[U-Boot] [U-BOOT PATCH] net: zynq_gem: Add d-cache support
Added d-cache support for zynq_gem.c, Observed a difference of +0.8 MiB/s when downloading a file of size of 3007944Bytes.
With d-cache OFF: ---------------- Filename 'uImage'. Load address: 0x800 Loading: ################################################################# ################################################################# ################################################################# ########## 1.3 MiB/s done Bytes transferred = 3007944 (2de5c8 hex)
With d-cache ON: --------------- Filename 'uImage'. Load address: 0x800 Loading: ################################################################# ################################################################# ################################################################# ########## 2.1 MiB/s done Bytes transferred = 3007944 (2de5c8 hex)
Changes on zynq_gem for d-cache support: - Tx and Rx buffers are cache-aligned - Updated logic for invalidating Rx buffers and flushing Tx buffers. - Tx and Rx BD's are allocated from non-cacheable region. (When BDs are cached, we don't see a consistent link) - Use TX BD status intead of txsr status checks.
Signed-off-by: Srikanth Thokala sthokal@xilinx.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com --- drivers/net/zynq_gem.c | 82 ++++++++++++++++++++++++++++++++------------------ 1 file changed, 53 insertions(+), 29 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 236a753..6a017a8 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -43,11 +43,6 @@ #define ZYNQ_GEM_TXBUF_WRAP_MASK 0x40000000 #define ZYNQ_GEM_TXBUF_LAST_MASK 0x00008000 /* Last buffer */
-#define ZYNQ_GEM_TXSR_HRESPNOK_MASK 0x00000100 /* Transmit hresp not OK */ -#define ZYNQ_GEM_TXSR_URUN_MASK 0x00000040 /* Transmit underrun */ -/* Transmit buffs exhausted mid frame */ -#define ZYNQ_GEM_TXSR_BUFEXH_MASK 0x00000010 - #define ZYNQ_GEM_NWCTRL_TXEN_MASK 0x00000008 /* Enable transmit */ #define ZYNQ_GEM_NWCTRL_RXEN_MASK 0x00000004 /* Enable receive */ #define ZYNQ_GEM_NWCTRL_MDEN_MASK 0x00000010 /* Enable MDIO port */ @@ -90,6 +85,11 @@ */ #define PHY_DETECT_MASK 0x1808
+/* TX BD status masks */ +#define ZYNQ_GEM_TXBUF_FRMLEN_MASK 0x000007ff +#define ZYNQ_GEM_TXBUF_EXHAUSTED 0x08000000 +#define ZYNQ_GEM_TXBUF_UNDERRUN 0x10000000 + /* Device registers */ struct zynq_gem_regs { u32 nwctrl; /* Network Control reg */ @@ -123,12 +123,18 @@ struct emac_bd { };
#define RX_BUF 3 +/* Page table entries are set to 1MB, or multiples of 1MB + * (not < 1MB). driver uses less bd's so use 1MB bdspace. + */ +#define BD_SPACE 0x100000 +/* BD separation space */ +#define BD_SEPRN_SPACE 64
/* Initialized, rxbd_current, rx_first_buf must be 0 after init */ struct zynq_gem_priv { - struct emac_bd tx_bd; - struct emac_bd rx_bd[RX_BUF]; - char rxbuffers[RX_BUF * PKTSIZE_ALIGN]; + struct emac_bd *tx_bd; + struct emac_bd *rx_bd; + char *rxbuffers; u32 rxbd_current; u32 rx_first_buf; int phyaddr; @@ -299,20 +305,18 @@ static int zynq_gem_init(struct eth_device *dev, bd_t * bis) readl(®s->stat[i]);
/* Setup RxBD space */ - memset(&(priv->rx_bd), 0, sizeof(priv->rx_bd)); - /* Create the RxBD ring */ - memset(&(priv->rxbuffers), 0, sizeof(priv->rxbuffers)); + memset(priv->rx_bd, 0, RX_BUF * sizeof(struct emac_bd));
for (i = 0; i < RX_BUF; i++) { priv->rx_bd[i].status = 0xF0000000; priv->rx_bd[i].addr = - (u32)((char *)&(priv->rxbuffers) + + ((u32)(priv->rxbuffers) + (i * PKTSIZE_ALIGN)); } /* WRAP bit to last BD */ priv->rx_bd[--i].addr |= ZYNQ_GEM_RXBUF_WRAP_MASK; /* Write RxBDs to IP */ - writel((u32)&(priv->rx_bd), ®s->rxqbase); + writel((u32)priv->rx_bd, ®s->rxqbase);
/* Setup for DMA Configuration register */ writel(ZYNQ_GEM_DMACR_INIT, ®s->dmacr); @@ -368,32 +372,35 @@ static int zynq_gem_init(struct eth_device *dev, bd_t * bis)
static int zynq_gem_send(struct eth_device *dev, void *ptr, int len) { - u32 status; + u32 addr, size; struct zynq_gem_priv *priv = dev->priv; struct zynq_gem_regs *regs = (struct zynq_gem_regs *)dev->iobase; - const u32 mask = ZYNQ_GEM_TXSR_HRESPNOK_MASK | \ - ZYNQ_GEM_TXSR_URUN_MASK | ZYNQ_GEM_TXSR_BUFEXH_MASK;
/* setup BD */ - writel((u32)&(priv->tx_bd), ®s->txqbase); + writel((u32)priv->tx_bd, ®s->txqbase);
/* Setup Tx BD */ - memset((void *)&(priv->tx_bd), 0, sizeof(struct emac_bd)); + memset(priv->tx_bd, 0, sizeof(struct emac_bd)); + + priv->tx_bd->addr = (u32)ptr; + priv->tx_bd->status = (len & ZYNQ_GEM_TXBUF_FRMLEN_MASK) | + ZYNQ_GEM_TXBUF_LAST_MASK;
- priv->tx_bd.addr = (u32)ptr; - priv->tx_bd.status = len | ZYNQ_GEM_TXBUF_LAST_MASK; + addr = (u32) ptr; + addr &= ~(ARCH_DMA_MINALIGN - 1); + size = roundup(len, ARCH_DMA_MINALIGN); + flush_dcache_range(addr, addr + size); + barrier();
/* Start transmit */ setbits_le32(®s->nwctrl, ZYNQ_GEM_NWCTRL_STARTTX_MASK);
- /* Read the stat register to know if the packet has been transmitted */ - status = readl(®s->txsr); - if (status & mask) - printf("Something has gone wrong here!? Status is 0x%x.\n", - status); + /* Read TX BD status */ + if (priv->tx_bd->status & ZYNQ_GEM_TXBUF_UNDERRUN) + printf("TX underrun\n"); + if (priv->tx_bd->status & ZYNQ_GEM_TXBUF_EXHAUSTED) + printf("TX buffers exhausted in mid frame\n");
- /* Clear Tx status register before leaving . */ - writel(status, ®s->txsr); return 0; }
@@ -416,8 +423,12 @@ static int zynq_gem_recv(struct eth_device *dev)
frame_len = current_bd->status & ZYNQ_GEM_RXBUF_LEN_MASK; if (frame_len) { - NetReceive((u8 *) (current_bd->addr & - ZYNQ_GEM_RXBUF_ADD_MASK), frame_len); + u32 addr = current_bd->addr & ZYNQ_GEM_RXBUF_ADD_MASK; + addr &= ~(ARCH_DMA_MINALIGN - 1); + u32 size = roundup(frame_len, ARCH_DMA_MINALIGN); + invalidate_dcache_range(addr, addr + size); + + NetReceive((u8 *)addr, frame_len);
if (current_bd->status & ZYNQ_GEM_RXBUF_SOF_MASK) priv->rx_first_buf = priv->rxbd_current; @@ -471,6 +482,7 @@ int zynq_gem_initialize(bd_t *bis, int base_addr, int phy_addr, u32 emio) { struct eth_device *dev; struct zynq_gem_priv *priv; + void *bd_space;
dev = calloc(1, sizeof(*dev)); if (dev == NULL) @@ -483,6 +495,18 @@ int zynq_gem_initialize(bd_t *bis, int base_addr, int phy_addr, u32 emio) } priv = dev->priv;
+ /* Align rxbuffers to ARCH_DMA_MINALIGN */ + priv->rxbuffers = memalign(ARCH_DMA_MINALIGN, RX_BUF * PKTSIZE_ALIGN); + memset(priv->rxbuffers, 0, RX_BUF * PKTSIZE_ALIGN); + + /* Align bd_space to 1MB */ + bd_space = memalign(1 << MMU_SECTION_SHIFT, BD_SPACE); + mmu_set_region_dcache_behaviour((u32)bd_space, BD_SPACE, DCACHE_OFF); + + /* Initialize the bd spaces for tx and rx bd's */ + priv->tx_bd = (struct emac_bd *)bd_space; + priv->rx_bd = (struct emac_bd *)((u32)bd_space + BD_SEPRN_SPACE); + priv->phyaddr = phy_addr; priv->emio = emio;
