[U-Boot] [PATCH 1/2] configs: ti_omap4_common: Include TWL6030 power and I2C support in SPL
This includes the TWL6030 power driver in SPL, to allow powering up MMC devices. This is especially relevant when the bootrom didn't power any MMC device yet but U-Boot is to be loaded from MMC (e.g. after setting boot mode from the SYS_BOOT pins in peripheral boot).
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- include/configs/ti_omap4_common.h | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 5fad3c1..7e08887 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -65,9 +65,7 @@ #define CONFIG_CONS_INDEX 3
/* TWL6030 */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_TWL6030_POWER 1 -#endif
/* USB */ #define CONFIG_USB_MUSB_UDC 1 @@ -162,11 +160,4 @@ #define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ #endif
-#ifdef CONFIG_SPL_BUILD -/* No need for i2c in SPL mode as we will use SRI2C for PMIC access on OMAP4 */ -#undef CONFIG_SYS_I2C -#undef CONFIG_SYS_I2C_OMAP24XX -#undef CONFIG_SPL_I2C_SUPPORT -#endif - #endif /* __CONFIG_TI_OMAP4_COMMON_H */
This adds support for initializing MMC power from TWL6030 in SPL, which is required when the bootrom didn't power the MMC device yet and U-Boot is to be loaded from MMC (e.g. after setting boot mode from the SYS_BOOT pins in peripheral boot).
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/ti/panda/panda.c | 2 +- include/configs/omap4_panda.h | 3 +++ 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 13b5daf..ebab4e7 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -292,12 +292,12 @@ int board_mmc_init(bd_t *bis) { return omap_mmc_init(0, 0, 0, -1, -1); } +#endif
void board_mmc_power_init(void) { twl6030_power_mmc_init(0); } -#endif
#ifdef CONFIG_USB_EHCI
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index ffa22c3..af9ff08 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -33,6 +33,9 @@
#include <configs/ti_omap4_common.h>
+/* MMCSD FS mode is preferred */ +#undef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR + /* GPIO */
/* ENV related config options */
So you're loading SPL via USB? If it's via serial I'd much rather just use the SPL Y-Modem support instead. Also:
[snip]
That's very much not true. Distro boot is usually done with raw mode not FAT.
Right, I'm loading SPL via USB and wish to load u-boot.img via MMC, according to the SYS_BOOT configuration.
This is useful when e.g. only UART Tx is exported from the device.
[snip]
Fair enough. The problem here is that the omap-common bootcode will assume raw mode when reading mmc boot media from SYS_BOOT pins. Raw mode is supposed to fallback to FS mode (which is what I want), but when CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR is defined, it'll go ahead and try to load the image. Even if it reads garbage (no valid header), it'll still go ahead and assume u-boot.bin. In practice, it means that raw mode can never fail as long as CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR is set.
Setting CONFIG_SPL_ABORT_ON_RAW_IMAGE allows properly returning when no valid header is found, but it conflicts with CONFIG_SPL_OS_BOOT.
If setting CONFIG_SPL_ABORT_ON_RAW_IMAGE seems agreeable to you (I don't think anyone cares about u-boot.bin anymore), I could rework the logic there so that there is no longer a conflict with CONFIG_SPL_OS_BOOT.
What do you think?
If nothing calls these functions in SPL they should be gc'd away and we won't get any size increase. So in that case:
Paul Kocialkowski
