[U-Boot] [PATCH] OneNAND: Fix compiler warnings
Signed-off-by: Stefan Roese sr@denx.de --- This patch has to be applied on top of the patch submitted by Kyungmin Park on 2008-11-04: [PATCH] [OneNAND] Sync with 2.6.27
It replaces my patch "[PATCH] OneNAND: Fix compiler warnings and add weak attribute to memcpy_16()". The weak method is not needed. Thanks to Scott for pointing this out.
drivers/mtd/onenand/onenand_base.c | 26 ++++++++++++++++++++++++++ 1 files changed, 26 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 66214e8..8d004d3 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -409,6 +409,30 @@ static int onenand_write_bufferram(struct mtd_info *mtd, loff_t addr, int area, }
/** + * onenand_get_2x_blockpage - [GENERIC] Get blockpage at 2x program mode + * @param mtd MTD data structure + * @param addr address to check + * @return blockpage address + * + * Get blockpage address at 2x program mode + */ +static int onenand_get_2x_blockpage(struct mtd_info *mtd, loff_t addr) +{ + struct onenand_chip *this = mtd->priv; + int blockpage, block, page; + + /* Calculate the even block number */ + block = (int) (addr >> this->erase_shift) & ~1; + /* Is it the odd plane? */ + if (addr & this->writesize) + block++; + page = (int) (addr >> (this->page_shift + 1)) & this->page_mask; + blockpage = (block << 7) | page; + + return blockpage; +} + +/** * onenand_check_bufferram - [GENERIC] Check BufferRAM information * @param mtd MTD data structure * @param addr address to check @@ -1666,6 +1690,7 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int return 0; }
+#ifdef ONENAND_LINUX /** * onenand_lock - [MTD Interface] Lock block(s) * @param mtd MTD device structure @@ -1701,6 +1726,7 @@ static int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len) onenand_release_device(mtd); return ret; } +#endif
/** * onenand_check_lock_status - [OneNAND Interface] Check lock status
Applied to u-boot-nand-flash/next
-Scott
Hi all,
I have to admit that I completely lost track of all the OneNAND patches floating around and being sent and resent and resent again.
This is especially the case since none of the boards I am familiar with uses OneNAND, sso I have zero experience and little ways to test anything.
In short: we need a OneNAND custodian, and we need him badly.
Is any of you volunteering, or knows of a potential candidate?
On Tue, Dec 9, 2008 at 5:44 AM, Wolfgang Denk wd@denx.de wrote:
Hi all,
Stefan,
Even though It's some difficult to access the external server, I can access http protocol. So I can pull the git. So if you control the git then I generate and send a patch against the OneNAND tree.
Or other ideas?
Thank you, Kyungmin Park
Stefan,
Or other ideas?
Till now Scott has takes care of the OneNAND related patches in his NAND repository. The latest patches are already present in his next branch, IIRC.
I'm not sure how you feel about this Scott. Are you willing to officially handle this OneNAND stuff further?
Best regards, Stefan
HI ----- Original Message ----- From: "Stefan Roese" sr@denx.de To: "Kyungmin Park" kmpark@infradead.org Cc: scottwood@freescale.com; u-boot@lists.denx.de Sent: Tuesday, December 09, 2008 11:57 AM Subject: Re: [U-Boot] [PATCH] OneNAND: Fix compiler warnings
I would like to work as OneNAND custodian ,Our team is already working for FlexOneNAND related parts , what is opinion of you guys.
Stefan,
Or other ideas?
===================================================================== DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de ===================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Amit,
Guessing from your email address, you are a co-worker of Kyungmin. Correct? Don't you have the same problems accessing the DENX git repositories as Kyungmin has?
Please don't get me wrong. I would really appreciate if you (and/or Kyungmin) would become the OneNAND custodian (if we really decide that we should create such a custodianship). Just checking if the infrastructure if working for you.
Thanks.
Hi Stefan,
Hi Amit,
Kyungmin and my team part of Samsung but in different divisions, I will check in my company about accessing DENX git reposotories,Let you know hope we can find some solution here.
regarding cowork kyungmin can take call , we have no problem as cowork or working independent. I show our interest because I feel by kyungmin mail , he has difficulty and busy with many other activities.
Thanks.
Best regards, Amit Kumar Sharma
I'm willing to continue, though if someone more familiar with OneNAND and with access to hardware wanted to take it over I'd be fine with that too.
-Scott
Dear Scott,
Thanks for the clarification.
I have this patch marked as open, and cannot find any comments for it in the archive:
11/10 Kyungmin Park [U-Boot] [PATCH] [ONENAND] Reduce OneNAND IPL code size v2
Could you please have a look? THanks.
On Wed, Dec 10, 2008 at 5:25 AM, Wolfgang Denk wd@denx.de wrote:
Dear Scott,
Thank you for Scott
Continue to work with Scott as before and make a custodian if it's needed. I will send OneNAND and IPL codes for merge tomorrow.
Plan: I worked OneNAND on several platform, S3C6410, PXA3xx, OMAP3 with different u-boot code base. So I want to merge this just one tree. actually PXA3xx and OMAP3 has same interface but s3c6410 doesn't. it has own OneNAND controller and difficult to use it.
participants (5)
Amit Kumar Sharma
Kyungmin Park
Scott Wood
Stefan Roese
