[RFC PATCH 0/4] mkimage: sunxi_egon: add riscv support
This patchset tries to make mkimage -T sunxi_egon to be able to generate an eGON.BT0 image for Allwinner RISC-V SoCs (e.g. D1).
In addition, to keep the compatibility, it will still consider the architecture to be ARM when no architecture is specified.
This patchset is RFC because I have no idea whether the change to mkimage common code is proper (maybe we should just change default value to IH_ARCH_INVALID?).
Icenowy Zheng (4): mkimage: add a flag to describe whether -A is specified mkimage: sunxi_egon: refactor for multi-architecture support mkimage: sunxi_egon: add support for riscv sunxi: specify architecture when generating SPL boot image
scripts/Makefile.spl | 2 +- tools/imagetool.h | 1 + tools/mkimage.c | 1 + tools/sunxi_egon.c | 86 ++++++++++++++++++++++++++++++++++++++++---- 4 files changed, 82 insertions(+), 8 deletions(-)
The sunxi_egon type used to take no -A argument (because we assume sunxi targets are all ARM). However, as Allwinner D1 appears as the first RISC-V sunxi target, we need to support -A; in addition, as external projects rely on U-Boot mkimage to generate sunxi eGON.BT0 header, we need to keep compatibility with command line without -A.
As the default value of arch in mkimage is not proper (IH_ARCH_PPC instead of IH_ARCH_INVALID), to keep more compatibility, add an Aflag field to image parameters to describe whether an architecture is explicitly specified.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- tools/imagetool.h | 1 + tools/mkimage.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/tools/imagetool.h b/tools/imagetool.h index e229a34ffc..5dc28312c2 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -51,6 +51,7 @@ struct image_tool_params { int pflag; int vflag; int xflag; + int Aflag; int skipcpy; int os; int arch; diff --git a/tools/mkimage.c b/tools/mkimage.c index cc7b242faf..54d8e3835a 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -168,6 +168,7 @@ static void process_args(int argc, char **argv) show_valid_options(IH_ARCH); usage("Invalid architecture"); } + params.Aflag = 1; break; case 'b': if (add_content(IH_TYPE_FLATDT, optarg)) {
Hi Icenowy,
int Aflag;
aflag
-- 2.30.2
Refactor some functions in mkimage sunxi_egon type, in order to prepare for adding support for more CPU architectures (e.g. RISC-V). In addition, compatibility for operation w/o specified architecture is kept, in this case the architecture is assumed as ARM.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- tools/sunxi_egon.c | 63 ++++++++++++++++++++++++++++++++++++++++------ 1 file changed, 56 insertions(+), 7 deletions(-)
diff --git a/tools/sunxi_egon.c b/tools/sunxi_egon.c index a5299eb6a1..af649c392e 100644 --- a/tools/sunxi_egon.c +++ b/tools/sunxi_egon.c @@ -16,7 +16,25 @@
static int egon_check_params(struct image_tool_params *params) { - /* We just need a binary image file. */ + int arch; + + /* Assume ARM when no architecture specified for compatibility */ + if (params->Aflags) + arch = params->arch; + else + arch = IH_ARCH_ARM; + + /* + * Check whether the architecture is supported. + */ + switch(params->arch) { + case IH_ARCH_ARM: + break; + default: + return EXIT_FAILURE; + } + + /* We need a binary image file. */ return !params->dflag; }
@@ -25,10 +43,26 @@ static int egon_verify_header(unsigned char *ptr, int image_size, { const struct boot_file_head *header = (void *)ptr; uint32_t length; + int arch;
- /* First 4 bytes must be an ARM branch instruction. */ - if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) - return EXIT_FAILURE; + /* Assume ARM when no architecture specified for compatibility */ + if (params->Aflags) + arch = params->arch; + else + arch = IH_ARCH_ARM; + + /* + * First 4 bytes must be a branch instruction of the corresponding + * architecture. + */ + switch(params->arch) { + case IH_ARCH_ARM: + if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) + return EXIT_FAILURE; + break; + default: + return EXIT_FAILURE; /* Unknown architecture */ + }
if (memcmp(header->magic, BOOT0_MAGIC, sizeof(header->magic))) return EXIT_FAILURE; @@ -76,10 +110,25 @@ static void egon_set_header(void *buf, struct stat *sbuf, int infd, uint32_t *buf32 = buf; uint32_t checksum = 0, value; int i; + int arch;
- /* Generate an ARM branch instruction to jump over the header. */ - value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); - header->b_instruction = cpu_to_le32(value); + /* Assume ARM when no architecture specified for compatibility */ + if (params->Aflags) + arch = params->arch; + else + arch = IH_ARCH_ARM; + + /* + * Different architectures need different first instruction to + * branch to the body. + */ + switch (params->arch) { + case IH_ARCH_ARM: + /* Generate an ARM branch instruction to jump over the header. */ + value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); + header->b_instruction = cpu_to_le32(value); + break; + }
memcpy(header->magic, BOOT0_MAGIC, sizeof(header->magic)); header->check_sum = cpu_to_le32(BROM_STAMP_VALUE);
- int arch;
- /* Assume ARM when no architecture specified for compatibility */
- if (params->Aflags)
Since this should be params->Aflag and you fix in the next part, please fix it in this patch for the next version. I'm pointing this out here because aside from this, everything looks fine and I agree with the overall approach. Thanks.
There's now a sun20i family in sunxi, which uses RISC-V CPU.
Add support for making eGON.BT0 image for RISC-V.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- tools/sunxi_egon.c | 35 +++++++++++++++++++++++++++++------ 1 file changed, 29 insertions(+), 6 deletions(-)
diff --git a/tools/sunxi_egon.c b/tools/sunxi_egon.c index af649c392e..0fff25843f 100644 --- a/tools/sunxi_egon.c +++ b/tools/sunxi_egon.c @@ -19,7 +19,7 @@ static int egon_check_params(struct image_tool_params *params) int arch;
/* Assume ARM when no architecture specified for compatibility */ - if (params->Aflags) + if (params->Aflag) arch = params->arch; else arch = IH_ARCH_ARM; @@ -27,8 +27,9 @@ static int egon_check_params(struct image_tool_params *params) /* * Check whether the architecture is supported. */ - switch(params->arch) { + switch(arch) { case IH_ARCH_ARM: + case IH_ARCH_RISCV: break; default: return EXIT_FAILURE; @@ -46,7 +47,7 @@ static int egon_verify_header(unsigned char *ptr, int image_size, int arch;
/* Assume ARM when no architecture specified for compatibility */ - if (params->Aflags) + if (params->Aflag) arch = params->arch; else arch = IH_ARCH_ARM; @@ -55,11 +56,15 @@ static int egon_verify_header(unsigned char *ptr, int image_size, * First 4 bytes must be a branch instruction of the corresponding * architecture. */ - switch(params->arch) { + switch(arch) { case IH_ARCH_ARM: if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) return EXIT_FAILURE; break; + case IH_ARCH_RISCV: + if ((le32_to_cpu(header->b_instruction) & 0x00000fff) != 0x0000006f) + return EXIT_FAILURE; + break; default: return EXIT_FAILURE; /* Unknown architecture */ } @@ -113,7 +118,7 @@ static void egon_set_header(void *buf, struct stat *sbuf, int infd, int arch;
/* Assume ARM when no architecture specified for compatibility */ - if (params->Aflags) + if (params->Aflag) arch = params->arch; else arch = IH_ARCH_ARM; @@ -122,12 +127,30 @@ static void egon_set_header(void *buf, struct stat *sbuf, int infd, * Different architectures need different first instruction to * branch to the body. */ - switch (params->arch) { + switch (arch) { case IH_ARCH_ARM: /* Generate an ARM branch instruction to jump over the header. */ value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); header->b_instruction = cpu_to_le32(value); break; + case IH_ARCH_RISCV: + /* + * Generate a RISC-V JAL instruction with rd=x0 + * (pseudo instruction J, jump without side effects). + * + * The following weird bit operation maps imm[20] + * to inst[31], imm[10:1] to inst[30:21], + * imm[11] to inst[20], imm[19:12] to inst[19:12], + * and imm[0] is dropped (because 1-byte RISC-V instruction + * is not allowed). + */ + value = 0x0000006f | + ((sizeof(struct boot_file_head) & 0x00100000) << 11) | + ((sizeof(struct boot_file_head) & 0x000007fe) << 20) | + ((sizeof(struct boot_file_head) & 0x00000800) << 9) | + ((sizeof(struct boot_file_head) & 0x000ff000) << 0); + header->b_instruction = cpu_to_le32(value); + break; }
As mkimage -T sunxi_egon now gains support for -A parameter, specify the architecture when generating SPL boot image for sunxi.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- scripts/Makefile.spl | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 5be1a9ba1b..c13a41a243 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -414,7 +414,7 @@ endif $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mkimage)
-MKIMAGEFLAGS_sunxi-spl.bin = -T sunxi_egon \ +MKIMAGEFLAGS_sunxi-spl.bin = -A $(ARCH) -T sunxi_egon \ -n $(CONFIG_DEFAULT_DEVICE_TREE)
OBJCOPYFLAGS_u-boot-spl-dtb.hex := -I binary -O ihex --change-address=$(CONFIG_SPL_TEXT_BASE)
Icenowy Zheng
