[U-Boot] [PATCH] CM4000: fix missing RAM definitions for OpenGear boards
The OpenGear boards CM4008, CM4116 and CM4148 need their DRAM base and RAM stack base addresses defined.
Fixes:
board.c: In function ‘__dram_init_banksize’: board.c:227: error: ‘CONFIG_SYS_SDRAM_BASE’ undeclared (first use in this function) board.c:227: error: (Each undeclared identifier is reported only once board.c:227: error: for each function it appears in.) board.c: In function ‘board_init_f’: board.c:270: error: ‘CONFIG_SYS_INIT_SP_ADDR’ undeclared (first use in this function) board.c:303: error: ‘CONFIG_SYS_SDRAM_BASE’ undeclared (first use in this function)
Signed-off-by: Greg Ungerer greg.ungerer@opengear.com --- include/configs/cm4008.h | 3 +++ include/configs/cm41xx.h | 3 +++ 2 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/include/configs/cm4008.h b/include/configs/cm4008.h index 6e4a3b4..81e4de4 100644 --- a/include/configs/cm4008.h +++ b/include/configs/cm4008.h @@ -114,6 +114,9 @@ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ #define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x01000000 /* 16 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +#define CONFIG_SYS_INIT_SP_ADDR 0x00020000 /* lowest 128k of RAM */
#define PHYS_FLASH_1 0x02000000 /* Flash Bank #1 */ #define PHYS_FLASH_SECT_SIZE 0x00020000 /* 128 KB sectors (x1) */ diff --git a/include/configs/cm41xx.h b/include/configs/cm41xx.h index dca7d54..785ab0a 100644 --- a/include/configs/cm41xx.h +++ b/include/configs/cm41xx.h @@ -114,6 +114,9 @@ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ #define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +#define CONFIG_SYS_INIT_SP_ADDR 0x00020000 /* lowest 128k of RAM */
Dear Greg Ungerer,
In message 1315570998-528-1-git-send-email-greg.ungerer@opengear.com you wrote:
Fixes:
board.c: In function `__dram_init_banksize´: board.c:227: error: `CONFIG_SYS_SDRAM_BASE´ undeclared (first use in this function) board.c:227: error: (Each undeclared identifier is reported only once board.c:227: error: for each function it appears in.) board.c: In function `board_init_f´: board.c:270: error: `CONFIG_SYS_INIT_SP_ADDR´ undeclared (first use in this function) board.c:303: error: `CONFIG_SYS_SDRAM_BASE´ undeclared (first use in this function)
Applied, thanks.
Greg Ungerer
