[U-Boot] [PATCH v4 1/2] powerpc/mpc85xx: SECURE BOOT- Enable chain of trust in SPL
As part of Chain of Trust for Secure boot, the SPL U-Boot will validate the next level U-boot image. Add a new function spl_validate_uboot to perform the validation.
Enable hardware crypto operations in SPL using SEC block. In case of Secure Boot, PAMU is not bypassed. For allowing SEC block access to CPC configured as SRAM, configure PAMU.
Reviewed-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Aneesh Bansal aneesh.bansal@nxp.com Signed-off-by: Sumit Garg sumit.garg@nxp.com --- Changes in v2: Patches rebased
Changes in v3: Patches rebased
Changes in v4: Generic changes in lib, drivers, common Makefiles removed from this patchset. Rebased this patchset on top of patch [1], so this patchset is dependent on patch [1].
[1]https://patchwork.ozlabs.org/patch/627664/
arch/powerpc/cpu/mpc8xxx/fsl_pamu.c | 8 +++++ arch/powerpc/cpu/mpc8xxx/pamu_table.c | 8 +++++ arch/powerpc/include/asm/fsl_secure_boot.h | 28 ++++++++++++++++ board/freescale/common/fsl_chain_of_trust.c | 50 +++++++++++++++++++++++++++++ drivers/crypto/fsl/jr.c | 16 +++++++++ drivers/mtd/nand/fsl_ifc_spl.c | 24 ++++++++++++++ include/fsl_validate.h | 1 + 7 files changed, 135 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c b/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c index 9421f1e..ede8e66 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c @@ -239,15 +239,23 @@ int pamu_init(void) spaact_size = sizeof(struct paace) * NUM_SPAACT_ENTRIES;
/* Allocate space for Primary PAACT Table */ +#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_PPAACT_ADDR)) + ppaact = (void *)CONFIG_SPL_PPAACT_ADDR; +#else ppaact = memalign(PAMU_TABLE_ALIGNMENT, ppaact_size); if (!ppaact) return -1; +#endif memset(ppaact, 0, ppaact_size);
/* Allocate space for Secondary PAACT Table */ +#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SPAACT_ADDR)) + sec = (void *)CONFIG_SPL_SPAACT_ADDR; +#else sec = memalign(PAMU_TABLE_ALIGNMENT, spaact_size); if (!sec) return -1; +#endif memset(sec, 0, spaact_size);
ppaact_phys = virt_to_phys((void *)ppaact); diff --git a/arch/powerpc/cpu/mpc8xxx/pamu_table.c b/arch/powerpc/cpu/mpc8xxx/pamu_table.c index 26c5ea4..a8e6f51 100644 --- a/arch/powerpc/cpu/mpc8xxx/pamu_table.c +++ b/arch/powerpc/cpu/mpc8xxx/pamu_table.c @@ -28,6 +28,14 @@ void construct_pamu_addr_table(struct pamu_addr_tbl *tbl, int *num_entries)
i++; #endif +#if (defined(CONFIG_SPL_BUILD) && (CONFIG_SYS_INIT_L3_VADDR)) + tbl->start_addr[i] = + (uint64_t)virt_to_phys((void *)CONFIG_SYS_INIT_L3_VADDR); + tbl->size[i] = 256 * 1024; /* 256K CPC flash */ + tbl->end_addr[i] = tbl->start_addr[i] + tbl->size[i] - 1; + + i++; +#endif debug("PAMU address\t\t\tsize\n"); for (j = 0; j < i ; j++) debug("%llx \t\t\t%llx\n", tbl->start_addr[j], tbl->size[j]); diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 826f9c9..99eec7f 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -72,6 +72,32 @@
#ifdef CONFIG_CHAIN_OF_TRUST
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_DM 1 +#define CONFIG_SPL_CRYPTO_SUPPORT +#define CONFIG_SPL_HASH_SUPPORT +#define CONFIG_SPL_RSA +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +/* + * PPAACT and SPAACT table for PAMU must be placed on DDR after DDR init + * due to space crunch on CPC and thus malloc will not work. + */ +#define CONFIG_SPL_PPAACT_ADDR 0x2e000000 +#define CONFIG_SPL_SPAACT_ADDR 0x2f000000 +#define CONFIG_SPL_JR0_LIODN_S 454 +#define CONFIG_SPL_JR0_LIODN_NS 458 +/* + * Define the key hash for U-Boot here if public/private key pair used to + * sign U-boot are different from the SRK hash put in the fuse + * Example of defining KEY_HASH is + * #define CONFIG_SPL_UBOOT_KEY_HASH \ + * "41066b564c6ffcef40ccbc1e0a5d0d519604000c785d97bbefd25e4d288d1c8b" + * else leave it defined as NULL + */ + +#define CONFIG_SPL_UBOOT_KEY_HASH NULL +#endif /* ifdef CONFIG_SPL_BUILD */ + #define CONFIG_CMD_ESBC_VALIDATE #define CONFIG_CMD_BLOB #define CONFIG_FSL_SEC_MON @@ -82,6 +108,7 @@ #define CONFIG_FSL_CAAM #endif
+#ifndef CONFIG_SPL_BUILD /* fsl_setenv_chain_of_trust() must be called from * board_late_init() */ @@ -119,5 +146,6 @@ #endif /* #ifdef CONFIG_BOOTSCRIPT_COPY_RAM */
#include <config_fsl_chain_trust.h> +#endif /* #ifndef CONFIG_SPL_BUILD */ #endif /* #ifdef CONFIG_CHAIN_OF_TRUST */ #endif diff --git a/board/freescale/common/fsl_chain_of_trust.c b/board/freescale/common/fsl_chain_of_trust.c index ecfcc82..992babf 100644 --- a/board/freescale/common/fsl_chain_of_trust.c +++ b/board/freescale/common/fsl_chain_of_trust.c @@ -6,7 +6,17 @@
#include <common.h> #include <fsl_validate.h> +#include <fsl_secboot_err.h> #include <fsl_sfp.h> +#include <dm/root.h> + +#ifdef CONFIG_ADDR_MAP +#include <asm/mmu.h> +#endif + +#ifdef CONFIG_FSL_CORENET +#include <asm/fsl_pamu.h> +#endif
#ifdef CONFIG_LS102XA #include <asm/arch/immap_ls102xa.h> @@ -52,6 +62,7 @@ int fsl_check_boot_mode_secure(void) return 0; }
+#ifndef CONFIG_SPL_BUILD int fsl_setenv_chain_of_trust(void) { /* Check Boot Mode @@ -68,3 +79,42 @@ int fsl_setenv_chain_of_trust(void) setenv("bootcmd", CONFIG_CHAIN_BOOT_CMD); return 0; } +#endif + +#ifdef CONFIG_SPL_BUILD +void spl_validate_uboot(uint32_t hdr_addr, uintptr_t img_addr) +{ + int res; + + /* Check Boot Mode + * If Boot Mode is Non-Secure, skip validation + */ + if (fsl_check_boot_mode_secure() == 0) + return; + + printf("SPL: Validating U-Boot image\n"); + +#ifdef CONFIG_ADDR_MAP + init_addr_map(); +#endif + +#ifdef CONFIG_FSL_CORENET + if (pamu_init() < 0) + fsl_secboot_handle_error(ERROR_ESBC_PAMU_INIT); +#endif + +#ifdef CONFIG_FSL_CAAM + if (sec_init() < 0) + fsl_secboot_handle_error(ERROR_ESBC_SEC_INIT); +#endif + +#if defined(CONFIG_DM) + dm_init_and_scan(false); +#endif + res = fsl_secboot_validate(hdr_addr, CONFIG_SPL_UBOOT_KEY_HASH, + &img_addr); + + if (res == 0) + printf("SPL: Validation of U-boot successful\n"); +} +#endif diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 510fa4e..1d4dd32 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -599,10 +599,26 @@ int sec_init_idx(uint8_t sec_idx) sec_out32(&sec->mcfgr, mcr);
#ifdef CONFIG_FSL_CORENET +#ifdef CONFIG_SPL_BUILD + /* For SPL Build, Set the Liodns in SEC JR0 for + * creating PAMU entries corresponding to these. + * For normal build, these are set in set_liodns(). + */ + liodn_ns = CONFIG_SPL_JR0_LIODN_NS & JRNSLIODN_MASK; + liodn_s = CONFIG_SPL_JR0_LIODN_S & JRSLIODN_MASK; + + liodnr = sec_in32(&sec->jrliodnr[0].ls) & + ~(JRNSLIODN_MASK | JRSLIODN_MASK); + liodnr = liodnr | + (liodn_ns << JRNSLIODN_SHIFT) | + (liodn_s << JRSLIODN_SHIFT); + sec_out32(&sec->jrliodnr[0].ls, liodnr); +#else liodnr = sec_in32(&sec->jrliodnr[0].ls); liodn_ns = (liodnr & JRNSLIODN_MASK) >> JRNSLIODN_SHIFT; liodn_s = (liodnr & JRSLIODN_MASK) >> JRSLIODN_SHIFT; #endif +#endif
ret = jr_init(sec_idx); if (ret < 0) { diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c index cbeb74a..30aa966 100644 --- a/drivers/mtd/nand/fsl_ifc_spl.c +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -11,6 +11,9 @@ #include <asm/io.h> #include <fsl_ifc.h> #include <linux/mtd/nand.h> +#ifdef CONFIG_CHAIN_OF_TRUST +#include <fsl_validate.h> +#endif
static inline int is_blank(uchar *addr, int page_size) { @@ -268,6 +271,27 @@ void nand_boot(void) */ flush_cache(CONFIG_SYS_NAND_U_BOOT_DST, CONFIG_SYS_NAND_U_BOOT_SIZE); #endif + +#ifdef CONFIG_CHAIN_OF_TRUST + /* + * As U-Boot header is appended at end of U-boot image, so + * calculate U-boot header address using U-boot header size. + */ +#define CONFIG_U_BOOT_HDR_ADDR \ + ((CONFIG_SYS_NAND_U_BOOT_START + \ + CONFIG_SYS_NAND_U_BOOT_SIZE) - \ + CONFIG_U_BOOT_HDR_SIZE) + spl_validate_uboot(CONFIG_U_BOOT_HDR_ADDR, + CONFIG_SYS_NAND_U_BOOT_START); + /* + * In case of failure in validation, spl_validate_uboot would + * not return back in case of Production environment with ITS=1. + * Thus U-Boot will not start. + * In Development environment (ITS=0 and SB_EN=1), the function + * may return back in case of non-fatal failures. + */ +#endif + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; uboot(); } diff --git a/include/fsl_validate.h b/include/fsl_validate.h index a71e1ce..7695b30 100644 --- a/include/fsl_validate.h +++ b/include/fsl_validate.h @@ -254,4 +254,5 @@ int fsl_secboot_blob_decap(cmd_tbl_t *cmdtp, int flag, int argc,
int fsl_check_boot_mode_secure(void); int fsl_setenv_chain_of_trust(void); +void spl_validate_uboot(uint32_t hdr_addr, uintptr_t img_addr); #endif
Hi Sumit,
I noticed your patch series just now and I certainly don't want to derail what you are trying to do here but I wanted to see what you think about something that's pretty much related.
In order to be more flexible in how we go from SPL to U-Boot (we have a need to inject ROM-API calls for decryption in addition to authentication) I've been experimenting with a method that basically injects a generic post-process function call into spl_load_simple_fit() that the platform-specific layer can provide/override. This function will basically get invoked on the U-Boot firmware itself as well as for the selected DTB after it gets loaded, allowing to do things like custom authentication and/or decryption through plugging in for example our ROM API calls. But this should also be a starting point for someone to plug in the U-Boot RSA libraries directly in a way that doesn't require using CONFIG_SPL_DM (for memory-constrained devices).
So mostly I wanted to see if this is something that could be useful for you as well, and any comments/concerns you may have on that.
Thanks and Regards,
-- Andreas Dannenberg Texas Instruments Inc
- ppaact = (void *)CONFIG_SPL_PPAACT_ADDR;
- sec = (void *)CONFIG_SPL_SPAACT_ADDR;
- tbl->start_addr[i] =
- tbl->size[i] = 256 * 1024; /* 256K CPC flash */
- tbl->end_addr[i] = tbl->start_addr[i] + tbl->size[i] - 1;
- i++;
- PPAACT and SPAACT table for PAMU must be placed on DDR after DDR init
- due to space crunch on CPC and thus malloc will not work.
- Define the key hash for U-Boot here if public/private key pair used to
- sign U-boot are different from the SRK hash put in the fuse
- Example of defining KEY_HASH is
- #define CONFIG_SPL_UBOOT_KEY_HASH \
- else leave it defined as NULL
- board_late_init()
- int res;
- /* Check Boot Mode
- if (fsl_check_boot_mode_secure() == 0)
return;
- printf("SPL: Validating U-Boot image\n");
- init_addr_map();
- if (pamu_init() < 0)
- if (sec_init() < 0)
- dm_init_and_scan(false);
- res = fsl_secboot_validate(hdr_addr, CONFIG_SPL_UBOOT_KEY_HASH,
&img_addr);
- if (res == 0)
- /* For SPL Build, Set the Liodns in SEC JR0 for
- liodn_ns = CONFIG_SPL_JR0_LIODN_NS & JRNSLIODN_MASK;
- liodn_s = CONFIG_SPL_JR0_LIODN_S & JRSLIODN_MASK;
- liodnr = sec_in32(&sec->jrliodnr[0].ls) &
- liodnr = liodnr |
- sec_out32(&sec->jrliodnr[0].ls, liodnr);
- spl_validate_uboot(CONFIG_U_BOOT_HDR_ADDR,
- uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; uboot();
#endif
1.8.1.4
On 9 June 2016 at 09:05, Andreas Dannenberg dannenberg@ti.com wrote:
Hi Sumit,
Thanks and Regards,
i++;
i++;
- board_late_init()
int res;
/* Check Boot Mode
return;
init_addr_map();
if (sec_init() < 0)
Eek, this is duplicating code and adding a board-specific hack. I agree that it would be better to use SPL FIT to handle this.
&img_addr);
if (res == 0)
liodnr = liodnr |
#endif
1.8.1.4
Hi Andreas, Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Friday, June 10, 2016 6:05 AM To: Andreas Dannenberg dannenberg@ti.com Cc: Sumit Garg sumit.garg@nxp.com; U-Boot Mailing List <u- boot@lists.denx.de>; york sun york.sun@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Teddy Reed V teddy.reed@gmail.com; Aneesh Bansal aneesh.bansal@nxp.com Subject: Re: [PATCH v4 1/2] powerpc/mpc85xx: SECURE BOOT- Enable chain of trust in SPL
Hi Sumit,
It’s a good idea to plug ROM API calls for decryption and authentication in U-boot firmware. I think your main concern is DM framework in SPL for memory constrained devices. But for our platforms memory constraint is not a barrier in this case, so for time being we could use CONFIG_SPL_DM. So if you come up with framework to add U-Boot RSA libraries without using DM in SPL, we could enable it on our platforms too.
Thanks and Regards,
ppaact = (void *)CONFIG_SPL_PPAACT_ADDR; #else ppaact = memalign(PAMU_TABLE_ALIGNMENT, ppaact_size); if (!ppaact) return -1;
sec = (void *)CONFIG_SPL_SPAACT_ADDR; #else sec = memalign(PAMU_TABLE_ALIGNMENT, spaact_size); if (!sec) return -1;
i++;
i++;
+init
+used to
- board_late_init()
+#ifdef CONFIG_SPL_BUILD +void spl_validate_uboot(uint32_t hdr_addr, uintptr_t img_addr) {
int res;
/* Check Boot Mode
return;
init_addr_map();
if (sec_init() < 0)
Currently our powerpc based platforms do not use generic SPL framework but uses board specific SPL framework (/board/freescale/<platform>/spl.c) and do not use DM in SPL either. So to include RSA library I called it here once rather than calling in every board specific file. Yeah you are correct I should use CONFIG_SPL_DM here instead of CONFIG_DM.
&img_addr);
if (res == 0)
printf("SPL: Validation of U-boot successful\n"); }
liodnr = liodnr |
sec_out32(&sec->jrliodnr[0].ls, liodnr); #else liodnr = sec_in32(&sec->jrliodnr[0].ls); liodn_ns = (liodnr & JRNSLIODN_MASK) >> JRNSLIODN_SHIFT; liodn_s = (liodnr & JRSLIODN_MASK) >> JRSLIODN_SHIFT; #endif
#endif
flag, int argc,
#endif
1.8.1.4
Regards, Sumit
Andreas Dannenberg
Sumit Garg
