[U-Boot] [PATCH] fdt: Do not report bad cell count when #size-cells = <0>
Upcomming pca953x gpio driver (tca6416 is compatible with it) is using for example this DT description (ZynqMP zcu102): i2c0: i2c@ff020000 { compatible = "cdns,i2c-r1p10"; interrupt-parent = <&gic>; interrupts = <0 17 4>; reg = <0x0 0xff020000 0x1000>; #address-cells = <1>; #size-cells = <0>;
tca6416_u61: gpio@21 { compatible = "ti,tca6416"; reg = <0x21>; gpio-controller; #gpio-cells = <2>; }; };
I2C bus is using #size-cells = <0> which current code detects as "Bad cell count": OF: reached root node OF: ** translation for device gpio@20 ** __of_translate_address: Bad cell count for gpio@20 Command 'gpio' failed: Error -19
This patch fixes OF_CHECK_COUNTS macro not to report problem when size-cells is 0 which is also valid bus configuration.
common/fdt_support.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index ced119e70d9f..5f5b49c6210b 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -941,7 +941,7 @@ void fdt_del_node_and_alias(void *blob, const char *alias) #define OF_MAX_ADDR_CELLS 4 #define OF_BAD_ADDR FDT_ADDR_T_NONE #define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= OF_MAX_ADDR_CELLS && \ - (ns) > 0) + (ns) >= 0)
/* Debug utility */ #ifdef DEBUG
Hi Michal,
Reviewed-by: Peng Fan van.freenix@gmail.com
Regards, Peng.
(ns) > 0)
(ns) >= 0)
/* Debug utility */
#ifdef DEBUG
1.9.1
Hello Michal,
+CC Stephen Warren
(ns) > 0)
(ns) >= 0)
Some time ago I tried to solve GPIO issue on Exynos boards, by proposing change similar to your patch. After some discussion with Stephen Warren and Simon Glass, I was aware, that it was a wrong approach to solve this problem.
You can follow it here:
http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/247651
https://patchwork.ozlabs.org/patch/564246/ https://patchwork.ozlabs.org/patch/557008/ https://patchwork.ozlabs.org/patch/557010/ https://patchwork.ozlabs.org/patch/557009/
As a conclusion, for MMIO addresses we are using 'reg' property with a range. If you need use this as I2C address or I2C device's register - e.g. 'reg = <0x4>' - it's good until you don't use dev_get_addr() function to get it - because it's a different address space - non-MMIO.
I didn't saw your GPIO driver, but I can assume, that you should use fdtdec_get_int() to get the GPIO register addres instead of dev_get_addr().
Please look at function i2c_chip_ofdata_to_platdata() in i2c-uclass.c, the reg is taken by using fdtdec_get_int()...
On 14.4.2016 11:45, Przemyslaw Marczak wrote:
Hello Michal,
+CC Stephen Warren
(ns) > 0)
(ns) >= 0)
Thank you so much for this. That explain it. Using fdtdec_get_int() is not a problem.
Please ignore this patch.
Thanks, Michal
Michal Simek
Peng Fan
Przemyslaw Marczak
