[U-Boot] [PATCH 2/2] Minor changes to allow clean creation of new i386/sc520 boards
Signed-off-by: Graeme Russ graeme.russ@gmail.com ---
Moved PCI specific definitions out of sc520.h into a new file plus fixed include path to ssi.h
cpu/i386/sc520.c | 2 +- include/asm-i386/ic/pci.h | 52 +++++++++++++++++++++++++++++++++++++++++++ include/asm-i386/ic/sc520.h | 22 ------------------ 3 files changed, 53 insertions(+), 23 deletions(-) create mode 100644 include/asm-i386/ic/pci.h
diff --git a/cpu/i386/sc520.c b/cpu/i386/sc520.c index 8bcb979..cb6bc03 100644 --- a/cpu/i386/sc520.c +++ b/cpu/i386/sc520.c @@ -32,7 +32,7 @@ #include <config.h> #include <pci.h> #ifdef CONFIG_SC520_SSI -#include <ssi.h> +#include <asm/ic/ssi.h> #endif #include <asm/io.h> #include <asm/pci.h> diff --git a/include/asm-i386/ic/pci.h b/include/asm-i386/ic/pci.h new file mode 100644 index 0000000..9721110 --- /dev/null +++ b/include/asm-i386/ic/pci.h @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2008 + * Graeme Russ graeme.russ@gmail.com. + * + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_IC_SC520_PCI_H_ +#define _ASM_IC_SC520_PCI_H_ 1 + +/* pin number used for PCI interrupt mappings */ +#define SC520_PCI_INTA 0 +#define SC520_PCI_INTB 1 +#define SC520_PCI_INTC 2 +#define SC520_PCI_INTD 3 +#define SC520_PCI_GPIRQ0 4 +#define SC520_PCI_GPIRQ1 5 +#define SC520_PCI_GPIRQ2 6 +#define SC520_PCI_GPIRQ3 7 +#define SC520_PCI_GPIRQ4 8 +#define SC520_PCI_GPIRQ5 9 +#define SC520_PCI_GPIRQ6 10 +#define SC520_PCI_GPIRQ7 11 +#define SC520_PCI_GPIRQ8 12 +#define SC520_PCI_GPIRQ9 13 +#define SC520_PCI_GPIRQ10 14 + +extern int sc520_pci_ints[]; + +void pci_sc520_init(struct pci_controller *hose); +int pci_sc520_set_irq(int pci_pin, int irq); + +#endif diff --git a/include/asm-i386/ic/sc520.h b/include/asm-i386/ic/sc520.h index 0f7e7a5..bf39516 100644 --- a/include/asm-i386/ic/sc520.h +++ b/include/asm-i386/ic/sc520.h @@ -282,24 +282,6 @@ #define SC520_IRQ14 9 #define SC520_IRQ15 10
- -/* pin number used for PCI interrupt mappings */ -#define SC520_PCI_INTA 0 -#define SC520_PCI_INTB 1 -#define SC520_PCI_INTC 2 -#define SC520_PCI_INTD 3 -#define SC520_PCI_GPIRQ0 4 -#define SC520_PCI_GPIRQ1 5 -#define SC520_PCI_GPIRQ2 6 -#define SC520_PCI_GPIRQ3 7 -#define SC520_PCI_GPIRQ4 8 -#define SC520_PCI_GPIRQ5 9 -#define SC520_PCI_GPIRQ6 10 -#define SC520_PCI_GPIRQ7 11 -#define SC520_PCI_GPIRQ8 12 -#define SC520_PCI_GPIRQ9 13 -#define SC520_PCI_GPIRQ10 14 - /* utility functions */ void write_mmcr_byte(u16 mmcr, u8 data); void write_mmcr_word(u16 mmcr, u16 data); @@ -308,11 +290,7 @@ u8 read_mmcr_byte(u16 mmcr); u16 read_mmcr_word(u16 mmcr); u32 read_mmcr_long(u16 mmcr);
-extern int sc520_pci_ints[]; - void init_sc520(void); unsigned long init_sc520_dram(void); -void pci_sc520_init(struct pci_controller *hose); -int pci_sc520_set_irq(int pci_pin, int irq);
#endif -- 1.5.4.3
please split it in 2 patch
- (C) Copyright 2008
- Graeme Russ graeme.russ@gmail.com.
you do not do enough modification to add it
Best Regards, J.
Signed Off By: Graeme Russ graeme.russ@gmail.com ---
Split '[U-Boot] [PATCH 2/2] Minor changes to allow clean creation of new i386/sc520 boards' as requested
cpu/i386/sc520.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
include/asm-i386/ic/pci.h | 49 +++++++++++++++++++++++++++++++++++++++++++ include/asm-i386/ic/sc520.h | 22 ------------------- 2 files changed, 49 insertions(+), 22 deletions(-) create mode 100644 include/asm-i386/ic/pci.h
diff --git a/include/asm-i386/ic/pci.h b/include/asm-i386/ic/pci.h new file mode 100644 index 0000000..bcccdbe --- /dev/null +++ b/include/asm-i386/ic/pci.h @@ -0,0 +1,49 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_IC_SC520_PCI_H_ +#define _ASM_IC_SC520_PCI_H_ 1 + +/* pin number used for PCI interrupt mappings */ +#define SC520_PCI_INTA 0 +#define SC520_PCI_INTB 1 +#define SC520_PCI_INTC 2 +#define SC520_PCI_INTD 3 +#define SC520_PCI_GPIRQ0 4 +#define SC520_PCI_GPIRQ1 5 +#define SC520_PCI_GPIRQ2 6 +#define SC520_PCI_GPIRQ3 7 +#define SC520_PCI_GPIRQ4 8 +#define SC520_PCI_GPIRQ5 9 +#define SC520_PCI_GPIRQ6 10 +#define SC520_PCI_GPIRQ7 11 +#define SC520_PCI_GPIRQ8 12 +#define SC520_PCI_GPIRQ9 13 +#define SC520_PCI_GPIRQ10 14 + +extern int sc520_pci_ints[]; + +void pci_sc520_init(struct pci_controller *hose); +int pci_sc520_set_irq(int pci_pin, int irq); + +#endif diff --git a/include/asm-i386/ic/sc520.h b/include/asm-i386/ic/sc520.h index 0f7e7a5..bf39516 100644 --- a/include/asm-i386/ic/sc520.h +++ b/include/asm-i386/ic/sc520.h @@ -282,24 +282,6 @@ #define SC520_IRQ14 9 #define SC520_IRQ15 10
#endif
Dear Graeme Russ,
cpu/i386/sc520.c | 2 +- include/asm-i386/ic/pci.h | 52 +++++++++++++++++++++++++++++++++++++++= ++++ include/asm-i386/ic/sc520.h | 22 ------------------ 3 files changed, 53 insertions(+), 23 deletions(-) create mode 100644 include/asm-i386/ic/pci.h
Applied, thanks.
Graeme Russ
Jean-Christophe PLAGNIOL-VILLARD
