[U-Boot-Users] Wind River SBC8560 saga continues
The more I dig into my problem, the more confused I get.
Here is the latest plot twist...
Looking at the sources for the memory configuration:
/opt/eldk/ppc_85xx/usr/src/u-boot-1.2.0/board/sbc8560/init.S /opt/eldk/ppc_85xx/usr/src/u-boot-1.2.0/cpu/mpc85xx/start.S /opt/eldk/ppc_85xx/usr/src/u-boot-1.2.0/include/configs/sbc8560.h
I notice the TLB entries seem to be set up to do a simple straight mapping from the effective address to the real address. No problem so far.
Looking further, I notice the addresses used for the chip select values do not match the addresses specified in the SBC8560 board engineering specifications. Now it is getting a little confusing.
Finally, I notice there is one area of memory, defined at 0x70000000, which has a TLB but does not appear to have any real memory to back it up. (This address is associated with the CFG_INIT_RAM_ADDR defined symbol.)
I am hoping someone might be able to point out if I am missing something (subtle or obvious :-).
I had thought this might be the source of the CPM SCC problem I am having, but so far it does not seem to be the case.
Thanks in advance.
- Mark (the confused :-)
This email message and any attachments are confidential and may contain information which is proprietary to Mintera Corporation. If you are not the intended recipient, please notify Mintera Corporation immediately -- by replying to this message or by sending an email to postmaster@mintera.com -- and destroy all copies of this message and any attachments. Thank you.
Mark Pilant
