[U-Boot-Users] Serial Port Configuration on MPC8xx
Hi.
I use smc1 for the output of Uboot. So I set #define CONFIG_8xx_CONS_SMC1.
In linux config I set SMC1 as my console output.
I would like to use SMC2 in linux also. So I added use SMC2 as UART in linux conf.
For the SMC1 it works fine as Uboot makes the config of the BRG and IO when CONFIG_8xx_CONS_SMC1 is set. But for SMC2 no config is done by Uboot and I can't set CONFIG_8xx_CONS_SMC2 & CONFIG_8xx_CONS_SMC1.
Is there something clean to do under Uboot to make it configure SMC2 ? Where should this init done ?
Thanks
Regards
Chris
Dear Chris,
in message D96E2AFA0DF3D211B139009027454948034CBEAF@helios.gnv.tcc.thomson-csf.com you wrote:
OK so far.
OK, too. This means you will have the serial console on SMC1, and SMC2 is used as second serial port (/dev/ttyS1).
This is because U-Boot uses SMC1.
When U-Boot is configured for console on SMC1, it will not use SMC2 for anything, and thus it will not initialize it.
Why should U-Boot initialize a port it does not use?
This should be done, and actually it _is_ done, in the Linux UART driver. No help from U-Boot needed here.
Ummm... what exactly is the problem?
Christophe.LINDHEIMER@fr.thalesgroup.com
