[U-Boot] Please pull u-boot-sunxi master
Hi Tom,
Here is the first sunxi pull-req for v2016.05, it contains:
-A sync of the sunxi dts files with the kernel -Addition of support for 10 new boards -Various fixes
The following changes since commit 0764f24ae6bc937e358990c357f7452b4d5351e3:
net: Move CONFIG_RTL8169 to Kconfig (2016-03-22 12:19:53 -0400)
http://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to e449e840c5adf728ddd308501af3115656aa9a60:
sunxi: A83T: fix 32bit overflow warning (2016-03-23 22:04:13 +0100)
---------------------------------------------------------------- Alex Kaplan (1): sunxi: Enable composite video out on the CHIP
Boris Brezillon (1): sunxi: Fix DCDC2 output in CHIP_defconfig
Chen-Yu Tsai (3): sunxi: Add defconfig for Cubietruck Plus sunxi: Add defconfig for Sinlinx SinA31s sunxi: Support SID e-fuses on A83T and H3
Hans de Goede (22): sunxi: A23: Fix some revisions needing a different magic sram poke include/dt-bindings: Sync some files with the kernel sunxi: Sync dts files with the upstream kernel sunxi: Fix clock_twi_onoff for sun6i sunxi: Fix clock_twi_onoff for sun8i-a83 sunxi: Fix clock_twi_onoff for sun9i sunxi: Add defconfig and dts for colorfly e708 q1 tablet sunxi: Add defconfig and dts for Difrence DIT4350 tablet sunxi: Add defconfig and dts for the Polaroid MID2809PXE4 tablet sunxi: Add defconfig and dts for Dserve DSRV9703C tablet sunxi: Add defconfig and dts for Orange Pi 2 SBC sunxi: Enable realtek phy support sunxi: Add support for USB vbus pin for USB3 sunxi: Specify USB vbus pins for orangepi boards sunxi: Add a bunch of missing compatible strings to sunxi_gpio.c spl: Print from which mmc slot spl is trying to boot sunxi: Enable support for the eMMC found on the orangepi plus sunxi: Fix 2nd usb controller on sun4i/sun7i no longer working sunxi: Fix gmac not working due to cpu_eth_init no longer being called sunxi: Turn satapwr on from board_init sunxi: Specify SATAPWR pin for Orangepi Plus sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/Kconfig
Lawrence Yu (1): sunxi: Configure only LVDS pins instead of all LCD pins when LVDS interface selected
Marcus Cooper (1): sun7i: Add defconfig for the Itead Ibox
Peter Korsgaard (1): sunxi: Add defconfig for yones toptech bs1078-v2 tablet
Stefan Roese (1): sunxi: Add defconfig for icnova-a20-swac
vishnupatekar (2): sunxi: sinovoip-bpi-m3: drop LDO settings from defconfig sunxi: A83T: fix 32bit overflow warning
arch/arm/Kconfig | 1 + arch/arm/cpu/armv7/sunxi/board.c | 50 +- arch/arm/cpu/armv7/sunxi/clock.c | 35 + arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 26 - arch/arm/cpu/armv7/sunxi/clock_sun9i.c | 4 +- arch/arm/cpu/armv7/sunxi/dram_sun8i_a83t.c | 2 +- arch/arm/cpu/armv7/sunxi/usb_phy.c | 1 + arch/arm/dts/Makefile | 13 +- arch/arm/dts/axp22x.dtsi | 145 ++++ arch/arm/dts/sun4i-a10-a1000.dts | 4 + arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts | 22 + arch/arm/dts/sun4i-a10-cubieboard.dts | 4 + arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts | 281 +++++++ arch/arm/dts/sun4i-a10-gemei-g9.dts | 63 +- arch/arm/dts/sun4i-a10-inet1.dts | 48 ++ arch/arm/dts/sun4i-a10-inet97fv2.dts | 127 +++- arch/arm/dts/sun4i-a10-inet9f-rev03.dts | 181 +++++ arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts | 86 +-- arch/arm/dts/sun4i-a10-jesurun-q5.dts | 15 + arch/arm/dts/sun4i-a10-marsboard.dts | 23 + arch/arm/dts/sun4i-a10-mk802.dts | 37 + arch/arm/dts/sun4i-a10-olinuxino-lime.dts | 12 + arch/arm/dts/sun4i-a10-pcduino.dts | 58 +- arch/arm/dts/sun4i-a10-pcduino2.dts | 78 ++ arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts | 69 ++ arch/arm/dts/sun4i-a10.dtsi | 153 +++- arch/arm/dts/sun5i-a10s-auxtek-t004.dts | 14 + arch/arm/dts/sun5i-a10s-olinuxino-micro.dts | 2 +- arch/arm/dts/sun5i-a13-difrnce-dit4350.dts | 226 ++++++ arch/arm/dts/sun5i-a13-empire-electronix-d709.dts | 19 +- arch/arm/dts/sun5i-a13-inet-98v-rev2.dts | 26 +- arch/arm/dts/sun5i-a13-utoo-p66.dts | 30 + arch/arm/dts/sun5i-q8-common.dtsi | 10 + arch/arm/dts/sun5i-r8-chip.dts | 47 +- arch/arm/dts/sun5i.dtsi | 31 + arch/arm/dts/sun6i-a31-colombus.dts | 24 + arch/arm/dts/sun6i-a31-hummingbird.dts | 132 ++-- arch/arm/dts/sun6i-a31.dtsi | 65 +- arch/arm/dts/sun6i-a31s-colorfly-e708-q1.dts | 208 ++++++ arch/arm/dts/sun6i-a31s-primo81.dts | 247 ++++++- arch/arm/dts/sun6i-a31s-sina31s-core.dtsi | 142 ++++ arch/arm/dts/sun6i-a31s-sina31s.dts | 153 ++++ .../arm/dts/sun6i-a31s-yones-toptech-bs1078-v2.dts | 205 ++++++ arch/arm/dts/sun7i-a20-bananapi.dts | 78 +- arch/arm/dts/sun7i-a20-cubieboard2.dts | 23 + arch/arm/dts/sun7i-a20-cubietruck.dts | 4 + arch/arm/dts/sun7i-a20-icnova-swac.dts | 169 +++++ arch/arm/dts/sun7i-a20-itead-ibox.dts | 125 ++++ arch/arm/dts/sun7i-a20-lamobo-r1.dts | 10 - arch/arm/dts/sun7i-a20-mk808c.dts | 39 + arch/arm/dts/sun7i-a20-olimex-som-evb.dts | 95 ++- arch/arm/dts/sun7i-a20-olinuxino-lime.dts | 12 + arch/arm/dts/sun7i-a20-olinuxino-lime2.dts | 47 ++ arch/arm/dts/sun7i-a20-olinuxino-micro.dts | 6 + arch/arm/dts/sun7i-a20-orangepi-mini.dts | 33 + arch/arm/dts/sun7i-a20-orangepi.dts | 29 + arch/arm/dts/sun7i-a20-pcduino3-nano.dts | 69 +- arch/arm/dts/sun7i-a20-pcduino3.dts | 58 +- arch/arm/dts/sun7i-a20-wexler-tab7200.dts | 90 ++- arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts | 187 ++++- arch/arm/dts/sun7i-a20.dtsi | 113 ++- arch/arm/dts/sun8i-a23-a33.dtsi | 71 +- arch/arm/dts/sun8i-a23-gt90h-v4.dts | 120 ++- arch/arm/dts/sun8i-a23-polaroid-mid2809pxe04.dts | 243 +++++++ arch/arm/dts/sun8i-a23.dtsi | 25 + arch/arm/dts/sun8i-a33-sinlinx-sina33.dts | 83 ++- arch/arm/dts/sun8i-a33.dtsi | 45 ++ arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 65 ++ arch/arm/dts/sun8i-a83t.dtsi | 125 ++-- arch/arm/dts/sun8i-h3-orangepi-2.dts | 186 +++++ arch/arm/dts/sun8i-h3-orangepi-pc.dts | 69 ++ arch/arm/dts/sun8i-h3-orangepi-plus.dts | 63 ++ arch/arm/dts/sun8i-h3.dtsi | 189 +++-- arch/arm/dts/sun8i-q8-common.dtsi | 96 ++- arch/arm/dts/sun9i-a80-cubieboard4.dts | 36 + arch/arm/dts/sun9i-a80-optimus.dts | 48 +- arch/arm/dts/sun9i-a80.dtsi | 204 +++++- arch/arm/dts/sunxi-itead-core-common.dtsi | 136 ++++ arch/arm/dts/sunxi-q8-common.dtsi | 6 + arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 7 + arch/arm/include/asm/arch-sunxi/sys_proto.h | 6 +- board/sunxi/Kconfig | 6 + board/sunxi/MAINTAINERS | 31 + board/sunxi/ahci.c | 8 - board/sunxi/board.c | 18 +- board/sunxi/gmac.c | 14 +- common/spl/spl.c | 6 +- configs/A10-OLinuXino-Lime_defconfig | 1 - configs/A10s-OLinuXino-M_defconfig | 1 - configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/A20-OLinuXino-Lime_defconfig | 1 - configs/A20-OLinuXino_MICRO_defconfig | 1 - configs/A20-Olimex-SOM-EVB_defconfig | 1 - configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T003_defconfig | 1 - configs/Auxtek-T004_defconfig | 1 - configs/Bananapi_defconfig | 1 - configs/Bananapro_defconfig | 1 - configs/CHIP_defconfig | 3 +- configs/CSQ_CS908_defconfig | 1 - configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 1 - configs/Cubieboard2_defconfig | 1 - configs/Cubieboard_defconfig | 1 - configs/Cubietruck_defconfig | 1 - configs/Cubietruck_plus_defconfig | 18 + configs/Empire_electronix_d709_defconfig | 1 - configs/Hummingbird_A31_defconfig | 1 - configs/Hyundai_A7HD_defconfig | 1 - configs/Itead_Ibox_A20_defconfig | 16 + configs/Lamobo_R1_defconfig | 1 - configs/Linksprite_pcDuino3_Nano_defconfig | 1 - configs/Linksprite_pcDuino3_defconfig | 1 - configs/Linksprite_pcDuino_defconfig | 1 - configs/MK808C_defconfig | 1 - configs/MSI_Primo73_defconfig | 1 - configs/MSI_Primo81_defconfig | 1 - configs/Marsboard_A10_defconfig | 1 - configs/Mele_A1000G_quad_defconfig | 1 - configs/Mele_A1000_defconfig | 1 - configs/Mele_I7_defconfig | 1 - configs/Mele_M3_defconfig | 1 - configs/Mele_M5_defconfig | 1 - configs/Mele_M9_defconfig | 1 - configs/Mini-X_defconfig | 1 - configs/Orangepi_defconfig | 1 - configs/Orangepi_mini_defconfig | 1 - configs/Sinlinx_SinA31s_defconfig | 20 + configs/Sinlinx_SinA33_defconfig | 1 - configs/Sinovoip_BPI_M2_defconfig | 1 - configs/Sinovoip_BPI_M3_defconfig | 2 - configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 1 - configs/Wits_Pro_A20_DKT_defconfig | 1 - configs/Wobo_i5_defconfig | 1 - configs/Yones_Toptech_BD1078_defconfig | 1 - configs/Yones_Toptech_BS1078_V2_defconfig | 24 + configs/ba10_tv_box_defconfig | 1 - configs/colorfly_e708_q1_defconfig | 25 + configs/difrnce_dit4350_defconfig | 23 + configs/dserve_dsrv9703c_defconfig | 22 + configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/i12-tvbox_defconfig | 1 - configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/icnova-a20-swac_defconfig | 21 + configs/inet1_defconfig | 1 - configs/inet97fv2_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/inet9f_rev03_defconfig | 1 - configs/jesurun_q5_defconfig | 1 - configs/mixtile_loftq_defconfig | 1 - configs/mk802_a10s_defconfig | 1 - configs/mk802_defconfig | 1 - configs/mk802ii_defconfig | 1 - configs/orangepi_2_defconfig | 18 + configs/orangepi_pc_defconfig | 3 + configs/orangepi_plus_defconfig | 4 + configs/polaroid_mid2809pxe04_defconfig | 25 + configs/pov_protab2_ips9_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 - configs/sunxi_Gemei_G9_defconfig | 1 - drivers/gpio/sunxi_gpio.c | 15 +- drivers/usb/host/ehci-sunxi.c | 13 +- drivers/usb/host/ohci-sunxi.c | 15 +- drivers/video/sunxi_display.c | 4 + include/configs/sunxi-common.h | 1 + include/dt-bindings/clock/sun4i-a10-pll2.h | 53 ++ include/dt-bindings/input/input.h | 510 +------------ include/dt-bindings/input/linux-event-codes.h | 805 +++++++++++++++++++++ 179 files changed, 6749 insertions(+), 1173 deletions(-) create mode 100644 arch/arm/dts/axp22x.dtsi create mode 100644 arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts create mode 100644 arch/arm/dts/sun4i-a10-pcduino2.dts create mode 100644 arch/arm/dts/sun5i-a13-difrnce-dit4350.dts create mode 100644 arch/arm/dts/sun6i-a31s-colorfly-e708-q1.dts create mode 100644 arch/arm/dts/sun6i-a31s-sina31s-core.dtsi create mode 100644 arch/arm/dts/sun6i-a31s-sina31s.dts create mode 100644 arch/arm/dts/sun6i-a31s-yones-toptech-bs1078-v2.dts create mode 100644 arch/arm/dts/sun7i-a20-icnova-swac.dts create mode 100644 arch/arm/dts/sun7i-a20-itead-ibox.dts create mode 100644 arch/arm/dts/sun8i-a23-polaroid-mid2809pxe04.dts create mode 100644 arch/arm/dts/sun8i-a83t-cubietruck-plus.dts create mode 100644 arch/arm/dts/sun8i-h3-orangepi-2.dts create mode 100644 arch/arm/dts/sunxi-itead-core-common.dtsi create mode 100644 configs/Cubietruck_plus_defconfig create mode 100644 configs/Itead_Ibox_A20_defconfig create mode 100644 configs/Sinlinx_SinA31s_defconfig create mode 100644 configs/Yones_Toptech_BS1078_V2_defconfig create mode 100644 configs/colorfly_e708_q1_defconfig create mode 100644 configs/difrnce_dit4350_defconfig create mode 100644 configs/dserve_dsrv9703c_defconfig create mode 100644 configs/icnova-a20-swac_defconfig create mode 100644 configs/orangepi_2_defconfig create mode 100644 configs/polaroid_mid2809pxe04_defconfig create mode 100644 include/dt-bindings/clock/sun4i-a10-pll2.h create mode 100644 include/dt-bindings/input/linux-event-codes.h
Regards,
Hans
On Wed, Mar 23, 2016 at 11:13:55PM +0100, Hans de Goede wrote:
Hi Tom,
Hans de Goede
