[U-Boot] [PATCH v2 1/2] cbfs: Remove mention of CREDITS files
As requested by Wolfgang, remove references to CREDITS in the CBFS files.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add patch to remove mention of CREDITS in CBFS files
fs/cbfs/Makefile | 4 +--- fs/cbfs/cbfs.c | 3 --- include/cbfs.h | 3 --- 3 files changed, 1 insertions(+), 9 deletions(-)
diff --git a/fs/cbfs/Makefile b/fs/cbfs/Makefile index 2be8a68..e0e6de6 100644 --- a/fs/cbfs/Makefile +++ b/fs/cbfs/Makefile @@ -1,6 +1,4 @@ -# -# See file CREDITS for list of people who contributed to this -# project. +# Copyright (c) 2011 The Chromium OS Authors. All rights reserved. # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License as diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index cae6d56..1b25a15 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -1,9 +1,6 @@ /* * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. * - * See file CREDITS for list of people who contributed to this - * project. - * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of diff --git a/include/cbfs.h b/include/cbfs.h index 6ea3f35..8a780c2 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -1,9 +1,6 @@ /* * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. * - * See file CREDITS for list of people who contributed to this - * project. - * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of
This adds a docbook template for fs, and makes CBFS use it.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Repeat function name in comment as required by dopey DocBook
doc/DocBook/Makefile | 2 +- include/cbfs.h | 69 ++++++++++++++++++++++++++------------------------ 2 files changed, 37 insertions(+), 34 deletions(-)
diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile index da88b32..521e8bc 100644 --- a/doc/DocBook/Makefile +++ b/doc/DocBook/Makefile @@ -8,7 +8,7 @@
include $(TOPDIR)/config.mk
-DOCBOOKS := linker_lists.xml stdio.xml +DOCBOOKS := fs.xml linker_lists.xml stdio.xml
### # The build process is as follows (targets): diff --git a/include/cbfs.h b/include/cbfs.h index 8a780c2..5bb12c3 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -74,46 +74,47 @@ struct cbfs_cachenode {
extern enum cbfs_result file_cbfs_result;
-/* - * Return a string describing the most recent error condition. +/** + * file_cbfs_error() - Return a string describing the most recent error + * condition. * * @return A pointer to the constant string. */ const char *file_cbfs_error(void);
-/* - * Initialize the CBFS driver and load metadata into RAM. +/** + * file_cbfs_init() - Initialize the CBFS driver and load metadata into RAM. * - * @param end_of_rom Points to the end of the ROM the CBFS should be read + * @end_of_rom: Points to the end of the ROM the CBFS should be read * from. */ void file_cbfs_init(uintptr_t end_of_rom);
-/* - * Get the header structure for the current CBFS. +/** + * file_cbfs_get_header() - Get the header structure for the current CBFS. * * @return A pointer to the constant structure, or NULL if there is none. */ const struct cbfs_header *file_cbfs_get_header(void);
-/* - * Get a handle for the first file in CBFS. +/** + * file_cbfs_get_first() - Get a handle for the first file in CBFS. * * @return A handle for the first file in CBFS, NULL on error. */ const struct cbfs_cachenode *file_cbfs_get_first(void);
-/* - * Get a handle to the file after this one in CBFS. +/** + * file_cbfs_get_next() - Get a handle to the file after this one in CBFS. * - * @param file A pointer to the handle to advance. + * @file: A pointer to the handle to advance. */ void file_cbfs_get_next(const struct cbfs_cachenode **file);
-/* - * Find a file with a particular name in CBFS. +/** + * file_cbfs_find() - Find a file with a particular name in CBFS. * - * @param name The name to search for. + * @name: The name to search for. * * @return A handle to the file, or NULL on error. */ @@ -124,53 +125,55 @@ const struct cbfs_cachenode *file_cbfs_find(const char *name); /* All of the functions below can be used without first initializing CBFS. */ /***************************************************************************/
-/* - * Find a file with a particular name in CBFS without using the heap. +/** + * file_cbfs_find_uncached() - Find a file with a particular name in CBFS + * without using the heap. * - * @param end_of_rom Points to the end of the ROM the CBFS should be read + * @end_of_rom: Points to the end of the ROM the CBFS should be read * from. - * @param name The name to search for. + * @name: The name to search for. * * @return A handle to the file, or NULL on error. */ const struct cbfs_cachenode *file_cbfs_find_uncached(uintptr_t end_of_rom, const char *name);
-/* - * Get the name of a file in CBFS. +/** + * file_cbfs_name() - Get the name of a file in CBFS. * - * @param file The handle to the file. + * @file: The handle to the file. * * @return The name of the file, NULL on error. */ const char *file_cbfs_name(const struct cbfs_cachenode *file);
-/* - * Get the size of a file in CBFS. +/** + * file_cbfs_size() - Get the size of a file in CBFS. * - * @param file The handle to the file. + * @file: The handle to the file. * * @return The size of the file, zero on error. */ u32 file_cbfs_size(const struct cbfs_cachenode *file);
-/* - * Get the type of a file in CBFS. +/** + * file_cbfs_type() - Get the type of a file in CBFS. * - * @param file The handle to the file. + * @file: The handle to the file. * * @return The type of the file, zero on error. */ u32 file_cbfs_type(const struct cbfs_cachenode *file);
-/* - * Read a file from CBFS into RAM +/** + * file_cbfs_read() - Read a file from CBFS into RAM * - * @param file A handle to the file to read. - * @param buffer Where to read it into memory. + * @file: A handle to the file to read. + * @buffer: Where to read it into memory. + * @maxsize: Maximum number of bytes to read * * @return If positive or zero, the number of characters read. If negative, an - * error occurred. + * error occurred. */ long file_cbfs_read(const struct cbfs_cachenode *file, void *buffer, unsigned long maxsize);
