The following changes since commit 0ac83d080a0044cd0d8f782ba12f02cf969d3004:
Merge branch 'next' of https://gitlab.denx.de/u-boot/custodians/u-boot-x86 into next (2020-09-25 09:04:01 -0400)
git://git.denx.de/u-boot-sh.git next
for you to fetch changes up to 9275a963d448562a80213639c73e2dc34c6d1835:
net: ravb: Remove writeext function call (2020-09-26 17:25:44 +0200)
---------------------------------------------------------------- Biju Das (11): arm: rmobile: Identify R8A7796 r1.3 SoC pinctrl: renesas: Fix PINCTRL_PFC_R8A774A1 help description arm: dts: r8a774a1: Import DTS from Linux 5.9-rc4 arm: dts: r8a774b1: Import DTS from Linux 5.9-rc4 arm: dts: r8a774e1: Import DTS from Linux 5.9-rc4 arm: mach-rmobile: Mark the default s_init function as weak board: renesas: Remove empty s_init function arm: rmobile: Use imply for BOARD_EARLY_INIT_F board: renesas: remove empty board_early_init_f function board: renesas: draak: Drop CA57 reset net: ravb: Remove writeext function call
Marek Vasut (2): ARM: rmobile: Enable RPC on Salvator-X, ULCB, Ebisu ARM: rmobile: Enable dfu tftp on Gen3
arch/arm/Kconfig | 2 +- arch/arm/dts/r8a774a1.dtsi | 10 +- arch/arm/dts/r8a774b1.dtsi | 2630 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/r8a774e1.dtsi | 1664 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/r8a77950-salvator-x-u-boot.dts | 5 + arch/arm/dts/r8a77950-ulcb-u-boot.dts | 5 + arch/arm/dts/r8a77960-salvator-x-u-boot.dts | 5 + arch/arm/dts/r8a77960-ulcb-u-boot.dts | 5 + arch/arm/dts/r8a77965-salvator-x-u-boot.dts | 5 + arch/arm/dts/r8a77965-ulcb-u-boot.dts | 5 + arch/arm/dts/r8a77990-ebisu-u-boot.dts | 5 + arch/arm/dts/r8a77995-draak-u-boot.dts | 5 + arch/arm/mach-rmobile/cpu_info-rcar.c | 9 +- arch/arm/mach-rmobile/lowlevel_init_gen3.S | 6 + board/renesas/condor/condor.c | 9 - board/renesas/draak/draak.c | 19 +- board/renesas/ebisu/ebisu.c | 9 - board/renesas/salvator-x/salvator-x.c | 4 - board/renesas/ulcb/ulcb.c | 4 - configs/grpeach_defconfig | 1 + configs/r8a77970_eagle_defconfig | 4 + configs/r8a77980_condor_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 17 + configs/r8a77995_draak_defconfig | 11 + configs/rcar3_salvator-x_defconfig | 16 + configs/rcar3_ulcb_defconfig | 16 + drivers/net/ravb.c | 2 - drivers/pinctrl/renesas/Kconfig | 20 +- include/configs/ebisu.h | 12 + include/configs/salvator-x.h | 12 + include/configs/ulcb.h | 12 + include/dt-bindings/clock/r8a774a1-cpg-mssr.h | 96 ++-- include/dt-bindings/clock/r8a774b1-cpg-mssr.h | 57 ++ include/dt-bindings/clock/r8a774e1-cpg-mssr.h | 59 ++ include/dt-bindings/power/r8a774a1-sysc.h | 2 - include/dt-bindings/power/r8a774b1-sysc.h | 26 + include/dt-bindings/power/r8a774e1-sysc.h | 36 ++ 37 files changed, 4690 insertions(+), 116 deletions(-) create mode 100644 arch/arm/dts/r8a774b1.dtsi create mode 100644 arch/arm/dts/r8a774e1.dtsi create mode 100644 include/dt-bindings/clock/r8a774b1-cpg-mssr.h create mode 100644 include/dt-bindings/clock/r8a774e1-cpg-mssr.h create mode 100644 include/dt-bindings/power/r8a774b1-sysc.h create mode 100644 include/dt-bindings/power/r8a774e1-sysc.h
