[U-Boot] [PATCH V2] ARM: DTS: imx6q-logicpd: Resync with Linux 5.1
Resync imx6q-logicpd with Kernel 5.1.5
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Re-sync with 5.1.5 from linux-stable branch
diff --git a/arch/arm/dts/imx6-logicpd-baseboard.dtsi b/arch/arm/dts/imx6-logicpd-baseboard.dtsi index 303c09334b..c40a7af6eb 100644 --- a/arch/arm/dts/imx6-logicpd-baseboard.dtsi +++ b/arch/arm/dts/imx6-logicpd-baseboard.dtsi @@ -1,45 +1,6 @@ -/* - * Copyright 2018 Logic PD, Inc. - * Based on SabreSD, Copyright 2016 Freescale Semiconductor, Inc. - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2019 Logic PD, Inc.
/ { keyboard { @@ -68,6 +29,7 @@ debounce-interval = <10>; wakeup-source; }; + btn3 { gpios = <&pcf8575 3 GPIO_ACTIVE_LOW>; label = "btn3"; @@ -81,7 +43,7 @@ leds { compatible = "gpio-leds";
- gen_led0 { + gen-led0 { label = "led0"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_led0>; @@ -89,25 +51,27 @@ linux,default-trigger = "cpu0"; };
- gen_led1 { + gen-led1 { label = "led1"; gpios = <&pcf8575 8 GPIO_ACTIVE_HIGH>; };
- gen_led2 { + gen-led2 { label = "led2"; gpios = <&pcf8575 9 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; };
- gen_led3 { + gen-led3 { label = "led3"; gpios = <&pcf8575 10 GPIO_ACTIVE_HIGH>; linux,default-trigger = "default-on"; }; };
- reg_usb_otg_vbus: regulator-otg-vbus@0 { + reg_usb_otg_vbus: regulator-otg-vbus { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usb_otg>; compatible = "regulator-fixed"; regulator-name = "usb_otg_vbus"; regulator-min-microvolt = <5000000>; @@ -116,14 +80,19 @@ enable-active-high; };
- reg_usb_h1_vbus: regulator-usbh1vbus@1 { + reg_usb_h1_vbus: regulator-usb-h1-vbus { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usb_h1_vbus>; compatible = "regulator-fixed"; regulator-name = "usb_h1_vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; + gpio = <&gpio7 12 GPIO_ACTIVE_HIGH>; + startup-delay-us = <70000>; + enable-active-high; };
- reg_3v3: regulator-3v3@2 { + reg_3v3: regulator-3v3 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_reg_3v3>; compatible = "regulator-fixed"; @@ -131,13 +100,14 @@ regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; gpio = <&gpio1 26 GPIO_ACTIVE_HIGH>; + startup-delay-us = <70000>; enable-active-high; regulator-always-on; };
- reg_enet: regulator-ethernet@3 { + reg_enet: regulator-ethernet { pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_enet_pwr>; + pinctrl-0 = <&pinctrl_reg_enet>; compatible = "regulator-fixed"; regulator-name = "ethernet-supply"; regulator-min-microvolt = <3300000>; @@ -148,7 +118,7 @@ vin-supply = <&sw4_reg>; };
- reg_audio: regulator-audio@4 { + reg_audio: regulator-audio { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_reg_audio>; compatible = "regulator-fixed"; @@ -157,11 +127,10 @@ regulator-max-microvolt = <3300000>; gpio = <&gpio1 29 GPIO_ACTIVE_HIGH>; enable-active-high; - regulator-always-on; vin-supply = <®_3v3>; };
- reg_hdmi: regulator-hdmi@5 { + reg_hdmi: regulator-hdmi { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_reg_hdmi>; compatible = "regulator-fixed"; @@ -173,7 +142,7 @@ vin-supply = <®_3v3>; };
- reg_uart3: regulator-uart3@6 { + reg_uart3: regulator-uart3 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_reg_uart3>; compatible = "regulator-fixed"; @@ -184,7 +153,7 @@ vin-supply = <®_3v3>; };
- reg_1v8: regulator-1v8@7 { + reg_1v8: regulator-1v8 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_reg_1v8>; compatible = "regulator-fixed"; @@ -195,21 +164,21 @@ vin-supply = <®_3v3>; };
- reg_pcie: regulator@8 { + reg_pcie: regulator-pcie { compatible = "regulator-fixed"; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie_reg>; - regulator-name = "MPCIE_3V3"; + pinctrl-0 = <&pinctrl_reg_pcie>; + regulator-name = "mpcie_3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>; enable-active-high; };
- mipi_pwr: regulator@9 { + reg_mipi: regulator-mipi { compatible = "regulator-fixed"; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_mipi_pwr>; + pinctrl-0 = <&pinctrl_reg_mipi>; regulator-name = "mipi_pwr_en"; regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; @@ -221,7 +190,7 @@ compatible = "fsl,imx-audio-wm8962"; model = "wm8962-audio"; ssi-controller = <&ssi2>; - audio-codec = <&codec>; + audio-codec = <&wm8962>; audio-routing = "Headphone Jack", "HPOUTL", "Headphone Jack", "HPOUTR", @@ -246,34 +215,10 @@ status = "disabled"; };
-&pwm3 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pwm3>; -}; - -&uart3 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart3>; - status = "okay"; -}; - -&usbh1 { - vbus-supply = <®_usb_h1_vbus>; - status = "okay"; -}; - -&usbotg { - vbus-supply = <®_usb_otg_vbus>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usbotg>; - disable-over-current; - status = "okay"; -}; - &fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_enet>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-reset-duration = <10>; phy-reset-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>; phy-supply = <®_enet>; @@ -282,23 +227,13 @@ status = "okay"; };
-&usdhc2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc2>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>; - no-1-8-v; - keep-power-in-suspend; - status = "okay"; -}; - &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; clock-frequency = <400000>; status = "okay";
- codec: wm8962@1a { + wm8962: audio-codec@1a { compatible = "wlf,wm8962"; reg = <0x1a>; clocks = <&clks IMX6QDL_CLK_CKO>; @@ -330,9 +265,9 @@ reg = <0x10>; clocks = <&clks IMX6QDL_CLK_CKO>; clock-names = "xclk"; - DOVDD-supply = <&mipi_pwr>; - AVDD-supply = <&mipi_pwr>; - DVDD-supply = <&mipi_pwr>; + DOVDD-supply = <®_mipi>; + AVDD-supply = <®_mipi>; + DVDD-supply = <®_mipi>; reset-gpios = <&gpio3 26 GPIO_ACTIVE_LOW>; powerdown-gpios = <&gpio3 27 GPIO_ACTIVE_HIGH>;
@@ -361,6 +296,11 @@ }; };
+&ipu1_csi1_from_mipi_vc1 { + clock-lanes = <0>; + data-lanes = <1 2>; +}; + &mipi_csi { status = "okay";
@@ -379,17 +319,52 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pcie>; reset-gpio = <&gpio1 9 GPIO_ACTIVE_LOW>; - status = "okay"; vpcie-supply = <®_pcie>; - /* fsl,max-link-speed = <2>; */ + status = "okay"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; };
&ssi2 { status = "okay"; };
-&iomuxc { +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +};
+&usbh1 { + vbus-supply = <®_usb_h1_vbus>; + status = "okay"; +}; + +&usbotg { + vbus-supply = <®_usb_otg_vbus>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + disable-over-current; + dr_mode = "otg"; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + vmmc-supply = <®_3v3>; + no-1-8-v; + keep-power-in-suspend; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&iomuxc { pinctrl_audmux: audmuxgrp { fsl,pins = < MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x130b0 @@ -399,21 +374,49 @@ >; };
- pinctrl_i2c1: i2c1 { + pinctrl_ecspi1: ecspi1grp { fsl,pins = < - MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 - MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x100b1 + MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x100b1 + MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x100b1 + MX6QDL_PAD_KEY_ROW1__ECSPI1_SS0 0x100b1 >; };
- pinctrl_enet_pwr: enet_pwr { + pinctrl_enet: enetgrp { fsl,pins = < - MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x1b0b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b8b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x100b0 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x13030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x13030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x13030 + MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1b0b0 /* ENET_INT */ + MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x1b0b0 /* ETHR_nRST */ >; };
- pinctrl_mipi_pwr: pwr_mipi { - fsl,pins = <MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x1b0b1>; + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_led0: led0grp { + fsl,pins = < + MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x1b0b0 + >; };
pinctrl_ov5640: ov5640grp { @@ -423,174 +426,132 @@ >; };
- pinctrl_reg_hdmi: reg_hdmi { + pinctrl_pcf8574: pcf8575grp { fsl,pins = < - MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x1b0b0 + MX6QDL_PAD_EIM_BCLK__GPIO6_IO31 0x1b0b0 >; };
- pinctrl_uart3: uart3grp { + pinctrl_pcie: pciegrp { fsl,pins = < - MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x1b0b1 - MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b1 - MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b1 - MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x1b0b1 + MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x1b0b0 + MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x1b0b0 >; };
- pinctrl_usbotg: usbotggrp { - fsl,pins = < - MX6QDL_PAD_GPIO_1__USB_OTG_ID 0xd17059 - MX6QDL_PAD_KEY_ROW4__USB_OTG_PWR 0x130b0 - >; + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + >; };
- pinctrl_ecspi1: ecspi1grp { - fsl,pins = < - MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x100b1 - MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x100b1 - MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x100b1 - MX6QDL_PAD_KEY_ROW1__ECSPI1_SS0 0x100b1 - >; + pinctrl_reg_1v8: reg1v8grp { + fsl,pins = < + MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x1b0b0 + >; };
- pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 /* CD */ - MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17069 - MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10069 - MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17069 - MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17069 - MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17069 - MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17069 - >; - }; - - pinctrl_usdhc2_100mhz: h100-usdhc2-100mhz { - fsl,pins = < - MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 /* CD */ - MX6QDL_PAD_SD2_CMD__SD2_CMD 0x170b9 - MX6QDL_PAD_SD2_CLK__SD2_CLK 0x100b9 - MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x170b9 - MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x170b9 - MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x170b9 - MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x170b9 - >; + pinctrl_reg_3v3: reg3v3grp { + fsl,pins = < + MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x1b0b0 + >; };
- pinctrl_usdhc2_200mhz: h100-usdhc2-200mhz { + pinctrl_reg_audio: reg-audiogrp { fsl,pins = < - MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 /* CD */ - MX6QDL_PAD_SD2_CMD__SD2_CMD 0x170f9 - MX6QDL_PAD_SD2_CLK__SD2_CLK 0x100f9 - MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x170f9 - MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x170f9 - MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x170f9 - MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x170f9 + MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x1b0b0 >; };
- pinctrl_enet: enetgrp { + pinctrl_reg_enet: reg-enetgrp { fsl,pins = < - MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b8b0 - MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 - MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 - MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 - MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 - MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 - MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 - MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x100b0 - MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 - MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 - MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 - MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x13030 - MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x13030 - MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 - MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 - MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x13030 - MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1b0b0 /* ENET_INT */ - MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x1b0b0 /* ETHR_nRST */ + MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x1b0b0 >; };
- pinctrl_reg_audio: audio-reg { + pinctrl_reg_hdmi: reg-hdmigrp { fsl,pins = < - MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x1b0b0 + MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x1b0b0 >; };
- pinctrl_pcie: pcie { - fsl,pins = < - MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x1b0b0 - MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x1b0b0 - >; + pinctrl_reg_mipi: reg-mipigrp { + fsl,pins = <MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x1b0b1>; };
- pinctrl_pcie_reg: pciereggrp { + pinctrl_reg_pcie: reg-pciegrp { fsl,pins = < MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x1b0b0 >; };
- pinctrl_pcf8574: pcf8575-pins { + pinctrl_reg_uart3: reguart3grp { + fsl,pins = < + MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x1b0b0 + >; + }; + + pinctrl_reg_usb_h1_vbus: usbh1grp { fsl,pins = < - MX6QDL_PAD_EIM_BCLK__GPIO6_IO31 0x1b0b0 + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x1b0b0 >; };
- pinctrl_lcd: lcdgrp { + pinctrl_reg_usb_otg: reg-usb-otggrp { fsl,pins = < - MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x10 /* R_LCD_DCLK */ - MX6QDL_PAD_DI0_PIN15__GPIO4_IO17 0x100b0 /* R_LCD_PANEL_PWR */ - MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0x10 /* R_LCD_HSYNC */ - MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0x10 /* R_LCD_VSYNC */ - MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04 0x10 /* R_LCD_MDISP */ - MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0x10 - MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0x10 - MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0x10 - MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0x10 - MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0x10 - MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0x10 - MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0x10 - MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x10 - MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x10 - MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x10 - MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x10 - MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x10 - MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x10 - MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x10 - MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x10 - MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0x10 + MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x1b0b0 >; };
- pinctrl_pwm3: pwm3grp { + pinctrl_uart3: uart3grp { fsl,pins = < - MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x1b0b1 + MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x1b0b1 >; };
- pinctrl_reg_uart3: uart3reg { + pinctrl_usbotg: usbotggrp { fsl,pins = < - MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x1b0b0 + MX6QDL_PAD_GPIO_1__USB_OTG_ID 0xd17059 >; };
- pinctrl_reg_3v3: reg-3v3 { + pinctrl_usdhc2: usdhc2grp { fsl,pins = < - MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x1b0b0 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 /* CD */ + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17069 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10069 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17069 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17069 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17069 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17069 >; };
- pinctrl_reg_1v8: reg-1v8 { + pinctrl_usdhc2_100mhz: h100-usdhc2-100mhz { fsl,pins = < - MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x1b0b0 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 /* CD */ + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x170b9 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x100b9 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x170b9 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x170b9 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x170b9 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x170b9 >; };
- pinctrl_led0: led0 { + pinctrl_usdhc2_200mhz: h100-usdhc2-200mhz { fsl,pins = < - MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x1b0b0 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 /* CD */ + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x170f9 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x100f9 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x170f9 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x170f9 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x170f9 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x170f9 >; }; + }; diff --git a/arch/arm/dts/imx6-logicpd-som.dtsi b/arch/arm/dts/imx6-logicpd-som.dtsi index 3fc50babf0..7ceae35732 100644 --- a/arch/arm/dts/imx6-logicpd-som.dtsi +++ b/arch/arm/dts/imx6-logicpd-som.dtsi @@ -1,16 +1,6 @@ -/* - * Copyright 2018 Logic PD - * This file is adapted from imx6qdl-sabresd.dtsi. - * Copyright 2012 Freescale Semiconductor, Inc. - * Copyright 2011 Linaro Ltd. - * - * The code contained herein is licensed under the GNU General Public - * License. You may obtain a copy of the GNU General Public License - * Version 2 or later at the following locations: - * - * http://www.opensource.org/licenses/gpl-license.html - * http://www.gnu.org/copyleft/gpl.html - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2019 Logic PD, Inc.
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> @@ -20,7 +10,8 @@ stdout-path = &uart1; };
- memory { + memory@10000000 { + device_type = "memory"; reg = <0x10000000 0x80000000>; };
@@ -35,17 +26,6 @@ }; };
-/* Reroute power feeding the CPU to come from the external PMIC */ -®_arm -{ - vin-supply = <&sw1a_reg>; -}; - -®_soc -{ - vin-supply = <&sw1c_reg>; -}; - &clks { assigned-clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>; @@ -56,8 +36,8 @@ &gpmi { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpmi_nand>; - status = "okay"; nand-on-flash-bbt; + status = "okay"; };
&i2c3 { @@ -66,7 +46,7 @@ pinctrl-0 = <&pinctrl_i2c3>; status = "okay";
- pmic: pfuze100@08 { + pfuze100: pmic@8 { compatible = "fsl,pfuze100"; reg = <0x08>;
@@ -94,20 +74,19 @@ regulator-max-microvolt = <3300000>; regulator-name = "gen_3v3"; regulator-boot-on; - /* regulator-always-on; */ };
sw3a_reg: sw3a { - regulator-min-microvolt = <400000>; - regulator-max-microvolt = <1975000>; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; regulator-name = "sw3a_vddr"; regulator-boot-on; regulator-always-on; };
sw3b_reg: sw3b { - regulator-min-microvolt = <400000>; - regulator-max-microvolt = <1975000>; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; regulator-name = "sw3b_vddr"; regulator-boot-on; regulator-always-on; @@ -152,8 +131,8 @@
vgen3_reg: vgen3 { regulator-name = "gen_vadj_0"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; };
vgen4_reg: vgen4 { @@ -164,8 +143,8 @@ };
vgen5_reg: vgen5 { - regulator-name = "gen_adj_1"; - regulator-min-microvolt = <3300000>; + regulator-name = "gen_vadj_1"; + regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-always-on; }; @@ -185,44 +164,75 @@ }; };
- temp_sense0: tmp102@4a { + temperature-sensor@49 { compatible = "ti,tmp102"; - reg = <0x4a>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_tempsense>; + reg = <0x49>; interrupt-parent = <&gpio6>; interrupts = <15 IRQ_TYPE_LEVEL_LOW>; #thermal-sensor-cells = <1>; };
- temp_sense1: tmp102@49 { + temperature-sensor@4a { compatible = "ti,tmp102"; - reg = <0x49>; + reg = <0x4a>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_tempsense>; interrupt-parent = <&gpio6>; interrupts = <15 IRQ_TYPE_LEVEL_LOW>; #thermal-sensor-cells = <1>; };
- mfg_eeprom: at24@51 { + eeprom@51 { compatible = "atmel,24c64"; pagesize = <32>; - read-only; + read-only; /* Manufacturing EEPROM programmed at factory */ reg = <0x51>; };
- user_eeprom: at24@52 { + eeprom@52 { compatible = "atmel,24c64"; pagesize = <32>; reg = <0x52>; }; };
+/* Reroute power feeding the CPU to come from the external PMIC */ +®_arm +{ + vin-supply = <&sw1a_reg>; +}; + +®_soc +{ + vin-supply = <&sw1c_reg>; +}; + &iomuxc { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_hog>;
- pinctrl_hog: hoggrp { + pinctrl_gpmi_nand: gpmi-nandgrp { fsl,pins = < + MX6QDL_PAD_NANDF_CLE__NAND_CLE 0x0b0b1 + MX6QDL_PAD_NANDF_ALE__NAND_ALE 0x0b0b1 + MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0x0b0b1 + MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0x0b000 + MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0x0b0b1 + MX6QDL_PAD_SD4_CMD__NAND_RE_B 0x0b0b1 + MX6QDL_PAD_SD4_CLK__NAND_WE_B 0x0b0b1 + MX6QDL_PAD_NANDF_D0__NAND_DATA00 0x0b0b1 + MX6QDL_PAD_NANDF_D1__NAND_DATA01 0x0b0b1 + MX6QDL_PAD_NANDF_D2__NAND_DATA02 0x0b0b1 + MX6QDL_PAD_NANDF_D3__NAND_DATA03 0x0b0b1 + MX6QDL_PAD_NANDF_D4__NAND_DATA04 0x0b0b1 + MX6QDL_PAD_NANDF_D5__NAND_DATA05 0x0b0b1 + MX6QDL_PAD_NANDF_D6__NAND_DATA06 0x0b0b1 + MX6QDL_PAD_NANDF_D7__NAND_DATA07 0x0b0b1 + >; + }; + + pinctrl_hog: hoggrp { + fsl,pins = < /* Enable ARM Debugger */ MX6QDL_PAD_CSI0_MCLK__ARM_TRACE_CTL 0x1b0b0 MX6QDL_PAD_CSI0_PIXCLK__ARM_EVENTO 0x1b0b0 MX6QDL_PAD_CSI0_VSYNC__ARM_TRACE00 0x1b0b0 @@ -246,30 +256,16 @@ >; };
- pinctrl_gpmi_nand: gpminandgrp { + pinctrl_i2c3: i2c3grp { fsl,pins = < - MX6QDL_PAD_NANDF_CLE__NAND_CLE 0x0b0b1 - MX6QDL_PAD_NANDF_ALE__NAND_ALE 0x0b0b1 - MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0x0b0b1 - MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0x0b000 - MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0x0b0b1 - MX6QDL_PAD_SD4_CMD__NAND_RE_B 0x0b0b1 - MX6QDL_PAD_SD4_CLK__NAND_WE_B 0x0b0b1 - MX6QDL_PAD_NANDF_D0__NAND_DATA00 0x0b0b1 - MX6QDL_PAD_NANDF_D1__NAND_DATA01 0x0b0b1 - MX6QDL_PAD_NANDF_D2__NAND_DATA02 0x0b0b1 - MX6QDL_PAD_NANDF_D3__NAND_DATA03 0x0b0b1 - MX6QDL_PAD_NANDF_D4__NAND_DATA04 0x0b0b1 - MX6QDL_PAD_NANDF_D5__NAND_DATA05 0x0b0b1 - MX6QDL_PAD_NANDF_D6__NAND_DATA06 0x0b0b1 - MX6QDL_PAD_NANDF_D7__NAND_DATA07 0x0b0b1 + MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 >; };
- pinctrl_i2c3: i2c3grp { + pinctrl_tempsense: tempsensegrp { fsl,pins = < - MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1 - MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 + MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x1b0b0 >; };
@@ -282,7 +278,7 @@
pinctrl_uart2: uart2grp { fsl,pins = < - MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x13059 /* BT_EN */ + MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x13059 /* BT_EN */ MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x1b0b1 MX6QDL_PAD_SD4_DAT5__UART2_RTS_B 0x1b0b1 MX6QDL_PAD_SD4_DAT6__UART2_CTS_B 0x1b0b1 @@ -313,12 +309,6 @@ MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x17059 /* WLAN_EN */ >; }; - - pinctrl_tempsense: tempsensegrp { - fsl,pins = < - MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x1b0b0 /* Temp Sense Alert */ - >; - }; };
&snvs_poweroff { @@ -334,8 +324,9 @@ &uart2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; - status = "okay"; uart-has-rtscts; + status = "okay"; + bluetooth { compatible = "ti,wl1837-st"; enable-gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>; @@ -347,9 +338,9 @@ pinctrl-0 = <&pinctrl_usdhc1>; non-removable; keep-power-in-suspend; - enable-sdio-wakeup; - status = "okay"; + wakeup-source; vmmc-supply = <&sw2_reg>; + status = "okay"; };
&usdhc3 { @@ -360,9 +351,10 @@ keep-power-in-suspend; wakeup-source; vmmc-supply = <®_wl18xx_vmmc>; - status = "okay"; #address-cells = <1>; #size-cells = <0>; + status = "okay"; + wlcore: wlcore@2 { compatible = "ti,wl1837"; reg = <2>; diff --git a/arch/arm/dts/imx6q-logicpd.dts b/arch/arm/dts/imx6q-logicpd.dts index dcea784477..45eb0b7f75 100644 --- a/arch/arm/dts/imx6q-logicpd.dts +++ b/arch/arm/dts/imx6q-logicpd.dts @@ -1,45 +1,6 @@ -/* - * Copyright 2018 Logic PD, Inc. - * Based on SabreSD, Copyright 2016 Freescale Semiconductor, Inc. - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2019 Logic PD, Inc.
/dts-v1/; #include "imx6q.dtsi" @@ -47,10 +8,10 @@ #include "imx6-logicpd-baseboard.dtsi"
/ { - model = "Logic PD i.MX6QD SOM-M3 (HDMI)"; + model = "Logic PD i.MX6QD SOM-M3"; compatible = "fsl,imx6q";
- backlight: backlight_lvds { + backlight: backlight-lvds { compatible = "pwm-backlight"; pwms = <&pwm3 0 20000>; brightness-levels = <0 4 8 16 32 64 128 255>; @@ -58,6 +19,16 @@ power-supply = <®_lcd>; };
+ panel-lvds0 { + compatible = "okaya,rs800480t-7x0gp"; + + port { + panel_in_lvds0: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + }; + reg_lcd: regulator-lcd { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lcd_reg>; @@ -72,7 +43,7 @@ startup-delay-us = <500000>; };
- lcd_reset: lcd_reset { + reg_lcd_reset: regulator-lcd-reset { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lcd_reset>; compatible = "regulator-fixed"; @@ -84,17 +55,17 @@ regulator-always-on; vin-supply = <®_lcd>; }; +};
- panel-lvds0 { - compatible = "ampire,am800480b3tmqw"; - backlight = <&backlight>; - - port { - panel_in_lvds0: endpoint { - remote-endpoint = <&lvds0_out>; - }; - }; - }; +&clks { + assigned-clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, + <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_PRE_SEL>, + <&clks IMX6QDL_CLK_IPU2_DI0_PRE_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_PLL5_VIDEO_DIV>, + <&clks IMX6QDL_CLK_PLL5_VIDEO_DIV>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>; };
&hdmi { @@ -102,22 +73,6 @@ status = "okay"; };
-&i2c1 { - ili_touch: ilitouch@26 { - compatible = "ili,ili2117a"; - reg = <0x26>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_touchscreen>; - interrupts-extended = <&gpio1 6 IRQ_TYPE_EDGE_RISING>; - ili2117a,poll-period = <10>; - ili2117a,max-touch = <2>; - }; -}; - -®_hdmi { - regulator-always-on; -}; - &ldb { status = "okay";
@@ -128,7 +83,6 @@
port@4 { reg = <4>; - lvds0_out: endpoint { remote-endpoint = <&panel_in_lvds0>; }; @@ -137,23 +91,12 @@
-&clks { - assigned-clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, - <&clks IMX6QDL_CLK_LDB_DI1_SEL>, - <&clks IMX6QDL_CLK_IPU1_DI0_PRE_SEL>, - <&clks IMX6QDL_CLK_IPU2_DI0_PRE_SEL>; - assigned-clock-parents = <&clks IMX6QDL_CLK_PLL5_VIDEO_DIV>, - <&clks IMX6QDL_CLK_PLL5_VIDEO_DIV>, - <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, - <&clks IMX6QDL_CLK_PLL2_PFD2_396M>; -}; - &pwm3 { status = "okay"; };
-&usdhc2 { - cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; +®_hdmi { + regulator-always-on; /* Without this, the level shifter on HDMI doesn't turn on */ };
&iomuxc { @@ -165,7 +108,7 @@
pinctrl_lcd_reset: lcdreset { fsl,pins = < - MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x100b0 /* LCD_nRESET */ + MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x100b0 /* LCD_nRESET */ >; };
@@ -175,4 +118,3 @@ >; }; }; -
Adam Ford
