[PATCH 1/5] qe: Add <config.h> to linux/immap_qe.h
Given how we define QE_MURAM_SIZE today, this header needs to have <config.h> added to it.
Signed-off-by: Tom Rini trini@konsulko.com --- include/linux/immap_qe.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/linux/immap_qe.h b/include/linux/immap_qe.h index 45307f51c103..a692f5dfb373 100644 --- a/include/linux/immap_qe.h +++ b/include/linux/immap_qe.h @@ -11,6 +11,8 @@ #ifndef __IMMAP_QE_H__ #define __IMMAP_QE_H__
+#include <config.h> + #ifdef CONFIG_MPC83xx #if defined(CONFIG_ARCH_MPC8360) #define QE_MURAM_SIZE 0xc000UL
We need to include <config.h> directly when a file needs to have something such as CFG_SYS_SDRAM_SIZE referenced as this file is not automatically globally included and is most commonly indirectly included via common.h. Remove most cases of arc including config.h directly, but add it where needed. Further clean up the tb100 board config.h file so that we don't rely on config.h being included there for a value used in a single place.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Alexey Brodkin abrodkin@synopsys.com Cc: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com Cc: uboot-snps-arc@synopsys.com --- arch/arc/include/asm/arc-bcr.h | 2 -- arch/arc/include/asm/arcregs.h | 1 - arch/arc/include/asm/cache.h | 2 -- arch/arc/lib/cpu.c | 1 + board/abilis/tb100/tb100.c | 4 ++++ include/configs/tb100.h | 21 --------------------- 6 files changed, 5 insertions(+), 26 deletions(-)
diff --git a/arch/arc/include/asm/arc-bcr.h b/arch/arc/include/asm/arc-bcr.h index 823906d946e4..a6c972bf1e31 100644 --- a/arch/arc/include/asm/arc-bcr.h +++ b/arch/arc/include/asm/arc-bcr.h @@ -13,8 +13,6 @@ #define __ARC_BCR_H #ifndef __ASSEMBLY__
-#include <config.h> - union bcr_di_cache { struct { #ifdef CONFIG_CPU_BIG_ENDIAN diff --git a/arch/arc/include/asm/arcregs.h b/arch/arc/include/asm/arcregs.h index a9f54f61e0cc..273fb8eed859 100644 --- a/arch/arc/include/asm/arcregs.h +++ b/arch/arc/include/asm/arcregs.h @@ -7,7 +7,6 @@ #define _ASM_ARC_ARCREGS_H
#include <asm/cache.h> -#include <config.h>
/* * ARC architecture has additional address space - auxiliary registers. diff --git a/arch/arc/include/asm/cache.h b/arch/arc/include/asm/cache.h index 74cff716ef60..65dff4214830 100644 --- a/arch/arc/include/asm/cache.h +++ b/arch/arc/include/asm/cache.h @@ -6,8 +6,6 @@ #ifndef __ASM_ARC_CACHE_H #define __ASM_ARC_CACHE_H
-#include <config.h> - /* * As of today we may handle any L1 cache line length right in software. * For that essentially cache line length is a variable not constant. diff --git a/arch/arc/lib/cpu.c b/arch/arc/lib/cpu.c index 803dfd425580..593950449f2e 100644 --- a/arch/arc/lib/cpu.c +++ b/arch/arc/lib/cpu.c @@ -3,6 +3,7 @@ * Copyright (C) 2013-2014, 2018 Synopsys, Inc. All rights reserved. */
+#include <config.h> #include <clock_legacy.h> #include <init.h> #include <malloc.h> diff --git a/board/abilis/tb100/tb100.c b/board/abilis/tb100/tb100.c index 3dc9e14ef8c0..eb7d12908134 100644 --- a/board/abilis/tb100/tb100.c +++ b/board/abilis/tb100/tb100.c @@ -14,6 +14,10 @@ void reset_cpu(void) writel(0x1, (void *)CRM_SWRESET); }
+/* + * Ethernet configuration + */ +#define ETH0_BASE_ADDRESS 0xFE100000 int board_eth_init(struct bd_info *bis) { if (designware_initialize(ETH0_BASE_ADDRESS, 0) >= 0) diff --git a/include/configs/tb100.h b/include/configs/tb100.h index 1318f5e5ee44..08b6f3219c33 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -21,25 +21,4 @@ */ #define CFG_SYS_NS16550_CLK 166666666
-/* - * Even though the board houses Realtek RTL8211E PHY - * corresponding PHY driver (drivers/net/phy/realtek.c) behaves unexpectedly. - * In particular "parse_status" reports link is down. - * - * Until Realtek PHY driver is fixed fall back to generic PHY driver - * which implements all required functionality and behaves much more stable. - * - * - */ - -/* - * Ethernet configuration - */ -#define ETH0_BASE_ADDRESS 0xFE100000 -#define ETH1_BASE_ADDRESS 0xFE110000 - -/* - * Console configuration - */ - #endif /* _CONFIG_TB100_H_ */
We need to include <config.h> directly when a file needs to have something such as CFG_SYS_SDRAM_SIZE referenced as this file is not automatically globally included and is most commonly indirectly included via common.h. Remove most cases of arm including config.h directly, but add it where needed. This includes a few board-specific fixes.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h | 2 -- arch/arm/include/asm/arch-ls102xa/fsl_serdes.h | 2 -- arch/arm/include/asm/assembler.h | 1 - arch/arm/include/asm/secure.h | 1 - arch/arm/include/asm/string.h | 2 -- arch/arm/mach-davinci/include/mach/pinmux_defs.h | 1 - arch/arm/mach-exynos/exynos4_setup.h | 1 - arch/arm/mach-exynos/exynos5_setup.h | 1 - arch/arm/mach-k3/common.c | 1 + arch/arm/mach-k3/include/mach/clock.h | 2 -- arch/arm/mach-k3/include/mach/j721e_hardware.h | 1 - arch/arm/mach-k3/include/mach/j721s2_hardware.h | 1 - arch/arm/mach-k3/r5_mpu.c | 1 + board/freescale/ls1088a/eth_ls1088aqds.c | 1 + board/freescale/ls2080aqds/eth.c | 1 + board/toradex/verdin-am62/verdin-am62.c | 1 + drivers/ddr/marvell/axp/ddr3_axp.h | 2 ++ 17 files changed, 7 insertions(+), 15 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index 8f4365175697..9e29350ca4ba 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -7,8 +7,6 @@ #ifndef __FSL_SERDES_H__ #define __FSL_SERDES_H__
-#include <config.h> - #ifdef CONFIG_FSL_LSCH3 enum srds_prtcl { /* diff --git a/arch/arm/include/asm/arch-ls102xa/fsl_serdes.h b/arch/arm/include/asm/arch-ls102xa/fsl_serdes.h index d99a6f318f8b..9244e0a78fd3 100644 --- a/arch/arm/include/asm/arch-ls102xa/fsl_serdes.h +++ b/arch/arm/include/asm/arch-ls102xa/fsl_serdes.h @@ -6,8 +6,6 @@ #ifndef __FSL_SERDES_H #define __FSL_SERDES_H
-#include <config.h> - enum srds_prtcl { /* * Nobody will check whether the device 'NONE' has been configured, diff --git a/arch/arm/include/asm/assembler.h b/arch/arm/include/asm/assembler.h index 8d42ef4823e9..4fda483b8d8d 100644 --- a/arch/arm/include/asm/assembler.h +++ b/arch/arm/include/asm/assembler.h @@ -14,7 +14,6 @@ * assembler source. */
-#include <config.h> #include <asm/unified.h>
/* diff --git a/arch/arm/include/asm/secure.h b/arch/arm/include/asm/secure.h index c7b00be8e0b9..abfa46470b2c 100644 --- a/arch/arm/include/asm/secure.h +++ b/arch/arm/include/asm/secure.h @@ -1,7 +1,6 @@ #ifndef __ASM_SECURE_H #define __ASM_SECURE_H
-#include <config.h> #include <asm/global_data.h>
#define __secure __section("._secure.text") diff --git a/arch/arm/include/asm/string.h b/arch/arm/include/asm/string.h index ead3f2c35643..c9ecdde0d3d8 100644 --- a/arch/arm/include/asm/string.h +++ b/arch/arm/include/asm/string.h @@ -1,8 +1,6 @@ #ifndef __ASM_ARM_STRING_H #define __ASM_ARM_STRING_H
-#include <config.h> - /* * We don't do inline string functions, since the * optimised inline asm versions are not small. diff --git a/arch/arm/mach-davinci/include/mach/pinmux_defs.h b/arch/arm/mach-davinci/include/mach/pinmux_defs.h index 4901ba49c9bb..120935310807 100644 --- a/arch/arm/mach-davinci/include/mach/pinmux_defs.h +++ b/arch/arm/mach-davinci/include/mach/pinmux_defs.h @@ -9,7 +9,6 @@ #define __ASM_ARCH_PINMUX_DEFS_H
#include <asm/arch/davinci_misc.h> -#include <config.h>
/* SPI0 pin muxer settings */ extern const struct pinmux_config spi0_pins_base[3]; diff --git a/arch/arm/mach-exynos/exynos4_setup.h b/arch/arm/mach-exynos/exynos4_setup.h index fbb45eb897e3..23c9011fbc63 100644 --- a/arch/arm/mach-exynos/exynos4_setup.h +++ b/arch/arm/mach-exynos/exynos4_setup.h @@ -8,7 +8,6 @@ #ifndef _ORIGEN_SETUP_H #define _ORIGEN_SETUP_H
-#include <config.h> #include <asm/arch/cpu.h>
/* Bus Configuration Register Address */ diff --git a/arch/arm/mach-exynos/exynos5_setup.h b/arch/arm/mach-exynos/exynos5_setup.h index af7a5afb03cd..e9874a8c1b24 100644 --- a/arch/arm/mach-exynos/exynos5_setup.h +++ b/arch/arm/mach-exynos/exynos5_setup.h @@ -8,7 +8,6 @@ #ifndef _SMDK5250_SETUP_H #define _SMDK5250_SETUP_H
-#include <config.h> #include <asm/arch/dmc.h>
#define NOT_AVAILABLE 0 diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index eff2fff3c706..2bbdd1077652 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -6,6 +6,7 @@ * Lokesh Vutla lokeshvutla@ti.com */
+#include <config.h> #include <cpu_func.h> #include <image.h> #include <init.h> diff --git a/arch/arm/mach-k3/include/mach/clock.h b/arch/arm/mach-k3/include/mach/clock.h index e3adbcd9dedc..850067d5afac 100644 --- a/arch/arm/mach-k3/include/mach/clock.h +++ b/arch/arm/mach-k3/include/mach/clock.h @@ -7,8 +7,6 @@ #ifndef __ASM_ARCH_CLOCK_H #define __ASM_ARCH_CLOCK_H
-#include <config.h> - /* Clock Defines */ #define V_OSCK 24000000 #define V_SCLK V_OSCK diff --git a/arch/arm/mach-k3/include/mach/j721e_hardware.h b/arch/arm/mach-k3/include/mach/j721e_hardware.h index 376db389ba19..d71d3b7a63f7 100644 --- a/arch/arm/mach-k3/include/mach/j721e_hardware.h +++ b/arch/arm/mach-k3/include/mach/j721e_hardware.h @@ -7,7 +7,6 @@ #ifndef __ASM_ARCH_J721E_HARDWARE_H #define __ASM_ARCH_J721E_HARDWARE_H
-#include <config.h> #ifndef __ASSEMBLY__ #include <linux/bitops.h> #endif diff --git a/arch/arm/mach-k3/include/mach/j721s2_hardware.h b/arch/arm/mach-k3/include/mach/j721s2_hardware.h index 7948bcf4789b..c994961c1d19 100644 --- a/arch/arm/mach-k3/include/mach/j721s2_hardware.h +++ b/arch/arm/mach-k3/include/mach/j721s2_hardware.h @@ -7,7 +7,6 @@ #ifndef __ASM_ARCH_J721S2_HARDWARE_H #define __ASM_ARCH_J721S2_HARDWARE_H
-#include <config.h> #ifndef __ASSEMBLY__ #include <linux/bitops.h> #endif diff --git a/arch/arm/mach-k3/r5_mpu.c b/arch/arm/mach-k3/r5_mpu.c index 6786e7e1e5af..ac28ff0f6b4b 100644 --- a/arch/arm/mach-k3/r5_mpu.c +++ b/arch/arm/mach-k3/r5_mpu.c @@ -6,6 +6,7 @@ * Lokesh Vutla lokeshvutla@ti.com */
+#include <config.h> #include <asm/io.h> #include <linux/kernel.h> #include "common.h" diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c index 2fece3a1b09b..e6033d251c56 100644 --- a/board/freescale/ls1088a/eth_ls1088aqds.c +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -3,6 +3,7 @@ * Copyright 2017 NXP */
+#include <config.h> #include <vsprintf.h> #include <linux/string.h> #include <asm/io.h> diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 048ab44c5919..b47e2ec5a793 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -3,6 +3,7 @@ * Copyright 2015 Freescale Semiconductor, Inc. */
+#include <config.h> #include <vsprintf.h> #include <linux/string.h> #include <asm/io.h> diff --git a/board/toradex/verdin-am62/verdin-am62.c b/board/toradex/verdin-am62/verdin-am62.c index d09dda5bccc9..2718263eb19b 100644 --- a/board/toradex/verdin-am62/verdin-am62.c +++ b/board/toradex/verdin-am62/verdin-am62.c @@ -6,6 +6,7 @@ * */
+#include <config.h> #include <asm/arch/hardware.h> #include <asm/io.h> #include <dm/uclass.h> diff --git a/drivers/ddr/marvell/axp/ddr3_axp.h b/drivers/ddr/marvell/axp/ddr3_axp.h index c40cd768abf5..c3d282477f5c 100644 --- a/drivers/ddr/marvell/axp/ddr3_axp.h +++ b/drivers/ddr/marvell/axp/ddr3_axp.h @@ -6,6 +6,8 @@ #ifndef __DDR3_AXP_H #define __DDR3_AXP_H
+#include <config.h> + #define MV_78XX0_Z1_REV 0x0 #define MV_78XX0_A0_REV 0x1 #define MV_78XX0_B0_REV 0x2
Remove and replace common.h and config.h in sandbox when it's not needed and add some explicit includes where needed.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/sandbox/cpu/cache.c | 1 - arch/sandbox/cpu/cpu.c | 1 - arch/sandbox/cpu/sdl.c | 2 +- arch/sandbox/cpu/spl.c | 1 - arch/sandbox/cpu/start.c | 2 +- arch/sandbox/cpu/state.c | 2 +- arch/sandbox/include/asm/io.h | 2 ++ arch/sandbox/include/asm/state.h | 1 - arch/sandbox/lib/bootm.c | 1 - arch/sandbox/lib/fdt_fixup.c | 1 - arch/sandbox/lib/interrupts.c | 1 - arch/sandbox/lib/pci_io.c | 1 - board/sandbox/sandbox.c | 2 +- 13 files changed, 6 insertions(+), 12 deletions(-)
diff --git a/arch/sandbox/cpu/cache.c b/arch/sandbox/cpu/cache.c index 46c62c0b4461..c8a5e64214b6 100644 --- a/arch/sandbox/cpu/cache.c +++ b/arch/sandbox/cpu/cache.c @@ -3,7 +3,6 @@ * Copyright 2020, Heinrich Schuchardt xypron.glpk@gmx.de */
-#include <common.h> #include <cpu_func.h> #include <asm/state.h>
diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index a1c5c7c4311a..d6475c969c4d 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -5,7 +5,6 @@
#define LOG_CATEGORY LOGC_SANDBOX
-#include <common.h> #include <bootstage.h> #include <cpu_func.h> #include <errno.h> diff --git a/arch/sandbox/cpu/sdl.c b/arch/sandbox/cpu/sdl.c index 590e406517bf..ed84646bdab7 100644 --- a/arch/sandbox/cpu/sdl.c +++ b/arch/sandbox/cpu/sdl.c @@ -72,7 +72,7 @@ static struct sdl_info { static void sandbox_sdl_poll_events(void) { /* - * We don't want to include common.h in this file since it uses + * We don't want to include cpu_func.h in this file since it uses * system headers. So add a declation here. */ extern void reset_cpu(void); diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 16b766279833..9ad9da686c6a 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -3,7 +3,6 @@ * Copyright (c) 2016 Google, Inc */
-#include <common.h> #include <dm.h> #include <hang.h> #include <handoff.h> diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 2589c2eba738..dce804165296 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -3,7 +3,7 @@ * Copyright (c) 2011-2012 The Chromium OS Authors. */
-#include <common.h> +#include <config.h> #include <cli.h> #include <command.h> #include <efi_loader.h> diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index e38bb248b7ff..2462f990baae 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -3,7 +3,7 @@ * Copyright (c) 2011-2012 The Chromium OS Authors. */
-#include <common.h> +#include <config.h> #include <autoboot.h> #include <bloblist.h> #include <errno.h> diff --git a/arch/sandbox/include/asm/io.h b/arch/sandbox/include/asm/io.h index 31ab7289b4bd..1ccb25a0fe1e 100644 --- a/arch/sandbox/include/asm/io.h +++ b/arch/sandbox/include/asm/io.h @@ -6,6 +6,8 @@ #ifndef __SANDBOX_ASM_IO_H #define __SANDBOX_ASM_IO_H
+#include <linux/types.h> + enum sandboxio_size_t { SB_SIZE_8, SB_SIZE_16, diff --git a/arch/sandbox/include/asm/state.h b/arch/sandbox/include/asm/state.h index 59a20595f51d..c84a1f7060f4 100644 --- a/arch/sandbox/include/asm/state.h +++ b/arch/sandbox/include/asm/state.h @@ -6,7 +6,6 @@ #ifndef __SANDBOX_STATE_H #define __SANDBOX_STATE_H
-#include <config.h> #include <sysreset.h> #include <stdbool.h> #include <linux/list.h> diff --git a/arch/sandbox/lib/bootm.c b/arch/sandbox/lib/bootm.c index dc8b8e46cb41..270671145a0b 100644 --- a/arch/sandbox/lib/bootm.c +++ b/arch/sandbox/lib/bootm.c @@ -4,7 +4,6 @@ * Copyright (c) 2015 Sjoerd Simons sjoerd.simons@collabora.co.uk */
-#include <common.h> #include <bootstage.h> #include <image.h> #include <asm/io.h> diff --git a/arch/sandbox/lib/fdt_fixup.c b/arch/sandbox/lib/fdt_fixup.c index a646f2059c2c..e333bd52ea28 100644 --- a/arch/sandbox/lib/fdt_fixup.c +++ b/arch/sandbox/lib/fdt_fixup.c @@ -2,7 +2,6 @@
#define LOG_CATEGORY LOGC_ARCH
-#include <common.h> #include <fdt_support.h> #include <log.h>
diff --git a/arch/sandbox/lib/interrupts.c b/arch/sandbox/lib/interrupts.c index 4d7cbff802c6..3f6583e11f04 100644 --- a/arch/sandbox/lib/interrupts.c +++ b/arch/sandbox/lib/interrupts.c @@ -5,7 +5,6 @@ * found in the LICENSE file. */
-#include <common.h> #include <efi_loader.h> #include <irq_func.h> #include <os.h> diff --git a/arch/sandbox/lib/pci_io.c b/arch/sandbox/lib/pci_io.c index 2038141947ab..6040eacb594f 100644 --- a/arch/sandbox/lib/pci_io.c +++ b/arch/sandbox/lib/pci_io.c @@ -8,7 +8,6 @@ * IO space access commands. */
-#include <common.h> #include <command.h> #include <dm.h> #include <log.h> diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index 9d58860451c5..802596569c64 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -3,8 +3,8 @@ * Copyright (c) 2011 The Chromium OS Authors. */
-#include <common.h> #include <addr_map.h> +#include <config.h> #include <cpu_func.h> #include <cros_ec.h> #include <dm.h>
Hi Tom,
Is it possible to move CFG_SYS_SDRAM_BASE/SIZE to Kconfig?
For CFG_SYS_BAUDRATE_TABLE perhaps we could have a standard set that most boards use, or turn it into a set of word flags with a bit for each rate?
- Copyright 2020, Heinrich Schuchardt xypron.glpk@gmx.de
- Copyright (c) 2016 Google, Inc
- Copyright (c) 2011-2012 The Chromium OS Authors.
- Copyright (c) 2015 Sjoerd Simons sjoerd.simons@collabora.co.uk
- found in the LICENSE file.
- IO space access commands.
- Copyright (c) 2011 The Chromium OS Authors.
It seems strange to add config.h anywhere other than first. But I don't mind if that is what you intend.
#include <dm.h>
2.34.1
On Sat, Nov 18, 2023 at 10:09:55AM -0700, Simon Glass wrote:
Hi Tom,
Possible? Sure. But I think it would end up being fairly horrible. What would be nice I think is some Zephyr-style "convert CONFIG_DEFAULT_DEVICE_TREE to some defines" because we could parse out /memory to CFG_SYS_SDRAM_BASE/SIZE and that's something we _need_ at build time.
We do, largely, use a default table. I forget which further rework I posted as an RFC a few years ago, but I believe it was largely seen as being uglier than what we have today.
Hi Tom,
Hi Tom,
That would be pretty easy to do. But I would prefer to have it create CONFIG_SYS_SDRAM_BASE/SIZE so that it fits in with Kconfig, just that the value is set for you.
If you like you could create an issue for it.
I found these:
https://patchwork.ozlabs.org/project/uboot/list/?series=262148&state=* http://patchwork.ozlabs.org/project/uboot/patch/20210925121958.26001-1-pali@...
IMO the second one from Pali makes sense, but it was never followed up. It doesn't look too difficult.
We should have a policy that if people complain about a patch but don't follow up, we apply the patch we have.
I would like to drop configs/sandbox.h at some point and these two points are all that is left.
Splitting this in to two different threads..
On Sat, Nov 18, 2023 at 10:58:50AM -0700, Simon Glass wrote:
Hi Tom,
Hi Tom,
I _think_ we need it to be non-CONFIG namespace or we'll run in to other problems? We could get the new autogenerated header to be included along with generated/autoconf.h but since we couldn't use it within Kconfig logic it would be confusing.
Please, thanks.
Hi Tom,
Hi Tom,
Hi Tom,
Please, thanks.
https://source.denx.de/u-boot/u-boot/-/issues/27
[snip]
I found these:
I think the patch from Pali was the right direction, but as I noted, I wanted to see it implemented for some other UARTs as well, and it wasn't high on anyone elses priority list. Covering ns16550-style UARTs too would be good.
Hi Tom,
[snip]
I found these:
https://source.denx.de/u-boot/u-boot/-/issues/28
In order to make it easier to move on to dropping common.h from code directly, remove common.h inclusion from the rest of the header file which had been including it.
Signed-off-by: Tom Rini trini@konsulko.com --- board/BuR/common/br_resetc.h | 1 - board/CZ.NIC/turris_mox/mox_sp.h | 2 -- board/freescale/common/vsc3316_3308.h | 1 - board/ti/ks2_evm/mux-k2g.h | 1 - board/tq/tqma6/tqma6_bb.h | 2 -- board/xilinx/zynqmp/xil_io.h | 1 - disk/part_amiga.h | 1 - drivers/bios_emulator/include/x86emu.h | 1 - drivers/crypto/fsl/jobdesc.h | 1 - drivers/crypto/fsl/rsa_caam.h | 2 -- drivers/ddr/altera/sdram_soc64.h | 1 - drivers/ddr/marvell/a38x/ddr_ml_wrapper.h | 1 - drivers/net/fm/fm.h | 1 - drivers/net/fsl-mc/dpio/qbman_private.h | 1 - drivers/net/fsl-mc/dpio/qbman_sys.h | 1 + drivers/net/mscc_eswitch/mscc_mac_table.c | 1 + drivers/net/mscc_eswitch/mscc_mac_table.h | 2 -- drivers/net/mscc_eswitch/mscc_xfer.c | 1 + drivers/net/mscc_eswitch/mscc_xfer.h | 2 -- drivers/pci/pcie_layerscape_fixup_common.h | 2 -- drivers/pci_endpoint/pcie-cadence.h | 1 - drivers/pinctrl/mtmips/pinctrl-mtmips-common.h | 2 -- drivers/usb/gadget/bcm_udc_otg.h | 2 -- fs/btrfs/ctree.h | 1 - fs/yaffs2/ydirectenv.h | 1 - lib/libavb/avb_sysdeps.h | 4 +++- lib/zlib/zlib.h | 1 - net/arp.h | 2 -- net/link_local.h | 5 +---- net/net_rand.h | 1 - net/ping.h | 1 - 31 files changed, 7 insertions(+), 40 deletions(-)
diff --git a/board/BuR/common/br_resetc.h b/board/BuR/common/br_resetc.h index ba0689bf2050..999045b867d2 100644 --- a/board/BuR/common/br_resetc.h +++ b/board/BuR/common/br_resetc.h @@ -7,7 +7,6 @@ */ #ifndef __CONFIG_BRRESETC_H__ #define __CONFIG_BRRESETC_H__ -#include <common.h>
int br_resetc_regget(u8 reg, u8 *dst); int br_resetc_regset(u8 reg, u8 val); diff --git a/board/CZ.NIC/turris_mox/mox_sp.h b/board/CZ.NIC/turris_mox/mox_sp.h index 720880d5df32..c766c7423ac5 100644 --- a/board/CZ.NIC/turris_mox/mox_sp.h +++ b/board/CZ.NIC/turris_mox/mox_sp.h @@ -6,8 +6,6 @@ #ifndef _BOARD_CZNIC_TURRIS_MOX_MOX_SP_H_ #define _BOARD_CZNIC_TURRIS_MOX_MOX_SP_H_
-#include <common.h> - enum cznic_a3720_board { BOARD_UNDEFINED = 0x0, BOARD_TURRIS_MOX = 0x1, diff --git a/board/freescale/common/vsc3316_3308.h b/board/freescale/common/vsc3316_3308.h index 8d343ba4d654..9725d6d9e390 100644 --- a/board/freescale/common/vsc3316_3308.h +++ b/board/freescale/common/vsc3316_3308.h @@ -6,7 +6,6 @@ #ifndef __VSC_CROSSBAR_H_ #define __VSC_CROSSBAR_H_
-#include <common.h> #include <i2c.h> #include <errno.h>
diff --git a/board/ti/ks2_evm/mux-k2g.h b/board/ti/ks2_evm/mux-k2g.h index f24e62850b8b..447e70607f96 100644 --- a/board/ti/ks2_evm/mux-k2g.h +++ b/board/ti/ks2_evm/mux-k2g.h @@ -6,7 +6,6 @@ * Texas Instruments Incorporated, <www.ti.com> */
-#include <common.h> #include <hang.h> #include <asm/io.h> #include <asm/arch/mux-k2g.h> diff --git a/board/tq/tqma6/tqma6_bb.h b/board/tq/tqma6/tqma6_bb.h index ca81bdf58535..a2f871af1f83 100644 --- a/board/tq/tqma6/tqma6_bb.h +++ b/board/tq/tqma6/tqma6_bb.h @@ -7,8 +7,6 @@ #ifndef __TQMA6_BB__ #define __TQMA6_BB__
-#include <common.h> - int tqma6_bb_board_mmc_getwp(struct mmc *mmc); int tqma6_bb_board_mmc_getcd(struct mmc *mmc); int tqma6_bb_board_mmc_init(struct bd_info *bis); diff --git a/board/xilinx/zynqmp/xil_io.h b/board/xilinx/zynqmp/xil_io.h index e6caa7c85033..dd823d6f62a5 100644 --- a/board/xilinx/zynqmp/xil_io.h +++ b/board/xilinx/zynqmp/xil_io.h @@ -5,7 +5,6 @@
/* FIXME remove this when vivado is fixed */ #include <asm/io.h> -#include <common.h> #include <linux/delay.h>
#define xil_printf(...) diff --git a/disk/part_amiga.h b/disk/part_amiga.h index 42f5eb0f941c..dfa70bdb8a8c 100644 --- a/disk/part_amiga.h +++ b/disk/part_amiga.h @@ -7,7 +7,6 @@
#ifndef _DISK_PART_AMIGA_H #define _DISK_PART_AMIGA_H -#include <common.h>
#if CONFIG_IS_ENABLED(ISO_PARTITION) /* Make the buffers bigger if ISO partition support is enabled -- CD-ROMS diff --git a/drivers/bios_emulator/include/x86emu.h b/drivers/bios_emulator/include/x86emu.h index b28cdc6b8cad..d2650a8d1600 100644 --- a/drivers/bios_emulator/include/x86emu.h +++ b/drivers/bios_emulator/include/x86emu.h @@ -42,7 +42,6 @@ #define __X86EMU_X86EMU_H
#include <asm/types.h> -#include <common.h> #include <pci.h> #include <asm/io.h> #define X86API diff --git a/drivers/crypto/fsl/jobdesc.h b/drivers/crypto/fsl/jobdesc.h index c4501abd26b2..69adfdca95b5 100644 --- a/drivers/crypto/fsl/jobdesc.h +++ b/drivers/crypto/fsl/jobdesc.h @@ -7,7 +7,6 @@ #ifndef __JOBDESC_H #define __JOBDESC_H
-#include <common.h> #include <asm/io.h> #include "rsa_caam.h"
diff --git a/drivers/crypto/fsl/rsa_caam.h b/drivers/crypto/fsl/rsa_caam.h index 9a6a8afa4aa7..fb132a3d1814 100644 --- a/drivers/crypto/fsl/rsa_caam.h +++ b/drivers/crypto/fsl/rsa_caam.h @@ -6,8 +6,6 @@ #ifndef __RSA_CAAM_H #define __RSA_CAAM_H
-#include <common.h> - /** * struct pk_in_params - holder for input to PKHA block in CAAM * These parameters are required to perform Modular Exponentiation diff --git a/drivers/ddr/altera/sdram_soc64.h b/drivers/ddr/altera/sdram_soc64.h index 07a0f9f2ae9b..87a70a861baa 100644 --- a/drivers/ddr/altera/sdram_soc64.h +++ b/drivers/ddr/altera/sdram_soc64.h @@ -6,7 +6,6 @@ #ifndef _SDRAM_SOC64_H_ #define _SDRAM_SOC64_H_
-#include <common.h> #include <linux/sizes.h>
struct altera_sdram_priv { diff --git a/drivers/ddr/marvell/a38x/ddr_ml_wrapper.h b/drivers/ddr/marvell/a38x/ddr_ml_wrapper.h index 735731196589..dff56338b19e 100644 --- a/drivers/ddr/marvell/a38x/ddr_ml_wrapper.h +++ b/drivers/ddr/marvell/a38x/ddr_ml_wrapper.h @@ -6,7 +6,6 @@ #ifndef _DDR_ML_WRAPPER_H #define _DDR_ML_WRAPPER_H
-#include <common.h> #include <i2c.h> #include <spl.h> #include <asm/io.h> diff --git a/drivers/net/fm/fm.h b/drivers/net/fm/fm.h index a2d5b03429ab..5c45ad56d0a5 100644 --- a/drivers/net/fm/fm.h +++ b/drivers/net/fm/fm.h @@ -6,7 +6,6 @@ #ifndef __FM_H__ #define __FM_H__
-#include <common.h> #include <phy.h> #include <fm_eth.h> #include <fsl_fman.h> diff --git a/drivers/net/fsl-mc/dpio/qbman_private.h b/drivers/net/fsl-mc/dpio/qbman_private.h index 53f1300eaf80..f9dad178075f 100644 --- a/drivers/net/fsl-mc/dpio/qbman_private.h +++ b/drivers/net/fsl-mc/dpio/qbman_private.h @@ -4,7 +4,6 @@ */
/* Perform extra checking */ -#include <common.h> #include <errno.h> #include <asm/io.h> #include <linux/bug.h> diff --git a/drivers/net/fsl-mc/dpio/qbman_sys.h b/drivers/net/fsl-mc/dpio/qbman_sys.h index 1c6e48913028..cac70a1291c7 100644 --- a/drivers/net/fsl-mc/dpio/qbman_sys.h +++ b/drivers/net/fsl-mc/dpio/qbman_sys.h @@ -20,6 +20,7 @@
/* Trace the 3 different classes of read/write access to QBMan. #undef as * required. */ +#include <config.h> #include <linux/bug.h> #include <linux/printk.h> #undef QBMAN_CCSR_TRACE diff --git a/drivers/net/mscc_eswitch/mscc_mac_table.c b/drivers/net/mscc_eswitch/mscc_mac_table.c index 25b9cad42c97..06e1f625fb74 100644 --- a/drivers/net/mscc_eswitch/mscc_mac_table.c +++ b/drivers/net/mscc_eswitch/mscc_mac_table.c @@ -3,6 +3,7 @@ * Copyright (c) 2018 Microsemi Corporation */
+#include <errno.h> #include <linux/bitops.h> #include <linux/io.h> #include "mscc_mac_table.h" diff --git a/drivers/net/mscc_eswitch/mscc_mac_table.h b/drivers/net/mscc_eswitch/mscc_mac_table.h index 17fed2e79253..5ec8db25417d 100644 --- a/drivers/net/mscc_eswitch/mscc_mac_table.h +++ b/drivers/net/mscc_eswitch/mscc_mac_table.h @@ -3,8 +3,6 @@ * Copyright (c) 2018 Microsemi Corporation */
-#include <common.h> - #define ETH_LEN 6 #define MAC_VID 1
diff --git a/drivers/net/mscc_eswitch/mscc_xfer.c b/drivers/net/mscc_eswitch/mscc_xfer.c index 6f7474645717..ee6bf065d3a8 100644 --- a/drivers/net/mscc_eswitch/mscc_xfer.c +++ b/drivers/net/mscc_eswitch/mscc_xfer.c @@ -3,6 +3,7 @@ * Copyright (c) 2018 Microsemi Corporation */
+#include <errno.h> #include <log.h> #include <linux/bitops.h> #include <linux/delay.h> diff --git a/drivers/net/mscc_eswitch/mscc_xfer.h b/drivers/net/mscc_eswitch/mscc_xfer.h index c880a4e7e6a6..70f279401e19 100644 --- a/drivers/net/mscc_eswitch/mscc_xfer.h +++ b/drivers/net/mscc_eswitch/mscc_xfer.h @@ -3,8 +3,6 @@ * Copyright (c) 2018 Microsemi Corporation */
-#include <common.h> - enum mscc_regs_qs { MSCC_QS_XTR_RD, MSCC_QS_XTR_FLUSH, diff --git a/drivers/pci/pcie_layerscape_fixup_common.h b/drivers/pci/pcie_layerscape_fixup_common.h index 70bd3f0cba31..3255b7648c0a 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.h +++ b/drivers/pci/pcie_layerscape_fixup_common.h @@ -9,8 +9,6 @@ #ifndef _PCIE_LAYERSCAPE_FIXUP_COMMON_H_ #define _PCIE_LAYERSCAPE_FIXUP_COMMON_H_
-#include <common.h> - void ft_pci_setup_ls(void *blob, struct bd_info *bd);
#ifdef CONFIG_PCIE_LAYERSCAPE_GEN4 diff --git a/drivers/pci_endpoint/pcie-cadence.h b/drivers/pci_endpoint/pcie-cadence.h index 8a659c36aa24..dd0101a33af9 100644 --- a/drivers/pci_endpoint/pcie-cadence.h +++ b/drivers/pci_endpoint/pcie-cadence.h @@ -11,7 +11,6 @@ #ifndef PCIE_CADENCE_H #define PCIE_CADENCE_H
-#include <common.h> #include <pci_ep.h> #include <asm/io.h> #include <linux/bitops.h> diff --git a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h index 1f1023ef4213..7a38f8d87532 100644 --- a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h +++ b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h @@ -8,8 +8,6 @@ #ifndef _PINCTRL_MTMIPS_COMMON_H_ #define _PINCTRL_MTMIPS_COMMON_H_
-#include <common.h> - struct mtmips_pmx_func { const char *name; int value; diff --git a/drivers/usb/gadget/bcm_udc_otg.h b/drivers/usb/gadget/bcm_udc_otg.h index 24cc936c6b48..48370f37d8a2 100644 --- a/drivers/usb/gadget/bcm_udc_otg.h +++ b/drivers/usb/gadget/bcm_udc_otg.h @@ -6,8 +6,6 @@ #ifndef __BCM_UDC_OTG_H #define __BCM_UDC_OTG_H
-#include <common.h> - static inline void wfld_set(uintptr_t addr, uint32_t fld_val, uint32_t fld_mask) { writel(((readl(addr) & ~(fld_mask)) | (fld_val)), (addr)); diff --git a/fs/btrfs/ctree.h b/fs/btrfs/ctree.h index ffd095ffdd2e..59439552a45c 100644 --- a/fs/btrfs/ctree.h +++ b/fs/btrfs/ctree.h @@ -9,7 +9,6 @@ #ifndef __BTRFS_CTREE_H__ #define __BTRFS_CTREE_H__
-#include <common.h> #include <compiler.h> #include <linux/rbtree.h> #include <linux/bug.h> diff --git a/fs/yaffs2/ydirectenv.h b/fs/yaffs2/ydirectenv.h index d274f22e84d0..790f8512f742 100644 --- a/fs/yaffs2/ydirectenv.h +++ b/fs/yaffs2/ydirectenv.h @@ -20,7 +20,6 @@ #ifndef __YDIRECTENV_H__ #define __YDIRECTENV_H__
-#include <common.h> #include <malloc.h> #include <linux/compat.h>
diff --git a/lib/libavb/avb_sysdeps.h b/lib/libavb/avb_sysdeps.h index f52428cc622f..aece8e0a0180 100644 --- a/lib/libavb/avb_sysdeps.h +++ b/lib/libavb/avb_sysdeps.h @@ -19,7 +19,9 @@ extern "C" { * like uint8_t, uint64_t, and bool (with |false|, |true| keywords) * must be present. */ -#include <common.h> +#include <stdio.h> +#include <stdbool.h> +#include <linux/types.h>
/* If you don't have gcc or clang, these attribute macros may need to * be adjusted. diff --git a/lib/zlib/zlib.h b/lib/zlib/zlib.h index af3703e6d770..560e7be97d3a 100644 --- a/lib/zlib/zlib.h +++ b/lib/zlib/zlib.h @@ -2,7 +2,6 @@ #ifndef __GLUE_ZLIB_H__ #define __GLUE_ZLIB_H__
-#include <common.h> #include <linux/compiler.h> #include <asm/unaligned.h> #include <watchdog.h> diff --git a/net/arp.h b/net/arp.h index 25b3c00d5c56..c50885fb9a57 100644 --- a/net/arp.h +++ b/net/arp.h @@ -12,8 +12,6 @@ #ifndef __ARP_H__ #define __ARP_H__
-#include <common.h> - extern struct in_addr net_arp_wait_packet_ip; /* MAC address of waiting packet's destination */ extern uchar *arp_wait_packet_ethaddr; diff --git a/net/link_local.h b/net/link_local.h index bb998164df9b..d8701255142f 100644 --- a/net/link_local.h +++ b/net/link_local.h @@ -10,15 +10,12 @@ * Licensed under the GPL v2 or later */
-#if defined(CONFIG_CMD_LINK_LOCAL) - #ifndef __LINK_LOCAL_H__ #define __LINK_LOCAL_H__
-#include <common.h> +struct arp_hdr;
void link_local_receive_arp(struct arp_hdr *arp, int len); void link_local_start(void);
#endif /* __LINK_LOCAL_H__ */ -#endif diff --git a/net/net_rand.h b/net/net_rand.h index 6a52cda85e03..d3c5559adfd4 100644 --- a/net/net_rand.h +++ b/net/net_rand.h @@ -9,7 +9,6 @@ #ifndef __NET_RAND_H__ #define __NET_RAND_H__
-#include <common.h> #include <dm/uclass.h> #include <rng.h>
diff --git a/net/ping.h b/net/ping.h index 7b6f4e566dbd..76ac225fc075 100644 --- a/net/ping.h +++ b/net/ping.h @@ -12,7 +12,6 @@ #ifndef __PING_H__ #define __PING_H__
-#include <common.h> #include <net.h>
