[PATCH v4 0/6] Introduce the sysinfo command
The command can be used to show various information that can be used to identify the running system.
Currently supported subcommands are: * model: A string representing the model * id: The id of the board * revision: The revision of this board.
Changes since v3: - Fix documentation typo. Changes since v2: - Fix code style. - Use printf() instead of debug(). - Clarify sysinfo new ids types (int). - Add a test for sysinfo command. - Add documentation for sysinfo command. Changes since v1: - Removed shell function to select linux device tree. This will be distributions job. - Break revision in rev_major and rev_minor in the sysinfo driver.
Detlev Casanova (6): sysinfo: Add IDs for board id and revision cmd: Add a sysinfo command sysinfo: Add a test sysinfo: Add documentation sysinfo: rcar3: Use int instead of char for revision sysinfo: rcar3: Implement BOARD_ID and BOARD_REV_*
cmd/Kconfig | 6 ++ cmd/Makefile | 1 + cmd/sysinfo.c | 133 +++++++++++++++++++++++++++++++++++ configs/sandbox_defconfig | 1 + doc/usage/cmd/sysinfo.rst | 56 +++++++++++++++ drivers/sysinfo/rcar3.c | 141 ++++++++++++++++++++++++++------------ drivers/sysinfo/sandbox.c | 17 +++++ include/sysinfo.h | 5 ++ test/cmd/Makefile | 1 + test/cmd/test_sysinfo.c | 51 ++++++++++++++ 10 files changed, 370 insertions(+), 42 deletions(-) create mode 100644 cmd/sysinfo.c create mode 100644 doc/usage/cmd/sysinfo.rst create mode 100644 test/cmd/test_sysinfo.c
These IDs will be used by the sysinfo command. The new IDs are: * SYSINFO_ID_BOARD_ID: The board ID as an integer * SYSINFO_ID_BOARD_REV_MAJOR: The board major revision as int * SYSINFO_ID_BOARD_REV_MINOR: The board minor revision as int
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- include/sysinfo.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/sysinfo.h b/include/sysinfo.h index b140d742e93..13815600ae6 100644 --- a/include/sysinfo.h +++ b/include/sysinfo.h @@ -47,6 +47,11 @@ enum sysinfo_id { /* For show_board_info() */ SYSINFO_ID_BOARD_MODEL,
+ /* For sysinfo command (all int) */ + SYSINFO_ID_BOARD_ID, + SYSINFO_ID_BOARD_REV_MAJOR, + SYSINFO_ID_BOARD_REV_MINOR, + /* First value available for downstream/board used */ SYSINFO_ID_USER = 0x1000, };
The command is able to show different information for the running system: * Model name * Board ID * Revision
This command can be used by boot shell scripts to select configurations depending on the specific running system.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- cmd/Kconfig | 6 +++ cmd/Makefile | 1 + cmd/sysinfo.c | 133 ++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 140 insertions(+) create mode 100644 cmd/sysinfo.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index ecfd5752377..796eedba194 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -218,6 +218,12 @@ config CMD_SBI help Display information about the SBI implementation.
+config CMD_SYSINFO + bool "sysinfo" + depends on SYSINFO + help + Display information about the system. + endmenu
menu "Boot commands" diff --git a/cmd/Makefile b/cmd/Makefile index 9f8c0b058be..87a196b4a03 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -166,6 +166,7 @@ obj-$(CONFIG_CMD_SPI) += spi.o obj-$(CONFIG_CMD_STRINGS) += strings.o obj-$(CONFIG_CMD_SMC) += smccc.o obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o +obj-$(CONFIG_CMD_SYSINFO) += sysinfo.o obj-$(CONFIG_CMD_STACKPROTECTOR_TEST) += stackprot_test.o obj-$(CONFIG_CMD_TEMPERATURE) += temperature.o obj-$(CONFIG_CMD_TERMINAL) += terminal.o diff --git a/cmd/sysinfo.c b/cmd/sysinfo.c new file mode 100644 index 00000000000..46369ff9ac7 --- /dev/null +++ b/cmd/sysinfo.c @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 + * Detlev Casanova detlev.casanova@collabora.com + */ + +#include <command.h> +#include <env.h> +#include <sysinfo.h> +#include <exports.h> + +static int get_sysinfo(struct udevice **devp) +{ + int ret = sysinfo_get(devp); + + if (ret) { + printf("Cannot get sysinfo: %d\n", ret); + return ret; + } + + ret = sysinfo_detect(*devp); + if (ret) { + printf("Cannot detect sysinfo: %d\n", ret); + return ret; + } + + return 0; +} + +static int do_sysinfo_model(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + char model[64]; + int ret = get_sysinfo(&dev); + + if (ret) + return CMD_RET_FAILURE; + + ret = sysinfo_get_str(dev, + SYSINFO_ID_BOARD_MODEL, + sizeof(model), + model); + if (ret) { + printf("Cannot get sysinfo str: %d\n", ret); + return CMD_RET_FAILURE; + } + + if (argc == 2) + ret = env_set(argv[1], model); + else + printf("%s\n", model); + + if (ret) + return CMD_RET_FAILURE; + else + return CMD_RET_SUCCESS; +} + +static int do_sysinfo_id(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + u32 board_id; + int ret = get_sysinfo(&dev); + + if (ret) + return CMD_RET_FAILURE; + + ret = sysinfo_get_int(dev, SYSINFO_ID_BOARD_ID, &board_id); + if (ret) { + printf("Cannot get sysinfo int: %d\n", ret); + return CMD_RET_FAILURE; + } + + if (argc == 2) + ret = env_set_hex(argv[1], board_id); + else + printf("0x%02x\n", board_id); + + if (ret) + return CMD_RET_FAILURE; + else + return CMD_RET_SUCCESS; +} + +static int do_sysinfo_revision(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + int rev_major; + int rev_minor; + char rev[64]; + int ret = get_sysinfo(&dev); + + if (ret) + return CMD_RET_FAILURE; + + ret = sysinfo_get_int(dev, SYSINFO_ID_BOARD_REV_MAJOR, &rev_major); + if (ret) { + printf("Cannot get sysinfo int: %d\n", ret); + return CMD_RET_FAILURE; + } + + ret = sysinfo_get_int(dev, SYSINFO_ID_BOARD_REV_MINOR, &rev_minor); + if (ret) { + printf("Cannot get sysinfo int: %d\n", ret); + return CMD_RET_FAILURE; + } + + snprintf(rev, sizeof(rev), "%d.%d", rev_major, rev_minor); + + if (argc == 2) + ret = env_set(argv[1], rev); + else + printf("%s\n", rev); + + if (ret) + return CMD_RET_FAILURE; + else + return CMD_RET_SUCCESS; +} + +static char sysinfo_help_text[] = + "model <varname> - Show or set the board model in varname\n" + "sysinfo id <varname> - Show or set the board id in varname (in format 0xHH)\n" + "sysinfo revision <varname> - Show or set the board revision in varname"; + +U_BOOT_CMD_WITH_SUBCMDS(sysinfo, "System information", sysinfo_help_text, + U_BOOT_SUBCMD_MKENT(model, 2, 1, do_sysinfo_model), + U_BOOT_SUBCMD_MKENT(id, 2, 1, do_sysinfo_id), + U_BOOT_SUBCMD_MKENT(revision, 2, 1, do_sysinfo_revision), +);
The test runs one of each subcommand and checks that the output matches the values in the sandbox sysinfo driver.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- configs/sandbox_defconfig | 1 + drivers/sysinfo/sandbox.c | 17 +++++++++++++ test/cmd/Makefile | 1 + test/cmd/test_sysinfo.c | 51 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 70 insertions(+) create mode 100644 test/cmd/test_sysinfo.c
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 19cc6701e62..a51762aa3ae 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -130,6 +130,7 @@ CONFIG_CMD_EROFS=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_SQUASHFS=y CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_SYSINFO=y CONFIG_CMD_STACKPROTECTOR_TEST=y CONFIG_MAC_PARTITION=y CONFIG_AMIGA_PARTITION=y diff --git a/drivers/sysinfo/sandbox.c b/drivers/sysinfo/sandbox.c index d270a26aa43..cc7783907a9 100644 --- a/drivers/sysinfo/sandbox.c +++ b/drivers/sysinfo/sandbox.c @@ -7,9 +7,14 @@ #include <common.h> #include <dm.h> #include <sysinfo.h> +#include <version.h>
#include "sandbox.h"
+#define SANDBOX_BOARD_ID 0x42 +#define SANDBOX_BOARD_REV_MAJOR U_BOOT_VERSION_NUM +#define SANDBOX_BOARD_REV_MINOR U_BOOT_VERSION_NUM_PATCH + struct sysinfo_sandbox_priv { bool called_detect; int test_i1; @@ -48,6 +53,15 @@ int sysinfo_sandbox_get_int(struct udevice *dev, int id, int *val) struct sysinfo_sandbox_priv *priv = dev_get_priv(dev);
switch (id) { + case SYSINFO_ID_BOARD_ID: + *val = SANDBOX_BOARD_ID; + return 0; + case SYSINFO_ID_BOARD_REV_MAJOR: + *val = SANDBOX_BOARD_REV_MAJOR; + return 0; + case SYSINFO_ID_BOARD_REV_MINOR: + *val = SANDBOX_BOARD_REV_MINOR; + return 0; case INT_TEST1: *val = priv->test_i1; /* Increments with every call */ @@ -71,6 +85,9 @@ int sysinfo_sandbox_get_str(struct udevice *dev, int id, size_t size, char *val) int index = (i1 * i2) % ARRAY_SIZE(vacation_spots);
switch (id) { + case SYSINFO_ID_BOARD_MODEL: + snprintf(val, size, "sandbox"); + return 0; case STR_VACATIONSPOT: /* Picks a vacation spot depending on i1 and i2 */ snprintf(val, size, vacation_spots[index]); diff --git a/test/cmd/Makefile b/test/cmd/Makefile index a3cf983739e..d3ac5bf2d5e 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_CMD_SEAMA) += seama.o ifdef CONFIG_SANDBOX obj-$(CONFIG_CMD_READ) += rw.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_CMD_SYSINFO) += test_sysinfo.o endif obj-$(CONFIG_CMD_TEMPERATURE) += temperature.o obj-$(CONFIG_CMD_WGET) += wget.o diff --git a/test/cmd/test_sysinfo.c b/test/cmd/test_sysinfo.c new file mode 100644 index 00000000000..7ba6dd0df89 --- /dev/null +++ b/test/cmd/test_sysinfo.c @@ -0,0 +1,51 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Tests for sysinfo command + * + * Copyright 2023, Detlev Casanova detlev.casanova@collabora.com + */ + +#include <common.h> +#include <command.h> +#include <asm/global_data.h> +#include <display_options.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> +#include <version.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define REV_(x, y) #x "." #y +#define REV(x, y) REV_(x, y) + +struct test_data { + char *cmd; + char *expected; +}; + +static struct test_data sysinfo_data[] = { + {"sysinfo model", "sandbox"}, + {"sysinfo id", "0x42"}, + {"sysinfo revision", REV(U_BOOT_VERSION_NUM, U_BOOT_VERSION_NUM_PATCH)}, +}; + +static int lib_test_sysinfo(struct unit_test_state *uts) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(sysinfo_data); ++i) { + ut_silence_console(uts); + console_record_reset_enable(); + ut_assertok(run_command(sysinfo_data[i].cmd, 0)); + ut_unsilence_console(uts); + console_record_readline(uts->actual_str, + sizeof(uts->actual_str)); + ut_asserteq_str(sysinfo_data[i].expected, uts->actual_str); + ut_assertok(ut_check_console_end(uts)); + } + + return 0; +} + +LIB_TEST(lib_test_sysinfo, 0);
Add documentation for the sysinfo command with examples.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- doc/usage/cmd/sysinfo.rst | 56 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 56 insertions(+) create mode 100644 doc/usage/cmd/sysinfo.rst
diff --git a/doc/usage/cmd/sysinfo.rst b/doc/usage/cmd/sysinfo.rst new file mode 100644 index 00000000000..1660b2aa1a6 --- /dev/null +++ b/doc/usage/cmd/sysinfo.rst @@ -0,0 +1,56 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +sysinfo command +=============== + +Synopis +------- + +:: + + sysinfo id <varname> + sysinfo model <varname> + sysinfo revision <varname> + +Description +----------- + +The `sysinfo` command is used to show information about the running system + +The `sysinfo id` command prints or sets an environment variable to the board id +as an hex value. + + varname + an optional environment variable to store the board id into. + +The `sysinfo model` command prints or sets an environment variable to the board +model name as a string value. + + varname + an optional environment variable to store the board model name into. + +The `sysinfo revision` command prints or sets an environment variable to the +board revision in the <MAJOR>.<MINOR> format, where MINOR and MINOR are int +values. + + varname + an optional environment variable to store the board revision into. + +Examples +-------- + +:: + + => sysinfo id + 0x0b + => sysinfo model + Renesas Starter Kit Premier board rev 2.1 + => sysinfo revision varname + => env print varname + 2.1 + +Return value +------------ + +The return value $? is set to 0 (true) if the command succeeded. If an +error occurs, the return value $? is set to 1 (false).
To be used with the sysinfo command, revision values must be considered as integers, not chars as some boards will implement BOARD_REVISION_* and might use numbers greater than 9.
Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- drivers/sysinfo/rcar3.c | 104 ++++++++++++++++++++++++---------------- 1 file changed, 62 insertions(+), 42 deletions(-)
diff --git a/drivers/sysinfo/rcar3.c b/drivers/sysinfo/rcar3.c index 7b127986da7..450a4c26773 100644 --- a/drivers/sysinfo/rcar3.c +++ b/drivers/sysinfo/rcar3.c @@ -68,90 +68,110 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) bool salvator_xs = false; bool ebisu_4d = false; bool condor_i = false; - char rev_major = '?'; - char rev_minor = '?'; + char model[64]; + char rev[4] = "?.?"; + u8 rev_major = 0; + u8 rev_minor = 0;
switch (board_id) { case BOARD_SALVATOR_XS: salvator_xs = true; fallthrough; case BOARD_SALVATOR_X: + snprintf(model, sizeof(model), + "Renesas Salvator-X%s board", salvator_xs ? "S" : ""); if (!(board_rev & ~1)) { /* Only rev 0 and 1 is valid */ - rev_major = '1'; - rev_minor = '0' + (board_rev & BIT(0)); + rev_major = 1; + rev_minor = board_rev & BIT(0); + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Salvator-X%s board rev %c.%c", - salvator_xs ? "S" : "", rev_major, rev_minor); + + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); + return; case BOARD_STARTER_KIT: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Starter Kit board"); if (!(board_rev & ~1)) { /* Only rev 0 and 1 is valid */ - rev_major = (board_rev & BIT(0)) ? '3' : '1'; - rev_minor = '0'; + rev_major = (board_rev & BIT(0)) ? 3 : 1; + rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Starter Kit board rev %c.%c", - rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; case BOARD_STARTER_KIT_PRE: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Starter Kit Premier board"); if (!(board_rev & ~3)) { /* Only rev 0..3 is valid */ - rev_major = (board_rev & BIT(1)) ? '2' : '1'; - rev_minor = (board_rev == 3) ? '1' : '0'; + rev_major = (board_rev & BIT(1)) ? 2 : 1; + rev_minor = (board_rev == 3) ? 1 : 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Starter Kit Premier board rev %c.%c", - rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; case BOARD_EAGLE: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Eagle board"); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = '1'; - rev_minor = '0'; + rev_major = 1; + rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Eagle board rev %c.%c", - rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; case BOARD_EBISU_4D: ebisu_4d = true; fallthrough; case BOARD_EBISU: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Ebisu%s board", ebisu_4d ? "-4D" : ""); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = '1'; - rev_minor = '0'; + rev_major = 1; + rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Ebisu%s board rev %c.%c", - ebisu_4d ? "-4D" : "", rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; case BOARD_DRAAK: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Draak board"); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = '1'; - rev_minor = '0'; + rev_major = 1; + rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Draak board rev %c.%c", - rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; case BOARD_KRIEK: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Kriek board"); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = '1'; - rev_minor = '0'; + rev_major = 1; + rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Kriek board rev %c.%c", - rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; case BOARD_CONDOR_I: condor_i = true; fallthrough; case BOARD_CONDOR: + snprintf(priv->boardmodel, sizeof(priv->boardmodel), + "Renesas Condor%s board", condor_i ? "-I" : ""); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = '1'; - rev_minor = '0'; + rev_major = 1; + rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); } - snprintf(priv->boardmodel, sizeof(priv->boardmodel), - "Renesas Condor%s board rev %c.%c", - condor_i ? "-I" : "", rev_major, rev_minor); + snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", + model, rev); return; default: snprintf(priv->boardmodel, sizeof(priv->boardmodel),
Expose that information to the sysinfo command to let scripts make decisions based on the board id and revision.
Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- drivers/sysinfo/rcar3.c | 103 +++++++++++++++++++++++++++------------- 1 file changed, 70 insertions(+), 33 deletions(-)
diff --git a/drivers/sysinfo/rcar3.c b/drivers/sysinfo/rcar3.c index 450a4c26773..1a99642bf75 100644 --- a/drivers/sysinfo/rcar3.c +++ b/drivers/sysinfo/rcar3.c @@ -32,6 +32,10 @@ */ struct sysinfo_rcar_priv { char boardmodel[64]; + u8 id; + u8 rev_major; + u8 rev_minor; + bool has_rev; u8 val; };
@@ -56,9 +60,33 @@ static int sysinfo_rcar_get_str(struct udevice *dev, int id, size_t size, char * }; }
+static int sysinfo_rcar_get_int(struct udevice *dev, int id, int *val) +{ + struct sysinfo_rcar_priv *priv = dev_get_priv(dev); + + switch (id) { + case SYSINFO_ID_BOARD_ID: + *val = priv->id; + return 0; + case SYSINFO_ID_BOARD_REVISION_MAJOR: + if (!priv->has_rev) + return -EINVAL; + *val = priv->rev_major; + return 0; + case SYSINFO_ID_BOARD_REVISION_MINOR: + if (!priv->has_rev) + return -EINVAL; + *val = priv->rev_minor; + return 0; + default: + return -EINVAL; + }; +} + static const struct sysinfo_ops sysinfo_rcar_ops = { .detect = sysinfo_rcar_detect, .get_str = sysinfo_rcar_get_str, + .get_int = sysinfo_rcar_get_int, };
static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) @@ -70,8 +98,9 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) bool condor_i = false; char model[64]; char rev[4] = "?.?"; - u8 rev_major = 0; - u8 rev_minor = 0; + + priv->id = board_id; + priv->has_rev = false;
switch (board_id) { case BOARD_SALVATOR_XS: @@ -81,9 +110,10 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) snprintf(model, sizeof(model), "Renesas Salvator-X%s board", salvator_xs ? "S" : ""); if (!(board_rev & ~1)) { /* Only rev 0 and 1 is valid */ - rev_major = 1; - rev_minor = board_rev & BIT(0); - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = 1; + priv->rev_minor = board_rev & BIT(0); + priv->has_rev = true; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); }
snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", @@ -91,34 +121,37 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv)
return; case BOARD_STARTER_KIT: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Starter Kit board"); if (!(board_rev & ~1)) { /* Only rev 0 and 1 is valid */ - rev_major = (board_rev & BIT(0)) ? 3 : 1; - rev_minor = 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = (board_rev & BIT(0)) ? 3 : 1; + priv->rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev); return; case BOARD_STARTER_KIT_PRE: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Starter Kit Premier board"); if (!(board_rev & ~3)) { /* Only rev 0..3 is valid */ - rev_major = (board_rev & BIT(1)) ? 2 : 1; - rev_minor = (board_rev == 3) ? 1 : 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = (board_rev & BIT(1)) ? 2 : 1; + priv->rev_minor = (board_rev == 3) ? 1 : 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev); return; case BOARD_EAGLE: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Eagle board"); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = 1; - rev_minor = 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = 1; + priv->rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev); @@ -127,34 +160,37 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) ebisu_4d = true; fallthrough; case BOARD_EBISU: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Ebisu%s board", ebisu_4d ? "-4D" : ""); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = 1; - rev_minor = 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = 1; + priv->rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev); return; case BOARD_DRAAK: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Draak board"); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = 1; - rev_minor = 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = 1; + priv->rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev); return; case BOARD_KRIEK: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Kriek board"); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = 1; - rev_minor = 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = 1; + priv->rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev); @@ -163,12 +199,13 @@ static void sysinfo_rcar_parse(struct sysinfo_rcar_priv *priv) condor_i = true; fallthrough; case BOARD_CONDOR: - snprintf(priv->boardmodel, sizeof(priv->boardmodel), + snprintf(model, sizeof(model), "Renesas Condor%s board", condor_i ? "-I" : ""); if (!board_rev) { /* Only rev 0 is valid */ - rev_major = 1; - rev_minor = 0; - snprintf(rev, sizeof(rev), "%u.%u", rev_major, rev_minor); + priv->rev_major = 1; + priv->rev_minor = 0; + snprintf(rev, sizeof(rev), "%u.%u", priv->rev_major, priv->rev_minor); + priv->has_rev = true; } snprintf(priv->boardmodel, sizeof(priv->boardmodel), "%s rev %s", model, rev);
On Thu, Jul 20, 2023 at 3:50 PM Detlev Casanova detlev.casanova@collabora.com wrote:
- model: A string representing the model
- id: The id of the board
- revision: The revision of this board.
How does this differ from the bdinfo and some of the other commands that provide similar info?
Changes since v3:
Changes since v2:
- Fix code style.
Changes since v1:
-- 2.41.0
If I'm not wrong, the bdinfo command is about showing what hardware is present on the board. The sysinfo command is about showing board identification information.
Changes since v3:
Changes since v2:
- Fix code style.
Changes since v1:
distributions job.
-- 2.41.0
On Tue, Aug 8, 2023 at 3:27 PM Detlev Casanova detlev.casanova@collabora.com wrote:
Why can't bdinfo be extended rather than adding yet another command?
Changes since v3:
Changes since v2:
- Fix code style.
Changes since v1:
distributions job.
-- 2.41.0
It could , but it feels like overloading bdinfo . Sysinfo is system identification (i.e. stuff in eeprom), bdinfo is things like memory layout.
Detlev Casanova
Peter Robinson
