[U-Boot] [PATCH] Add i.MX6 CPU temperature sensor support
This patch adds support for i.MX6 on chip temperature sensor support.
Nitin Garg (1): Add i.MX6 CPU temperature sensor support
arch/arm/cpu/armv7/mx6/soc.c | 137 +++++++- arch/arm/imx-common/cpu.c | 7 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 543 +++++++++++++++++++++++++++++- arch/arm/include/asm/arch-mx6/imx-regs.h | 9 +- 4 files changed, 692 insertions(+), 4 deletions(-)
Support CPU temperature sensors on i.MX6 SoC.
Signed-off-by: Nitin Garg nitin.garg@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 137 +++++++- arch/arm/imx-common/cpu.c | 7 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 543 +++++++++++++++++++++++++++++- arch/arm/include/asm/arch-mx6/imx-regs.h | 9 +- 4 files changed, 692 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index ac84a1f..8aacdaf 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -2,7 +2,7 @@ * (C) Copyright 2007 * Sascha Hauer, Pengutronix * - * (C) Copyright 2009 Freescale Semiconductor, Inc. + * (C) Copyright 2009-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -35,6 +35,18 @@ struct scu_regs { u32 fpga_rev; };
+#define TEMPERATURE_MIN -40 +#define TEMPERATURE_HOT 80 +#define TEMPERATURE_MAX 125 +#define FACTOR1 15976 +#define FACTOR2 4297157 +#define MEASURE_FREQ 327 + +#define REG_VALUE_TO_CEL(ratio, raw) \ + ((raw_n40c - raw) * 100 / ratio - 40) + +static unsigned int fuse = ~0; + u32 get_nr_cpus(void) { struct scu_regs *scu = (struct scu_regs *)SCU_BASE_ADDR; @@ -218,6 +230,129 @@ static void imx_set_wdog_powerdown(bool enable) writew(enable, &wdog2->wmcr); }
+static int read_cpu_temperature(void) +{ + int temperature; + unsigned int ccm_ccgr2; + unsigned int reg, tmp; + unsigned int raw_25c, raw_n40c, ratio; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[1]; + struct fuse_bank1_regs *fuse_bank1 = + (struct fuse_bank1_regs *)bank->fuse_regs; + + /* need to make sure pll3 is enabled for thermal sensor */ + if ((readl(&anatop->usb1_pll_480_ctrl) & + BM_ANADIG_USB1_PLL_480_CTRL_LOCK) == 0) { + /* enable pll's power */ + writel(BM_ANADIG_USB1_PLL_480_CTRL_POWER, + &anatop->usb1_pll_480_ctrl_set); + writel(0x80, &anatop->ana_misc2_clr); + /* wait for pll lock */ + while ((readl(&anatop->usb1_pll_480_ctrl) & + BM_ANADIG_USB1_PLL_480_CTRL_LOCK) == 0) + ; + /* disable bypass */ + writel(BM_ANADIG_USB1_PLL_480_CTRL_BYPASS, + &anatop->usb1_pll_480_ctrl_clr); + /* enable pll output */ + writel(BM_ANADIG_USB1_PLL_480_CTRL_ENABLE, + &anatop->usb1_pll_480_ctrl_set); + } + + ccm_ccgr2 = readl(&mxc_ccm->CCGR2); + /* enable OCOTP_CTRL clock in CCGR2 */ + writel(ccm_ccgr2 | MXC_CCM_CCGR2_OCOTP_CTRL_MASK, &mxc_ccm->CCGR2); + fuse = readl(&fuse_bank1->ana1); + + /* restore CCGR2 */ + writel(ccm_ccgr2, &mxc_ccm->CCGR2); + + if (fuse == 0 || fuse == 0xffffffff || (fuse & 0xfff00000) == 0) + return TEMPERATURE_MIN; + + /* + * fuse data layout: + * [31:20] sensor value @ 25C + * [19:8] sensor value of hot + * [7:0] hot temperature value + */ + raw_25c = fuse >> 20; + + /* + * The universal equation for thermal sensor + * is slope = 0.4297157 - (0.0015976 * 25C fuse), + * here we convert them to integer to make them + * easy for counting, FACTOR1 is 15976, + * FACTOR2 is 4297157. Our ratio = -100 * slope + */ + ratio = ((FACTOR1 * raw_25c - FACTOR2) + 50000) / 100000; + + debug("Thermal sensor with ratio = %d\n", ratio); + + raw_n40c = raw_25c + (13 * ratio) / 20; + + /* + * now we only use single measure, every time we read + * the temperature, we will power on/down anadig thermal + * module + */ + writel(BM_ANADIG_TEMPSENSE0_POWER_DOWN, &anatop->tempsense0_clr); + writel(BM_ANADIG_ANA_MISC0_REFTOP_SELBIASOFF, &anatop->ana_misc0_set); + + /* write measure freq */ + reg = readl(&anatop->tempsense1); + reg &= ~BM_ANADIG_TEMPSENSE1_MEASURE_FREQ; + reg |= MEASURE_FREQ; + writel(reg, &anatop->tempsense1); + + writel(BM_ANADIG_TEMPSENSE0_MEASURE_TEMP, &anatop->tempsense0_clr); + writel(BM_ANADIG_TEMPSENSE0_FINISHED, &anatop->tempsense0_clr); + writel(BM_ANADIG_TEMPSENSE0_MEASURE_TEMP, &anatop->tempsense0_set); + + while ((readl(&anatop->tempsense0) & + BM_ANADIG_TEMPSENSE0_FINISHED) == 0) + udelay(10000); + + reg = readl(&anatop->tempsense0); + tmp = (reg & BM_ANADIG_TEMPSENSE0_TEMP_VALUE) + >> BP_ANADIG_TEMPSENSE0_TEMP_VALUE; + writel(BM_ANADIG_TEMPSENSE0_FINISHED, &anatop->tempsense0_clr); + + if (tmp <= raw_n40c) + temperature = REG_VALUE_TO_CEL(ratio, tmp); + else + temperature = TEMPERATURE_MIN; + /* power down anatop thermal sensor */ + writel(BM_ANADIG_TEMPSENSE0_POWER_DOWN, &anatop->tempsense0_set); + writel(BM_ANADIG_ANA_MISC0_REFTOP_SELBIASOFF, &anatop->ana_misc0_clr); + + return temperature; +} + +void check_cpu_temperature(void) +{ + int cpu_tmp = 0; + + cpu_tmp = read_cpu_temperature(); + while (cpu_tmp > TEMPERATURE_MIN && cpu_tmp < TEMPERATURE_MAX) { + if (cpu_tmp >= TEMPERATURE_HOT) { + printf("CPU is %d C, too hot to boot, waiting...\n", + cpu_tmp); + udelay(5000000); + cpu_tmp = read_cpu_temperature(); + } else + break; + } + if (cpu_tmp > TEMPERATURE_MIN && cpu_tmp < TEMPERATURE_MAX) + printf("CPU: Temperature %d C, calibration data: 0x%x\n", + cpu_tmp, fuse); + else + printf("CPU: Temperature: can't get valid data or fuse not programmed!\n"); +} + static void set_ahb_rate(u32 val) { struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index ed826a0..addd6eb 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -2,7 +2,7 @@ * (C) Copyright 2007 * Sascha Hauer, Pengutronix * - * (C) Copyright 2009 Freescale Semiconductor, Inc. + * (C) Copyright 2009-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -139,6 +139,11 @@ int print_cpuinfo(void) (cpurev & 0x000F0) >> 4, (cpurev & 0x0000F) >> 0, mxc_get_clock(MXC_ARM_CLK) / 1000000); + +#if defined(CONFIG_MX6) + check_cpu_temperature(); +#endif + printf("Reset cause: %s\n", get_reset_cause()); return 0; } diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index e67b5b9..66a7cea 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -1,5 +1,5 @@ /* - * Copyright 2011 Freescale Semiconductor, Inc. All Rights Reserved. + * Copyright 2011-2014 Freescale Semiconductor, Inc. All Rights Reserved. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -1061,4 +1061,545 @@ struct mxc_ccm_reg { #define BF_ANADIG_PFD_528_PFD0_FRAC(v) \ (((v) << 0) & BM_ANADIG_PFD_528_PFD0_FRAC)
+#define HW_ANADIG_REG_1P1 (0x00000110) +#define HW_ANADIG_REG_1P1_SET (0x00000114) +#define HW_ANADIG_REG_1P1_CLR (0x00000118) +#define HW_ANADIG_REG_1P1_TOG (0x0000011c) + +#define BP_ANADIG_REG_1P1_RSVD2 18 +#define BM_ANADIG_REG_1P1_RSVD2 0xFFFC0000 +#define BF_ANADIG_REG_1P1_RSVD2(v) \ + (((v) << 18) & BM_ANADIG_REG_1P1_RSVD2) +#define BM_ANADIG_REG_1P1_OK_VDD1P1 0x00020000 +#define BM_ANADIG_REG_1P1_BO_VDD1P1 0x00010000 +#define BP_ANADIG_REG_1P1_RSVD1 13 +#define BM_ANADIG_REG_1P1_RSVD1 0x0000E000 +#define BF_ANADIG_REG_1P1_RSVD1(v) \ + (((v) << 13) & BM_ANADIG_REG_1P1_RSVD1) +#define BP_ANADIG_REG_1P1_OUTPUT_TRG 8 +#define BM_ANADIG_REG_1P1_OUTPUT_TRG 0x00001F00 +#define BF_ANADIG_REG_1P1_OUTPUT_TRG(v) \ + (((v) << 8) & BM_ANADIG_REG_1P1_OUTPUT_TRG) +#define BM_ANADIG_REG_1P1_RSVD0 0x00000080 +#define BP_ANADIG_REG_1P1_BO_OFFSET 4 +#define BM_ANADIG_REG_1P1_BO_OFFSET 0x00000070 +#define BF_ANADIG_REG_1P1_BO_OFFSET(v) \ + (((v) << 4) & BM_ANADIG_REG_1P1_BO_OFFSET) +#define BM_ANADIG_REG_1P1_ENABLE_PULLDOWN 0x00000008 +#define BM_ANADIG_REG_1P1_ENABLE_ILIMIT 0x00000004 +#define BM_ANADIG_REG_1P1_ENABLE_BO 0x00000002 +#define BM_ANADIG_REG_1P1_ENABLE_LINREG 0x00000001 + +#define HW_ANADIG_REG_3P0 (0x00000120) +#define HW_ANADIG_REG_3P0_SET (0x00000124) +#define HW_ANADIG_REG_3P0_CLR (0x00000128) +#define HW_ANADIG_REG_3P0_TOG (0x0000012c) + +#define BP_ANADIG_REG_3P0_RSVD2 18 +#define BM_ANADIG_REG_3P0_RSVD2 0xFFFC0000 +#define BF_ANADIG_REG_3P0_RSVD2(v) \ + (((v) << 18) & BM_ANADIG_REG_3P0_RSVD2) +#define BM_ANADIG_REG_3P0_OK_VDD3P0 0x00020000 +#define BM_ANADIG_REG_3P0_BO_VDD3P0 0x00010000 +#define BP_ANADIG_REG_3P0_RSVD1 13 +#define BM_ANADIG_REG_3P0_RSVD1 0x0000E000 +#define BF_ANADIG_REG_3P0_RSVD1(v) \ + (((v) << 13) & BM_ANADIG_REG_3P0_RSVD1) +#define BP_ANADIG_REG_3P0_OUTPUT_TRG 8 +#define BM_ANADIG_REG_3P0_OUTPUT_TRG 0x00001F00 +#define BF_ANADIG_REG_3P0_OUTPUT_TRG(v) \ + (((v) << 8) & BM_ANADIG_REG_3P0_OUTPUT_TRG) +#define BM_ANADIG_REG_3P0_VBUS_SEL 0x00000080 +#define BP_ANADIG_REG_3P0_BO_OFFSET 4 +#define BM_ANADIG_REG_3P0_BO_OFFSET 0x00000070 +#define BF_ANADIG_REG_3P0_BO_OFFSET(v) \ + (((v) << 4) & BM_ANADIG_REG_3P0_BO_OFFSET) +#define BM_ANADIG_REG_3P0_RSVD0 0x00000008 +#define BM_ANADIG_REG_3P0_ENABLE_ILIMIT 0x00000004 +#define BM_ANADIG_REG_3P0_ENABLE_BO 0x00000002 +#define BM_ANADIG_REG_3P0_ENABLE_LINREG 0x00000001 + +#define HW_ANADIG_REG_2P5 (0x00000130) +#define HW_ANADIG_REG_2P5_SET (0x00000134) +#define HW_ANADIG_REG_2P5_CLR (0x00000138) +#define HW_ANADIG_REG_2P5_TOG (0x0000013c) + +#define BP_ANADIG_REG_2P5_RSVD2 19 +#define BM_ANADIG_REG_2P5_RSVD2 0xFFF80000 +#define BF_ANADIG_REG_2P5_RSVD2(v) \ + (((v) << 19) & BM_ANADIG_REG_2P5_RSVD2) +#define BM_ANADIG_REG_2P5_ENABLE_WEAK_LINREG 0x00040000 +#define BM_ANADIG_REG_2P5_OK_VDD2P5 0x00020000 +#define BM_ANADIG_REG_2P5_BO_VDD2P5 0x00010000 +#define BP_ANADIG_REG_2P5_RSVD1 13 +#define BM_ANADIG_REG_2P5_RSVD1 0x0000E000 +#define BF_ANADIG_REG_2P5_RSVD1(v) \ + (((v) << 13) & BM_ANADIG_REG_2P5_RSVD1) +#define BP_ANADIG_REG_2P5_OUTPUT_TRG 8 +#define BM_ANADIG_REG_2P5_OUTPUT_TRG 0x00001F00 +#define BF_ANADIG_REG_2P5_OUTPUT_TRG(v) \ + (((v) << 8) & BM_ANADIG_REG_2P5_OUTPUT_TRG) +#define BM_ANADIG_REG_2P5_RSVD0 0x00000080 +#define BP_ANADIG_REG_2P5_BO_OFFSET 4 +#define BM_ANADIG_REG_2P5_BO_OFFSET 0x00000070 +#define BF_ANADIG_REG_2P5_BO_OFFSET(v) \ + (((v) << 4) & BM_ANADIG_REG_2P5_BO_OFFSET) +#define BM_ANADIG_REG_2P5_ENABLE_PULLDOWN 0x00000008 +#define BM_ANADIG_REG_2P5_ENABLE_ILIMIT 0x00000004 +#define BM_ANADIG_REG_2P5_ENABLE_BO 0x00000002 +#define BM_ANADIG_REG_2P5_ENABLE_LINREG 0x00000001 + +#define HW_ANADIG_REG_CORE (0x00000140) +#define HW_ANADIG_REG_CORE_SET (0x00000144) +#define HW_ANADIG_REG_CORE_CLR (0x00000148) +#define HW_ANADIG_REG_CORE_TOG (0x0000014c) + +#define BM_ANADIG_REG_CORE_REF_SHIFT 0x80000000 +#define BM_ANADIG_REG_CORE_RSVD0 0x40000000 +#define BM_ANADIG_REG_CORE_FET_ODRIVE 0x20000000 +#define BP_ANADIG_REG_CORE_RAMP_RATE 27 +#define BM_ANADIG_REG_CORE_RAMP_RATE 0x18000000 +#define BF_ANADIG_REG_CORE_RAMP_RATE(v) \ + (((v) << 27) & BM_ANADIG_REG_CORE_RAMP_RATE) +#define BP_ANADIG_REG_CORE_REG2_ADJ 23 +#define BM_ANADIG_REG_CORE_REG2_ADJ 0x07800000 +#define BF_ANADIG_REG_CORE_REG2_ADJ(v) \ + (((v) << 23) & BM_ANADIG_REG_CORE_REG2_ADJ) +#define BP_ANADIG_REG_CORE_REG2_TRG 18 +#define BM_ANADIG_REG_CORE_REG2_TRG 0x007C0000 +#define BF_ANADIG_REG_CORE_REG2_TRG(v) \ + (((v) << 18) & BM_ANADIG_REG_CORE_REG2_TRG) +#define BP_ANADIG_REG_CORE_REG1_ADJ 14 +#define BM_ANADIG_REG_CORE_REG1_ADJ 0x0003C000 +#define BF_ANADIG_REG_CORE_REG1_ADJ(v) \ + (((v) << 14) & BM_ANADIG_REG_CORE_REG1_ADJ) +#define BP_ANADIG_REG_CORE_REG1_TRG 9 +#define BM_ANADIG_REG_CORE_REG1_TRG 0x00003E00 +#define BF_ANADIG_REG_CORE_REG1_TRG(v) \ + (((v) << 9) & BM_ANADIG_REG_CORE_REG1_TRG) +#define BP_ANADIG_REG_CORE_REG0_ADJ 5 +#define BM_ANADIG_REG_CORE_REG0_ADJ 0x000001E0 +#define BF_ANADIG_REG_CORE_REG0_ADJ(v) \ + (((v) << 5) & BM_ANADIG_REG_CORE_REG0_ADJ) +#define BP_ANADIG_REG_CORE_REG0_TRG 0 +#define BM_ANADIG_REG_CORE_REG0_TRG 0x0000001F +#define BF_ANADIG_REG_CORE_REG0_TRG(v) \ + (((v) << 0) & BM_ANADIG_REG_CORE_REG0_TRG) + +#define HW_ANADIG_ANA_MISC0 (0x00000150) +#define HW_ANADIG_ANA_MISC0_SET (0x00000154) +#define HW_ANADIG_ANA_MISC0_CLR (0x00000158) +#define HW_ANADIG_ANA_MISC0_TOG (0x0000015c) + +#define BP_ANADIG_ANA_MISC0_RSVD2 29 +#define BM_ANADIG_ANA_MISC0_RSVD2 0xE0000000 +#define BF_ANADIG_ANA_MISC0_RSVD2(v) \ + (((v) << 29) & BM_ANADIG_ANA_MISC0_RSVD2) +#define BP_ANADIG_ANA_MISC0_CLKGATE_DELAY 26 +#define BM_ANADIG_ANA_MISC0_CLKGATE_DELAY 0x1C000000 +#define BF_ANADIG_ANA_MISC0_CLKGATE_DELAY(v) \ + (((v) << 26) & BM_ANADIG_ANA_MISC0_CLKGATE_DELAY) +#define BM_ANADIG_ANA_MISC0_CLKGATE_CTRL 0x02000000 +#define BP_ANADIG_ANA_MISC0_ANAMUX 21 +#define BM_ANADIG_ANA_MISC0_ANAMUX 0x01E00000 +#define BF_ANADIG_ANA_MISC0_ANAMUX(v) \ + (((v) << 21) & BM_ANADIG_ANA_MISC0_ANAMUX) +#define BM_ANADIG_ANA_MISC0_ANAMUX_EN 0x00100000 +#define BP_ANADIG_ANA_MISC0_WBCP_VPW_THRESH 18 +#define BM_ANADIG_ANA_MISC0_WBCP_VPW_THRESH 0x000C0000 +#define BF_ANADIG_ANA_MISC0_WBCP_VPW_THRESH(v) \ + (((v) << 18) & BM_ANADIG_ANA_MISC0_WBCP_VPW_THRESH) +#define BM_ANADIG_ANA_MISC0_OSC_XTALOK_EN 0x00020000 +#define BM_ANADIG_ANA_MISC0_OSC_XTALOK 0x00010000 +#define BP_ANADIG_ANA_MISC0_OSC_I 14 +#define BM_ANADIG_ANA_MISC0_OSC_I 0x0000C000 +#define BF_ANADIG_ANA_MISC0_OSC_I(v) \ + (((v) << 14) & BM_ANADIG_ANA_MISC0_OSC_I) +#define BM_ANADIG_ANA_MISC0_RTC_RINGOSC_EN 0x00002000 +#define BM_ANADIG_ANA_MISC0_STOP_MODE_CONFIG 0x00001000 +#define BP_ANADIG_ANA_MISC0_RSVD0 10 +#define BM_ANADIG_ANA_MISC0_RSVD0 0x00000C00 +#define BF_ANADIG_ANA_MISC0_RSVD0(v) \ + (((v) << 10) & BM_ANADIG_ANA_MISC0_RSVD0) +#define BP_ANADIG_ANA_MISC0_REFTOP_BIAS_TST 8 +#define BM_ANADIG_ANA_MISC0_REFTOP_BIAS_TST 0x00000300 +#define BF_ANADIG_ANA_MISC0_REFTOP_BIAS_TST(v) \ + (((v) << 8) & BM_ANADIG_ANA_MISC0_REFTOP_BIAS_TST) +#define BM_ANADIG_ANA_MISC0_REFTOP_VBGUP 0x00000080 +#define BP_ANADIG_ANA_MISC0_REFTOP_VBGADJ 4 +#define BM_ANADIG_ANA_MISC0_REFTOP_VBGADJ 0x00000070 +#define BF_ANADIG_ANA_MISC0_REFTOP_VBGADJ(v) \ + (((v) << 4) & BM_ANADIG_ANA_MISC0_REFTOP_VBGADJ) +#define BM_ANADIG_ANA_MISC0_REFTOP_SELBIASOFF 0x00000008 +#define BM_ANADIG_ANA_MISC0_REFTOP_LOWPOWER 0x00000004 +#define BM_ANADIG_ANA_MISC0_REFTOP_PWDVBGUP 0x00000002 +#define BM_ANADIG_ANA_MISC0_REFTOP_PWD 0x00000001 + +#define HW_ANADIG_ANA_MISC1 (0x00000160) +#define HW_ANADIG_ANA_MISC1_SET (0x00000164) +#define HW_ANADIG_ANA_MISC1_CLR (0x00000168) +#define HW_ANADIG_ANA_MISC1_TOG (0x0000016c) + +#define BM_ANADIG_ANA_MISC1_IRQ_DIG_BO 0x80000000 +#define BM_ANADIG_ANA_MISC1_IRQ_ANA_BO 0x40000000 +#define BM_ANADIG_ANA_MISC1_IRQ_TEMPSENSE_BO 0x20000000 +#define BP_ANADIG_ANA_MISC1_RSVD0 14 +#define BM_ANADIG_ANA_MISC1_RSVD0 0x1FFFC000 +#define BF_ANADIG_ANA_MISC1_RSVD0(v) \ + (((v) << 14) & BM_ANADIG_ANA_MISC1_RSVD0) +#define BM_ANADIG_ANA_MISC1_LVDSCLK2_IBEN 0x00002000 +#define BM_ANADIG_ANA_MISC1_LVDSCLK1_IBEN 0x00001000 +#define BM_ANADIG_ANA_MISC1_LVDSCLK2_OBEN 0x00000800 +#define BM_ANADIG_ANA_MISC1_LVDSCLK1_OBEN 0x00000400 +#define BP_ANADIG_ANA_MISC1_LVDS2_CLK_SEL 5 +#define BM_ANADIG_ANA_MISC1_LVDS2_CLK_SEL 0x000003E0 +#define BF_ANADIG_ANA_MISC1_LVDS2_CLK_SEL(v) \ + (((v) << 5) & BM_ANADIG_ANA_MISC1_LVDS2_CLK_SEL) +#define BP_ANADIG_ANA_MISC1_LVDS1_CLK_SEL 0 +#define BM_ANADIG_ANA_MISC1_LVDS1_CLK_SEL 0x0000001F +#define BF_ANADIG_ANA_MISC1_LVDS1_CLK_SEL(v) \ + (((v) << 0) & BM_ANADIG_ANA_MISC1_LVDS1_CLK_SEL) + +#define HW_ANADIG_ANA_MISC2 (0x00000170) +#define HW_ANADIG_ANA_MISC2_SET (0x00000174) +#define HW_ANADIG_ANA_MISC2_CLR (0x00000178) +#define HW_ANADIG_ANA_MISC2_TOG (0x0000017c) + +#define BP_ANADIG_ANA_MISC2_CONTROL3 30 +#define BM_ANADIG_ANA_MISC2_CONTROL3 0xC0000000 +#define BF_ANADIG_ANA_MISC2_CONTROL3(v) \ + (((v) << 30) & BM_ANADIG_ANA_MISC2_CONTROL3) +#define BP_ANADIG_ANA_MISC2_REG2_STEP_TIME 28 +#define BM_ANADIG_ANA_MISC2_REG2_STEP_TIME 0x30000000 +#define BF_ANADIG_ANA_MISC2_REG2_STEP_TIME(v) \ + (((v) << 28) & BM_ANADIG_ANA_MISC2_REG2_STEP_TIME) +#define BP_ANADIG_ANA_MISC2_REG1_STEP_TIME 26 +#define BM_ANADIG_ANA_MISC2_REG1_STEP_TIME 0x0C000000 +#define BF_ANADIG_ANA_MISC2_REG1_STEP_TIME(v) \ + (((v) << 26) & BM_ANADIG_ANA_MISC2_REG1_STEP_TIME) +#define BP_ANADIG_ANA_MISC2_REG0_STEP_TIME 24 +#define BM_ANADIG_ANA_MISC2_REG0_STEP_TIME 0x03000000 +#define BF_ANADIG_ANA_MISC2_REG0_STEP_TIME(v) \ + (((v) << 24) & BM_ANADIG_ANA_MISC2_REG0_STEP_TIME) +#define BM_ANADIG_ANA_MISC2_CONTROL2 0x00800000 +#define BM_ANADIG_ANA_MISC2_REG2_OK 0x00400000 +#define BM_ANADIG_ANA_MISC2_REG2_ENABLE_BO 0x00200000 +#define BM_ANADIG_ANA_MISC2_RSVD2 0x00100000 +#define BM_ANADIG_ANA_MISC2_REG2_BO_STATUS 0x00080000 +#define BP_ANADIG_ANA_MISC2_REG2_BO_OFFSET 16 +#define BM_ANADIG_ANA_MISC2_REG2_BO_OFFSET 0x00070000 +#define BF_ANADIG_ANA_MISC2_REG2_BO_OFFSET(v) \ + (((v) << 16) & BM_ANADIG_ANA_MISC2_REG2_BO_OFFSET) +#define BM_ANADIG_ANA_MISC2_CONTROL1 0x00008000 +#define BM_ANADIG_ANA_MISC2_REG1_OK 0x00004000 +#define BM_ANADIG_ANA_MISC2_REG1_ENABLE_BO 0x00002000 +#define BM_ANADIG_ANA_MISC2_RSVD1 0x00001000 +#define BM_ANADIG_ANA_MISC2_REG1_BO_STATUS 0x00000800 +#define BP_ANADIG_ANA_MISC2_REG1_BO_OFFSET 8 +#define BM_ANADIG_ANA_MISC2_REG1_BO_OFFSET 0x00000700 +#define BF_ANADIG_ANA_MISC2_REG1_BO_OFFSET(v) \ + (((v) << 8) & BM_ANADIG_ANA_MISC2_REG1_BO_OFFSET) +#define BM_ANADIG_ANA_MISC2_CONTROL0 0x00000080 +#define BM_ANADIG_ANA_MISC2_REG0_OK 0x00000040 +#define BM_ANADIG_ANA_MISC2_REG0_ENABLE_BO 0x00000020 +#define BM_ANADIG_ANA_MISC2_RSVD0 0x00000010 +#define BM_ANADIG_ANA_MISC2_REG0_BO_STATUS 0x00000008 +#define BP_ANADIG_ANA_MISC2_REG0_BO_OFFSET 0 +#define BM_ANADIG_ANA_MISC2_REG0_BO_OFFSET 0x00000007 +#define BF_ANADIG_ANA_MISC2_REG0_BO_OFFSET(v) \ + (((v) << 0) & BM_ANADIG_ANA_MISC2_REG0_BO_OFFSET) + +#define HW_ANADIG_TEMPSENSE0 (0x00000180) +#define HW_ANADIG_TEMPSENSE0_SET (0x00000184) +#define HW_ANADIG_TEMPSENSE0_CLR (0x00000188) +#define HW_ANADIG_TEMPSENSE0_TOG (0x0000018c) + +#define BP_ANADIG_TEMPSENSE0_ALARM_VALUE 20 +#define BM_ANADIG_TEMPSENSE0_ALARM_VALUE 0xFFF00000 +#define BF_ANADIG_TEMPSENSE0_ALARM_VALUE(v) \ + (((v) << 20) & BM_ANADIG_TEMPSENSE0_ALARM_VALUE) +#define BP_ANADIG_TEMPSENSE0_TEMP_VALUE 8 +#define BM_ANADIG_TEMPSENSE0_TEMP_VALUE 0x000FFF00 +#define BF_ANADIG_TEMPSENSE0_TEMP_VALUE(v) \ + (((v) << 8) & BM_ANADIG_TEMPSENSE0_TEMP_VALUE) +#define BM_ANADIG_TEMPSENSE0_RSVD0 0x00000080 +#define BM_ANADIG_TEMPSENSE0_TEST 0x00000040 +#define BP_ANADIG_TEMPSENSE0_VBGADJ 3 +#define BM_ANADIG_TEMPSENSE0_VBGADJ 0x00000038 +#define BF_ANADIG_TEMPSENSE0_VBGADJ(v) \ + (((v) << 3) & BM_ANADIG_TEMPSENSE0_VBGADJ) +#define BM_ANADIG_TEMPSENSE0_FINISHED 0x00000004 +#define BM_ANADIG_TEMPSENSE0_MEASURE_TEMP 0x00000002 +#define BM_ANADIG_TEMPSENSE0_POWER_DOWN 0x00000001 + +#define HW_ANADIG_TEMPSENSE1 (0x00000190) +#define HW_ANADIG_TEMPSENSE1_SET (0x00000194) +#define HW_ANADIG_TEMPSENSE1_CLR (0x00000198) +#define HW_ANADIG_TEMPSENSE1_TOG (0x0000019c) + +#define BP_ANADIG_TEMPSENSE1_RSVD0 16 +#define BM_ANADIG_TEMPSENSE1_RSVD0 0xFFFF0000 +#define BF_ANADIG_TEMPSENSE1_RSVD0(v) \ + (((v) << 16) & BM_ANADIG_TEMPSENSE1_RSVD0) +#define BP_ANADIG_TEMPSENSE1_MEASURE_FREQ 0 +#define BM_ANADIG_TEMPSENSE1_MEASURE_FREQ 0x0000FFFF +#define BF_ANADIG_TEMPSENSE1_MEASURE_FREQ(v) \ + (((v) << 0) & BM_ANADIG_TEMPSENSE1_MEASURE_FREQ) + +#define HW_ANADIG_USB1_VBUS_DETECT (0x000001a0) +#define HW_ANADIG_USB1_VBUS_DETECT_SET (0x000001a4) +#define HW_ANADIG_USB1_VBUS_DETECT_CLR (0x000001a8) +#define HW_ANADIG_USB1_VBUS_DETECT_TOG (0x000001ac) + +#define BM_ANADIG_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR 0x80000000 +#define BP_ANADIG_USB1_VBUS_DETECT_RSVD2 28 +#define BM_ANADIG_USB1_VBUS_DETECT_RSVD2 0x70000000 +#define BF_ANADIG_USB1_VBUS_DETECT_RSVD2(v) \ + (((v) << 28) & BM_ANADIG_USB1_VBUS_DETECT_RSVD2) +#define BM_ANADIG_USB1_VBUS_DETECT_CHARGE_VBUS 0x08000000 +#define BM_ANADIG_USB1_VBUS_DETECT_DISCHARGE_VBUS 0x04000000 +#define BP_ANADIG_USB1_VBUS_DETECT_RSVD1 21 +#define BM_ANADIG_USB1_VBUS_DETECT_RSVD1 0x03E00000 +#define BF_ANADIG_USB1_VBUS_DETECT_RSVD1(v) \ + (((v) << 21) & BM_ANADIG_USB1_VBUS_DETECT_RSVD1) +#define BM_ANADIG_USB1_VBUS_DETECT_VBUSVALID_PWRUP_CMPS 0x00100000 +#define BM_ANADIG_USB1_VBUS_DETECT_VBUSVALID_5VDETECT 0x00080000 +#define BM_ANADIG_USB1_VBUS_DETECT_VBUSVALID_TO_B 0x00040000 +#define BP_ANADIG_USB1_VBUS_DETECT_RSVD0 8 +#define BM_ANADIG_USB1_VBUS_DETECT_RSVD0 0x0003FF00 +#define BF_ANADIG_USB1_VBUS_DETECT_RSVD0(v) \ + (((v) << 8) & BM_ANADIG_USB1_VBUS_DETECT_RSVD0) +#define BM_ANADIG_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE 0x00000080 +#define BM_ANADIG_USB1_VBUS_DETECT_AVALID_OVERRIDE 0x00000040 +#define BM_ANADIG_USB1_VBUS_DETECT_BVALID_OVERRIDE 0x00000020 +#define BM_ANADIG_USB1_VBUS_DETECT_SESSEND_OVERRIDE 0x00000010 +#define BM_ANADIG_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN 0x00000008 +#define BP_ANADIG_USB1_VBUS_DETECT_VBUSVALID_THRESH 0 +#define BM_ANADIG_USB1_VBUS_DETECT_VBUSVALID_THRESH 0x00000007 +#define BF_ANADIG_USB1_VBUS_DETECT_VBUSVALID_THRESH(v) \ + (((v) << 0) & BM_ANADIG_USB1_VBUS_DETECT_VBUSVALID_THRESH) + +#define HW_ANADIG_USB1_CHRG_DETECT (0x000001b0) +#define HW_ANADIG_USB1_CHRG_DETECT_SET (0x000001b4) +#define HW_ANADIG_USB1_CHRG_DETECT_CLR (0x000001b8) +#define HW_ANADIG_USB1_CHRG_DETECT_TOG (0x000001bc) + +#define BP_ANADIG_USB1_CHRG_DETECT_RSVD2 24 +#define BM_ANADIG_USB1_CHRG_DETECT_RSVD2 0xFF000000 +#define BF_ANADIG_USB1_CHRG_DETECT_RSVD2(v) \ + (((v) << 24) & BM_ANADIG_USB1_CHRG_DETECT_RSVD2) +#define BM_ANADIG_USB1_CHRG_DETECT_BGR_BIAS 0x00800000 +#define BP_ANADIG_USB1_CHRG_DETECT_RSVD1 21 +#define BM_ANADIG_USB1_CHRG_DETECT_RSVD1 0x00600000 +#define BF_ANADIG_USB1_CHRG_DETECT_RSVD1(v) \ + (((v) << 21) & BM_ANADIG_USB1_CHRG_DETECT_RSVD1) +#define BM_ANADIG_USB1_CHRG_DETECT_EN_B 0x00100000 +#define BM_ANADIG_USB1_CHRG_DETECT_CHK_CHRG_B 0x00080000 +#define BM_ANADIG_USB1_CHRG_DETECT_CHK_CONTACT 0x00040000 +#define BP_ANADIG_USB1_CHRG_DETECT_RSVD0 1 +#define BM_ANADIG_USB1_CHRG_DETECT_RSVD0 0x0003FFFE +#define BF_ANADIG_USB1_CHRG_DETECT_RSVD0(v) \ + (((v) << 1) & BM_ANADIG_USB1_CHRG_DETECT_RSVD0) +#define BM_ANADIG_USB1_CHRG_DETECT_FORCE_DETECT 0x00000001 + +#define HW_ANADIG_USB1_VBUS_DET_STAT (0x000001c0) +#define HW_ANADIG_USB1_VBUS_DET_STAT_SET (0x000001c4) +#define HW_ANADIG_USB1_VBUS_DET_STAT_CLR (0x000001c8) +#define HW_ANADIG_USB1_VBUS_DET_STAT_TOG (0x000001cc) + +#define BP_ANADIG_USB1_VBUS_DET_STAT_RSVD0 4 +#define BM_ANADIG_USB1_VBUS_DET_STAT_RSVD0 0xFFFFFFF0 +#define BF_ANADIG_USB1_VBUS_DET_STAT_RSVD0(v) \ + (((v) << 4) & BM_ANADIG_USB1_VBUS_DET_STAT_RSVD0) +#define BM_ANADIG_USB1_VBUS_DET_STAT_VBUS_VALID 0x00000008 +#define BM_ANADIG_USB1_VBUS_DET_STAT_AVALID 0x00000004 +#define BM_ANADIG_USB1_VBUS_DET_STAT_BVALID 0x00000002 +#define BM_ANADIG_USB1_VBUS_DET_STAT_SESSEND 0x00000001 + +#define HW_ANADIG_USB1_CHRG_DET_STAT (0x000001d0) +#define HW_ANADIG_USB1_CHRG_DET_STAT_SET (0x000001d4) +#define HW_ANADIG_USB1_CHRG_DET_STAT_CLR (0x000001d8) +#define HW_ANADIG_USB1_CHRG_DET_STAT_TOG (0x000001dc) + +#define BP_ANADIG_USB1_CHRG_DET_STAT_RSVD0 4 +#define BM_ANADIG_USB1_CHRG_DET_STAT_RSVD0 0xFFFFFFF0 +#define BF_ANADIG_USB1_CHRG_DET_STAT_RSVD0(v) \ + (((v) << 4) & BM_ANADIG_USB1_CHRG_DET_STAT_RSVD0) +#define BM_ANADIG_USB1_CHRG_DET_STAT_DP_STATE 0x00000008 +#define BM_ANADIG_USB1_CHRG_DET_STAT_DM_STATE 0x00000004 +#define BM_ANADIG_USB1_CHRG_DET_STAT_CHRG_DETECTED 0x00000002 +#define BM_ANADIG_USB1_CHRG_DET_STAT_PLUG_CONTACT 0x00000001 + +#define HW_ANADIG_USB1_LOOPBACK (0x000001e0) +#define HW_ANADIG_USB1_LOOPBACK_SET (0x000001e4) +#define HW_ANADIG_USB1_LOOPBACK_CLR (0x000001e8) +#define HW_ANADIG_USB1_LOOPBACK_TOG (0x000001ec) + +#define BP_ANADIG_USB1_LOOPBACK_RSVD0 9 +#define BM_ANADIG_USB1_LOOPBACK_RSVD0 0xFFFFFE00 +#define BF_ANADIG_USB1_LOOPBACK_RSVD0(v) \ + (((v) << 9) & BM_ANADIG_USB1_LOOPBACK_RSVD0) +#define BM_ANADIG_USB1_LOOPBACK_UTMO_DIG_TST1 0x00000100 +#define BM_ANADIG_USB1_LOOPBACK_UTMO_DIG_TST0 0x00000080 +#define BM_ANADIG_USB1_LOOPBACK_TSTI_TX_HIZ 0x00000040 +#define BM_ANADIG_USB1_LOOPBACK_TSTI_TX_EN 0x00000020 +#define BM_ANADIG_USB1_LOOPBACK_TSTI_TX_LS_MODE 0x00000010 +#define BM_ANADIG_USB1_LOOPBACK_TSTI_TX_HS_MODE 0x00000008 +#define BM_ANADIG_USB1_LOOPBACK_UTMI_DIG_TST1 0x00000004 +#define BM_ANADIG_USB1_LOOPBACK_UTMI_DIG_TST0 0x00000002 +#define BM_ANADIG_USB1_LOOPBACK_UTMI_TESTSTART 0x00000001 + +#define HW_ANADIG_USB1_MISC (0x000001f0) +#define HW_ANADIG_USB1_MISC_SET (0x000001f4) +#define HW_ANADIG_USB1_MISC_CLR (0x000001f8) +#define HW_ANADIG_USB1_MISC_TOG (0x000001fc) + +#define BM_ANADIG_USB1_MISC_RSVD1 0x80000000 +#define BM_ANADIG_USB1_MISC_EN_CLK_UTMI 0x40000000 +#define BM_ANADIG_USB1_MISC_RX_VPIN_FS 0x20000000 +#define BM_ANADIG_USB1_MISC_RX_VMIN_FS 0x10000000 +#define BM_ANADIG_USB1_MISC_RX_RXD_FS 0x08000000 +#define BM_ANADIG_USB1_MISC_RX_SQUELCH 0x04000000 +#define BM_ANADIG_USB1_MISC_RX_DISCON_DET 0x02000000 +#define BM_ANADIG_USB1_MISC_RX_HS_DATA 0x01000000 +#define BP_ANADIG_USB1_MISC_RSVD0 2 +#define BM_ANADIG_USB1_MISC_RSVD0 0x00FFFFFC +#define BF_ANADIG_USB1_MISC_RSVD0(v) \ + (((v) << 2) & BM_ANADIG_USB1_MISC_RSVD0) +#define BM_ANADIG_USB1_MISC_EN_DEGLITCH 0x00000002 +#define BM_ANADIG_USB1_MISC_HS_USE_EXTERNAL_R 0x00000001 + +#define HW_ANADIG_USB2_VBUS_DETECT (0x00000200) +#define HW_ANADIG_USB2_VBUS_DETECT_SET (0x00000204) +#define HW_ANADIG_USB2_VBUS_DETECT_CLR (0x00000208) +#define HW_ANADIG_USB2_VBUS_DETECT_TOG (0x0000020c) + +#define BM_ANADIG_USB2_VBUS_DETECT_EN_CHARGER_RESISTOR 0x80000000 +#define BP_ANADIG_USB2_VBUS_DETECT_RSVD2 28 +#define BM_ANADIG_USB2_VBUS_DETECT_RSVD2 0x70000000 +#define BF_ANADIG_USB2_VBUS_DETECT_RSVD2(v) \ + (((v) << 28) & BM_ANADIG_USB2_VBUS_DETECT_RSVD2) +#define BM_ANADIG_USB2_VBUS_DETECT_CHARGE_VBUS 0x08000000 +#define BM_ANADIG_USB2_VBUS_DETECT_DISCHARGE_VBUS 0x04000000 +#define BP_ANADIG_USB2_VBUS_DETECT_RSVD1 21 +#define BM_ANADIG_USB2_VBUS_DETECT_RSVD1 0x03E00000 +#define BF_ANADIG_USB2_VBUS_DETECT_RSVD1(v) \ + (((v) << 21) & BM_ANADIG_USB2_VBUS_DETECT_RSVD1) +#define BM_ANADIG_USB2_VBUS_DETECT_VBUSVALID_PWRUP_CMPS 0x00100000 +#define BM_ANADIG_USB2_VBUS_DETECT_VBUSVALID_5VDETECT 0x00080000 +#define BM_ANADIG_USB2_VBUS_DETECT_VBUSVALID_TO_B 0x00040000 +#define BP_ANADIG_USB2_VBUS_DETECT_RSVD0 3 +#define BM_ANADIG_USB2_VBUS_DETECT_RSVD0 0x0003FFF8 +#define BF_ANADIG_USB2_VBUS_DETECT_RSVD0(v) \ + (((v) << 3) & BM_ANADIG_USB2_VBUS_DETECT_RSVD0) +#define BP_ANADIG_USB2_VBUS_DETECT_VBUSVALID_THRESH 0 +#define BM_ANADIG_USB2_VBUS_DETECT_VBUSVALID_THRESH 0x00000007 +#define BF_ANADIG_USB2_VBUS_DETECT_VBUSVALID_THRESH(v) \ + (((v) << 0) & BM_ANADIG_USB2_VBUS_DETECT_VBUSVALID_THRESH) + +#define HW_ANADIG_USB2_CHRG_DETECT (0x00000210) +#define HW_ANADIG_USB2_CHRG_DETECT_SET (0x00000214) +#define HW_ANADIG_USB2_CHRG_DETECT_CLR (0x00000218) +#define HW_ANADIG_USB2_CHRG_DETECT_TOG (0x0000021c) + +#define BP_ANADIG_USB2_CHRG_DETECT_RSVD2 24 +#define BM_ANADIG_USB2_CHRG_DETECT_RSVD2 0xFF000000 +#define BF_ANADIG_USB2_CHRG_DETECT_RSVD2(v) \ + (((v) << 24) & BM_ANADIG_USB2_CHRG_DETECT_RSVD2) +#define BM_ANADIG_USB2_CHRG_DETECT_BGR_BIAS 0x00800000 +#define BP_ANADIG_USB2_CHRG_DETECT_RSVD1 21 +#define BM_ANADIG_USB2_CHRG_DETECT_RSVD1 0x00600000 +#define BF_ANADIG_USB2_CHRG_DETECT_RSVD1(v) \ + (((v) << 21) & BM_ANADIG_USB2_CHRG_DETECT_RSVD1) +#define BM_ANADIG_USB2_CHRG_DETECT_EN_B 0x00100000 +#define BM_ANADIG_USB2_CHRG_DETECT_CHK_CHRG_B 0x00080000 +#define BM_ANADIG_USB2_CHRG_DETECT_CHK_CONTACT 0x00040000 +#define BP_ANADIG_USB2_CHRG_DETECT_RSVD0 1 +#define BM_ANADIG_USB2_CHRG_DETECT_RSVD0 0x0003FFFE +#define BF_ANADIG_USB2_CHRG_DETECT_RSVD0(v) \ + (((v) << 1) & BM_ANADIG_USB2_CHRG_DETECT_RSVD0) +#define BM_ANADIG_USB2_CHRG_DETECT_FORCE_DETECT 0x00000001 + +#define HW_ANADIG_USB2_VBUS_DET_STAT (0x00000220) +#define HW_ANADIG_USB2_VBUS_DET_STAT_SET (0x00000224) +#define HW_ANADIG_USB2_VBUS_DET_STAT_CLR (0x00000228) +#define HW_ANADIG_USB2_VBUS_DET_STAT_TOG (0x0000022c) + +#define BP_ANADIG_USB2_VBUS_DET_STAT_RSVD0 4 +#define BM_ANADIG_USB2_VBUS_DET_STAT_RSVD0 0xFFFFFFF0 +#define BF_ANADIG_USB2_VBUS_DET_STAT_RSVD0(v) \ + (((v) << 4) & BM_ANADIG_USB2_VBUS_DET_STAT_RSVD0) +#define BM_ANADIG_USB2_VBUS_DET_STAT_VBUS_VALID 0x00000008 +#define BM_ANADIG_USB2_VBUS_DET_STAT_AVALID 0x00000004 +#define BM_ANADIG_USB2_VBUS_DET_STAT_BVALID 0x00000002 +#define BM_ANADIG_USB2_VBUS_DET_STAT_SESSEND 0x00000001 + +#define HW_ANADIG_USB2_CHRG_DET_STAT (0x00000230) +#define HW_ANADIG_USB2_CHRG_DET_STAT_SET (0x00000234) +#define HW_ANADIG_USB2_CHRG_DET_STAT_CLR (0x00000238) +#define HW_ANADIG_USB2_CHRG_DET_STAT_TOG (0x0000023c) + +#define BP_ANADIG_USB2_CHRG_DET_STAT_RSVD0 4 +#define BM_ANADIG_USB2_CHRG_DET_STAT_RSVD0 0xFFFFFFF0 +#define BF_ANADIG_USB2_CHRG_DET_STAT_RSVD0(v) \ + (((v) << 4) & BM_ANADIG_USB2_CHRG_DET_STAT_RSVD0) +#define BM_ANADIG_USB2_CHRG_DET_STAT_DP_STATE 0x00000008 +#define BM_ANADIG_USB2_CHRG_DET_STAT_DM_STATE 0x00000004 +#define BM_ANADIG_USB2_CHRG_DET_STAT_CHRG_DETECTED 0x00000002 +#define BM_ANADIG_USB2_CHRG_DET_STAT_PLUG_CONTACT 0x00000001 + +#define HW_ANADIG_USB2_LOOPBACK (0x00000240) +#define HW_ANADIG_USB2_LOOPBACK_SET (0x00000244) +#define HW_ANADIG_USB2_LOOPBACK_CLR (0x00000248) +#define HW_ANADIG_USB2_LOOPBACK_TOG (0x0000024c) + +#define BP_ANADIG_USB2_LOOPBACK_RSVD0 9 +#define BM_ANADIG_USB2_LOOPBACK_RSVD0 0xFFFFFE00 +#define BF_ANADIG_USB2_LOOPBACK_RSVD0(v) \ + (((v) << 9) & BM_ANADIG_USB2_LOOPBACK_RSVD0) +#define BM_ANADIG_USB2_LOOPBACK_UTMO_DIG_TST1 0x00000100 +#define BM_ANADIG_USB2_LOOPBACK_UTMO_DIG_TST0 0x00000080 +#define BM_ANADIG_USB2_LOOPBACK_TSTI_TX_HIZ 0x00000040 +#define BM_ANADIG_USB2_LOOPBACK_TSTI_TX_EN 0x00000020 +#define BM_ANADIG_USB2_LOOPBACK_TSTI_TX_LS_MODE 0x00000010 +#define BM_ANADIG_USB2_LOOPBACK_TSTI_TX_HS_MODE 0x00000008 +#define BM_ANADIG_USB2_LOOPBACK_UTMI_DIG_TST1 0x00000004 +#define BM_ANADIG_USB2_LOOPBACK_UTMI_DIG_TST0 0x00000002 +#define BM_ANADIG_USB2_LOOPBACK_UTMI_TESTSTART 0x00000001 + +#define HW_ANADIG_USB2_MISC (0x00000250) +#define HW_ANADIG_USB2_MISC_SET (0x00000254) +#define HW_ANADIG_USB2_MISC_CLR (0x00000258) +#define HW_ANADIG_USB2_MISC_TOG (0x0000025c) + +#define BM_ANADIG_USB2_MISC_RSVD1 0x80000000 +#define BM_ANADIG_USB2_MISC_EN_CLK_UTMI 0x40000000 +#define BM_ANADIG_USB2_MISC_RX_VPIN_FS 0x20000000 +#define BM_ANADIG_USB2_MISC_RX_VMIN_FS 0x10000000 +#define BM_ANADIG_USB2_MISC_RX_RXD_FS 0x08000000 +#define BM_ANADIG_USB2_MISC_RX_SQUELCH 0x04000000 +#define BM_ANADIG_USB2_MISC_RX_DISCON_DET 0x02000000 +#define BM_ANADIG_USB2_MISC_RX_HS_DATA 0x01000000 +#define BP_ANADIG_USB2_MISC_RSVD0 2 +#define BM_ANADIG_USB2_MISC_RSVD0 0x00FFFFFC +#define BF_ANADIG_USB2_MISC_RSVD0(v) \ + (((v) << 2) & BM_ANADIG_USB2_MISC_RSVD0) +#define BM_ANADIG_USB2_MISC_EN_DEGLITCH 0x00000002 +#define BM_ANADIG_USB2_MISC_HS_USE_EXTERNAL_R 0x00000001 + +#define HW_ANADIG_DIGPROG (0x00000260) + +#define BP_ANADIG_DIGPROG_RSVD 24 +#define BM_ANADIG_DIGPROG_RSVD 0xFF000000 +#define BF_ANADIG_DIGPROG_RSVD(v) \ + (((v) << 24) & BM_ANADIG_DIGPROG_RSVD) +#define BP_ANADIG_DIGPROG_MAJOR 8 +#define BM_ANADIG_DIGPROG_MAJOR 0x00FFFF00 +#define BF_ANADIG_DIGPROG_MAJOR(v) \ + (((v) << 8) & BM_ANADIG_DIGPROG_MAJOR) +#define BP_ANADIG_DIGPROG_MINOR 0 +#define BM_ANADIG_DIGPROG_MINOR 0x000000FF +#define BF_ANADIG_DIGPROG_MINOR(v) \ + (((v) << 0) & BM_ANADIG_DIGPROG_MINOR) + #endif /*__ARCH_ARM_MACH_MX6_CCM_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 2631beb..62b72a5 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2011 Freescale Semiconductor, Inc. All Rights Reserved. + * Copyright (C) 2011-2014 Freescale Semiconductor, Inc. All Rights Reserved. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -587,6 +587,12 @@ struct fuse_bank0_regs { u32 rsvd7[4]; };
+struct fuse_bank1_regs { + u32 mem[0x18]; + u32 ana1; + u32 ana2; +}; + #ifdef CONFIG_MX6SX struct fuse_bank4_regs { u32 sjc_resp_low; @@ -805,5 +811,6 @@ struct pwm_regs { u32 pr; u32 cnr; }; +extern void check_cpu_temperature(void); #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */
