[RESEND PATCH 1/3] Nokia RX-51: Update documentation about ext2/3/4
Since commit 25c5b6517854 ("Nokia RX-51: Do not try calling both ext2load and ext4load") command ext4load is used for all ext2/3/4 fs variants.
Signed-off-by: Pali Rohár pali@kernel.org --- doc/README.nokia_rx51 | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/doc/README.nokia_rx51 b/doc/README.nokia_rx51 index 7f22ed49bd75..1be077514f03 100644 --- a/doc/README.nokia_rx51 +++ b/doc/README.nokia_rx51 @@ -44,8 +44,7 @@ Boot from SD or eMMC in this order: * 1.2 find uImage on first fat partition * 1.3 find zImage on first fat partition * 1.4 same order for 2. - 4. fat partition - * 2. same as 1. but for ext2/3 partition - * 3. same as 1. but for ext4 partition + * 2. same as 1. but for ext2/3/4 partition
Available additional commands/variables: @@ -70,7 +69,7 @@ Additional variables for loading files from mmc:
* mmc ${mmcnum} (0 - external, 1 - internal) * partition number ${mmcpart} (1 - 4) - * parition type ${mmctype} (fat, ext2, ext4) + * partition type ${mmctype} (fat, ext2, ext4; ext2 is just alias for ext4)
Additional variables for booting kernel:
This change contains update for doc/README.nokia_rx51 documentation file with information how to load U-Boot image to device RAM without need to flash it and also how to flash it into OneNAND via 0xFFFF flasher.
Signed-off-by: Pali Rohár pali@kernel.org --- doc/README.nokia_rx51 | 45 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/doc/README.nokia_rx51 b/doc/README.nokia_rx51 index 1be077514f03..e739b02088ea 100644 --- a/doc/README.nokia_rx51 +++ b/doc/README.nokia_rx51 @@ -22,6 +22,51 @@ following repository:
https://github.com/pali/u-boot-maemo
+To generate combined.bin image from u-boot.bin and kernel.bin (either uImage +or zImage) use: + + sh u-boot-gen-combined u-boot.bin kernel.bin combined.bin + +Original Maemo Fremantle PR1.3 zImage kernel binary is available at: + + http://repository.maemo.org/pool/maemo5.0/free/k/kernel/kernel_2.6.28-201031... + +To unpack it (from DEB/AR, TAR and FIASCO) call commands: + + ar x kernel_2.6.28-20103103+0m5_armel.deb data.tar.gz + tar -O -xf data.tar.gz ./boot/zImage-2.6.28-20103103+0m5.fiasco > kernel_2.6.28-20103103+0m5.fiasco + 0xFFFF -M kernel_2.6.28-20103103+0m5.fiasco -u + +Flashed image must start with 2 kB "NOLO!img" header which contains size of +the image. Header consist of bytes "NOLO!img\x02\x00\x00\x00\x00\x00\x00\x00" +followed by 4 byte little endian size of the image and rest of the 2 kB header +are just zero bytes. + +Nokia proprietary flasher and also open source 0xFFFF flasher automatically +prepend required "NOLO!img" header and both applications expect that image +does not contain "NOLO!img" header. Adding "NOLO!img" header is required +only in case using "nandwrite" tool for flashing. + +Open source 0xFFFF flasher is available in following repository: + + https://github.com/pali/0xFFFF + +It is possible to load u-boot.bin via USB to N900 RAM and boot it without +need to flashing it. Via 0xFFFF running at host PC it is done: + + 0xFFFF -m u-boot.bin -l -b + +0xFFFF support also flashing kernel image either via USB or directly on +N900 device. Flashing u-boot/kernel/combined image is done as: + + 0xFFFF -m combined.bin -f + +Via 0xFFFF is possible to generate also standard flashable image in Nokia +FIASCO format which contains metadata information like device identification +(RX-51) and version string (v2021.04): + + 0xFFFF -m RX-51:v2021.04:kernel:u-boot.bin -g u-boot.fiasco + There is support for hardware watchdog. Hardware watchdog is started by NOLO so u-boot must kick watchdog to prevent reboot device (but not very often, max every 2 seconds). There is also support for framebuffer display
Thank you for adding all this information.
In the restructured text (patch 3), please use:
.. code-block:: bash
- sh u-boot-gen-combined u-boot.bin kernel.bin combined.bin
- ar x kernel_2.6.28-20103103+0m5_armel.deb data.tar.gz
- tar -O -xf data.tar.gz ./boot/zImage-2.6.28-20103103+0m5.fiasco > kernel_2.6.28-20103103+0m5.fiasco
- 0xFFFF -M kernel_2.6.28-20103103+0m5.fiasco -u
%s/Flashed/The flashed/
%s/size/the size/
%/Header consist/The header consists/
%s/4 byte/by the 4 byte/
%s/rest/the rest/
%s/kB/KiB/
%s/Nokia/Nokia's/ ?
%s/prepend required/prepends the required/
%s/that image/that the image/
%s/contain/contain a/
%s/Adding/Adding a/
%s/using/of using the/
%s/Open/The open/
%s/following/the following/
- 0xFFFF -m u-boot.bin -l -b
%s/support/supports/
- 0xFFFF -m combined.bin -f
%s/is/it is/
%s/standard/a standard/
%s/identification/the identification/
%s/and/and the/
Best regards
Heinrich
- 0xFFFF -m RX-51:v2021.04:kernel:u-boot.bin -g u-boot.fiasco
- There is support for hardware watchdog. Hardware watchdog is started by NOLO so u-boot must kick watchdog to prevent reboot device (but not very often, max every 2 seconds). There is also support for framebuffer display
Convert documentation to rst format
Signed-off-by: Pali Rohár pali@kernel.org --- board/nokia/rx51/MAINTAINERS | 2 +- doc/board/index.rst | 1 + doc/board/nokia/index.rst | 9 ++ .../nokia/rx51.rst} | 144 +++++++++--------- 4 files changed, 87 insertions(+), 69 deletions(-) create mode 100644 doc/board/nokia/index.rst rename doc/{README.nokia_rx51 => board/nokia/rx51.rst} (32%)
diff --git a/board/nokia/rx51/MAINTAINERS b/board/nokia/rx51/MAINTAINERS index 58b16bf9a95c..25f8b3c5a9ad 100644 --- a/board/nokia/rx51/MAINTAINERS +++ b/board/nokia/rx51/MAINTAINERS @@ -4,5 +4,5 @@ S: Maintained F: board/nokia/rx51/ F: include/configs/nokia_rx51.h F: configs/nokia_rx51_defconfig -F: doc/README.nokia_rx51 +F: doc/board/nokia/rx51.rst F: test/nokia_rx51_test.sh diff --git a/doc/board/index.rst b/doc/board/index.rst index 5607e1f94638..75c34c4a9998 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -22,6 +22,7 @@ Board-specific doc intel/index kontron/index microchip/index + nokia/index nxp/index openpiton/index qualcomm/index diff --git a/doc/board/nokia/index.rst b/doc/board/nokia/index.rst new file mode 100644 index 000000000000..b68c3c613164 --- /dev/null +++ b/doc/board/nokia/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Nokia +===== + +.. toctree:: + :maxdepth: 2 + + rx51 diff --git a/doc/README.nokia_rx51 b/doc/board/nokia/rx51.rst similarity index 32% rename from doc/README.nokia_rx51 rename to doc/board/nokia/rx51.rst index e739b02088ea..7ab3a1686b1d 100644 --- a/doc/README.nokia_rx51 +++ b/doc/board/nokia/rx51.rst @@ -1,6 +1,9 @@ -Board: Nokia RX-51 aka N900 +.. SPDX-License-Identifier: GPL-2.0+
-This board definition results in a u-boot.bin which can be chainloaded +Nokia RX-51 aka N900 +==================== + +This board definition results in a ``u-boot.bin`` which can be chainloaded from NOLO in qemu or on a real N900. It does very little hardware config because NOLO has already configured the board. Only needed is enabling internal eMMC memory via twl4030 regulator which is not enabled by NOLO. @@ -8,64 +11,64 @@ internal eMMC memory via twl4030 regulator which is not enabled by NOLO. NOLO is expecting a kernel image and will treat any image it finds in onenand as such. This u-boot is intended to be flashed to the N900 like a kernel. In order to transparently boot the original kernel, it will be -appended to u-boot.bin at 0x40000. NOLO will load the entire image into +appended to ``u-boot.bin`` at 0x40000. NOLO will load the entire image into (random) memory and execute u-boot, which saves hw revision, boot reason and boot mode ATAGs set by NOLO. Then the bootscripts will attempt to load -uImage, zImage or boot.scr from a fat or ext2/3/4 filesystem on external -SD card or internal eMMC memory. If this fails or keyboard is closed then -the appended kernel image will be booted using some generated and some -stored ATAGs (see boot order). +``uImage``, ``zImage`` or ``boot.scr`` file from a fat or ext2/3/4 filesystem +on external SD card or internal eMMC memory. If this fails or keyboard is +closed then the appended kernel image will be booted using some generated +and some stored ATAGs (see boot order).
For generating combined image of u-boot and kernel (either in uImage or zImage -format) there is a simple script called u-boot-gen-combined. It is available in -following repository: +format) there is a simple script called ``u-boot-gen-combined``. It is available +in following repository:
- https://github.com/pali/u-boot-maemo + https://github.com/pali/u-boot-maemo
-To generate combined.bin image from u-boot.bin and kernel.bin (either uImage -or zImage) use: +To generate ``combined.bin`` image from ``u-boot.bin`` and ``kernel.bin`` +(either uImage or zImage format) use::
- sh u-boot-gen-combined u-boot.bin kernel.bin combined.bin + $ sh u-boot-gen-combined u-boot.bin kernel.bin combined.bin
- http://repository.maemo.org/pool/maemo5.0/free/k/kernel/kernel_2.6.28-201031... + http://repository.maemo.org/pool/maemo5.0/free/k/kernel/kernel_2.6.28-201031...
-To unpack it (from DEB/AR, TAR and FIASCO) call commands: +To unpack it (from DEB/AR, TAR and FIASCO) call commands::
- ar x kernel_2.6.28-20103103+0m5_armel.deb data.tar.gz - tar -O -xf data.tar.gz ./boot/zImage-2.6.28-20103103+0m5.fiasco > kernel_2.6.28-20103103+0m5.fiasco - 0xFFFF -M kernel_2.6.28-20103103+0m5.fiasco -u + $ ar x kernel_2.6.28-20103103+0m5_armel.deb data.tar.gz + $ tar -O -xf data.tar.gz ./boot/zImage-2.6.28-20103103+0m5.fiasco > kernel_2.6.28-20103103+0m5.fiasco + $ 0xFFFF -M kernel_2.6.28-20103103+0m5.fiasco -u
-Flashed image must start with 2 kB "NOLO!img" header which contains size of -the image. Header consist of bytes "NOLO!img\x02\x00\x00\x00\x00\x00\x00\x00" +Flashed image must start with 2 kB ``NOLO!img`` header which contains size of +the image. Header consist of bytes ``NOLO!img\x02\x00\x00\x00\x00\x00\x00\x00`` followed by 4 byte little endian size of the image and rest of the 2 kB header are just zero bytes.
Nokia proprietary flasher and also open source 0xFFFF flasher automatically -prepend required "NOLO!img" header and both applications expect that image -does not contain "NOLO!img" header. Adding "NOLO!img" header is required -only in case using "nandwrite" tool for flashing. +prepend required ``NOLO!img`` header and both applications expect that image +does not contain ``NOLO!img`` header. Adding ``NOLO!img`` header is required +only in case using ``nandwrite`` tool for flashing.
- https://github.com/pali/0xFFFF + https://github.com/pali/0xFFFF
-It is possible to load u-boot.bin via USB to N900 RAM and boot it without -need to flashing it. Via 0xFFFF running at host PC it is done: +It is possible to load ``u-boot.bin`` via USB to N900 RAM and boot it without +need to flashing it. Via 0xFFFF running at host PC it is done::
- 0xFFFF -m u-boot.bin -l -b + $ 0xFFFF -m u-boot.bin -l -b
0xFFFF support also flashing kernel image either via USB or directly on -N900 device. Flashing u-boot/kernel/combined image is done as: +N900 device. Flashing u-boot/kernel/combined image is done as::
- 0xFFFF -m combined.bin -f + $ 0xFFFF -m combined.bin -f
Via 0xFFFF is possible to generate also standard flashable image in Nokia FIASCO format which contains metadata information like device identification -(RX-51) and version string (v2021.04): +(RX-51) and version string (v2021.04)::
- 0xFFFF -m RX-51:v2021.04:kernel:u-boot.bin -g u-boot.fiasco + $ 0xFFFF -m RX-51:v2021.04:kernel:u-boot.bin -g u-boot.fiasco
There is support for hardware watchdog. Hardware watchdog is started by NOLO so u-boot must kick watchdog to prevent reboot device (but not very @@ -77,62 +80,67 @@ which is needed for Thumb-2 ISA support. It is workaround for errata 430973.
Default boot order:
- * 0. if keyboard is closed boot automatically attached kernel image - * 1. try boot from external SD card - * 2. try boot from internal eMMC memory - * 3. try boot from attached kernel image +0. if keyboard is closed boot automatically attached kernel image +1. try boot from external SD card +2. try boot from internal eMMC memory +3. try boot from attached kernel image
- * 1. - * 1.1 find boot.scr on first fat partition - * 1.2 find uImage on first fat partition - * 1.3 find zImage on first fat partition - * 1.4 same order for 2. - 4. fat partition - * 2. same as 1. but for ext2/3/4 partition +* 1. step + + * 1.1 find ``boot.scr`` on first fat partition + * 1.2 find ``uImage`` on first fat partition + * 1.3 find ``zImage`` on first fat partition + * 1.4 same order for 2. - 4. fat partition
+* 2. step - same as 1. but for ext2/3/4 partition
- * run sdboot - Boot from external SD card (see boot order) - * run emmcboot - Boot from internal eMMC memory (see boot order) - * run attachboot - Boot attached kernel image (attached to U-Boot binary) +* run sdboot - Boot from external SD card (see boot order) +* run emmcboot - Boot from internal eMMC memory (see boot order) +* run attachboot - Boot attached kernel image (attached to U-Boot binary) + +\ + +* run scriptload - Load boot script ``${mmcscriptfile}`` +* run scriptboot - Run loaded boot script +* run kernload - Load kernel image ``${mmckernfile}`` +* run initrdload - Load initrd image ``${mmcinitrdfile}`` +* run kernboot - Boot loaded kernel image +* run kerninitrdboot - Boot loaded kernel image with loaded initrd image
- * run scriptload - Load boot script ${mmcscriptfile} - * run scriptboot - Run loaded boot script - * run kernload - Load kernel image ${mmckernfile} - * run initrdload - Load initrd image ${mmcinitrdfile} - * run kernboot - Boot loaded kernel image - * run kerninitrdboot - Boot loaded kernel image with loaded initrd image +\
- * run trymmcscriptboot - Try to load and boot script ${mmcscriptfile} - * run trymmckernboot - Try to load and boot kernel image ${mmckernfile} - * run trymmckerninitrdboot - Try to load and boot kernel image ${mmckernfile} - with initrd image ${mmcinitrdfile} +* run trymmcscriptboot - Try to load and boot script ``${mmcscriptfile}`` +* run trymmckernboot - Try to load and boot kernel image ``${mmckernfile}`` +* run trymmckerninitrdboot - Try to load and boot kernel image ``${mmckernfile}`` + with initrd image ``${mmcinitrdfile}``
- * mmc ${mmcnum} (0 - external, 1 - internal) - * partition number ${mmcpart} (1 - 4) - * partition type ${mmctype} (fat, ext2, ext4; ext2 is just alias for ext4) +* mmc ``${mmcnum}`` (0 - external, 1 - internal) +* partition number ``${mmcpart}`` (1 - 4) +* partition type ``${mmctype}`` (fat, ext2, ext4; ext2 is just alias for ext4)
- * setup_omap_atag - Add OMAP table into atags structure (needs maemo kernel) - * setup_console_atag - Enable serial console in OMAP table - * setup_boot_reason_atag - Change boot reason in OMAP table - * setup_boot_mode_atag - Change boot mode in OMAP table +* ``setup_omap_atag`` - Add OMAP table into atags structure (needed for maemo kernel) +* ``setup_console_atag`` - Enable serial console in OMAP table +* ``setup_boot_reason_atag`` - Change boot reason in OMAP table +* ``setup_boot_mode_atag`` - Change boot mode in OMAP table
- Variable setup_omap_atag is automatically set when booting attached kernel. - When variable setup_omap_atag is set, variable setup_console_atag is unset - and u-boot standard output is set to serial then setup_console_atag is - automatically set to 1. So output from Maemo kernel would go to serial port. +Variable ``setup_omap_atag`` is automatically set when booting attached kernel. +When variable ``setup_omap_atag`` is set, variable ``setup_console_atag`` is unset +and u-boot standard output is set to serial then ``setup_console_atag`` is +automatically set to 1. So output from Maemo kernel would go to serial port.
UBIFS support:
- UBIFS support is disabled, because U-Boot image is too big and cannot be - flashed with attached zImage to RX-51 kernel nand area. For enabling UBIFS - support add following lines into file configs/nokia_rx51_defconfig +UBIFS support is disabled, because U-Boot image is too big and cannot be +flashed with attached kernel image to RX-51 kernel nand area. For enabling +UBIFS support add following lines into file ``configs/nokia_rx51_defconfig``::
CONFIG_CMD_UBI=y CONFIG_CMD_UBIFS=y
Thanks for converting to rst.
I guess I will simply add all 3 patches to my repo and add all typo fixes to patch 3.
Acked-by: Heinrich Schuchardt xypron.glpk@gmx.de
- nokia/index nxp/index openpiton/index qualcomm/index
+Nokia +=====
+.. toctree::
- :maxdepth: 2
- rx51
- $ ar x kernel_2.6.28-20103103+0m5_armel.deb data.tar.gz
- $ tar -O -xf data.tar.gz ./boot/zImage-2.6.28-20103103+0m5.fiasco > kernel_2.6.28-20103103+0m5.fiasco
- $ 0xFFFF -M kernel_2.6.28-20103103+0m5.fiasco -u
Default boot order:
- if keyboard is closed boot automatically attached kernel image
- try boot from external SD card
- try boot from internal eMMC memory
- try boot from attached kernel image
- 1.1 find boot.scr on first fat partition
- 1.2 find uImage on first fat partition
- 1.3 find zImage on first fat partition
- 1.4 same order for 2. - 4. fat partition
+* 1. step
- 1.1 find ``boot.scr`` on first fat partition
- 1.2 find ``uImage`` on first fat partition
- 1.3 find ``zImage`` on first fat partition
- run sdboot - Boot from external SD card (see boot order)
- run emmcboot - Boot from internal eMMC memory (see boot order)
- run attachboot - Boot attached kernel image (attached to U-Boot binary)
- run scriptload - Load boot script ${mmcscriptfile}
- run scriptboot - Run loaded boot script
- run kernload - Load kernel image ${mmckernfile}
- run initrdload - Load initrd image ${mmcinitrdfile}
- run kernboot - Boot loaded kernel image
- run kerninitrdboot - Boot loaded kernel image with loaded initrd image
- run trymmcscriptboot - Try to load and boot script ${mmcscriptfile}
- run trymmckernboot - Try to load and boot kernel image ${mmckernfile}
- run trymmckerninitrdboot - Try to load and boot kernel image ${mmckernfile}
- mmc ${mmcnum} (0 - external, 1 - internal)
- partition number ${mmcpart} (1 - 4)
- partition type ${mmctype} (fat, ext2, ext4; ext2 is just alias for ext4)
- setup_omap_atag - Add OMAP table into atags structure (needs maemo kernel)
- setup_console_atag - Enable serial console in OMAP table
- setup_boot_reason_atag - Change boot reason in OMAP table
- setup_boot_mode_atag - Change boot mode in OMAP table
UBIFS support:
Ok, thank you!
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- same as 1. but for ext2/3 partition
- same as 1. but for ext4 partition
- parition type ${mmctype} (fat, ext2, ext4)
Pali Rohár
