[PATCH] ARM: dts: stm32: Do not set eth1addr if KS8851 has EEPROM
In case the KS8851 has external EEPROM attached to it, do not set eth1addr at all. The network stack will read the MAC out of the KS8851 and set eth1addr accordingly.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@st.com Cc: Patrick Delaunay patrick.delaunay@st.com --- board/dhelectronics/dh_stm32mp1/board.c | 40 ++++++++++++++++++++++--- 1 file changed, 36 insertions(+), 4 deletions(-)
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index c9abe3cc6d..f42d395098 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -81,6 +81,11 @@ */ DECLARE_GLOBAL_DATA_PTR;
+#define KS_CCR 0x08 +#define KS_CCR_EEPROM BIT(9) +#define KS_BE0 BIT(12) +#define KS_BE1 BIT(13) + int setup_mac_address(void) { unsigned char enetaddr[6]; @@ -97,12 +102,39 @@ int setup_mac_address(void) if (off < 0) { /* ethernet1 is not present in the system */ skip_eth1 = true; - } else { - ret = eth_env_get_enetaddr("eth1addr", enetaddr); - if (ret) /* eth1addr is already set */ - skip_eth1 = true; + goto out_set_ethaddr; + } + + ret = eth_env_get_enetaddr("eth1addr", enetaddr); + if (ret) { + /* eth1addr is already set */ + skip_eth1 = true; + goto out_set_ethaddr; + } + + ret = fdt_node_check_compatible(gd->fdt_blob, off, "micrel,ks8851-mll"); + if (ret) + goto out_set_ethaddr; + + /* + * KS8851 with EEPROM may use custom MAC from EEPROM, read + * out the KS8851 CCR register to determine whether EEPROM + * is present. If EEPROM is present, it must contain valid + * MAC address. + */ + u32 reg, ccr; + reg = fdt_get_base_address(gd->fdt_blob, off); + if (!reg) + goto out_set_ethaddr; + + writew(KS_BE0 | KS_BE1 | KS_CCR, reg + 2); + ccr = readw(reg); + if (ccr & KS_CCR_EEPROM) { + skip_eth1 = true; + goto out_set_ethaddr; }
+out_set_ethaddr: if (skip_eth0 && skip_eth1) return 0;
Hi Marek
- } else {
skip_eth1 = true;
- if (ret) {
skip_eth1 = true;
- ret = fdt_node_check_compatible(gd->fdt_blob, off, "micrel,ks8851-mll");
- if (ret)
* MAC address.
- u32 reg, ccr;
- reg = fdt_get_base_address(gd->fdt_blob, off);
- if (!reg)
- writew(KS_BE0 | KS_BE1 | KS_CCR, reg + 2);
- ccr = readw(reg);
- if (ccr & KS_CCR_EEPROM) {
skip_eth1 = true;
}goto out_set_ethaddr;
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Patrice
Hi Marek,
From: Marek Vasut marex@denx.de Sent: jeudi 8 octobre 2020 15:15
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
Thanks
Patrick
Hi Marek,
Applied to u-boot-stm/master, thanks!
Regards
Patrick
Patrice CHOTARD
Patrick DELAUNAY
