[U-Boot] [PATCH] mpc8349itx: allow SATA boot from the onboard SIL1334
This patch allows using of SATA devices connected to the onboard PCI SIL1334 SATA controller.
Signed-off-by: Valeriy Glushkov gvv@lstec.com --- include/configs/MPC8349ITX.h | 23 +++++++++++++++++++++-- 1 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index f1b5566..38a7386 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -78,6 +78,7 @@ #ifdef CONFIG_MPC8349ITX #define CONFIG_COMPACT_FLASH /* The CF card interface on the back of the board */ #define CONFIG_VSC7385_ENET /* VSC7385 ethernet support */ +#define CONFIG_SATA_SIL3114 /* SIL3114 SATA controller */ #endif
#define CONFIG_PCI @@ -142,7 +143,16 @@
#define ATA_RESET_TIME 1 /* If a CF card is not inserted, time out quickly */
-#define CONFIG_DOS_PARTITION +#endif + +/* + * SATA + */ +#ifdef CONFIG_SATA_SIL3114 + +#define CONFIG_SYS_SATA_MAX_DEVICE 4 +#define CONFIG_LIBATA +#define CONFIG_LBA48
#endif
@@ -454,9 +464,18 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_CMD_DHCP #define CONFIG_CMD_SDRAM
+#if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) + #define CONFIG_DOS_PARTITION + #define CONFIG_CMD_FAT +#endif + #ifdef CONFIG_COMPACT_FLASH #define CONFIG_CMD_IDE - #define CONFIG_CMD_FAT +#endif + +#ifdef CONFIG_SATA_SIL3114 + #define CONFIG_CMD_SATA + #define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_PCI
applied.
Thanks,
Kim
Kim Phillips
Valeriy Glushkov
