Re: [U-Boot] [PATCH 1/1] efi_loader: add a README.iscsi describing booting via iSCSI
From: Heinrich Schuchardt xypron.debian@gmx.de To: Duncan Hare dh@synoia.com; Alexander Graf agraf@suse.de Subject: Re: [U-Boot] [PATCH 1/1] efi_loader: add a README.iscsi describing booting via iSCSI
On 01/25/2018 08:39 PM, Duncan Hare wrote:
----- Forwarded Message ----- From: Alexander Graf agraf@suse.de To: Heinrich Schuchardt xypron.glpk@gmx.de
The appended README explains how U-Boot and iPXE can be used to boot a diskless system from an iSCSI SAN.
We are implementing a limited TCP and a wget (http 1.0) app.>> It is almost ready for an test release. Selective Acknowledgment (SACK) is under test as a final piece of the TCP stack.
In which git can I find the code?
We have noticed that omitting the http 1.0 declaration in downloading the kernel from an nginx web server that we remove the overhead of an http header completely.
RFC 1945 - Hypertext Transfer Protocol -- HTTP/1.0
You should not program to please another accommodating software but according to a standard.
I agree. The comment was a FYI.
The key to TCP performance is supporting multiple packets in flight.
And we do. That's set in include/net.h in the buffer definitions.With single packet-at-a time one might as well stick with udp. I've worked on network communication protocols since 1973.c programming, not so much. git, I'm a newb.
HeinrichIt is not yet pushed to git.I need to fix the bugs in SACK before taking that step. I had hoped this week but I was delayed by flu. It adheres to http 1.0. It is a minimal implementation. It is relatively fast. It drives a Raspberry Pi at 10 M bits/sec, the limitation being the raspberry pi processor speed.
I can send you a tarball, together with the changes to tftp.c for testing that a downloaded image is correct.
Regards Duncan Hare
714 931 7952
Duncan Hare
