[U-Boot] [PATCH][v5] powerpc: eSPI and eSPI controller support
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Singed-off-by: Jerry Huang Chang-Ming.Huang@freescale.com Signed-off-by: Shaohui Xie b21989@freescale.com Cc: Mike Frysinger vapier@gentoo.org --- changes for v2: remove #ifdef wrapper and refactor spi_xfer by use SPI_XFER(BEGIN | END). remove 'volatile' use I/O accessors instead.
changes for v3: move powerpc specific code to asm/config.h. use spi_claim_bus() to setup hardware rather than spi_setup_slave(). use slave data rather than global. drop useless return.
changes for v4: use controller specific struct rather than put in common header. merge read more than 0xfffa bytes patch.
changes for v5: fix code style. drop flag check. drop unnecessary copy right.
arch/powerpc/include/asm/config.h | 7 + drivers/spi/Makefile | 1 + drivers/spi/fsl_espi.c | 334 +++++++++++++++++++++++++++++++++++++ include/spi.h | 7 - 4 files changed, 342 insertions(+), 7 deletions(-) create mode 100644 drivers/spi/fsl_espi.c
diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index 624d8c2..9aad9be 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -29,6 +29,13 @@ #include <asm/config_mpc86xx.h> #endif
+/* CONFIG_HARD_SPI triggers SPI bus initialization in PowerPC */ +#if defined(CONFIG_MPC8XXX_SPI) || defined(CONFIG_FSL_ESPI) +# ifndef CONFIG_HARD_SPI +# define CONFIG_HARD_SPI +# endif +#endif + #define CONFIG_LMB #define CONFIG_SYS_BOOT_RAMDISK_HIGH #define CONFIG_SYS_BOOT_GET_CMDLINE diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index d582fbb..74f1293 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o COBJS-$(CONFIG_SH_SPI) += sh_spi.o +COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c new file mode 100644 index 0000000..f872cd8 --- /dev/null +++ b/drivers/spi/fsl_espi.c @@ -0,0 +1,334 @@ +/* + * eSPI controller driver. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * Author: Mingkai Hu (Mingkai.hu@freescale.com) + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#include <malloc.h> +#include <spi.h> +#include <asm/immap_85xx.h> + +struct fsl_spi_slave { + struct spi_slave slave; + unsigned int div16; + unsigned int pm; + unsigned int mode; + size_t cmd_len; + u8 cmd_buf[16]; + size_t data_len; + unsigned int max_transfer_length; +}; + +#define to_fsl_spi_slave(s) container_of(s, struct fsl_spi_slave, slave) + +#define ESPI_MAX_CS_NUM 4 + +#define ESPI_EV_RNE (1 << 9) +#define ESPI_EV_TNF (1 << 8) + +#define ESPI_MODE_EN (1 << 31) /* Enable interface */ +#define ESPI_MODE_TXTHR(x) ((x) << 8) /* Tx FIFO threshold */ +#define ESPI_MODE_RXTHR(x) ((x) << 0) /* Rx FIFO threshold */ + +#define ESPI_COM_CS(x) ((x) << 30) +#define ESPI_COM_TRANLEN(x) ((x) << 0) + +#define ESPI_CSMODE_CI_INACTIVEHIGH (1 << 31) +#define ESPI_CSMODE_CP_BEGIN_EDGCLK (1 << 30) +#define ESPI_CSMODE_REV_MSB_FIRST (1 << 29) +#define ESPI_CSMODE_DIV16 (1 << 28) +#define ESPI_CSMODE_PM(x) ((x) << 24) +#define ESPI_CSMODE_POL_ASSERTED_LOW (1 << 20) +#define ESPI_CSMODE_LEN(x) ((x) << 16) +#define ESPI_CSMODE_CSBEF(x) ((x) << 12) +#define ESPI_CSMODE_CSAFT(x) ((x) << 8) +#define ESPI_CSMODE_CSCG(x) ((x) << 3) + +#define ESPI_CSMODE_INIT_VAL (ESPI_CSMODE_POL_ASSERTED_LOW | \ + ESPI_CSMODE_CSBEF(0) | ESPI_CSMODE_CSAFT(0) | \ + ESPI_CSMODE_CSCG(1)) + +#define ESPI_MAX_DATA_TRANSFER_LEN 0xFFF0 + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct fsl_spi_slave *fsl; + sys_info_t sysinfo; + unsigned long spibrg = 0; + unsigned char pm = 0; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + fsl = malloc(sizeof(struct fsl_spi_slave)); + if (!fsl) + return NULL; + + fsl->slave.bus = bus; + fsl->slave.cs = cs; + fsl->mode = mode; + fsl->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; + + /* Set eSPI BRG clock source */ + get_sys_info(&sysinfo); + spibrg = sysinfo.freqSystemBus / 2; + fsl->div16 = 0; + if ((spibrg / max_hz) > 32) { + fsl->div16 = ESPI_CSMODE_DIV16; + pm = spibrg / (max_hz * 16 * 2); + if (pm > 16) { + pm = 16; + debug("Requested speed is too low: %d Hz, " + "%d Hz is used.\n", max_hz, spibrg / (32 * 16)); + } + } else + pm = spibrg / (max_hz * 2); + if (pm) + pm--; + fsl->pm = pm; + + return &fsl->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + free(fsl); +} + +void spi_init(void) +{ + +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + ccsr_espi_t *espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); + unsigned char pm = fsl->pm; + unsigned int cs = slave->cs; + unsigned int mode = fsl->mode; + unsigned int div16 = fsl->div16; + int i; + + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, cs); + + /* Enable eSPI interface */ + out_be32(&espi->mode, ESPI_MODE_RXTHR(3) + | ESPI_MODE_TXTHR(4) | ESPI_MODE_EN); + + out_be32(&espi->event, 0xffffffff); /* Clear all eSPI events */ + out_be32(&espi->mask, 0x00000000); /* Mask all eSPI interrupts */ + + /* Init CS mode interface */ + for (i = 0; i < ESPI_MAX_CS_NUM; i++) + out_be32(&espi->csmode[i], ESPI_CSMODE_INIT_VAL); + + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) & + ~(ESPI_CSMODE_PM(0xF) | ESPI_CSMODE_DIV16 + | ESPI_CSMODE_CI_INACTIVEHIGH | ESPI_CSMODE_CP_BEGIN_EDGCLK + | ESPI_CSMODE_REV_MSB_FIRST | ESPI_CSMODE_LEN(0xF))); + + /* Set eSPI BRG clock source */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_PM(pm) | div16); + + /* Set eSPI mode */ + if (mode & SPI_CPHA) + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_CP_BEGIN_EDGCLK); + if (mode & SPI_CPOL) + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_CI_INACTIVEHIGH); + + /* Character bit order: msb first */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_REV_MSB_FIRST); + + /* Character length in bits, between 0x3~0xf, i.e. 4bits~16bits */ + out_be32(&espi->csmode[cs], in_be32(&espi->csmode[cs]) + | ESPI_CSMODE_LEN(7)); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, + void *data_in, unsigned long flags) +{ + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + ccsr_espi_t *espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); + unsigned int tmpdout, tmpdin, event; + const void *dout = NULL; + void *din = NULL; + int len = 0; + int num_blks, num_chunks, max_tran_len, tran_len; + int num_bytes; + unsigned char *ch; + unsigned char *buffer = NULL; + size_t buf_len; + u8 *cmd_buf = fsl->cmd_buf; + size_t cmd_len = fsl->cmd_len; + size_t data_len = bitlen / 8; + size_t rx_offset = 0; + + max_tran_len = fsl->max_transfer_length; + switch (flags) { + case SPI_XFER_BEGIN: + cmd_len = fsl->cmd_len = data_len; + memcpy(cmd_buf, data_out, cmd_len); + return 0; + case 0: + case SPI_XFER_END: + if (bitlen == 0) { + spi_cs_deactivate(slave); + return 0; + } + buf_len = 2 * cmd_len + min(data_len, max_tran_len); + len = cmd_len + data_len; + rx_offset = cmd_len; + buffer = (unsigned char *)malloc(buf_len); + if (!buffer) { + debug("SF: Failed to malloc memory.\n"); + return 1; + } + memcpy(buffer, cmd_buf, cmd_len); + if (cmd_len != 1) { + if (data_in == NULL) + memcpy(buffer + cmd_len, data_out, data_len); + } + break; + case SPI_XFER_BEGIN | SPI_XFER_END: + len = data_len; + buffer = (unsigned char *)malloc(len * 2); + if (!buffer) { + debug("SF: Failed to malloc memory.\n"); + return 1; + } + memcpy(buffer, data_out, len); + rx_offset = len; + cmd_len = 0; + break; + } + + debug("spi_xfer: slave %u:%u dout %08X(%08x) din %08X(%08x) len %u\n", + slave->bus, slave->cs, *(uint *) dout, + dout, *(uint *) din, din, len); + + num_chunks = data_len / max_tran_len + + (data_len % max_tran_len ? 1 : 0); + while (num_chunks--) { + if (data_in) + din = buffer + rx_offset; + dout = buffer; + tran_len = min(data_len , max_tran_len); + num_blks = (tran_len + cmd_len) / 4 + + ((tran_len + cmd_len) % 4 ? 1 : 0); + num_bytes = (tran_len + cmd_len) % 4; + fsl->data_len = tran_len + cmd_len; + spi_cs_activate(slave); + + /* Clear all eSPI events */ + out_be32(&espi->event , 0xffffffff); + /* handle data in 32-bit chunks */ + while (num_blks--) { + + event = in_be32(&espi->event); + if (event & ESPI_EV_TNF) { + tmpdout = *(u32 *)dout; + + /* Set up the next iteration */ + if (len > 4) { + len -= 4; + dout += 4; + } + + out_be32(&espi->tx, tmpdout); + out_be32(&espi->event, ESPI_EV_TNF); + debug("***spi_xfer:...%08x written\n", tmpdout); + } + + /* Wait for eSPI transmit to get out */ + udelay(80); + + event = in_be32(&espi->event); + if (event & ESPI_EV_RNE) { + tmpdin = in_be32(&espi->rx); + if (num_blks == 0 && num_bytes != 0) { + ch = (unsigned char *)&tmpdin; + while (num_bytes--) + *(unsigned char *)din++ = *ch++; + } else { + *(u32 *) din = tmpdin; + din += 4; + } + + out_be32(&espi->event, in_be32(&espi->event) + | ESPI_EV_RNE); + debug("***spi_xfer:...%08x readed\n", tmpdin); + } + } + if (data_in) { + memcpy(data_in, buffer + 2 * cmd_len, tran_len); + if (*buffer == 0x0b) { + data_in += tran_len; + data_len -= tran_len; + *(int *)buffer += tran_len; + } + } + spi_cs_deactivate(slave); + } + + free(buffer); + return 0; +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs < ESPI_MAX_CS_NUM; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + struct fsl_spi_slave *fsl = to_fsl_spi_slave(slave); + ccsr_espi_t *espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); + unsigned int com = 0; + size_t data_len = fsl->data_len; + + com &= ~(ESPI_COM_CS(0x3) | ESPI_COM_TRANLEN(0xFFFF)); + com |= ESPI_COM_CS(slave->cs); + com |= ESPI_COM_TRANLEN(data_len - 1); + out_be32(&espi->com, com); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + ccsr_espi_t *espi = (void *)(CONFIG_SYS_MPC85xx_ESPI_ADDR); + + /* clear the RXCNT and TXCNT */ + out_be32(&espi->mode, in_be32(&espi->mode) & (~ESPI_MODE_EN)); + out_be32(&espi->mode, in_be32(&espi->mode) | ESPI_MODE_EN); +} diff --git a/include/spi.h b/include/spi.h index 320e50e..1eb31d9 100644 --- a/include/spi.h +++ b/include/spi.h @@ -26,13 +26,6 @@
/* Controller-specific definitions: */
-/* CONFIG_HARD_SPI triggers SPI bus initialization in PowerPC */ -#ifdef CONFIG_MPC8XXX_SPI -# ifndef CONFIG_HARD_SPI -# define CONFIG_HARD_SPI -# endif -#endif - /* SPI mode flags */ #define SPI_CPHA 0x01 /* clock phase */ #define SPI_CPOL 0x02 /* clock polarity */
applied to 85xx
- k
Kumar Gala
Shaohui Xie
