Re: [U-Boot] [U-Boot PATCH v2] RISC-V: Align boot image header with Linux
From: Atish Patra [mailto:atish.patra@wdc.com] Sent: Thursday, October 10, 2019 1:34 AM To: u-boot@lists.denx.de Cc: Atish Patra; Marek Vasut; Rick Jian-Zhi Chen(陳建志); David Abdurachmanov; paul.walmsley@sifive.com Subject: [U-Boot PATCH v2] RISC-V: Align boot image header with Linux
The released Linux boot image header in v5.3 is different from the one present in U-Boot. Align the header with the new version. The changes in Linux are backward compatible. Previous U-Boot releases with older header will continue to work as well. As v5.3 kernel is the first one to support image header, there is no compatibility issue between new U-Boot (with this patch) and older kernel.
Signed-off-by: Atish Patra atish.patra@wdc.com
arch/riscv/lib/image.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/riscv/lib/image.c b/arch/riscv/lib/image.c index d063beb7dfbe..7357d3b07d6c 100644 --- a/arch/riscv/lib/image.c +++ b/arch/riscv/lib/image.c @@ -14,20 +14,21 @@
DECLARE_GLOBAL_DATA_PTR;
-/* ASCII version of "RISCV" defined in Linux kernel */ -#define LINUX_RISCV_IMAGE_MAGIC 0x5643534952 +/* ASCII version of "RSC\0x5" defined in Linux kernel */ #define +LINUX_RISCV_IMAGE_MAGIC 0x05435352
struct linux_image_h { uint32_t code0; /* Executable code */ uint32_t code1; /* Executable code */ uint64_t text_offset; /* Image load offset */ uint64_t image_size; /* Effective Image size */
uint64_t res1; /* reserved */
uint64_t flags; /* kernel flags (little endian) */
uint32_t version; /* version of the header */
uint32_t res1; /* reserved */ uint64_t res2; /* reserved */ uint64_t res3; /* reserved */
uint64_t magic; /* Magic number */
uint32_t magic; /* Magic number */ uint32_t res4; /* reserved */
uint32_t res5; /* reserved */
int booti_setup(ulong image, ulong *relocated_addr, ulong *size,
2.21.0
Reviewed-by: Rick Chen rick@andestech.com
Rick Chen
