[U-Boot] [PATCH 0/5] Add target EDOSK2674
Hi lists,
This patches added new target EDOSK2674. Please comments. Thanks.
Yoshinori Sato (5): Add h8300 architecture part1 - core Add h8300 architecture part2 - headers Add h8300 architecture part3 - misc standard SCI support Add target edosk2674
arch/h8300/config.mk | 35 +++++++ arch/h8300/cpu/h8300s/Makefile | 53 ++++++++++ arch/h8300/cpu/h8300s/config.mk | 26 +++++ arch/h8300/cpu/h8300s/cpu.c | 83 +++++++++++++++ arch/h8300/cpu/h8300s/interrupts.c | 38 +++++++ arch/h8300/cpu/h8300s/start.S | 87 ++++++++++++++++ arch/h8300/cpu/h8300s/watchdog.c | 36 +++++++ arch/h8300/include/asm/bitops.h | 186 ++++++++++++++++++++++++++++++++++ arch/h8300/include/asm/byteorder.h | 6 + arch/h8300/include/asm/config.h | 26 +++++ arch/h8300/include/asm/global_data.h | 55 ++++++++++ arch/h8300/include/asm/io.h | 178 ++++++++++++++++++++++++++++++++ arch/h8300/include/asm/posix_types.h | 123 ++++++++++++++++++++++ arch/h8300/include/asm/processor.h | 4 + arch/h8300/include/asm/ptrace.h | 64 ++++++++++++ arch/h8300/include/asm/string.h | 41 ++++++++ arch/h8300/include/asm/types.h | 62 +++++++++++ arch/h8300/include/asm/u-boot.h | 41 ++++++++ arch/h8300/include/asm/unaligned.h | 10 ++ arch/h8300/lib/Makefile | 43 ++++++++ arch/h8300/lib/board.c | 158 +++++++++++++++++++++++++++++ arch/h8300/lib/bootm.c | 70 +++++++++++++ arch/h8300/lib/time.c | 87 ++++++++++++++++ board/edosk2674/Makefile | 48 +++++++++ board/edosk2674/config.mk | 25 +++++ board/edosk2674/edosk2674.c | 63 ++++++++++++ board/edosk2674/lowlevel_init.S | 84 +++++++++++++++ board/edosk2674/u-boot.lds | 84 +++++++++++++++ boards.cfg | 1 + common/cmd_bdinfo.c | 20 ++++ common/cmd_bootm.c | 2 + drivers/net/lan91c96.h | 21 ++++ drivers/serial/serial_sh.c | 74 ++++++++++++-- drivers/serial/serial_sh.h | 93 ++++++----------- examples/standalone/Makefile | 3 +- examples/standalone/stubs.c | 20 ++++- include/configs/edosk2674.h | 104 +++++++++++++++++++ include/image.h | 5 + 38 files changed, 2086 insertions(+), 73 deletions(-) create mode 100644 arch/h8300/config.mk create mode 100644 arch/h8300/cpu/h8300s/Makefile create mode 100644 arch/h8300/cpu/h8300s/config.mk create mode 100644 arch/h8300/cpu/h8300s/cpu.c create mode 100644 arch/h8300/cpu/h8300s/interrupts.c create mode 100644 arch/h8300/cpu/h8300s/start.S create mode 100644 arch/h8300/cpu/h8300s/watchdog.c create mode 100644 arch/h8300/include/asm/bitops.h create mode 100644 arch/h8300/include/asm/byteorder.h create mode 100644 arch/h8300/include/asm/config.h create mode 100644 arch/h8300/include/asm/global_data.h create mode 100644 arch/h8300/include/asm/io.h create mode 100644 arch/h8300/include/asm/posix_types.h create mode 100644 arch/h8300/include/asm/processor.h create mode 100644 arch/h8300/include/asm/ptrace.h create mode 100644 arch/h8300/include/asm/string.h create mode 100644 arch/h8300/include/asm/types.h create mode 100644 arch/h8300/include/asm/u-boot.h create mode 100644 arch/h8300/include/asm/unaligned.h create mode 100644 arch/h8300/lib/Makefile create mode 100644 arch/h8300/lib/board.c create mode 100644 arch/h8300/lib/bootm.c create mode 100644 arch/h8300/lib/time.c create mode 100644 board/edosk2674/Makefile create mode 100644 board/edosk2674/config.mk create mode 100644 board/edosk2674/edosk2674.c create mode 100644 board/edosk2674/lowlevel_init.S create mode 100644 board/edosk2674/u-boot.lds create mode 100644 include/configs/edosk2674.h
Dear Yoshinori Sato,
In message 87zkpe9dj9.wl%ysato@users.sourceforge.jp you wrote:
Hi lists,
As a general note, it would be a good idea to include some comments about hwat sort this CPU is, why it is implemented here as a new architecture, where one can find related documentation, etc.
This split is artifical and makes no sense. Please keep in ind that commits shall implement atomic changes, always resulting in some sort of sane state. So adding code without the needed headers is a strict no-no.
Finally, these changes have a number of style issues. In a first step I recommend to clean up checkpatch errors and warnings:
[U-Boot] [PATCH 1/5] Add h8300 architecture part1 - core total: 6 errors, 9 warnings, 716 lines checked [U-Boot] [PATCH 2/5] Add h8300 architecture part2 - headers total: 84 errors, 84 warnings, 796 lines checked [U-Boot] [PATCH 3/5] Add h8300 architecture part3 - misc total: 1 errors, 11 warnings, 104 lines checked [U-Boot] [PATCH 4/5] standard SCI support total: 9 errors, 3 warnings, 273 lines checked [U-Boot] [PATCH 5/5] Add target edosk2674 total: 8 errors, 11 warnings, 442 lines checked
Thanks.
Yoshinori Sato
