[U-Boot] [PATCH] net: phy: micrel: fix KSZ9031 clock skew for values greater 0ps
For KSZ9021, all skew register fields are 4-bit wide. For KSZ9031, the clock skew register fields are 5-bit wide.
The common code in ksz90x1_of_config_group calculating the combined register value checks if the requested value is above the maximum and uses this maximum if so. The calculation of this maximum uses the register width, but the check itself does not. It uses a hardcoded value of 0xf, which is too low in case of the 5-bit clock (0x1f). This detail was probably lost during driver unification.
Effect (only for KSZ9031 clock skews): For values greater 900 (== 0ps), this silently results in 1860 (== +960ps) instead of the requested one.
Fix the check by using the bit width instead of hardcoded value(s).
Signed-off-by: Andreas Pretzsch apr@cn-eng.de --- drivers/net/phy/micrel_ksz90x1.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/phy/micrel_ksz90x1.c b/drivers/net/phy/micrel_ksz90x1.c index 3951535bf1..63e7b0242b 100644 --- a/drivers/net/phy/micrel_ksz90x1.c +++ b/drivers/net/phy/micrel_ksz90x1.c @@ -123,8 +123,8 @@ static int ksz90x1_of_config_group(struct phy_device *phydev, } else { changed = 1; /* Value was changed in OF */ /* Calculate the register value and fix corner cases */ - if (val[i] > ps_to_regval * 0xf) { - max = (1 << ofcfg->grp[i].size) - 1; + max = (1 << ofcfg->grp[i].size) - 1; + if (val[i] > ps_to_regval * max) { regval |= max << offset; } else { regval |= (val[i] / ps_to_regval) << offset;
Request for inclusion of below patch. CC Joe Hershberger as listed maintainer for 'drivers/net/'.
Thanks, Andreas
offset;
Hi Andreas,
https://patchwork.ozlabs.org/patch/1005603/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Andreas Pretzsch
Joe Hershberger
Joe Hershberger
