[U-Boot] [PATCH] [OneNAND IPL] Refactor OneNAND IPL code
Refactoring the OneNAND IPL code
and some minor fixed: - Remove unnecessary header file - Fix wrong access at read interrupt - The recent OneNAND has 4KiB pagesize
Also Board can override OneNAND IPL image
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com
diff --git a/Makefile b/Makefile index 0b61d05..961c007 100644 --- a/Makefile +++ b/Makefile @@ -285,6 +285,7 @@ endif ifeq ($(CONFIG_ONENAND_U_BOOT),y) ONENAND_IPL = onenand_ipl U_BOOT_ONENAND = $(obj)u-boot-onenand.bin +ONENAND_BIN ?= $(obj)onenand_ipl/onenand-ipl-2k.bin endif
__OBJS := $(subst $(obj),,$(OBJS)) @@ -378,8 +379,7 @@ $(ONENAND_IPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C onenand_ipl/board/$(BOARDDIR) all
$(U_BOOT_ONENAND): $(ONENAND_IPL) $(obj)u-boot.bin - cat $(obj)onenand_ipl/onenand-ipl-2k.bin $(obj)u-boot.bin > $(obj)u-boot-onenand.bin - cat $(obj)onenand_ipl/onenand-ipl-4k.bin $(obj)u-boot.bin > $(obj)u-boot-flexonenand.bin + cat $(ONENAND_BIN) $(obj)u-boot.bin > $(obj)u-boot-onenand.bin
$(VERSION_FILE): @( printf '#define U_BOOT_VERSION "U-Boot %s%s"\n' "$(U_BOOT_VERSION)" \ @@ -3259,8 +3259,6 @@ zylonite_config : #########################################################################
apollon_config : unconfig - @mkdir -p $(obj)include - @mkdir -p $(obj)onenand_ipl/board/apollon @echo "#define CONFIG_ONENAND_U_BOOT" > $(obj)include/config.h @$(MKCONFIG) $(@:_config=) arm arm1136 apollon NULL omap24xx @echo "CONFIG_ONENAND_U_BOOT = y" >> $(obj)include/config.mk @@ -3742,7 +3740,8 @@ clean: $(obj)cpu/blackfin/bootrom-asm-offsets.[chs] @rm -f $(obj)include/bmp_logo.h @rm -f $(obj)nand_spl/{u-boot.lds,u-boot-spl,u-boot-spl.map,System.map} - @rm -f $(obj)onenand_ipl/onenand-{ipl,ipl.bin,ipl-2k.bin,ipl-4k.bin,ipl.map} + @rm -f $(obj)onenand_ipl/onenand-{ipl,ipl.bin,ipl.map} + @rm -f $(ONENAND_BIN) @rm -f $(obj)onenand_ipl/u-boot.lds @rm -f $(TIMESTAMP_FILE) $(VERSION_FILE) @find $(OBJTREE) -type f \ diff --git a/onenand_ipl/onenand_boot.c b/onenand_ipl/onenand_boot.c index 63995ce..22baebb 100644 --- a/onenand_ipl/onenand_boot.c +++ b/onenand_ipl/onenand_boot.c @@ -24,7 +24,6 @@ */
#include <common.h> -#include <version.h>
#include "onenand_ipl.h"
diff --git a/onenand_ipl/onenand_ipl.h b/onenand_ipl/onenand_ipl.h index 412572a..7ebb3e3 100644 --- a/onenand_ipl/onenand_ipl.h +++ b/onenand_ipl/onenand_ipl.h @@ -28,8 +28,9 @@
#define THIS_ONENAND(a) (CONFIG_SYS_ONENAND_BASE + (a))
-#define READ_INTERRUPT() \ - onenand_readw(THIS_ONENAND(ONENAND_REG_INTERRUPT)) +#define READ_INTERRUPT() onenand_readw(ONENAND_REG_INTERRUPT)
+extern int (*onenand_read_page)(ulong block, ulong page, + u_char *buf, int pagesize); extern int onenand_read_block(unsigned char *buf); #endif diff --git a/onenand_ipl/onenand_read.c b/onenand_ipl/onenand_read.c index d1a842d..8d0df81 100644 --- a/onenand_ipl/onenand_read.c +++ b/onenand_ipl/onenand_read.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2005-2008 Samsung Electronis + * (C) Copyright 2005-2009 Samsung Electronics * Kyungmin Park kyungmin.park@samsung.com * * See file CREDITS for list of people who contributed to this @@ -37,8 +37,10 @@ extern void *memcpy32(void *dest, void *src, int size); #endif
+int (*onenand_read_page)(ulong block, ulong page, u_char *buf, int pagesize); + /* read a page with ECC */ -static inline int onenand_read_page(ulong block, ulong page, +static int generic_onenand_read_page(ulong block, ulong page, u_char * buf, int pagesize) { unsigned long *base; @@ -89,9 +91,25 @@ static inline int onenand_read_page(ulong block, ulong page, return 0; }
-#define ONENAND_START_PAGE 1 +#ifndef CONFIG_ONENAND_START_PAGE +#define CONFIG_ONENAND_START_PAGE 1 +#endif #define ONENAND_PAGES_PER_BLOCK 64
+static void onenand_generic_init(int *page_is_4KiB, int *page) +{ + int dev_id, density; + + if (onenand_readw(ONENAND_REG_TECHNOLOGY)) + *page_is_4KiB = 1; + dev_id = onenand_readw(ONENAND_REG_DEVICE_ID); + density = dev_id >> ONENAND_DEVICE_DENSITY_SHIFT; + density &= ONENAND_DEVICE_DENSITY_MASK; + if (density >= ONENAND_DEVICE_DENSITY_4Gb && + !(dev_id & ONENAND_DEVICE_IS_DDP)) + *page_is_4KiB = 1; +} + /** * onenand_read_block - Read CONFIG_SYS_MONITOR_LEN from begining * of OneNAND, skipping bad blocks @@ -99,24 +117,28 @@ static inline int onenand_read_page(ulong block, ulong page, */ int onenand_read_block(unsigned char *buf) { - int block; - int page = ONENAND_START_PAGE, offset = 0; - int pagesize = 0, erase_shift = 0; - int erasesize = 0, nblocks = 0; + int block, nblocks; + int page = CONFIG_ONENAND_START_PAGE, offset = 0; + int pagesize, erasesize, erase_shift; + int page_is_4KiB = 0; + + onenand_read_page = generic_onenand_read_page; + + onenand_generic_init(&page_is_4KiB, &page);
- if (onenand_readw(ONENAND_REG_TECHNOLOGY)) { - pagesize = 4096; /* MLC OneNAND has 4KiB pagesize */ + if (page_is_4KiB) { + pagesize = 4096; /* OneNAND has 4KiB pagesize */ erase_shift = 18; } else { - pagesize = 2048; + pagesize = 2048; /* OneNAND has 2KiB pagesize */ erase_shift = 17; }
- erasesize = ONENAND_PAGES_PER_BLOCK * pagesize; + erasesize = (1 << erase_shift); nblocks = (CONFIG_SYS_MONITOR_LEN + erasesize - 1) >> erase_shift;
/* NOTE: you must read page from page 1 of block 0 */ - /* read the block page by page*/ + /* read the block page by page */ for (block = 0; block < nblocks; block++) { for (; page < ONENAND_PAGES_PER_BLOCK; page++) { if (onenand_read_page(block, page, buf + offset,
Applied to u-boot-nand-flash
-Scott
Kyungmin Park
Scott Wood
