[U-Boot] Auto-booting problem
Hi all, I am working on MPC8313erdb board. I configure U-Boot 1.3.0 for my board, But the problem is on auto-boot. When I start the board it stop on command prompt of u-boot. Please help me to solve this problem. The list of environment variables are given below.
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ U-Boot 1.3.0 (May 15 2009 - 11:35:09) MPC83XX
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c3, MPC8313E, Rev: 10 at 333.333 MHz, CSB: 166 MHz Board: Freescale MPC8313ERDB I2C: ready DRAM: 128 MB FLASH: 8 MB NAND: 32 MiB In: serial Out: serial Err: serial Net: TSEC0, TSEC1 [PRIME] => printenv ramboot=setenv rootdev /dev/ram;run setbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr nfsboot=setenv rootdev /dev/nfs;run setbootargs;run setipargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr baudrate=115200 loads_echo=1 ethaddr=00:E0:0C:00:95:01 eth1addr=00:E0:0C:00:95:02 rootpath=/nfs/root/path hostname=mpc8313erdb bootfile=uImage loadaddr=200000 netdev=eth1 ethprime=TSEC1 uboot=u-boot.bin tftpflash=tftpboot $loadaddr $uboot; protect off 0xFE000000 +$filesize; erase 0xFE000000 +$filesize; cp.b $loadaddr 0xFE000000 $filesize; protect on 0xFE000000 +$filesize; cmp.b $e fdtaddr=400000 fdtfile=mpc8313erdb.dtb console=ttyS0 setbootargs=setenv bootargs root=$rootdev rw console=$console,$baudrate $othbootargs setipargs=setenv bootargs nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off root=$rootdev rw console=$console,$baudrate $othbootargs filesize=490000 fileaddr=100000 gatewayip=10.0.0.1 netmask=255.0.0.0 bootargs=root=/dev/mtdblock6 rootfstype=jffs2 rw console=ttyS0,115200 bootcmd=cp.b fe710000 40000 11000; go 40004; bootm fe100000 - fe700000 stdin=serial stdout=serial stderr=serial ethact=TSEC1
Environment size: 1334/8188 bytes =>
Thank in advance.
Dear paras,
In message 8136f0210905220236o93ab0a0gbf8ff5e15192ea21@mail.gmail.com you wrote:
U-Boot 1.3.0 is very old. Why don't you use current code?
That's normal given your setup. Try setting "bootdelay".
Thank you Sir for your response. As per your instruction I set "bootdelay" variable. log is given below, But the problem is not solve. I run command "run bootcmd" for booting the kernel.
------------------------------------------ LOG ------------------------------------------------------------- ramboot=setenv rootdev /dev/ram;run setbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr nfsboot=setenv rootdev /dev/nfs;run setbootargs;run setipargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr baudrate=115200 loads_echo=1 ethaddr=00:E0:0C:00:95:01 eth1addr=00:E0:0C:00:95:02 rootpath=/nfs/root/path hostname=mpc8313erdb bootfile=uImage loadaddr=200000 netdev=eth1 ethprime=TSEC1 uboot=u-boot.bin tftpflash=tftpboot $loadaddr $uboot; protect off 0xFE000000 +$filesize; erase 0xFE000000 +$filesize; cp.b $loadaddr 0xFE000000 $filesize; protect on 0xFE000000 +$filesize; cmp.b $e fdtaddr=400000 fdtfile=mpc8313erdb.dtb console=ttyS0 setbootargs=setenv bootargs root=$rootdev rw console=$console,$baudrate $othbootargs setipargs=setenv bootargs nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off root=$rootdev rw console=$console,$baudrate $othbootargs filesize=490000 fileaddr=100000 netmask=255.0.0.0 bootargs=root=/dev/mtdblock6 rootfstype=jffs2 rw console=ttyS0,115200 bootcmd=cp.b fe710000 40000 11000; go 40004; bootm fe100000 - fe700000 *bootdelay=3* stdin=serial stdout=serial stderr=serial ethact=TSEC1 --------------------------------------------------------------------------------------------------------------------------------------------------
Thanks In Advance.
On Fri, May 22, 2009 at 4:22 PM, Wolfgang Denk wd@denx.de wrote:
Dear paras,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Do we define evil as the absence of goodness? It seems only logical that shit happens--we discover this by the process of elimination." -- Larry Wall
Yes, then you need to set/use CONFIG_BOOTDELAY to enable or disable for autoboot. For details and information have a look at doc/README.autoboot
Once you use CONFIG_BOOTDELAY, then recompile and generate u-boot.bin, if everything goes fine you would have bootdelay option in you printenv settings.
Kind Regards, Vijay Nikam
Thanks In Advance.
Dear paras,
Note that this has been added to the 8313erdb config file in more recent versions of u-boot.
-Scott
paras
Scott Wood
Vijay Nikam
