Re: [U-Boot] Question: Installing U-Boot on the Karo TX25
On 22/03/2012 15:48, Züger Martin wrote:
Dear Stefano
Hi Martin,
please do not remove the ML when you post an answer. Your experience can be helpful for other people, too.
Thank you very much for your help! I've downloaded u-boot to 0x81200000 like you told me and it works! After that, I used the U-Boot running from RAM to write u-boot-nand.bin to flash. It works too, after a reset RedBoot was gone and U-Boot started.
Fine
The base address where U-Boot is linked to for a specific board, is this always the CONFIG_SYS_NAND_U_BOOT_DST address?
Generally, they can share the same value, but they have different meaning. For TX25, the link address is set in board/karo/tx25/config.mk. However, this is the old way to do things. Currently, CONFIG_SYS_TEXT_BASE (link address) must be set into the board configuration file (tx25.h).
CONFIG_SYS_NAND_U_BOOT_DST tells the first loader (nand_spl) where u-boot code must be copied. If u-boot has a small header that must be also copied, the two address are different. On tx25, they have the same value.
Best regards, Stefano Babic
On Thursday, March 22, 2012 4:06 PM, Stefano Babic wrote:
Hi Martin,
Hello Stefano
Sorry about that, I just hit the replay button and didn't realized that the answer went directly to you instead to the mailing list.
Generally, they can share the same value, but they have different meaning. For TX25, the link address is set in board/karo/tx25/config.mk. However, this is the old way to do things. Currently, CONFIG_SYS_TEXT_BASE (link address) must be set into the board configuration file (tx25.h). CONFIG_SYS_NAND_U_BOOT_DST tells the first loader (nand_spl) where u-boot code must be copied. If u-boot has a small header that must be also copied, the two address are different. On tx25, they have the same value.
Thank you very much for your explanation. I'd like to learn how u-boot works and how a board support package have to be implemented. Probably I'd better choose another board if the BSP of the TX25 uses some deprecated ways.
Best regards, Martin
Stefano Babic
Züger Martin
