPY is not set +# CONFIG_SPL_USE_ARCH_MEMMOVE is not set +# CONFIG_SPL_USE_ARCH_MEMSET is not set +CONFIG_TEXT_BASE=0x80000000 +CONFIG_SYS_MALLOC_LEN=0xf00 +CONFIG_SYS_MALLOC_F_LEN=0xf00 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x14bd7800 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="ast2700-ibex" +CONFIG_SPL_TEXT_BASE=0x14bc0080 +CONFIG_DM_RESET=y +CONFIG_SPL_BSS_START_ADDR=0x14bd7800 +CONFIG_SPL_BSS_MAX_SIZE=0x800 +CONFIG_SPL_SIZE_LIMIT=0x16000 +CONFIG_SPL=y +CONFIG_SYS_MEM_TOP_HIDE=0x10000000 +CONFIG_SYS_LOAD_ADDR=0x83000000 +CONFIG_BUILD_TARGET="" +CONFIG_TARGET_ASPEED_AST2700_IBEX=y +# CONFIG_RISCV_ISA_F is not set +# CONFIG_RISCV_ISA_A is not set +# CONFIG_SPL_SMP is not set +CONFIG_XIP=y +CONFIG_SPL_XIP=y +# CONFIG_AVAILABLE_HARTS is not set +CONFIG_STACK_SIZE_SHIFT=11 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_STACK_SIZE=0x100000 +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x200c0000 +# CONFIG_BOOTSTD is not set +CONFIG_SYS_BOOTM_LEN=0x4000000 +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SYS_CBSIZE=256 +CONFIG_SYS_PBSIZE=276 +# CONFIG_CONSOLE_FLUSH_SUPPORT is not set +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x16000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_BOOTM_LINUX is not set +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SYSBOOT=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_DEVICE_TREE_INCLUDES="ast2700-u-boot.dtsi" +# CONFIG_OF_TAG_MIGRATE is not set +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +CONFIG_SYS_RX_ETH_BUFFER=2 +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_DM_SEQ_ALIAS is not set +# CONFIG_BLOCK_CACHE is not set +# CONFIG_CPU is not set +# CONFIG_GPIO is not set +# CONFIG_I2C is not set +CONFIG_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_SDHCI=y +# CONFIG_MTD is not set +# CONFIG_POWER is not set +CONFIG_RAM=y +CONFIG_SPL_RAM=y +# CONFIG_RAM_SIFIVE is not set +CONFIG_SYS_NS16550=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_LOGO is not set +# CONFIG_RSA is not set +# CONFIG_EFI_LOADER is not set diff --git a/doc/board/aspeed/ibex-ast2700.rst b/doc/board/aspeed/ibex-ast2700.rst new file mode 100644 index 00000000000..511bd081ba2 --- /dev/null +++ b/doc/board/aspeed/ibex-ast2700.rst @@ -0,0 +1,26 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +IBex AST2700 +============ + +AST2700 integrates an IBex RISC-V 32-bits CPU as the boot MCU to execute the +first stage bootlaoder, namely SPL. + +Build +----- + +1. Prepare the toolchains and make sure the $PATH to toolchains is correct. +2. Use `make ibex-ast2700_defconfig` in u-boot root to build the image + +Running U-Boot SPL +------------------ + +The U-Boot SPL will boot in M mode and load the FIT image which includes +the 2nd stage bootloaders executed by the main processor Cortex-A35. + + +Burn U-Boot to SPI Flash +------------------------ + +Use SPI flash programmer (e.g. SF100) to program the u-book-spl.bin with the +offset 0x80 bytes to the SPI flash beginning. diff --git a/doc/board/aspeed/index.rst b/doc/board/aspeed/index.rst new file mode 100644 index 00000000000..d784c88494f --- /dev/null +++ b/doc/board/aspeed/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Aspeed +====== + +.. toctree:: + :maxdepth: 2 + + ibex-ast2700 diff --git a/doc/board/index.rst b/doc/board/index.rst index 417c128c7af..3fb7c84f10c 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -14,6 +14,7 @@ Board-specific doc anbernic/index apple/index armltd/index + aspeed/index asus/index atmel/index beacon/index diff --git a/include/configs/ibex_ast2700.h b/include/configs/ibex_ast2700.h new file mode 100644 index 00000000000..0f6850f7240 --- /dev/null +++ b/include/configs/ibex_ast2700.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) Aspeed Technology Inc. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CFG_SYS_UBOOT_BASE CONFIG_TEXT_BASE +#define CFG_SYS_SDRAM_BASE 0x80000000 + +#endif /* __CONFIG_H */
Add the driver for the AST2700 Ibex timer, which uses CPU cycles as the timer count running at 200MHz.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- drivers/timer/Kconfig | 6 +++++ drivers/timer/Makefile | 1 + drivers/timer/ast_ibex_timer.c | 45 ++++++++++++++++++++++++++++++++++ 3 files changed, 52 insertions(+) create mode 100644 drivers/timer/ast_ibex_timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 6b1de82ae38..cb6fc0e7fda 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -106,6 +106,12 @@ config AST_TIMER This is mostly because they all share several registers which makes it difficult to completely separate them.
+config AST_IBEX_TIMER + bool "Aspeed ast2700 Ibex timer" + depends on TIMER + help + Select this to enable a timer support for the Ibex RV32-based MCUs in AST2700. + config ATCPIT100_TIMER bool "ATCPIT100 timer support" depends on TIMER diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index fb95c8899e3..fec4af392e6 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_$(SPL_)ANDES_PLMT_TIMER) += andes_plmt_timer.o obj-$(CONFIG_ARC_TIMER) += arc_timer.o obj-$(CONFIG_ARM_TWD_TIMER) += arm_twd_timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o +obj-$(CONFIG_AST_IBEX_TIMER) += ast_ibex_timer.o obj-$(CONFIG_ATCPIT100_TIMER) += atcpit100_timer.o obj-$(CONFIG_$(SPL_)ATMEL_PIT_TIMER) += atmel_pit_timer.o obj-$(CONFIG_$(SPL_)ATMEL_TCB_TIMER) += atmel_tcb_timer.o diff --git a/drivers/timer/ast_ibex_timer.c b/drivers/timer/ast_ibex_timer.c new file mode 100644 index 00000000000..261839661e9 --- /dev/null +++ b/drivers/timer/ast_ibex_timer.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 Aspeed Technology Inc. + */ + +#include <asm/csr.h> +#include <asm/io.h> +#include <dm.h> +#include <errno.h> +#include <timer.h> + +#define CSR_MCYCLE 0xb00 +#define CSR_MCYCLEH 0xb80 + +static u64 ast_ibex_timer_get_count(struct udevice *dev) +{ + uint32_t cnt_l, cnt_h; + + cnt_l = csr_read(CSR_MCYCLE); + cnt_h = csr_read(CSR_MCYCLEH); + + return ((uint64_t)cnt_h << 32) | cnt_l; +} + +static int ast_ibex_timer_probe(struct udevice *dev) +{ + return 0; +} + +static const struct timer_ops ast_ibex_timer_ops = { + .get_count = ast_ibex_timer_get_count, +}; + +static const struct udevice_id ast_ibex_timer_ids[] = { + { .compatible = "aspeed,ast2700-ibex-timer" }, + { } +}; + +U_BOOT_DRIVER(ast_ibex_timer) = { + .name = "ast_ibex_timer", + .id = UCLASS_TIMER, + .of_match = ast_ibex_timer_ids, + .probe = ast_ibex_timer_probe, + .ops = &ast_ibex_timer_ops, +};
Define and parse the header of the First Mutable Code (FMC) of AST2700 SoCs at runtime phase.
The FMC header contains the information to load prebuilt binaries required for device initialization such as DRAM and VGA.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/include/asm/arch-ast2700/fmc_hdr.h | 52 +++++++++++++++ board/aspeed/ibex_ast2700/Makefile | 1 + board/aspeed/ibex_ast2700/fmc_hdr.c | 64 +++++++++++++++++++ 3 files changed, 117 insertions(+) create mode 100644 arch/riscv/include/asm/arch-ast2700/fmc_hdr.h create mode 100644 board/aspeed/ibex_ast2700/fmc_hdr.c
diff --git a/arch/riscv/include/asm/arch-ast2700/fmc_hdr.h b/arch/riscv/include/asm/arch-ast2700/fmc_hdr.h new file mode 100644 index 00000000000..fbbcdb25cca --- /dev/null +++ b/arch/riscv/include/asm/arch-ast2700/fmc_hdr.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) ASPEED Technology Inc. + */ + +#ifndef __ASM_AST2700_FMC_HDR_H__ +#define __ASM_AST2700_FMC_HDR_H__ + +#include <linux/types.h> + +#define HDR_MAGIC 0x48545341 /* ASTH */ +#define HDR_PB_MAX 30 + +enum prebuilt_type { + PBT_END_MARK = 0x0, + + PBT_DDR4_PMU_TRAIN_IMEM, + PBT_DDR4_PMU_TRAIN_DMEM, + PBT_DDR4_2D_PMU_TRAIN_IMEM, + PBT_DDR4_2D_PMU_TRAIN_DMEM, + PBT_DDR5_PMU_TRAIN_IMEM, + PBT_DDR5_PMU_TRAIN_DMEM, + PBT_DP_FW, + PBT_UEFI_X64_AST2700, + + PBT_NUM +}; + +struct fmc_hdr_preamble { + uint32_t magic; + uint32_t version; +}; + +struct fmc_hdr_body { + uint32_t fmc_size; + union { + struct { + uint32_t type; + uint32_t size; + } pbs[0]; + uint32_t raz[29]; + }; +}; + +struct fmc_hdr { + struct fmc_hdr_preamble preamble; + struct fmc_hdr_body body; +} __packed; + +int fmc_hdr_get_prebuilt(uint32_t type, uint32_t *ofst, uint32_t *size); + +#endif diff --git a/board/aspeed/ibex_ast2700/Makefile b/board/aspeed/ibex_ast2700/Makefile index 162f46fd46a..3d8eea9166d 100644 --- a/board/aspeed/ibex_ast2700/Makefile +++ b/board/aspeed/ibex_ast2700/Makefile @@ -1,2 +1,3 @@ obj-y += ibex_ast2700.o +obj-y += fmc_hdr.o obj-y += sli.o diff --git a/board/aspeed/ibex_ast2700/fmc_hdr.c b/board/aspeed/ibex_ast2700/fmc_hdr.c new file mode 100644 index 00000000000..2068a906f60 --- /dev/null +++ b/board/aspeed/ibex_ast2700/fmc_hdr.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) Aspeed Technology Inc. + */ + +#include <asm/arch/fmc_hdr.h> +#include <asm/io.h> +#include <asm/sections.h> +#include <errno.h> +#include <spl.h> +#include <string.h> + +int fmc_hdr_get_prebuilt(uint32_t type, uint32_t *ofst, uint32_t *size) +{ + struct fmc_hdr_preamble *preamble; + struct fmc_hdr_body *body; + struct fmc_hdr *hdr; + uint32_t t, s, o; + int i; + + if (type >= PBT_NUM) + return -EINVAL; + + if (!ofst || !size) + return -EINVAL; + + hdr = (struct fmc_hdr *)(_start - sizeof(*hdr)); + preamble = &hdr->preamble; + body = &hdr->body; + + if (preamble->magic != HDR_MAGIC) + return -EIO; + + for (i = 0, o = sizeof(*hdr) + body->fmc_size; i < HDR_PB_MAX; ++i) { + t = body->pbs[i].type; + s = body->pbs[i].size; + + /* skip if unrecognized, yet */ + if (t >= PBT_NUM) { + o += s; + continue; + } + + /* prebuilt end mark */ + if (t == 0 && s == 0) + break; + + /* return the prebuilt info if found */ + if (t == type) { + *ofst = o; + *size = s; + + goto found; + } + + /* update offset for next prebuilt */ + o += s; + } + + return -ENODATA; + +found: + return 0; +}
Add driver for AST2700 to initialize DRAM in SPL.
This patch also refactors the Kconfig dependency of Aspeed DRAM drivers as some of them are shared among the file structures of RV and ARM ISAs.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Acked-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/include/asm/arch-ast2700/sdram.h | 137 + drivers/ram/Makefile | 2 +- drivers/ram/aspeed/Kconfig | 27 +- drivers/ram/aspeed/Makefile | 1 + ..._ddrphy_phyinit_ddr4-3200-nodimm-train2D.c | 2700 +++++++ ..._ddrphy_phyinit_ddr5-3200-nodimm-train2D.c | 6930 +++++++++++++++++ drivers/ram/aspeed/sdram_ast2700.c | 1036 +++ 7 files changed, 10828 insertions(+), 5 deletions(-) create mode 100644 arch/riscv/include/asm/arch-ast2700/sdram.h create mode 100644 drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr4-3200-nodimm-train2D.c create mode 100644 drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr5-3200-nodimm-train2D.c create mode 100644 drivers/ram/aspeed/sdram_ast2700.c
diff --git a/arch/riscv/include/asm/arch-ast2700/sdram.h b/arch/riscv/include/asm/arch-ast2700/sdram.h new file mode 100644 index 00000000000..daf48dd6ed1 --- /dev/null +++ b/arch/riscv/include/asm/arch-ast2700/sdram.h @@ -0,0 +1,137 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) Aspeed Technology Inc. + */ +#ifndef __ASM_AST2700_SDRAM_H__ +#define __ASM_AST2700_SDRAM_H__ + +struct sdrammc_regs { + u32 prot_key; + u32 intr_status; + u32 intr_clear; + u32 intr_mask; + u32 mcfg; + u32 mctl; + u32 msts; + u32 error_status; + u32 actime1; + u32 actime2; + u32 actime3; + u32 actime4; + u32 actime5; + u32 actime6; + u32 actime7; + u32 dfi_timing; + u32 dcfg; + u32 dctl; + u32 mrctl; + u32 mrwr; + u32 mrrd; + u32 mr01; + u32 mr23; + u32 mr45; + u32 mr67; + u32 refctl; + u32 refmng_ctl; + u32 refsts; + u32 zqctl; + u32 ecc_addr_range; + u32 ecc_failure_status; + u32 ecc_failure_addr; + u32 ecc_test_control; + u32 ecc_test_status; + u32 arbctl; + u32 enccfg; + u32 protect_lock_set; + u32 protect_lock_status; + u32 protect_lock_reset; + u32 enc_min_addr; + u32 enc_max_addr; + u32 enc_key[4]; + u32 enc_iv[3]; + u32 bistcfg; + u32 bist_addr; + u32 bist_size; + u32 bist_patt; + u32 bist_res; + u32 bist_fail_addr; + u32 bist_fail_data[4]; + u32 reserved2[2]; + u32 debug_control; + u32 debug_status; + u32 phy_intf_status; + u32 testcfg; + u32 gfmcfg; + u32 gfm0ctl; + u32 gfm1ctl; + u32 reserved3[0xf8]; +}; + +#define DRAMC_UNLK_KEY 0x1688a8a8 + +/* offset 0x04 */ +#define DRAMC_IRQSTA_PWRCTL_ERR BIT(16) +#define DRAMC_IRQSTA_PHY_ERR BIT(15) +#define DRAMC_IRQSTA_LOWPOWER_DONE BIT(12) +#define DRAMC_IRQSTA_FREQ_CHG_DONE BIT(11) +#define DRAMC_IRQSTA_REF_DONE BIT(10) +#define DRAMC_IRQSTA_ZQ_DONE BIT(9) +#define DRAMC_IRQSTA_BIST_DONE BIT(8) +#define DRAMC_IRQSTA_ECC_RCVY_ERR BIT(5) +#define DRAMC_IRQSTA_ECC_ERR BIT(4) +#define DRAMC_IRQSTA_PROT_ERR BIT(3) +#define DRAMC_IRQSTA_OVERSZ_ERR BIT(2) +#define DRAMC_IRQSTA_MR_DONE BIT(1) +#define DRAMC_IRQSTA_PHY_INIT_DONE BIT(0) + +/* offset 0x14 */ +#define DRAMC_MCTL_WB_SOFT_RESET BIT(24) +#define DRAMC_MCTL_PHY_CLK_DIS BIT(18) +#define DRAMC_MCTL_PHY_RESET BIT(17) +#define DRAMC_MCTL_PHY_POWER_ON BIT(16) +#define DRAMC_MCTL_FREQ_CHG_START BIT(3) +#define DRAMC_MCTL_PHY_LOWPOWER_START BIT(2) +#define DRAMC_MCTL_SELF_REF_START BIT(1) +#define DRAMC_MCTL_PHY_INIT_START BIT(0) + +/* offset 0x40 */ +#define DRAMC_DFICFG_WD_POL BIT(18) +#define DRAMC_DFICFG_CKE_OUT BIT(17) +#define DRAMC_DFICFG_RESET BIT(16) + +/* offset 0x48 */ +#define DRAMC_MRCTL_ERR_STATUS BIT(31) +#define DRAMC_MRCTL_READY_STATUS BIT(30) +#define DRAMC_MRCTL_MR_ADDR BIT(8) +#define DRAMC_MRCTL_CMD_DLL_RST BIT(7) +#define DRAMC_MRCTL_CMD_DQ_SEL BIT(6) +#define DRAMC_MRCTL_CMD_TYPE BIT(2) +#define DRAMC_MRCTL_CMD_WR_CTL BIT(1) +#define DRAMC_MRCTL_CMD_START BIT(0) + +/* offset 0xC0 */ +#define DRAMC_BISTRES_RUNNING BIT(10) +#define DRAMC_BISTRES_FAIL BIT(9) +#define DRAMC_BISTRES_DONE BIT(8) +#define DRAMC_BISTCFG_INIT_MODE BIT(7) +#define DRAMC_BISTCFG_PMODE GENMASK(6, 4) +#define DRAMC_BISTCFG_BMODE GENMASK(3, 2) +#define DRAMC_BISTCFG_ENABLE BIT(1) +#define DRAMC_BISTCFG_START BIT(0) +#define BIST_PMODE_CRC (3) +#define BIST_BMODE_RW_SWITCH (3) + +/* DRAMC048 MR Control Register */ +#define MR_TYPE_SHIFT 2 +#define MR_RW (0 << MR_TYPE_SHIFT) +#define MR_MPC BIT(2) +#define MR_VREFCS (2 << MR_TYPE_SHIFT) +#define MR_VREFCA (3 << MR_TYPE_SHIFT) +#define MR_ADDRESS_SHIFT 8 +#define MR_ADDR(n) (((n) << MR_ADDRESS_SHIFT) | DRAMC_MRCTL_CMD_WR_CTL) +#define MR_NUM_SHIFT 4 +#define MR_NUM(n) ((n) << MR_NUM_SHIFT) +#define MR_DLL_RESET BIT(7) +#define MR_1T_MODE BIT(16) + +#endif diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index c9c46cc17a8..fdb2e78ec9e 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/
obj-$(CONFIG_K3_AM654_DDRSS) += k3-am654-ddrss.o obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ -obj-$(CONFIG_ARCH_ASPEED) += aspeed/ +obj-$(CONFIG_ASPEED_RAM) += aspeed/ obj-$(CONFIG_K3_DDRSS) += k3-ddrss/
obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o diff --git a/drivers/ram/aspeed/Kconfig b/drivers/ram/aspeed/Kconfig index 0deab8649b6..e4918460de6 100644 --- a/drivers/ram/aspeed/Kconfig +++ b/drivers/ram/aspeed/Kconfig @@ -1,6 +1,7 @@ menuconfig ASPEED_RAM bool "ASPEED SDRAM configuration" - depends on RAM && ARCH_ASPEED + depends on RAM + depends on ARCH_ASPEED || TARGET_ASPEED_AST2700_IBEX default ARCH_ASPEED help Configuration options for DDR SDRAM on ASPEED systems. @@ -8,8 +9,6 @@ menuconfig ASPEED_RAM RAM initialisation is always built in for the platform. This menu allows customisation of the configuration used.
-if ASPEED_RAM - config ASPEED_DDR4_DUALX8 bool "Enable Dual X8 DDR4 die" depends on ASPEED_RAM @@ -74,4 +73,24 @@ config ASPEED_DDR4_1600 select DDR4 target data rate at 1600M endchoice
-endif # End of ASPEED_RAM +choice + prompt "AST2700 DDR target date rate" + default ASPEED_DDR_3200 + depends on ASPEED_RAM + depends on TARGET_ASPEED_AST2700_IBEX + +config ASPEED_DDR_1600 + bool "1600 Mbps" + help + select DDR target data rate at 1600M + +config ASPEED_DDR_2400 + bool "2400 Mbps" + help + select DDR target data rate at 2400M + +config ASPEED_DDR_3200 + bool "3200 Mbps" + help + select DDR target data rate at 3200M +endchoice diff --git a/drivers/ram/aspeed/Makefile b/drivers/ram/aspeed/Makefile index 7ac10af1c22..1f0b22c8e9f 100644 --- a/drivers/ram/aspeed/Makefile +++ b/drivers/ram/aspeed/Makefile @@ -2,3 +2,4 @@ # obj-$(CONFIG_ASPEED_AST2500) += sdram_ast2500.o obj-$(CONFIG_ASPEED_AST2600) += sdram_ast2600.o +obj-$(CONFIG_TARGET_ASPEED_AST2700_IBEX) += sdram_ast2700.o diff --git a/drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr4-3200-nodimm-train2D.c b/drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr4-3200-nodimm-train2D.c new file mode 100644 index 00000000000..de593c17fad --- /dev/null +++ b/drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr4-3200-nodimm-train2D.c @@ -0,0 +1,2700 @@ +// SPDX-License-Identifier: GPL-2.0+ +// [dwc_ddrphy_phyinit_main] Start of dwc_ddrphy_phyinit_main() +// [dwc_ddrphy_phyinit_sequence] Start of dwc_ddrphy_phyinit_sequence() +// [dwc_ddrphy_phyinit_initStruct] Start of dwc_ddrphy_phyinit_initStruct() +// [dwc_ddrphy_phyinit_initStruct] End of dwc_ddrphy_phyinit_initStruct() +// [dwc_ddrphy_phyinit_setDefault] Start of dwc_ddrphy_phyinit_setDefault() +// [dwc_ddrphy_phyinit_setDefault] End of dwc_ddrphy_phyinit_setDefault() + +////############################################################## +// +//// dwc_ddrphy_phyinit_userCustom_overrideUserInput is a user-editable function. User can edit this function according to their needs. +//// +//// The purpose of dwc_ddrphy_phyinit_userCustom_overrideUserInput() is to override any +//// any field in Phyinit data structure set by dwc_ddrphy_phyinit_setDefault() +//// User should only override values in userInputBasic and userInputAdvanced. +//// IMPORTANT: in this function, user shall not override any values in the +//// messageblock directly on the data structue as the might be overwritten by +//// dwc_ddrphy_phyinit_calcMb(). Use dwc_ddrphy_phyinit_setMb() to set +//// messageblock parameters for override values to remain pervasive if +//// desired +// +////############################################################## + +dwc_ddrphy_phyinit_userCustom_overrideUserInput(); +// +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramType' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DimmType' to 0x4 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumDbyte' to 0x2 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumActiveDbyteDfi0' to 0x2 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumAnib' to 0xa +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumRank_dfi0' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[0]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[1]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[2]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[3]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumPStates' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Frequency[0]' to 0x640 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PllBypass[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DfiFreqRatio[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Dfi1Exists' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'D4RxPreambleLength[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'D4TxPreambleLength[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'ExtCalResVal' to 0xf0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Is2Ttiming[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'ODTImpedance[0]' to 0x78 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxImpedance[0]' to 0x3c +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'MemAlertEn' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'MtestPUImp' to 0xf0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DisDynAdrTri[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PhyMstrTrainInterval[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PhyMstrMaxReqToAck[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PhyMstrCtrlMode[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'WDQSExt' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'CalInterval' to 0x9 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'CalOnce' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'RxEnBackOff' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TrainSequenceCtrl' to 0x31f +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'SnpsUmctlOpt' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'SnpsUmctlF0RC5x[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewRiseDQ[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewFallDQ[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewRiseAC' to 0x45 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewFallAC' to 0xa +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'IsHighVDD' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewRiseCK' to 0x52 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewFallCK' to 0x12 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DisablePmuEcc' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnableMAlertAsync' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Apb32BitMode' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tDQS2DQ' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tDQSCK' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_override' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][1]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][2]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][3]' to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MsgMisc to 0x7 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].Pstate to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].PllBypassEn to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].DRAMFreq to 0xc80 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].PhyVref to 0x40 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].DramType to 0x2 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].DisabledDbyte to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].EnabledDQs to 0x10 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].CsPresent to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].CsPresentD0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].CsPresentD1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AddrMirror to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].PhyCfg to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].SequenceCtrl to 0x31f +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].HdtCtrl to 0xc8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].PhyConfigOverride to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].DFIMRLMargin to 0x2 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR0 to 0x2150 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR1 to 0x101 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR2 to 0x228 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR3 to 0x400 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR4 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR5 to 0x500 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].MR6 to 0x104f +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].X16Present to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].CsSetupGDDec to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl4 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl5 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl6 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].AcsmOdtCtrl7 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR0Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR1Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR2Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].VrefDqR3Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].ALT_CAS_L to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].ALT_WCAS_L to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].D4Misc to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].ExtTrainOpt to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_1D[0].NVDIMM to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MsgMisc to 0x7 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].Pstate to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].PllBypassEn to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].DRAMFreq to 0xc80 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].PhyVref to 0x40 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].DramType to 0x2 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].DisabledDbyte to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].EnabledDQs to 0x10 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].CsPresent to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].CsPresentD0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].CsPresentD1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AddrMirror to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].PhyCfg to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].SequenceCtrl to 0x31f +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].HdtCtrl to 0xc8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].PhyConfigOverride to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].DFIMRLMargin to 0x2 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR0 to 0x2150 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR1 to 0x101 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR2 to 0x228 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR3 to 0x400 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR4 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR5 to 0x500 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].MR6 to 0x104f +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].X16Present to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].CsSetupGDDec to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl4 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl5 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl6 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].AcsmOdtCtrl7 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR0Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR1Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR2Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib0 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib1 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib2 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib3 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib4 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib5 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib6 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib7 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib8 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib9 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib10 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib11 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib12 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib13 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib14 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib15 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib16 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib17 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib18 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].VrefDqR3Nib19 to 0xf +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].ALT_CAS_L to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].ALT_WCAS_L to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].D4Misc to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].ExtTrainOpt to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR4U_2D[0].NVDIMM to 0x0 +// [dwc_ddrphy_phyinit_userCustom_overrideUserInput] End of dwc_ddrphy_phyinit_userCustom_overrideUserInput() +//[dwc_ddrphy_phyinit_calcMb] Start of dwc_ddrphy_phyinit_calcMb() +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].DramType override to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].Pstate override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].DRAMFreq override to 0xc80 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].PllBypassEn override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].EnabledDQs override to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].PhyCfg override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].DisabledDbyte override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_1D[0].X16Present override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].DramType to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].Pstate to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].DRAMFreq to 0x856 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].PllBypassEn to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].EnabledDQs to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].PhyCfg to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].DisabledDbyte to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[1].X16Present to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].DramType to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].Pstate to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].DRAMFreq to 0x74a +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].PllBypassEn to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].EnabledDQs to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].PhyCfg to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].DisabledDbyte to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[2].X16Present to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].DramType to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].Pstate to 0x3 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].DRAMFreq to 0x640 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].PllBypassEn to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].EnabledDQs to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].PhyCfg to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].DisabledDbyte to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR4U_1D[3].X16Present to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].DramType override to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].Pstate override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].DRAMFreq override to 0xc80 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].PllBypassEn override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].EnabledDQs override to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].PhyCfg override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].DisabledDbyte override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR4U_2D[0].X16Present override to 0x0 +////[dwc_ddrphy_phyinit_calcMb] TG_active[0] = 1 +////[dwc_ddrphy_phyinit_calcMb] TG_active[1] = 0 +////[dwc_ddrphy_phyinit_calcMb] TG_active[2] = 0 +////[dwc_ddrphy_phyinit_calcMb] TG_active[3] = 0 +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=0] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=0] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=0] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=1] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=1] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=1] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=2] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=2] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=2] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=3] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=3] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=3] = 0 ps +//[dwc_ddrphy_phyinit_calcMb] End of dwc_ddrphy_phyinit_calcMb() +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // Printing values in user input structure +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] pUserInputBasic->Frequency[0] = 1600 +//// [phyinit_print_dat] pUserInputBasic->Frequency[1] = 1067 +//// [phyinit_print_dat] pUserInputBasic->Frequency[2] = 933 +//// [phyinit_print_dat] pUserInputBasic->Frequency[3] = 800 +//// [phyinit_print_dat] pUserInputBasic->NumAnib = 10 +//// [phyinit_print_dat] pUserInputBasic->DramType = 0 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitValOvr = 0 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[0] = 3 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[1] = 3 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[2] = 3 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[3] = 3 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[0] = 1 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[1] = 1 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[2] = 1 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[3] = 1 +//// [phyinit_print_dat] pUserInputBasic->NumActiveDbyteDfi0 = 2 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[0] = 0 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[1] = 0 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[2] = 0 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[3] = 0 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[0] = 16 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[1] = 16 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[2] = 16 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[3] = 16 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[0] = 0 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[1] = 0 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[2] = 0 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[3] = 0 +//// [phyinit_print_dat] pUserInputBasic->Dfi1Exists = 0 +//// [phyinit_print_dat] pUserInputBasic->Train2D = 0 +//// [phyinit_print_dat] pUserInputBasic->NumRank_dfi0 = 1 +//// [phyinit_print_dat] pUserInputBasic->DimmType = 4 +//// [phyinit_print_dat] pUserInputBasic->NumPStates = 1 +//// [phyinit_print_dat] pUserInputBasic->NumDbyte = 2 +//// [phyinit_print_dat] pUserInputAdvanced->DisablePmuEcc = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[1] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[2] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[3] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[4] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[5] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[6] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[7] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlOpt = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[0] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[1] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[2] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[3] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallAC = 10 +//// [phyinit_print_dat] pUserInputAdvanced->CalOnce = 0 +//// [phyinit_print_dat] pUserInputAdvanced->ExtCalResVal = 240 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[2] = 11 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[3] = 11 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[4] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[5] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[6] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[7] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->CalInterval = 9 +//// [phyinit_print_dat] pUserInputAdvanced->IsHighVDD = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseAC = 69 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseCK = 82 +//// [phyinit_print_dat] pUserInputAdvanced->RedundantCs_en = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TrainSequenceCtrl = 799 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->MtestPUImp = 240 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[1] = 3 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[2] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[3] = 3 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[4] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[5] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[6] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[7] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AlertRecoveryEnable = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->VREGCtrl_LP2_PwrSavings_En = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[1] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[2] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[3] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallCK = 18 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[0] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[1] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[2] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[3] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->en_16LogicalRanks_3DS = 0 +//// [phyinit_print_dat] pUserInputAdvanced->RstRxTrkState = 0 +//// [phyinit_print_dat] pUserInputAdvanced->Is2Ttiming[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->Is2Ttiming[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->Is2Ttiming[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->Is2Ttiming[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->MemAlertEn = 0 +//// [phyinit_print_dat] pUserInputAdvanced->rtt_term_en = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->WDQSExt = 0 +//// [phyinit_print_dat] pUserInputAdvanced->en_3DS = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[0] = 120 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[1] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[2] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[3] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->EnableMAlertAsync = 0 +//// [phyinit_print_dat] pUserInputAdvanced->Apb32BitMode = 1 +//// [phyinit_print_dat] pUserInputAdvanced->Nibble_ECC = 15 +//// [phyinit_print_dat] pUserInputAdvanced->RxEnBackOff = 1 +//// [phyinit_print_dat] pUserInputAdvanced->ATxImpedance = 53247 +//// [phyinit_print_dat] pUserInputSim->tDQS2DQ = 0 +//// [phyinit_print_dat] pUserInputSim->tDQSCK = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[0] = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[1] = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[2] = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[3] = 0 +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // Printing values of 1D message block input/inout fields, PState=0 +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] mb_DDR4U_1D[0].AdvTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MsgMisc = 0x7 +//// [phyinit_print_dat] mb_DDR4U_1D[0].Pstate = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PllBypassEn = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DRAMFreq = 0xc80 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PhyVref = 0x40 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DramType = 0x2 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DisabledDbyte = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].EnabledDQs = 0x10 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsPresent = 0x1 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsPresentD0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsPresentD1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AddrMirror = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PhyCfg = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].SequenceCtrl = 0x31f +//// [phyinit_print_dat] mb_DDR4U_1D[0].HdtCtrl = 0xc8 +//// [phyinit_print_dat] mb_DDR4U_1D[0].Rx2D_CmdSpacing = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MREP_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DWL_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PhyConfigOverride = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DFIMRLMargin = 0x2 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DDR4_RXEN_OFFSET = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR0 = 0x2150 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR1 = 0x101 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR2 = 0x228 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR3 = 0x400 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR5 = 0x500 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR6 = 0x104f +//// [phyinit_print_dat] mb_DDR4U_1D[0].X16Present = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsSetupGDDec = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].ALT_CAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].ALT_WCAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].D4Misc = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].ExtTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].NVDIMM = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AdvTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MsgMisc = 0x7 +//// [phyinit_print_dat] mb_DDR4U_1D[0].Pstate = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PllBypassEn = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DRAMFreq = 0xc80 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PhyVref = 0x40 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DramType = 0x2 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DisabledDbyte = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].EnabledDQs = 0x10 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsPresent = 0x1 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsPresentD0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsPresentD1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AddrMirror = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PhyCfg = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].SequenceCtrl = 0x31f +//// [phyinit_print_dat] mb_DDR4U_1D[0].HdtCtrl = 0xc8 +//// [phyinit_print_dat] mb_DDR4U_1D[0].Rx2D_CmdSpacing = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MREP_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DWL_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].PhyConfigOverride = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DFIMRLMargin = 0x2 +//// [phyinit_print_dat] mb_DDR4U_1D[0].DDR4_RXEN_OFFSET = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR0 = 0x2150 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR1 = 0x101 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR2 = 0x228 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR3 = 0x400 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR5 = 0x500 +//// [phyinit_print_dat] mb_DDR4U_1D[0].MR6 = 0x104f +//// [phyinit_print_dat] mb_DDR4U_1D[0].X16Present = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].CsSetupGDDec = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].RTT_NOM_WR_PARK7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].AcsmOdtCtrl7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR0Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR1Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR2Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].VrefDqR3Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_1D[0].ALT_CAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].ALT_WCAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].D4Misc = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].ExtTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_1D[0].NVDIMM = 0x0 +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // Printing values of 2D message block input/inout fields, PState=0 +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] mb_DDR4U_2D[0].AdvTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MsgMisc = 0x7 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Pstate = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PllBypassEn = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DRAMFreq = 0xc80 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PhyVref = 0x40 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DramType = 0x2 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DisabledDbyte = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].EnabledDQs = 0x10 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsPresent = 0x1 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsPresentD0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsPresentD1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AddrMirror = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PhyCfg = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].SequenceCtrl = 0x31f +//// [phyinit_print_dat] mb_DDR4U_2D[0].HdtCtrl = 0xc8 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].TX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Share2DVrefResult = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Delay_Weight2D = 0x20 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Voltage_Weight2D = 0x80 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Rx2D_CmdSpacing = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MREP_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DWL_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PhyConfigOverride = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DFIMRLMargin = 0x2 +//// [phyinit_print_dat] mb_DDR4U_2D[0].VoltageRange2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR1_EQU_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].advSearch_rd2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].advSearch_wr2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].moreDebug2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR6_EQU_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].TX2D_DB_DFE_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsWriteNoise = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AdvTrainOpt2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Misc2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR0 = 0x2150 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR1 = 0x101 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR2 = 0x228 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR3 = 0x400 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR5 = 0x500 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR6 = 0x104f +//// [phyinit_print_dat] mb_DDR4U_2D[0].X16Present = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsSetupGDDec = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].ALT_CAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].ALT_WCAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].D4Misc = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].ExtTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].NVDIMM = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AdvTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MsgMisc = 0x7 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Pstate = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PllBypassEn = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DRAMFreq = 0xc80 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PhyVref = 0x40 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DramType = 0x2 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DisabledDbyte = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].EnabledDQs = 0x10 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsPresent = 0x1 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsPresentD0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsPresentD1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AddrMirror = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PhyCfg = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].SequenceCtrl = 0x31f +//// [phyinit_print_dat] mb_DDR4U_2D[0].HdtCtrl = 0xc8 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].TX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Share2DVrefResult = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Delay_Weight2D = 0x20 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Voltage_Weight2D = 0x80 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Rx2D_CmdSpacing = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MREP_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DWL_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].PhyConfigOverride = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].DFIMRLMargin = 0x2 +//// [phyinit_print_dat] mb_DDR4U_2D[0].VoltageRange2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR1_EQU_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].advSearch_rd2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].advSearch_wr2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].moreDebug2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR6_EQU_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].TX2D_DB_DFE_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsWriteNoise = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AdvTrainOpt2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].Misc2D = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR0 = 0x2150 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR1 = 0x101 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR2 = 0x228 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR3 = 0x400 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR5 = 0x500 +//// [phyinit_print_dat] mb_DDR4U_2D[0].MR6 = 0x104f +//// [phyinit_print_dat] mb_DDR4U_2D[0].X16Present = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].CsSetupGDDec = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].RTT_NOM_WR_PARK7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl0 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl1 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl2 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl3 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl4 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl5 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl6 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].AcsmOdtCtrl7 = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR0Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR1Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR2Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib0 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib1 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib2 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib3 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib4 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib5 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib6 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib7 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib8 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib9 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib10 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib11 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib12 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib13 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib14 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib15 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib16 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib17 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib18 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].VrefDqR3Nib19 = 0xf +//// [phyinit_print_dat] mb_DDR4U_2D[0].ALT_CAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].ALT_WCAS_L = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].D4Misc = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].ExtTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR4U_2D[0].NVDIMM = 0x0 + +////############################################################## +//// +//// Step (A) : Bring up VDD, VDDQ, and VAA +//// +//// The power supplies can come up and stabilize in any order. +//// While the power supplies are coming up, all outputs will be unknown and +//// the values of the inputs are don't cares. +//// +////############################################################## + +dwc_ddrphy_phyinit_userCustom_A_bringupPower(); + +//[dwc_ddrphy_phyinit_userCustom_A_bringupPower] End of dwc_ddrphy_phyinit_userCustom_A_bringupPower() +// +// +////############################################################## +//// +//// 4.3.2(B) Start Clocks and Reset the PHY +//// +//// Following is one possbile sequence to reset the PHY. Other sequences are also possible. +//// See section 5.2.2 of the PUB for other possible reset sequences. +//// +//// 1. Drive PwrOkIn to 0. Note: Reset, DfiClk, and APBCLK can be X. +//// 2. Start DfiClk and APBCLK +//// 3. Drive Reset to 1 and PRESETn_APB to 0. +//// Note: The combination of PwrOkIn=0 and Reset=1 signals a cold reset to the PHY. +//// 4. Wait a minimum of 8 cycles. +//// 5. Drive PwrOkIn to 1. Once the PwrOkIn is asserted (and Reset is still asserted), +//// DfiClk synchronously switches to any legal input frequency. +//// 6. Wait a minimum of 64 cycles. Note: This is the reset period for the PHY. +//// 7. Drive Reset to 0. Note: All DFI and APB inputs must be driven at valid reset states before the deassertion of Reset. +//// 8. Wait a minimum of 1 Cycle. +//// 9. Drive PRESETn_APB to 1 to de-assert reset on the ABP bus. +////10. The PHY is now in the reset state and is ready to accept APB transactions. +//// +////############################################################## +// +// +dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy(sdrammc); + +//// [dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy] End of dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy() +// + +////############################################################## +//// +//// Step (C) Initialize PHY Configuration +//// +//// Load the required PHY configuration registers for the appropriate mode and memory configuration +//// +////############################################################## +// + +//// [phyinit_C_initPhyConfig] Start of dwc_ddrphy_phyinit_C_initPhyConfig() +//// [phyinit_C_initPhyConfig] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x1 +dwc_ddrphy_apb_wr(0x200a6, 0x2); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for MASTER +dwc_ddrphy_apb_wr(0x20066, 0x0); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all DBYTEs +dwc_ddrphy_apb_wr(0x10066, 0x0); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x11066, 0x0); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all ANIBs +dwc_ddrphy_apb_wr(0x66, 0x0); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x1066, 0x0); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x2066, 0x0); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x3066, 0x0); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x4066, 0x0); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x5066, 0x0); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x6066, 0x0); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x7066, 0x0); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x8066, 0x0); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x9066, 0x0); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl1::VshDAC to 0x31 for MASTER +dwc_ddrphy_apb_wr(0x20029, 0xc4); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl1_p0 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl1::VshDAC to 0x31 for all DBYTEs +dwc_ddrphy_apb_wr(0x10029, 0xc4); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x11029, 0xc4); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl1_p0 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl1::VshDAC to 0x31 for all ANIBs +dwc_ddrphy_apb_wr(0x29, 0xc4); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x1029, 0xc4); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x2029, 0xc4); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x3029, 0xc4); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x4029, 0xc4); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x5029, 0xc4); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x6029, 0xc4); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x7029, 0xc4); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x8029, 0xc4); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x9029, 0xc4); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxSlewRate::CsrTxSrc to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxSlewRate::TxPreDrvMode to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxSlewRate to 0x0 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for TxSlewRate::CsrTxSrc are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult the "Output Slew Rate" section of HSpice Model App Note in specific technology for recommended settings + +dwc_ddrphy_apb_wr(0x1005f, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxSlewRate_b0_p0 +dwc_ddrphy_apb_wr(0x1015f, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxSlewRate_b1_p0 +dwc_ddrphy_apb_wr(0x1105f, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxSlewRate_b0_p0 +dwc_ddrphy_apb_wr(0x1115f, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxSlewRate_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::ATxPreDrvMode to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 0 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 0 to 0x11e +dwc_ddrphy_apb_wr(0x55, 0x11e); // DWC_DDRPHYA_ANIB0_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 1 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 1 to 0x11e +dwc_ddrphy_apb_wr(0x1055, 0x11e); // DWC_DDRPHYA_ANIB1_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 2 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 2 to 0x11e +dwc_ddrphy_apb_wr(0x2055, 0x11e); // DWC_DDRPHYA_ANIB2_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 3 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 3 to 0x11e +dwc_ddrphy_apb_wr(0x3055, 0x11e); // DWC_DDRPHYA_ANIB3_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 4 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 4 to 0x11e +dwc_ddrphy_apb_wr(0x4055, 0x11e); // DWC_DDRPHYA_ANIB4_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 5 to 0x15a +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 5 to 0x15a +dwc_ddrphy_apb_wr(0x5055, 0x15a); // DWC_DDRPHYA_ANIB5_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 6 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 6 to 0x11e +dwc_ddrphy_apb_wr(0x6055, 0x11e); // DWC_DDRPHYA_ANIB6_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 7 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 7 to 0x11e +dwc_ddrphy_apb_wr(0x7055, 0x11e); // DWC_DDRPHYA_ANIB7_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 8 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 8 to 0x11e +dwc_ddrphy_apb_wr(0x8055, 0x11e); // DWC_DDRPHYA_ANIB8_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 9 to 0x11e +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 9 to 0x11e +dwc_ddrphy_apb_wr(0x9055, 0x11e); // DWC_DDRPHYA_ANIB9_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for ATxSlewRate::CsrATxSrc are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult the "Output Slew Rate" section of HSpice Model App Note in specific technology for recommended settings + +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride::CsrTxOvSrc to 0x172 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride::TxCalBaseN to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride::TxCalBaseP to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride to 0x372 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for CalPreDriverOverride::CsrTxOvSrc are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult the "Output Slew Rate" section of HSpice Model App Note in specific technology for recommended settings + +dwc_ddrphy_apb_wr(0x2008c, 0x372); // DWC_DDRPHYA_MASTER0_base0_CalPreDriverOverride +//// [phyinit_C_initPhyConfig] PUB revision is 0x0350. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl2::PllFreqSel to 0x19 based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200c5, 0x19); // DWC_DDRPHYA_MASTER0_base0_PllCtrl2_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl1::PllCpPropCtrl to 0x3 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl1::PllCpIntCtrl to 0x1 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl1 to 0x61 based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200c7, 0x61); // DWC_DDRPHYA_MASTER0_base0_PllCtrl1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllTestMode to 0x400f based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200ca, 0x400f); // DWC_DDRPHYA_MASTER0_base0_PllTestMode_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl4::PllCpPropGsCtrl to 0x6 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl4::PllCpIntGsCtrl to 0x12 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl4 to 0xd2 based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200cc, 0xd2); // DWC_DDRPHYA_MASTER0_base0_PllCtrl4_p0 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for PllCtrl1 and PllTestMode are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult technology specific PHY Databook for recommended settings + +// +////############################################################## +//// +//// Program ARdPtrInitVal based on Frequency and PLL Bypass inputs +//// The values programmed here assume ideal properties of DfiClk +//// and Pclk including: +//// - DfiClk skew +//// - DfiClk jitter +//// - DfiClk PVT variations +//// - Pclk skew +//// - Pclk jitter +//// +//// PLL Bypassed mode: +//// For MemClk frequency > 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 2-5 +//// For MemClk frequency < 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 1-5 +//// +//// PLL Enabled mode: +//// For MemClk frequency > 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 1-5 +//// For MemClk frequency < 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 0-5 +//// +////############################################################## +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ARdPtrInitVal to 0x1 +dwc_ddrphy_apb_wr(0x2002e, 0x1); // DWC_DDRPHYA_MASTER0_base0_ARdPtrInitVal_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DisPtrInitClrTxTracking to 0x0 +dwc_ddrphy_apb_wr(0x20051, 0x0); // DWC_DDRPHYA_MASTER0_base0_PtrInitTrackingModeCntrl_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::TwoTckRxDqsPre to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::TwoTckTxDqsPre to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::PositionDfeInit to 0x2 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::DDR5RxPreamble to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::DDR5RxPostamble to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl to 0x8 +dwc_ddrphy_apb_wr(0x20024, 0x8); // DWC_DDRPHYA_MASTER0_base0_DqsPreambleControl_p0 +//// [phyinit_C_initPhyConfig] Programming DbyteDllModeCntrl::DllRxPreambleMode to 0x1 +//// [phyinit_C_initPhyConfig] Programming DbyteDllModeCntrl::DllRxBurstLengthMode to 0x0 +//// [phyinit_C_initPhyConfig] Programming DbyteDllModeCntrl to 0x2 +dwc_ddrphy_apb_wr(0x2003a, 0x2); // DWC_DDRPHYA_MASTER0_base0_DbyteDllModeCntrl +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxOdtDrvStren::TxOdtStrenPu to 0x4 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxOdtDrvStren::TxOdtStrenPd to 0x0 +dwc_ddrphy_apb_wr(0x1004d, 0x4); // DWC_DDRPHYA_DBYTE0_base0_TxOdtDrvStren_b0_p0 +dwc_ddrphy_apb_wr(0x1014d, 0x4); // DWC_DDRPHYA_DBYTE0_base0_TxOdtDrvStren_b1_p0 +dwc_ddrphy_apb_wr(0x1104d, 0x4); // DWC_DDRPHYA_DBYTE1_base0_TxOdtDrvStren_b0_p0 +dwc_ddrphy_apb_wr(0x1114d, 0x4); // DWC_DDRPHYA_DBYTE1_base0_TxOdtDrvStren_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ADrvStrenP to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ADrvStrenN to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ATxReserved13x12 to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ATxCalBaseN to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ATxCalBaseP to 0x1 +dwc_ddrphy_apb_wr(0x43, 0xcfff); // DWC_DDRPHYA_ANIB0_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x1043, 0xcfff); // DWC_DDRPHYA_ANIB1_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x2043, 0xcfff); // DWC_DDRPHYA_ANIB2_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x3043, 0xcfff); // DWC_DDRPHYA_ANIB3_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x4043, 0xcfff); // DWC_DDRPHYA_ANIB4_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x5043, 0xcfff); // DWC_DDRPHYA_ANIB5_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x6043, 0xcfff); // DWC_DDRPHYA_ANIB6_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x7043, 0xcfff); // DWC_DDRPHYA_ANIB7_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x8043, 0xcfff); // DWC_DDRPHYA_ANIB8_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x9043, 0xcfff); // DWC_DDRPHYA_ANIB9_base0_ATxImpedance +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl0::TxStrenEqHiPu to 0xc +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl0::TxStrenEqLoPd to 0xc +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl1::TxStrenPu to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl1::TxStrenPd to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl2::TxStrenEqLoPu to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl2::TxStrenEqHiPd to 0x0 +dwc_ddrphy_apb_wr(0x10041, 0x30c); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl0_b0_p0 +dwc_ddrphy_apb_wr(0x10049, 0xfff); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl1_b0_p0 +dwc_ddrphy_apb_wr(0x1004b, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl2_b0_p0 +dwc_ddrphy_apb_wr(0x10141, 0x30c); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl0_b1_p0 +dwc_ddrphy_apb_wr(0x10149, 0xfff); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl1_b1_p0 +dwc_ddrphy_apb_wr(0x1014b, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl2_b1_p0 +dwc_ddrphy_apb_wr(0x11041, 0x30c); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl0_b0_p0 +dwc_ddrphy_apb_wr(0x11049, 0xfff); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl1_b0_p0 +dwc_ddrphy_apb_wr(0x1104b, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl2_b0_p0 +dwc_ddrphy_apb_wr(0x11141, 0x30c); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl0_b1_p0 +dwc_ddrphy_apb_wr(0x11149, 0xfff); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl1_b1_p0 +dwc_ddrphy_apb_wr(0x1114b, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl2_b1_p0 +//// [phyinit_C_initPhyConfig] Programming DfiMode to 0x1 +dwc_ddrphy_apb_wr(0x20018, 0x1); // DWC_DDRPHYA_MASTER0_base0_DfiMode +//// [phyinit_C_initPhyConfig] Programming DfiCAMode to 0x2 +dwc_ddrphy_apb_wr(0x20075, 0x2); // DWC_DDRPHYA_MASTER0_base0_DfiCAMode +//// [phyinit_C_initPhyConfig] Programming CalDrvStr0::CalDrvStrPd50 to 0x2 +//// [phyinit_C_initPhyConfig] Programming CalDrvStr0::CalDrvStrPu50 to 0x2 +dwc_ddrphy_apb_wr(0x20050, 0x82); // DWC_DDRPHYA_MASTER0_base0_CalDrvStr0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalUclkInfo::CalUClkTicksPer1uS to 0x320 +dwc_ddrphy_apb_wr(0x20008, 0x320); // DWC_DDRPHYA_MASTER0_base0_CalUclkInfo_p0 +//// [phyinit_C_initPhyConfig] Programming CalRate::CalInterval to 0x9 +//// [phyinit_C_initPhyConfig] Programming CalRate::CalOnce to 0x0 +dwc_ddrphy_apb_wr(0x20088, 0x9); // DWC_DDRPHYA_MASTER0_base0_CalRate +//// [phyinit_C_initPhyConfig] Pstate=0, Programming VrefInGlobal::GlobalVrefInSel to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming VrefInGlobal::GlobalVrefInDAC to 0x1f +//// [phyinit_C_initPhyConfig] Pstate=0, Programming VrefInGlobal to 0xf8 +dwc_ddrphy_apb_wr(0x200b2, 0xf8); // DWC_DDRPHYA_MASTER0_base0_VrefInGlobal_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=0, Upper/Lower=0) to 0x2500 +dwc_ddrphy_apb_wr(0x10043, 0x2500); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl_b0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=0, Upper/Lower=1) to 0x2500 +dwc_ddrphy_apb_wr(0x10143, 0x2500); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=1, Upper/Lower=0) to 0x2500 +dwc_ddrphy_apb_wr(0x11043, 0x2500); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl_b0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=1, Upper/Lower=1) to 0x2500 +dwc_ddrphy_apb_wr(0x11143, 0x2500); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl2 to 0x1c +dwc_ddrphy_apb_wr(0x1004c, 0x1c); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl2_p0 +dwc_ddrphy_apb_wr(0x1104c, 0x1c); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl2_p0 +//// [phyinit_C_initPhyConfig] Programming ATxOdtDrvStren of ANIB_0 to 0x0 +dwc_ddrphy_apb_wr(0x42, 0x0); // DWC_DDRPHYA_ANIB0_base0_ATxOdtDrvStren +//// [phyinit_C_initPhyConfig] Programming ATxOdtDrvStren of ANIB_0 to 0x0 +dwc_ddrphy_apb_wr(0x42, 0x0); // DWC_DDRPHYA_ANIB0_base0_ATxOdtDrvStren +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TristateModeCA::DisDynAdrTri_p0 to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TristateModeCA::DDR2TMode_p0 to 0x0 +dwc_ddrphy_apb_wr(0x20019, 0x5); // DWC_DDRPHYA_MASTER0_base0_TristateModeCA_p0 +//// [phyinit_C_initPhyConfig] Programming DfiFreqXlat* +dwc_ddrphy_apb_wr(0x200f0, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat0 +dwc_ddrphy_apb_wr(0x200f1, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat1 +dwc_ddrphy_apb_wr(0x200f2, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat2 +dwc_ddrphy_apb_wr(0x200f3, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat3 +dwc_ddrphy_apb_wr(0x200f4, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat4 +dwc_ddrphy_apb_wr(0x200f5, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat5 +dwc_ddrphy_apb_wr(0x200f6, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat6 +dwc_ddrphy_apb_wr(0x200f7, 0xf000); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat7 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY0 to 0x64 +dwc_ddrphy_apb_wr(0x2000b, 0x64); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY1 to 0xc8 +dwc_ddrphy_apb_wr(0x2000c, 0xc8); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY2 to 0x2bc +dwc_ddrphy_apb_wr(0x2000d, 0x2bc); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY2_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY3 to 0x2c +dwc_ddrphy_apb_wr(0x2000e, 0x2c); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY3_p0 +//// [phyinit_C_initPhyConfig] Disabling DBYTE 0 Lane 8 (DBI) Receiver to save power. +dwc_ddrphy_apb_wr(0x1004a, 0x500); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl1 +//// [phyinit_C_initPhyConfig] Disabling DBYTE 1 Lane 8 (DBI) Receiver to save power. +dwc_ddrphy_apb_wr(0x1104a, 0x500); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl1 +//// [phyinit_C_initPhyConfig] Programming MasterX4Config::X4TG to 0x0 +dwc_ddrphy_apb_wr(0x20025, 0x0); // DWC_DDRPHYA_MASTER0_base0_MasterX4Config +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming GPR7(csrAlertRecovery) to 0x0 +dwc_ddrphy_apb_wr(0x90307, 0x0); // DWC_DDRPHYA_INITENG0_base0_Seq0BGPR7_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DMIPinPresent::RdDbiEnabled to 0x0 +dwc_ddrphy_apb_wr(0x2002d, 0x0); // DWC_DDRPHYA_MASTER0_base0_DMIPinPresent_p0 +// [phyinit_C_initPhyConfig] Programming TimingModeCntrl::Dly64Prec to 0x0 +dwc_ddrphy_apb_wr(0x20040, 0x0); // DWC_DDRPHYA_MASTER0_base0_TimingModeCntrl +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x1 for MASTER +dwc_ddrphy_apb_wr(0x20066, 0x1); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x1 for all DBYTEs +dwc_ddrphy_apb_wr(0x10066, 0x1); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x11066, 0x1); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x1 for all ANIBs +dwc_ddrphy_apb_wr(0x66, 0x1); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x1066, 0x1); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x2066, 0x1); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x3066, 0x1); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x4066, 0x1); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x5066, 0x1); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x6066, 0x1); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x7066, 0x1); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x8066, 0x1); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x9066, 0x1); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming AcClkDLLControl to 0x1080 +dwc_ddrphy_apb_wr(0x200ea, 0x1080); // DWC_DDRPHYA_MASTER0_base0_AcClkDLLControl_p0 +// [phyinit_C_initPhyConfig] Programming ArcPmuEccCtl to 0x1 +dwc_ddrphy_apb_wr(0xc0086, 0x1); // DWC_DDRPHYA_DRTUB0_ArcPmuEccCtl +// [phyinit_C_initPhyConfig] Programming VREGCtrl2 to 0x9820 for MASTER +dwc_ddrphy_apb_wr(0x2002b, 0x9820); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl2 +// [phyinit_C_initPhyConfig] Programming VREGCtrl2 to 0x8020 for all DBYTEs +dwc_ddrphy_apb_wr(0x1002b, 0x8020); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x1102b, 0x8020); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl2 +// [phyinit_C_initPhyConfig] Programming VREGCtrl2 to 0x8020 for all ANIBs +dwc_ddrphy_apb_wr(0x2b, 0x8020); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x102b, 0x8020); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x202b, 0x8020); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x302b, 0x8020); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x402b, 0x8020); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x502b, 0x8020); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x602b, 0x8020); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x702b, 0x8020); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x802b, 0x8020); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x902b, 0x8020); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl2 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for MASTER +dwc_ddrphy_apb_wr(0x20066, 0x0); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all DBYTEs +dwc_ddrphy_apb_wr(0x10066, 0x0); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x11066, 0x0); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all ANIBs +dwc_ddrphy_apb_wr(0x66, 0x0); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x1066, 0x0); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x2066, 0x0); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x3066, 0x0); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x4066, 0x0); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x5066, 0x0); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x6066, 0x0); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x7066, 0x0); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x8066, 0x0); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x9066, 0x0); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Programming VrefDAC0 to 0x3f for all DBYTEs and lanes +// [phyinit_C_initPhyConfig] Programming VrefDAC1 to 0x3f for all DBYTEs and lanes +// [phyinit_C_initPhyConfig] Programming VrefDAC2 to 0x3f for all DBYTEs and lanes +// [phyinit_C_initPhyConfig] Programming VrefDAC3 to 0x3f for all DBYTEs and lanes +dwc_ddrphy_apb_wr(0x10040, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r0_p0 +dwc_ddrphy_apb_wr(0x10030, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r0 +dwc_ddrphy_apb_wr(0x10050, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r0 +dwc_ddrphy_apb_wr(0x10060, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r0 +dwc_ddrphy_apb_wr(0x10140, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r1_p0 +dwc_ddrphy_apb_wr(0x10130, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r1 +dwc_ddrphy_apb_wr(0x10150, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r1 +dwc_ddrphy_apb_wr(0x10160, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r1 +dwc_ddrphy_apb_wr(0x10240, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r2_p0 +dwc_ddrphy_apb_wr(0x10230, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r2 +dwc_ddrphy_apb_wr(0x10250, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r2 +dwc_ddrphy_apb_wr(0x10260, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r2 +dwc_ddrphy_apb_wr(0x10340, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r3_p0 +dwc_ddrphy_apb_wr(0x10330, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r3 +dwc_ddrphy_apb_wr(0x10350, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r3 +dwc_ddrphy_apb_wr(0x10360, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r3 +dwc_ddrphy_apb_wr(0x10440, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r4_p0 +dwc_ddrphy_apb_wr(0x10430, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r4 +dwc_ddrphy_apb_wr(0x10450, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r4 +dwc_ddrphy_apb_wr(0x10460, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r4 +dwc_ddrphy_apb_wr(0x10540, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r5_p0 +dwc_ddrphy_apb_wr(0x10530, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r5 +dwc_ddrphy_apb_wr(0x10550, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r5 +dwc_ddrphy_apb_wr(0x10560, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r5 +dwc_ddrphy_apb_wr(0x10640, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r6_p0 +dwc_ddrphy_apb_wr(0x10630, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r6 +dwc_ddrphy_apb_wr(0x10650, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r6 +dwc_ddrphy_apb_wr(0x10660, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r6 +dwc_ddrphy_apb_wr(0x10740, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r7_p0 +dwc_ddrphy_apb_wr(0x10730, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r7 +dwc_ddrphy_apb_wr(0x10750, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r7 +dwc_ddrphy_apb_wr(0x10760, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r7 +dwc_ddrphy_apb_wr(0x10840, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r8_p0 +dwc_ddrphy_apb_wr(0x10830, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r8 +dwc_ddrphy_apb_wr(0x10850, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r8 +dwc_ddrphy_apb_wr(0x10860, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r8 +dwc_ddrphy_apb_wr(0x11040, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r0_p0 +dwc_ddrphy_apb_wr(0x11030, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r0 +dwc_ddrphy_apb_wr(0x11050, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r0 +dwc_ddrphy_apb_wr(0x11060, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r0 +dwc_ddrphy_apb_wr(0x11140, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r1_p0 +dwc_ddrphy_apb_wr(0x11130, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r1 +dwc_ddrphy_apb_wr(0x11150, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r1 +dwc_ddrphy_apb_wr(0x11160, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r1 +dwc_ddrphy_apb_wr(0x11240, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r2_p0 +dwc_ddrphy_apb_wr(0x11230, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r2 +dwc_ddrphy_apb_wr(0x11250, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r2 +dwc_ddrphy_apb_wr(0x11260, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r2 +dwc_ddrphy_apb_wr(0x11340, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r3_p0 +dwc_ddrphy_apb_wr(0x11330, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r3 +dwc_ddrphy_apb_wr(0x11350, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r3 +dwc_ddrphy_apb_wr(0x11360, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r3 +dwc_ddrphy_apb_wr(0x11440, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r4_p0 +dwc_ddrphy_apb_wr(0x11430, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r4 +dwc_ddrphy_apb_wr(0x11450, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r4 +dwc_ddrphy_apb_wr(0x11460, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r4 +dwc_ddrphy_apb_wr(0x11540, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r5_p0 +dwc_ddrphy_apb_wr(0x11530, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r5 +dwc_ddrphy_apb_wr(0x11550, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r5 +dwc_ddrphy_apb_wr(0x11560, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r5 +dwc_ddrphy_apb_wr(0x11640, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r6_p0 +dwc_ddrphy_apb_wr(0x11630, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r6 +dwc_ddrphy_apb_wr(0x11650, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r6 +dwc_ddrphy_apb_wr(0x11660, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r6 +dwc_ddrphy_apb_wr(0x11740, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r7_p0 +dwc_ddrphy_apb_wr(0x11730, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r7 +dwc_ddrphy_apb_wr(0x11750, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r7 +dwc_ddrphy_apb_wr(0x11760, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r7 +dwc_ddrphy_apb_wr(0x11840, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r8_p0 +dwc_ddrphy_apb_wr(0x11830, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r8 +dwc_ddrphy_apb_wr(0x11850, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r8 +dwc_ddrphy_apb_wr(0x11860, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r8 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DfiFreqRatio_p0 to 0x1 +dwc_ddrphy_apb_wr(0x200fa, 0x1); // DWC_DDRPHYA_MASTER0_base0_DfiFreqRatio_p0 +//// [phyinit_C_initPhyConfig] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x0 +dwc_ddrphy_apb_wr(0x200a6, 0x0); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=0) to 0xc +dwc_ddrphy_apb_wr(0x28, 0xc); // DWC_DDRPHYA_ANIB0_base0_AForceTriCont +//// [phyinit_C_initPhyConfig] End of dwc_ddrphy_phyinit_C_initPhyConfig() +// +// +////############################################################## +//// +//// dwc_ddrphy_phyinit_userCustom_customPreTrain is a user-editable function. +//// +//// The purpose of dwc_ddrphy_phyinit_userCustom_customPreTrain() is to override any +//// any message block fields calculated by Phyinit in dwc_ddrphy_phyinit_calcMb() or to +//// override any CSR values programmed by Phyinit in dwc_ddrphy_phyinit_C_initPhyConfig(). +//// This function is executed before training and thus any override here might affect +//// training result. +//// +//// IMPORTANT: in this function, user shall not override any values in userInputBasic and +//// userInputAdvanced data structures. Use dwc_ddrphy_phyinit_userCustom_overrideUserInput() +//// to modify values in those data structures. +//// +////############################################################## +// +//// [phyinit_userCustom_customPreTrain] Start of dwc_ddrphy_phyinit_userCustom_customPreTrain() +//// [phyinit_userCustom_customPreTrain] End of dwc_ddrphy_phyinit_userCustom_customPreTrain() +//// [dwc_ddrphy_phyinit_D_loadIMEM, 1D] Start of dwc_ddrphy_phyinit_D_loadIMEM (Train2D=0) +// +// +////############################################################## +//// +//// (D) Load the 1D IMEM image +//// +//// This function loads the training firmware IMEM image into the SRAM. +//// See PhyInit App Note for detailed description and function usage +//// +////############################################################## +// +// +//// [dwc_ddrphy_phyinit_D_loadIMEM, 1D] Programming MemResetL to 0x2 +dwc_ddrphy_apb_wr(0x20060, 0x2); // DWC_DDRPHYA_MASTER0_base0_MemResetL +// [dwc_ddrphy_phyinit_storeIncvFile] Reading input file: /home/jerry_ku/Project/Development/ast2700dev/ddr45phy_tsmc12/coreConsultant/config3_3.50a/2022-12-12-16-52-55/firmware/Latest/training/ddr4/ddr4_pmu_train_imem.incv + +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_WriteOutMem] STARTING 32bit write. offset 0x50000 size 0x8000 +//#ifdef TRAIN_LOADBIN +dwc_ddrphy_phyinit_userCustom_D_loadIMEM(sdrammc, 0); +//// [dwc_ddrphy_phyinit_WriteOutMem] DONE. Index 0x8000 +//// 2. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +//// This allows the firmware unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_D_loadIMEM, 1D] End of dwc_ddrphy_phyinit_D_loadIMEM() +// +// +////############################################################## +//// +//// 4.3.5(E) Set the PHY input clocks to the desired frequency for pstate 0 +//// +//// Set the PHY input Dfi Clk to the desired operating frequency associated with the given Pstate. Before proceeding to the next step, +//// the clock should be stable at the new frequency. For more information on clocking requirements, see "Clocks" on page <XXX>. +//// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_E_setDfiClk(sdrammc); + +// +//// [dwc_ddrphy_phyinit_userCustom_E_setDfiClk] End of dwc_ddrphy_phyinit_userCustom_E_setDfiClk() +//// [phyinit_F_loadDMEM, 1D] Start of dwc_ddrphy_phyinit_F_loadDMEM (pstate=0, Train2D=0) +// +// +////############################################################## +//// +//// 4.3.5(F) Load the 1D DMEM image and write the 1D Message Block parameters for the training firmware +//// +//// The procedure is as follows: +//// +////############################################################## +// +// +// +//// 1. Load the firmware DMEM segment to initialize the data structures. +// +//// 2. Write the Firmware Message Block with the required contents detailing the training parameters. +// +// [dwc_ddrphy_phyinit_storeIncvFile] Reading input file: /home/jerry_ku/Project/Development/ast2700dev/ddr45phy_tsmc12/coreConsultant/config3_3.50a/2022-12-12-16-52-55/firmware/Latest/training/ddr4/ddr4_pmu_train_dmem.incv + +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_WriteOutMem] STARTING 32bit write. offset 0x58000 size 0x8000 +//#ifdef TRAIN_LOADBIN +dwc_ddrphy_phyinit_userCustom_F_loadDMEM(sdrammc, 0, 0); + +dwc_ddrphy_apb_wr_32b(0x58000, 0x100); +dwc_ddrphy_apb_wr_32b(0x58002, 0xc800000); +dwc_ddrphy_apb_wr_32b(0x58004, 0x0); +dwc_ddrphy_apb_wr_32b(0x58006, 0x10000240); +dwc_ddrphy_apb_wr_32b(0x58008, 0x1); +dwc_ddrphy_apb_wr_32b(0x5800a, 0x31f0000); +dwc_ddrphy_apb_wr_32b(0x5800c, 0xc8); +dwc_ddrphy_apb_wr_32b(0x5800e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58010, 0x0); +dwc_ddrphy_apb_wr_32b(0x58012, 0x2); +dwc_ddrphy_apb_wr_32b(0x58014, 0x0); +dwc_ddrphy_apb_wr_32b(0x58016, 0x0); +dwc_ddrphy_apb_wr_32b(0x58018, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58020, 0x0); +dwc_ddrphy_apb_wr_32b(0x58022, 0x0); +dwc_ddrphy_apb_wr_32b(0x58024, 0x0); +dwc_ddrphy_apb_wr_32b(0x58026, 0x0); +dwc_ddrphy_apb_wr_32b(0x58028, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802e, 0x21500000); +dwc_ddrphy_apb_wr_32b(0x58030, 0x2280101); +dwc_ddrphy_apb_wr_32b(0x58032, 0x400); +dwc_ddrphy_apb_wr_32b(0x58034, 0x104f0500); +dwc_ddrphy_apb_wr_32b(0x58036, 0x0); +dwc_ddrphy_apb_wr_32b(0x58038, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58040, 0x0); +dwc_ddrphy_apb_wr_32b(0x58042, 0xf0f0000); +dwc_ddrphy_apb_wr_32b(0x58044, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58046, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58048, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5804a, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5804c, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5804e, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58050, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58052, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58054, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58056, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58058, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5805a, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5805c, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5805e, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58060, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58062, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58064, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58066, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58068, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5806a, 0xf0f); +dwc_ddrphy_apb_wr_32b(0x5806c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5806e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58070, 0x0); +dwc_ddrphy_apb_wr_32b(0x58072, 0x0); +dwc_ddrphy_apb_wr_32b(0x58074, 0x0); +dwc_ddrphy_apb_wr_32b(0x58076, 0x0); +dwc_ddrphy_apb_wr_32b(0x58078, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58080, 0x0); +dwc_ddrphy_apb_wr_32b(0x58082, 0x0); +dwc_ddrphy_apb_wr_32b(0x58084, 0x0); +dwc_ddrphy_apb_wr_32b(0x58086, 0x0); +dwc_ddrphy_apb_wr_32b(0x58088, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58090, 0x0); +dwc_ddrphy_apb_wr_32b(0x58092, 0x0); +dwc_ddrphy_apb_wr_32b(0x58094, 0x0); +dwc_ddrphy_apb_wr_32b(0x58096, 0x0); +dwc_ddrphy_apb_wr_32b(0x58098, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809e, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x580bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580be, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x580cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580da, 0x0); +dwc_ddrphy_apb_wr_32b(0x580dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580de, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fe, 0x0); +dwc_ddrphy_apb_wr_32b(0x58100, 0x0); +dwc_ddrphy_apb_wr_32b(0x58102, 0x0); +dwc_ddrphy_apb_wr_32b(0x58104, 0x0); +dwc_ddrphy_apb_wr_32b(0x58106, 0x0); +dwc_ddrphy_apb_wr_32b(0x58108, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58110, 0x0); +dwc_ddrphy_apb_wr_32b(0x58112, 0x0); +dwc_ddrphy_apb_wr_32b(0x58114, 0x0); +dwc_ddrphy_apb_wr_32b(0x58116, 0x0); +dwc_ddrphy_apb_wr_32b(0x58118, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58120, 0x0); +dwc_ddrphy_apb_wr_32b(0x58122, 0x0); +dwc_ddrphy_apb_wr_32b(0x58124, 0x0); +dwc_ddrphy_apb_wr_32b(0x58126, 0x0); +dwc_ddrphy_apb_wr_32b(0x58128, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58130, 0x0); +dwc_ddrphy_apb_wr_32b(0x58132, 0x0); +dwc_ddrphy_apb_wr_32b(0x58134, 0x0); +dwc_ddrphy_apb_wr_32b(0x58136, 0x0); +dwc_ddrphy_apb_wr_32b(0x58138, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58140, 0x0); +dwc_ddrphy_apb_wr_32b(0x58142, 0x0); +dwc_ddrphy_apb_wr_32b(0x58144, 0x0); +dwc_ddrphy_apb_wr_32b(0x58146, 0x0); +dwc_ddrphy_apb_wr_32b(0x58148, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58150, 0x0); +dwc_ddrphy_apb_wr_32b(0x58152, 0x0); +dwc_ddrphy_apb_wr_32b(0x58154, 0x0); +dwc_ddrphy_apb_wr_32b(0x58156, 0x0); +dwc_ddrphy_apb_wr_32b(0x58158, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58160, 0x0); +dwc_ddrphy_apb_wr_32b(0x58162, 0x0); +dwc_ddrphy_apb_wr_32b(0x58164, 0x0); +dwc_ddrphy_apb_wr_32b(0x58166, 0x0); +dwc_ddrphy_apb_wr_32b(0x58168, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58170, 0x0); +dwc_ddrphy_apb_wr_32b(0x58172, 0x0); +dwc_ddrphy_apb_wr_32b(0x58174, 0x0); +dwc_ddrphy_apb_wr_32b(0x58176, 0x0); +dwc_ddrphy_apb_wr_32b(0x58178, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58180, 0x0); +dwc_ddrphy_apb_wr_32b(0x58182, 0x0); +dwc_ddrphy_apb_wr_32b(0x58184, 0x0); +dwc_ddrphy_apb_wr_32b(0x58186, 0x0); +dwc_ddrphy_apb_wr_32b(0x58188, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58190, 0x0); +dwc_ddrphy_apb_wr_32b(0x58192, 0x0); +dwc_ddrphy_apb_wr_32b(0x58194, 0x0); +dwc_ddrphy_apb_wr_32b(0x58196, 0x0); +dwc_ddrphy_apb_wr_32b(0x58198, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819e, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x581bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581be, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x581cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581da, 0x0); +dwc_ddrphy_apb_wr_32b(0x581dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581de, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fe, 0x0); +//// [dwc_ddrphy_phyinit_WriteOutMem] DONE. Index 0x8000 +//// 2. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +//// This allows the firmware unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_F_loadDMEM, 1D] End of dwc_ddrphy_phyinit_F_loadDMEM() +// +// +////############################################################## +//// +//// 4.3.7(G) Execute the Training Firmware +//// +//// The training firmware is executed with the following procedure: +//// +////############################################################## +// +// +//// 1. Reset the firmware microcontroller by writing the MicroReset CSR to set the StallToMicro and +//// ResetToMicro fields to 1 (all other fields should be zero). +//// Then rewrite the CSR so that only the StallToMicro remains set (all other fields should be zero). +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +dwc_ddrphy_apb_wr(0xd0099, 0x9); // DWC_DDRPHYA_APBONLY0_MicroReset +dwc_ddrphy_apb_wr(0xd0099, 0x1); // DWC_DDRPHYA_APBONLY0_MicroReset +// +//// 2. Begin execution of the training firmware by setting the MicroReset CSR to 4'b0000. +dwc_ddrphy_apb_wr(0xd0099, 0x0); // DWC_DDRPHYA_APBONLY0_MicroReset +// +//// 3. Wait for the training firmware to complete by following the procedure in "uCtrl Initialization and Mailbox Messaging" +//// 4.3.7 3. Wait for the training firmware to complete. Implement timeout function or follow the procedure in "3.4 Running the firmware" of the Training Firmware Application Note to poll the Mailbox message. +dwc_ddrphy_phyinit_userCustom_G_waitFwDone(sdrammc); + +//// [dwc_ddrphy_phyinit_userCustom_G_waitFwDone] End of dwc_ddrphy_phyinit_userCustom_G_waitFwDone() +//// 4. Halt the microcontroller." +dwc_ddrphy_apb_wr(0xd0099, 0x1); // DWC_DDRPHYA_APBONLY0_MicroReset +dwc_ddrphy_apb_wr(0x20089, 0x0); // DWC_DDRPHYA_MASTER0_base0_CalZap +//// [dwc_ddrphy_phyinit_G_execFW] End of dwc_ddrphy_phyinit_G_execFW() +// +// +////############################################################## +//// +//// 4.3.8(H) Read the Message Block results +//// +//// The procedure is as follows: +//// +////############################################################## +// +// +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +// +//2. Read the Firmware Message Block to obtain the results from the training. +//This can be accomplished by issuing APB read commands to the DMEM addresses. +//Example: +//if (Train2D) +//{ +// _read_2d_message_block_outputs_ +//} +//else +//{ +// _read_1d_message_block_outputs_ +//} +//This can be accomplished by issuing APB read commands to the DMEM addresses. +dwc_ddrphy_phyinit_userCustom_H_readMsgBlock(sdrammc, 0); + +//[dwc_ddrphy_phyinit_userCustom_H_readMsgBlock] End of dwc_ddrphy_phyinit_userCustom_H_readMsgBlock() +//// 3. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// 4. If training is required at another frequency, repeat the operations starting at step (E). +//// [dwc_ddrphy_phyinit_H_readMsgBlock] End of dwc_ddrphy_phyinit_H_readMsgBlock() +// +// +////############################################################## +//// +//// 4.3.5(E) Set the PHY input clocks to the desired frequency for pstate 0 +//// +//// Set the PHY input Dfi Clk to the desired operating frequency associated with the given Pstate. Before proceeding to the next step, +//// the clock should be stable at the new frequency. For more information on clocking requirements, see "Clocks" on page <XXX>. +//// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_E_setDfiClk(sdrammc); + +// +//// [dwc_ddrphy_phyinit_userCustom_E_setDfiClk] End of dwc_ddrphy_phyinit_userCustom_E_setDfiClk() +//// [dwc_ddrphy_phyinit_D_loadIMEM, 2D] Start of dwc_ddrphy_phyinit_D_loadIMEM (Train2D=1) +// +// +////############################################################## +//// +//// (D) Load the 2D IMEM image +//// +//// This function loads the training firmware IMEM image into the SRAM. +//// See PhyInit App Note for detailed description and function usage +//// +////############################################################## +// +// +// [dwc_ddrphy_phyinit_storeIncvFile] Reading input file: /home/jerry_ku/Project/Development/ast2700dev/ddr45phy_tsmc12/coreConsultant/config3_3.50a/2022-12-12-16-52-55/firmware/Latest/training/ddr4_2d/ddr4_2d_pmu_train_imem.incv + +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_WriteOutMem] STARTING 32bit write. offset 0x50000 size 0x8000 +dwc_ddrphy_phyinit_userCustom_D_loadIMEM(sdrammc, 1); +//// [dwc_ddrphy_phyinit_WriteOutMem] DONE. Index 0x8000 +//// 2. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +//// This allows the firmware unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_D_loadIMEM, 2D] End of dwc_ddrphy_phyinit_D_loadIMEM() +//// [phyinit_F_loadDMEM, 2D] Start of dwc_ddrphy_phyinit_F_loadDMEM (pstate=0, Train2D=1) +// +// +////############################################################## +//// +//// 4.3.5(F) Load the 2D DMEM image and write the 2D Message Block parameters for the training firmware +//// +//// The procedure is as follows: +//// +////############################################################## +// +// +// +//// 1. Load the firmware DMEM segment to initialize the data structures. +// +//// 2. Write the Firmware Message Block with the required contents detailing the training parameters. +// +// [dwc_ddrphy_phyinit_storeIncvFile] Reading input file: /home/jerry_ku/Project/Development/ast2700dev/ddr45phy_tsmc12/coreConsultant/config3_3.50a/2022-12-12-16-52-55/firmware/Latest/training/ddr4_2d/ddr4_2d_pmu_train_dmem.incv + +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_WriteOutMem] STARTING 32bit write. offset 0x58000 size 0x8000 +dwc_ddrphy_phyinit_userCustom_F_loadDMEM(sdrammc, 0, 1); +dwc_ddrphy_apb_wr_32b(0x58000, 0x100); +dwc_ddrphy_apb_wr_32b(0x58002, 0xc800000); +dwc_ddrphy_apb_wr_32b(0x58004, 0x0); +dwc_ddrphy_apb_wr_32b(0x58006, 0x10000240); +dwc_ddrphy_apb_wr_32b(0x58008, 0x1); +//printf("- <DWC_DDRPHY/TRAIN>: Override 2D DMEM image for SequenceCtrl, RX2D_TrainOpt, TX2D_TrainOpt, Delay_Weight2D, and Voltage_Weight2D\n"); +// uint16_t SequenceCtrl; // Byte offset 0x16, CSR Addr 0x5800b, Direction=In + // SequenceCtrl[0] = Run DevInit - Device/PHY initialization. Should always be set + // SequenceCtrl[5] = Run rd2D - 2d read dqs training + // SequenceCtrl[6] = Run wr2D - 2d write dq training +dwc_ddrphy_apb_wr_32b(0x5800a, 0x0610000); + +// Redmine 1392: To speed up data collection, set the voltage and delay step size in Rx2D_TrainOpt and Tx2D_TrainOpt to its maximum value. +// uint8_t HdtCtrl; // Byte offset 0x18, CSR Addr 0x5800c, Direction=In + // 0x04 = Maximal debug messages (e.g., Eye contours) + // 0x05 = Detailed debug messages (e.g. Eye delays) + // 0x0A = Coarse debug messages (e.g. rank information) + // 0xC8 = Stage completion + // 0xC9 = Assertion messages + // 0xFF = Firmware completion messages only +// uint8_t RX2D_TrainOpt; // Byte offset 0x19, CSR Addr 0x5800c, Direction=In +// uint8_t TX2D_TrainOpt; // Byte offset 0x1a, CSR Addr 0x5800d, Direction=In + #ifdef DWC_DEBUG +//dwc_ddrphy_apb_wr_32b(0x5800c, 0x001e1e0a); + #else +//dwc_ddrphy_apb_wr_32b(0x5800c, 0x001e1ec8); +dwc_ddrphy_apb_wr_32b(0x5800c, 0x000000c8); + #endif +// uint8_t Delay_Weight2D; // Byte offset 0x1c, CSR Addr 0x5800e, Direction=In +// uint8_t Voltage_Weight2D; // Byte offset 0x1d, CSR Addr 0x5800e, Direction=In +dwc_ddrphy_apb_wr_32b(0x5800e, 0x8020); + +dwc_ddrphy_apb_wr_32b(0x58010, 0x0); +dwc_ddrphy_apb_wr_32b(0x58012, 0x2); +dwc_ddrphy_apb_wr_32b(0x58014, 0x0); +dwc_ddrphy_apb_wr_32b(0x58016, 0x0); +dwc_ddrphy_apb_wr_32b(0x58018, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58020, 0x0); +dwc_ddrphy_apb_wr_32b(0x58022, 0x0); +dwc_ddrphy_apb_wr_32b(0x58024, 0x0); +dwc_ddrphy_apb_wr_32b(0x58026, 0x0); +dwc_ddrphy_apb_wr_32b(0x58028, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802e, 0x21500000); +dwc_ddrphy_apb_wr_32b(0x58030, 0x2280101); +dwc_ddrphy_apb_wr_32b(0x58032, 0x400); +dwc_ddrphy_apb_wr_32b(0x58034, 0x104f0500); +dwc_ddrphy_apb_wr_32b(0x58036, 0x0); +dwc_ddrphy_apb_wr_32b(0x58038, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58040, 0x0); +dwc_ddrphy_apb_wr_32b(0x58042, 0xf0f0000); +dwc_ddrphy_apb_wr_32b(0x58044, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58046, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58048, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5804a, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5804c, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5804e, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58050, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58052, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58054, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58056, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58058, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5805a, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5805c, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5805e, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58060, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58062, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58064, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58066, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x58068, 0xf0f0f0f); +dwc_ddrphy_apb_wr_32b(0x5806a, 0xf0f); +dwc_ddrphy_apb_wr_32b(0x5806c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5806e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58070, 0x0); +dwc_ddrphy_apb_wr_32b(0x58072, 0x0); +dwc_ddrphy_apb_wr_32b(0x58074, 0x0); +dwc_ddrphy_apb_wr_32b(0x58076, 0x0); +dwc_ddrphy_apb_wr_32b(0x58078, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58080, 0x0); +dwc_ddrphy_apb_wr_32b(0x58082, 0x0); +dwc_ddrphy_apb_wr_32b(0x58084, 0x0); +dwc_ddrphy_apb_wr_32b(0x58086, 0x0); +dwc_ddrphy_apb_wr_32b(0x58088, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58090, 0x0); +dwc_ddrphy_apb_wr_32b(0x58092, 0x0); +dwc_ddrphy_apb_wr_32b(0x58094, 0x0); +dwc_ddrphy_apb_wr_32b(0x58096, 0x0); +dwc_ddrphy_apb_wr_32b(0x58098, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809e, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x580bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580be, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x580cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580da, 0x0); +dwc_ddrphy_apb_wr_32b(0x580dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580de, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fe, 0x0); +dwc_ddrphy_apb_wr_32b(0x58100, 0x0); +dwc_ddrphy_apb_wr_32b(0x58102, 0x0); +dwc_ddrphy_apb_wr_32b(0x58104, 0x0); +dwc_ddrphy_apb_wr_32b(0x58106, 0x0); +dwc_ddrphy_apb_wr_32b(0x58108, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58110, 0x0); +dwc_ddrphy_apb_wr_32b(0x58112, 0x0); +dwc_ddrphy_apb_wr_32b(0x58114, 0x0); +dwc_ddrphy_apb_wr_32b(0x58116, 0x0); +dwc_ddrphy_apb_wr_32b(0x58118, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58120, 0x0); +dwc_ddrphy_apb_wr_32b(0x58122, 0x0); +dwc_ddrphy_apb_wr_32b(0x58124, 0x0); +dwc_ddrphy_apb_wr_32b(0x58126, 0x0); +dwc_ddrphy_apb_wr_32b(0x58128, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58130, 0x0); +dwc_ddrphy_apb_wr_32b(0x58132, 0x0); +dwc_ddrphy_apb_wr_32b(0x58134, 0x0); +dwc_ddrphy_apb_wr_32b(0x58136, 0x0); +dwc_ddrphy_apb_wr_32b(0x58138, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58140, 0x0); +dwc_ddrphy_apb_wr_32b(0x58142, 0x0); +dwc_ddrphy_apb_wr_32b(0x58144, 0x0); +dwc_ddrphy_apb_wr_32b(0x58146, 0x0); +dwc_ddrphy_apb_wr_32b(0x58148, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58150, 0x0); +dwc_ddrphy_apb_wr_32b(0x58152, 0x0); +dwc_ddrphy_apb_wr_32b(0x58154, 0x0); +dwc_ddrphy_apb_wr_32b(0x58156, 0x0); +dwc_ddrphy_apb_wr_32b(0x58158, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58160, 0x0); +dwc_ddrphy_apb_wr_32b(0x58162, 0x0); +dwc_ddrphy_apb_wr_32b(0x58164, 0x0); +dwc_ddrphy_apb_wr_32b(0x58166, 0x0); +dwc_ddrphy_apb_wr_32b(0x58168, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58170, 0x0); +dwc_ddrphy_apb_wr_32b(0x58172, 0x0); +dwc_ddrphy_apb_wr_32b(0x58174, 0x0); +dwc_ddrphy_apb_wr_32b(0x58176, 0x0); +dwc_ddrphy_apb_wr_32b(0x58178, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58180, 0x0); +dwc_ddrphy_apb_wr_32b(0x58182, 0x0); +dwc_ddrphy_apb_wr_32b(0x58184, 0x0); +dwc_ddrphy_apb_wr_32b(0x58186, 0x0); +dwc_ddrphy_apb_wr_32b(0x58188, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58190, 0x0); +dwc_ddrphy_apb_wr_32b(0x58192, 0x0); +dwc_ddrphy_apb_wr_32b(0x58194, 0x0); +dwc_ddrphy_apb_wr_32b(0x58196, 0x0); +dwc_ddrphy_apb_wr_32b(0x58198, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819e, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x581bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581be, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x581cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581da, 0x0); +dwc_ddrphy_apb_wr_32b(0x581dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581de, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fe, 0x0); +//// [dwc_ddrphy_phyinit_WriteOutMem] DONE. Index 0x8000 +//// 2. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +//// This allows the firmware unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_F_loadDMEM, 2D] End of dwc_ddrphy_phyinit_F_loadDMEM() +// +// +////############################################################## +//// +//// 4.3.7(G) Execute the Training Firmware +//// +//// The training firmware is executed with the following procedure: +//// +////############################################################## +// +// +//// 1. Reset the firmware microcontroller by writing the MicroReset CSR to set the StallToMicro and +//// ResetToMicro fields to 1 (all other fields should be zero). +//// Then rewrite the CSR so that only the StallToMicro remains set (all other fields should be zero). +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +dwc_ddrphy_apb_wr(0xd0099, 0x9); // DWC_DDRPHYA_APBONLY0_MicroReset +dwc_ddrphy_apb_wr(0xd0099, 0x1); // DWC_DDRPHYA_APBONLY0_MicroReset +// +//// 2. Begin execution of the training firmware by setting the MicroReset CSR to 4'b0000. +dwc_ddrphy_apb_wr(0xd0099, 0x0); // DWC_DDRPHYA_APBONLY0_MicroReset +// +//// 3. Wait for the training firmware to complete by following the procedure in "uCtrl Initialization and Mailbox Messaging" +//// 4.3.7 3. Wait for the training firmware to complete. Implement timeout function or follow the procedure in "3.4 Running the firmware" of the Training Firmware Application Note to poll the Mailbox message. +dwc_ddrphy_phyinit_userCustom_G_waitFwDone(sdrammc); + +//// [dwc_ddrphy_phyinit_userCustom_G_waitFwDone] End of dwc_ddrphy_phyinit_userCustom_G_waitFwDone() +//// 4. Halt the microcontroller." +dwc_ddrphy_apb_wr(0xd0099, 0x1); // DWC_DDRPHYA_APBONLY0_MicroReset +dwc_ddrphy_apb_wr(0x20089, 0x0); // DWC_DDRPHYA_MASTER0_base0_CalZap +//// [dwc_ddrphy_phyinit_G_execFW] End of dwc_ddrphy_phyinit_G_execFW() +// +// +////############################################################## +//// +//// 4.3.8(H) Read the Message Block results +//// +//// The procedure is as follows: +//// +////############################################################## +// +// +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +// +//2. Read the Firmware Message Block to obtain the results from the training. +//This can be accomplished by issuing APB read commands to the DMEM addresses. +//Example: +//if (Train2D) +//{ +// _read_2d_message_block_outputs_ +//} +//else +//{ +// _read_1d_message_block_outputs_ +//} +//This can be accomplished by issuing APB read commands to the DMEM addresses. +dwc_ddrphy_phyinit_userCustom_H_readMsgBlock(sdrammc, 1); + +//[dwc_ddrphy_phyinit_userCustom_H_readMsgBlock] End of dwc_ddrphy_phyinit_userCustom_H_readMsgBlock() +//// 3. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// 4. If training is required at another frequency, repeat the operations starting at step (E). +//// [dwc_ddrphy_phyinit_H_readMsgBlock] End of dwc_ddrphy_phyinit_H_readMsgBlock() +//// [initRuntimeConfigEnableBits] Start of initRuntimeConfigEnableBits() +//// [initRuntimeConfigEnableBits] enableBits[0] = 0x00000009 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A0 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A1 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A2 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A3 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] enableBits[1] = 0x00000000 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B0 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B1 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B2 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B3 = 0x000000ff, rtt_required = 0x0000000f +//// [initRuntimeConfigEnableBits] enableBits[2] = 0x00000000 +//// [initRuntimeConfigEnableBits] End of initRuntimeConfigEnableBits() +//// [phyinit_I_loadPIEImage] Start of dwc_ddrphy_phyinit_I_loadPIEImage() +// +// +////############################################################## +//// +//// 4.3.9(I) Load PHY Init Engine Image +//// +//// Load the PHY Initialization Engine memory with the provided initialization sequence. +//// +////############################################################## +// +// +//// Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_I_loadPIEImage] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x1 +dwc_ddrphy_apb_wr(0x200a6, 0x2); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +//// [phyinit_I_loadPIEImage] Programming PIE Production Code +//// [phyinit_LoadPIECodeSections] Start of dwc_ddrphy_phyinit_LoadPIECodeSections() +//// [phyinit_LoadPIECodeSections] Moving start address from 0 to 90000 +dwc_ddrphy_apb_wr(0x90000, 0x10); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b0s0 +dwc_ddrphy_apb_wr(0x90001, 0x400); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b0s1 +dwc_ddrphy_apb_wr(0x90002, 0x10e); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b0s2 +dwc_ddrphy_apb_wr(0x90003, 0x0); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b1s0 +dwc_ddrphy_apb_wr(0x90004, 0x0); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b1s1 +dwc_ddrphy_apb_wr(0x90005, 0x8); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b1s2 +//// [phyinit_LoadPIECodeSections] Moving start address from 90006 to 90029 +dwc_ddrphy_apb_wr(0x90029, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b0s0 +dwc_ddrphy_apb_wr(0x9002a, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b0s1 +dwc_ddrphy_apb_wr(0x9002b, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b0s2 +dwc_ddrphy_apb_wr(0x9002c, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b1s0 +dwc_ddrphy_apb_wr(0x9002d, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b1s1 +dwc_ddrphy_apb_wr(0x9002e, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b1s2 +dwc_ddrphy_apb_wr(0x9002f, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b2s0 +dwc_ddrphy_apb_wr(0x90030, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b2s1 +dwc_ddrphy_apb_wr(0x90031, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b2s2 +dwc_ddrphy_apb_wr(0x90032, 0xb); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b3s0 +dwc_ddrphy_apb_wr(0x90033, 0x480); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b3s1 +dwc_ddrphy_apb_wr(0x90034, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b3s2 +dwc_ddrphy_apb_wr(0x90035, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b4s0 +dwc_ddrphy_apb_wr(0x90036, 0x448); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b4s1 +dwc_ddrphy_apb_wr(0x90037, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b4s2 +dwc_ddrphy_apb_wr(0x90038, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b5s0 +dwc_ddrphy_apb_wr(0x90039, 0x478); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b5s1 +dwc_ddrphy_apb_wr(0x9003a, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b5s2 +dwc_ddrphy_apb_wr(0x9003b, 0x2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b6s0 +dwc_ddrphy_apb_wr(0x9003c, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b6s1 +dwc_ddrphy_apb_wr(0x9003d, 0x139); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b6s2 +dwc_ddrphy_apb_wr(0x9003e, 0xf); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b7s0 +dwc_ddrphy_apb_wr(0x9003f, 0x7c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b7s1 +dwc_ddrphy_apb_wr(0x90040, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b7s2 +dwc_ddrphy_apb_wr(0x90041, 0x107); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b8s0 +dwc_ddrphy_apb_wr(0x90042, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b8s1 +dwc_ddrphy_apb_wr(0x90043, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b8s2 +dwc_ddrphy_apb_wr(0x90044, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b9s0 +dwc_ddrphy_apb_wr(0x90045, 0xe0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b9s1 +dwc_ddrphy_apb_wr(0x90046, 0x139); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b9s2 +dwc_ddrphy_apb_wr(0x90047, 0x147); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b10s0 +dwc_ddrphy_apb_wr(0x90048, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b10s1 +dwc_ddrphy_apb_wr(0x90049, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b10s2 +dwc_ddrphy_apb_wr(0x9004a, 0x14f); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b11s0 +dwc_ddrphy_apb_wr(0x9004b, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b11s1 +dwc_ddrphy_apb_wr(0x9004c, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b11s2 +dwc_ddrphy_apb_wr(0x9004d, 0x7); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b12s0 +dwc_ddrphy_apb_wr(0x9004e, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b12s1 +dwc_ddrphy_apb_wr(0x9004f, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b12s2 +dwc_ddrphy_apb_wr(0x90050, 0x47); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b13s0 +dwc_ddrphy_apb_wr(0x90051, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b13s1 +dwc_ddrphy_apb_wr(0x90052, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b13s2 +dwc_ddrphy_apb_wr(0x90053, 0x4f); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b14s0 +dwc_ddrphy_apb_wr(0x90054, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b14s1 +dwc_ddrphy_apb_wr(0x90055, 0x179); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b14s2 +dwc_ddrphy_apb_wr(0x90056, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b15s0 +dwc_ddrphy_apb_wr(0x90057, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b15s1 +dwc_ddrphy_apb_wr(0x90058, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b15s2 +dwc_ddrphy_apb_wr(0x90059, 0x11); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b16s0 +dwc_ddrphy_apb_wr(0x9005a, 0x530); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b16s1 +dwc_ddrphy_apb_wr(0x9005b, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b16s2 +dwc_ddrphy_apb_wr(0x9005c, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b17s0 +dwc_ddrphy_apb_wr(0x9005d, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b17s1 +dwc_ddrphy_apb_wr(0x9005e, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b17s2 +dwc_ddrphy_apb_wr(0x9005f, 0x14f); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b18s0 +dwc_ddrphy_apb_wr(0x90060, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b18s1 +dwc_ddrphy_apb_wr(0x90061, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b18s2 +dwc_ddrphy_apb_wr(0x90062, 0x2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b19s0 +dwc_ddrphy_apb_wr(0x90063, 0x45a); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b19s1 +dwc_ddrphy_apb_wr(0x90064, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b19s2 +dwc_ddrphy_apb_wr(0x90065, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b20s0 +dwc_ddrphy_apb_wr(0x90066, 0x530); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b20s1 +dwc_ddrphy_apb_wr(0x90067, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b20s2 +dwc_ddrphy_apb_wr(0x90068, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b21s0 +dwc_ddrphy_apb_wr(0x90069, 0x65a); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b21s1 +dwc_ddrphy_apb_wr(0x9006a, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b21s2 +dwc_ddrphy_apb_wr(0x9006b, 0x41); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b22s0 +dwc_ddrphy_apb_wr(0x9006c, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b22s1 +dwc_ddrphy_apb_wr(0x9006d, 0x179); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b22s2 +dwc_ddrphy_apb_wr(0x9006e, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b23s0 +dwc_ddrphy_apb_wr(0x9006f, 0x618); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b23s1 +dwc_ddrphy_apb_wr(0x90070, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b23s2 +dwc_ddrphy_apb_wr(0x90071, 0x40c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b24s0 +dwc_ddrphy_apb_wr(0x90072, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b24s1 +dwc_ddrphy_apb_wr(0x90073, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b24s2 +dwc_ddrphy_apb_wr(0x90074, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b25s0 +dwc_ddrphy_apb_wr(0x90075, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b25s1 +dwc_ddrphy_apb_wr(0x90076, 0x48); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b25s2 +dwc_ddrphy_apb_wr(0x90077, 0x4040); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b26s0 +dwc_ddrphy_apb_wr(0x90078, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b26s1 +dwc_ddrphy_apb_wr(0x90079, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b26s2 +dwc_ddrphy_apb_wr(0x9007a, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b27s0 +dwc_ddrphy_apb_wr(0x9007b, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b27s1 +dwc_ddrphy_apb_wr(0x9007c, 0x48); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b27s2 +dwc_ddrphy_apb_wr(0x9007d, 0x40); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b28s0 +dwc_ddrphy_apb_wr(0x9007e, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b28s1 +dwc_ddrphy_apb_wr(0x9007f, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b28s2 +dwc_ddrphy_apb_wr(0x90080, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b29s0 +dwc_ddrphy_apb_wr(0x90081, 0x658); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b29s1 +dwc_ddrphy_apb_wr(0x90082, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b29s2 +dwc_ddrphy_apb_wr(0x90083, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b30s0 +dwc_ddrphy_apb_wr(0x90084, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b30s1 +dwc_ddrphy_apb_wr(0x90085, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b30s2 +dwc_ddrphy_apb_wr(0x90086, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b31s0 +dwc_ddrphy_apb_wr(0x90087, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b31s1 +dwc_ddrphy_apb_wr(0x90088, 0x78); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b31s2 +dwc_ddrphy_apb_wr(0x90089, 0x549); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b32s0 +dwc_ddrphy_apb_wr(0x9008a, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b32s1 +dwc_ddrphy_apb_wr(0x9008b, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b32s2 +dwc_ddrphy_apb_wr(0x9008c, 0xd49); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b33s0 +dwc_ddrphy_apb_wr(0x9008d, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b33s1 +dwc_ddrphy_apb_wr(0x9008e, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b33s2 +dwc_ddrphy_apb_wr(0x9008f, 0x94c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b34s0 +dwc_ddrphy_apb_wr(0x90090, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b34s1 +dwc_ddrphy_apb_wr(0x90091, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b34s2 +dwc_ddrphy_apb_wr(0x90092, 0x94c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b35s0 +dwc_ddrphy_apb_wr(0x90093, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b35s1 +dwc_ddrphy_apb_wr(0x90094, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b35s2 +dwc_ddrphy_apb_wr(0x90095, 0x442); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b36s0 +dwc_ddrphy_apb_wr(0x90096, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b36s1 +dwc_ddrphy_apb_wr(0x90097, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b36s2 +dwc_ddrphy_apb_wr(0x90098, 0x42); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b37s0 +dwc_ddrphy_apb_wr(0x90099, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b37s1 +dwc_ddrphy_apb_wr(0x9009a, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b37s2 +dwc_ddrphy_apb_wr(0x9009b, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b38s0 +dwc_ddrphy_apb_wr(0x9009c, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b38s1 +dwc_ddrphy_apb_wr(0x9009d, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b38s2 +dwc_ddrphy_apb_wr(0x9009e, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b39s0 +dwc_ddrphy_apb_wr(0x9009f, 0xe0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b39s1 +dwc_ddrphy_apb_wr(0x900a0, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b39s2 +dwc_ddrphy_apb_wr(0x900a1, 0xa); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b40s0 +dwc_ddrphy_apb_wr(0x900a2, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b40s1 +dwc_ddrphy_apb_wr(0x900a3, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b40s2 +dwc_ddrphy_apb_wr(0x900a4, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b41s0 +dwc_ddrphy_apb_wr(0x900a5, 0x3c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b41s1 +dwc_ddrphy_apb_wr(0x900a6, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b41s2 +dwc_ddrphy_apb_wr(0x900a7, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b42s0 +dwc_ddrphy_apb_wr(0x900a8, 0x3c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b42s1 +dwc_ddrphy_apb_wr(0x900a9, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b42s2 +dwc_ddrphy_apb_wr(0x900aa, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b43s0 +dwc_ddrphy_apb_wr(0x900ab, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b43s1 +dwc_ddrphy_apb_wr(0x900ac, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b43s2 +dwc_ddrphy_apb_wr(0x900ad, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b44s0 +dwc_ddrphy_apb_wr(0x900ae, 0x3c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b44s1 +dwc_ddrphy_apb_wr(0x900af, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b44s2 +dwc_ddrphy_apb_wr(0x900b0, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b45s0 +dwc_ddrphy_apb_wr(0x900b1, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b45s1 +dwc_ddrphy_apb_wr(0x900b2, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b45s2 +dwc_ddrphy_apb_wr(0x900b3, 0xc); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b46s0 +dwc_ddrphy_apb_wr(0x900b4, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b46s1 +dwc_ddrphy_apb_wr(0x900b5, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b46s2 +dwc_ddrphy_apb_wr(0x900b6, 0x3); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b47s0 +dwc_ddrphy_apb_wr(0x900b7, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b47s1 +dwc_ddrphy_apb_wr(0x900b8, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b47s2 +dwc_ddrphy_apb_wr(0x900b9, 0x7); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b48s0 +dwc_ddrphy_apb_wr(0x900ba, 0x7c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b48s1 +dwc_ddrphy_apb_wr(0x900bb, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b48s2 +//// [phyinit_LoadPIECodeSections] Matched ANY enable_bits = 8, type = 0 +dwc_ddrphy_apb_wr(0x900bc, 0x3a); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b49s0 +dwc_ddrphy_apb_wr(0x900bd, 0x1e2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b49s1 +dwc_ddrphy_apb_wr(0x900be, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b49s2 +dwc_ddrphy_apb_wr(0x900bf, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b50s0 +dwc_ddrphy_apb_wr(0x900c0, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b50s1 +dwc_ddrphy_apb_wr(0x900c1, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b50s2 +dwc_ddrphy_apb_wr(0x900c2, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b51s0 +dwc_ddrphy_apb_wr(0x900c3, 0x8140); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b51s1 +dwc_ddrphy_apb_wr(0x900c4, 0x10c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b51s2 +dwc_ddrphy_apb_wr(0x900c5, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b52s0 +dwc_ddrphy_apb_wr(0x900c6, 0x8138); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b52s1 +dwc_ddrphy_apb_wr(0x900c7, 0x10c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b52s2 +//// [phyinit_LoadPIECodeSections] Matched ANY enable_bits = 1, type = 0 +dwc_ddrphy_apb_wr(0x900c8, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b53s0 +dwc_ddrphy_apb_wr(0x900c9, 0x400); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b53s1 +dwc_ddrphy_apb_wr(0x900ca, 0x10e); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b53s2 +dwc_ddrphy_apb_wr(0x900cb, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b54s0 +dwc_ddrphy_apb_wr(0x900cc, 0x448); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b54s1 +dwc_ddrphy_apb_wr(0x900cd, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b54s2 +dwc_ddrphy_apb_wr(0x900ce, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b55s0 +dwc_ddrphy_apb_wr(0x900cf, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b55s1 +dwc_ddrphy_apb_wr(0x900d0, 0x101); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b55s2 +dwc_ddrphy_apb_wr(0x900d1, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b56s0 +dwc_ddrphy_apb_wr(0x900d2, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b56s1 +dwc_ddrphy_apb_wr(0x900d3, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b56s2 +dwc_ddrphy_apb_wr(0x900d4, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b57s0 +dwc_ddrphy_apb_wr(0x900d5, 0x448); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b57s1 +dwc_ddrphy_apb_wr(0x900d6, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b57s2 +dwc_ddrphy_apb_wr(0x900d7, 0xf); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b58s0 +dwc_ddrphy_apb_wr(0x900d8, 0x7c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b58s1 +dwc_ddrphy_apb_wr(0x900d9, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b58s2 +dwc_ddrphy_apb_wr(0x900da, 0x7); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s0 +dwc_ddrphy_apb_wr(0x900db, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s1 +dwc_ddrphy_apb_wr(0x900dc, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s2 +dwc_ddrphy_apb_wr(0x900dd, 0x47); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b60s0 +dwc_ddrphy_apb_wr(0x900de, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b60s1 +dwc_ddrphy_apb_wr(0x900df, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b60s2 +dwc_ddrphy_apb_wr(0x900e0, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b61s0 +dwc_ddrphy_apb_wr(0x900e1, 0x618); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b61s1 +dwc_ddrphy_apb_wr(0x900e2, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b61s2 +dwc_ddrphy_apb_wr(0x900e3, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b62s0 +dwc_ddrphy_apb_wr(0x900e4, 0xe0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b62s1 +dwc_ddrphy_apb_wr(0x900e5, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b62s2 +dwc_ddrphy_apb_wr(0x900e6, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b63s0 +dwc_ddrphy_apb_wr(0x900e7, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b63s1 +dwc_ddrphy_apb_wr(0x900e8, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b63s2 +dwc_ddrphy_apb_wr(0x900e9, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b64s0 +dwc_ddrphy_apb_wr(0x900ea, 0x8140); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b64s1 +dwc_ddrphy_apb_wr(0x900eb, 0x10c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b64s2 +dwc_ddrphy_apb_wr(0x900ec, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b65s0 +dwc_ddrphy_apb_wr(0x900ed, 0x478); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b65s1 +dwc_ddrphy_apb_wr(0x900ee, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b65s2 +dwc_ddrphy_apb_wr(0x900ef, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b66s0 +dwc_ddrphy_apb_wr(0x900f0, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b66s1 +dwc_ddrphy_apb_wr(0x900f1, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b66s2 +dwc_ddrphy_apb_wr(0x900f2, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b67s0 +dwc_ddrphy_apb_wr(0x900f3, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b67s1 +dwc_ddrphy_apb_wr(0x900f4, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b67s2 +dwc_ddrphy_apb_wr(0x900f5, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b68s0 +dwc_ddrphy_apb_wr(0x900f6, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b68s1 +dwc_ddrphy_apb_wr(0x900f7, 0x101); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b68s2 +//// [phyinit_LoadPIECodeSections] Moving start address from 900f8 to 90006 +dwc_ddrphy_apb_wr(0x90006, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b0s0 +dwc_ddrphy_apb_wr(0x90007, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b0s1 +dwc_ddrphy_apb_wr(0x90008, 0x8); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b0s2 +dwc_ddrphy_apb_wr(0x90009, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b1s0 +dwc_ddrphy_apb_wr(0x9000a, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b1s1 +dwc_ddrphy_apb_wr(0x9000b, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b1s2 +//// [phyinit_LoadPIECodeSections] Moving start address from 9000c to d00e7 +dwc_ddrphy_apb_wr(0xd00e7, 0x400); // DWC_DDRPHYA_APBONLY0_SequencerOverride +//// [phyinit_LoadPIECodeSections] End of dwc_ddrphy_phyinit_LoadPIECodeSections() +//seq0b_LoadPstateSeqProductionCode(): --------------------------------------------------------------------------------------------------- +//seq0b_LoadPstateSeqProductionCode(): Programming the 0B sequencer 0b0000 start vector registers with 0. +//seq0b_LoadPstateSeqProductionCode(): Programming the 0B sequencer 0b1111 start vector register with 56. +//seq0b_LoadPstateSeqProductionCode(): --------------------------------------------------------------------------------------------------- +dwc_ddrphy_apb_wr(0x90017, 0x0); // DWC_DDRPHYA_INITENG0_base0_StartVector0b0 +dwc_ddrphy_apb_wr(0x90026, 0x38); // DWC_DDRPHYA_INITENG0_base0_StartVector0b15 +dwc_ddrphy_apb_wr(0x9000c, 0x0); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag0 +dwc_ddrphy_apb_wr(0x9000d, 0x173); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag1 +dwc_ddrphy_apb_wr(0x9000e, 0x60); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag2 +dwc_ddrphy_apb_wr(0x9000f, 0x6110); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag3 +dwc_ddrphy_apb_wr(0x90010, 0x2152); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag4 +dwc_ddrphy_apb_wr(0x90011, 0xdfbd); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag5 +dwc_ddrphy_apb_wr(0x90012, 0xffff); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag6 +dwc_ddrphy_apb_wr(0x90013, 0x6152); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag7 +//// [phyinit_I_loadPIEImage] Programming D4PowerControl::D4CATxDllLP to 0x1 +//// [phyinit_I_loadPIEImage] Programming AcLcdlMasDis to 0xfff +dwc_ddrphy_apb_wr(0x2006d, 0x1); // DWC_DDRPHYA_MASTER0_base0_D4PowerControl +dwc_ddrphy_apb_wr(0x200e8, 0xfff); // DWC_DDRPHYA_MASTER0_base0_AcLcdlMasDis +//// [phyinit_I_loadPIEImage] Turn on calibration and hold idle until dfi_init_start is asserted sequence is triggered. +//// [phyinit_I_loadPIEImage] Programming CalZap to 0x1 +//// [phyinit_I_loadPIEImage] Programming CalRate::CalRun to 0x1 +//// [phyinit_I_loadPIEImage] Programming CalRate to 0x19 +dwc_ddrphy_apb_wr(0x20089, 0x1); // DWC_DDRPHYA_MASTER0_base0_CalZap +dwc_ddrphy_apb_wr(0x20088, 0x19); // DWC_DDRPHYA_MASTER0_base0_CalRate +//// [phyinit_I_loadPIEImage] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x0 +dwc_ddrphy_apb_wr(0x200a6, 0x0); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +//// Disabling Ucclk (PMU) and Hclk (training hardware) +dwc_ddrphy_apb_wr(0xc0080, 0x0); // DWC_DDRPHYA_DRTUB0_UcclkHclkEnables +//// Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_I_loadPIEImage] End of dwc_ddrphy_phyinit_I_loadPIEImage() +// +// +////############################################################## +//// +//// dwc_ddrphy_phyinit_userCustom_customPostTrain is a user-editable function. +//// +//// The purpose of dwc_ddrphy_phyinit_userCustom_customPostTrain() is to override any +//// CSR values programmed by the training firmware or dwc_ddrphy_phyinit_progCsrSkipTrain() +//// This function is executed after training +//// +//// IMPORTANT: in this function, user shall not override any values in userInputBasic and +//// userInputAdvanced data structures. Only CSR programming should be done in this function. +//// +//// Sequence of Events in this function are: +//// 1. Enable APB access. +//// 2. Issue register writes +//// 3. Isolate APB access. +// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_customPostTrain(); + +//// [dwc_ddrphy_phyinit_userCustom_customPostTrain] End of dwc_ddrphy_phyinit_userCustom_customPostTrain() +//// [dwc_ddrphy_phyinit_userCustom_J_enterMissionMode] Start of dwc_ddrphy_phyinit_userCustom_J_enterMissionMode() +// +// +////############################################################## +//// +//// 4.3.10(J) Initialize the PHY to Mission Mode through DFI Initialization +//// +//// Initialize the PHY to mission mode as follows: +//// +//// 1. Set the PHY input clocks to the desired frequency. +//// 2. Initialize the PHY to mission mode by performing DFI Initialization. +//// Please see the DFI specification for more information. See the DFI frequency bus encoding in section <XXX>. +//// Note: The PHY training firmware initializes the DRAM state. if skip +//// training is used, the DRAM state is not initialized. +//// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_J_enterMissionMode(sdrammc); + +// +//// [dwc_ddrphy_phyinit_userCustom_J_enterMissionMode] End of dwc_ddrphy_phyinit_userCustom_J_enterMissionMode() +// [dwc_ddrphy_phyinit_sequence] End of dwc_ddrphy_phyinit_sequence() +// [dwc_ddrphy_phyinit_main] End of dwc_ddrphy_phyinit_main() diff --git a/drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr5-3200-nodimm-train2D.c b/drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr5-3200-nodimm-train2D.c new file mode 100644 index 00000000000..d21bcda6fb8 --- /dev/null +++ b/drivers/ram/aspeed/dwc_ddrphy_phyinit_ddr5-3200-nodimm-train2D.c @@ -0,0 +1,6930 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) ASPEED Technology Inc. + */ +// [dwc_ddrphy_phyinit_main] Start of dwc_ddrphy_phyinit_main() +// [dwc_ddrphy_phyinit_sequence] Start of dwc_ddrphy_phyinit_sequence() +// [dwc_ddrphy_phyinit_initStruct] Start of dwc_ddrphy_phyinit_initStruct() +// [dwc_ddrphy_phyinit_initStruct] End of dwc_ddrphy_phyinit_initStruct() +// [dwc_ddrphy_phyinit_setDefault] Start of dwc_ddrphy_phyinit_setDefault() +// [dwc_ddrphy_phyinit_setDefault] End of dwc_ddrphy_phyinit_setDefault() + +////############################################################## +// +//// dwc_ddrphy_phyinit_userCustom_overrideUserInput is a user-editable function. User can edit this function according to their needs. +//// +//// The purpose of dwc_ddrphy_phyinit_userCustom_overrideUserInput() is to override any +//// any field in Phyinit data structure set by dwc_ddrphy_phyinit_setDefault() +//// User should only override values in userInputBasic and userInputAdvanced. +//// IMPORTANT: in this function, user shall not override any values in the +//// messageblock directly on the data structue as the might be overwritten by +//// dwc_ddrphy_phyinit_calcMb(). Use dwc_ddrphy_phyinit_setMb() to set +//// messageblock parameters for override values to remain pervasive if +//// desired +// +////############################################################## + +dwc_ddrphy_phyinit_userCustom_overrideUserInput(); +// +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramType' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DimmType' to 0x4 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumDbyte' to 0x2 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumActiveDbyteDfi0' to 0x2 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumActiveDbyteDfi1' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumAnib' to 0xa +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumRank_dfi0' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumRank_dfi1' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[0]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[1]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[2]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DramDataWidth[3]' to 0x10 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'NumPStates' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Frequency[0]' to 0x640 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PllBypass[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DfiFreqRatio[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Dfi1Exists' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'ExtCalResVal' to 0xf0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'ODTImpedance[0]' to 0x78 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxImpedance[0]' to 0x3c +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'MemAlertEn' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'MtestPUImp' to 0xf0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DisDynAdrTri[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PhyMstrTrainInterval[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PhyMstrMaxReqToAck[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'PhyMstrCtrlMode[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'WDQSExt' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'CalInterval' to 0x9 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'CalOnce' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'RxEnBackOff' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TrainSequenceCtrl' to 0x837f +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'SnpsUmctlOpt' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'SnpsUmctlF0RC5x[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewRiseDQ[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewFallDQ[0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewRiseAC' to 0x66 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewFallAC' to 0x26 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'IsHighVDD' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewRiseCK' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'TxSlewFallCK' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnTdqs2dqTrackingTg0[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnTdqs2dqTrackingTg1[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnTdqs2dqTrackingTg2[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnTdqs2dqTrackingTg3[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DqsOscRunTimeSel[0]' to 0x100 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnRxDqsTracking[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'D5TxDqPreambleCtrl[0]' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'D5DisableRetraining' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'DisablePmuEcc' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'EnableMAlertAsync' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'Apb32BitMode' to 0x1 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tDQS2DQ' to 0x2ee +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tDQSCK' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_override' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][0]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][1]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][2]' to 0x0 +//// [dwc_ddrphy_phyinit_setUserInput] Setting PHYINIT field 'tCASL_add[0][3]' to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MsgMisc to 0x7 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].Pstate to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].PllBypassEn to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].DRAMFreq to 0xc80 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].PhyVref to 0x40 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].D5Misc to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].WL_ADJ to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].SequenceCtrl to 0x837f +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].HdtCtrl to 0xc8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].PhyCfg to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].DFIMRLMargin to 0x2 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].X16Present to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].UseBroadcastMR to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].DisabledDbyte to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].CATrainOpt to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].PhyConfigOverride to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].EnabledDQsChA to 0x10 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].CsPresentChA to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_A0 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_A0 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_A0 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_A0 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_A0 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_A0 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_A0 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_A0 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_A0 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_A0 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_A0 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_A0 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_A0 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_A0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_A1 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_A1 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_A1 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_A1 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_A1 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_A1 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_A1 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_A1 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_A1 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_A1 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_A1 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_A1 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_A1 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_A1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_A2 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_A2 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_A2 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_A2 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_A2 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_A2 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_A2 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_A2 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_A2 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_A2 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_A2 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_A2 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_A2 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_A2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_A3 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_A3 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_A3 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_A3 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_A3 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_A3 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_A3 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_A3 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_A3 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_A3 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_A3 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_A3 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_A3 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_A3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].EnabledDQsChB to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].CsPresentChB to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_B0 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_B0 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_B0 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_B0 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_B0 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_B0 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_B0 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_B0 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_B0 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_B0 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_B0 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_B0 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_B0 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_B0 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_B1 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_B1 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_B1 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_B1 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_B1 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_B1 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_B1 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_B1 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_B1 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_B1 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_B1 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_B1 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_B1 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_B1 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_B2 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_B2 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_B2 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_B2 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_B2 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_B2 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_B2 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_B2 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_B2 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_B2 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_B2 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_B2 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_B2 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_B2 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR0_B3 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR2_B3 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR3_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR4_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR5_B3 to 0x20 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR6_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR8_B3 to 0x8 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR10_B3 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR11_B3 to 0x2d +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR12_B3 to 0xd6 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR13_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR14_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR15_B3 to 0x3 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR111_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR32_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR33_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR34_B3 to 0x11 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR35_B3 to 0x4 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR37_B3 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR38_B3 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR39_B3 to 0x2c +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR50_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR51_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].MR52_B3 to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].WL_ADJ_START to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].WL_ADJ_END to 0x0 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].RCW00_ChA_D0 to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].RCW00_ChA_D1 to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].RCW00_ChB_D0 to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].RCW00_ChB_D1 to 0x1 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib0 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib1 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib2 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib3 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib4 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib5 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib6 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib7 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib8 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib9 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib10 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib11 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib12 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib13 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib14 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib15 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib16 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib17 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib18 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR0Nib19 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib0 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib1 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib2 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib3 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib4 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib5 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib6 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib7 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib8 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib9 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib10 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib11 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib12 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib13 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib14 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib15 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib16 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib17 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib18 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR1Nib19 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib0 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib1 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib2 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib3 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib4 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib5 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib6 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib7 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib8 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib9 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib10 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib11 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib12 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib13 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib14 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib15 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib16 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib17 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib18 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR2Nib19 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib0 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib1 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib2 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib3 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib4 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib5 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib6 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib7 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib8 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib9 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib10 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib11 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib12 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib13 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib14 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib15 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib16 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib17 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib18 to 0x17 +// [dwc_ddrphy_phyinit_setMb] Setting mb_DDR5U_1D[0].VrefDqR3Nib19 to 0x17 +// [dwc_ddrphy_phyinit_userCustom_overrideUserInput] End of dwc_ddrphy_phyinit_userCustom_overrideUserInput() +//[dwc_ddrphy_phyinit_calcMb] Start of dwc_ddrphy_phyinit_calcMb() +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR5U_1D[0].Pstate override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR5U_1D[0].DRAMFreq override to 0xc80 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR5U_1D[0].PllBypassEn override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR5U_1D[0].X16Present override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR5U_1D[0].EnabledDQsChA override to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] mb_DDR5U_1D[0].EnabledDQsChB override to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[1].Pstate to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[1].DRAMFreq to 0x856 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[1].PllBypassEn to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[1].X16Present to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[1].EnabledDQsChA to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[1].EnabledDQsChB to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[2].Pstate to 0x2 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[2].DRAMFreq to 0x74a +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[2].PllBypassEn to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[2].X16Present to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[2].EnabledDQsChA to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[2].EnabledDQsChB to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[3].Pstate to 0x3 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[3].DRAMFreq to 0x640 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[3].PllBypassEn to 0x0 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[3].X16Present to 0x1 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[3].EnabledDQsChA to 0x10 +//// [dwc_ddrphy_phyinit_softSetMb] Setting mb_DDR5U_1D[3].EnabledDQsChB to 0x0 +////[dwc_ddrphy_phyinit_calcMb] TG_active[0] = 1 +////[dwc_ddrphy_phyinit_calcMb] TG_active[1] = 0 +////[dwc_ddrphy_phyinit_calcMb] TG_active[2] = 0 +////[dwc_ddrphy_phyinit_calcMb] TG_active[3] = 0 +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=0] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=0] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=0] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=1] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=1] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=1] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=2] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=2] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=2] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_CK [pstate=0][tg=3] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] tDIMM_DQ [pstate=0][tg=3] = 0 ps +////[dwc_ddrphy_phyinit_calcMb] userInputSim.tCASL_add[pstate=0][tg=3] = 0 ps +//[dwc_ddrphy_phyinit_calcMb] End of dwc_ddrphy_phyinit_calcMb() +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // Printing values in user input structure +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[0] = 16 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[1] = 16 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[2] = 16 +//// [phyinit_print_dat] pUserInputBasic->DramDataWidth[3] = 16 +//// [phyinit_print_dat] pUserInputBasic->NumActiveDbyteDfi1 = 0 +//// [phyinit_print_dat] pUserInputBasic->DramType = 1 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitValOvr = 0 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[0] = 3 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[1] = 3 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[2] = 3 +//// [phyinit_print_dat] pUserInputBasic->ARdPtrInitVal[3] = 3 +//// [phyinit_print_dat] pUserInputBasic->Dfi1Exists = 0 +//// [phyinit_print_dat] pUserInputBasic->Frequency[0] = 1600 +//// [phyinit_print_dat] pUserInputBasic->Frequency[1] = 1067 +//// [phyinit_print_dat] pUserInputBasic->Frequency[2] = 933 +//// [phyinit_print_dat] pUserInputBasic->Frequency[3] = 800 +//// [phyinit_print_dat] pUserInputBasic->NumActiveDbyteDfi0 = 2 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[0] = 0 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[1] = 0 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[2] = 0 +//// [phyinit_print_dat] pUserInputBasic->DisPtrInitClrTxTracking[3] = 0 +//// [phyinit_print_dat] pUserInputBasic->NumRank_dfi0 = 1 +//// [phyinit_print_dat] pUserInputBasic->NumPStates = 1 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[0] = 0 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[1] = 0 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[2] = 0 +//// [phyinit_print_dat] pUserInputBasic->PllBypass[3] = 0 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[0] = 1 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[1] = 1 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[2] = 1 +//// [phyinit_print_dat] pUserInputBasic->DfiFreqRatio[3] = 1 +//// [phyinit_print_dat] pUserInputBasic->NumAnib = 10 +//// [phyinit_print_dat] pUserInputBasic->DimmType = 4 +//// [phyinit_print_dat] pUserInputBasic->NumRank_dfi1 = 0 +//// [phyinit_print_dat] pUserInputBasic->NumDbyte = 2 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg1[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg1[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg1[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg1[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg0[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg0[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg0[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg0[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlF0RC5x[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl2[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->IsHighVDD = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DramByteSwap[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->ExtCalResVal = 240 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4TxPreambleLength[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->RxEnBackOff = 1 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[4] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[5] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[6] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvLaneSel[7] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->CalOnce = 0 +//// [phyinit_print_dat] pUserInputAdvanced->Apb32BitMode = 1 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseCK = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallAC = 38 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallCK = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisablePmuEcc = 1 +//// [phyinit_print_dat] pUserInputAdvanced->SnpsUmctlOpt = 0 +//// [phyinit_print_dat] pUserInputAdvanced->WDQSExt = 0 +//// [phyinit_print_dat] pUserInputAdvanced->VREGCtrl_LP2_PwrSavings_En = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseAC = 102 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DisDynAdrTri[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[4] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[5] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[6] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AnibRcvEn[7] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg3[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg3[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg3[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg3[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrTrainInterval[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->rtt_term_en = 0 +//// [phyinit_print_dat] pUserInputAdvanced->AlertRecoveryEnable = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewRiseDQ[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->en_16LogicalRanks_3DS = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[1] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[2] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->D4RxPreambleLength[3] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrCtrlMode[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxSlewFallDQ[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[4] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[5] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[6] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->NvAnibRcvSel[7] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[0] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[1] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[2] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedanceCtrl1[3] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->Nibble_ECC = 15 +//// [phyinit_print_dat] pUserInputAdvanced->D5DisableRetraining = 0 +//// [phyinit_print_dat] pUserInputAdvanced->DqsOscRunTimeSel[0] = 256 +//// [phyinit_print_dat] pUserInputAdvanced->DqsOscRunTimeSel[1] = 256 +//// [phyinit_print_dat] pUserInputAdvanced->DqsOscRunTimeSel[2] = 256 +//// [phyinit_print_dat] pUserInputAdvanced->DqsOscRunTimeSel[3] = 256 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[0] = 120 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[1] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[2] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->ODTImpedance[3] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->MtestPUImp = 240 +//// [phyinit_print_dat] pUserInputAdvanced->EnableMAlertAsync = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[0] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->PhyMstrMaxReqToAck[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->RedundantCs_en = 0 +//// [phyinit_print_dat] pUserInputAdvanced->CalInterval = 9 +//// [phyinit_print_dat] pUserInputAdvanced->D5TxDqPreambleCtrl[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->D5TxDqPreambleCtrl[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D5TxDqPreambleCtrl[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->D5TxDqPreambleCtrl[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->MemAlertEn = 0 +//// [phyinit_print_dat] pUserInputAdvanced->ATxImpedance = 53247 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg2[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg2[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg2[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnTdqs2dqTrackingTg2[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->en_3DS = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnRxDqsTracking[0] = 1 +//// [phyinit_print_dat] pUserInputAdvanced->EnRxDqsTracking[1] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnRxDqsTracking[2] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->EnRxDqsTracking[3] = 0 +//// [phyinit_print_dat] pUserInputAdvanced->RstRxTrkState = 0 +//// [phyinit_print_dat] pUserInputAdvanced->TrainSequenceCtrl = 33663 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[0] = 60 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[1] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[2] = 25 +//// [phyinit_print_dat] pUserInputAdvanced->TxImpedance[3] = 25 +//// [phyinit_print_dat] pUserInputSim->tDQS2DQ = 750 +//// [phyinit_print_dat] pUserInputSim->tDQSCK = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[0] = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[1] = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[2] = 0 +//// [phyinit_print_dat] pUserInputSim->tSTAOFF[3] = 0 +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // Printing values of 1D message block input/inout fields, PState=0 +//// [phyinit_print_dat] // +//// [phyinit_print_dat] // #################################################### +//// [phyinit_print_dat] mb_DDR5U_1D[0].AdvTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MsgMisc = 0x7 +//// [phyinit_print_dat] mb_DDR5U_1D[0].Pstate = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PllBypassEn = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DRAMFreq = 0xc80 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RXEN_ADJ = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RX2D_DFE_Misc = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PhyVref = 0x40 +//// [phyinit_print_dat] mb_DDR5U_1D[0].D5Misc = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WL_ADJ = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].SequenceCtrl = 0x837f +//// [phyinit_print_dat] mb_DDR5U_1D[0].HdtCtrl = 0xc8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PhyCfg = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFIMRLMargin = 0x2 +//// [phyinit_print_dat] mb_DDR5U_1D[0].X16Present = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].UseBroadcastMR = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].D5Quickboot = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDbyte = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].CATrainOpt = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].TX2D_DFE_Misc = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].TX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].Share2DVrefResult = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MRE_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DWL_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PhyConfigOverride = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].EnabledDQsChA = 0x10 +//// [phyinit_print_dat] mb_DDR5U_1D[0].CsPresentChA = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A0 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A0 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A0 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A0 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A1 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A1 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A1 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A1 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A2 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A2 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A2 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A2 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A3 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A3 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A3 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A3 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].EnabledDQsChB = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].CsPresentChB = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B0 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B0 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B0 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B0 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B1 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B1 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B1 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B1 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B2 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B2 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B2 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B2 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B3 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B3 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B3 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B3 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WL_ADJ_START = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WL_ADJ_END = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChA_D0 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChA_D1 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChB_D0 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChB_D1 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].AdvTrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MsgMisc = 0x7 +//// [phyinit_print_dat] mb_DDR5U_1D[0].Pstate = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PllBypassEn = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DRAMFreq = 0xc80 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RXEN_ADJ = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RX2D_DFE_Misc = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PhyVref = 0x40 +//// [phyinit_print_dat] mb_DDR5U_1D[0].D5Misc = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WL_ADJ = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].SequenceCtrl = 0x837f +//// [phyinit_print_dat] mb_DDR5U_1D[0].HdtCtrl = 0xc8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PhyCfg = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFIMRLMargin = 0x2 +//// [phyinit_print_dat] mb_DDR5U_1D[0].X16Present = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].UseBroadcastMR = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].D5Quickboot = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDbyte = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].CATrainOpt = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].TX2D_DFE_Misc = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].TX2D_TrainOpt = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].Share2DVrefResult = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MRE_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DWL_MIN_PULSE = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].PhyConfigOverride = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].EnabledDQsChA = 0x10 +//// [phyinit_print_dat] mb_DDR5U_1D[0].CsPresentChA = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A0 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A0 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A0 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A0 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A1 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A1 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A1 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A1 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A2 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A2 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A2 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A2 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_A3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_A3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_A3 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_A3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_A3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A3 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_A3 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_A3 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_A3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_A3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_A3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_A3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_A3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_A3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].EnabledDQsChB = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].CsPresentChB = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B0 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B0 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B0 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B0 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B0 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B0 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B0 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B0 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B0_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B1 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B1 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B1 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B1 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B1 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B1 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B1 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B1 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B1_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B2 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B2 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B2 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B2 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B2 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B2 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B2 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B2 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B2_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR0_B3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR2_B3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR4_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR5_B3 = 0x20 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR6_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR8_B3 = 0x8 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR10_B3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B3 = 0x2d +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B3 = 0xd6 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR14_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR15_B3 = 0x3 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR111_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR34_B3 = 0x11 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR35_B3 = 0x4 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR32_ORG_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR37_B3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR38_B3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR39_B3 = 0x2c +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR11_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR12_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR13_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_ORG_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR33_B3_next = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR50_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR51_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR52_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DFE_GainBias_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WR_RD_RTT_PARK_B3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WL_ADJ_START = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].WL_ADJ_END = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChA_D0 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChA_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChA_D1 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChA_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChB_D0 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChB_D0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW00_ChB_D1 = 0x1 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW01_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW02_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW03_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW04_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW05_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW06_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW07_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW08_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW09_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW0F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW10_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW11_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW12_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW13_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW14_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW15_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW16_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW17_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW18_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW19_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW1F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW20_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW21_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW22_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW23_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW24_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW25_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW26_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW27_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW28_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW29_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW2F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW30_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW31_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW32_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW33_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW34_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW35_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW36_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW37_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW38_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW39_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW3F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW40_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW41_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW42_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW43_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW44_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW45_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW46_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW47_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW48_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW49_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW4F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW50_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW51_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW52_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW53_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW54_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW55_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW56_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW57_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW58_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW59_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW5F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW60_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW61_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW62_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW63_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW64_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW65_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW66_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW67_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW68_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW69_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW6F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW70_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW71_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW72_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW73_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW74_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW75_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW76_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW77_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW78_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW79_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].RCW7F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW00_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW01_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW02_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW03_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW04_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW05_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW06_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW07_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW08_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW09_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW0F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW10_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW11_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW12_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW13_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW14_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW15_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW16_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW17_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW18_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW19_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW1F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW20_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW21_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW22_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW23_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW24_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW25_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW26_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW27_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW28_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW29_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW2F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW30_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW31_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW32_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW33_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW34_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW35_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW36_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW37_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW38_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW39_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW3F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW40_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW41_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW42_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW43_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW44_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW45_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW46_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW47_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW48_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW49_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW4F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW50_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW51_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW52_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW53_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW54_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW55_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW56_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW57_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW58_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW59_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW5F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW60_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW61_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW62_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW63_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW64_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW65_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW66_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW67_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW68_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW69_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW6F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW70_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW71_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW72_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW73_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW74_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW75_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW76_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW77_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW78_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW79_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7A_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7B_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7C_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7D_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7E_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].BCW7F_ChB_D1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR0Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR1Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR2Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib0 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib1 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib2 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib3 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib4 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib5 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib6 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib7 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib8 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib9 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib10 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib11 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib12 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib13 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib14 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib15 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib16 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib17 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib18 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefDqR3Nib19 = 0x17 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R0Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R1Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R2Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].MR3R3Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR0Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR1Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR2Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCSR3Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR0Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR1Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR2Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib4 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib5 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib6 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib7 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib8 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib9 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib10 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib11 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib12 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib13 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib14 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib15 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib16 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib17 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib18 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].VrefCAR3Nib19 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR0 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR1 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR2 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB0LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB1LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB2LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB3LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB4LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB5LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB6LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB7LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB8LaneR3 = 0x0 +//// [phyinit_print_dat] mb_DDR5U_1D[0].DisabledDB9LaneR3 = 0x0 + +////############################################################## +//// +//// Step (A) : Bring up VDD, VDDQ, and VAA +//// +//// The power supplies can come up and stabilize in any order. +//// While the power supplies are coming up, all outputs will be unknown and +//// the values of the inputs are don't cares. +//// +////############################################################## + +dwc_ddrphy_phyinit_userCustom_A_bringupPower(); + +//[dwc_ddrphy_phyinit_userCustom_A_bringupPower] End of dwc_ddrphy_phyinit_userCustom_A_bringupPower() +// +// +////############################################################## +//// +//// 4.3.2(B) Start Clocks and Reset the PHY +//// +//// Following is one possbile sequence to reset the PHY. Other sequences are also possible. +//// See section 5.2.2 of the PUB for other possible reset sequences. +//// +//// 1. Drive PwrOkIn to 0. Note: Reset, DfiClk, and APBCLK can be X. +//// 2. Start DfiClk and APBCLK +//// 3. Drive Reset to 1 and PRESETn_APB to 0. +//// Note: The combination of PwrOkIn=0 and Reset=1 signals a cold reset to the PHY. +//// 4. Wait a minimum of 8 cycles. +//// 5. Drive PwrOkIn to 1. Once the PwrOkIn is asserted (and Reset is still asserted), +//// DfiClk synchronously switches to any legal input frequency. +//// 6. Wait a minimum of 64 cycles. Note: This is the reset period for the PHY. +//// 7. Drive Reset to 0. Note: All DFI and APB inputs must be driven at valid reset states before the deassertion of Reset. +//// 8. Wait a minimum of 1 Cycle. +//// 9. Drive PRESETn_APB to 1 to de-assert reset on the ABP bus. +////10. The PHY is now in the reset state and is ready to accept APB transactions. +//// +////############################################################## +// +// +dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy(sdrammc); + +//// [dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy] End of dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy() +// + +////############################################################## +//// +//// Step (C) Initialize PHY Configuration +//// +//// Load the required PHY configuration registers for the appropriate mode and memory configuration +//// +////############################################################## +// + +//// [phyinit_C_initPhyConfig] Start of dwc_ddrphy_phyinit_C_initPhyConfig() +//// [phyinit_C_initPhyConfig] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x1 +dwc_ddrphy_apb_wr(0x200a6, 0x2); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for MASTER +dwc_ddrphy_apb_wr(0x20066, 0x0); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all DBYTEs +dwc_ddrphy_apb_wr(0x10066, 0x0); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x11066, 0x0); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all ANIBs +dwc_ddrphy_apb_wr(0x66, 0x0); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x1066, 0x0); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x2066, 0x0); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x3066, 0x0); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x4066, 0x0); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x5066, 0x0); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x6066, 0x0); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x7066, 0x0); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x8066, 0x0); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x9066, 0x0); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl1::VshDAC to 0x16 for MASTER +dwc_ddrphy_apb_wr(0x20029, 0x58); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl1_p0 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl1::VshDAC to 0x16 for all DBYTEs +dwc_ddrphy_apb_wr(0x10029, 0x58); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x11029, 0x58); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl1_p0 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl1::VshDAC to 0x16 for all ANIBs +dwc_ddrphy_apb_wr(0x29, 0x58); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x1029, 0x58); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x2029, 0x58); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x3029, 0x58); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x4029, 0x58); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x5029, 0x58); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x6029, 0x58); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x7029, 0x58); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x8029, 0x58); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x9029, 0x58); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl1_p0 +dwc_ddrphy_apb_wr(0x90301, 0x59); // DWC_DDRPHYA_INITENG0_base0_Seq0BGPR1_p0 +dwc_ddrphy_apb_wr(0x90302, 0x58); // DWC_DDRPHYA_INITENG0_base0_Seq0BGPR2_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxSlewRate::CsrTxSrc to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxSlewRate::TxPreDrvMode to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxSlewRate to 0x0 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for TxSlewRate::CsrTxSrc are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult the "Output Slew Rate" section of HSpice Model App Note in specific technology for recommended settings + +dwc_ddrphy_apb_wr(0x1005f, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxSlewRate_b0_p0 +dwc_ddrphy_apb_wr(0x1015f, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxSlewRate_b1_p0 +dwc_ddrphy_apb_wr(0x1105f, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxSlewRate_b0_p0 +dwc_ddrphy_apb_wr(0x1115f, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxSlewRate_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::ATxPreDrvMode to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 0 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 0 to 0x1be +dwc_ddrphy_apb_wr(0x55, 0x1be); // DWC_DDRPHYA_ANIB0_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 1 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 1 to 0x1be +dwc_ddrphy_apb_wr(0x1055, 0x1be); // DWC_DDRPHYA_ANIB1_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 2 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 2 to 0x1be +dwc_ddrphy_apb_wr(0x2055, 0x1be); // DWC_DDRPHYA_ANIB2_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 3 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 3 to 0x1be +dwc_ddrphy_apb_wr(0x3055, 0x1be); // DWC_DDRPHYA_ANIB3_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 4 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 4 to 0x1be +dwc_ddrphy_apb_wr(0x4055, 0x1be); // DWC_DDRPHYA_ANIB4_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 5 to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 5 to 0x0 +dwc_ddrphy_apb_wr(0x5055, 0x0); // DWC_DDRPHYA_ANIB5_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 6 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 6 to 0x1be +dwc_ddrphy_apb_wr(0x6055, 0x1be); // DWC_DDRPHYA_ANIB6_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 7 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 7 to 0x1be +dwc_ddrphy_apb_wr(0x7055, 0x1be); // DWC_DDRPHYA_ANIB7_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 8 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 8 to 0x1be +dwc_ddrphy_apb_wr(0x8055, 0x1be); // DWC_DDRPHYA_ANIB8_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate::CsrATxSrc ANIB 9 to 0x1be +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxSlewRate ANIB 9 to 0x1be +dwc_ddrphy_apb_wr(0x9055, 0x1be); // DWC_DDRPHYA_ANIB9_base0_ATxSlewRate_p0 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for ATxSlewRate::CsrATxSrc are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult the "Output Slew Rate" section of HSpice Model App Note in specific technology for recommended settings + +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride::CsrTxOvSrc to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride::TxCalBaseN to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride::TxCalBaseP to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalPreDriverOverride to 0x300 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for CalPreDriverOverride::CsrTxOvSrc are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult the "Output Slew Rate" section of HSpice Model App Note in specific technology for recommended settings + +dwc_ddrphy_apb_wr(0x2008c, 0x300); // DWC_DDRPHYA_MASTER0_base0_CalPreDriverOverride +//// [phyinit_C_initPhyConfig] PUB revision is 0x0350. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl2::PllFreqSel to 0x19 based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200c5, 0x19); // DWC_DDRPHYA_MASTER0_base0_PllCtrl2_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl1::PllCpPropCtrl to 0x3 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl1::PllCpIntCtrl to 0x1 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl1 to 0x61 based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200c7, 0x21); // DWC_DDRPHYA_MASTER0_base0_PllCtrl1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllTestMode to 0x400f based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200ca, 0x402f); // DWC_DDRPHYA_MASTER0_base0_PllTestMode_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl4::PllCpPropGsCtrl to 0x6 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl4::PllCpIntGsCtrl to 0x12 based on DfiClk frequency = 800. +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming PllCtrl4 to 0xd2 based on DfiClk frequency = 800. +dwc_ddrphy_apb_wr(0x200cc, 0x17f); // DWC_DDRPHYA_MASTER0_base0_PllCtrl4_p0 +//// [phyinit_C_initPhyConfig] ### NOTE ### Optimal setting for PllCtrl1 and PllTestMode are technology specific. +//// [phyinit_C_initPhyConfig] ### NOTE ### Please consult technology specific PHY Databook for recommended settings + +// +////############################################################## +//// +//// Program ARdPtrInitVal based on Frequency and PLL Bypass inputs +//// The values programmed here assume ideal properties of DfiClk +//// and Pclk including: +//// - DfiClk skew +//// - DfiClk jitter +//// - DfiClk PVT variations +//// - Pclk skew +//// - Pclk jitter +//// +//// PLL Bypassed mode: +//// For MemClk frequency > 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 2-5 +//// For MemClk frequency < 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 1-5 +//// +//// PLL Enabled mode: +//// For MemClk frequency > 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 1-5 +//// For MemClk frequency < 933MHz, the valid range of ARdPtrInitVal_p0[3:0] is: 0-5 +//// +////############################################################## +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ARdPtrInitVal to 0x1 +dwc_ddrphy_apb_wr(0x2002e, 0x1); // DWC_DDRPHYA_MASTER0_base0_ARdPtrInitVal_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DisPtrInitClrTxTracking to 0x0 +dwc_ddrphy_apb_wr(0x20051, 0x0); // DWC_DDRPHYA_MASTER0_base0_PtrInitTrackingModeCntrl_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::TwoTckRxDqsPre to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::TwoTckTxDqsPre to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::PositionDfeInit to 0x2 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::DDR5RxPreamble to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl::DDR5RxPostamble to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreambleControl to 0x88 +dwc_ddrphy_apb_wr(0x20024, 0x88); // DWC_DDRPHYA_MASTER0_base0_DqsPreambleControl_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreamblePattern::EnTxDqsPreamblePattern to 0x7 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreamblePattern::TxDqsPreamblePattern to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPreamblePattern to 0x701 +dwc_ddrphy_apb_wr(0x200a1, 0x701); // DWC_DDRPHYA_MASTER0_base0_DqsPreamblePattern_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPostamblePattern::EnTxDqsPostamblePattern to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPostamblePattern::TxDqsPostamblePattern to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqsPostamblePattern to 0x0 +dwc_ddrphy_apb_wr(0x200a2, 0x0); // DWC_DDRPHYA_MASTER0_base0_DqsPostamblePattern_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DmPreamblePattern::EnTxDmPreamblePattern to 0xf +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DmPreamblePattern::TxDmPreamblePattern to 0xf +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DmPreamblePattern to 0xf5 +dwc_ddrphy_apb_wr(0x200fe, 0xf5); // DWC_DDRPHYA_MASTER0_base0_DmPreamblePattern_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqPreamblePatternU0::EnTxDqPreamblePatternU0 to 0xf +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqPreamblePatternU0::TxDqPreamblePatternU0 to 0xf +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqPreamblePatternU0 to 0xf5 +dwc_ddrphy_apb_wr(0x200fc, 0xf5); // DWC_DDRPHYA_MASTER0_base0_DqPreamblePatternU0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqPreamblePatternU1::EnTxDqPreamblePatternU1 to 0xf +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqPreamblePatternU1::TxDqPreamblePatternU1 to 0xf +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DqPreamblePatternU1 to 0xf5 +dwc_ddrphy_apb_wr(0x200fd, 0xf5); // DWC_DDRPHYA_MASTER0_base0_DqPreamblePatternU1_p0 +//// [phyinit_C_initPhyConfig] Programming DbyteDllModeCntrl::DllRxPreambleMode to 0x1 +//// [phyinit_C_initPhyConfig] Programming DbyteDllModeCntrl::DllRxBurstLengthMode to 0x0 +//// [phyinit_C_initPhyConfig] Programming DbyteDllModeCntrl to 0x2 +dwc_ddrphy_apb_wr(0x2003a, 0x2); // DWC_DDRPHYA_MASTER0_base0_DbyteDllModeCntrl +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxOdtDrvStren::TxOdtStrenPu to 0x4 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxOdtDrvStren::TxOdtStrenPd to 0x0 +dwc_ddrphy_apb_wr(0x1004d, 0x104); // DWC_DDRPHYA_DBYTE0_base0_TxOdtDrvStren_b0_p0 +dwc_ddrphy_apb_wr(0x1014d, 0x104); // DWC_DDRPHYA_DBYTE0_base0_TxOdtDrvStren_b1_p0 +dwc_ddrphy_apb_wr(0x1104d, 0x104); // DWC_DDRPHYA_DBYTE1_base0_TxOdtDrvStren_b0_p0 +dwc_ddrphy_apb_wr(0x1114d, 0x104); // DWC_DDRPHYA_DBYTE1_base0_TxOdtDrvStren_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ADrvStrenP to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ADrvStrenN to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ATxReserved13x12 to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ATxCalBaseN to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming ATxImpedance::ATxCalBaseP to 0x1 +dwc_ddrphy_apb_wr(0x43, 0xcfff); // DWC_DDRPHYA_ANIB0_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x1043, 0xcfff); // DWC_DDRPHYA_ANIB1_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x2043, 0xcfff); // DWC_DDRPHYA_ANIB2_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x3043, 0xcfff); // DWC_DDRPHYA_ANIB3_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x4043, 0xcfff); // DWC_DDRPHYA_ANIB4_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x5043, 0xcfff); // DWC_DDRPHYA_ANIB5_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x6043, 0xcfff); // DWC_DDRPHYA_ANIB6_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x7043, 0xcfff); // DWC_DDRPHYA_ANIB7_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x8043, 0xcfff); // DWC_DDRPHYA_ANIB8_base0_ATxImpedance +dwc_ddrphy_apb_wr(0x9043, 0xcfff); // DWC_DDRPHYA_ANIB9_base0_ATxImpedance +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl0::TxStrenEqHiPu to 0xc +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl0::TxStrenEqLoPd to 0xc +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl1::TxStrenPu to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl1::TxStrenPd to 0x3f +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl2::TxStrenEqLoPu to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TxImpedanceCtrl2::TxStrenEqHiPd to 0x0 +dwc_ddrphy_apb_wr(0x10041, 0x30c); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl0_b0_p0 +dwc_ddrphy_apb_wr(0x10049, 0x79e); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl1_b0_p0 +dwc_ddrphy_apb_wr(0x1004b, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl2_b0_p0 +dwc_ddrphy_apb_wr(0x10141, 0x30c); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl0_b1_p0 +dwc_ddrphy_apb_wr(0x10149, 0x79e); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl1_b1_p0 +dwc_ddrphy_apb_wr(0x1014b, 0x0); // DWC_DDRPHYA_DBYTE0_base0_TxImpedanceCtrl2_b1_p0 +dwc_ddrphy_apb_wr(0x11041, 0x30c); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl0_b0_p0 +dwc_ddrphy_apb_wr(0x11049, 0x79e); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl1_b0_p0 +dwc_ddrphy_apb_wr(0x1104b, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl2_b0_p0 +dwc_ddrphy_apb_wr(0x11141, 0x30c); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl0_b1_p0 +dwc_ddrphy_apb_wr(0x11149, 0x79e); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl1_b1_p0 +dwc_ddrphy_apb_wr(0x1114b, 0x0); // DWC_DDRPHYA_DBYTE1_base0_TxImpedanceCtrl2_b1_p0 +//// [phyinit_C_initPhyConfig] Programming DfiMode to 0x1 +dwc_ddrphy_apb_wr(0x20018, 0x1); // DWC_DDRPHYA_MASTER0_base0_DfiMode +//// [phyinit_C_initPhyConfig] Programming DfiCAMode to 0x10 +dwc_ddrphy_apb_wr(0x20075, 0x10); // DWC_DDRPHYA_MASTER0_base0_DfiCAMode +//// [phyinit_C_initPhyConfig] Programming CalDrvStr0::CalDrvStrPd50 to 0x2 +//// [phyinit_C_initPhyConfig] Programming CalDrvStr0::CalDrvStrPu50 to 0x2 +dwc_ddrphy_apb_wr(0x20050, 0x82); // DWC_DDRPHYA_MASTER0_base0_CalDrvStr0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming CalUclkInfo::CalUClkTicksPer1uS to 0x320 +dwc_ddrphy_apb_wr(0x20008, 0x320); // DWC_DDRPHYA_MASTER0_base0_CalUclkInfo_p0 +//// [phyinit_C_initPhyConfig] Programming CalRate::CalInterval to 0x9 +//// [phyinit_C_initPhyConfig] Programming CalRate::CalOnce to 0x0 +dwc_ddrphy_apb_wr(0x20088, 0x9); // DWC_DDRPHYA_MASTER0_base0_CalRate +//// [phyinit_C_initPhyConfig] Pstate=0, Programming VrefInGlobal::GlobalVrefInSel to 0x0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming VrefInGlobal::GlobalVrefInDAC to 0x1f +//// [phyinit_C_initPhyConfig] Pstate=0, Programming VrefInGlobal to 0xf8 +dwc_ddrphy_apb_wr(0x200b2, 0xf8); // DWC_DDRPHYA_MASTER0_base0_VrefInGlobal_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=0, Upper/Lower=0) to 0x2900 +dwc_ddrphy_apb_wr(0x10043, 0x2900); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl_b0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=0, Upper/Lower=1) to 0x2900 +dwc_ddrphy_apb_wr(0x10143, 0x2900); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=1, Upper/Lower=0) to 0x2900 +dwc_ddrphy_apb_wr(0x11043, 0x2900); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl_b0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl (Byte=1, Upper/Lower=1) to 0x2900 +dwc_ddrphy_apb_wr(0x11143, 0x2900); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl_b1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Programming DqDqsRcvCntrl2 to 0x1c +dwc_ddrphy_apb_wr(0x1004c, 0x1c); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl2_p0 +dwc_ddrphy_apb_wr(0x1104c, 0x1c); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl2_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TristateModeCA::DisDynAdrTri_p0 to 0x1 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming TristateModeCA::DDR2TMode_p0 to 0x0 +dwc_ddrphy_apb_wr(0x20019, 0x5); // DWC_DDRPHYA_MASTER0_base0_TristateModeCA_p0 +//// [phyinit_C_initPhyConfig] Programming DfiFreqXlat* +dwc_ddrphy_apb_wr(0x200f0, 0x0); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat0 +dwc_ddrphy_apb_wr(0x200f1, 0x0); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat1 +dwc_ddrphy_apb_wr(0x200f2, 0x4444); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat2 +dwc_ddrphy_apb_wr(0x200f3, 0x8888); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat3 +dwc_ddrphy_apb_wr(0x200f4, 0x5555); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat4 +dwc_ddrphy_apb_wr(0x200f5, 0x0); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat5 +dwc_ddrphy_apb_wr(0x200f6, 0x0); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat6 +dwc_ddrphy_apb_wr(0x200f7, 0xf000); // DWC_DDRPHYA_MASTER0_base0_DfiFreqXlat7 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY0 to 0x64 +dwc_ddrphy_apb_wr(0x2000b, 0x64); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY0_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY1 to 0xc8 +dwc_ddrphy_apb_wr(0x2000c, 0xc8); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY1_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY2 to 0x2bc +dwc_ddrphy_apb_wr(0x2000d, 0x2bc); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY2_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming Seq0BDLY3 to 0x2c +dwc_ddrphy_apb_wr(0x2000e, 0x2c); // DWC_DDRPHYA_MASTER0_base0_Seq0BDLY3_p0 +//// [phyinit_C_initPhyConfig] Disabling DBYTE 0 Lane 8 (DBI) Receiver to save power. +dwc_ddrphy_apb_wr(0x1004a, 0x500); // DWC_DDRPHYA_DBYTE0_base0_DqDqsRcvCntrl1 +//// [phyinit_C_initPhyConfig] Disabling DBYTE 1 Lane 8 (DBI) Receiver to save power. +dwc_ddrphy_apb_wr(0x1104a, 0x500); // DWC_DDRPHYA_DBYTE1_base0_DqDqsRcvCntrl1 +//// [phyinit_C_initPhyConfig] Programming MasterX4Config::X4TG to 0x0 +dwc_ddrphy_apb_wr(0x20025, 0x0); // DWC_DDRPHYA_MASTER0_base0_MasterX4Config +// [phyinit_C_initPhyConfig] Programming DfiDataEnLatency::WLm13 and RLm13 +dwc_ddrphy_apb_wr(0x2019a, 0x18); // DWC_DDRPHYA_MASTER0_base0_DfiDataEnLatency +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, rd_Crc = 0 cwl= 24 , cl = 26 mr_cl =2 MR0_A0 = 0x8 +dwc_ddrphy_apb_wr(0x400f5, 0x1200); // DWC_DDRPHYA_ACSM0_base0_AcsmCtrl5_p0 +dwc_ddrphy_apb_wr(0x400f6, 0x10); // DWC_DDRPHYA_ACSM0_base0_AcsmCtrl6_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0RxEnPulse to 2062 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0RxValPulse to 2062 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0RdcsPulse to 2062 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0TxEnPulse to 2060 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0WrcsPulse to 2060 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0SnoopPulse to 2062 +dwc_ddrphy_apb_wr(0x20120, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0RxEnPulse_p0 +dwc_ddrphy_apb_wr(0x20121, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0RxValPulse_p0 +dwc_ddrphy_apb_wr(0x20124, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0RdcsPulse_p0 +dwc_ddrphy_apb_wr(0x20122, 0x80c); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0TxEnPulse_p0 +dwc_ddrphy_apb_wr(0x20123, 0x80c); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0WrcsPulse_p0 +dwc_ddrphy_apb_wr(0x20125, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0SnoopPulse_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM0SnoopVal to 801 +dwc_ddrphy_apb_wr(0x2012e, 0x321); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0SnoopVal +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1RxEnPulse to 2062 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1RxValPulse to 2062 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1RdcsPulse to 2062 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1TxEnPulse to 2060 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1WrcsPulse to 2060 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1SnoopPulse to 2062 +dwc_ddrphy_apb_wr(0x20140, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1RxEnPulse_p0 +dwc_ddrphy_apb_wr(0x20141, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1RxValPulse_p0 +dwc_ddrphy_apb_wr(0x20144, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1RdcsPulse_p0 +dwc_ddrphy_apb_wr(0x20142, 0x80c); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1TxEnPulse_p0 +dwc_ddrphy_apb_wr(0x20143, 0x80c); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1WrcsPulse_p0 +dwc_ddrphy_apb_wr(0x20145, 0x80e); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1SnoopPulse_p0 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming D5ACSM1SnoopVal to 801 +dwc_ddrphy_apb_wr(0x2014e, 0x321); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1SnoopVal +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming GPR7(csrAlertRecovery) to 0x0 +dwc_ddrphy_apb_wr(0x90307, 0x0); // DWC_DDRPHYA_INITENG0_base0_Seq0BGPR7_p0 +// [phyinit_C_initPhyConfig] Programming TimingModeCntrl::Dly64Prec to 0x1 +dwc_ddrphy_apb_wr(0x20040, 0x1); // DWC_DDRPHYA_MASTER0_base0_TimingModeCntrl +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x1 for MASTER +dwc_ddrphy_apb_wr(0x20066, 0x1); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x1 for all DBYTEs +dwc_ddrphy_apb_wr(0x10066, 0x1); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x11066, 0x1); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x1 for all ANIBs +dwc_ddrphy_apb_wr(0x66, 0x1); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x1066, 0x1); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x2066, 0x1); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x3066, 0x1); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x4066, 0x1); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x5066, 0x1); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x6066, 0x1); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x7066, 0x1); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x8066, 0x1); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x9066, 0x1); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming AcClkDLLControl to 0x1080 +dwc_ddrphy_apb_wr(0x200ea, 0x1080); // DWC_DDRPHYA_MASTER0_base0_AcClkDLLControl_p0 +// [phyinit_C_initPhyConfig] Programming ArcPmuEccCtl to 0x1 +dwc_ddrphy_apb_wr(0xc0086, 0x1); // DWC_DDRPHYA_DRTUB0_ArcPmuEccCtl +// [phyinit_C_initPhyConfig] Programming VREGCtrl2 to 0x9820 for MASTER +dwc_ddrphy_apb_wr(0x2002b, 0x9820); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl2 +// [phyinit_C_initPhyConfig] Programming VREGCtrl2 to 0x8020 for all DBYTEs +dwc_ddrphy_apb_wr(0x1002b, 0x8020); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x1102b, 0x8020); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl2 +// [phyinit_C_initPhyConfig] Programming VREGCtrl2 to 0x8020 for all ANIBs +dwc_ddrphy_apb_wr(0x2b, 0x8020); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x102b, 0x8020); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x202b, 0x8020); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x302b, 0x8020); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x402b, 0x8020); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x502b, 0x8020); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x602b, 0x8020); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x702b, 0x8020); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x802b, 0x8020); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl2 +dwc_ddrphy_apb_wr(0x902b, 0x8020); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl2 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for MASTER +dwc_ddrphy_apb_wr(0x20066, 0x0); // DWC_DDRPHYA_MASTER0_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all DBYTEs +dwc_ddrphy_apb_wr(0x10066, 0x0); // DWC_DDRPHYA_DBYTE0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x11066, 0x0); // DWC_DDRPHYA_DBYTE1_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming VREGCtrl3::VshCtrlUpdate to 0x0 for all ANIBs +dwc_ddrphy_apb_wr(0x66, 0x0); // DWC_DDRPHYA_ANIB0_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x1066, 0x0); // DWC_DDRPHYA_ANIB1_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x2066, 0x0); // DWC_DDRPHYA_ANIB2_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x3066, 0x0); // DWC_DDRPHYA_ANIB3_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x4066, 0x0); // DWC_DDRPHYA_ANIB4_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x5066, 0x0); // DWC_DDRPHYA_ANIB5_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x6066, 0x0); // DWC_DDRPHYA_ANIB6_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x7066, 0x0); // DWC_DDRPHYA_ANIB7_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x8066, 0x0); // DWC_DDRPHYA_ANIB8_base0_VREGCtrl3 +dwc_ddrphy_apb_wr(0x9066, 0x0); // DWC_DDRPHYA_ANIB9_base0_VREGCtrl3 +// [phyinit_C_initPhyConfig] Programming VrefDAC0 to 0x3f for all DBYTEs and lanes +// [phyinit_C_initPhyConfig] Programming VrefDAC1 to 0x3f for all DBYTEs and lanes +// [phyinit_C_initPhyConfig] Programming VrefDAC2 to 0x3f for all DBYTEs and lanes +// [phyinit_C_initPhyConfig] Programming VrefDAC3 to 0x3f for all DBYTEs and lanes +dwc_ddrphy_apb_wr(0x10040, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r0_p0 +dwc_ddrphy_apb_wr(0x10030, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r0 +dwc_ddrphy_apb_wr(0x10050, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r0 +dwc_ddrphy_apb_wr(0x10060, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r0 +dwc_ddrphy_apb_wr(0x10140, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r1_p0 +dwc_ddrphy_apb_wr(0x10130, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r1 +dwc_ddrphy_apb_wr(0x10150, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r1 +dwc_ddrphy_apb_wr(0x10160, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r1 +dwc_ddrphy_apb_wr(0x10240, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r2_p0 +dwc_ddrphy_apb_wr(0x10230, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r2 +dwc_ddrphy_apb_wr(0x10250, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r2 +dwc_ddrphy_apb_wr(0x10260, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r2 +dwc_ddrphy_apb_wr(0x10340, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r3_p0 +dwc_ddrphy_apb_wr(0x10330, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r3 +dwc_ddrphy_apb_wr(0x10350, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r3 +dwc_ddrphy_apb_wr(0x10360, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r3 +dwc_ddrphy_apb_wr(0x10440, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r4_p0 +dwc_ddrphy_apb_wr(0x10430, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r4 +dwc_ddrphy_apb_wr(0x10450, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r4 +dwc_ddrphy_apb_wr(0x10460, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r4 +dwc_ddrphy_apb_wr(0x10540, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r5_p0 +dwc_ddrphy_apb_wr(0x10530, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r5 +dwc_ddrphy_apb_wr(0x10550, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r5 +dwc_ddrphy_apb_wr(0x10560, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r5 +dwc_ddrphy_apb_wr(0x10640, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r6_p0 +dwc_ddrphy_apb_wr(0x10630, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r6 +dwc_ddrphy_apb_wr(0x10650, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r6 +dwc_ddrphy_apb_wr(0x10660, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r6 +dwc_ddrphy_apb_wr(0x10740, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r7_p0 +dwc_ddrphy_apb_wr(0x10730, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r7 +dwc_ddrphy_apb_wr(0x10750, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r7 +dwc_ddrphy_apb_wr(0x10760, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r7 +dwc_ddrphy_apb_wr(0x10840, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC0_r8_p0 +dwc_ddrphy_apb_wr(0x10830, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC1_r8 +dwc_ddrphy_apb_wr(0x10850, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC2_r8 +dwc_ddrphy_apb_wr(0x10860, 0x3f); // DWC_DDRPHYA_DBYTE0_base0_VrefDAC3_r8 +dwc_ddrphy_apb_wr(0x11040, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r0_p0 +dwc_ddrphy_apb_wr(0x11030, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r0 +dwc_ddrphy_apb_wr(0x11050, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r0 +dwc_ddrphy_apb_wr(0x11060, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r0 +dwc_ddrphy_apb_wr(0x11140, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r1_p0 +dwc_ddrphy_apb_wr(0x11130, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r1 +dwc_ddrphy_apb_wr(0x11150, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r1 +dwc_ddrphy_apb_wr(0x11160, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r1 +dwc_ddrphy_apb_wr(0x11240, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r2_p0 +dwc_ddrphy_apb_wr(0x11230, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r2 +dwc_ddrphy_apb_wr(0x11250, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r2 +dwc_ddrphy_apb_wr(0x11260, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r2 +dwc_ddrphy_apb_wr(0x11340, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r3_p0 +dwc_ddrphy_apb_wr(0x11330, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r3 +dwc_ddrphy_apb_wr(0x11350, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r3 +dwc_ddrphy_apb_wr(0x11360, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r3 +dwc_ddrphy_apb_wr(0x11440, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r4_p0 +dwc_ddrphy_apb_wr(0x11430, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r4 +dwc_ddrphy_apb_wr(0x11450, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r4 +dwc_ddrphy_apb_wr(0x11460, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r4 +dwc_ddrphy_apb_wr(0x11540, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r5_p0 +dwc_ddrphy_apb_wr(0x11530, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r5 +dwc_ddrphy_apb_wr(0x11550, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r5 +dwc_ddrphy_apb_wr(0x11560, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r5 +dwc_ddrphy_apb_wr(0x11640, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r6_p0 +dwc_ddrphy_apb_wr(0x11630, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r6 +dwc_ddrphy_apb_wr(0x11650, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r6 +dwc_ddrphy_apb_wr(0x11660, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r6 +dwc_ddrphy_apb_wr(0x11740, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r7_p0 +dwc_ddrphy_apb_wr(0x11730, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r7 +dwc_ddrphy_apb_wr(0x11750, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r7 +dwc_ddrphy_apb_wr(0x11760, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r7 +dwc_ddrphy_apb_wr(0x11840, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC0_r8_p0 +dwc_ddrphy_apb_wr(0x11830, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC1_r8 +dwc_ddrphy_apb_wr(0x11850, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC2_r8 +dwc_ddrphy_apb_wr(0x11860, 0x3f); // DWC_DDRPHYA_DBYTE1_base0_VrefDAC3_r8 +//// [phyinit_C_initPhyConfig] Pstate=0, Memclk=1600MHz, Programming DfiFreqRatio_p0 to 0x1 +dwc_ddrphy_apb_wr(0x200fa, 0x1); // DWC_DDRPHYA_MASTER0_base0_DfiFreqRatio_p0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg0 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg1 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg2 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg3 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg0 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg1 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg2 (dbyte=0) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg3 (dbyte=0) to 0x0 +dwc_ddrphy_apb_wr(0x100aa, 0x0); // DWC_DDRPHYA_DBYTE0_base0_PptCtlStatic +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg0 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg1 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg2 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::DOCByteSelTg3 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg0 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg1 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg2 (dbyte=1) to 0x0 +//// [phyinit_C_initPhyConfig] Programming PptCtlStatic::NoX4onUpperNibbleTg3 (dbyte=1) to 0x0 +dwc_ddrphy_apb_wr(0x110aa, 0x0); // DWC_DDRPHYA_DBYTE1_base0_PptCtlStatic +//// [phyinit_C_initPhyConfig] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x0 +dwc_ddrphy_apb_wr(0x200a6, 0x0); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=0) to 0xc +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=4) to 0x8 +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=6) to 0xf +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=7) to 0xf +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=8) to 0xf +//// [phyinit_C_initPhyConfig] Programming AForceTriCont (anib=9) to 0xf +dwc_ddrphy_apb_wr(0x28, 0xc); // DWC_DDRPHYA_ANIB0_base0_AForceTriCont +dwc_ddrphy_apb_wr(0x4028, 0x8); // DWC_DDRPHYA_ANIB4_base0_AForceTriCont +dwc_ddrphy_apb_wr(0x6028, 0xf); // DWC_DDRPHYA_ANIB6_base0_AForceTriCont +dwc_ddrphy_apb_wr(0x7028, 0xf); // DWC_DDRPHYA_ANIB7_base0_AForceTriCont +dwc_ddrphy_apb_wr(0x8028, 0xf); // DWC_DDRPHYA_ANIB8_base0_AForceTriCont +dwc_ddrphy_apb_wr(0x9028, 0xf); // DWC_DDRPHYA_ANIB9_base0_AForceTriCont +//// [phyinit_C_initPhyConfig] End of dwc_ddrphy_phyinit_C_initPhyConfig() +// +// +////############################################################## +//// +//// dwc_ddrphy_phyinit_userCustom_customPreTrain is a user-editable function. +//// +//// The purpose of dwc_ddrphy_phyinit_userCustom_customPreTrain() is to override any +//// any message block fields calculated by Phyinit in dwc_ddrphy_phyinit_calcMb() or to +//// override any CSR values programmed by Phyinit in dwc_ddrphy_phyinit_C_initPhyConfig(). +//// This function is executed before training and thus any override here might affect +//// training result. +//// +//// IMPORTANT: in this function, user shall not override any values in userInputBasic and +//// userInputAdvanced data structures. Use dwc_ddrphy_phyinit_userCustom_overrideUserInput() +//// to modify values in those data structures. +//// +////############################################################## +// +//// [phyinit_userCustom_customPreTrain] Start of dwc_ddrphy_phyinit_userCustom_customPreTrain() +//// [phyinit_userCustom_customPreTrain] End of dwc_ddrphy_phyinit_userCustom_customPreTrain() +//// [dwc_ddrphy_phyinit_D_loadIMEM, 1D] Start of dwc_ddrphy_phyinit_D_loadIMEM (Train2D=0) +// +// +////############################################################## +//// +//// (D) Load the 1D IMEM image +//// +//// This function loads the training firmware IMEM image into the SRAM. +//// See PhyInit App Note for detailed description and function usage +//// +////############################################################## +// +// +//// [dwc_ddrphy_phyinit_D_loadIMEM, 1D] Programming MemResetL to 0x2 +dwc_ddrphy_apb_wr(0x20060, 0x2); // DWC_DDRPHYA_MASTER0_base0_MemResetL +// [dwc_ddrphy_phyinit_storeIncvFile] Reading input file: /home/jerry_ku/Project/Development/ast2700dev/ddr45phy_tsmc12/coreConsultant/config3_3.50a/2022-12-12-17-01-49/firmware/Latest/training/ddr5/ddr5_pmu_train_imem.incv + +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_WriteOutMem] STARTING 32bit write. offset 0x50000 size 0x8000 +dwc_ddrphy_phyinit_userCustom_D_loadIMEM(sdrammc, 0); + +//// [dwc_ddrphy_phyinit_WriteOutMem] DONE. Index 0x8000 +//// 2. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +//// This allows the firmware unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_D_loadIMEM, 1D] End of dwc_ddrphy_phyinit_D_loadIMEM() +// +// +////############################################################## +//// +//// 4.3.5(E) Set the PHY input clocks to the desired frequency for pstate 0 +//// +//// Set the PHY input Dfi Clk to the desired operating frequency associated with the given Pstate. Before proceeding to the next step, +//// the clock should be stable at the new frequency. For more information on clocking requirements, see "Clocks" on page <XXX>. +//// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_E_setDfiClk(sdrammc); + +// +//// [dwc_ddrphy_phyinit_userCustom_E_setDfiClk] End of dwc_ddrphy_phyinit_userCustom_E_setDfiClk() +//// [phyinit_F_loadDMEM, 1D] Start of dwc_ddrphy_phyinit_F_loadDMEM (pstate=0, Train2D=0) +// +// +////############################################################## +//// +//// 4.3.5(F) Load the 1D DMEM image and write the 1D Message Block parameters for the training firmware +//// +//// The procedure is as follows: +//// +////############################################################## +// +// +// +//// 1. Load the firmware DMEM segment to initialize the data structures. +// +//// 2. Write the Firmware Message Block with the required contents detailing the training parameters. +// +// [dwc_ddrphy_phyinit_storeIncvFile] Reading input file: /home/jerry_ku/Project/Development/ast2700dev/ddr45phy_tsmc12/coreConsultant/config3_3.50a/2022-12-12-17-01-49/firmware/Latest/training/ddr5/ddr5_pmu_train_dmem.incv + +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [dwc_ddrphy_phyinit_WriteOutMem] STARTING 32bit write. offset 0x58000 size 0x8000 + +dwc_ddrphy_phyinit_userCustom_F_loadDMEM(sdrammc, 0, 0); + +dwc_ddrphy_apb_wr_32b(0x58000, 0x100); +dwc_ddrphy_apb_wr_32b(0x58002, 0xc800000); +dwc_ddrphy_apb_wr_32b(0x58004, 0x0); +dwc_ddrphy_apb_wr_32b(0x58006, 0x40); +if (IS_ENABLED(CONFIG_ASPEED_PHY_TRAINING_MESSAGE)) + dwc_ddrphy_apb_wr_32b(0x58008, 0x04827f); +else + dwc_ddrphy_apb_wr_32b(0x58008, 0xc8827f); +// Redmine 1392: Set X16Present=1 by Synopsys's comment +// 0x5800b[7:0]=DFIMRLMargin, 0x5800b[15:8]=X16Present +dwc_ddrphy_apb_wr_32b(0x5800a, 0x01020000); +// Redmine 1456: Skip_CA13_during_CAtraining during DDR5 +dwc_ddrphy_apb_wr_32b(0x5800c, 0x10000001); +// Redmine 1392: To speed up data collection, set the voltage and delay step size in Rx2D_TrainOpt and Tx2D_TrainOpt to its maximum value. +// uint8_t RX2D_TrainOpt; // Byte offset 0x1d, CSR Addr 0x5800e, Direction=In +// uint8_t TX2D_TrainOpt; // Byte offset 0x1e, CSR Addr 0x5800f, Direction=In +//dwc_ddrphy_apb_wr_32b(0x5800e, 0x001e1e00); +//#elif defined(TRAIN_1D) +//printf("- <DWC_DDRPHY TRAIN>: Enable RdDQS1D, WrDQ1D for 1D training"); +// #ifdef DWC_DEBUG +//printf("- <DWC_DDRPHY TRAIN>: Debug level = 0x05: Detailed debug messages (e.g. Eye delays)"); +//dwc_ddrphy_apb_wr_32b(0x58008, 0x05821f); +// #else +//printf("- <DWC_DDRPHY TRAIN>: Debug level = 0xC8: Stage completion"); +//dwc_ddrphy_apb_wr_32b(0x58008, 0xc8821f); +// #endif +//// Redmine 1392: Set X16Present=1 by Synopsys's comment +//dwc_ddrphy_apb_wr_32b(0x5800a, 0x01020000); +//// Redmine 1456: Skip_CA13_during_CAtraining during DDR5 +//dwc_ddrphy_apb_wr_32b(0x5800c, 0x18000001); +//// Redmine 1392: To speed up data collection, set the voltage and delay step size in Rx2D_TrainOpt and Tx2D_TrainOpt to its maximum value. +//// uint8_t RX2D_TrainOpt; // Byte offset 0x1d, CSR Addr 0x5800e, Direction=In +//// uint8_t TX2D_TrainOpt; // Byte offset 0x1e, CSR Addr 0x5800f, Direction=In +//dwc_ddrphy_apb_wr_32b(0x5800e, 0x001e1e00); +//#else +//dwc_ddrphy_apb_wr_32b(0x58008, 0xc8837f); +//dwc_ddrphy_apb_wr_32b(0x5800a, 0x20000); +//dwc_ddrphy_apb_wr_32b(0x5800c, 0x8000001); +//dwc_ddrphy_apb_wr_32b(0x5800e, 0x0); +//#endif +dwc_ddrphy_apb_wr_32b(0x58010, 0x0); +dwc_ddrphy_apb_wr_32b(0x58012, 0x110); +dwc_ddrphy_apb_wr_32b(0x58014, 0x0); +dwc_ddrphy_apb_wr_32b(0x58016, 0x0); +dwc_ddrphy_apb_wr_32b(0x58018, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5801e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58020, 0x0); +dwc_ddrphy_apb_wr_32b(0x58022, 0x0); +dwc_ddrphy_apb_wr_32b(0x58024, 0x0); +dwc_ddrphy_apb_wr_32b(0x58026, 0x0); +dwc_ddrphy_apb_wr_32b(0x58028, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5802e, 0x84080000); //MR0 0x5802f=0x8(CL=26), MR2 0x5802f=0x84(OP[2]=1 2N mode, OP[7]=enable internal WL training) +dwc_ddrphy_apb_wr_32b(0x58030, 0x200000); //MR5 0x58031=0x20(OP[5]=1 DM enable, OP[2:1]=0 pu 34ohm, 1=40ohm, 2=48ohm, OP7:6]=pd) +dwc_ddrphy_apb_wr_32b(0x58032, 0x2d000800); //MR8 0x58032=0x08(OP[4:3]=1 Write preamble 2 tCK) MR10 0x58033=0x2d(Vref 75%) +dwc_ddrphy_apb_wr_32b(0x58034, 0xd62d); +dwc_ddrphy_apb_wr_32b(0x58036, 0x04240003); //MR32 0x58037=0x24(OP[2:0]=4 CK ODT 80, OP[5:3]=4 CS ODT 80ohm), MR33 0x58037=0x4(OP[2:0]=4 CA ODTt 80ohm) +dwc_ddrphy_apb_wr_32b(0x58038, 0x2c000499); //MR34 0x58038(OP[5:3]=3 RTT_WR 80) +dwc_ddrphy_apb_wr_32b(0x5803a, 0x2c2c); +dwc_ddrphy_apb_wr_32b(0x5803c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5803e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58040, 0x0); +dwc_ddrphy_apb_wr_32b(0x58042, 0x408); +dwc_ddrphy_apb_wr_32b(0x58044, 0x8000020); +dwc_ddrphy_apb_wr_32b(0x58046, 0xd62d2d00); +dwc_ddrphy_apb_wr_32b(0x58048, 0x30000); +dwc_ddrphy_apb_wr_32b(0x5804a, 0x4110000); +dwc_ddrphy_apb_wr_32b(0x5804c, 0x2c2c2c00); +dwc_ddrphy_apb_wr_32b(0x5804e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58050, 0x0); +dwc_ddrphy_apb_wr_32b(0x58052, 0x0); +dwc_ddrphy_apb_wr_32b(0x58054, 0x4080000); +dwc_ddrphy_apb_wr_32b(0x58056, 0x200000); +dwc_ddrphy_apb_wr_32b(0x58058, 0x2d000800); +dwc_ddrphy_apb_wr_32b(0x5805a, 0xd62d); +dwc_ddrphy_apb_wr_32b(0x5805c, 0x3); +dwc_ddrphy_apb_wr_32b(0x5805e, 0x2c000411); +dwc_ddrphy_apb_wr_32b(0x58060, 0x2c2c); +dwc_ddrphy_apb_wr_32b(0x58062, 0x0); +dwc_ddrphy_apb_wr_32b(0x58064, 0x0); +dwc_ddrphy_apb_wr_32b(0x58066, 0x0); +dwc_ddrphy_apb_wr_32b(0x58068, 0x408); +dwc_ddrphy_apb_wr_32b(0x5806a, 0x8000020); +dwc_ddrphy_apb_wr_32b(0x5806c, 0xd62d2d00); +dwc_ddrphy_apb_wr_32b(0x5806e, 0x30000); +dwc_ddrphy_apb_wr_32b(0x58070, 0x4110000); +dwc_ddrphy_apb_wr_32b(0x58072, 0x2c2c2c00); +dwc_ddrphy_apb_wr_32b(0x58074, 0x0); +dwc_ddrphy_apb_wr_32b(0x58076, 0x0); +dwc_ddrphy_apb_wr_32b(0x58078, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5807e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58080, 0x0); +dwc_ddrphy_apb_wr_32b(0x58082, 0x0); +dwc_ddrphy_apb_wr_32b(0x58084, 0x0); +dwc_ddrphy_apb_wr_32b(0x58086, 0x0); +dwc_ddrphy_apb_wr_32b(0x58088, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5808e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58090, 0x0); +dwc_ddrphy_apb_wr_32b(0x58092, 0x0); +dwc_ddrphy_apb_wr_32b(0x58094, 0x0); +dwc_ddrphy_apb_wr_32b(0x58096, 0x0); +dwc_ddrphy_apb_wr_32b(0x58098, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5809e, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580a4, 0x4080000); +dwc_ddrphy_apb_wr_32b(0x580a6, 0x200000); +dwc_ddrphy_apb_wr_32b(0x580a8, 0x2d000800); +dwc_ddrphy_apb_wr_32b(0x580aa, 0xd62d); +dwc_ddrphy_apb_wr_32b(0x580ac, 0x3); +dwc_ddrphy_apb_wr_32b(0x580ae, 0x2c000411); +dwc_ddrphy_apb_wr_32b(0x580b0, 0x2c2c); +dwc_ddrphy_apb_wr_32b(0x580b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580b8, 0x408); +dwc_ddrphy_apb_wr_32b(0x580ba, 0x8000020); +dwc_ddrphy_apb_wr_32b(0x580bc, 0xd62d2d00); +dwc_ddrphy_apb_wr_32b(0x580be, 0x30000); +dwc_ddrphy_apb_wr_32b(0x580c0, 0x4110000); +dwc_ddrphy_apb_wr_32b(0x580c2, 0x2c2c2c00); +dwc_ddrphy_apb_wr_32b(0x580c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ca, 0x4080000); +dwc_ddrphy_apb_wr_32b(0x580cc, 0x200000); +dwc_ddrphy_apb_wr_32b(0x580ce, 0x2d000800); +dwc_ddrphy_apb_wr_32b(0x580d0, 0xd62d); +dwc_ddrphy_apb_wr_32b(0x580d2, 0x3); +dwc_ddrphy_apb_wr_32b(0x580d4, 0x2c000411); +dwc_ddrphy_apb_wr_32b(0x580d6, 0x2c2c); +dwc_ddrphy_apb_wr_32b(0x580d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580da, 0x0); +dwc_ddrphy_apb_wr_32b(0x580dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580de, 0x408); +dwc_ddrphy_apb_wr_32b(0x580e0, 0x8000020); +dwc_ddrphy_apb_wr_32b(0x580e2, 0xd62d2d00); +dwc_ddrphy_apb_wr_32b(0x580e4, 0x30000); +dwc_ddrphy_apb_wr_32b(0x580e6, 0x4110000); +dwc_ddrphy_apb_wr_32b(0x580e8, 0x2c2c2c00); +dwc_ddrphy_apb_wr_32b(0x580ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x580ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x580f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x580fe, 0xa00060); // WL_ADJ_START, WL_ADJ_END +dwc_ddrphy_apb_wr_32b(0x58100, 0x1); +dwc_ddrphy_apb_wr_32b(0x58102, 0x0); +dwc_ddrphy_apb_wr_32b(0x58104, 0x0); +dwc_ddrphy_apb_wr_32b(0x58106, 0x0); +dwc_ddrphy_apb_wr_32b(0x58108, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5810e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58110, 0x0); +dwc_ddrphy_apb_wr_32b(0x58112, 0x0); +dwc_ddrphy_apb_wr_32b(0x58114, 0x0); +dwc_ddrphy_apb_wr_32b(0x58116, 0x0); +dwc_ddrphy_apb_wr_32b(0x58118, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5811e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58120, 0x0); +dwc_ddrphy_apb_wr_32b(0x58122, 0x0); +dwc_ddrphy_apb_wr_32b(0x58124, 0x0); +dwc_ddrphy_apb_wr_32b(0x58126, 0x0); +dwc_ddrphy_apb_wr_32b(0x58128, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5812e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58130, 0x0); +dwc_ddrphy_apb_wr_32b(0x58132, 0x0); +dwc_ddrphy_apb_wr_32b(0x58134, 0x0); +dwc_ddrphy_apb_wr_32b(0x58136, 0x0); +dwc_ddrphy_apb_wr_32b(0x58138, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5813e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58140, 0x0); +dwc_ddrphy_apb_wr_32b(0x58142, 0x0); +dwc_ddrphy_apb_wr_32b(0x58144, 0x0); +dwc_ddrphy_apb_wr_32b(0x58146, 0x0); +dwc_ddrphy_apb_wr_32b(0x58148, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5814e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58150, 0x0); +dwc_ddrphy_apb_wr_32b(0x58152, 0x0); +dwc_ddrphy_apb_wr_32b(0x58154, 0x0); +dwc_ddrphy_apb_wr_32b(0x58156, 0x0); +dwc_ddrphy_apb_wr_32b(0x58158, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5815e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58160, 0x0); +dwc_ddrphy_apb_wr_32b(0x58162, 0x0); +dwc_ddrphy_apb_wr_32b(0x58164, 0x0); +dwc_ddrphy_apb_wr_32b(0x58166, 0x0); +dwc_ddrphy_apb_wr_32b(0x58168, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5816e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58170, 0x0); +dwc_ddrphy_apb_wr_32b(0x58172, 0x0); +dwc_ddrphy_apb_wr_32b(0x58174, 0x0); +dwc_ddrphy_apb_wr_32b(0x58176, 0x0); +dwc_ddrphy_apb_wr_32b(0x58178, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5817e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58180, 0x1); +dwc_ddrphy_apb_wr_32b(0x58182, 0x0); +dwc_ddrphy_apb_wr_32b(0x58184, 0x0); +dwc_ddrphy_apb_wr_32b(0x58186, 0x0); +dwc_ddrphy_apb_wr_32b(0x58188, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5818e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58190, 0x0); +dwc_ddrphy_apb_wr_32b(0x58192, 0x0); +dwc_ddrphy_apb_wr_32b(0x58194, 0x0); +dwc_ddrphy_apb_wr_32b(0x58196, 0x0); +dwc_ddrphy_apb_wr_32b(0x58198, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5819e, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x581bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581be, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x581cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581da, 0x0); +dwc_ddrphy_apb_wr_32b(0x581dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581de, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x581ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x581f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x581fe, 0x0); +dwc_ddrphy_apb_wr_32b(0x58200, 0x1); +dwc_ddrphy_apb_wr_32b(0x58202, 0x0); +dwc_ddrphy_apb_wr_32b(0x58204, 0x0); +dwc_ddrphy_apb_wr_32b(0x58206, 0x0); +dwc_ddrphy_apb_wr_32b(0x58208, 0x0); +dwc_ddrphy_apb_wr_32b(0x5820a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5820c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5820e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58210, 0x0); +dwc_ddrphy_apb_wr_32b(0x58212, 0x0); +dwc_ddrphy_apb_wr_32b(0x58214, 0x0); +dwc_ddrphy_apb_wr_32b(0x58216, 0x0); +dwc_ddrphy_apb_wr_32b(0x58218, 0x0); +dwc_ddrphy_apb_wr_32b(0x5821a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5821c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5821e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58220, 0x0); +dwc_ddrphy_apb_wr_32b(0x58222, 0x0); +dwc_ddrphy_apb_wr_32b(0x58224, 0x0); +dwc_ddrphy_apb_wr_32b(0x58226, 0x0); +dwc_ddrphy_apb_wr_32b(0x58228, 0x0); +dwc_ddrphy_apb_wr_32b(0x5822a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5822c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5822e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58230, 0x0); +dwc_ddrphy_apb_wr_32b(0x58232, 0x0); +dwc_ddrphy_apb_wr_32b(0x58234, 0x0); +dwc_ddrphy_apb_wr_32b(0x58236, 0x0); +dwc_ddrphy_apb_wr_32b(0x58238, 0x0); +dwc_ddrphy_apb_wr_32b(0x5823a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5823c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5823e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58240, 0x0); +dwc_ddrphy_apb_wr_32b(0x58242, 0x0); +dwc_ddrphy_apb_wr_32b(0x58244, 0x0); +dwc_ddrphy_apb_wr_32b(0x58246, 0x0); +dwc_ddrphy_apb_wr_32b(0x58248, 0x0); +dwc_ddrphy_apb_wr_32b(0x5824a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5824c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5824e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58250, 0x0); +dwc_ddrphy_apb_wr_32b(0x58252, 0x0); +dwc_ddrphy_apb_wr_32b(0x58254, 0x0); +dwc_ddrphy_apb_wr_32b(0x58256, 0x0); +dwc_ddrphy_apb_wr_32b(0x58258, 0x0); +dwc_ddrphy_apb_wr_32b(0x5825a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5825c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5825e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58260, 0x0); +dwc_ddrphy_apb_wr_32b(0x58262, 0x0); +dwc_ddrphy_apb_wr_32b(0x58264, 0x0); +dwc_ddrphy_apb_wr_32b(0x58266, 0x0); +dwc_ddrphy_apb_wr_32b(0x58268, 0x0); +dwc_ddrphy_apb_wr_32b(0x5826a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5826c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5826e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58270, 0x0); +dwc_ddrphy_apb_wr_32b(0x58272, 0x0); +dwc_ddrphy_apb_wr_32b(0x58274, 0x0); +dwc_ddrphy_apb_wr_32b(0x58276, 0x0); +dwc_ddrphy_apb_wr_32b(0x58278, 0x0); +dwc_ddrphy_apb_wr_32b(0x5827a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5827c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5827e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58280, 0x1); +dwc_ddrphy_apb_wr_32b(0x58282, 0x0); +dwc_ddrphy_apb_wr_32b(0x58284, 0x0); +dwc_ddrphy_apb_wr_32b(0x58286, 0x0); +dwc_ddrphy_apb_wr_32b(0x58288, 0x0); +dwc_ddrphy_apb_wr_32b(0x5828a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5828c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5828e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58290, 0x0); +dwc_ddrphy_apb_wr_32b(0x58292, 0x0); +dwc_ddrphy_apb_wr_32b(0x58294, 0x0); +dwc_ddrphy_apb_wr_32b(0x58296, 0x0); +dwc_ddrphy_apb_wr_32b(0x58298, 0x0); +dwc_ddrphy_apb_wr_32b(0x5829a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5829c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5829e, 0x0); +dwc_ddrphy_apb_wr_32b(0x582a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x582a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x582a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x582a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x582a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x582aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x582b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x582b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x582b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x582b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x582b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x582bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x582be, 0x0); +dwc_ddrphy_apb_wr_32b(0x582c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x582c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x582c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x582c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x582c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x582cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x582d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x582d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x582d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x582d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x582d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x582da, 0x0); +dwc_ddrphy_apb_wr_32b(0x582dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x582de, 0x0); +dwc_ddrphy_apb_wr_32b(0x582e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x582e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x582e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x582e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x582e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x582ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x582f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x582f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x582f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x582f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x582f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x582fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x582fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x582fe, 0x0); +dwc_ddrphy_apb_wr_32b(0x58300, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58302, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58304, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58306, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58308, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x5830a, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x5830c, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x5830e, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58310, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58312, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58314, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58316, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58318, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x5831a, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x5831c, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x5831e, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58320, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58322, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58324, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58326, 0x17171717); +dwc_ddrphy_apb_wr_32b(0x58328, 0x0); +dwc_ddrphy_apb_wr_32b(0x5832a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5832c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5832e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58330, 0x0); +dwc_ddrphy_apb_wr_32b(0x58332, 0x0); +dwc_ddrphy_apb_wr_32b(0x58334, 0x0); +dwc_ddrphy_apb_wr_32b(0x58336, 0x0); +dwc_ddrphy_apb_wr_32b(0x58338, 0x0); +dwc_ddrphy_apb_wr_32b(0x5833a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5833c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5833e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58340, 0x0); +dwc_ddrphy_apb_wr_32b(0x58342, 0x0); +dwc_ddrphy_apb_wr_32b(0x58344, 0x0); +dwc_ddrphy_apb_wr_32b(0x58346, 0x0); +dwc_ddrphy_apb_wr_32b(0x58348, 0x0); +dwc_ddrphy_apb_wr_32b(0x5834a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5834c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5834e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58350, 0x0); +dwc_ddrphy_apb_wr_32b(0x58352, 0x0); +dwc_ddrphy_apb_wr_32b(0x58354, 0x0); +dwc_ddrphy_apb_wr_32b(0x58356, 0x0); +dwc_ddrphy_apb_wr_32b(0x58358, 0x0); +dwc_ddrphy_apb_wr_32b(0x5835a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5835c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5835e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58360, 0x0); +dwc_ddrphy_apb_wr_32b(0x58362, 0x0); +dwc_ddrphy_apb_wr_32b(0x58364, 0x0); +dwc_ddrphy_apb_wr_32b(0x58366, 0x0); +dwc_ddrphy_apb_wr_32b(0x58368, 0x0); +dwc_ddrphy_apb_wr_32b(0x5836a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5836c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5836e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58370, 0x0); +dwc_ddrphy_apb_wr_32b(0x58372, 0x0); +dwc_ddrphy_apb_wr_32b(0x58374, 0x0); +dwc_ddrphy_apb_wr_32b(0x58376, 0x0); +dwc_ddrphy_apb_wr_32b(0x58378, 0x0); +dwc_ddrphy_apb_wr_32b(0x5837a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5837c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5837e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58380, 0x0); +dwc_ddrphy_apb_wr_32b(0x58382, 0x0); +dwc_ddrphy_apb_wr_32b(0x58384, 0x0); +dwc_ddrphy_apb_wr_32b(0x58386, 0x0); +dwc_ddrphy_apb_wr_32b(0x58388, 0x0); +dwc_ddrphy_apb_wr_32b(0x5838a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5838c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5838e, 0x0); +dwc_ddrphy_apb_wr_32b(0x58390, 0x0); +dwc_ddrphy_apb_wr_32b(0x58392, 0x0); +dwc_ddrphy_apb_wr_32b(0x58394, 0x0); +dwc_ddrphy_apb_wr_32b(0x58396, 0x0); +dwc_ddrphy_apb_wr_32b(0x58398, 0x0); +dwc_ddrphy_apb_wr_32b(0x5839a, 0x0); +dwc_ddrphy_apb_wr_32b(0x5839c, 0x0); +dwc_ddrphy_apb_wr_32b(0x5839e, 0x0); +dwc_ddrphy_apb_wr_32b(0x583a0, 0x0); +dwc_ddrphy_apb_wr_32b(0x583a2, 0x0); +dwc_ddrphy_apb_wr_32b(0x583a4, 0x0); +dwc_ddrphy_apb_wr_32b(0x583a6, 0x0); +dwc_ddrphy_apb_wr_32b(0x583a8, 0x0); +dwc_ddrphy_apb_wr_32b(0x583aa, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ac, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ae, 0x0); +dwc_ddrphy_apb_wr_32b(0x583b0, 0x0); +dwc_ddrphy_apb_wr_32b(0x583b2, 0x0); +dwc_ddrphy_apb_wr_32b(0x583b4, 0x0); +dwc_ddrphy_apb_wr_32b(0x583b6, 0x0); +dwc_ddrphy_apb_wr_32b(0x583b8, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ba, 0x0); +dwc_ddrphy_apb_wr_32b(0x583bc, 0x0); +dwc_ddrphy_apb_wr_32b(0x583be, 0x0); +dwc_ddrphy_apb_wr_32b(0x583c0, 0x0); +dwc_ddrphy_apb_wr_32b(0x583c2, 0x0); +dwc_ddrphy_apb_wr_32b(0x583c4, 0x0); +dwc_ddrphy_apb_wr_32b(0x583c6, 0x0); +dwc_ddrphy_apb_wr_32b(0x583c8, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ca, 0x0); +dwc_ddrphy_apb_wr_32b(0x583cc, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ce, 0x0); +dwc_ddrphy_apb_wr_32b(0x583d0, 0x0); +dwc_ddrphy_apb_wr_32b(0x583d2, 0x0); +dwc_ddrphy_apb_wr_32b(0x583d4, 0x0); +dwc_ddrphy_apb_wr_32b(0x583d6, 0x0); +dwc_ddrphy_apb_wr_32b(0x583d8, 0x0); +dwc_ddrphy_apb_wr_32b(0x583da, 0x0); +dwc_ddrphy_apb_wr_32b(0x583dc, 0x0); +dwc_ddrphy_apb_wr_32b(0x583de, 0x0); +dwc_ddrphy_apb_wr_32b(0x583e0, 0x0); +dwc_ddrphy_apb_wr_32b(0x583e2, 0x0); +dwc_ddrphy_apb_wr_32b(0x583e4, 0x0); +dwc_ddrphy_apb_wr_32b(0x583e6, 0x0); +dwc_ddrphy_apb_wr_32b(0x583e8, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ea, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ec, 0x0); +dwc_ddrphy_apb_wr_32b(0x583ee, 0x0); +dwc_ddrphy_apb_wr_32b(0x583f0, 0x0); +dwc_ddrphy_apb_wr_32b(0x583f2, 0x0); +dwc_ddrphy_apb_wr_32b(0x583f4, 0x0); +dwc_ddrphy_apb_wr_32b(0x583f6, 0x0); +dwc_ddrphy_apb_wr_32b(0x583f8, 0x0); +dwc_ddrphy_apb_wr_32b(0x583fa, 0x0); +dwc_ddrphy_apb_wr_32b(0x583fc, 0x0); +dwc_ddrphy_apb_wr_32b(0x583fe, 0x0); +//// [dwc_ddrphy_phyinit_WriteOutMem] DONE. Index 0x8000 +//// 2. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +//// This allows the firmware unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_F_loadDMEM, 1D] End of dwc_ddrphy_phyinit_F_loadDMEM() +// +// +////############################################################## +//// +//// 4.3.7(G) Execute the Training Firmware +//// +//// The training firmware is executed with the following procedure: +//// +////############################################################## +// +// +//// 1. Reset the firmware microcontroller by writing the MicroReset CSR to set the StallToMicro and +//// ResetToMicro fields to 1 (all other fields should be zero). +//// Then rewrite the CSR so that only the StallToMicro remains set (all other fields should be zero). +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +dwc_ddrphy_apb_wr(0xd0099, 0x9); // DWC_DDRPHYA_APBONLY0_MicroReset +dwc_ddrphy_apb_wr(0xd0099, 0x1); // DWC_DDRPHYA_APBONLY0_MicroReset +// +//// 2. Begin execution of the training firmware by setting the MicroReset CSR to 4'b0000. +dwc_ddrphy_apb_wr(0xd0099, 0x0); // DWC_DDRPHYA_APBONLY0_MicroReset +// +//// 3. Wait for the training firmware to complete by following the procedure in "uCtrl Initialization and Mailbox Messaging" +//// 4.3.7 3. Wait for the training firmware to complete. Implement timeout function or follow the procedure in "3.4 Running the firmware" of the Training Firmware Application Note to poll the Mailbox message. +dwc_ddrphy_phyinit_userCustom_G_waitFwDone(sdrammc); + +//// [dwc_ddrphy_phyinit_userCustom_G_waitFwDone] End of dwc_ddrphy_phyinit_userCustom_G_waitFwDone() +//// 4. Halt the microcontroller." +dwc_ddrphy_apb_wr(0xd0099, 0x1); // DWC_DDRPHYA_APBONLY0_MicroReset +dwc_ddrphy_apb_wr(0x20089, 0x0); // DWC_DDRPHYA_MASTER0_base0_CalZap +//// [dwc_ddrphy_phyinit_G_execFW] End of dwc_ddrphy_phyinit_G_execFW() +// +// +////############################################################## +//// +//// 4.3.8(H) Read the Message Block results +//// +//// The procedure is as follows: +//// +////############################################################## +// +// +//// 1. Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +// +//2. Read the Firmware Message Block to obtain the results from the training. +//This can be accomplished by issuing APB read commands to the DMEM addresses. +//Example: +//if (Train2D) +//{ +// _read_2d_message_block_outputs_ +//} +//else +//{ +// _read_1d_message_block_outputs_ +//} +//This can be accomplished by issuing APB read commands to the DMEM addresses. +dwc_ddrphy_phyinit_userCustom_H_readMsgBlock(sdrammc, 0); + +//[dwc_ddrphy_phyinit_userCustom_H_readMsgBlock] End of dwc_ddrphy_phyinit_userCustom_H_readMsgBlock() +//// 3. Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// 4. If training is required at another frequency, repeat the operations starting at step (E). +//// [dwc_ddrphy_phyinit_H_readMsgBlock] End of dwc_ddrphy_phyinit_H_readMsgBlock() +//// [initRuntimeConfigEnableBits] Start of initRuntimeConfigEnableBits() +//// [initRuntimeConfigEnableBits] enableBits[0] = 0x00000009 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A0 = 0x00000000, rtt_required = 0x00000001 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A1 = 0x00000000, rtt_required = 0x00000002 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A2 = 0x00000000, rtt_required = 0x00000004 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_A3 = 0x00000000, rtt_required = 0x00000008 +//// [initRuntimeConfigEnableBits] enableBits[1] = 0x00000000 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B0 = 0x00000000, rtt_required = 0x00000001 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B1 = 0x00000000, rtt_required = 0x00000002 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B2 = 0x00000000, rtt_required = 0x00000004 +//// [initRuntimeConfigEnableBits] WR_RD_RTT_PARK_B3 = 0x00000000, rtt_required = 0x00000008 +//// [initRuntimeConfigEnableBits] enableBits[2] = 0x00000000 +//// [initRuntimeConfigEnableBits] End of initRuntimeConfigEnableBits() +//// [phyinit_I_loadPIEImage] Start of dwc_ddrphy_phyinit_I_loadPIEImage() +// +// +////############################################################## +//// +//// 4.3.9(I) Load PHY Init Engine Image +//// +//// Load the PHY Initialization Engine memory with the provided initialization sequence. +//// +////############################################################## +// +// +//// Enable access to the internal CSRs by setting the MicroContMuxSel CSR to 0. +//// This allows the memory controller unrestricted access to the configuration CSRs. +dwc_ddrphy_apb_wr(0xd0000, 0x0); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_I_loadPIEImage] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x1 +dwc_ddrphy_apb_wr(0x200a6, 0x2); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +//// [phyinit_I_loadPIEImage] Programming PIE Production Code +//// [phyinit_LoadPIECodeSections] Start of dwc_ddrphy_phyinit_LoadPIECodeSections() +//// [phyinit_LoadPIECodeSections] Moving start address from 0 to 90000 +dwc_ddrphy_apb_wr(0x90000, 0x10); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b0s0 +dwc_ddrphy_apb_wr(0x90001, 0x400); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b0s1 +dwc_ddrphy_apb_wr(0x90002, 0x10e); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b0s2 +dwc_ddrphy_apb_wr(0x90003, 0x0); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b1s0 +dwc_ddrphy_apb_wr(0x90004, 0x0); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b1s1 +dwc_ddrphy_apb_wr(0x90005, 0x8); // DWC_DDRPHYA_INITENG0_base0_PreSequenceReg0b1s2 +//// [phyinit_LoadPIECodeSections] Moving start address from 90006 to 41000 +dwc_ddrphy_apb_wr(0x41000, 0x3fff); +dwc_ddrphy_apb_wr(0x41001, 0xff00); +dwc_ddrphy_apb_wr(0x41002, 0x3f); +dwc_ddrphy_apb_wr(0x41003, 0x2c1); +dwc_ddrphy_apb_wr(0x41004, 0x3fff); +dwc_ddrphy_apb_wr(0x41005, 0xff00); +dwc_ddrphy_apb_wr(0x41006, 0x3f); +dwc_ddrphy_apb_wr(0x41007, 0xa01); +dwc_ddrphy_apb_wr(0x41008, 0x3fff); +dwc_ddrphy_apb_wr(0x41009, 0xff00); +dwc_ddrphy_apb_wr(0x4100a, 0x3f); +dwc_ddrphy_apb_wr(0x4100b, 0x1); +dwc_ddrphy_apb_wr(0x4100c, 0xffff); +dwc_ddrphy_apb_wr(0x4100d, 0xff03); +dwc_ddrphy_apb_wr(0x4100e, 0x3ff); +dwc_ddrphy_apb_wr(0x4100f, 0x0); +dwc_ddrphy_apb_wr(0x41010, 0xffff); +dwc_ddrphy_apb_wr(0x41011, 0xff03); +dwc_ddrphy_apb_wr(0x41012, 0x3ff); +dwc_ddrphy_apb_wr(0x41013, 0x1c1); +dwc_ddrphy_apb_wr(0x41014, 0xffff); +dwc_ddrphy_apb_wr(0x41015, 0xff03); +dwc_ddrphy_apb_wr(0x41016, 0x3ff); +dwc_ddrphy_apb_wr(0x41017, 0x1); +dwc_ddrphy_apb_wr(0x41018, 0xffff); +dwc_ddrphy_apb_wr(0x41019, 0xff03); +dwc_ddrphy_apb_wr(0x4101a, 0x3ff); +dwc_ddrphy_apb_wr(0x4101b, 0x2c1); +dwc_ddrphy_apb_wr(0x4101c, 0xffff); +dwc_ddrphy_apb_wr(0x4101d, 0xff03); +dwc_ddrphy_apb_wr(0x4101e, 0x3ff); +dwc_ddrphy_apb_wr(0x4101f, 0x101); +dwc_ddrphy_apb_wr(0x41020, 0x3fff); +dwc_ddrphy_apb_wr(0x41021, 0xff00); +dwc_ddrphy_apb_wr(0x41022, 0x3f); +dwc_ddrphy_apb_wr(0x41023, 0x1); +dwc_ddrphy_apb_wr(0x41024, 0x3fff); +dwc_ddrphy_apb_wr(0x41025, 0xff00); +dwc_ddrphy_apb_wr(0x41026, 0x3ff); +dwc_ddrphy_apb_wr(0x41027, 0x1); +dwc_ddrphy_apb_wr(0x41028, 0xffff); +dwc_ddrphy_apb_wr(0x41029, 0xff03); +dwc_ddrphy_apb_wr(0x4102a, 0x3ff); +dwc_ddrphy_apb_wr(0x4102b, 0x2c1); +dwc_ddrphy_apb_wr(0x4102c, 0xffff); +dwc_ddrphy_apb_wr(0x4102d, 0xff03); +dwc_ddrphy_apb_wr(0x4102e, 0x3ff); +dwc_ddrphy_apb_wr(0x4102f, 0xf901); +dwc_ddrphy_apb_wr(0x41030, 0xffff); +dwc_ddrphy_apb_wr(0x41031, 0xff03); +dwc_ddrphy_apb_wr(0x41032, 0x3ff); +dwc_ddrphy_apb_wr(0x41033, 0x2c1); +dwc_ddrphy_apb_wr(0x41034, 0xffff); +dwc_ddrphy_apb_wr(0x41035, 0xff03); +dwc_ddrphy_apb_wr(0x41036, 0x3ff); +dwc_ddrphy_apb_wr(0x41037, 0x5901); +dwc_ddrphy_apb_wr(0x41038, 0x5a5); +dwc_ddrphy_apb_wr(0x41039, 0x4000); +dwc_ddrphy_apb_wr(0x4103a, 0x3c0); +dwc_ddrphy_apb_wr(0x4103b, 0x1); +dwc_ddrphy_apb_wr(0x4103c, 0xc000); +dwc_ddrphy_apb_wr(0x4103d, 0x3); +dwc_ddrphy_apb_wr(0x4103e, 0x3c0); +dwc_ddrphy_apb_wr(0x4103f, 0x0); +dwc_ddrphy_apb_wr(0x41040, 0xc000); +dwc_ddrphy_apb_wr(0x41041, 0x3); +dwc_ddrphy_apb_wr(0x41042, 0x3c0); +dwc_ddrphy_apb_wr(0x41043, 0x2c1); +dwc_ddrphy_apb_wr(0x41044, 0xc000); +dwc_ddrphy_apb_wr(0x41045, 0x3); +dwc_ddrphy_apb_wr(0x41046, 0x3c0); +dwc_ddrphy_apb_wr(0x41047, 0xa01); +dwc_ddrphy_apb_wr(0x41048, 0xef); +dwc_ddrphy_apb_wr(0x41049, 0xef00); +dwc_ddrphy_apb_wr(0x4104a, 0x3c0); +dwc_ddrphy_apb_wr(0x4104b, 0x1); +dwc_ddrphy_apb_wr(0x4104c, 0xc000); +dwc_ddrphy_apb_wr(0x4104d, 0x3); +dwc_ddrphy_apb_wr(0x4104e, 0x3c0); +dwc_ddrphy_apb_wr(0x4104f, 0x0); +dwc_ddrphy_apb_wr(0x41050, 0xc000); +dwc_ddrphy_apb_wr(0x41051, 0x3); +dwc_ddrphy_apb_wr(0x41052, 0x3c0); +dwc_ddrphy_apb_wr(0x41053, 0x2c1); +dwc_ddrphy_apb_wr(0x41054, 0xc000); +dwc_ddrphy_apb_wr(0x41055, 0x3); +dwc_ddrphy_apb_wr(0x41056, 0x3c0); +dwc_ddrphy_apb_wr(0x41057, 0xff01); +dwc_ddrphy_apb_wr(0x41058, 0xc000); +dwc_ddrphy_apb_wr(0x41059, 0x3); +dwc_ddrphy_apb_wr(0x4105a, 0x3c0); +dwc_ddrphy_apb_wr(0x4105b, 0x2c1); +dwc_ddrphy_apb_wr(0x4105c, 0xc000); +dwc_ddrphy_apb_wr(0x4105d, 0x3); +dwc_ddrphy_apb_wr(0x4105e, 0x3c0); +dwc_ddrphy_apb_wr(0x4105f, 0xff01); +dwc_ddrphy_apb_wr(0x41060, 0xc000); +dwc_ddrphy_apb_wr(0x41061, 0x3); +dwc_ddrphy_apb_wr(0x41062, 0x3c0); +dwc_ddrphy_apb_wr(0x41063, 0x2c1); +dwc_ddrphy_apb_wr(0x41064, 0xc000); +dwc_ddrphy_apb_wr(0x41065, 0x3); +dwc_ddrphy_apb_wr(0x41066, 0x3c0); +dwc_ddrphy_apb_wr(0x41067, 0xa01); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 0 +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 4, type = 0 +dwc_ddrphy_apb_wr(0x41068, 0x85d5); +dwc_ddrphy_apb_wr(0x41069, 0x63); +dwc_ddrphy_apb_wr(0x4106a, 0x3c0); +dwc_ddrphy_apb_wr(0x4106b, 0x400); +dwc_ddrphy_apb_wr(0x4106c, 0xc000); +dwc_ddrphy_apb_wr(0x4106d, 0x3); +dwc_ddrphy_apb_wr(0x4106e, 0x3c0); +dwc_ddrphy_apb_wr(0x4106f, 0x0); +dwc_ddrphy_apb_wr(0x41070, 0xc000); +dwc_ddrphy_apb_wr(0x41071, 0x3); +dwc_ddrphy_apb_wr(0x41072, 0x3c0); +dwc_ddrphy_apb_wr(0x41073, 0x2c1); +dwc_ddrphy_apb_wr(0x41074, 0xc000); +dwc_ddrphy_apb_wr(0x41075, 0x3); +dwc_ddrphy_apb_wr(0x41076, 0x3c0); +dwc_ddrphy_apb_wr(0x41077, 0x1001); +dwc_ddrphy_apb_wr(0x41078, 0x85f5); +dwc_ddrphy_apb_wr(0x41079, 0x63); +dwc_ddrphy_apb_wr(0x4107a, 0x3c0); +dwc_ddrphy_apb_wr(0x4107b, 0x800); +dwc_ddrphy_apb_wr(0x4107c, 0xc000); +dwc_ddrphy_apb_wr(0x4107d, 0x3); +dwc_ddrphy_apb_wr(0x4107e, 0x3c0); +dwc_ddrphy_apb_wr(0x4107f, 0x0); +dwc_ddrphy_apb_wr(0x41080, 0xc000); +dwc_ddrphy_apb_wr(0x41081, 0x3); +dwc_ddrphy_apb_wr(0x41082, 0x3c0); +dwc_ddrphy_apb_wr(0x41083, 0x2c1); +dwc_ddrphy_apb_wr(0x41084, 0xc000); +dwc_ddrphy_apb_wr(0x41085, 0x3); +dwc_ddrphy_apb_wr(0x41086, 0x3c0); +dwc_ddrphy_apb_wr(0x41087, 0x1001); +dwc_ddrphy_apb_wr(0x41088, 0x45d5); +dwc_ddrphy_apb_wr(0x41089, 0x63); +dwc_ddrphy_apb_wr(0x4108a, 0x3c0); +dwc_ddrphy_apb_wr(0x4108b, 0x401); +dwc_ddrphy_apb_wr(0x4108c, 0xc000); +dwc_ddrphy_apb_wr(0x4108d, 0x3); +dwc_ddrphy_apb_wr(0x4108e, 0x3c0); +dwc_ddrphy_apb_wr(0x4108f, 0x1); +dwc_ddrphy_apb_wr(0x41090, 0xc000); +dwc_ddrphy_apb_wr(0x41091, 0x3); +dwc_ddrphy_apb_wr(0x41092, 0x3c0); +dwc_ddrphy_apb_wr(0x41093, 0x2c1); +dwc_ddrphy_apb_wr(0x41094, 0xc000); +dwc_ddrphy_apb_wr(0x41095, 0x3); +dwc_ddrphy_apb_wr(0x41096, 0x3c0); +dwc_ddrphy_apb_wr(0x41097, 0x1001); +dwc_ddrphy_apb_wr(0x41098, 0x45f5); +dwc_ddrphy_apb_wr(0x41099, 0x63); +dwc_ddrphy_apb_wr(0x4109a, 0x3c0); +dwc_ddrphy_apb_wr(0x4109b, 0x801); +dwc_ddrphy_apb_wr(0x4109c, 0xc000); +dwc_ddrphy_apb_wr(0x4109d, 0x3); +dwc_ddrphy_apb_wr(0x4109e, 0x3c0); +dwc_ddrphy_apb_wr(0x4109f, 0x1); +dwc_ddrphy_apb_wr(0x410a0, 0xc000); +dwc_ddrphy_apb_wr(0x410a1, 0x3); +dwc_ddrphy_apb_wr(0x410a2, 0x3c0); +dwc_ddrphy_apb_wr(0x410a3, 0x2c1); +dwc_ddrphy_apb_wr(0x410a4, 0xc000); +dwc_ddrphy_apb_wr(0x410a5, 0x3); +dwc_ddrphy_apb_wr(0x410a6, 0x3c0); +dwc_ddrphy_apb_wr(0x410a7, 0x1001); +dwc_ddrphy_apb_wr(0x410a8, 0xc5d5); +dwc_ddrphy_apb_wr(0x410a9, 0x62); +dwc_ddrphy_apb_wr(0x410aa, 0x3c0); +dwc_ddrphy_apb_wr(0x410ab, 0x402); +dwc_ddrphy_apb_wr(0x410ac, 0xc000); +dwc_ddrphy_apb_wr(0x410ad, 0x3); +dwc_ddrphy_apb_wr(0x410ae, 0x3c0); +dwc_ddrphy_apb_wr(0x410af, 0x2); +dwc_ddrphy_apb_wr(0x410b0, 0xc000); +dwc_ddrphy_apb_wr(0x410b1, 0x3); +dwc_ddrphy_apb_wr(0x410b2, 0x3c0); +dwc_ddrphy_apb_wr(0x410b3, 0x2c1); +dwc_ddrphy_apb_wr(0x410b4, 0xc000); +dwc_ddrphy_apb_wr(0x410b5, 0x3); +dwc_ddrphy_apb_wr(0x410b6, 0x3c0); +dwc_ddrphy_apb_wr(0x410b7, 0x1001); +dwc_ddrphy_apb_wr(0x410b8, 0xc5f5); +dwc_ddrphy_apb_wr(0x410b9, 0x62); +dwc_ddrphy_apb_wr(0x410ba, 0x3c0); +dwc_ddrphy_apb_wr(0x410bb, 0x802); +dwc_ddrphy_apb_wr(0x410bc, 0xc000); +dwc_ddrphy_apb_wr(0x410bd, 0x3); +dwc_ddrphy_apb_wr(0x410be, 0x3c0); +dwc_ddrphy_apb_wr(0x410bf, 0x2); +dwc_ddrphy_apb_wr(0x410c0, 0xc000); +dwc_ddrphy_apb_wr(0x410c1, 0x3); +dwc_ddrphy_apb_wr(0x410c2, 0x3c0); +dwc_ddrphy_apb_wr(0x410c3, 0x2c1); +dwc_ddrphy_apb_wr(0x410c4, 0xc000); +dwc_ddrphy_apb_wr(0x410c5, 0x3); +dwc_ddrphy_apb_wr(0x410c6, 0x3c0); +dwc_ddrphy_apb_wr(0x410c7, 0x1001); +dwc_ddrphy_apb_wr(0x410c8, 0xc5d5); +dwc_ddrphy_apb_wr(0x410c9, 0x61); +dwc_ddrphy_apb_wr(0x410ca, 0x3c0); +dwc_ddrphy_apb_wr(0x410cb, 0x403); +dwc_ddrphy_apb_wr(0x410cc, 0xc000); +dwc_ddrphy_apb_wr(0x410cd, 0x3); +dwc_ddrphy_apb_wr(0x410ce, 0x3c0); +dwc_ddrphy_apb_wr(0x410cf, 0x3); +dwc_ddrphy_apb_wr(0x410d0, 0xc000); +dwc_ddrphy_apb_wr(0x410d1, 0x3); +dwc_ddrphy_apb_wr(0x410d2, 0x3c0); +dwc_ddrphy_apb_wr(0x410d3, 0x2c1); +dwc_ddrphy_apb_wr(0x410d4, 0xc000); +dwc_ddrphy_apb_wr(0x410d5, 0x3); +dwc_ddrphy_apb_wr(0x410d6, 0x3c0); +dwc_ddrphy_apb_wr(0x410d7, 0x1001); +dwc_ddrphy_apb_wr(0x410d8, 0xc5f5); +dwc_ddrphy_apb_wr(0x410d9, 0x61); +dwc_ddrphy_apb_wr(0x410da, 0x3c0); +dwc_ddrphy_apb_wr(0x410db, 0x803); +dwc_ddrphy_apb_wr(0x410dc, 0xc000); +dwc_ddrphy_apb_wr(0x410dd, 0x3); +dwc_ddrphy_apb_wr(0x410de, 0x3c0); +dwc_ddrphy_apb_wr(0x410df, 0x3); +dwc_ddrphy_apb_wr(0x410e0, 0xc000); +dwc_ddrphy_apb_wr(0x410e1, 0x3); +dwc_ddrphy_apb_wr(0x410e2, 0x3c0); +dwc_ddrphy_apb_wr(0x410e3, 0x2c1); +dwc_ddrphy_apb_wr(0x410e4, 0xc000); +dwc_ddrphy_apb_wr(0x410e5, 0x3); +dwc_ddrphy_apb_wr(0x410e6, 0x3c0); +dwc_ddrphy_apb_wr(0x410e7, 0x1d01); +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 2, type = 0 +dwc_ddrphy_apb_wr(0x410e8, 0x213); +dwc_ddrphy_apb_wr(0x410e9, 0x0); +dwc_ddrphy_apb_wr(0x410ea, 0x3c0); +dwc_ddrphy_apb_wr(0x410eb, 0x1); +dwc_ddrphy_apb_wr(0x410ec, 0xc000); +dwc_ddrphy_apb_wr(0x410ed, 0x3); +dwc_ddrphy_apb_wr(0x410ee, 0x3c0); +dwc_ddrphy_apb_wr(0x410ef, 0x0); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 0 +dwc_ddrphy_apb_wr(0x410f0, 0xc000); +dwc_ddrphy_apb_wr(0x410f1, 0x3); +dwc_ddrphy_apb_wr(0x410f2, 0x3c0); +dwc_ddrphy_apb_wr(0x410f3, 0x2c1); +dwc_ddrphy_apb_wr(0x410f4, 0xc000); +dwc_ddrphy_apb_wr(0x410f5, 0x3); +dwc_ddrphy_apb_wr(0x410f6, 0x3c0); +dwc_ddrphy_apb_wr(0x410f7, 0xef00); +dwc_ddrphy_apb_wr(0x410f8, 0xc000); +dwc_ddrphy_apb_wr(0x410f9, 0x3); +dwc_ddrphy_apb_wr(0x410fa, 0x3c0); +dwc_ddrphy_apb_wr(0x410fb, 0x2c1); +dwc_ddrphy_apb_wr(0x410fc, 0xc000); +dwc_ddrphy_apb_wr(0x410fd, 0x3); +dwc_ddrphy_apb_wr(0x410fe, 0x3c0); +dwc_ddrphy_apb_wr(0x410ff, 0x5900); +dwc_ddrphy_apb_wr(0x41100, 0x217); +dwc_ddrphy_apb_wr(0x41101, 0x1700); +dwc_ddrphy_apb_wr(0x41102, 0x3c2); +dwc_ddrphy_apb_wr(0x41103, 0x1); +dwc_ddrphy_apb_wr(0x41104, 0xc000); +dwc_ddrphy_apb_wr(0x41105, 0x3); +dwc_ddrphy_apb_wr(0x41106, 0x3c0); +dwc_ddrphy_apb_wr(0x41107, 0x0); +dwc_ddrphy_apb_wr(0x41108, 0xc000); +dwc_ddrphy_apb_wr(0x41109, 0x3); +dwc_ddrphy_apb_wr(0x4110a, 0x3c0); +dwc_ddrphy_apb_wr(0x4110b, 0x2c1); +dwc_ddrphy_apb_wr(0x4110c, 0xc000); +dwc_ddrphy_apb_wr(0x4110d, 0x3); +dwc_ddrphy_apb_wr(0x4110e, 0x3c0); +dwc_ddrphy_apb_wr(0x4110f, 0x400); +dwc_ddrphy_apb_wr(0x41110, 0x3fff); +dwc_ddrphy_apb_wr(0x41111, 0xff00); +dwc_ddrphy_apb_wr(0x41112, 0x3f); +dwc_ddrphy_apb_wr(0x41113, 0x2e1); +dwc_ddrphy_apb_wr(0x41114, 0x3fff); +dwc_ddrphy_apb_wr(0x41115, 0xff00); +dwc_ddrphy_apb_wr(0x41116, 0x3f); +dwc_ddrphy_apb_wr(0x41117, 0xa21); +dwc_ddrphy_apb_wr(0x41118, 0x3fff); +dwc_ddrphy_apb_wr(0x41119, 0xff00); +dwc_ddrphy_apb_wr(0x4111a, 0x3f); +dwc_ddrphy_apb_wr(0x4111b, 0x21); +dwc_ddrphy_apb_wr(0x4111c, 0xffff); +dwc_ddrphy_apb_wr(0x4111d, 0xff03); +dwc_ddrphy_apb_wr(0x4111e, 0x3ff); +dwc_ddrphy_apb_wr(0x4111f, 0x20); +dwc_ddrphy_apb_wr(0x41120, 0xffff); +dwc_ddrphy_apb_wr(0x41121, 0xff03); +dwc_ddrphy_apb_wr(0x41122, 0x3ff); +dwc_ddrphy_apb_wr(0x41123, 0x1e1); +dwc_ddrphy_apb_wr(0x41124, 0xffff); +dwc_ddrphy_apb_wr(0x41125, 0xff03); +dwc_ddrphy_apb_wr(0x41126, 0x3ff); +dwc_ddrphy_apb_wr(0x41127, 0x21); +dwc_ddrphy_apb_wr(0x41128, 0xffff); +dwc_ddrphy_apb_wr(0x41129, 0xff03); +dwc_ddrphy_apb_wr(0x4112a, 0x3ff); +dwc_ddrphy_apb_wr(0x4112b, 0x2e1); +dwc_ddrphy_apb_wr(0x4112c, 0xffff); +dwc_ddrphy_apb_wr(0x4112d, 0xff03); +dwc_ddrphy_apb_wr(0x4112e, 0x3ff); +dwc_ddrphy_apb_wr(0x4112f, 0x121); +dwc_ddrphy_apb_wr(0x41130, 0x3fff); +dwc_ddrphy_apb_wr(0x41131, 0xff00); +dwc_ddrphy_apb_wr(0x41132, 0x3ff); +dwc_ddrphy_apb_wr(0x41133, 0x21); +dwc_ddrphy_apb_wr(0x41134, 0x3fff); +dwc_ddrphy_apb_wr(0x41135, 0xff00); +dwc_ddrphy_apb_wr(0x41136, 0x3ff); +dwc_ddrphy_apb_wr(0x41137, 0x21); +dwc_ddrphy_apb_wr(0x41138, 0x3fff); +dwc_ddrphy_apb_wr(0x41139, 0xff00); +dwc_ddrphy_apb_wr(0x4113a, 0x3ff); +dwc_ddrphy_apb_wr(0x4113b, 0x21); +dwc_ddrphy_apb_wr(0x4113c, 0xffff); +dwc_ddrphy_apb_wr(0x4113d, 0xff03); +dwc_ddrphy_apb_wr(0x4113e, 0x3ff); +dwc_ddrphy_apb_wr(0x4113f, 0x21); +dwc_ddrphy_apb_wr(0x41140, 0xffff); +dwc_ddrphy_apb_wr(0x41141, 0xff03); +dwc_ddrphy_apb_wr(0x41142, 0x3ff); +dwc_ddrphy_apb_wr(0x41143, 0x2e1); +dwc_ddrphy_apb_wr(0x41144, 0xffff); +dwc_ddrphy_apb_wr(0x41145, 0xff03); +dwc_ddrphy_apb_wr(0x41146, 0x3ff); +dwc_ddrphy_apb_wr(0x41147, 0xf921); +dwc_ddrphy_apb_wr(0x41148, 0xffff); +dwc_ddrphy_apb_wr(0x41149, 0xff03); +dwc_ddrphy_apb_wr(0x4114a, 0x3ff); +dwc_ddrphy_apb_wr(0x4114b, 0x2e1); +dwc_ddrphy_apb_wr(0x4114c, 0xffff); +dwc_ddrphy_apb_wr(0x4114d, 0xff03); +dwc_ddrphy_apb_wr(0x4114e, 0x3ff); +dwc_ddrphy_apb_wr(0x4114f, 0x5921); +dwc_ddrphy_apb_wr(0x41150, 0x5a5); +dwc_ddrphy_apb_wr(0x41151, 0xa500); +dwc_ddrphy_apb_wr(0x41152, 0x3c5); +dwc_ddrphy_apb_wr(0x41153, 0x21); +dwc_ddrphy_apb_wr(0x41154, 0xc040); +dwc_ddrphy_apb_wr(0x41155, 0x4003); +dwc_ddrphy_apb_wr(0x41156, 0x3c0); +dwc_ddrphy_apb_wr(0x41157, 0x20); +dwc_ddrphy_apb_wr(0x41158, 0xc000); +dwc_ddrphy_apb_wr(0x41159, 0x3); +dwc_ddrphy_apb_wr(0x4115a, 0x3c0); +dwc_ddrphy_apb_wr(0x4115b, 0x2e1); +dwc_ddrphy_apb_wr(0x4115c, 0xc000); +dwc_ddrphy_apb_wr(0x4115d, 0x3); +dwc_ddrphy_apb_wr(0x4115e, 0x3c0); +dwc_ddrphy_apb_wr(0x4115f, 0xa21); +dwc_ddrphy_apb_wr(0x41160, 0xef); +dwc_ddrphy_apb_wr(0x41161, 0xef00); +dwc_ddrphy_apb_wr(0x41162, 0x3c0); +dwc_ddrphy_apb_wr(0x41163, 0x21); +dwc_ddrphy_apb_wr(0x41164, 0xc000); +dwc_ddrphy_apb_wr(0x41165, 0x3); +dwc_ddrphy_apb_wr(0x41166, 0x3c0); +dwc_ddrphy_apb_wr(0x41167, 0x20); +dwc_ddrphy_apb_wr(0x41168, 0xc000); +dwc_ddrphy_apb_wr(0x41169, 0x3); +dwc_ddrphy_apb_wr(0x4116a, 0x3c0); +dwc_ddrphy_apb_wr(0x4116b, 0x2e1); +dwc_ddrphy_apb_wr(0x4116c, 0xc000); +dwc_ddrphy_apb_wr(0x4116d, 0x3); +dwc_ddrphy_apb_wr(0x4116e, 0x3c0); +dwc_ddrphy_apb_wr(0x4116f, 0xff21); +dwc_ddrphy_apb_wr(0x41170, 0xc000); +dwc_ddrphy_apb_wr(0x41171, 0x3); +dwc_ddrphy_apb_wr(0x41172, 0x3c0); +dwc_ddrphy_apb_wr(0x41173, 0x2e1); +dwc_ddrphy_apb_wr(0x41174, 0xc000); +dwc_ddrphy_apb_wr(0x41175, 0x3); +dwc_ddrphy_apb_wr(0x41176, 0x3c0); +dwc_ddrphy_apb_wr(0x41177, 0xff21); +dwc_ddrphy_apb_wr(0x41178, 0xc000); +dwc_ddrphy_apb_wr(0x41179, 0x3); +dwc_ddrphy_apb_wr(0x4117a, 0x3c0); +dwc_ddrphy_apb_wr(0x4117b, 0x2e1); +dwc_ddrphy_apb_wr(0x4117c, 0xc000); +dwc_ddrphy_apb_wr(0x4117d, 0x3); +dwc_ddrphy_apb_wr(0x4117e, 0x3c0); +dwc_ddrphy_apb_wr(0x4117f, 0xa21); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000000, type = 1 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 0 +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 4, type = 0 +dwc_ddrphy_apb_wr(0x41180, 0x85d5); +dwc_ddrphy_apb_wr(0x41181, 0xd563); +dwc_ddrphy_apb_wr(0x41182, 0x3c5); +dwc_ddrphy_apb_wr(0x41183, 0x420); +dwc_ddrphy_apb_wr(0x41184, 0xc000); +dwc_ddrphy_apb_wr(0x41185, 0x3); +dwc_ddrphy_apb_wr(0x41186, 0x3c0); +dwc_ddrphy_apb_wr(0x41187, 0x20); +dwc_ddrphy_apb_wr(0x41188, 0xc000); +dwc_ddrphy_apb_wr(0x41189, 0x3); +dwc_ddrphy_apb_wr(0x4118a, 0x3c0); +dwc_ddrphy_apb_wr(0x4118b, 0x2c1); +dwc_ddrphy_apb_wr(0x4118c, 0xc000); +dwc_ddrphy_apb_wr(0x4118d, 0x3); +dwc_ddrphy_apb_wr(0x4118e, 0x3c0); +dwc_ddrphy_apb_wr(0x4118f, 0x1001); +dwc_ddrphy_apb_wr(0x41190, 0x85f5); +dwc_ddrphy_apb_wr(0x41191, 0xf563); +dwc_ddrphy_apb_wr(0x41192, 0x3c5); +dwc_ddrphy_apb_wr(0x41193, 0x820); +dwc_ddrphy_apb_wr(0x41194, 0xc000); +dwc_ddrphy_apb_wr(0x41195, 0x3); +dwc_ddrphy_apb_wr(0x41196, 0x3c0); +dwc_ddrphy_apb_wr(0x41197, 0x20); +dwc_ddrphy_apb_wr(0x41198, 0xc000); +dwc_ddrphy_apb_wr(0x41199, 0x3); +dwc_ddrphy_apb_wr(0x4119a, 0x3c0); +dwc_ddrphy_apb_wr(0x4119b, 0x2c1); +dwc_ddrphy_apb_wr(0x4119c, 0xc000); +dwc_ddrphy_apb_wr(0x4119d, 0x3); +dwc_ddrphy_apb_wr(0x4119e, 0x3c0); +dwc_ddrphy_apb_wr(0x4119f, 0x1001); +dwc_ddrphy_apb_wr(0x411a0, 0x45d5); +dwc_ddrphy_apb_wr(0x411a1, 0xd563); +dwc_ddrphy_apb_wr(0x411a2, 0x3c5); +dwc_ddrphy_apb_wr(0x411a3, 0x421); +dwc_ddrphy_apb_wr(0x411a4, 0xc000); +dwc_ddrphy_apb_wr(0x411a5, 0x3); +dwc_ddrphy_apb_wr(0x411a6, 0x3c0); +dwc_ddrphy_apb_wr(0x411a7, 0x21); +dwc_ddrphy_apb_wr(0x411a8, 0xc000); +dwc_ddrphy_apb_wr(0x411a9, 0x3); +dwc_ddrphy_apb_wr(0x411aa, 0x3c0); +dwc_ddrphy_apb_wr(0x411ab, 0x2c1); +dwc_ddrphy_apb_wr(0x411ac, 0xc000); +dwc_ddrphy_apb_wr(0x411ad, 0x3); +dwc_ddrphy_apb_wr(0x411ae, 0x3c0); +dwc_ddrphy_apb_wr(0x411af, 0x1001); +dwc_ddrphy_apb_wr(0x411b0, 0x45f5); +dwc_ddrphy_apb_wr(0x411b1, 0xf563); +dwc_ddrphy_apb_wr(0x411b2, 0x3c5); +dwc_ddrphy_apb_wr(0x411b3, 0x821); +dwc_ddrphy_apb_wr(0x411b4, 0xc000); +dwc_ddrphy_apb_wr(0x411b5, 0x3); +dwc_ddrphy_apb_wr(0x411b6, 0x3c0); +dwc_ddrphy_apb_wr(0x411b7, 0x21); +dwc_ddrphy_apb_wr(0x411b8, 0xc000); +dwc_ddrphy_apb_wr(0x411b9, 0x3); +dwc_ddrphy_apb_wr(0x411ba, 0x3c0); +dwc_ddrphy_apb_wr(0x411bb, 0x2c1); +dwc_ddrphy_apb_wr(0x411bc, 0xc000); +dwc_ddrphy_apb_wr(0x411bd, 0x3); +dwc_ddrphy_apb_wr(0x411be, 0x3c0); +dwc_ddrphy_apb_wr(0x411bf, 0x1001); +dwc_ddrphy_apb_wr(0x411c0, 0xc5d5); +dwc_ddrphy_apb_wr(0x411c1, 0xd562); +dwc_ddrphy_apb_wr(0x411c2, 0x3c5); +dwc_ddrphy_apb_wr(0x411c3, 0x422); +dwc_ddrphy_apb_wr(0x411c4, 0xc000); +dwc_ddrphy_apb_wr(0x411c5, 0x3); +dwc_ddrphy_apb_wr(0x411c6, 0x3c0); +dwc_ddrphy_apb_wr(0x411c7, 0x22); +dwc_ddrphy_apb_wr(0x411c8, 0xc000); +dwc_ddrphy_apb_wr(0x411c9, 0x3); +dwc_ddrphy_apb_wr(0x411ca, 0x3c0); +dwc_ddrphy_apb_wr(0x411cb, 0x2c1); +dwc_ddrphy_apb_wr(0x411cc, 0xc000); +dwc_ddrphy_apb_wr(0x411cd, 0x3); +dwc_ddrphy_apb_wr(0x411ce, 0x3c0); +dwc_ddrphy_apb_wr(0x411cf, 0x1001); +dwc_ddrphy_apb_wr(0x411d0, 0xc5f5); +dwc_ddrphy_apb_wr(0x411d1, 0xf562); +dwc_ddrphy_apb_wr(0x411d2, 0x3c5); +dwc_ddrphy_apb_wr(0x411d3, 0x822); +dwc_ddrphy_apb_wr(0x411d4, 0xc000); +dwc_ddrphy_apb_wr(0x411d5, 0x3); +dwc_ddrphy_apb_wr(0x411d6, 0x3c0); +dwc_ddrphy_apb_wr(0x411d7, 0x22); +dwc_ddrphy_apb_wr(0x411d8, 0xc000); +dwc_ddrphy_apb_wr(0x411d9, 0x3); +dwc_ddrphy_apb_wr(0x411da, 0x3c0); +dwc_ddrphy_apb_wr(0x411db, 0x2c1); +dwc_ddrphy_apb_wr(0x411dc, 0xc000); +dwc_ddrphy_apb_wr(0x411dd, 0x3); +dwc_ddrphy_apb_wr(0x411de, 0x3c0); +dwc_ddrphy_apb_wr(0x411df, 0x1001); +dwc_ddrphy_apb_wr(0x411e0, 0xc5d5); +dwc_ddrphy_apb_wr(0x411e1, 0xd561); +dwc_ddrphy_apb_wr(0x411e2, 0x3c5); +dwc_ddrphy_apb_wr(0x411e3, 0x423); +dwc_ddrphy_apb_wr(0x411e4, 0xc000); +dwc_ddrphy_apb_wr(0x411e5, 0x3); +dwc_ddrphy_apb_wr(0x411e6, 0x3c0); +dwc_ddrphy_apb_wr(0x411e7, 0x23); +dwc_ddrphy_apb_wr(0x411e8, 0xc000); +dwc_ddrphy_apb_wr(0x411e9, 0x3); +dwc_ddrphy_apb_wr(0x411ea, 0x3c0); +dwc_ddrphy_apb_wr(0x411eb, 0x2c1); +dwc_ddrphy_apb_wr(0x411ec, 0xc000); +dwc_ddrphy_apb_wr(0x411ed, 0x3); +dwc_ddrphy_apb_wr(0x411ee, 0x3c0); +dwc_ddrphy_apb_wr(0x411ef, 0x1001); +dwc_ddrphy_apb_wr(0x411f0, 0xc5f5); +dwc_ddrphy_apb_wr(0x411f1, 0xf561); +dwc_ddrphy_apb_wr(0x411f2, 0x3c5); +dwc_ddrphy_apb_wr(0x411f3, 0x823); +dwc_ddrphy_apb_wr(0x411f4, 0xc000); +dwc_ddrphy_apb_wr(0x411f5, 0x3); +dwc_ddrphy_apb_wr(0x411f6, 0x3c0); +dwc_ddrphy_apb_wr(0x411f7, 0x23); +dwc_ddrphy_apb_wr(0x411f8, 0xc000); +dwc_ddrphy_apb_wr(0x411f9, 0x3); +dwc_ddrphy_apb_wr(0x411fa, 0x3c0); +dwc_ddrphy_apb_wr(0x411fb, 0x2c1); +dwc_ddrphy_apb_wr(0x411fc, 0xc000); +dwc_ddrphy_apb_wr(0x411fd, 0x3); +dwc_ddrphy_apb_wr(0x411fe, 0x3c0); +dwc_ddrphy_apb_wr(0x411ff, 0x1d01); +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 2, type = 0 +dwc_ddrphy_apb_wr(0x41200, 0x213); +dwc_ddrphy_apb_wr(0x41201, 0x1300); +dwc_ddrphy_apb_wr(0x41202, 0x3c2); +dwc_ddrphy_apb_wr(0x41203, 0x21); +dwc_ddrphy_apb_wr(0x41204, 0xc000); +dwc_ddrphy_apb_wr(0x41205, 0x3); +dwc_ddrphy_apb_wr(0x41206, 0x3c0); +dwc_ddrphy_apb_wr(0x41207, 0x20); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 0 +dwc_ddrphy_apb_wr(0x41208, 0xc000); +dwc_ddrphy_apb_wr(0x41209, 0x3); +dwc_ddrphy_apb_wr(0x4120a, 0x3c0); +dwc_ddrphy_apb_wr(0x4120b, 0x2e1); +dwc_ddrphy_apb_wr(0x4120c, 0xc000); +dwc_ddrphy_apb_wr(0x4120d, 0x3); +dwc_ddrphy_apb_wr(0x4120e, 0x3c0); +dwc_ddrphy_apb_wr(0x4120f, 0xef20); +dwc_ddrphy_apb_wr(0x41210, 0xc000); +dwc_ddrphy_apb_wr(0x41211, 0x3); +dwc_ddrphy_apb_wr(0x41212, 0x3c0); +dwc_ddrphy_apb_wr(0x41213, 0x2e1); +dwc_ddrphy_apb_wr(0x41214, 0xc000); +dwc_ddrphy_apb_wr(0x41215, 0x3); +dwc_ddrphy_apb_wr(0x41216, 0x3c0); +dwc_ddrphy_apb_wr(0x41217, 0x5920); +dwc_ddrphy_apb_wr(0x41218, 0x217); +dwc_ddrphy_apb_wr(0x41219, 0x1700); +dwc_ddrphy_apb_wr(0x4121a, 0x3c2); +dwc_ddrphy_apb_wr(0x4121b, 0x21); +dwc_ddrphy_apb_wr(0x4121c, 0xc000); +dwc_ddrphy_apb_wr(0x4121d, 0x3); +dwc_ddrphy_apb_wr(0x4121e, 0x3c0); +dwc_ddrphy_apb_wr(0x4121f, 0x20); +dwc_ddrphy_apb_wr(0x41220, 0xc000); +dwc_ddrphy_apb_wr(0x41221, 0x3); +dwc_ddrphy_apb_wr(0x41222, 0x3c0); +dwc_ddrphy_apb_wr(0x41223, 0x2e1); +dwc_ddrphy_apb_wr(0x41224, 0xc000); +dwc_ddrphy_apb_wr(0x41225, 0x3); +dwc_ddrphy_apb_wr(0x41226, 0x3c0); +dwc_ddrphy_apb_wr(0x41227, 0x420); +//// [phyinit_LoadPIECodeSections] Moving start address from 41228 to 42000 +dwc_ddrphy_apb_wr(0x42000, 0x3fff); +dwc_ddrphy_apb_wr(0x42001, 0xff00); +dwc_ddrphy_apb_wr(0x42002, 0x3f); +dwc_ddrphy_apb_wr(0x42003, 0x2c1); +dwc_ddrphy_apb_wr(0x42004, 0x3fff); +dwc_ddrphy_apb_wr(0x42005, 0xff00); +dwc_ddrphy_apb_wr(0x42006, 0x3f); +dwc_ddrphy_apb_wr(0x42007, 0xa01); +dwc_ddrphy_apb_wr(0x42008, 0x3fff); +dwc_ddrphy_apb_wr(0x42009, 0xff00); +dwc_ddrphy_apb_wr(0x4200a, 0x3f); +dwc_ddrphy_apb_wr(0x4200b, 0x1); +dwc_ddrphy_apb_wr(0x4200c, 0xffff); +dwc_ddrphy_apb_wr(0x4200d, 0xff03); +dwc_ddrphy_apb_wr(0x4200e, 0x3ff); +dwc_ddrphy_apb_wr(0x4200f, 0x0); +dwc_ddrphy_apb_wr(0x42010, 0xffff); +dwc_ddrphy_apb_wr(0x42011, 0xff03); +dwc_ddrphy_apb_wr(0x42012, 0x3ff); +dwc_ddrphy_apb_wr(0x42013, 0x1c1); +dwc_ddrphy_apb_wr(0x42014, 0xffff); +dwc_ddrphy_apb_wr(0x42015, 0xff03); +dwc_ddrphy_apb_wr(0x42016, 0x3ff); +dwc_ddrphy_apb_wr(0x42017, 0x1); +dwc_ddrphy_apb_wr(0x42018, 0xffff); +dwc_ddrphy_apb_wr(0x42019, 0xff03); +dwc_ddrphy_apb_wr(0x4201a, 0x3ff); +dwc_ddrphy_apb_wr(0x4201b, 0x2c1); +dwc_ddrphy_apb_wr(0x4201c, 0xffff); +dwc_ddrphy_apb_wr(0x4201d, 0xff03); +dwc_ddrphy_apb_wr(0x4201e, 0x3ff); +dwc_ddrphy_apb_wr(0x4201f, 0x101); +dwc_ddrphy_apb_wr(0x42020, 0x3fff); +dwc_ddrphy_apb_wr(0x42021, 0xff00); +dwc_ddrphy_apb_wr(0x42022, 0x3f); +dwc_ddrphy_apb_wr(0x42023, 0x1); +dwc_ddrphy_apb_wr(0x42024, 0x3fff); +dwc_ddrphy_apb_wr(0x42025, 0xff00); +dwc_ddrphy_apb_wr(0x42026, 0x3ff); +dwc_ddrphy_apb_wr(0x42027, 0x1); +dwc_ddrphy_apb_wr(0x42028, 0xffff); +dwc_ddrphy_apb_wr(0x42029, 0xff03); +dwc_ddrphy_apb_wr(0x4202a, 0x3ff); +dwc_ddrphy_apb_wr(0x4202b, 0x2c1); +dwc_ddrphy_apb_wr(0x4202c, 0xffff); +dwc_ddrphy_apb_wr(0x4202d, 0xff03); +dwc_ddrphy_apb_wr(0x4202e, 0x3ff); +dwc_ddrphy_apb_wr(0x4202f, 0xf901); +dwc_ddrphy_apb_wr(0x42030, 0xffff); +dwc_ddrphy_apb_wr(0x42031, 0xff03); +dwc_ddrphy_apb_wr(0x42032, 0x3ff); +dwc_ddrphy_apb_wr(0x42033, 0x2c1); +dwc_ddrphy_apb_wr(0x42034, 0xffff); +dwc_ddrphy_apb_wr(0x42035, 0xff03); +dwc_ddrphy_apb_wr(0x42036, 0x3ff); +dwc_ddrphy_apb_wr(0x42037, 0x5901); +dwc_ddrphy_apb_wr(0x42038, 0x5a5); +dwc_ddrphy_apb_wr(0x42039, 0x4000); +dwc_ddrphy_apb_wr(0x4203a, 0x3c0); +dwc_ddrphy_apb_wr(0x4203b, 0x1); +dwc_ddrphy_apb_wr(0x4203c, 0xc000); +dwc_ddrphy_apb_wr(0x4203d, 0x3); +dwc_ddrphy_apb_wr(0x4203e, 0x3c0); +dwc_ddrphy_apb_wr(0x4203f, 0x0); +dwc_ddrphy_apb_wr(0x42040, 0xc000); +dwc_ddrphy_apb_wr(0x42041, 0x3); +dwc_ddrphy_apb_wr(0x42042, 0x3c0); +dwc_ddrphy_apb_wr(0x42043, 0x2c1); +dwc_ddrphy_apb_wr(0x42044, 0xc000); +dwc_ddrphy_apb_wr(0x42045, 0x3); +dwc_ddrphy_apb_wr(0x42046, 0x3c0); +dwc_ddrphy_apb_wr(0x42047, 0xa01); +dwc_ddrphy_apb_wr(0x42048, 0xef); +dwc_ddrphy_apb_wr(0x42049, 0xef00); +dwc_ddrphy_apb_wr(0x4204a, 0x3c0); +dwc_ddrphy_apb_wr(0x4204b, 0x1); +dwc_ddrphy_apb_wr(0x4204c, 0xc000); +dwc_ddrphy_apb_wr(0x4204d, 0x3); +dwc_ddrphy_apb_wr(0x4204e, 0x3c0); +dwc_ddrphy_apb_wr(0x4204f, 0x0); +dwc_ddrphy_apb_wr(0x42050, 0xc000); +dwc_ddrphy_apb_wr(0x42051, 0x3); +dwc_ddrphy_apb_wr(0x42052, 0x3c0); +dwc_ddrphy_apb_wr(0x42053, 0x2c1); +dwc_ddrphy_apb_wr(0x42054, 0xc000); +dwc_ddrphy_apb_wr(0x42055, 0x3); +dwc_ddrphy_apb_wr(0x42056, 0x3c0); +dwc_ddrphy_apb_wr(0x42057, 0xff01); +dwc_ddrphy_apb_wr(0x42058, 0xc000); +dwc_ddrphy_apb_wr(0x42059, 0x3); +dwc_ddrphy_apb_wr(0x4205a, 0x3c0); +dwc_ddrphy_apb_wr(0x4205b, 0x2c1); +dwc_ddrphy_apb_wr(0x4205c, 0xc000); +dwc_ddrphy_apb_wr(0x4205d, 0x3); +dwc_ddrphy_apb_wr(0x4205e, 0x3c0); +dwc_ddrphy_apb_wr(0x4205f, 0xff01); +dwc_ddrphy_apb_wr(0x42060, 0xc000); +dwc_ddrphy_apb_wr(0x42061, 0x3); +dwc_ddrphy_apb_wr(0x42062, 0x3c0); +dwc_ddrphy_apb_wr(0x42063, 0x2c1); +dwc_ddrphy_apb_wr(0x42064, 0xc000); +dwc_ddrphy_apb_wr(0x42065, 0x3); +dwc_ddrphy_apb_wr(0x42066, 0x3c0); +dwc_ddrphy_apb_wr(0x42067, 0xa01); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 0 +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 4, type = 0 +dwc_ddrphy_apb_wr(0x42068, 0x85d5); +dwc_ddrphy_apb_wr(0x42069, 0x63); +dwc_ddrphy_apb_wr(0x4206a, 0x3c0); +dwc_ddrphy_apb_wr(0x4206b, 0x400); +dwc_ddrphy_apb_wr(0x4206c, 0xc000); +dwc_ddrphy_apb_wr(0x4206d, 0x3); +dwc_ddrphy_apb_wr(0x4206e, 0x3c0); +dwc_ddrphy_apb_wr(0x4206f, 0x0); +dwc_ddrphy_apb_wr(0x42070, 0xc000); +dwc_ddrphy_apb_wr(0x42071, 0x3); +dwc_ddrphy_apb_wr(0x42072, 0x3c0); +dwc_ddrphy_apb_wr(0x42073, 0x2c1); +dwc_ddrphy_apb_wr(0x42074, 0xc000); +dwc_ddrphy_apb_wr(0x42075, 0x3); +dwc_ddrphy_apb_wr(0x42076, 0x3c0); +dwc_ddrphy_apb_wr(0x42077, 0x1001); +dwc_ddrphy_apb_wr(0x42078, 0x85f5); +dwc_ddrphy_apb_wr(0x42079, 0x63); +dwc_ddrphy_apb_wr(0x4207a, 0x3c0); +dwc_ddrphy_apb_wr(0x4207b, 0x800); +dwc_ddrphy_apb_wr(0x4207c, 0xc000); +dwc_ddrphy_apb_wr(0x4207d, 0x3); +dwc_ddrphy_apb_wr(0x4207e, 0x3c0); +dwc_ddrphy_apb_wr(0x4207f, 0x0); +dwc_ddrphy_apb_wr(0x42080, 0xc000); +dwc_ddrphy_apb_wr(0x42081, 0x3); +dwc_ddrphy_apb_wr(0x42082, 0x3c0); +dwc_ddrphy_apb_wr(0x42083, 0x2c1); +dwc_ddrphy_apb_wr(0x42084, 0xc000); +dwc_ddrphy_apb_wr(0x42085, 0x3); +dwc_ddrphy_apb_wr(0x42086, 0x3c0); +dwc_ddrphy_apb_wr(0x42087, 0x1001); +dwc_ddrphy_apb_wr(0x42088, 0x45d5); +dwc_ddrphy_apb_wr(0x42089, 0x63); +dwc_ddrphy_apb_wr(0x4208a, 0x3c0); +dwc_ddrphy_apb_wr(0x4208b, 0x401); +dwc_ddrphy_apb_wr(0x4208c, 0xc000); +dwc_ddrphy_apb_wr(0x4208d, 0x3); +dwc_ddrphy_apb_wr(0x4208e, 0x3c0); +dwc_ddrphy_apb_wr(0x4208f, 0x1); +dwc_ddrphy_apb_wr(0x42090, 0xc000); +dwc_ddrphy_apb_wr(0x42091, 0x3); +dwc_ddrphy_apb_wr(0x42092, 0x3c0); +dwc_ddrphy_apb_wr(0x42093, 0x2c1); +dwc_ddrphy_apb_wr(0x42094, 0xc000); +dwc_ddrphy_apb_wr(0x42095, 0x3); +dwc_ddrphy_apb_wr(0x42096, 0x3c0); +dwc_ddrphy_apb_wr(0x42097, 0x1001); +dwc_ddrphy_apb_wr(0x42098, 0x45f5); +dwc_ddrphy_apb_wr(0x42099, 0x63); +dwc_ddrphy_apb_wr(0x4209a, 0x3c0); +dwc_ddrphy_apb_wr(0x4209b, 0x801); +dwc_ddrphy_apb_wr(0x4209c, 0xc000); +dwc_ddrphy_apb_wr(0x4209d, 0x3); +dwc_ddrphy_apb_wr(0x4209e, 0x3c0); +dwc_ddrphy_apb_wr(0x4209f, 0x1); +dwc_ddrphy_apb_wr(0x420a0, 0xc000); +dwc_ddrphy_apb_wr(0x420a1, 0x3); +dwc_ddrphy_apb_wr(0x420a2, 0x3c0); +dwc_ddrphy_apb_wr(0x420a3, 0x2c1); +dwc_ddrphy_apb_wr(0x420a4, 0xc000); +dwc_ddrphy_apb_wr(0x420a5, 0x3); +dwc_ddrphy_apb_wr(0x420a6, 0x3c0); +dwc_ddrphy_apb_wr(0x420a7, 0x1001); +dwc_ddrphy_apb_wr(0x420a8, 0xc5d5); +dwc_ddrphy_apb_wr(0x420a9, 0x62); +dwc_ddrphy_apb_wr(0x420aa, 0x3c0); +dwc_ddrphy_apb_wr(0x420ab, 0x402); +dwc_ddrphy_apb_wr(0x420ac, 0xc000); +dwc_ddrphy_apb_wr(0x420ad, 0x3); +dwc_ddrphy_apb_wr(0x420ae, 0x3c0); +dwc_ddrphy_apb_wr(0x420af, 0x2); +dwc_ddrphy_apb_wr(0x420b0, 0xc000); +dwc_ddrphy_apb_wr(0x420b1, 0x3); +dwc_ddrphy_apb_wr(0x420b2, 0x3c0); +dwc_ddrphy_apb_wr(0x420b3, 0x2c1); +dwc_ddrphy_apb_wr(0x420b4, 0xc000); +dwc_ddrphy_apb_wr(0x420b5, 0x3); +dwc_ddrphy_apb_wr(0x420b6, 0x3c0); +dwc_ddrphy_apb_wr(0x420b7, 0x1001); +dwc_ddrphy_apb_wr(0x420b8, 0xc5f5); +dwc_ddrphy_apb_wr(0x420b9, 0x62); +dwc_ddrphy_apb_wr(0x420ba, 0x3c0); +dwc_ddrphy_apb_wr(0x420bb, 0x802); +dwc_ddrphy_apb_wr(0x420bc, 0xc000); +dwc_ddrphy_apb_wr(0x420bd, 0x3); +dwc_ddrphy_apb_wr(0x420be, 0x3c0); +dwc_ddrphy_apb_wr(0x420bf, 0x2); +dwc_ddrphy_apb_wr(0x420c0, 0xc000); +dwc_ddrphy_apb_wr(0x420c1, 0x3); +dwc_ddrphy_apb_wr(0x420c2, 0x3c0); +dwc_ddrphy_apb_wr(0x420c3, 0x2c1); +dwc_ddrphy_apb_wr(0x420c4, 0xc000); +dwc_ddrphy_apb_wr(0x420c5, 0x3); +dwc_ddrphy_apb_wr(0x420c6, 0x3c0); +dwc_ddrphy_apb_wr(0x420c7, 0x1001); +dwc_ddrphy_apb_wr(0x420c8, 0xc5d5); +dwc_ddrphy_apb_wr(0x420c9, 0x61); +dwc_ddrphy_apb_wr(0x420ca, 0x3c0); +dwc_ddrphy_apb_wr(0x420cb, 0x403); +dwc_ddrphy_apb_wr(0x420cc, 0xc000); +dwc_ddrphy_apb_wr(0x420cd, 0x3); +dwc_ddrphy_apb_wr(0x420ce, 0x3c0); +dwc_ddrphy_apb_wr(0x420cf, 0x3); +dwc_ddrphy_apb_wr(0x420d0, 0xc000); +dwc_ddrphy_apb_wr(0x420d1, 0x3); +dwc_ddrphy_apb_wr(0x420d2, 0x3c0); +dwc_ddrphy_apb_wr(0x420d3, 0x2c1); +dwc_ddrphy_apb_wr(0x420d4, 0xc000); +dwc_ddrphy_apb_wr(0x420d5, 0x3); +dwc_ddrphy_apb_wr(0x420d6, 0x3c0); +dwc_ddrphy_apb_wr(0x420d7, 0x1001); +dwc_ddrphy_apb_wr(0x420d8, 0xc5f5); +dwc_ddrphy_apb_wr(0x420d9, 0x61); +dwc_ddrphy_apb_wr(0x420da, 0x3c0); +dwc_ddrphy_apb_wr(0x420db, 0x803); +dwc_ddrphy_apb_wr(0x420dc, 0xc000); +dwc_ddrphy_apb_wr(0x420dd, 0x3); +dwc_ddrphy_apb_wr(0x420de, 0x3c0); +dwc_ddrphy_apb_wr(0x420df, 0x3); +dwc_ddrphy_apb_wr(0x420e0, 0xc000); +dwc_ddrphy_apb_wr(0x420e1, 0x3); +dwc_ddrphy_apb_wr(0x420e2, 0x3c0); +dwc_ddrphy_apb_wr(0x420e3, 0x2c1); +dwc_ddrphy_apb_wr(0x420e4, 0xc000); +dwc_ddrphy_apb_wr(0x420e5, 0x3); +dwc_ddrphy_apb_wr(0x420e6, 0x3c0); +dwc_ddrphy_apb_wr(0x420e7, 0x1d01); +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 2, type = 0 +dwc_ddrphy_apb_wr(0x420e8, 0x213); +dwc_ddrphy_apb_wr(0x420e9, 0x0); +dwc_ddrphy_apb_wr(0x420ea, 0x3c0); +dwc_ddrphy_apb_wr(0x420eb, 0x1); +dwc_ddrphy_apb_wr(0x420ec, 0xc000); +dwc_ddrphy_apb_wr(0x420ed, 0x3); +dwc_ddrphy_apb_wr(0x420ee, 0x3c0); +dwc_ddrphy_apb_wr(0x420ef, 0x0); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 0 +dwc_ddrphy_apb_wr(0x420f0, 0xc000); +dwc_ddrphy_apb_wr(0x420f1, 0x3); +dwc_ddrphy_apb_wr(0x420f2, 0x3c0); +dwc_ddrphy_apb_wr(0x420f3, 0x2c1); +dwc_ddrphy_apb_wr(0x420f4, 0xc000); +dwc_ddrphy_apb_wr(0x420f5, 0x3); +dwc_ddrphy_apb_wr(0x420f6, 0x3c0); +dwc_ddrphy_apb_wr(0x420f7, 0xef00); +dwc_ddrphy_apb_wr(0x420f8, 0xc000); +dwc_ddrphy_apb_wr(0x420f9, 0x3); +dwc_ddrphy_apb_wr(0x420fa, 0x3c0); +dwc_ddrphy_apb_wr(0x420fb, 0x2c1); +dwc_ddrphy_apb_wr(0x420fc, 0xc000); +dwc_ddrphy_apb_wr(0x420fd, 0x3); +dwc_ddrphy_apb_wr(0x420fe, 0x3c0); +dwc_ddrphy_apb_wr(0x420ff, 0x5900); +dwc_ddrphy_apb_wr(0x42100, 0x217); +dwc_ddrphy_apb_wr(0x42101, 0x1700); +dwc_ddrphy_apb_wr(0x42102, 0x3c2); +dwc_ddrphy_apb_wr(0x42103, 0x1); +dwc_ddrphy_apb_wr(0x42104, 0xc000); +dwc_ddrphy_apb_wr(0x42105, 0x3); +dwc_ddrphy_apb_wr(0x42106, 0x3c0); +dwc_ddrphy_apb_wr(0x42107, 0x0); +dwc_ddrphy_apb_wr(0x42108, 0xc000); +dwc_ddrphy_apb_wr(0x42109, 0x3); +dwc_ddrphy_apb_wr(0x4210a, 0x3c0); +dwc_ddrphy_apb_wr(0x4210b, 0x2c1); +dwc_ddrphy_apb_wr(0x4210c, 0xc000); +dwc_ddrphy_apb_wr(0x4210d, 0x3); +dwc_ddrphy_apb_wr(0x4210e, 0x3c0); +dwc_ddrphy_apb_wr(0x4210f, 0x400); +dwc_ddrphy_apb_wr(0x42110, 0x3fff); +dwc_ddrphy_apb_wr(0x42111, 0xff00); +dwc_ddrphy_apb_wr(0x42112, 0x3f); +dwc_ddrphy_apb_wr(0x42113, 0x2e1); +dwc_ddrphy_apb_wr(0x42114, 0x3fff); +dwc_ddrphy_apb_wr(0x42115, 0xff00); +dwc_ddrphy_apb_wr(0x42116, 0x3f); +dwc_ddrphy_apb_wr(0x42117, 0xa21); +dwc_ddrphy_apb_wr(0x42118, 0x3fff); +dwc_ddrphy_apb_wr(0x42119, 0xff00); +dwc_ddrphy_apb_wr(0x4211a, 0x3f); +dwc_ddrphy_apb_wr(0x4211b, 0x21); +dwc_ddrphy_apb_wr(0x4211c, 0xffff); +dwc_ddrphy_apb_wr(0x4211d, 0xff03); +dwc_ddrphy_apb_wr(0x4211e, 0x3ff); +dwc_ddrphy_apb_wr(0x4211f, 0x20); +dwc_ddrphy_apb_wr(0x42120, 0xffff); +dwc_ddrphy_apb_wr(0x42121, 0xff03); +dwc_ddrphy_apb_wr(0x42122, 0x3ff); +dwc_ddrphy_apb_wr(0x42123, 0x1e1); +dwc_ddrphy_apb_wr(0x42124, 0xffff); +dwc_ddrphy_apb_wr(0x42125, 0xff03); +dwc_ddrphy_apb_wr(0x42126, 0x3ff); +dwc_ddrphy_apb_wr(0x42127, 0x21); +dwc_ddrphy_apb_wr(0x42128, 0xffff); +dwc_ddrphy_apb_wr(0x42129, 0xff03); +dwc_ddrphy_apb_wr(0x4212a, 0x3ff); +dwc_ddrphy_apb_wr(0x4212b, 0x2e1); +dwc_ddrphy_apb_wr(0x4212c, 0xffff); +dwc_ddrphy_apb_wr(0x4212d, 0xff03); +dwc_ddrphy_apb_wr(0x4212e, 0x3ff); +dwc_ddrphy_apb_wr(0x4212f, 0x121); +dwc_ddrphy_apb_wr(0x42130, 0x3fff); +dwc_ddrphy_apb_wr(0x42131, 0xff00); +dwc_ddrphy_apb_wr(0x42132, 0x3ff); +dwc_ddrphy_apb_wr(0x42133, 0x21); +dwc_ddrphy_apb_wr(0x42134, 0x3fff); +dwc_ddrphy_apb_wr(0x42135, 0xff00); +dwc_ddrphy_apb_wr(0x42136, 0x3ff); +dwc_ddrphy_apb_wr(0x42137, 0x21); +dwc_ddrphy_apb_wr(0x42138, 0x3fff); +dwc_ddrphy_apb_wr(0x42139, 0xff00); +dwc_ddrphy_apb_wr(0x4213a, 0x3ff); +dwc_ddrphy_apb_wr(0x4213b, 0x21); +dwc_ddrphy_apb_wr(0x4213c, 0xffff); +dwc_ddrphy_apb_wr(0x4213d, 0xff03); +dwc_ddrphy_apb_wr(0x4213e, 0x3ff); +dwc_ddrphy_apb_wr(0x4213f, 0x21); +dwc_ddrphy_apb_wr(0x42140, 0xffff); +dwc_ddrphy_apb_wr(0x42141, 0xff03); +dwc_ddrphy_apb_wr(0x42142, 0x3ff); +dwc_ddrphy_apb_wr(0x42143, 0x2e1); +dwc_ddrphy_apb_wr(0x42144, 0xffff); +dwc_ddrphy_apb_wr(0x42145, 0xff03); +dwc_ddrphy_apb_wr(0x42146, 0x3ff); +dwc_ddrphy_apb_wr(0x42147, 0xf921); +dwc_ddrphy_apb_wr(0x42148, 0xffff); +dwc_ddrphy_apb_wr(0x42149, 0xff03); +dwc_ddrphy_apb_wr(0x4214a, 0x3ff); +dwc_ddrphy_apb_wr(0x4214b, 0x2e1); +dwc_ddrphy_apb_wr(0x4214c, 0xffff); +dwc_ddrphy_apb_wr(0x4214d, 0xff03); +dwc_ddrphy_apb_wr(0x4214e, 0x3ff); +dwc_ddrphy_apb_wr(0x4214f, 0x5921); +dwc_ddrphy_apb_wr(0x42150, 0x5a5); +dwc_ddrphy_apb_wr(0x42151, 0xa500); +dwc_ddrphy_apb_wr(0x42152, 0x3c5); +dwc_ddrphy_apb_wr(0x42153, 0x21); +dwc_ddrphy_apb_wr(0x42154, 0xc040); +dwc_ddrphy_apb_wr(0x42155, 0x4003); +dwc_ddrphy_apb_wr(0x42156, 0x3c0); +dwc_ddrphy_apb_wr(0x42157, 0x20); +dwc_ddrphy_apb_wr(0x42158, 0xc000); +dwc_ddrphy_apb_wr(0x42159, 0x3); +dwc_ddrphy_apb_wr(0x4215a, 0x3c0); +dwc_ddrphy_apb_wr(0x4215b, 0x2e1); +dwc_ddrphy_apb_wr(0x4215c, 0xc000); +dwc_ddrphy_apb_wr(0x4215d, 0x3); +dwc_ddrphy_apb_wr(0x4215e, 0x3c0); +dwc_ddrphy_apb_wr(0x4215f, 0xa21); +dwc_ddrphy_apb_wr(0x42160, 0xef); +dwc_ddrphy_apb_wr(0x42161, 0xef00); +dwc_ddrphy_apb_wr(0x42162, 0x3c0); +dwc_ddrphy_apb_wr(0x42163, 0x21); +dwc_ddrphy_apb_wr(0x42164, 0xc000); +dwc_ddrphy_apb_wr(0x42165, 0x3); +dwc_ddrphy_apb_wr(0x42166, 0x3c0); +dwc_ddrphy_apb_wr(0x42167, 0x20); +dwc_ddrphy_apb_wr(0x42168, 0xc000); +dwc_ddrphy_apb_wr(0x42169, 0x3); +dwc_ddrphy_apb_wr(0x4216a, 0x3c0); +dwc_ddrphy_apb_wr(0x4216b, 0x2e1); +dwc_ddrphy_apb_wr(0x4216c, 0xc000); +dwc_ddrphy_apb_wr(0x4216d, 0x3); +dwc_ddrphy_apb_wr(0x4216e, 0x3c0); +dwc_ddrphy_apb_wr(0x4216f, 0xff21); +dwc_ddrphy_apb_wr(0x42170, 0xc000); +dwc_ddrphy_apb_wr(0x42171, 0x3); +dwc_ddrphy_apb_wr(0x42172, 0x3c0); +dwc_ddrphy_apb_wr(0x42173, 0x2e1); +dwc_ddrphy_apb_wr(0x42174, 0xc000); +dwc_ddrphy_apb_wr(0x42175, 0x3); +dwc_ddrphy_apb_wr(0x42176, 0x3c0); +dwc_ddrphy_apb_wr(0x42177, 0xff21); +dwc_ddrphy_apb_wr(0x42178, 0xc000); +dwc_ddrphy_apb_wr(0x42179, 0x3); +dwc_ddrphy_apb_wr(0x4217a, 0x3c0); +dwc_ddrphy_apb_wr(0x4217b, 0x2e1); +dwc_ddrphy_apb_wr(0x4217c, 0xc000); +dwc_ddrphy_apb_wr(0x4217d, 0x3); +dwc_ddrphy_apb_wr(0x4217e, 0x3c0); +dwc_ddrphy_apb_wr(0x4217f, 0xa21); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 200000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 400000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 1000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 2000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 4000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 8000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80000000, type = 2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 10, type = 0 +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 4, type = 0 +dwc_ddrphy_apb_wr(0x42180, 0x85d5); +dwc_ddrphy_apb_wr(0x42181, 0xd563); +dwc_ddrphy_apb_wr(0x42182, 0x3c5); +dwc_ddrphy_apb_wr(0x42183, 0x420); +dwc_ddrphy_apb_wr(0x42184, 0xc000); +dwc_ddrphy_apb_wr(0x42185, 0x3); +dwc_ddrphy_apb_wr(0x42186, 0x3c0); +dwc_ddrphy_apb_wr(0x42187, 0x20); +dwc_ddrphy_apb_wr(0x42188, 0xc000); +dwc_ddrphy_apb_wr(0x42189, 0x3); +dwc_ddrphy_apb_wr(0x4218a, 0x3c0); +dwc_ddrphy_apb_wr(0x4218b, 0x2c1); +dwc_ddrphy_apb_wr(0x4218c, 0xc000); +dwc_ddrphy_apb_wr(0x4218d, 0x3); +dwc_ddrphy_apb_wr(0x4218e, 0x3c0); +dwc_ddrphy_apb_wr(0x4218f, 0x1001); +dwc_ddrphy_apb_wr(0x42190, 0x85f5); +dwc_ddrphy_apb_wr(0x42191, 0xf563); +dwc_ddrphy_apb_wr(0x42192, 0x3c5); +dwc_ddrphy_apb_wr(0x42193, 0x820); +dwc_ddrphy_apb_wr(0x42194, 0xc000); +dwc_ddrphy_apb_wr(0x42195, 0x3); +dwc_ddrphy_apb_wr(0x42196, 0x3c0); +dwc_ddrphy_apb_wr(0x42197, 0x20); +dwc_ddrphy_apb_wr(0x42198, 0xc000); +dwc_ddrphy_apb_wr(0x42199, 0x3); +dwc_ddrphy_apb_wr(0x4219a, 0x3c0); +dwc_ddrphy_apb_wr(0x4219b, 0x2c1); +dwc_ddrphy_apb_wr(0x4219c, 0xc000); +dwc_ddrphy_apb_wr(0x4219d, 0x3); +dwc_ddrphy_apb_wr(0x4219e, 0x3c0); +dwc_ddrphy_apb_wr(0x4219f, 0x1001); +dwc_ddrphy_apb_wr(0x421a0, 0x45d5); +dwc_ddrphy_apb_wr(0x421a1, 0xd563); +dwc_ddrphy_apb_wr(0x421a2, 0x3c5); +dwc_ddrphy_apb_wr(0x421a3, 0x421); +dwc_ddrphy_apb_wr(0x421a4, 0xc000); +dwc_ddrphy_apb_wr(0x421a5, 0x3); +dwc_ddrphy_apb_wr(0x421a6, 0x3c0); +dwc_ddrphy_apb_wr(0x421a7, 0x21); +dwc_ddrphy_apb_wr(0x421a8, 0xc000); +dwc_ddrphy_apb_wr(0x421a9, 0x3); +dwc_ddrphy_apb_wr(0x421aa, 0x3c0); +dwc_ddrphy_apb_wr(0x421ab, 0x2c1); +dwc_ddrphy_apb_wr(0x421ac, 0xc000); +dwc_ddrphy_apb_wr(0x421ad, 0x3); +dwc_ddrphy_apb_wr(0x421ae, 0x3c0); +dwc_ddrphy_apb_wr(0x421af, 0x1001); +dwc_ddrphy_apb_wr(0x421b0, 0x45f5); +dwc_ddrphy_apb_wr(0x421b1, 0xf563); +dwc_ddrphy_apb_wr(0x421b2, 0x3c5); +dwc_ddrphy_apb_wr(0x421b3, 0x821); +dwc_ddrphy_apb_wr(0x421b4, 0xc000); +dwc_ddrphy_apb_wr(0x421b5, 0x3); +dwc_ddrphy_apb_wr(0x421b6, 0x3c0); +dwc_ddrphy_apb_wr(0x421b7, 0x21); +dwc_ddrphy_apb_wr(0x421b8, 0xc000); +dwc_ddrphy_apb_wr(0x421b9, 0x3); +dwc_ddrphy_apb_wr(0x421ba, 0x3c0); +dwc_ddrphy_apb_wr(0x421bb, 0x2c1); +dwc_ddrphy_apb_wr(0x421bc, 0xc000); +dwc_ddrphy_apb_wr(0x421bd, 0x3); +dwc_ddrphy_apb_wr(0x421be, 0x3c0); +dwc_ddrphy_apb_wr(0x421bf, 0x1001); +dwc_ddrphy_apb_wr(0x421c0, 0xc5d5); +dwc_ddrphy_apb_wr(0x421c1, 0xd562); +dwc_ddrphy_apb_wr(0x421c2, 0x3c5); +dwc_ddrphy_apb_wr(0x421c3, 0x422); +dwc_ddrphy_apb_wr(0x421c4, 0xc000); +dwc_ddrphy_apb_wr(0x421c5, 0x3); +dwc_ddrphy_apb_wr(0x421c6, 0x3c0); +dwc_ddrphy_apb_wr(0x421c7, 0x22); +dwc_ddrphy_apb_wr(0x421c8, 0xc000); +dwc_ddrphy_apb_wr(0x421c9, 0x3); +dwc_ddrphy_apb_wr(0x421ca, 0x3c0); +dwc_ddrphy_apb_wr(0x421cb, 0x2c1); +dwc_ddrphy_apb_wr(0x421cc, 0xc000); +dwc_ddrphy_apb_wr(0x421cd, 0x3); +dwc_ddrphy_apb_wr(0x421ce, 0x3c0); +dwc_ddrphy_apb_wr(0x421cf, 0x1001); +dwc_ddrphy_apb_wr(0x421d0, 0xc5f5); +dwc_ddrphy_apb_wr(0x421d1, 0xf562); +dwc_ddrphy_apb_wr(0x421d2, 0x3c5); +dwc_ddrphy_apb_wr(0x421d3, 0x822); +dwc_ddrphy_apb_wr(0x421d4, 0xc000); +dwc_ddrphy_apb_wr(0x421d5, 0x3); +dwc_ddrphy_apb_wr(0x421d6, 0x3c0); +dwc_ddrphy_apb_wr(0x421d7, 0x22); +dwc_ddrphy_apb_wr(0x421d8, 0xc000); +dwc_ddrphy_apb_wr(0x421d9, 0x3); +dwc_ddrphy_apb_wr(0x421da, 0x3c0); +dwc_ddrphy_apb_wr(0x421db, 0x2c1); +dwc_ddrphy_apb_wr(0x421dc, 0xc000); +dwc_ddrphy_apb_wr(0x421dd, 0x3); +dwc_ddrphy_apb_wr(0x421de, 0x3c0); +dwc_ddrphy_apb_wr(0x421df, 0x1001); +dwc_ddrphy_apb_wr(0x421e0, 0xc5d5); +dwc_ddrphy_apb_wr(0x421e1, 0xd561); +dwc_ddrphy_apb_wr(0x421e2, 0x3c5); +dwc_ddrphy_apb_wr(0x421e3, 0x423); +dwc_ddrphy_apb_wr(0x421e4, 0xc000); +dwc_ddrphy_apb_wr(0x421e5, 0x3); +dwc_ddrphy_apb_wr(0x421e6, 0x3c0); +dwc_ddrphy_apb_wr(0x421e7, 0x23); +dwc_ddrphy_apb_wr(0x421e8, 0xc000); +dwc_ddrphy_apb_wr(0x421e9, 0x3); +dwc_ddrphy_apb_wr(0x421ea, 0x3c0); +dwc_ddrphy_apb_wr(0x421eb, 0x2c1); +dwc_ddrphy_apb_wr(0x421ec, 0xc000); +dwc_ddrphy_apb_wr(0x421ed, 0x3); +dwc_ddrphy_apb_wr(0x421ee, 0x3c0); +dwc_ddrphy_apb_wr(0x421ef, 0x1001); +dwc_ddrphy_apb_wr(0x421f0, 0xc5f5); +dwc_ddrphy_apb_wr(0x421f1, 0xf561); +dwc_ddrphy_apb_wr(0x421f2, 0x3c5); +dwc_ddrphy_apb_wr(0x421f3, 0x823); +dwc_ddrphy_apb_wr(0x421f4, 0xc000); +dwc_ddrphy_apb_wr(0x421f5, 0x3); +dwc_ddrphy_apb_wr(0x421f6, 0x3c0); +dwc_ddrphy_apb_wr(0x421f7, 0x23); +dwc_ddrphy_apb_wr(0x421f8, 0xc000); +dwc_ddrphy_apb_wr(0x421f9, 0x3); +dwc_ddrphy_apb_wr(0x421fa, 0x3c0); +dwc_ddrphy_apb_wr(0x421fb, 0x2c1); +dwc_ddrphy_apb_wr(0x421fc, 0xc000); +dwc_ddrphy_apb_wr(0x421fd, 0x3); +dwc_ddrphy_apb_wr(0x421fe, 0x3c0); +dwc_ddrphy_apb_wr(0x421ff, 0x1d01); +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 2, type = 0 +dwc_ddrphy_apb_wr(0x42200, 0x213); +dwc_ddrphy_apb_wr(0x42201, 0x1300); +dwc_ddrphy_apb_wr(0x42202, 0x3c2); +dwc_ddrphy_apb_wr(0x42203, 0x21); +dwc_ddrphy_apb_wr(0x42204, 0xc000); +dwc_ddrphy_apb_wr(0x42205, 0x3); +dwc_ddrphy_apb_wr(0x42206, 0x3c0); +dwc_ddrphy_apb_wr(0x42207, 0x20); +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 0 +dwc_ddrphy_apb_wr(0x42208, 0xc000); +dwc_ddrphy_apb_wr(0x42209, 0x3); +dwc_ddrphy_apb_wr(0x4220a, 0x3c0); +dwc_ddrphy_apb_wr(0x4220b, 0x2e1); +dwc_ddrphy_apb_wr(0x4220c, 0xc000); +dwc_ddrphy_apb_wr(0x4220d, 0x3); +dwc_ddrphy_apb_wr(0x4220e, 0x3c0); +dwc_ddrphy_apb_wr(0x4220f, 0xef20); +dwc_ddrphy_apb_wr(0x42210, 0xc000); +dwc_ddrphy_apb_wr(0x42211, 0x3); +dwc_ddrphy_apb_wr(0x42212, 0x3c0); +dwc_ddrphy_apb_wr(0x42213, 0x2e1); +dwc_ddrphy_apb_wr(0x42214, 0xc000); +dwc_ddrphy_apb_wr(0x42215, 0x3); +dwc_ddrphy_apb_wr(0x42216, 0x3c0); +dwc_ddrphy_apb_wr(0x42217, 0x5920); +dwc_ddrphy_apb_wr(0x42218, 0x217); +dwc_ddrphy_apb_wr(0x42219, 0x1700); +dwc_ddrphy_apb_wr(0x4221a, 0x3c2); +dwc_ddrphy_apb_wr(0x4221b, 0x21); +dwc_ddrphy_apb_wr(0x4221c, 0xc000); +dwc_ddrphy_apb_wr(0x4221d, 0x3); +dwc_ddrphy_apb_wr(0x4221e, 0x3c0); +dwc_ddrphy_apb_wr(0x4221f, 0x20); +dwc_ddrphy_apb_wr(0x42220, 0xc000); +dwc_ddrphy_apb_wr(0x42221, 0x3); +dwc_ddrphy_apb_wr(0x42222, 0x3c0); +dwc_ddrphy_apb_wr(0x42223, 0x2e1); +dwc_ddrphy_apb_wr(0x42224, 0xc000); +dwc_ddrphy_apb_wr(0x42225, 0x3); +dwc_ddrphy_apb_wr(0x42226, 0x3c0); +dwc_ddrphy_apb_wr(0x42227, 0x420); +//// [phyinit_LoadPIECodeSections] Moving start address from 42228 to 90029 +dwc_ddrphy_apb_wr(0x90029, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b0s0 +dwc_ddrphy_apb_wr(0x9002a, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b0s1 +dwc_ddrphy_apb_wr(0x9002b, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b0s2 +dwc_ddrphy_apb_wr(0x9002c, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b1s0 +dwc_ddrphy_apb_wr(0x9002d, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b1s1 +dwc_ddrphy_apb_wr(0x9002e, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b1s2 +dwc_ddrphy_apb_wr(0x9002f, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b2s0 +dwc_ddrphy_apb_wr(0x90030, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b2s1 +dwc_ddrphy_apb_wr(0x90031, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b2s2 +dwc_ddrphy_apb_wr(0x90032, 0xb); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b3s0 +dwc_ddrphy_apb_wr(0x90033, 0x480); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b3s1 +dwc_ddrphy_apb_wr(0x90034, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b3s2 +dwc_ddrphy_apb_wr(0x90035, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b4s0 +dwc_ddrphy_apb_wr(0x90036, 0x448); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b4s1 +dwc_ddrphy_apb_wr(0x90037, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b4s2 +dwc_ddrphy_apb_wr(0x90038, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b5s0 +dwc_ddrphy_apb_wr(0x90039, 0x478); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b5s1 +dwc_ddrphy_apb_wr(0x9003a, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b5s2 +dwc_ddrphy_apb_wr(0x9003b, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b6s0 +dwc_ddrphy_apb_wr(0x9003c, 0xe8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b6s1 +dwc_ddrphy_apb_wr(0x9003d, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b6s2 +dwc_ddrphy_apb_wr(0x9003e, 0x2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b7s0 +dwc_ddrphy_apb_wr(0x9003f, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b7s1 +dwc_ddrphy_apb_wr(0x90040, 0x139); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b7s2 +dwc_ddrphy_apb_wr(0x90041, 0xf); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b8s0 +dwc_ddrphy_apb_wr(0x90042, 0x7c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b8s1 +dwc_ddrphy_apb_wr(0x90043, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b8s2 +dwc_ddrphy_apb_wr(0x90044, 0x107); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b9s0 +dwc_ddrphy_apb_wr(0x90045, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b9s1 +dwc_ddrphy_apb_wr(0x90046, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b9s2 +dwc_ddrphy_apb_wr(0x90047, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b10s0 +dwc_ddrphy_apb_wr(0x90048, 0xe0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b10s1 +dwc_ddrphy_apb_wr(0x90049, 0x139); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b10s2 +dwc_ddrphy_apb_wr(0x9004a, 0x147); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b11s0 +dwc_ddrphy_apb_wr(0x9004b, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b11s1 +dwc_ddrphy_apb_wr(0x9004c, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b11s2 +dwc_ddrphy_apb_wr(0x9004d, 0x14f); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b12s0 +dwc_ddrphy_apb_wr(0x9004e, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b12s1 +dwc_ddrphy_apb_wr(0x9004f, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b12s2 +dwc_ddrphy_apb_wr(0x90050, 0x7); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b13s0 +dwc_ddrphy_apb_wr(0x90051, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b13s1 +dwc_ddrphy_apb_wr(0x90052, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b13s2 +dwc_ddrphy_apb_wr(0x90053, 0x47); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b14s0 +dwc_ddrphy_apb_wr(0x90054, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b14s1 +dwc_ddrphy_apb_wr(0x90055, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b14s2 +dwc_ddrphy_apb_wr(0x90056, 0x4f); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b15s0 +dwc_ddrphy_apb_wr(0x90057, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b15s1 +dwc_ddrphy_apb_wr(0x90058, 0x179); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b15s2 +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 800, type = 0 +dwc_ddrphy_apb_wr(0x90059, 0x100); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b16s0 +dwc_ddrphy_apb_wr(0x9005a, 0x15c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b16s1 +dwc_ddrphy_apb_wr(0x9005b, 0x139); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b16s2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800, type = 0 +dwc_ddrphy_apb_wr(0x9005c, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b17s0 +dwc_ddrphy_apb_wr(0x9005d, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b17s1 +dwc_ddrphy_apb_wr(0x9005e, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b17s2 +dwc_ddrphy_apb_wr(0x9005f, 0x11); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b18s0 +dwc_ddrphy_apb_wr(0x90060, 0x530); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b18s1 +dwc_ddrphy_apb_wr(0x90061, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b18s2 +dwc_ddrphy_apb_wr(0x90062, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b19s0 +dwc_ddrphy_apb_wr(0x90063, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b19s1 +dwc_ddrphy_apb_wr(0x90064, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b19s2 +dwc_ddrphy_apb_wr(0x90065, 0x14f); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b20s0 +dwc_ddrphy_apb_wr(0x90066, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b20s1 +dwc_ddrphy_apb_wr(0x90067, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b20s2 +dwc_ddrphy_apb_wr(0x90068, 0x2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b21s0 +dwc_ddrphy_apb_wr(0x90069, 0x45a); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b21s1 +dwc_ddrphy_apb_wr(0x9006a, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b21s2 +dwc_ddrphy_apb_wr(0x9006b, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b22s0 +dwc_ddrphy_apb_wr(0x9006c, 0x530); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b22s1 +dwc_ddrphy_apb_wr(0x9006d, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b22s2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 800, type = 0 +dwc_ddrphy_apb_wr(0x9006e, 0xc100); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b23s0 +dwc_ddrphy_apb_wr(0x9006f, 0x15c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b23s1 +dwc_ddrphy_apb_wr(0x90070, 0x139); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b23s2 +dwc_ddrphy_apb_wr(0x90071, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b24s0 +dwc_ddrphy_apb_wr(0x90072, 0x65a); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b24s1 +dwc_ddrphy_apb_wr(0x90073, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b24s2 +dwc_ddrphy_apb_wr(0x90074, 0x41); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b25s0 +dwc_ddrphy_apb_wr(0x90075, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b25s1 +dwc_ddrphy_apb_wr(0x90076, 0x179); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b25s2 +dwc_ddrphy_apb_wr(0x90077, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b26s0 +dwc_ddrphy_apb_wr(0x90078, 0x618); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b26s1 +dwc_ddrphy_apb_wr(0x90079, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b26s2 +dwc_ddrphy_apb_wr(0x9007a, 0x40c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b27s0 +dwc_ddrphy_apb_wr(0x9007b, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b27s1 +dwc_ddrphy_apb_wr(0x9007c, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b27s2 +dwc_ddrphy_apb_wr(0x9007d, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b28s0 +dwc_ddrphy_apb_wr(0x9007e, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b28s1 +dwc_ddrphy_apb_wr(0x9007f, 0x48); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b28s2 +dwc_ddrphy_apb_wr(0x90080, 0x4040); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b29s0 +dwc_ddrphy_apb_wr(0x90081, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b29s1 +dwc_ddrphy_apb_wr(0x90082, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b29s2 +dwc_ddrphy_apb_wr(0x90083, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b30s0 +dwc_ddrphy_apb_wr(0x90084, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b30s1 +dwc_ddrphy_apb_wr(0x90085, 0x48); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b30s2 +dwc_ddrphy_apb_wr(0x90086, 0x40); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b31s0 +dwc_ddrphy_apb_wr(0x90087, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b31s1 +dwc_ddrphy_apb_wr(0x90088, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b31s2 +dwc_ddrphy_apb_wr(0x90089, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b32s0 +dwc_ddrphy_apb_wr(0x9008a, 0x658); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b32s1 +dwc_ddrphy_apb_wr(0x9008b, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b32s2 +dwc_ddrphy_apb_wr(0x9008c, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b33s0 +dwc_ddrphy_apb_wr(0x9008d, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b33s1 +dwc_ddrphy_apb_wr(0x9008e, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b33s2 +dwc_ddrphy_apb_wr(0x9008f, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b34s0 +dwc_ddrphy_apb_wr(0x90090, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b34s1 +dwc_ddrphy_apb_wr(0x90091, 0x78); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b34s2 +dwc_ddrphy_apb_wr(0x90092, 0x549); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b35s0 +dwc_ddrphy_apb_wr(0x90093, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b35s1 +dwc_ddrphy_apb_wr(0x90094, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b35s2 +dwc_ddrphy_apb_wr(0x90095, 0xd49); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b36s0 +dwc_ddrphy_apb_wr(0x90096, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b36s1 +dwc_ddrphy_apb_wr(0x90097, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b36s2 +dwc_ddrphy_apb_wr(0x90098, 0x94c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b37s0 +dwc_ddrphy_apb_wr(0x90099, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b37s1 +dwc_ddrphy_apb_wr(0x9009a, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b37s2 +dwc_ddrphy_apb_wr(0x9009b, 0x94c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b38s0 +dwc_ddrphy_apb_wr(0x9009c, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b38s1 +dwc_ddrphy_apb_wr(0x9009d, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b38s2 +dwc_ddrphy_apb_wr(0x9009e, 0x442); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b39s0 +dwc_ddrphy_apb_wr(0x9009f, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b39s1 +dwc_ddrphy_apb_wr(0x900a0, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b39s2 +dwc_ddrphy_apb_wr(0x900a1, 0x42); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b40s0 +dwc_ddrphy_apb_wr(0x900a2, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b40s1 +dwc_ddrphy_apb_wr(0x900a3, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b40s2 +dwc_ddrphy_apb_wr(0x900a4, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b41s0 +dwc_ddrphy_apb_wr(0x900a5, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b41s1 +dwc_ddrphy_apb_wr(0x900a6, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b41s2 +dwc_ddrphy_apb_wr(0x900a7, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b42s0 +dwc_ddrphy_apb_wr(0x900a8, 0xe0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b42s1 +dwc_ddrphy_apb_wr(0x900a9, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b42s2 +dwc_ddrphy_apb_wr(0x900aa, 0xa); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b43s0 +dwc_ddrphy_apb_wr(0x900ab, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b43s1 +dwc_ddrphy_apb_wr(0x900ac, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b43s2 +dwc_ddrphy_apb_wr(0x900ad, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b44s0 +dwc_ddrphy_apb_wr(0x900ae, 0x3c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b44s1 +dwc_ddrphy_apb_wr(0x900af, 0x149); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b44s2 +dwc_ddrphy_apb_wr(0x900b0, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b45s0 +dwc_ddrphy_apb_wr(0x900b1, 0x3c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b45s1 +dwc_ddrphy_apb_wr(0x900b2, 0x159); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b45s2 +dwc_ddrphy_apb_wr(0x900b3, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b46s0 +dwc_ddrphy_apb_wr(0x900b4, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b46s1 +dwc_ddrphy_apb_wr(0x900b5, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b46s2 +dwc_ddrphy_apb_wr(0x900b6, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b47s0 +dwc_ddrphy_apb_wr(0x900b7, 0x3c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b47s1 +dwc_ddrphy_apb_wr(0x900b8, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b47s2 +dwc_ddrphy_apb_wr(0x900b9, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b48s0 +dwc_ddrphy_apb_wr(0x900ba, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b48s1 +dwc_ddrphy_apb_wr(0x900bb, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b48s2 +dwc_ddrphy_apb_wr(0x900bc, 0xc); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b49s0 +dwc_ddrphy_apb_wr(0x900bd, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b49s1 +dwc_ddrphy_apb_wr(0x900be, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b49s2 +dwc_ddrphy_apb_wr(0x900bf, 0x3); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b50s0 +dwc_ddrphy_apb_wr(0x900c0, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b50s1 +dwc_ddrphy_apb_wr(0x900c1, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b50s2 +dwc_ddrphy_apb_wr(0x900c2, 0x7); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b51s0 +dwc_ddrphy_apb_wr(0x900c3, 0x7c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b51s1 +dwc_ddrphy_apb_wr(0x900c4, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b51s2 +//// [phyinit_LoadPIECodeSections] Matched ANY enable_bits = 8, type = 0 +dwc_ddrphy_apb_wr(0x900c5, 0x3a); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b52s0 +dwc_ddrphy_apb_wr(0x900c6, 0x1e2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b52s1 +dwc_ddrphy_apb_wr(0x900c7, 0x9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b52s2 +dwc_ddrphy_apb_wr(0x900c8, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b53s0 +dwc_ddrphy_apb_wr(0x900c9, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b53s1 +dwc_ddrphy_apb_wr(0x900ca, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b53s2 +dwc_ddrphy_apb_wr(0x900cb, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b54s0 +dwc_ddrphy_apb_wr(0x900cc, 0x400); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b54s1 +dwc_ddrphy_apb_wr(0x900cd, 0x16e); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b54s2 +dwc_ddrphy_apb_wr(0x900ce, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b55s0 +dwc_ddrphy_apb_wr(0x900cf, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b55s1 +dwc_ddrphy_apb_wr(0x900d0, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b55s2 +dwc_ddrphy_apb_wr(0x900d1, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b56s0 +dwc_ddrphy_apb_wr(0x900d2, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b56s1 +dwc_ddrphy_apb_wr(0x900d3, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b56s2 +dwc_ddrphy_apb_wr(0x900d4, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b57s0 +dwc_ddrphy_apb_wr(0x900d5, 0x978); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b57s1 +dwc_ddrphy_apb_wr(0x900d6, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b57s2 +dwc_ddrphy_apb_wr(0x900d7, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b58s0 +dwc_ddrphy_apb_wr(0x900d8, 0xa78); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b58s1 +dwc_ddrphy_apb_wr(0x900d9, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b58s2 +dwc_ddrphy_apb_wr(0x900da, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s0 +dwc_ddrphy_apb_wr(0x900db, 0x980); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s1 +dwc_ddrphy_apb_wr(0x900dc, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s2 +dwc_ddrphy_apb_wr(0x900dd, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b60s0 +dwc_ddrphy_apb_wr(0x900de, 0xa80); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b60s1 +dwc_ddrphy_apb_wr(0x900df, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b60s2 +dwc_ddrphy_apb_wr(0x900e0, 0x32); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b61s0 +dwc_ddrphy_apb_wr(0x900e1, 0x952); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b61s1 +dwc_ddrphy_apb_wr(0x900e2, 0x69); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b61s2 +dwc_ddrphy_apb_wr(0x900e3, 0x32); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b62s0 +dwc_ddrphy_apb_wr(0x900e4, 0xa52); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b62s1 +dwc_ddrphy_apb_wr(0x900e5, 0x69); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b62s2 +dwc_ddrphy_apb_wr(0x900e6, 0x2); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b63s0 +dwc_ddrphy_apb_wr(0x900e7, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b63s1 +dwc_ddrphy_apb_wr(0x900e8, 0x68); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b63s2 +dwc_ddrphy_apb_wr(0x900e9, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b64s0 +dwc_ddrphy_apb_wr(0x900ea, 0x370); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b64s1 +dwc_ddrphy_apb_wr(0x900eb, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b64s2 +dwc_ddrphy_apb_wr(0x900ec, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b65s0 +dwc_ddrphy_apb_wr(0x900ed, 0x1400); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b65s1 +dwc_ddrphy_apb_wr(0x900ee, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b65s2 +dwc_ddrphy_apb_wr(0x900ef, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b66s0 +dwc_ddrphy_apb_wr(0x900f0, 0x8e8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b66s1 +dwc_ddrphy_apb_wr(0x900f1, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b66s2 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 20, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 80, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 40, type = 0 +//// [phyinit_LoadPIECodeSections] No match for ANY enable_bits = 100, type = 0 +//// [phyinit_LoadPIECodeSections] Matched NO enable_bits = 2, type = 0 +dwc_ddrphy_apb_wr(0x900f2, 0x2cd); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b67s0 +dwc_ddrphy_apb_wr(0x900f3, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b67s1 +dwc_ddrphy_apb_wr(0x900f4, 0x68); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b67s2 +dwc_ddrphy_apb_wr(0x900f5, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b68s0 +dwc_ddrphy_apb_wr(0x900f6, 0x8e8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b68s1 +dwc_ddrphy_apb_wr(0x900f7, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b68s2 +dwc_ddrphy_apb_wr(0x900f8, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b69s0 +dwc_ddrphy_apb_wr(0x900f9, 0x3c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b69s1 +dwc_ddrphy_apb_wr(0x900fa, 0x1e9); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b69s2 +dwc_ddrphy_apb_wr(0x900fb, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b70s0 +dwc_ddrphy_apb_wr(0x900fc, 0x370); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b70s1 +dwc_ddrphy_apb_wr(0x900fd, 0x169); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b70s2 +dwc_ddrphy_apb_wr(0x900fe, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b71s0 +dwc_ddrphy_apb_wr(0x900ff, 0xe8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b71s1 +dwc_ddrphy_apb_wr(0x90100, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b71s2 +dwc_ddrphy_apb_wr(0x90101, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b72s0 +dwc_ddrphy_apb_wr(0x90102, 0x8140); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b72s1 +dwc_ddrphy_apb_wr(0x90103, 0x10c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b72s2 +dwc_ddrphy_apb_wr(0x90104, 0x10); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b73s0 +dwc_ddrphy_apb_wr(0x90105, 0x8138); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b73s1 +dwc_ddrphy_apb_wr(0x90106, 0x10c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b73s2 +//// [phyinit_LoadPIECodeSections] Matched ANY enable_bits = 1, type = 0 +dwc_ddrphy_apb_wr(0x90107, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b74s0 +dwc_ddrphy_apb_wr(0x90108, 0x400); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b74s1 +dwc_ddrphy_apb_wr(0x90109, 0x10e); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b74s2 +dwc_ddrphy_apb_wr(0x9010a, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b75s0 +dwc_ddrphy_apb_wr(0x9010b, 0x448); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b75s1 +dwc_ddrphy_apb_wr(0x9010c, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b75s2 +dwc_ddrphy_apb_wr(0x9010d, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b76s0 +dwc_ddrphy_apb_wr(0x9010e, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b76s1 +dwc_ddrphy_apb_wr(0x9010f, 0x101); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b76s2 +dwc_ddrphy_apb_wr(0x90110, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b77s0 +dwc_ddrphy_apb_wr(0x90111, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b77s1 +dwc_ddrphy_apb_wr(0x90112, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b77s2 +dwc_ddrphy_apb_wr(0x90113, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b78s0 +dwc_ddrphy_apb_wr(0x90114, 0x448); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b78s1 +dwc_ddrphy_apb_wr(0x90115, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b78s2 +dwc_ddrphy_apb_wr(0x90116, 0xf); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b79s0 +dwc_ddrphy_apb_wr(0x90117, 0x7c0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b79s1 +dwc_ddrphy_apb_wr(0x90118, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b79s2 +dwc_ddrphy_apb_wr(0x90119, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b80s0 +dwc_ddrphy_apb_wr(0x9011a, 0xe8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b80s1 +dwc_ddrphy_apb_wr(0x9011b, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b80s2 +dwc_ddrphy_apb_wr(0x9011c, 0x7); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b81s0 +dwc_ddrphy_apb_wr(0x9011d, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b81s1 +dwc_ddrphy_apb_wr(0x9011e, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b81s2 +dwc_ddrphy_apb_wr(0x9011f, 0x47); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b82s0 +dwc_ddrphy_apb_wr(0x90120, 0x630); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b82s1 +dwc_ddrphy_apb_wr(0x90121, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b82s2 +dwc_ddrphy_apb_wr(0x90122, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b83s0 +dwc_ddrphy_apb_wr(0x90123, 0x618); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b83s1 +dwc_ddrphy_apb_wr(0x90124, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b83s2 +dwc_ddrphy_apb_wr(0x90125, 0x18); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b84s0 +dwc_ddrphy_apb_wr(0x90126, 0xe0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b84s1 +dwc_ddrphy_apb_wr(0x90127, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b84s2 +dwc_ddrphy_apb_wr(0x90128, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b85s0 +dwc_ddrphy_apb_wr(0x90129, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b85s1 +dwc_ddrphy_apb_wr(0x9012a, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b85s2 +dwc_ddrphy_apb_wr(0x9012b, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b86s0 +dwc_ddrphy_apb_wr(0x9012c, 0x8140); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b86s1 +dwc_ddrphy_apb_wr(0x9012d, 0x10c); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b86s2 +dwc_ddrphy_apb_wr(0x9012e, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b87s0 +dwc_ddrphy_apb_wr(0x9012f, 0x478); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b87s1 +dwc_ddrphy_apb_wr(0x90130, 0x109); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b87s2 +dwc_ddrphy_apb_wr(0x90131, 0x0); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b88s0 +dwc_ddrphy_apb_wr(0x90132, 0x1); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b88s1 +dwc_ddrphy_apb_wr(0x90133, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b88s2 +dwc_ddrphy_apb_wr(0x90134, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b89s0 +dwc_ddrphy_apb_wr(0x90135, 0x4); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b89s1 +dwc_ddrphy_apb_wr(0x90136, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b89s2 +dwc_ddrphy_apb_wr(0x90137, 0x8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b90s0 +dwc_ddrphy_apb_wr(0x90138, 0x7c8); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b90s1 +dwc_ddrphy_apb_wr(0x90139, 0x101); // DWC_DDRPHYA_INITENG0_base0_SequenceReg0b90s2 +//// [phyinit_LoadPIECodeSections] Moving start address from 9013a to 90006 +dwc_ddrphy_apb_wr(0x90006, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b0s0 +dwc_ddrphy_apb_wr(0x90007, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b0s1 +dwc_ddrphy_apb_wr(0x90008, 0x8); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b0s2 +dwc_ddrphy_apb_wr(0x90009, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b1s0 +dwc_ddrphy_apb_wr(0x9000a, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b1s1 +dwc_ddrphy_apb_wr(0x9000b, 0x0); // DWC_DDRPHYA_INITENG0_base0_PostSequenceReg0b1s2 +//// [phyinit_LoadPIECodeSections] Moving start address from 9000c to d00e7 +dwc_ddrphy_apb_wr(0xd00e7, 0x400); // DWC_DDRPHYA_APBONLY0_SequencerOverride +//// [phyinit_LoadPIECodeSections] End of dwc_ddrphy_phyinit_LoadPIECodeSections() +dwc_ddrphy_apb_wr(0x20240, 0x4300); // DWC_DDRPHYA_MASTER0_base0_D5ACSMPtrXlat0 +dwc_ddrphy_apb_wr(0x20242, 0x8944); // DWC_DDRPHYA_MASTER0_base0_D5ACSMPtrXlat2 +dwc_ddrphy_apb_wr(0x20241, 0x4300); // DWC_DDRPHYA_MASTER0_base0_D5ACSMPtrXlat1 +dwc_ddrphy_apb_wr(0x20243, 0x8944); // DWC_DDRPHYA_MASTER0_base0_D5ACSMPtrXlat3 +//seq0b_LoadPstateSeqProductionCode(): --------------------------------------------------------------------------------------------------- +//seq0b_LoadPstateSeqProductionCode(): Programming the 0B sequencer 0b0000 start vector registers with 0. +//seq0b_LoadPstateSeqProductionCode(): Programming the 0B sequencer 0b1000 start vector register with 54. +//seq0b_LoadPstateSeqProductionCode(): Programming the 0B sequencer 0b1111 start vector register with 77. +//seq0b_LoadPstateSeqProductionCode(): --------------------------------------------------------------------------------------------------- +dwc_ddrphy_apb_wr(0x90017, 0x0); // DWC_DDRPHYA_INITENG0_base0_StartVector0b0 +dwc_ddrphy_apb_wr(0x9001f, 0x36); // DWC_DDRPHYA_INITENG0_base0_StartVector0b8 +dwc_ddrphy_apb_wr(0x90026, 0x4d); // DWC_DDRPHYA_INITENG0_base0_StartVector0b15 +dwc_ddrphy_apb_wr(0x9000c, 0x0); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag0 +dwc_ddrphy_apb_wr(0x9000d, 0x173); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag1 +dwc_ddrphy_apb_wr(0x9000e, 0x60); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag2 +dwc_ddrphy_apb_wr(0x9000f, 0x6110); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag3 +dwc_ddrphy_apb_wr(0x90010, 0x2152); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag4 +dwc_ddrphy_apb_wr(0x90011, 0xdfbd); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag5 +dwc_ddrphy_apb_wr(0x90012, 0x8060); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag6 +dwc_ddrphy_apb_wr(0x90013, 0x6152); // DWC_DDRPHYA_INITENG0_base0_Seq0BDisableFlag7 +//// [phyinit_I_loadPIEImage] Enabling Phy Master Interface for DRAM drift compensation +//// [phyinit_I_loadPIEImage] Pstate=0, Memclk=1600MHz, Programming PPTTrainSetup::PhyMstrTrainInterval to 0x0 +//// [phyinit_I_loadPIEImage] Pstate=0, Memclk=1600MHz, Programming PPTTrainSetup::PhyMstrMaxReqToAck to 0x0 +dwc_ddrphy_apb_wr(0x20010, 0x0); // DWC_DDRPHYA_MASTER0_base0_PPTTrainSetup_p0 +//// [phyinit_I_loadPIEImage] Pstate=0, Memclk=1600MHz, Programming PPTTrainSetup2::PhyMstrFreqOverride to 0x3 +dwc_ddrphy_apb_wr(0x20011, 0x3); // DWC_DDRPHYA_MASTER0_base0_PPTTrainSetup2_p0 +//// [phyinit_I_loadPIEImage] Programming D5ACSMXlatSelect to 0x1 +dwc_ddrphy_apb_wr(0x20281, 0x1); // DWC_DDRPHYA_MASTER0_base0_D5ACSMXlatSelect +//// [phyinit_I_loadPIEImage] Programming DbyteRxEnTrain::EnDqsSampNegRxEn to 0x1 +dwc_ddrphy_apb_wr(0x2003b, 0x2); // DWC_DDRPHYA_MASTER0_base0_DbyteRxEnTrain +//// [phyinit_I_loadPIEImage] Pstate=0, Memclk=1600MHz, Programming TrackingModeCntrl to 0x131f +dwc_ddrphy_apb_wr(0x20041, 0x131f); // DWC_DDRPHYA_MASTER0_base0_TrackingModeCntrl_p0 +//// [phyinit_I_loadPIEImage] Programming D5ACSM0MaskCs to 0xe +dwc_ddrphy_apb_wr(0x20131, 0xe); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0MaskCs +//// [phyinit_I_loadPIEImage] Programming D5ACSM1MaskCs to 0xf +dwc_ddrphy_apb_wr(0x20151, 0xf); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1MaskCs +//// [phyinit_I_loadPIEImage] Pstate=0, Memclk=1600MHz, Programming Seq0BGPR6[0] with OuterLoopRepeatCnt values to 0x2 +dwc_ddrphy_apb_wr(0x90306, 0x2); // DWC_DDRPHYA_INITENG0_base0_Seq0BGPR6_p0 +//// [phyinit_I_loadPIEImage] Programming D5ACSM<0/1>OuterLoopRepeatCnt=2 +dwc_ddrphy_apb_wr(0x2012a, 0x2); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0OuterLoopRepeatCnt +dwc_ddrphy_apb_wr(0x2014a, 0x2); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1OuterLoopRepeatCnt +//// [phyinit_I_loadPIEImage] Programming D5ACSM<0/1>AddressMask=7ff +dwc_ddrphy_apb_wr(0x20126, 0x7ff); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0AddressMask +dwc_ddrphy_apb_wr(0x20146, 0x7ff); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1AddressMask +//// [phyinit_I_loadPIEImage] Programming D5ACSM<0/1>AlgaIncVal=1 +dwc_ddrphy_apb_wr(0x20127, 0x1); // DWC_DDRPHYA_MASTER0_base0_D5ACSM0AlgaIncVal +dwc_ddrphy_apb_wr(0x20147, 0x1); // DWC_DDRPHYA_MASTER0_base0_D5ACSM1AlgaIncVal +//// [phyinit_I_loadPIEImage] Turn on calibration and hold idle until dfi_init_start is asserted sequence is triggered. +//// [phyinit_I_loadPIEImage] Programming CalZap to 0x1 +//// [phyinit_I_loadPIEImage] Programming CalRate::CalRun to 0x1 +//// [phyinit_I_loadPIEImage] Programming CalRate to 0x19 +dwc_ddrphy_apb_wr(0x20089, 0x1); // DWC_DDRPHYA_MASTER0_base0_CalZap +dwc_ddrphy_apb_wr(0x20088, 0x19); // DWC_DDRPHYA_MASTER0_base0_CalRate +//// [phyinit_I_loadPIEImage] Programming ForceClkGaterEnables::ForcePubDxClkEnLow to 0x0 +dwc_ddrphy_apb_wr(0x200a6, 0x0); // DWC_DDRPHYA_MASTER0_base0_ForceClkGaterEnables +//// Disabling Ucclk (PMU) and Hclk (training hardware) +dwc_ddrphy_apb_wr(0xc0080, 0x0); // DWC_DDRPHYA_DRTUB0_UcclkHclkEnables +//// Isolate the APB access from the internal CSRs by setting the MicroContMuxSel CSR to 1. +dwc_ddrphy_apb_wr(0xd0000, 0x1); // DWC_DDRPHYA_APBONLY0_MicroContMuxSel +//// [phyinit_userCustom_wait] Wait 40 DfiClks +//// [phyinit_I_loadPIEImage] End of dwc_ddrphy_phyinit_I_loadPIEImage() +// +// +////############################################################## +//// +//// dwc_ddrphy_phyinit_userCustom_customPostTrain is a user-editable function. +//// +//// The purpose of dwc_ddrphy_phyinit_userCustom_customPostTrain() is to override any +//// CSR values programmed by the training firmware or dwc_ddrphy_phyinit_progCsrSkipTrain() +//// This function is executed after training +//// +//// IMPORTANT: in this function, user shall not override any values in userInputBasic and +//// userInputAdvanced data structures. Only CSR programming should be done in this function. +//// +//// Sequence of Events in this function are: +//// 1. Enable APB access. +//// 2. Issue register writes +//// 3. Isolate APB access. +// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_customPostTrain(); + +//// [dwc_ddrphy_phyinit_userCustom_customPostTrain] End of dwc_ddrphy_phyinit_userCustom_customPostTrain() +//// [dwc_ddrphy_phyinit_userCustom_J_enterMissionMode] Start of dwc_ddrphy_phyinit_userCustom_J_enterMissionMode() +// +// +////############################################################## +//// +//// 4.3.10(J) Initialize the PHY to Mission Mode through DFI Initialization +//// +//// Initialize the PHY to mission mode as follows: +//// +//// 1. Set the PHY input clocks to the desired frequency. +//// 2. Initialize the PHY to mission mode by performing DFI Initialization. +//// Please see the DFI specification for more information. See the DFI frequency bus encoding in section <XXX>. +//// Note: The PHY training firmware initializes the DRAM state. if skip +//// training is used, the DRAM state is not initialized. +//// +////############################################################## +// +dwc_ddrphy_phyinit_userCustom_J_enterMissionMode(sdrammc); + +// +//// [dwc_ddrphy_phyinit_userCustom_J_enterMissionMode] End of dwc_ddrphy_phyinit_userCustom_J_enterMissionMode() +// [dwc_ddrphy_phyinit_sequence] End of dwc_ddrphy_phyinit_sequence() +// [dwc_ddrphy_phyinit_main] End of dwc_ddrphy_phyinit_main() diff --git a/drivers/ram/aspeed/sdram_ast2700.c b/drivers/ram/aspeed/sdram_ast2700.c new file mode 100644 index 00000000000..4a019c4edb1 --- /dev/null +++ b/drivers/ram/aspeed/sdram_ast2700.c @@ -0,0 +1,1036 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) ASPEED Technology Inc. + */ +#include <asm/io.h> +#include <asm/arch/fmc_hdr.h> +#include <asm/arch/scu.h> +#include <asm/arch/sdram.h> +#include <config.h> +#include <dm.h> +#include <linux/bitfield.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/sizes.h> +#include <ram.h> + +enum ddr_type { + DDR4_1600 = 0x0, + DDR4_2400, + DDR4_3200, + DDR5_3200, + + DDR_TYPES +}; + +enum ddr_size { + DDR_SIZE_256MB, + DDR_SIZE_512MB, + DDR_SIZE_1GB, + DDR_SIZE_2GB, + + DDR_SIZE_MAX, +}; + +#define IS_DDR4(t) \ + (((t) <= DDR4_3200) ? 1 : 0) + +struct sdrammc_ac_timing { + u32 t_cl; + u32 t_cwl; + u32 t_bl; + u32 t_rcd; /* ACT-to-read/write command delay */ + u32 t_rp; /* PRE command period */ + u32 t_ras; /* ACT-to-PRE command delay */ + u32 t_rrd; /* ACT-to-ACT delay for different BG */ + u32 t_rrd_l; /* ACT-to-ACT delay for same BG */ + u32 t_faw; /* Four active window */ + u32 t_rtp; /* Read-to-PRE command delay */ + u32 t_wtr; /* Minimum write to read command for different BG */ + u32 t_wtr_l; /* Minimum write to read command for same BG */ + u32 t_wtr_a; /* Write to read command for same BG with auto precharge */ + u32 t_wtp; /* Minimum write to precharge command delay */ + u32 t_rtw; /* minimum read to write command */ + u32 t_ccd_l; /* CAS-to-CAS delay for same BG */ + u32 t_dllk; /* DLL locking time */ + u32 t_cksre; /* valid clock before after self-refresh or power-down entry/exit process */ + u32 t_pd; /* power-down entry to exit minimum width */ + u32 t_xp; /* exit power-down to valid command delay */ + u32 t_rfc; /* refresh time period */ + u32 t_mrd; + u32 t_refsbrd; + u32 t_rfcsb; + u32 t_cshsr; + u32 t_zq; +}; + +static const struct sdrammc_ac_timing ac_table[] = { + [DDR4_1600] = { + .t_cl = 10, .t_cwl = 9, .t_bl = 8, .t_rcd = 10, + .t_rp = 10, .t_ras = 28, .t_rrd = 5, .t_rrd_l = 6, + .t_faw = 28, .t_rtp = 6, .t_wtr = 2, .t_wtr_l = 6, + .t_wtr_a = 0, .t_wtp = 12, .t_rtw = 0, .t_ccd_l = 5, + .t_dllk = 597, .t_cksre = 8, .t_pd = 4, .t_xp = 5, + .t_rfc = 880, .t_mrd = 24, .t_refsbrd = 0, .t_rfcsb = 0, + .t_cshsr = 0, .t_zq = 80, + }, + [DDR4_2400] = { + .t_cl = 15, .t_cwl = 12, .t_bl = 8, .t_rcd = 16, + .t_rp = 16, .t_ras = 39, .t_rrd = 7, .t_rrd_l = 8, + .t_faw = 37, .t_rtp = 10, .t_wtr = 4, .t_wtr_l = 10, + .t_wtr_a = 0, .t_wtp = 19, .t_rtw = 0, .t_ccd_l = 7, + .t_dllk = 768, .t_cksre = 13, .t_pd = 7, .t_xp = 8, + .t_rfc = 880, .t_mrd = 24, .t_refsbrd = 0, .t_rfcsb = 0, + .t_cshsr = 0, .t_zq = 80, + }, + [DDR4_3200] = { + .t_cl = 20, .t_cwl = 16, .t_bl = 8, .t_rcd = 20, + .t_rp = 20, .t_ras = 52, .t_rrd = 9, .t_rrd_l = 11, + .t_faw = 48, .t_rtp = 12, .t_wtr = 4, .t_wtr_l = 12, + .t_wtr_a = 0, .t_wtp = 24, .t_rtw = 0, .t_ccd_l = 8, + .t_dllk = 1023, .t_cksre = 16, .t_pd = 8, .t_xp = 10, + .t_rfc = 880, .t_mrd = 24, .t_refsbrd = 0, .t_rfcsb = 0, + .t_cshsr = 0, .t_zq = 80, + }, + [DDR5_3200] = { + .t_cl = 26, .t_cwl = 24, .t_bl = 16, .t_rcd = 26, + .t_rp = 26, .t_ras = 52, .t_rrd = 8, .t_rrd_l = 8, + .t_faw = 40, .t_rtp = 12, .t_wtr = 4, .t_wtr_l = 16, + .t_wtr_a = 36, .t_wtp = 48, .t_rtw = 0, .t_ccd_l = 8, + .t_dllk = 1024, .t_cksre = 9, .t_pd = 13, .t_xp = 13, + .t_rfc = 880, .t_mrd = 23, .t_refsbrd = 48, .t_rfcsb = 208, + .t_cshsr = 30, + .t_zq = 48, + }, +}; + +struct sdrammc { + u32 type; + void __iomem *regs; + void __iomem *phy; + void __iomem *scu0; + void __iomem *scu1; + const struct sdrammc_ac_timing *ac; + struct ram_info info; +}; + +static size_t ast2700_sdrammc_get_vga_mem_size(struct sdrammc *sdrammc) +{ + struct sdrammc_regs *regs = sdrammc->regs; + void *scu0 = sdrammc->scu0; + size_t vga_memsz[] = { + SZ_32M, + SZ_64M, + }; + u32 reg, sel, dual = 0; + + sel = readl(®s->gfmcfg) & 0x1; + + reg = readl(scu0 + SCU0_PCI_MISC70); + if (reg & SCU0_PCI_MISC70_EN_PCIEVGA0) { + debug("VGA0:%dMB\n", vga_memsz[sel] / SZ_1M); + dual++; + } + + reg = readl(scu0 + SCU0_PCI_MISC80); + if (reg & SCU0_PCI_MISC80_EN_PCIEVGA1) { + debug("VGA1:%dMB\n", vga_memsz[sel] / SZ_1M); + dual++; + } + + return vga_memsz[sel] * dual; +} + +static int sdrammc_calc_size(struct sdrammc *sdrammc) +{ + struct sdrammc_regs *regs = sdrammc->regs; + u32 val, test_pattern = 0xdeadbeef; + size_t sz; + + struct { + u32 size; + int rfc[2]; + } ddr_capacity[] = { + { 0x10000000UL, {208, 256} }, /* 256MB */ + { 0x20000000UL, {208, 416} }, /* 512MB */ + { 0x40000000UL, {208, 560} }, /* 1GB */ + { 0x80000000UL, {472, 880} }, /* 2GB */ + }; + + /* Configure ram size to max to enable whole area */ + val = readl(®s->mcfg); + val &= ~(0x7 << 2); + writel(val | (DDR_SIZE_2GB << 2), ®s->mcfg); + + /* Clear basement. */ + writel(0, (void *)CFG_SYS_SDRAM_BASE); + + for (sz = DDR_SIZE_2GB - 1; sz > DDR_SIZE_256MB; sz--) { + test_pattern = (test_pattern << 4) + sz; + writel(test_pattern, (void *)(CFG_SYS_SDRAM_BASE + ddr_capacity[sz].size)); + + if (readl((void *)CFG_SYS_SDRAM_BASE) != test_pattern) + break; + } + + /* re-configure ram size to dramc. */ + val = readl(®s->mcfg); + val &= ~(0x7 << 2); + writel(val | ((sz + 1) << 2), ®s->mcfg); + + /* update rfc in ac_timing5 register. */ + val = readl(®s->actime5); + val &= ~(0x3ff); + val |= (ddr_capacity[sz + 1].rfc[IS_DDR4(sdrammc->type)] >> 1); + writel(val, ®s->actime5); + + /* report actual ram base and size to kernel */ + sdrammc->info.base = CFG_SYS_SDRAM_BASE; + sdrammc->info.size = ddr_capacity[sz + 1].size; + + /* reserve the VGA memory */ + sdrammc->info.size -= ast2700_sdrammc_get_vga_mem_size(sdrammc); + + return 0; +} + +static int sdrammc_bist(struct sdrammc *sdrammc, u32 addr, u32 size, u32 cfg, u32 timeout) +{ + struct sdrammc_regs *regs = sdrammc->regs; + u32 val; + u32 err = 0; + + writel(0, ®s->bistcfg); + writel(cfg, ®s->bistcfg); + writel(addr >> 4, ®s->bist_addr); + writel(size >> 4, ®s->bist_size); + writel(0x89abcdef, ®s->bist_patt); + writel(cfg | DRAMC_BISTCFG_START, ®s->bistcfg); + + while (!(readl(®s->intr_status) & DRAMC_IRQSTA_BIST_DONE)) + ; + + writel(DRAMC_IRQSTA_BIST_DONE, ®s->intr_clear); + + val = readl(®s->bist_res); + + if (val & DRAMC_BISTRES_DONE) { + if (val & DRAMC_BISTRES_FAIL) + err++; + } else { + err++; + } + + return err; +} + +static void sdrammc_enable_refresh(struct sdrammc *sdrammc) +{ + struct sdrammc_regs *regs = sdrammc->regs; + + /* refresh update */ + clrbits_le32(®s->refctl, 0x8000); +} + +static void sdrammc_mr_send(struct sdrammc *sdrammc, u32 ctrl, u32 op) +{ + struct sdrammc_regs *regs = sdrammc->regs; + + writel(op, ®s->mrwr); + writel(ctrl | DRAMC_MRCTL_CMD_START, ®s->mrctl); + + while (!(readl(®s->intr_status) & DRAMC_IRQSTA_MR_DONE)) + ; + + writel(DRAMC_IRQSTA_MR_DONE, ®s->intr_clear); +} + +static void sdrammc_config_mrs(struct sdrammc *sdrammc) +{ + const struct sdrammc_ac_timing *ac = sdrammc->ac; + struct sdrammc_regs *regs = sdrammc->regs; + u32 mr0_cas, mr0_rtp, mr0_val; + u32 mr6_tccd_l, mr6_val; + u32 mr2_cwl, mr2_val; + u32 mr1_val; + u32 mr3_val; + u32 mr4_val; + u32 mr5_val; + + if (!IS_DDR4(sdrammc->type)) + return; + + //------------------------------------------------------------------- + // CAS Latency (Table-15) + //------------------------------------------------------------------- + switch (ac->t_cl) { + case 9: + mr0_cas = 0x00; //5'b00000; + break; + case 10: + mr0_cas = 0x01; //5'b00001; + break; + case 11: + mr0_cas = 0x02; //5'b00010; + break; + case 12: + mr0_cas = 0x03; //5'b00011; + break; + case 13: + mr0_cas = 0x04; //5'b00100; + break; + case 14: + mr0_cas = 0x05; //5'b00101; + break; + case 15: + mr0_cas = 0x06; //5'b00110; + break; + case 16: + mr0_cas = 0x07; //5'b00111; + break; + case 18: + mr0_cas = 0x08; //5'b01000; + break; + case 20: + mr0_cas = 0x09; //5'b01001; + break; + case 22: + mr0_cas = 0x0a; //5'b01010; + break; + case 24: + mr0_cas = 0x0b; //5'b01011; + break; + case 23: + mr0_cas = 0x0c; //5'b01100; + break; + case 17: + mr0_cas = 0x0d; //5'b01101; + break; + case 19: + mr0_cas = 0x0e; //5'b01110; + break; + case 21: + mr0_cas = 0x0f; //5'b01111; + break; + case 25: + mr0_cas = 0x10; //5'b10000; + break; + case 26: + mr0_cas = 0x11; //5'b10001; + break; + case 27: + mr0_cas = 0x12; //5'b10010; + break; + case 28: + mr0_cas = 0x13; //5'b10011; + break; + case 30: + mr0_cas = 0x15; //5'b10101; + break; + case 32: + mr0_cas = 0x17; //5'b10111; + break; + } + + //------------------------------------------------------------------- + // WR and RTP (Table-14) + //------------------------------------------------------------------- + switch (ac->t_rtp) { + case 5: + mr0_rtp = 0x0; //4'b0000; + break; + case 6: + mr0_rtp = 0x1; //4'b0001; + break; + case 7: + mr0_rtp = 0x2; //4'b0010; + break; + case 8: + mr0_rtp = 0x3; //4'b0011; + break; + case 9: + mr0_rtp = 0x4; //4'b0100; + break; + case 10: + mr0_rtp = 0x5; //4'b0101; + break; + case 12: + mr0_rtp = 0x6; //4'b0110; + break; + case 11: + mr0_rtp = 0x7; //4'b0111; + break; + case 13: + mr0_rtp = 0x8; //4'b1000; + break; + } + + //------------------------------------------------------------------- + // CAS Write Latency (Table-21) + //------------------------------------------------------------------- + switch (ac->t_cwl) { + case 9: + mr2_cwl = 0x0; // 3'b000; // 1600 + break; + case 10: + mr2_cwl = 0x1; // 3'b001; // 1866 + break; + case 11: + mr2_cwl = 0x2; // 3'b010; // 2133 + break; + case 12: + mr2_cwl = 0x3; // 3'b011; // 2400 + break; + case 14: + mr2_cwl = 0x4; // 3'b100; // 2666 + break; + case 16: + mr2_cwl = 0x5; // 3'b101; // 2933/3200 + break; + case 18: + mr2_cwl = 0x6; // 3'b110; + break; + case 20: + mr2_cwl = 0x7; // 3'b111; + break; + } + + //------------------------------------------------------------------- + // tCCD_L and tDLLK + //------------------------------------------------------------------- + switch (ac->t_ccd_l) { + case 4: + mr6_tccd_l = 0x0; //3'b000; // rate <= 1333 + break; + case 5: + mr6_tccd_l = 0x1; //3'b001; // 1333 < rate <= 1866 + break; + case 6: + mr6_tccd_l = 0x2; //3'b010; // 1866 < rate <= 2400 + break; + case 7: + mr6_tccd_l = 0x3; //3'b011; // 2400 < rate <= 2666 + break; + case 8: + mr6_tccd_l = 0x4; //3'b100; // 2666 < rate <= 3200 + break; + } + + /* + * mr0_val = + * mr0_rtp[3], // 13 + * mr0_cas[4], // 12 + * mr0_rtp[2:0], // 13,11-9: WR and RTP + * 1'b0, // 8: DLL reset + * 1'b0, // 7: TM + * mr0_cas[3:1], // 6-4,2: CAS latency + * 1'b0, // 3: sequential + * mr0_cas[0], + * 2'b00 // 1-0: burst length + */ + mr0_val = ((mr0_cas & 0x1) << 2) | + (((mr0_cas >> 1) & 0x7) << 4) | + (((mr0_cas >> 4) & 0x1) << 12) | + ((mr0_rtp & 0x7) << 9) | + (((mr0_rtp >> 3) & 0x1) << 13); + + /* + * 3'b2 //[10:8]: rtt_nom, 000:disable,001:rzq/4,010:rzq/2,011:rzq/6,100:rzq/1,101:rzq/5,110:rzq/3,111:rzq/7 + * 1'b0 //[7]: write leveling enable + * 2'b0 //[6:5]: reserved + * 2'b0 //[4:3]: additive latency + * 2'b0 //[2:1]: output driver impedance + * 1'b1 //[0]: enable dll + */ + mr1_val = 0x201; + + /* + * [10:9]: rtt_wr, 00:dynamic odt off, 01:rzq/2, 10:rzq/1, 11: hi-z + * [8]: 0 + */ + mr2_val = ((mr2_cwl & 0x7) << 3) | 0x200; + + mr3_val = 0; + + mr4_val = 0; + + /* + * mr5_val = { + * 1'b0, // 13: RFU + * 1'b0, // 12: read DBI + * 1'b0, // 11: write DBI + * 1'b1, // 10: Data mask + * 1'b0, // 9: C/A parity persistent error + * 3'b000, // 8-6: RTT_PARK (disable) + * 1'b1, // 5: ODT input buffer during power down mode + * 1'b0, // 4: C/A parity status + * 1'b0, // 3: CRC error clear + * 3'b0 // 2-0: C/A parity latency mode + * }; + */ + mr5_val = 0x420; + + /* + * mr6_val = { + * 1'b0, // 13, 9-8: RFU + * mr6_tccd_l[2:0], // 12-10: tCCD_L + * 2'b0, // 13, 9-8: RFU + * 1'b0, // 7: VrefDQ training enable + * 1'b0, // 6: VrefDQ training range + * 6'b0 // 5-0: VrefDQ training value + * }; + */ + mr6_val = ((mr6_tccd_l & 0x7) << 10); + + writel((mr1_val << 16) + mr0_val, ®s->mr01); + writel((mr3_val << 16) + mr2_val, ®s->mr23); + writel((mr5_val << 16) + mr4_val, ®s->mr45); + writel(mr6_val, ®s->mr67); + + /* Power-up initialization sequence */ + sdrammc_mr_send(sdrammc, MR_ADDR(3), 0); + sdrammc_mr_send(sdrammc, MR_ADDR(6), 0); + sdrammc_mr_send(sdrammc, MR_ADDR(5), 0); + sdrammc_mr_send(sdrammc, MR_ADDR(4), 0); + sdrammc_mr_send(sdrammc, MR_ADDR(2), 0); + sdrammc_mr_send(sdrammc, MR_ADDR(1), 0); + sdrammc_mr_send(sdrammc, MR_ADDR(0), 0); +} + +static void sdrammc_exit_self_refresh(struct sdrammc *sdrammc) +{ + struct sdrammc_regs *regs = sdrammc->regs; + + /* exit self-refresh after phy init */ + setbits_le32(®s->mctl, DRAMC_MCTL_SELF_REF_START); + + /* query if self-ref done */ + while (!(readl(®s->intr_status) & DRAMC_IRQSTA_REF_DONE)) + ; + + /* clear status */ + writel(DRAMC_IRQSTA_REF_DONE, ®s->intr_clear); + udelay(1); +} + +/* user-customized functions for the vendor PHY init code */ +#define DWC_PHY_IMEM_OFST 0x50000 +#define DWC_PHY_DMEM_OFST 0x58000 +#define DWC_PHY_MB_START_STREAM_MSG 0x8 +#define DWC_PHY_MB_TRAIN_SUCCESS 0x7 +#define DWC_PHY_MB_TRAIN_FAIL 0xff + +#define dwc_ddrphy_apb_wr(addr, data) \ + writew((data), sdrammc->phy + ((addr) << 1)) + +#define dwc_ddrphy_apb_rd(addr) \ + readw(sdrammc->phy + ((addr) << 1)) + +#define dwc_ddrphy_apb_wr_32b(addr, data) \ + writel((data), sdrammc->phy + ((addr) << 1)) + +#define dwc_ddrphy_apb_rd_32b(addr) \ + readl(sdrammc->phy + ((addr) << 1)) + +void dwc_get_mailbox(struct sdrammc *sdrammc, const int mode, u32 *mbox) +{ + u32 val; + + /* 1. Poll the UctWriteProtShadow, looking for a 0 */ + while (dwc_ddrphy_apb_rd(0xd0004) & BIT(0)) + ; + + /* 2. When a 0 is seen, read the UctWriteOnlyShadow register to get the major message number. */ + *mbox = dwc_ddrphy_apb_rd(0xd0032) & 0xffff; + + /* 3. If reading a streaming or SMBus message, also read the UctDatWriteOnlyShadow register. */ + if (mode) { + val = (dwc_ddrphy_apb_rd(0xd0034)) & 0xffff; + *mbox |= (val << 16); + } + + /* 4. Write the DctWriteProt to 0 to acknowledge the reception of the message */ + dwc_ddrphy_apb_wr(0xd0031, 0); + + /* 5. Poll the UctWriteProtShadow, looking for a 1 */ + while (!(dwc_ddrphy_apb_rd(0xd0004) & BIT(0))) + ; + + /* 6. When a 1 is seen, write the DctWriteProt to 1 to complete the protocol */ + dwc_ddrphy_apb_wr(0xd0031, 1); +} + +uint32_t dwc_readMsgBlock(struct sdrammc *sdrammc, const u32 addr_half) +{ + u32 data_word; + + data_word = dwc_ddrphy_apb_rd_32b((addr_half >> 1) << 1); + + if (addr_half & 0x1) + data_word = data_word >> 16; + else + data_word &= 0xffff; + + return data_word; +} + +int dwc_ddrphy_phyinit_userCustom_H_readMsgBlock(struct sdrammc *sdrammc, int train2D) +{ + u32 msg; + + if (IS_DDR4(sdrammc->type)) { + /* DWC_PHY_DDR4_MB_RESULT */ + msg = dwc_readMsgBlock(sdrammc, 0x5800a); + if (msg & 0xff) + debug("%s: Training Failure index (0x%x)\n", __func__, msg); + else + debug("%s: %dD Training Passed\n", __func__, train2D ? 2 : 1); + } else { + /* DWC_PHY_DDR5_MB_RESULT */ + msg = dwc_readMsgBlock(sdrammc, 0x58007); + if (msg & 0xff00) + debug("%s: Training Failure index (0x%x)\n", __func__, msg); + else + debug("%s: DDR5 1D/2D Training Passed\n", __func__); + + /* DWC_PHY_DDR5_MB_RESULT_ADR */ + msg = dwc_readMsgBlock(sdrammc, 0x5800a); + debug("%s: Result Address Offset (0x%x)\n", __func__, msg); + } + + return 0; +} + +void dwc_ddrphy_phyinit_userCustom_A_bringupPower(void) +{ + /* do nothing */ +} + +void dwc_ddrphy_phyinit_userCustom_B_startClockResetPhy(struct sdrammc *sdrammc) +{ + struct sdrammc_regs *regs = sdrammc->regs; + + /* + * 1. Drive PwrOkIn to 0. Note: Reset, DfiClk, and APBCLK can be X. + * 2. Start DfiClk and APBCLK + * 3. Drive Reset to 1 and PRESETn_APB to 0. + * Note: The combination of PwrOkIn=0 and Reset=1 signals a cold reset to the PHY. + */ + writel(DRAMC_MCTL_PHY_RESET, ®s->mctl); + udelay(2); + + /* + * 5. Drive PwrOkIn to 1. Once the PwrOkIn is asserted (and Reset is still asserted), + * DfiClk synchronously switches to any legal input frequency. + */ + writel(DRAMC_MCTL_PHY_RESET | DRAMC_MCTL_PHY_POWER_ON, ®s->mctl); + udelay(2); + + /* + * 7. Drive Reset to 0. Note: All DFI and APB inputs must be driven at valid reset states + * before the deassertion of Reset. + */ + writel(DRAMC_MCTL_PHY_POWER_ON, ®s->mctl); + udelay(2); + + /* + * 9. Drive PRESETn_APB to 1 to de-assert reset on the ABP bus. + * 10. The PHY is now in the reset state and is ready to accept APB transactions. + */ +} + +void dwc_ddrphy_phyinit_userCustom_overrideUserInput(void) +{ + /* do nothing */ +} + +void dwc_ddrphy_phyinit_userCustom_customPostTrain(void) +{ + /* do nothing */ +} + +void dwc_ddrphy_phyinit_userCustom_E_setDfiClk(struct sdrammc *sdrammc) +{ + dwc_ddrphy_apb_wr(0xd0031, 1); /* DWC_DCTWRITEPROT */ + dwc_ddrphy_apb_wr(0xd0033, 1); /* DWC_UCTWRITEPROT */ +} + +void dwc_ddrphy_phyinit_userCustom_G_waitFwDone(struct sdrammc *sdrammc) +{ + u32 mbox, msg = 0; + + while (msg != DWC_PHY_MB_TRAIN_SUCCESS && msg != DWC_PHY_MB_TRAIN_FAIL) { + dwc_get_mailbox(sdrammc, 0, &mbox); + msg = mbox & 0xffff; + } +} + +void dwc_ddrphy_phyinit_userCustom_J_enterMissionMode(struct sdrammc *sdrammc) +{ + struct sdrammc_regs *regs = sdrammc->regs; + u32 val; + + /* + * 1. Set the PHY input clocks to the desired frequency. + * 2. Initialize the PHY to mission mode by performing DFI Initialization. + * Please see the DFI specification for more information. See the DFI frequency bus encoding in section <XXX>. + * Note: The PHY training firmware initializes the DRAM state. if skip + * training is used, the DRAM state is not initialized. + */ + + writel(0xffffffff, (void *)®s->intr_mask); + + writel(0x0, (void *)®s->dcfg); + + if (!IS_DDR4(sdrammc->type)) { + dwc_ddrphy_apb_wr(0xd0000, 0); /* DWC_DDRPHYA_APBONLY0_MicroContMuxSel */ + dwc_ddrphy_apb_wr(0x20240, 0x3900); /* DWC_DDRPHYA_MASTER0_base0_D5ACSMPtr0lat0 */ + dwc_ddrphy_apb_wr(0x900da, 8); /* DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s0 */ + dwc_ddrphy_apb_wr(0xd0000, 1); /* DWC_DDRPHYA_APBONLY0_MicroContMuxSel */ + } + + /* phy init start */ + val = readl((void *)®s->mctl); + val = val | DRAMC_MCTL_PHY_INIT_START; + writel(val, (void *)®s->mctl); + + /* wait phy complete */ + while (1) { + val = readl(®s->intr_status) & DRAMC_IRQSTA_PHY_INIT_DONE; + if (val == DRAMC_IRQSTA_PHY_INIT_DONE) + break; + } + + writel(0xffff, (void *)®s->intr_clear); + + while (readl((void *)®s->intr_status)) + ; + + if (!IS_DDR4(sdrammc->type)) { + dwc_ddrphy_apb_wr(0xd0000, 0); /* DWC_DDRPHYA_APBONLY0_MicroContMuxSel */ + dwc_ddrphy_apb_wr(0x20240, 0x4300); /* DWC_DDRPHYA_MASTER0_base0_D5ACSMPtr0lat0 */ + dwc_ddrphy_apb_wr(0x900da, 0); /* DWC_DDRPHYA_INITENG0_base0_SequenceReg0b59s0 */ + dwc_ddrphy_apb_wr(0xd0000, 1); /* DWC_DDRPHYA_APBONLY0_MicroContMuxSel */ + } +} + +int dwc_ddrphy_phyinit_userCustom_D_loadIMEM(struct sdrammc *sdrammc, const int train2D) +{ + u32 imem_ofst, imem_size; + u32 pb_type; + + if (IS_DDR4(sdrammc->type)) + pb_type = (train2D) ? PBT_DDR4_2D_PMU_TRAIN_IMEM : PBT_DDR4_PMU_TRAIN_IMEM; + else + pb_type = PBT_DDR5_PMU_TRAIN_IMEM; + + fmc_hdr_get_prebuilt(pb_type, &imem_ofst, &imem_size); + + memcpy(sdrammc->phy + (DWC_PHY_IMEM_OFST << 1), + (void *)(0x20000000 + imem_ofst), imem_size); + + return 0; +} + +int dwc_ddrphy_phyinit_userCustom_F_loadDMEM(struct sdrammc *sdrammc, + const int pState, const int train2D) +{ + u32 dmem_ofst, dmem_size; + u32 pb_type; + + if (IS_DDR4(sdrammc->type)) + pb_type = (train2D) ? PBT_DDR4_2D_PMU_TRAIN_DMEM : PBT_DDR4_PMU_TRAIN_DMEM; + else + pb_type = PBT_DDR5_PMU_TRAIN_DMEM; + + fmc_hdr_get_prebuilt(pb_type, &dmem_ofst, &dmem_size); + + memcpy(sdrammc->phy + (DWC_PHY_DMEM_OFST << 1), + (void *)(0x20000000 + dmem_ofst), dmem_size); + + return 0; +} + +static void sdrammc_dwc_phy_init(struct sdrammc *sdrammc) +{ + /* enable ddr phy free-run clock */ + writel(SCU0_CLKGATE1_CLR_DDRPHY, sdrammc->scu0 + SCU0_CLKGATE1_CLR); + + /* include the vendor-provided PHY init code */ + if (IS_DDR4(sdrammc->type)) { + #include "dwc_ddrphy_phyinit_ddr4-3200-nodimm-train2D.c" + } else { + #include "dwc_ddrphy_phyinit_ddr5-3200-nodimm-train2D.c" + } +} + +static void sdrammc_config_ac_timing(struct sdrammc *sdrammc) +{ + const struct sdrammc_ac_timing *ac = sdrammc->ac; + struct sdrammc_regs *regs = sdrammc->regs; + u32 actime; + +#define ACTIME1(ccd, rrd_l, rrd, mrd) \ + (((ccd) << 24) | \ + (((rrd_l) >> 1) << 16) | \ + (((rrd) >> 1) << 8) | \ + ((mrd) >> 1)) + +#define ACTIME2(faw, rp, ras, rcd) \ + ((((faw) >> 1) << 24) | \ + (((rp) >> 1) << 16) | \ + (((ras) >> 1) << 8) | \ + ((rcd) >> 1)) + +#define ACTIME3(wtr, rtw, wtp, rtp) \ + ((((wtr) >> 1) << 24) | \ + (((rtw) >> 1) << 16) | \ + (((wtp) >> 1) << 8) | \ + ((rtp) >> 1)) + +#define ACTIME4(wtr_a, wtr_l) \ + ((((wtr_a) >> 1) << 8) | \ + ((wtr_l) >> 1)) + +#define ACTIME5(refsbrd, rfcsb, rfc) \ + ((((refsbrd) >> 1) << 20) | \ + (((rfcsb) >> 1) << 10) | \ + ((rfc) >> 1)) + +#define ACTIME6(cshsr, pd, xp, cksre) \ + ((((cshsr) >> 1) << 24) | \ + (((pd) >> 1) << 16) | \ + (((xp) >> 1) << 8) | \ + ((cksre) >> 1)) + +#define ACTIME7(zqcs, dllk) \ + ((((zqcs) >> 1) << 10) | \ + ((dllk) >> 1)) + + actime = ACTIME1(ac->t_ccd_l, ac->t_rrd_l, ac->t_rrd, ac->t_mrd); + writel(actime, ®s->actime1); + + actime = ACTIME2(ac->t_faw, ac->t_rp, ac->t_ras, ac->t_rcd); + writel(actime, ®s->actime2); + + actime = ACTIME3(ac->t_cwl + ac->t_bl / 2 + ac->t_wtr, + ac->t_cl - ac->t_cwl + (ac->t_bl / 2) + 2, + ac->t_cwl + ac->t_bl / 2 + ac->t_wtp, + ac->t_rtp); + writel(actime, ®s->actime3); + + actime = ACTIME4(ac->t_cwl + ac->t_bl / 2 + ac->t_wtr_a, + ac->t_cwl + ac->t_bl / 2 + ac->t_wtr_l); + writel(actime, ®s->actime4); + + actime = ACTIME5(ac->t_refsbrd, ac->t_rfcsb, ac->t_rfc); + writel(actime, ®s->actime5); + + actime = ACTIME6(ac->t_cshsr, ac->t_pd, ac->t_xp, ac->t_cksre); + writel(actime, ®s->actime6); + + actime = ACTIME7(ac->t_zq, ac->t_dllk); + writel(actime, ®s->actime7); +} + +static void sdrammc_config_registers(struct sdrammc *sdrammc) +{ + const struct sdrammc_ac_timing *ac = sdrammc->ac; + struct sdrammc_regs *regs = sdrammc->regs; + u32 reg; + + u32 dram_size = 5; + u32 t_phy_wrdata; + u32 t_phy_wrlat; + u32 t_phy_rddata_en; + u32 t_phy_odtlat; + u32 t_phy_odtext; + + if (IS_DDR4(sdrammc->type)) { + t_phy_wrlat = ac->t_cwl - 5 - 4; + t_phy_rddata_en = ac->t_cl - 5 - 4; + t_phy_wrdata = 2; + t_phy_odtlat = ac->t_cwl - 5 - 4; + t_phy_odtext = 0; + } else { + t_phy_wrlat = ac->t_cwl - 13 - 3; + t_phy_rddata_en = ac->t_cl - 13 - 3; + t_phy_wrdata = 6; + t_phy_odtlat = 0; + t_phy_odtext = 0; + } + + writel(0x20 + (dram_size << 2) + !!!IS_DDR4(sdrammc->type), ®s->mcfg); + + reg = (t_phy_odtext << 20) + (t_phy_odtlat << 16) + + (t_phy_rddata_en << 10) + (t_phy_wrdata << 6) + + t_phy_wrlat; + writel(reg, ®s->dfi_timing); + writel(0, ®s->dctl); + + writel(0x40b48200, ®s->refctl); + + writel(0x42aa1800, ®s->zqctl); + + writel(0, ®s->arbctl); + + if (!IS_DDR4(sdrammc->type)) + writel(0, ®s->refmng_ctl); + + writel(0xffffffff, ®s->intr_mask); +} + +static void sdrammc_init(struct sdrammc *sdrammc) +{ + u32 reg; + + reg = readl(sdrammc->scu1 + SCU1_HWSTRAP1); + + if (reg & SCU1_HWSTRAP1_DDR4) { + if (IS_ENABLED(CONFIG_ASPEED_DDR_1600)) + sdrammc->type = DDR4_1600; + else if (IS_ENABLED(CONFIG_ASPEED_DDR_2400)) + sdrammc->type = DDR4_2400; + else if (IS_ENABLED(CONFIG_ASPEED_DDR_3200)) + sdrammc->type = DDR4_3200; + } else { + sdrammc->type = DDR5_3200; + } + + sdrammc->ac = &ac_table[sdrammc->type]; + + sdrammc_config_ac_timing(sdrammc); + sdrammc_config_registers(sdrammc); +} + +static int ast2700_sdrammc_probe(struct udevice *dev) +{ + struct sdrammc *sdrammc = dev_get_priv(dev); + struct sdrammc_regs *regs = sdrammc->regs; + u32 bistcfg; + u32 reg; + int rc; + + /* skip DRAM init if already done */ + reg = readl(sdrammc->scu0 + SCU0_VGA0_SCRATCH); + if (reg & SCU0_VGA0_SCRATCH_DRAM_INIT) + goto out; + + /* unlock DRAM controller */ + writel(DRAMC_UNLK_KEY, ®s->prot_key); + + sdrammc_init(sdrammc); + + sdrammc_dwc_phy_init(sdrammc); + + sdrammc_exit_self_refresh(sdrammc); + + sdrammc_config_mrs(sdrammc); + + sdrammc_enable_refresh(sdrammc); + + bistcfg = FIELD_PREP(DRAMC_BISTCFG_PMODE, BIST_PMODE_CRC) | + FIELD_PREP(DRAMC_BISTCFG_BMODE, BIST_BMODE_RW_SWITCH) | + DRAMC_BISTCFG_ENABLE; + + rc = sdrammc_bist(sdrammc, 0, 0x10000, bistcfg, 0x200000); + if (rc) { + debug("bist test failed, type=%d\n", sdrammc->type); + return rc; + } + + /* set DRAM init flag */ + reg |= SCU0_VGA0_SCRATCH_DRAM_INIT; + writel(reg, sdrammc->scu0 + SCU0_VGA0_SCRATCH); + +out: + sdrammc_calc_size(sdrammc); + + return 0; +} + +static int ast2700_sdrammc_of_to_plat(struct udevice *dev) +{ + struct sdrammc *sdrammc = dev_get_priv(dev); + u32 phandle; + ofnode node; + int rc; + + sdrammc->regs = (struct sdrammc_regs *)devfdt_get_addr_index(dev, 0); + if (sdrammc->regs == (void *)FDT_ADDR_T_NONE) { + debug("cannot map DRAM register\n"); + return -ENODEV; + } + + sdrammc->phy = (void *)devfdt_get_addr_index(dev, 1); + if (sdrammc->phy == (void *)FDT_ADDR_T_NONE) { + debug("cannot map PHY memory\n"); + return -ENODEV; + } + + rc = ofnode_read_u32(dev_ofnode(dev), "aspeed,scu0", &phandle); + if (rc) { + debug("cannot find SCU0 handle\n"); + return -ENODEV; + } + + node = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(node)) { + debug("cannot get SCU0 node\n"); + return -ENODEV; + } + + sdrammc->scu0 = (void *)ofnode_get_addr(node); + if (sdrammc->scu0 == (void *)FDT_ADDR_T_NONE) { + debug("cannot map SCU0 register\n"); + return -ENODEV; + } + + rc = ofnode_read_u32(dev_ofnode(dev), "aspeed,scu1", &phandle); + if (rc) { + debug("cannot find SCU1 handle\n"); + return -ENODEV; + } + + node = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(node)) { + debug("cannot get SCU1 node\n"); + return -ENODEV; + } + + sdrammc->scu1 = (void *)ofnode_get_addr(node); + if (sdrammc->scu1 == (void *)FDT_ADDR_T_NONE) { + debug("cannot map SCU1 register\n"); + return -ENODEV; + } + + return 0; +} + +static int ast2700_sdrammc_get_info(struct udevice *dev, struct ram_info *info) +{ + struct sdrammc *sdrammc = dev_get_priv(dev); + + *info = sdrammc->info; + + return 0; +} + +static struct ram_ops ast2700_sdrammc_ops = { + .get_info = ast2700_sdrammc_get_info, +}; + +static const struct udevice_id ast2700_sdrammc_ids[] = { + { .compatible = "aspeed,ast2700-sdrammc" }, + { } +}; + +U_BOOT_DRIVER(sdrammc_ast2700) = { + .name = "aspeed_ast2700_sdrammc", + .id = UCLASS_RAM, + .of_match = ast2700_sdrammc_ids, + .ops = &ast2700_sdrammc_ops, + .of_to_plat = ast2700_sdrammc_of_to_plat, + .probe = ast2700_sdrammc_probe, + .priv_auto = sizeof(struct sdrammc), +};
Enable the driver support for the DRAM and timer devices.
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- configs/ibex-ast2700_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/ibex-ast2700_defconfig b/configs/ibex-ast2700_defconfig index 22629b90489..855615cc1ea 100644 --- a/configs/ibex-ast2700_defconfig +++ b/configs/ibex-ast2700_defconfig @@ -83,9 +83,11 @@ CONFIG_MMC_SDHCI=y # CONFIG_POWER is not set CONFIG_RAM=y CONFIG_SPL_RAM=y +CONFIG_ASPEED_RAM=y # CONFIG_RAM_SIFIVE is not set CONFIG_SYS_NS16550=y CONFIG_SYS_NS16550_MEM32=y +CONFIG_AST_IBEX_TIMER=y CONFIG_VIDEO=y # CONFIG_VIDEO_LOGO is not set # CONFIG_RSA is not set
Chia-Wei Wang
