[U-Boot-Users] [PATCH] Nios-II Support (4 of 7)
-Add support for Altera Nios-II processors. -Add support for Psyent PCI-5441 board. -Add support for Psyent PK1C20 board.
Regards, --Scott
diff -Naurb u-boot-2004-08-24/include/asm-nios2/bitops.h u-boot-nios2/include/asm-nios2/bitops.h --- u-boot-2004-08-24/include/asm-nios2/bitops.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/bitops.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_BITOPS_H_ +#define __ASM_NIOS2_BITOPS_H_ + + +extern void set_bit(int nr, volatile void * a); +extern void clear_bit(int nr, volatile void * a); +extern int test_and_clear_bit(int nr, volatile void * a); +extern void change_bit(unsigned long nr, volatile void *addr); +extern int test_and_set_bit(int nr, volatile void * a); +extern int test_and_change_bit(int nr, volatile void * addr); +extern int test_bit(int nr, volatile void * a); +extern int ffs(int i); + +#endif /* __ASM_NIOS2_BITOPS_H */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/byteorder.h u-boot-nios2/include/asm-nios2/byteorder.h --- u-boot-2004-08-24/include/asm-nios2/byteorder.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/byteorder.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,30 @@ +/* +* (C) Copyright 2004, Psyent Corporation <www.psyent.com> +* Scott McNutt smcnutt@psyent.com +* +* See file CREDITS for list of people who contributed to this +* project. +* +* This program is free software; you can redistribute it and/or +* modify it under the terms of the GNU General Public License as +* published by the Free Software Foundation; either version 2 of +* the License, or (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License +* along with this program; if not, write to the Free Software +* Foundation, Inc., 59 Temple Place, Suite 330, Boston, +* MA 02111-1307 USA +*/ + +#ifndef __ASM_NIOS2_BYTEORDER_H_ +#define __ASM_NIOS2_BYTEORDER_H_ + +#include <asm/types.h> +#include <linux/byteorder/little_endian.h> + +#endif /* __ASM_NIOS2_BYTEORDER_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/cache.h u-boot-nios2/include/asm-nios2/cache.h --- u-boot-2004-08-24/include/asm-nios2/cache.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/cache.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_CACHE_H_ +#define __ASM_NIOS2_CACHE_H_ + +extern void flush_dcache (unsigned long start, unsigned long size); +extern void flush_icache (unsigned long start, unsigned long size); + +#endif /* __ASM_NIOS2_CACHE_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/global_data.h u-boot-nios2/include/asm-nios2/global_data.h --- u-boot-2004-08-24/include/asm-nios2/global_data.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/global_data.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_NIOS2_GLOBALDATA_H_ +#define __ASM_NIOS2_GLOBALDATA_H_ + +typedef struct global_data { + bd_t *bd; + unsigned long flags; + unsigned long baudrate; + unsigned long cpu_clk; /* CPU clock in Hz! */ + unsigned long have_console; /* serial_init() was called */ + unsigned long ram_size; /* RAM size */ + unsigned long reloc_off; /* Relocation Offset */ + unsigned long env_addr; /* Address of Environment struct */ + unsigned long env_valid; /* Checksum of Environment valid */ +#if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER) + unsigned long post_log_word; /* Record POST activities */ + unsigned long post_init_f_time; /* When post_init_f started */ +#endif + void **jt; /* Standalone app jump table */ +} gd_t; + +/* flags */ +#define GD_FLG_RELOC 0x00001 /* Code was relocated to RAM */ +#define GD_FLG_DEVINIT 0x00002 /* Devices have been initialized */ +#define GD_FLG_SILENT 0x00004 /* Silent mode */ + +#define DECLARE_GLOBAL_DATA_PTR register gd_t *gd asm ("r15") + +#endif /* __ASM_NIOS2_GLOBALDATA_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/io.h u-boot-nios2/include/asm-nios2/io.h --- u-boot-2004-08-24/include/asm-nios2/io.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/io.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,36 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_IO_H_ +#define __ASM_NIOS2_IO_H_ + +#define sync() asm volatile ("sync" : : : "memory"); + +extern unsigned char inb (unsigned char *port); +extern unsigned short inw (unsigned short *port); +extern unsigned inl (unsigned port); +extern void outb (unsigned char val, unsigned char *port); +extern void outw (unsigned short val, unsigned short *port); +extern void outl (unsigned val, unsigned port); + +#endif /* __ASM_NIOS2_IO_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/opcodes.h u-boot-nios2/include/asm-nios2/opcodes.h --- u-boot-2004-08-24/include/asm-nios2/opcodes.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/opcodes.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,131 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_OPCODES_H_ +#define __ASM_NIOS2_OPCODES_H_ + +#define OPCODE_OP(inst) ((inst) & 0x3f) +#define OPCODE_OPX(inst) (((inst)>>11) & 0x3f) +#define OPCODE_RA(inst) (((inst)>>27) & 01f) +#define OPCODE_RB(inst) (((inst)>>22) & 01f) +#define OPCODE_RC(inst) (((inst)>>17) & 01f) + +/* I-TYPE (immediate) and J-TYPE (jump) opcodes + */ +#define OPCODE_CALL 0x00 +#define OPCODE_LDBU 0x03 +#define OPCODE_ADDI 0x04 +#define OPCODE_STB 0x05 +#define OPCODE_BR 0x06 +#define OPCODE_LDB 0x07 +#define OPCODE_CMPGEI 0x08 +#define OPCODE_LDHU 0x0B +#define OPCODE_ANDI 0x0C +#define OPCODE_STH 0x0D +#define OPCODE_BGE 0x0E +#define OPCODE_LDH 0x0F +#define OPCODE_CMPLTI 0x10 +#define OPCODE_XORI 0x1C +#define OPCODE_ORI 0x14 +#define OPCODE_STW 0x15 +#define OPCODE_BLT 0x16 +#define OPCODE_LDW 0x17 +#define OPCODE_CMPNEI 0x18 +#define OPCODE_BNE 0x1E +#define OPCODE_CMPEQI 0x20 +#define OPCODE_LDBUIO 0x23 +#define OPCODE_MULI 0x24 +#define OPCODE_STBIO 0x25 +#define OPCODE_BEQ 0x26 +#define OPCODE_LDBIO 0x27 +#define OPCODE_CMPGEUI 0x28 +#define OPCODE_ANDHI 0x2C +#define OPCODE_STHIO 0x2D +#define OPCODE_BGEU 0x2E +#define OPCODE_LDHIO 0x2F +#define OPCODE_CMPLTUI 0x30 +#define OPCODE_CUSTOM 0x32 +#define OPCODE_INITD 0x33 +#define OPCODE_ORHI 0x34 +#define OPCODE_STWIO 0x35 +#define OPCODE_BLTU 0x36 +#define OPCODE_LDWIO 0x37 +#define OPCODE_RTYPE 0x3A +#define OPCODE_LDHUIO 0x2B +#define OPCODE_FLUSHD 0x3B +#define OPCODE_XORHI 0x3C + +/* R-Type (register) OPX field encodings + */ +#define OPCODE_ERET 0x01 +#define OPCODE_ROLI 0x02 +#define OPCODE_ROL 0x03 +#define OPCODE_FLUSHP 0x04 +#define OPCODE_RET 0x05 +#define OPCODE_NOR 0x06 +#define OPCODE_MULXUU 0x07 +#define OPCODE_CMPGE 0x08 +#define OPCODE_BRET 0x09 +#define OPCODE_ROR 0x0B +#define OPCODE_FLUSHI 0x0C +#define OPCODE_JMP 0x0D +#define OPCODE_AND 0x0E + +#define OPCODE_CMPLT 0x10 +#define OPCODE_SLLI 0x12 +#define OPCODE_SLL 0x13 +#define OPCODE_OR 0x16 +#define OPCODE_MULXSU 0x17 +#define OPCODE_CMPNE 0x18 +#define OPCODE_SRLI 0x1A +#define OPCODE_SRL 0x1B +#define OPCODE_NEXTPC 0x1C +#define OPCODE_CALLR 0x1D +#define OPCODE_XOR 0x1E +#define OPCODE_MULXSS 0x1F + +#define OPCODE_CMPEQ 0x20 +#define OPCODE_CMPLTU 0x30 +#define OPCODE_ADD 0x31 +#define OPCODE_DIVU 0x24 +#define OPCODE_DIV 0x25 +#define OPCODE_RDCTL 0x26 +#define OPCODE_MUL 0x27 +#define OPCODE_CMPGEU 0x28 +#define OPCODE_TRAP 0x2D +#define OPCODE_WRCTL 0x2E + +#define OPCODE_BREAK 0x34 +#define OPCODE_SYNC 0x36 +#define OPCODE_INITI 0x29 +#define OPCODE_SUB 0x39 +#define OPCODE_SRAI 0x3A +#define OPCODE_SRA 0x3B + +/*Full instruction encodings for R-Type, without the R's ;-) + * + * TODO: BREAK, BRET, ERET, RET, SYNC (as needed) + */ +#define OPC_TRAP 0x003b683a + +#endif /* __ASM_NIOS2_OPCODES_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/posix_types.h u-boot-nios2/include/asm-nios2/posix_types.h --- u-boot-2004-08-24/include/asm-nios2/posix_types.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/posix_types.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,63 @@ +#ifndef __ASM_NIOS2_POSIX_TYPES_H_ +#define __ASM_NIOS2_POSIX_TYPES_H_ + +/* + * This file is generally used by user-level software, so you need to + * be a little careful about namespace pollution etc. Also, we cannot + * assume GCC is being used. + */ + +typedef unsigned short __kernel_dev_t; +typedef unsigned long __kernel_ino_t; +typedef unsigned short __kernel_mode_t; +typedef unsigned short __kernel_nlink_t; +typedef long __kernel_off_t; +typedef int __kernel_pid_t; +typedef unsigned short __kernel_ipc_pid_t; +typedef unsigned short __kernel_uid_t; +typedef unsigned short __kernel_gid_t; +typedef unsigned long __kernel_size_t; +typedef int __kernel_ssize_t; +typedef int __kernel_ptrdiff_t; +typedef long __kernel_time_t; +typedef long __kernel_suseconds_t; +typedef long __kernel_clock_t; +typedef int __kernel_daddr_t; +typedef char * __kernel_caddr_t; +typedef unsigned short __kernel_uid16_t; +typedef unsigned short __kernel_gid16_t; +typedef unsigned int __kernel_uid32_t; +typedef unsigned int __kernel_gid32_t; + +typedef unsigned short __kernel_old_uid_t; +typedef unsigned short __kernel_old_gid_t; + +#ifdef __GNUC__ +typedef long long __kernel_loff_t; +#endif + +typedef struct { +#if defined(__KERNEL__) || defined(__USE_ALL) + int val[2]; +#else /* !defined(__KERNEL__) && !defined(__USE_ALL) */ + int __val[2]; +#endif /* !defined(__KERNEL__) && !defined(__USE_ALL) */ +} __kernel_fsid_t; + +#if defined(__KERNEL__) || !defined(__GLIBC__) || (__GLIBC__ < 2) + +#undef __FD_SET +#define __FD_SET(d, set) ((set)->fds_bits[__FDELT(d)] |= __FDMASK(d)) + +#undef __FD_CLR +#define __FD_CLR(d, set) ((set)->fds_bits[__FDELT(d)] &= ~__FDMASK(d)) + +#undef __FD_ISSET +#define __FD_ISSET(d, set) ((set)->fds_bits[__FDELT(d)] & __FDMASK(d)) + +#undef __FD_ZERO +#define __FD_ZERO(fdsetp) (memset (fdsetp, 0, sizeof(*(fd_set *)fdsetp))) + +#endif /* defined(__KERNEL__) || !defined(__GLIBC__) || (__GLIBC__ < 2) */ + +#endif /* __ASM_NIOS2_POSIX_TYPES_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/processor.h u-boot-nios2/include/asm-nios2/processor.h --- u-boot-2004-08-24/include/asm-nios2/processor.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/processor.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_PROCESSOR_H_ +#define __ASM_NIOS2_PROCESSOR_H_ +#endif /* __ASM_NIOS2_PROCESSOR_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/psr.h u-boot-nios2/include/asm-nios2/psr.h --- u-boot-2004-08-24/include/asm-nios2/psr.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/psr.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_PSR_H_ +#define __ASM_NIOS2_PSR_H_ + + +#endif /* __ASM_NIOS2_PSR_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/ptrace.h u-boot-nios2/include/asm-nios2/ptrace.h --- u-boot-2004-08-24/include/asm-nios2/ptrace.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/ptrace.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,33 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_PTRACE_H_ +#define __ASM_NIOS2_PTRACE_H_ + +struct pt_regs { + unsigned reg[32]; + unsigned status; +}; + + +#endif /* __ASM_NIOS2_PTRACE_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/status_led.h u-boot-nios2/include/asm-nios2/status_led.h --- u-boot-2004-08-24/include/asm-nios2/status_led.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/status_led.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,31 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_STATUS_LED_H__ +#define __ASM_STATUS_LED_H__ + +typedef unsigned led_id_t; +extern void __led_init (led_id_t mask, int state); +extern void __led_set (led_id_t mask, int state); +inline void __led_toggle (led_id_t mask); + +#endif /* __ASM_STATUS_LED_H__ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/string.h u-boot-nios2/include/asm-nios2/string.h --- u-boot-2004-08-24/include/asm-nios2/string.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/string.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_NIOS2_STRING_H_ +#define __ASM_NIOS2_STRING_H_ + +#undef __HAVE_ARCH_STRRCHR +extern char * strrchr(const char * s, int c); + +#undef __HAVE_ARCH_STRCHR +extern char * strchr(const char * s, int c); + +#undef __HAVE_ARCH_MEMCPY +extern void * memcpy(void *, const void *, __kernel_size_t); + +#undef __HAVE_ARCH_MEMMOVE +extern void * memmove(void *, const void *, __kernel_size_t); + +#undef __HAVE_ARCH_MEMCHR +extern void * memchr(const void *, int, __kernel_size_t); + +#undef __HAVE_ARCH_MEMSET +extern void * memset(void *, int, __kernel_size_t); + +#undef __HAVE_ARCH_MEMZERO +extern void memzero(void *ptr, __kernel_size_t n); + +#endif /* __ASM_NIOS2_STRING_H_ */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/system.h u-boot-nios2/include/asm-nios2/system.h --- u-boot-2004-08-24/include/asm-nios2/system.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/system.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_NIOS2_SYSTEM_H_ +#define __ASM_NIOS2_SYSTEM_H_ + +#endif /* __ASM_NIOS2_SYSTEM_H */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/types.h u-boot-nios2/include/asm-nios2/types.h --- u-boot-2004-08-24/include/asm-nios2/types.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/types.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,57 @@ +#ifndef __ASM_NIOS2_TYPES_H_ +#define __ASM_NIOS2_TYPES_H_ + +/* + * This file is never included by application software unless + * explicitly requested (e.g., via linux/types.h) in which case the + * application is Linux specific so (user-) name space pollution is + * not a major issue. However, for interoperability, libraries still + * need to be careful to avoid a name clashes. + */ + +typedef unsigned short umode_t; + +/* + * __xx is ok: it doesn't pollute the POSIX namespace. Use these in the + * header files exported to user space + */ + +typedef __signed__ char __s8; +typedef unsigned char __u8; + +typedef __signed__ short __s16; +typedef unsigned short __u16; + +typedef __signed__ int __s32; +typedef unsigned int __u32; + +#if defined(__GNUC__) && !defined(__STRICT_ANSI__) +typedef __signed__ long long __s64; +typedef unsigned long long __u64; +#endif + +/* + * These aren't exported outside the kernel to avoid name space clashes + */ +#ifdef __KERNEL__ + +typedef signed char s8; +typedef unsigned char u8; + +typedef signed short s16; +typedef unsigned short u16; + +typedef signed int s32; +typedef unsigned int u32; + +typedef signed long long s64; +typedef unsigned long long u64; + +#define BITS_PER_LONG 32 + +/* Dma addresses are 32-bits wide. */ + +typedef u32 dma_addr_t; +#endif /* __KERNEL__ */ + +#endif /* __ASM_NIOS2_TYPES_H */ diff -Naurb u-boot-2004-08-24/include/asm-nios2/u-boot.h u-boot-nios2/include/asm-nios2/u-boot.h --- u-boot-2004-08-24/include/asm-nios2/u-boot.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/asm-nios2/u-boot.h 2004-08-24 05:48:28.000000000 -0400 @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_NIOS2_U_BOOT_H_ +#define __ASM_NIOS2_U_BOOT_H_ + +typedef struct bd_info { + unsigned long bi_memstart; /* start of DRAM memory */ + unsigned long bi_memsize; /* size of DRAM memory in bytes */ + unsigned long bi_flashstart; /* start of FLASH memory */ + unsigned long bi_flashsize; /* size of FLASH memory */ + unsigned long bi_flashoffset; /* reserved area for startup monitor */ + unsigned long bi_sramstart; /* start of SRAM memory */ + unsigned long bi_sramsize; /* size of SRAM memory */ + unsigned long bi_ip_addr; /* IP Address */ + unsigned char bi_enetaddr[6]; /* Ethernet adress */ + unsigned long bi_baudrate; /* Console Baudrate */ +} bd_t; + + +#endif /* __ASM_NIOS2_U_BOOT_H_ */
Added, thanks.
Scott McNutt
