[PATCH v1 5/9] arm: rockchip: Enable display cpuinfo to be build with SPL_BUILD
Changes help enable CONFIG_DISPLAY_CPUINFO to build with SPL_BUILD for SoC RK356x and RK3588.
Cc: Jagan Teki jagan@edgeble.ai Signed-off-by: Anand Moon anand@edgeble.ai --- arch/arm/mach-rockchip/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index c07bdaee4c..6722e7c9ea 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -25,7 +25,7 @@ obj-y += boot_mode.o obj-$(CONFIG_ROCKCHIP_COMMON_BOARD) += board.o endif
-ifeq ($(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o endif
Hi Anand,
If I'm not mistaken, this is a way for disabling building cpu-info.o if either in TPL or SPL build mode (therefore only compiling for proper build mode).
I think it'd make more sense to convert CONFIG_DISPLAY_CPUINFO into three symbols, e.g. CONFIG_TPL_DISPLAY_CPUINFO, CONFIG_SPL_DISPLAY_INFO and then use
""" obj-$(CONFIG_$(TPL_SPL_)DISPLAY_CPUINFO) += cpu-info.o """
Also... considering the mail I sent to your first patch in this patch series, if we migrate to using sysreset driver to print the reset reason, we wouldn't need this file anymore so we could remove it and not have to care about this.
Cheers, Quentin
Hi Anand,
Suggest you move the cpu-info.o line inside the ifeq/endif block above.
Regards, Jonas
Anand Moon
Jonas Karlman
Quentin Schulz
