[U-Boot] [PATCH] spl: Allow cache drivers to be used in SPL
Add an option for building cache drivers in SPL.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- common/spl/Kconfig | 5 +++++ drivers/Makefile | 1 + drivers/cache/Makefile | 2 +- 3 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index c661809923..6e095c33e1 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -714,6 +714,11 @@ config SPL_UBI README.ubispl for more info.
if SPL_DM +config SPL_CACHE + bool "Support cache drivers in SPL" + help + Enable support for cache drivers in SPL. + config SPL_DM_SPI bool "Support SPI DM drivers in SPL" help diff --git a/drivers/Makefile b/drivers/Makefile index 0befeddfcb..0e42d006b9 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -31,6 +31,7 @@ ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_BUILD
obj-$(CONFIG_SPL_BOOTCOUNT_LIMIT) += bootcount/ +obj-$(CONFIG_SPL_CACHE) += cache/ obj-$(CONFIG_SPL_CPU_SUPPORT) += cpu/ obj-$(CONFIG_SPL_CRYPTO_SUPPORT) += crypto/ obj-$(CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT) += ddr/fsl/ diff --git a/drivers/cache/Makefile b/drivers/cache/Makefile index 4a6458c602..c1f766cfca 100644 --- a/drivers/cache/Makefile +++ b/drivers/cache/Makefile @@ -1,5 +1,5 @@
-obj-$(CONFIG_CACHE) += cache-uclass.o +obj-$(CONFIG_$(SPL_)CACHE) += cache-uclass.o obj-$(CONFIG_SANDBOX) += sandbox_cache.o obj-$(CONFIG_L2X0_CACHE) += cache-l2x0.o obj-$(CONFIG_V5L2_CACHE) += cache-v5l2.o
help
-obj-$(CONFIG_CACHE) += cache-uclass.o +obj-$(CONFIG_$(SPL_)CACHE) += cache-uclass.o obj-$(CONFIG_SANDBOX) += sandbox_cache.o obj-$(CONFIG_L2X0_CACHE) += cache-l2x0.o obj-$(CONFIG_V5L2_CACHE) += cache-v5l2.o -- 2.19.0
Hi Tom
Any comment on this patch?
Regards
Ley Foon
Ley, Tom,
Am 26.11.2019 um 10:26 schrieb Ley Foon Tan:
Ley:
What's the actual problem here? Can you further describe your change? Why do you need to change drivers/cache/Makefile? That seems to only make sense if you enable the new SPL_CACHE without (non-SPL) CACHE.
However, the series this was pulled out from adds a new cache driver and makes it select CACHE, not SPL_CACHE, so how would this be activated anyway?
Maybe it would be better to always dive down into drivers/cache/ if CACHE is y?
Tom:
As drivers/cache is rather new and initiated via the socfpga tree, would you be OK for us to take this via the socfpga/next tree once it's sorted out?
help
- config SPL_DM_SPI bool "Support SPI DM drivers in SPL" help
Hi Tom
Regards
Ley Foon
On Wed, Nov 27, 2019 at 09:33:19PM +0100, Simon Goldschmidt wrote:
Ley, Tom,
Ley:
Tom:
Sounds good, thanks.
On Thu, Nov 28, 2019 at 4:33 AM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Ley, Tom,
Ley:
Hi Simon
The existing drivers/cache is only build when compile for Uboot proper, but not SPL build. So, this patch mainly is to allow drivers/cache to compile in SPL build. User can enable CONFIG_SPL_CACHE if they need to include drivers/cache in SPL, eg: Agilex platform.
Regards Ley Foon
Tom:
help
Hi Tom
Regards
Ley Foon
Ley, Tom,
Ley:
Hi Simon
But you might not have CACHE enabled since you can enable SPL_CACHE without CACHE, see my suggestions below.
Regards Ley Foon
Tom:
I think this needs to depend on CACHE.
help
Can you move this up to the common part and make it:
obj-$(CONFIG_$(SPL_TPL_)CACHE) += cache/
This should then probably be $(SPL_TPL), too?
Although we don't have CONFIG_TPL_CACHE, yet, it might be better like that to prevent including cache drivers in TPL?
Hi Tom
Regards
Ley Foon
On Thu, Nov 28, 2019 at 7:38 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Ley, Tom,
Ley:
Hi Simon
Regards Ley Foon
Tom:
Okay.
help
Noted.
Okay.
Regards Ley Foon
Hi Tom
Regards
Ley Foon
Ley Foon Tan
Ley Foon Tan
Simon Goldschmidt
