[PATCH v2] i2c: designware_i2c: adjust timing calculation
In SPL probing of the designware_i2c device on the StarFive VisionFive 2 board fails with
dw_i2c: mode 0, ic_clk 1000000, speed 100000, period 10 rise 1 fall 1 tlow 5 thigh 4 spk 0 dw_i2c: bad counts. hcnt = -4 lcnt = 4 device_probe: i2c@12050000 failed to probe -22
When changing the offset for the high phase from 7 to 3 the device is probed correctly. This now matches the value from the Linux driver.
Without this fix the memory size of the StarFive VisionFive 2 board cannot be read from EEPROM.
Fixes: e71b6f6622d6 ("i2c: designware_i2c: Rewrite timing calculation")
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: use the same timing offset at Linux provide a descriptive comment for the constant --- drivers/i2c/designware_i2c.c | 19 +++++++++++++++---- 1 file changed, 15 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index e54de42abc..215ce010cb 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -24,6 +24,17 @@ */ #define DW_I2C_COMP_TYPE 0x44570140
+/* + * This constant is used to calculate when during the clock high phase the data + * bit shall be read. The value was copied from the Linux v6.5 function + * i2c_dw_scl_hcnt() which provides the following explanation: + * + * "This is just an experimental rule: the tHD;STA period turned out to be + * proportinal to (_HCNT + 3). With this setting, we could meet both tHIGH and + * tHD;STA timing specs." + */ +#define T_HD_STA_OFFSET 3 + static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) { u32 ena = enable ? IC_ENABLE_0B : 0; @@ -155,10 +166,10 @@ static int dw_i2c_calc_timing(struct dw_i2c *priv, enum i2c_speed_mode mode,
/* * Back-solve for hcnt and lcnt according to the following equations: - * SCL_High_time = [(HCNT + IC_*_SPKLEN + 7) * ic_clk] + SCL_Fall_time + * SCL_High_time = [(HCNT + IC_*_SPKLEN + T_HD_STA_OFFSET) * ic_clk] + SCL_Fall_time * SCL_Low_time = [(LCNT + 1) * ic_clk] - SCL_Fall_time + SCL_Rise_time */ - hcnt = min_thigh_cnt - fall_cnt - 7 - spk_cnt; + hcnt = min_thigh_cnt - fall_cnt - T_HD_STA_OFFSET - spk_cnt; lcnt = min_tlow_cnt - rise_cnt + fall_cnt - 1;
if (hcnt < 0 || lcnt < 0) { @@ -170,13 +181,13 @@ static int dw_i2c_calc_timing(struct dw_i2c *priv, enum i2c_speed_mode mode, * Now add things back up to ensure the period is hit. If it is off, * split the difference and bias to lcnt for remainder */ - tot = hcnt + lcnt + 7 + spk_cnt + rise_cnt + 1; + tot = hcnt + lcnt + T_HD_STA_OFFSET + spk_cnt + rise_cnt + 1;
if (tot < period_cnt) { diff = (period_cnt - tot) / 2; hcnt += diff; lcnt += diff; - tot = hcnt + lcnt + 7 + spk_cnt + rise_cnt + 1; + tot = hcnt + lcnt + T_HD_STA_OFFSET + spk_cnt + rise_cnt + 1; lcnt += period_cnt - tot; }
Hello Heinrich,
Many thanks for this update!
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Heinrich,
Applied to u-boot-i2c.git master
Thanks!
bye, Heiko
Heiko Schocher
