[U-Boot] Clock tree in U-Boot
Hi all,
Heiko's recent patch set [1] to control the LDB clock on i.MX5/6 boards makes it painfully obvious that some semblance of clock tree is needed, even if it starts off as a shell.
We currently have routines declared in [2] that should be moved into a more common spot:
void clk_enable(struct clk *clk); void clk_disable(struct clk *clk); u32 clk_get_rate(struct clk *clk); int clk_set_rate(struct clk *clk, unsigned long rate); long clk_round_rate(struct clk *clk, unsigned long rate); int clk_set_parent(struct clk *clk, struct clk *parent); int clk_get_usecount(struct clk *clk); struct clk *clk_get_parent(struct clk *clk);
Can we get some agreement on a proper subset of [3] that's appropriate for use in U-Boot?
My thought is that the list above, plus some form of clk_get() and/or clk_get_sys() would be a good start.
Please advise,
Eric
[1] http://lists.denx.de/pipermail/u-boot/2015-April/thread.html#210677 [2] http://git.denx.de/?p=u-boot.git;a=blob;f=drivers/video/ipu.h#l245 [3] https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/include...
Hi Eric,
On 17 April 2015 at 10:12, Eric Nelson eric.nelson@boundarydevices.com wrote:
Hi all,
Please advise,
I'd like to see this. It should use driver model I think. The above list looks good to me.
For clk_get(), we could support claiming of clocks so we know when we can turn off its parent / automatically enable it / etc. But perhaps as a first step just implementing a uclass and a driver for one device would be a good start.
Eric
Eric Nelson
