[U-Boot] [PATCH 0/3] test: Extending USB gadget tests infrastructure
New test for UMS regressions catching has been added. Moreover some DFU enhancements have been included as well.
Lukasz Majewski (3): test: dfu: Extend dfu_gadget_test_init.sh to accept sizes of test files test: dfu: cosmetic: Add missing license information to DFU test scripts test: ums: Add script for testing UMS gadget operation
test/dfu/dfu_gadget_test.sh | 10 +++ test/dfu/dfu_gadget_test_init.sh | 16 ++++- test/ums/README | 17 +++++ test/ums/ums_gadget_test.sh | 130 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 172 insertions(+), 1 deletion(-) create mode 100644 test/ums/README create mode 100755 test/ums/ums_gadget_test.sh
It is now possible to pass to the dfu_gadget_test_init.sh script the sizes of files to be generated.
This feature is required by UMS tests which reuse this code.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com --- test/dfu/dfu_gadget_test_init.sh | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/test/dfu/dfu_gadget_test_init.sh b/test/dfu/dfu_gadget_test_init.sh index 2163a68..0d5c6c0 100755 --- a/test/dfu/dfu_gadget_test_init.sh +++ b/test/dfu/dfu_gadget_test_init.sh @@ -9,7 +9,11 @@ COLOUR_DEFAULT="\33[0m"
LOG_DIR="./log"
-TEST_FILES_SIZES="63 64 65 127 128 129 4095 4096 4097 959 960 961 1048575 1048576 8M" +if [ $# -eq 0 ]; then + TEST_FILES_SIZES="63 64 65 127 128 129 4095 4096 4097 959 960 961 1048575 1048576 8M" +else + TEST_FILES_SIZES=$@ +fi
printf "Init script for generating data necessary for DFU test script"
By mistake I've forgotten to add the SPDX license tags for the DFU testing scripts. This commit fixes that and also provides some other relevant information.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com --- test/dfu/dfu_gadget_test.sh | 10 ++++++++++ test/dfu/dfu_gadget_test_init.sh | 10 ++++++++++ 2 files changed, 20 insertions(+)
diff --git a/test/dfu/dfu_gadget_test.sh b/test/dfu/dfu_gadget_test.sh index 4133155..2f5b7db 100755 --- a/test/dfu/dfu_gadget_test.sh +++ b/test/dfu/dfu_gadget_test.sh @@ -1,5 +1,15 @@ #! /bin/bash
+# Copyright (C) 2014 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# Script fixes, enhancements and testing: +# Stephen Warren swarren@nvidia.com +# +# DFU operation test script +# +# SPDX-License-Identifier: GPL-2.0+ + set -e # any command return if not equal to zero clear
diff --git a/test/dfu/dfu_gadget_test_init.sh b/test/dfu/dfu_gadget_test_init.sh index 0d5c6c0..640628e 100755 --- a/test/dfu/dfu_gadget_test_init.sh +++ b/test/dfu/dfu_gadget_test_init.sh @@ -1,5 +1,15 @@ #! /bin/bash
+# Copyright (C) 2014 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# Script fixes, enhancements and testing: +# Stephen Warren swarren@nvidia.com +# +# Script for test files generation +# +# SPDX-License-Identifier: GPL-2.0+ + set -e # any command return if not equal to zero clear
This commit adds new test for UMS USB gadget to u-boot mainline tree. It it similar in operation to the one already available in test/dfu directory.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com --- test/ums/README | 17 ++++++ test/ums/ums_gadget_test.sh | 130 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 147 insertions(+) create mode 100644 test/ums/README create mode 100755 test/ums/ums_gadget_test.sh
diff --git a/test/ums/README b/test/ums/README new file mode 100644 index 0000000..cb7b27d --- /dev/null +++ b/test/ums/README @@ -0,0 +1,17 @@ +UMS test script. + +Example usage: +1. On the target: + create UMS exportable partition with a proper file system created on + it (e.g. EXT4, FAT). + ums 0 mmc 0 +2. On the host: + sudo test/ums/ums_gadget_test.sh X Y dir [test_file] + e.g. sudo test/ums/ums_gadget_test.sh 1 vfat /mnt ./dat_14M.img + +... where X is the partition number on which UMS operates and the Y is +the file system. The 'dir' parameter is the mount directory on the HOST. +Information about available partitions one can read from target via the +'mmc part' command. +The optional [test_file] parameter is for specifying the exact test file +to use. \ No newline at end of file diff --git a/test/ums/ums_gadget_test.sh b/test/ums/ums_gadget_test.sh new file mode 100755 index 0000000..a304c1c --- /dev/null +++ b/test/ums/ums_gadget_test.sh @@ -0,0 +1,130 @@ +#! /bin/bash + +# Copyright (C) 2014 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# UMS operation test script +# +# SPDX-License-Identifier: GPL-2.0+ + +set -e # any command return not equal to zero +clear + +COLOUR_RED="\33[31m" +COLOUR_GREEN="\33[32m" +COLOUR_DEFAULT="\33[0m" + +DIR=./ +SUFFIX=img +RCV_DIR=rcv/ +LOG_FILE=./log/log-`date +%d-%m-%Y_%H-%M-%S` + +cd `dirname $0` +../dfu/dfu_gadget_test_init.sh 33M 97M + +cleanup () { + rm -rf $RCV_DIR +} + +die () { + printf " $COLOUR_RED FAILED $COLOUR_DEFAULT \n" + cleanup + exit 1 +} + +calculate_md5sum () { + MD5SUM=`md5sum $1` + MD5SUM=`echo $MD5SUM | cut -d ' ' -f1` + echo "md5sum:"$MD5SUM +} + +ums_test_file () { + printf "$COLOUR_GREEN========================================================================================= $COLOUR_DEFAULT\n" + printf "File:$COLOUR_GREEN %s $COLOUR_DEFAULT\n" $1 + + mount -t $2 /dev/$MEM_DEV $MNT_DIR + if [ -f $MNT_DIR/dat_* ]; then + rm $MNT_DIR/dat_* + fi + sync + + cp ./$1 $MNT_DIR + sync + umount $MNT_DIR + + + echo -n "TX: " + calculate_md5sum $1 + + MD5_TX=$MD5SUM + sleep 1 + N_FILE=$DIR$RCV_DIR${1:2}"_rcv" + + mount -t $2 /dev/$MEM_DEV $MNT_DIR + cp $MNT_DIR/$1 $N_FILE || die $? + sync + rm $MNT_DIR/$1 + sync + umount $MNT_DIR + + echo -n "RX: " + calculate_md5sum $N_FILE + MD5_RX=$MD5SUM + + if [ "$MD5_TX" == "$MD5_RX" ]; then + printf " $COLOUR_GREEN -------> OK $COLOUR_DEFAULT \n" + else + printf " $COLOUR_RED -------> FAILED $COLOUR_DEFAULT \n" + cleanup + exit 1 + fi +} + +printf "$COLOUR_GREEN========================================================================================= $COLOUR_DEFAULT\n" +echo "U-boot UMS test program" + +if [ $EUID -ne 0 ]; then + echo "You must be root to do this." 1>&2 + exit 100 +fi + +if [ $# -lt 3 ]; then + echo "Wrong number of arguments" + echo "Example:" + echo "sudo ./ums_gadget_test.sh 1 vfat /mnt [test_file]" + die +fi + +MNT_DIR=$3 + +mkdir -p $RCV_DIR + +MEM_DEV=`dmesg | tail -n 10 | grep -E " sd[a-z]:" - | cut -d ':' -f 1` +MEM_DEV=$(echo $MEM_DEV | cut -d ']' -f2 | tr -d ' ') + +if [ -z $MEM_DEV ]; then + echo "Connect target" + echo "e.g. ums 0 mmc 0" + die +fi + +MEM_DEV=$MEM_DEV$1 + +printf "Mount: /dev/$MEM_DEV FS: %s\n" $2 + +if [ -n "$4" ]; then + if [ ! -e $4 ]; then + echo "No file: $4" + die + fi + ums_test_file $4 $2 +else + for file in $DIR*.$SUFFIX + do + ums_test_file $file $2 + done +fi + +cleanup + +exit 0 \ No newline at end of file
Patches 1 and 2, Acked-by: Stephen Warren swarren@nvidia.com
For this patch, I wonder whether:
a) Should it do some raw dd tests too, for partitions/devices without a filesystem? Perhaps we should have separate scripts (for each of DFU and UMS) for filesystem and raw testing. So, this could be addressed later.
b) Should this script (optionally?) create the filesystem itself, so the test is completely self-contained. Otherwise, the user has to manually run e.g. parted and mk*fs themselves, by which time they've already tested UMS a fair bit without this script.
c) Do we really need the "Y" parameters (filesystem type) to the script? "mount" will automatically try all known filesystem types on my Linux host at least, and it would make it simpler to run the script if you simply dropped the "-t" option to "mount".
- create UMS exportable partition with a proper file system created on
- it (e.g. EXT4, FAT).
- ums 0 mmc 0
+2. On the host:
- sudo test/ums/ums_gadget_test.sh X Y dir [test_file]
- e.g. sudo test/ums/ums_gadget_test.sh 1 vfat /mnt ./dat_14M.img
can you s/X/PARTNUM/ s/Y/fstype/ here. That'd make the example command a bit more explanatory even without the paragraph below that explains what X and Y are, and also make it easier to correlate the description with the command.
Perhaps this should say: 'mmc part' or 'part list' commands.
That's probably not right.
I'm just curious what's special about those two sizes.
+ums_test_file () {
- mount -t $2 /dev/$MEM_DEV $MNT_DIR
- if [ -f $MNT_DIR/dat_* ]; then
- rm $MNT_DIR/dat_*
- fi
- sync
- cp ./$1 $MNT_DIR
- sync
- umount $MNT_DIR
I'm not sure any of those "sync"s are necessary; "mount" should sync as part of its own operation.
- MD5_TX=$MD5SUM
- sleep 1
Why do we need to sleep?
- echo "Wrong number of arguments"
- echo "Example:"
- echo "sudo ./ums_gadget_test.sh 1 vfat /mnt [test_file]"
- die
+fi
+MNT_DIR=$3
I think here, we should assign all positional arguments to named variables rather than using $1/... later on; something like:
PART_NUM=$1; shift FSTYPE=$1; shift MNT_DIR=$1; shift TEST_FILES=$@
For MNT_DIR, can we simply create a temporary directory (e.g. /mnt/tmp-ums-test-$$) so the user doesn't have to pass in the name? The script requires root after all.
May as well use `` or $() consistently for those two lines.
This seems slightly dangerous; what if my system has been plugged in for a long time and I've plugged in some other USB storage device since. Better to take the device name on the command-line, or perhaps to take the USB VID/PID on the command-line, then scan sysfs for a USB device with matching VID/PID, and find out what device node is hosted by it.
Probably should fix that too.
Can you add a trap handler so that if the user CTRL-C's the script, the disk is unmounted, the mount directory is removed (if you make the script create one internally), and any temporary files are deleted. Right now, cleanup only runs if the script successfully runs to the end.
Hi Stephen,
I think that we should prepare separate scripts. One script per tested functionality.
The test should be extended to accept an additional flat - e.g. --create_fs. As you pointed out, this could save some time.
I agree. The Y parameter will be removed and we will allow mount to do the job.
created on
- ums 0 mmc 0
+2. On the host:
Ok, I will do that.
Ok.
Ok.
Nothing special. I just wanted to have sufficiently large files to test UMS capabilities (since I assume, that DFU will not transfer so large files very often).
With UMS it is not so important to test the corner cases values (as we did with DFU tests), but to check how well transfers of large files is performed.
+ums_test_file () {
- rm $MNT_DIR/dat_*
- fi
- sync
- cp ./$1 $MNT_DIR
- sync
- umount $MNT_DIR
Yes, I agree. mount/umount do the sync as well. I will fix this.
- MD5_TX=$MD5SUM
- sleep 1
On my linux box there were some problems without this delay (probably caused by time needed for plugging in USB device).
Maybe on your setup it will work smoothly.
- echo "Example:"
- die
+fi
+MNT_DIR=$3
Ok.
Ok.
According to the reply written below, we will not need this code.
Your proposition is more reliable. I think that the idProduct/idVendor shall be passed to the script.
Ok.
Good idea. I will add this to v2.
test/dfu/dfu_gadget_test.sh | 10 +++ test/dfu/dfu_gadget_test_init.sh | 16 +++- test/ums/README | 26 ++++++ test/ums/ums_gadget_test.sh | 169 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 220 insertions(+), 1 deletion(-) create mode 100644 test/ums/README create mode 100755 test/ums/ums_gadget_test.sh
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Stephen Warren swarren@nvidia.com --- Changes for v2: - None --- test/dfu/dfu_gadget_test_init.sh | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
LOG_DIR="./log"
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Stephen Warren swarren@nvidia.com --- Changes for v2: - None --- test/dfu/dfu_gadget_test.sh | 10 ++++++++++ test/dfu/dfu_gadget_test_init.sh | 10 ++++++++++ 2 files changed, 20 insertions(+)
This commit adds new test for UMS USB gadget to u-boot mainline tree. It is similar in operation to the one already available in test/dfu directory.
--- Changes for v2: - Add -f switch for optional FS creation on target UMS partition - Remove need for passing FS type to script - Remove syncs - Use named variables instead of $1, $2, $3 ... etc - Create temporary mount directory at /mnt/tmp-ums-test/ - Use target device's VID/PID to find exact mount device (/dev/sdX) - Add support for Ctrl+C tap - Rewrite README entry --- test/ums/README | 26 +++++++ test/ums/ums_gadget_test.sh | 169 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 195 insertions(+) create mode 100644 test/ums/README create mode 100755 test/ums/ums_gadget_test.sh
diff --git a/test/ums/README b/test/ums/README new file mode 100644 index 0000000..84906be --- /dev/null +++ b/test/ums/README @@ -0,0 +1,26 @@ +UMS test script. + +ums_gadget_test.sh +================== + +Example usage: +1. On the target: + create UMS exportable partitions (with e.g. gpt write) + ums 0 mmc 0 +2. On the host: + sudo test/ums/ums_gadget_test.sh VID PID PART_NUM [-f FILE_SYSTEM] [test_file] + e.g. sudo test/ums/ums_gadget_test.sh 04e8 6601 6 -f vfat ./dat_14M.img + +... where: + VID - UMS device USB Vendor ID + PID - UMS device USB Product ID + PART_NUM - is the partition number on which UMS operates + +Information about available partitions on the target one can read with using +the 'mmc part' or 'part list' commands. + +The [-f FILE_SYSTEM] optional switch allows for formatting target partition to +FILE_SYSTEM. + +The last, optional [test_file] parameter is for specifying the exact test file +to use. diff --git a/test/ums/ums_gadget_test.sh b/test/ums/ums_gadget_test.sh new file mode 100755 index 0000000..2cfa208 --- /dev/null +++ b/test/ums/ums_gadget_test.sh @@ -0,0 +1,169 @@ +#! /bin/bash + +# Copyright (C) 2014 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# UMS operation test script +# +# SPDX-License-Identifier: GPL-2.0+ + +clear + +COLOUR_RED="\33[31m" +COLOUR_GREEN="\33[32m" +COLOUR_DEFAULT="\33[0m" + +DIR=./ +SUFFIX=img +RCV_DIR=rcv/ +LOG_FILE=./log/log-`date +%d-%m-%Y_%H-%M-%S` + +cd `dirname $0` +../dfu/dfu_gadget_test_init.sh 33M 97M + +cleanup () { + rm -rf $RCV_DIR $MNT_DIR +} + +control_c() +# run if user hits control-c +{ + echo -en "\n*** CTRL+C ***\n" + umount $MNT_DIR + cleanup + exit 0 +} + +# trap keyboard interrupt (control-c) +trap control_c SIGINT + +die () { + printf " $COLOUR_RED FAILED $COLOUR_DEFAULT \n" + cleanup + exit 1 +} + +calculate_md5sum () { + MD5SUM=`md5sum $1` + MD5SUM=`echo $MD5SUM | cut -d ' ' -f1` + echo "md5sum:"$MD5SUM +} + +ums_test_file () { + printf "$COLOUR_GREEN========================================================================================= $COLOUR_DEFAULT\n" + printf "File:$COLOUR_GREEN %s $COLOUR_DEFAULT\n" $1 + + mount /dev/$MEM_DEV $MNT_DIR + if [ -f $MNT_DIR/dat_* ]; then + rm $MNT_DIR/dat_* + fi + + cp ./$1 $MNT_DIR + umount $MNT_DIR + + + echo -n "TX: " + calculate_md5sum $1 + + MD5_TX=$MD5SUM + sleep 1 + N_FILE=$DIR$RCV_DIR${1:2}"_rcv" + + mount /dev/$MEM_DEV $MNT_DIR + cp $MNT_DIR/$1 $N_FILE || die $? + rm $MNT_DIR/$1 + umount $MNT_DIR + + echo -n "RX: " + calculate_md5sum $N_FILE + MD5_RX=$MD5SUM + + if [ "$MD5_TX" == "$MD5_RX" ]; then + printf " $COLOUR_GREEN -------> OK $COLOUR_DEFAULT \n" + else + printf " $COLOUR_RED -------> FAILED $COLOUR_DEFAULT \n" + cleanup + exit 1 + fi +} + +printf "$COLOUR_GREEN========================================================================================= $COLOUR_DEFAULT\n" +echo "U-boot UMS test program" + +if [ $EUID -ne 0 ]; then + echo "You must be root to do this." 1>&2 + exit 100 +fi + +if [ $# -lt 3 ]; then + echo "Wrong number of arguments" + echo "Example:" + echo "sudo ./ums_gadget_test.sh VID PID PART_NUM [-f ext4] [test_file]" + die +fi + +MNT_DIR="/mnt/tmp-ums-test" + +VID=$1; shift +PID=$1; shift +PART_NUM=$1; shift + +if [ "$1" == "-f" ]; then + shift + FS_TO_FORMAT=$1; shift +fi + +TEST_FILE=$1 + +idVendor=`find /sys -type f -name "idVendor" -exec grep -w $VID {} ;` +idProduct=`find /sys -type f -name "idProduct" -exec grep -w $PID {} ;` +if [ -z "$idVendor" ] || [ -z "$idProduct" ]; then + echo "Device $VID:$PID not connected!" + exit 0 +fi + +USB_DEV=`find /sys -type f -name "idProduct" -exec grep -l $PID {} ;` +USB_DEV=`dirname $USB_DEV` + +MEM_DEV=`find $USB_DEV -name "sd[a-z]" | awk -F/ '{print $(NF)}' -` +if [ -z $MEM_DEV ]; then + echo "Connect target" + echo "e.g. ums 0 mmc 0" + die +fi + +mkdir -p $RCV_DIR +if [ ! -d $MNT_DIR ]; then + mkdir -p $MNT_DIR +fi + +MEM_DEV=$MEM_DEV$PART_NUM + +if [ -n "$FS_TO_FORMAT" ]; then + echo -n "Formatting partition /dev/$MEM_DEV to $FS_TO_FORMAT" + mkfs -t $FS_TO_FORMAT /dev/$MEM_DEV > /dev/null 2>&1 + if [ $? -eq 0 ]; then + printf " $COLOUR_GREEN DONE $COLOUR_DEFAULT \n" + else + die + fi +fi + +printf "Mount: /dev/$MEM_DEV \n" + +if [ -n "$TEST_FILE" ]; then + if [ ! -e $TEST_FILE ]; then + echo "No file: $TEST_FILE" + die + fi + ums_test_file $TEST_FILE +else + for file in $DIR*.$SUFFIX + do + ums_test_file $file + done +fi + +cleanup + +exit 0
This looks good, although I have a few small comments...
- create UMS exportable partitions (with e.g. gpt write)
I'd like to avoid that requirement. Perhaps the script can operate on raw devices without a partition table too. Can we enhance the script so that if the user specifies - as the partition ID, then $PART_NUM gets set to '' and hence the whole device is used?
If you do that, I'd like to add the following to the line I quoted above:
, or specify a partition ID of - to use the entire device.
You might want to insert an extra step in the documentation here:
Create a filesystem on the partition or device, or pass the -f option to the test script.
- echo "Device $VID:$PID not connected!"
- exit 0
+fi
That ensures that the given VID/PID exist somewhere, but not necessarily even on the same USB device.
... and that simply finds a USB device with a matching PID, but ignores the VID.
This might work better:
#!/bin/bash
VID=0955 PID=701a
for f in `find /sys -type f -name idProduct`; do d=`dirname ${f}` if [ `cat ${d}/idVendor` != "${VID}" ]; then continue fi if [ `cat ${d}/idProduct` != "${PID}" ]; then continue fi USB_DEV=${d} break done
if [ -z "${USB_DEV}" ]; then echo "Connect target" echo "e.g. ums 0 mmc 0" exit 1 fi
echo ${USB_DEV}
"-type d" might be a good idea there.
That's probably OK, although it worries me slightly to rely on the naming convention of the device. If the code above doesn't work for some people, perhaps we could find a file named "dev", and extract the device major/minor from it. However, we'd need some complex logic to distinguish between the many files named "dev"; in ${USB_DEV}/ itself, the various partitions on the device, and the scsi_generic and "bsg" (whatever that is) devices. So, it's probably not worth changing that now.
test/dfu/dfu_gadget_test.sh | 10 +++ test/dfu/dfu_gadget_test_init.sh | 16 +++- test/ums/README | 30 +++++++ test/ums/ums_gadget_test.sh | 175 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 230 insertions(+), 1 deletion(-) create mode 100644 test/ums/README create mode 100755 test/ums/ums_gadget_test.sh
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Stephen Warren swarren@nvidia.com --- Changes for v2: - None Changes for v3: - None --- test/dfu/dfu_gadget_test_init.sh | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
LOG_DIR="./log"
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Stephen Warren swarren@nvidia.com --- Changes for v2: - None Changes for v3: - None --- test/dfu/dfu_gadget_test.sh | 10 ++++++++++ test/dfu/dfu_gadget_test_init.sh | 10 ++++++++++ 2 files changed, 20 insertions(+)
Changes for v3: - Allow PART_NUM to be "-", which gives access to the whole device - Rewrite VID/PID sysfs matching code - Update documentation for PART_NUM - Add -type d switch for memory device matching
--- test/ums/README | 30 ++++++++ test/ums/ums_gadget_test.sh | 175 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 205 insertions(+) create mode 100644 test/ums/README create mode 100755 test/ums/ums_gadget_test.sh
diff --git a/test/ums/README b/test/ums/README new file mode 100644 index 0000000..69aa6b7 --- /dev/null +++ b/test/ums/README @@ -0,0 +1,30 @@ +UMS test script. + +ums_gadget_test.sh +================== + +Example usage: +1. On the target: + create UMS exportable partitions (with e.g. gpt write), or specify a + partition number (PART_NUM) as "-" to use the entire device + ums 0 mmc 0 +2. On the host: + sudo test/ums/ums_gadget_test.sh VID PID PART_NUM [-f FILE_SYSTEM] [test_file] + e.g. sudo test/ums/ums_gadget_test.sh 04e8 6601 6 -f vfat ./dat_14M.img + +... where: + VID - UMS device USB Vendor ID + PID - UMS device USB Product ID + PART_NUM - is the partition number on which UMS operates or "-" to use the + whole device + +Information about available partitions on the target one can read with using +the 'mmc part' or 'part list' commands. + +The partition num (PART_NUM) can be specified as '-' for using the whole device. + +The [-f FILE_SYSTEM] optional switch allows for formatting target partition to +FILE_SYSTEM. + +The last, optional [test_file] parameter is for specifying the exact test file +to use. diff --git a/test/ums/ums_gadget_test.sh b/test/ums/ums_gadget_test.sh new file mode 100755 index 0000000..56d4616 --- /dev/null +++ b/test/ums/ums_gadget_test.sh @@ -0,0 +1,175 @@ +#! /bin/bash + +# Copyright (C) 2014 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# UMS operation test script +# +# SPDX-License-Identifier: GPL-2.0+ + +clear + +COLOUR_RED="\33[31m" +COLOUR_GREEN="\33[32m" +COLOUR_DEFAULT="\33[0m" + +DIR=./ +SUFFIX=img +RCV_DIR=rcv/ +LOG_FILE=./log/log-`date +%d-%m-%Y_%H-%M-%S` + +cd `dirname $0` +../dfu/dfu_gadget_test_init.sh 33M 97M + +cleanup () { + rm -rf $RCV_DIR $MNT_DIR +} + +control_c() +# run if user hits control-c +{ + echo -en "\n*** CTRL+C ***\n" + umount $MNT_DIR + cleanup + exit 0 +} + +# trap keyboard interrupt (control-c) +trap control_c SIGINT + +die () { + printf " $COLOUR_RED FAILED $COLOUR_DEFAULT \n" + cleanup + exit 1 +} + +calculate_md5sum () { + MD5SUM=`md5sum $1` + MD5SUM=`echo $MD5SUM | cut -d ' ' -f1` + echo "md5sum:"$MD5SUM +} + +ums_test_file () { + printf "$COLOUR_GREEN========================================================================================= $COLOUR_DEFAULT\n" + printf "File:$COLOUR_GREEN %s $COLOUR_DEFAULT\n" $1 + + mount /dev/$MEM_DEV $MNT_DIR + if [ -f $MNT_DIR/dat_* ]; then + rm $MNT_DIR/dat_* + fi + + cp ./$1 $MNT_DIR + umount $MNT_DIR + + + echo -n "TX: " + calculate_md5sum $1 + + MD5_TX=$MD5SUM + sleep 1 + N_FILE=$DIR$RCV_DIR${1:2}"_rcv" + + mount /dev/$MEM_DEV $MNT_DIR + cp $MNT_DIR/$1 $N_FILE || die $? + rm $MNT_DIR/$1 + umount $MNT_DIR + + echo -n "RX: " + calculate_md5sum $N_FILE + MD5_RX=$MD5SUM + + if [ "$MD5_TX" == "$MD5_RX" ]; then + printf " $COLOUR_GREEN -------> OK $COLOUR_DEFAULT \n" + else + printf " $COLOUR_RED -------> FAILED $COLOUR_DEFAULT \n" + cleanup + exit 1 + fi +} + +printf "$COLOUR_GREEN========================================================================================= $COLOUR_DEFAULT\n" +echo "U-boot UMS test program" + +if [ $EUID -ne 0 ]; then + echo "You must be root to do this." 1>&2 + exit 100 +fi + +if [ $# -lt 3 ]; then + echo "Wrong number of arguments" + echo "Example:" + echo "sudo ./ums_gadget_test.sh VID PID PART_NUM [-f ext4] [test_file]" + die +fi + +MNT_DIR="/mnt/tmp-ums-test" + +VID=$1; shift +PID=$1; shift +PART_NUM=$1; shift + +if [ "$1" == "-f" ]; then + shift + FS_TO_FORMAT=$1; shift +fi + +TEST_FILE=$1 + +for f in `find /sys -type f -name idProduct`; do + d=`dirname ${f}` + if [ `cat ${d}/idVendor` != "${VID}" ]; then + continue + fi + if [ `cat ${d}/idProduct` != "${PID}" ]; then + continue + fi + USB_DEV=${d} + break +done + +if [ -z "${USB_DEV}" ]; then + echo "Connect target" + echo "e.g. ums 0 mmc 0" + exit 1 +fi + +MEM_DEV=`find $USB_DEV -type d -name "sd[a-z]" | awk -F/ '{print $(NF)}' -` + +mkdir -p $RCV_DIR +if [ ! -d $MNT_DIR ]; then + mkdir -p $MNT_DIR +fi + +if [ "$PART_NUM" == "-" ]; then + PART_NUM="" +fi +MEM_DEV=$MEM_DEV$PART_NUM + +if [ -n "$FS_TO_FORMAT" ]; then + echo -n "Formatting partition /dev/$MEM_DEV to $FS_TO_FORMAT" + mkfs -t $FS_TO_FORMAT /dev/$MEM_DEV > /dev/null 2>&1 + if [ $? -eq 0 ]; then + printf " $COLOUR_GREEN DONE $COLOUR_DEFAULT \n" + else + die + fi +fi + +printf "Mount: /dev/$MEM_DEV \n" + +if [ -n "$TEST_FILE" ]; then + if [ ! -e $TEST_FILE ]; then + echo "No file: $TEST_FILE" + die + fi + ums_test_file $TEST_FILE +else + for file in $DIR*.$SUFFIX + do + ums_test_file $file + done +fi + +cleanup + +exit 0
Hi Stephen,
Applied to u-boot-dfu.
Thanks!
Lukasz Majewski
Stephen Warren
