[PATCH 1/1] efi_loader: efi_dp_from_lo() should skip VenMedia node
The 'efidebug boot dump' command should not display the VenMedia() device path node preceding the device path of the initial ram disk.
By letting efi_dp_from_lo() skip the VenMedia() device path node we can simplify the coding.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_device_path.c | 2 +- lib/efi_loader/efi_helper.c | 19 +++++-------------- 2 files changed, 6 insertions(+), 15 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index aaf1999d46..7f2aa239de 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1287,7 +1287,7 @@ efi_device_path *efi_dp_from_lo(struct efi_load_option *lo,
vendor = (struct efi_device_path_vendor *)fp; if (!guidcmp(&vendor->guid, guid)) - return efi_dp_dup(fp); + return efi_dp_dup(efi_dp_next(fp)); } log_debug("VenMedia(%pUl) not found in %ls\n", &guid, lo->label);
diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c index 485384b7ee..b80a6e07df 100644 --- a/lib/efi_loader/efi_helper.c +++ b/lib/efi_loader/efi_helper.c @@ -68,10 +68,8 @@ out: */ struct efi_device_path *efi_get_dp_from_boot(const efi_guid_t guid) { - struct efi_device_path *file_path = NULL; - struct efi_device_path *tmp = NULL; struct efi_load_option lo; - void *var_value = NULL; + void *var_value; efi_uintn_t size; efi_status_t ret; u16 var_name[16]; @@ -86,18 +84,11 @@ struct efi_device_path *efi_get_dp_from_boot(const efi_guid_t guid)
ret = efi_deserialize_load_option(&lo, var_value, &size); if (ret != EFI_SUCCESS) - goto out; - - tmp = efi_dp_from_lo(&lo, &guid); - if (!tmp) - goto out; + goto err;
- /* efi_dp_dup will just return NULL if efi_dp_next is NULL */ - file_path = efi_dp_dup(efi_dp_next(tmp)); + return efi_dp_from_lo(&lo, &guid);
-out: - efi_free_pool(tmp); +err: free(var_value); - - return file_path; + return NULL; } -- 2.30.2
} log_debug("VenMedia(%pUl) not found in %ls\n", &guid, lo->label);return efi_dp_dup(efi_dp_next(fp));
- void *var_value; efi_uintn_t size; efi_status_t ret; u16 var_name[16];
goto out;
- if (!tmp)
goto out;
goto err;
- return efi_dp_from_lo(&lo, &guid);
-out:
- return file_path;
- return NULL;
2.30.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
