[U-Boot-Users] u-boot compilation
Hello,
i´ve problems compiling u-boot. I use cross compiler 2.95.3. When i compile u-boot i get an errer that he cant finde a file called "mach-types.h". What could it be? How can i fix this problems? I haven´t found the file in my filesystem.. not in the kernel directory (2.4.18 and 2.5.0) and not in the directory of the cross compiler!
André
On Tue, Nov 05, 2002 at 07:36:24PM +0100, André Stierenberg wrote:
i?ve problems compiling u-boot. I use cross compiler 2.95.3. When i compile u-boot i get an errer that he cant finde a file called "mach-types.h". What could it be? How can i fix this problems? I haven?t found the file in my filesystem.. not in the kernel directory (2.4.18 and 2.5.0) and not in the directory of the cross compiler!
mach-types.h should be in the include/asm-arm/ directory of your kernel tree. Are you sure you have installed a correct toolchain and kernel source?
Robert
No. No file "mach-types.h" is needed anywhere in the U-Boot source code. If the compiler thinks it needs it (and cannot find it), then the cross compiler is misconfigured.
Get a working set of tools.
André Stierenberg
Robert Schwebel
