[U-Boot] [PATCH V2 0/5] ARM: OMAP: Cleanup save_boot_params function
The save_boot_params function does not store the data in a always writable area. So the code is broken for a 'XIP' boot. This series corrects this by storing it in 'gd' and also adds a 'C' equivalent function for the same. The essential cleanups for the same are added in this.
Tested this on omap5 uevm board with SD/EMMC boot. omap4/5 boards does not have a XIP flash. So yet to test XIP with this series.
Also verfied a MAKEALL for armv7.
Sricharan R (5): ARM: OMAP: Make omap_boot_parameters common across socs ARM: OMAP4/5: Make OMAPx_SRAM_SCRATCH_ defines common ARM: OMAP: Correct save_boot_params and replace with 'C' function ARM: OMAP: Cleanup boot parameters usage ARM: OMAP: Add arch_cpu_init function
arch/arm/cpu/armv7/lowlevel_init.S | 8 +++- arch/arm/cpu/armv7/omap-common/boot-common.c | 20 ++------ arch/arm/cpu/armv7/omap-common/hwinit-common.c | 61 +++++++++++++++++++++--- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 50 +------------------ arch/arm/cpu/armv7/omap4/emif.c | 4 +- arch/arm/cpu/armv7/omap4/hw_data.c | 2 +- arch/arm/cpu/armv7/omap4/hwinit.c | 3 +- arch/arm/cpu/armv7/omap5/emif.c | 4 +- arch/arm/cpu/armv7/omap5/hw_data.c | 2 +- arch/arm/cpu/armv7/omap5/hwinit.c | 3 +- arch/arm/include/asm/arch-am33xx/omap.h | 25 ---------- arch/arm/include/asm/arch-omap4/omap.h | 36 -------------- arch/arm/include/asm/arch-omap4/sys_proto.h | 11 ++--- arch/arm/include/asm/arch-omap5/omap.h | 36 -------------- arch/arm/include/asm/arch-omap5/sys_proto.h | 12 ++--- arch/arm/include/asm/global_data.h | 8 ++++ arch/arm/include/asm/omap_boot.h | 50 +++++++++++++++++++ arch/arm/include/asm/omap_common.h | 19 ++++++++ common/spl/spl.c | 12 +++-- include/configs/am335x_evm.h | 4 ++ include/configs/omap4_common.h | 4 ++ include/configs/omap5_common.h | 3 ++ include/configs/pcm051.h | 4 ++ include/configs/ti814x_evm.h | 4 ++ include/spl.h | 1 - 25 files changed, 187 insertions(+), 199 deletions(-) create mode 100644 arch/arm/include/asm/omap_boot.h
omap_boot_parameters is same and defined for each soc. So move this to a common place to reuse it across socs.
Signed-off-by: Sricharan R r.sricharan@ti.com --- [V2] Rebased on mainline.
arch/arm/include/asm/arch-am33xx/omap.h | 25 ---------------- arch/arm/include/asm/arch-omap4/omap.h | 24 --------------- arch/arm/include/asm/arch-omap5/omap.h | 23 --------------- arch/arm/include/asm/omap_boot.h | 49 +++++++++++++++++++++++++++++++ 4 files changed, 49 insertions(+), 72 deletions(-) create mode 100644 arch/arm/include/asm/omap_boot.h
diff --git a/arch/arm/include/asm/arch-am33xx/omap.h b/arch/arm/include/asm/arch-am33xx/omap.h index d28f9a8..7e3bb9c 100644 --- a/arch/arm/include/asm/arch-am33xx/omap.h +++ b/arch/arm/include/asm/arch-am33xx/omap.h @@ -35,29 +35,4 @@ #define NON_SECURE_SRAM_START 0x40300000 #define NON_SECURE_SRAM_END 0x40320000 #endif - -/* ROM code defines */ -/* Boot device */ -#define BOOT_DEVICE_MASK 0xFF -#define BOOT_DEVICE_OFFSET 0x8 -#define DEV_DESC_PTR_OFFSET 0x4 -#define DEV_DATA_PTR_OFFSET 0x18 -#define BOOT_MODE_OFFSET 0x8 -#define RESET_REASON_OFFSET 0x9 -#define CH_FLAGS_OFFSET 0xA - -#define CH_FLAGS_CHSETTINGS (0x1 << 0) -#define CH_FLAGS_CHRAM (0x1 << 1) -#define CH_FLAGS_CHFLASH (0x1 << 2) -#define CH_FLAGS_CHMMCSD (0x1 << 3) - -#ifndef __ASSEMBLY__ -struct omap_boot_parameters { - char *boot_message; - unsigned int mem_boot_descriptor; - unsigned char omap_bootdevice; - unsigned char reset_reason; - unsigned char ch_flags; -}; -#endif #endif diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index ad984da..9ad1e82 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -155,28 +155,4 @@ struct s32ktimer { #define OMAP4_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) #define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24)
-/* ROM code defines */ -/* Boot device */ -#define BOOT_DEVICE_MASK 0xFF -#define BOOT_DEVICE_OFFSET 0x8 -#define DEV_DESC_PTR_OFFSET 0x4 -#define DEV_DATA_PTR_OFFSET 0x18 -#define BOOT_MODE_OFFSET 0x8 -#define RESET_REASON_OFFSET 0x9 -#define CH_FLAGS_OFFSET 0xA - -#define CH_FLAGS_CHSETTINGS (0x1 << 0) -#define CH_FLAGS_CHRAM (0x1 << 1) -#define CH_FLAGS_CHFLASH (0x1 << 2) -#define CH_FLAGS_CHMMCSD (0x1 << 3) - -#ifndef __ASSEMBLY__ -struct omap_boot_parameters { - char *boot_message; - unsigned int mem_boot_descriptor; - unsigned char omap_bootdevice; - unsigned char reset_reason; - unsigned char ch_flags; -}; -#endif #endif diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 887fcaa..3bf5afa 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -214,21 +214,6 @@ struct s32ktimer { #define OMAP4460_ES1_0 0x44600100 #define OMAP4460_ES1_1 0x44600110
-/* ROM code defines */ -/* Boot device */ -#define BOOT_DEVICE_MASK 0xFF -#define BOOT_DEVICE_OFFSET 0x8 -#define DEV_DESC_PTR_OFFSET 0x4 -#define DEV_DATA_PTR_OFFSET 0x18 -#define BOOT_MODE_OFFSET 0x8 -#define RESET_REASON_OFFSET 0x9 -#define CH_FLAGS_OFFSET 0xA - -#define CH_FLAGS_CHSETTINGS (0x1 << 0) -#define CH_FLAGS_CHRAM (0x1 << 1) -#define CH_FLAGS_CHFLASH (0x1 << 2) -#define CH_FLAGS_CHMMCSD (0x1 << 3) - /* CONTROL_SRCOMP_XXX_SIDE */ #define OVERRIDE_XS_SHIFT 30 #define OVERRIDE_XS_MASK (1 << 30) @@ -249,14 +234,6 @@ struct srcomp_params { s8 multiply_factor; };
-struct omap_boot_parameters { - char *boot_message; - unsigned int mem_boot_descriptor; - unsigned char omap_bootdevice; - unsigned char reset_reason; - unsigned char ch_flags; -}; - struct ctrl_ioregs { u32 ctrl_ddrch; u32 ctrl_lpddr2ch; diff --git a/arch/arm/include/asm/omap_boot.h b/arch/arm/include/asm/omap_boot.h new file mode 100644 index 0000000..87a9530 --- /dev/null +++ b/arch/arm/include/asm/omap_boot.h @@ -0,0 +1,49 @@ +/* + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * Sricharan R r.sricharan@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 +#define DEV_DESC_PTR_OFFSET 0x4 +#define DEV_DATA_PTR_OFFSET 0x18 +#define BOOT_MODE_OFFSET 0x8 +#define RESET_REASON_OFFSET 0x9 +#define CH_FLAGS_OFFSET 0xA + +#define CH_FLAGS_CHSETTINGS (0x1 << 0) +#define CH_FLAGS_CHRAM (0x1 << 1) +#define CH_FLAGS_CHFLASH (0x1 << 2) +#define CH_FLAGS_CHMMCSD (0x1 << 3) + +#ifndef __ASSEMBLY__ +struct omap_boot_parameters { + char *boot_message; + unsigned int mem_boot_descriptor; + unsigned char omap_bootdevice; + unsigned char reset_reason; + unsigned char ch_flags; +}; +#endif
These defines are same across OMAP4/5. So move them to omap_common.h. This is required for the patches that follow.
arch/arm/cpu/armv7/omap4/emif.c | 4 ++-- arch/arm/cpu/armv7/omap4/hw_data.c | 2 +- arch/arm/cpu/armv7/omap4/hwinit.c | 3 ++- arch/arm/cpu/armv7/omap5/emif.c | 4 ++-- arch/arm/cpu/armv7/omap5/hw_data.c | 2 +- arch/arm/cpu/armv7/omap5/hwinit.c | 3 ++- arch/arm/include/asm/arch-omap4/omap.h | 12 ------------ arch/arm/include/asm/arch-omap5/omap.h | 13 ------------- arch/arm/include/asm/omap_common.h | 14 ++++++++++++++ 9 files changed, 24 insertions(+), 33 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index 53f6063..0ddf35f 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -31,8 +31,8 @@ #include <asm/utils.h>
#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS -u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; -u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; +u32 *const T_num = (u32 *)OMAP_SRAM_SCRATCH_EMIF_T_NUM; +u32 *const T_den = (u32 *)OMAP_SRAM_SCRATCH_EMIF_T_DEN; #endif
#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c index 04977b4..06a2fc8 100644 --- a/arch/arm/cpu/armv7/omap4/hw_data.c +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -40,7 +40,7 @@ struct dplls const **dplls_data = struct vcores_data const **omap_vcores = (struct vcores_data const **) OMAP_SRAM_SCRATCH_VCORES_PTR; struct omap_sys_ctrl_regs const **ctrl = - (struct omap_sys_ctrl_regs const **)OMAP4_SRAM_SCRATCH_SYS_CTRL; + (struct omap_sys_ctrl_regs const **)OMAP_SRAM_SCRATCH_SYS_CTRL;
/* * The M & N values in the following tables are created using the diff --git a/arch/arm/cpu/armv7/omap4/hwinit.c b/arch/arm/cpu/armv7/omap4/hwinit.c index 2db517b..81f5a48 100644 --- a/arch/arm/cpu/armv7/omap4/hwinit.c +++ b/arch/arm/cpu/armv7/omap4/hwinit.c @@ -34,10 +34,11 @@ #include <asm/sizes.h> #include <asm/emif.h> #include <asm/arch/gpio.h> +#include <asm/omap_common.h>
DECLARE_GLOBAL_DATA_PTR;
-u32 *const omap_si_rev = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV; +u32 *const omap_si_rev = (u32 *)OMAP_SRAM_SCRATCH_OMAP_REV;
static const struct gpio_bank gpio_bank_44xx[6] = { { (void *)OMAP44XX_GPIO1_BASE, METHOD_GPIO_24XX }, diff --git a/arch/arm/cpu/armv7/omap5/emif.c b/arch/arm/cpu/armv7/omap5/emif.c index 3f37abd..b4c1319 100644 --- a/arch/arm/cpu/armv7/omap5/emif.c +++ b/arch/arm/cpu/armv7/omap5/emif.c @@ -32,8 +32,8 @@
#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS #define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) -static u32 *const T_num = (u32 *)OMAP5_SRAM_SCRATCH_EMIF_T_NUM; -static u32 *const T_den = (u32 *)OMAP5_SRAM_SCRATCH_EMIF_T_DEN; +static u32 *const T_num = (u32 *)OMAP_SRAM_SCRATCH_EMIF_T_NUM; +static u32 *const T_den = (u32 *)OMAP_SRAM_SCRATCH_EMIF_T_DEN; #endif
#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index ced274e..e29803d 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -41,7 +41,7 @@ struct dplls const **dplls_data = struct vcores_data const **omap_vcores = (struct vcores_data const **) OMAP_SRAM_SCRATCH_VCORES_PTR; struct omap_sys_ctrl_regs const **ctrl = - (struct omap_sys_ctrl_regs const **)OMAP5_SRAM_SCRATCH_SYS_CTRL; + (struct omap_sys_ctrl_regs const **)OMAP_SRAM_SCRATCH_SYS_CTRL;
/* OPP HIGH FREQUENCY for ES2.0 */ static const struct dpll_params mpu_dpll_params_1_5ghz[NUM_SYS_CLKS] = { diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index 2f4b247..e93f403 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -37,10 +37,11 @@ #include <asm/utils.h> #include <asm/arch/gpio.h> #include <asm/emif.h> +#include <asm/omap_common.h>
-u32 *const omap_si_rev = (u32 *)OMAP5_SRAM_SCRATCH_OMAP5_REV; +u32 *const omap_si_rev = (u32 *)OMAP_SRAM_SCRATCH_OMAP_REV;
static struct gpio_bank gpio_bank_54xx[6] = { { (void *)OMAP54XX_GPIO1_BASE, METHOD_GPIO_24XX }, diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index 9ad1e82..e9a6ffe 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -143,16 +143,4 @@ struct s32ktimer { #define NON_SECURE_SRAM_END 0x4030E000 /* Not inclusive */ /* base address for indirect vectors (internal boot mode) */ #define SRAM_ROM_VECT_BASE 0x4030D000 -/* Temporary SRAM stack used while low level init is done */ -#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START -/* SRAM scratch space entries */ -#define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR -#define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) -#define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) -#define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) -#define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) -#define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) -#define OMAP4_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) -#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24) - #endif diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 3bf5afa..4f43a90 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -191,19 +191,6 @@ struct s32ktimer { /* base address for indirect vectors (internal boot mode) */ #define SRAM_ROM_VECT_BASE 0x4031F000
-#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START -/* - * SRAM scratch space entries - */ -#define OMAP5_SRAM_SCRATCH_OMAP5_REV SRAM_SCRATCH_SPACE_ADDR -#define OMAP5_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) -#define OMAP5_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) -#define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) -#define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) -#define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) -#define OMAP5_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) -#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24) - /* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF #define OMAP4430_ES1_0 0x44300100 diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 091ddb5..6b70dbb 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -583,4 +583,18 @@ static inline u32 omap_revision(void)
/* DRA7XX */ #define DRA752_ES1_0 0x07520100 + +/* + * SRAM scratch space entries + */ +#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START +#define OMAP_SRAM_SCRATCH_OMAP_REV SRAM_SCRATCH_SPACE_ADDR +#define OMAP_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) +#define OMAP_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) +#define OMAP_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) +#define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) +#define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) +#define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) +#define OMAP_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) +#define OMAP_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24) #endif /* _OMAP_COMMON_H_ */
Currently save_boot_params saves the boot parameters passed from romcode. But this is not stored in a writable location consistently. So the current code would not work for a 'XIP' boot. Change this by saving the boot parameters in 'gd' which is always writable. Also add a 'C' function instead of an assembly code that is more readable.
Signed-off-by: Sricharan R r.sricharan@ti.com --- [V2] Fixed comments and rebased on mainline There is a checkpatch warning because of multiple assignments in the below mainline. gd->arch.omap_boot_params.omap_bootdevice = boot_device = . But the code is better readable this way
arch/arm/cpu/armv7/omap-common/hwinit-common.c | 50 +++++++++++++++++++++--- arch/arm/include/asm/global_data.h | 8 ++++ arch/arm/include/asm/omap_boot.h | 1 + arch/arm/include/asm/omap_common.h | 4 +- 4 files changed, 56 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 70d16a8..c710784 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -101,11 +101,6 @@ void omap_rev_string(void) }
#ifdef CONFIG_SPL_BUILD -static void init_boot_params(void) -{ - boot_params_ptr = (u32 *) &boot_params; -} - void spl_display_print(void) { omap_rev_string(); @@ -116,6 +111,42 @@ void __weak srcomp_enable(void) { }
+static void save_omap_boot_params(void) +{ + u32 rom_params = *((u32 *)OMAP_SRAM_SCRATCH_BOOT_PARAMS); + u8 boot_device; + u32 dev_desc, dev_data; + + if ((rom_params < NON_SECURE_SRAM_START) || + (rom_params > NON_SECURE_SRAM_END)) + return; + + /* + * rom_params can be type casted to omap_boot_parameters and + * used. But it not correct to assume that romcode structure + * encoding would be same as u-boot. So use the defined offsets. + */ + gd->arch.omap_boot_params.omap_bootdevice = boot_device = + *((u8 *)(rom_params + BOOT_DEVICE_OFFSET)); + + gd->arch.omap_boot_params.ch_flags = + *((u8 *)(rom_params + CH_FLAGS_OFFSET)); + + if ((boot_device >= MMC_BOOT_DEVICES_START) && + (boot_device <= MMC_BOOT_DEVICES_END)) { + if ((omap_hw_init_context() == + OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL)) { + gd->arch.omap_boot_params.omap_bootmode = + *((u8 *)(rom_params + BOOT_MODE_OFFSET)); + } else { + dev_desc = *((u32 *)(rom_params + DEV_DESC_PTR_OFFSET)); + dev_data = *((u32 *)(dev_desc + DEV_DATA_PTR_OFFSET)); + gd->arch.omap_boot_params.omap_bootmode = + *((u32 *)(dev_data + BOOT_MODE_OFFSET)); + } + } +} + /* * Routine: s_init * Description: Does early system init of watchdog, muxing, andclocks @@ -132,6 +163,14 @@ void __weak srcomp_enable(void) */ void s_init(void) { + /* + * Save the boot parameters passed from romcode. + * We cannot delay the saving further than this, + * to prevent overwrites. + */ +#ifdef CONFIG_SPL_BUILD + save_omap_boot_params(); +#endif init_omap_revision(); hw_data_init();
@@ -156,7 +195,6 @@ void s_init(void)
/* For regular u-boot sdram_init() is called from dram_init() */ sdram_init(); - init_boot_params(); #endif }
diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 37ac0da..7611d0a 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -24,6 +24,10 @@ #ifndef __ASM_GBL_DATA_H #define __ASM_GBL_DATA_H
+#ifdef CONFIG_OMAP +#include <asm/omap_boot.h> +#endif + /* Architecture-specific global data */ struct arch_global_data { #if defined(CONFIG_FSL_ESDHC) @@ -51,6 +55,10 @@ struct arch_global_data { unsigned long tlb_addr; unsigned long tlb_size; #endif + +#ifdef CONFIG_OMAP + struct omap_boot_parameters omap_boot_params; +#endif };
#include <asm-generic/global_data.h> diff --git a/arch/arm/include/asm/omap_boot.h b/arch/arm/include/asm/omap_boot.h index 87a9530..a803965 100644 --- a/arch/arm/include/asm/omap_boot.h +++ b/arch/arm/include/asm/omap_boot.h @@ -45,5 +45,6 @@ struct omap_boot_parameters { unsigned char omap_bootdevice; unsigned char reset_reason; unsigned char ch_flags; + unsigned long omap_bootmode; }; #endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 6b70dbb..6b73d86 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -596,5 +596,7 @@ static inline u32 omap_revision(void) #define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) #define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) #define OMAP_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) -#define OMAP_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24) +#define OMAP_SRAM_SCRATCH_BOOT_PARAMS (SRAM_SCRATCH_SPACE_ADDR + 0x24) +#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x28) + #endif /* _OMAP_COMMON_H_ */
The boot parameters are read from individual variables assigned for each of them. This been corrected and now they are stored as a part of the global data 'gd' structure. So read them from 'gd' instead.
Signed-off-by: Sricharan R r.sricharan@ti.com --- [V2] Addressed comments and rebased on mainline.
arch/arm/cpu/armv7/lowlevel_init.S | 8 +++- arch/arm/cpu/armv7/omap-common/boot-common.c | 31 +++++++-------- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 50 +----------------------- arch/arm/include/asm/arch-omap4/sys_proto.h | 11 ++---- arch/arm/include/asm/arch-omap5/sys_proto.h | 12 ++---- arch/arm/include/asm/omap_common.h | 3 ++ common/spl/spl.c | 10 ++--- include/configs/am335x_evm.h | 1 + include/configs/pcm051.h | 1 + include/configs/ti814x_evm.h | 1 + include/spl.h | 1 - 11 files changed, 38 insertions(+), 91 deletions(-)
diff --git a/arch/arm/cpu/armv7/lowlevel_init.S b/arch/arm/cpu/armv7/lowlevel_init.S index 0d45528..0a15aa4 100644 --- a/arch/arm/cpu/armv7/lowlevel_init.S +++ b/arch/arm/cpu/armv7/lowlevel_init.S @@ -37,7 +37,13 @@ ENTRY(lowlevel_init) */ ldr sp, =CONFIG_SYS_INIT_SP_ADDR bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - +#ifdef CONFIG_SPL_BUILD + ldr r8, =gdata +#else + sub sp, #GD_SIZE + bic sp, sp, #7 + mov r8, sp +#endif /* * Save the old lr(passed in ip) and the current lr to stack */ diff --git a/arch/arm/cpu/armv7/omap-common/boot-common.c b/arch/arm/cpu/armv7/omap-common/boot-common.c index 24cbe2d..bff7e9c 100644 --- a/arch/arm/cpu/armv7/omap-common/boot-common.c +++ b/arch/arm/cpu/armv7/omap-common/boot-common.c @@ -23,31 +23,17 @@ #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h>
-/* - * This is used to verify if the configuration header - * was executed by rom code prior to control of transfer - * to the bootloader. SPL is responsible for saving and - * passing the boot_params pointer to the u-boot. - */ -struct omap_boot_parameters boot_params __attribute__ ((section(".data"))); +DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_SPL_BUILD -/* - * We use static variables because global data is not ready yet. - * Initialized data is available in SPL right from the beginning. - * We would not typically need to save these parameters in regular - * U-Boot. This is needed only in SPL at the moment. - */ -u32 omap_bootmode = MMCSD_MODE_FAT; - u32 spl_boot_device(void) { - return (u32) (boot_params.omap_bootdevice); + return (u32) (gd->arch.omap_boot_params.omap_bootdevice); }
u32 spl_boot_mode(void) { - return omap_bootmode; + return gd->arch.omap_boot_params.omap_bootmode; }
void spl_board_init(void) @@ -73,4 +59,15 @@ int board_mmc_init(bd_t *bis) } return 0; } + +void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) +{ + typedef void __noreturn (*image_entry_noargs_t)(u32 *); + image_entry_noargs_t image_entry = + (image_entry_noargs_t) spl_image->entry_point; + + debug("image entry point: 0x%X\n", spl_image->entry_point); + /* Pass the saved boot_params from rom code */ + image_entry((u32 *)&gd->arch.omap_boot_params); +} #endif diff --git a/arch/arm/cpu/armv7/omap-common/lowlevel_init.S b/arch/arm/cpu/armv7/omap-common/lowlevel_init.S index 90b3c8a..c489536 100644 --- a/arch/arm/cpu/armv7/omap-common/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap-common/lowlevel_init.S @@ -28,59 +28,13 @@
#include <config.h> #include <asm/arch/omap.h> +#include <asm/omap_common.h> #include <asm/arch/spl.h> #include <linux/linkage.h>
ENTRY(save_boot_params) - /* - * See if the rom code passed pointer is valid: - * It is not valid if it is not in non-secure SRAM - * This may happen if you are booting with the help of - * debugger - */ - ldr r2, =NON_SECURE_SRAM_START - cmp r2, r0 - bgt 1f - ldr r2, =NON_SECURE_SRAM_END - cmp r2, r0 - blt 1f - - /* - * store the boot params passed from rom code or saved - * and passed by SPL - */ - cmp r0, #0 - beq 1f - ldr r1, =boot_params + ldr r1, =OMAP_SRAM_SCRATCH_BOOT_PARAMS str r0, [r1] -#ifdef CONFIG_SPL_BUILD - /* Store the boot device in spl_boot_device */ - ldrb r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device - and r2, #BOOT_DEVICE_MASK - ldr r3, =boot_params - strb r2, [r3, #BOOT_DEVICE_OFFSET] @ spl_boot_device <- r1 - - /* - * boot mode is only valid for device that can be raw or FAT booted. - * in other cases it may be fatal to look. While platforms differ - * in the values used for each MMC slot, they are contiguous. - */ - cmp r2, #MMC_BOOT_DEVICES_START - blt 2f - cmp r2, #MMC_BOOT_DEVICES_END - bgt 2f - /* Store the boot mode (raw/FAT) in omap_bootmode */ - ldr r2, [r0, #DEV_DESC_PTR_OFFSET] @ get the device descriptor ptr - ldr r2, [r2, #DEV_DATA_PTR_OFFSET] @ get the pDeviceData ptr - ldr r2, [r2, #BOOT_MODE_OFFSET] @ get the boot mode - ldr r3, =omap_bootmode - str r2, [r3] -#endif -2: - ldrb r2, [r0, #CH_FLAGS_OFFSET] - ldr r3, =boot_params - strb r2, [r3, #CH_FLAGS_OFFSET] -1: bx lr ENDPROC(save_boot_params)
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index d5f1868..841388a 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -27,6 +27,8 @@ #include <asm/omap_common.h> #include <asm/arch/mux_omap4.h>
+DECLARE_GLOBAL_DATA_PTR; + struct omap_sysinfo { char *board_string; }; @@ -58,13 +60,6 @@ void omap_vc_init(u16 speed_khz); int omap_vc_bypass_send_value(u8 sa, u8 reg_addr, u8 reg_data); u32 warm_reset(void); void force_emif_self_refresh(void); -/* - * This is used to verify if the configuration header - * was executed by Romcode prior to control of transfer - * to the bootloader. SPL is responsible for saving and - * passing this to the u-boot. - */ -extern struct omap_boot_parameters boot_params;
static inline u32 running_from_sdram(void) { @@ -84,7 +79,7 @@ static inline u8 uboot_loaded_by_spl(void) * variable by both SPL and u-boot.Check out for CHSETTINGS, which is a * mandatory section if CH is present. */ - if ((boot_params.ch_flags) & (CH_FLAGS_CHSETTINGS)) + if ((gd->arch.omap_boot_params.ch_flags) & (CH_FLAGS_CHSETTINGS)) return 0; else return running_from_sdram(); diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index e66ab44..1099ec3 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -27,6 +27,8 @@ #include <asm/omap_common.h> #include <asm/arch/clocks.h>
+DECLARE_GLOBAL_DATA_PTR; + struct pad_conf_entry { u32 offset; u32 val; @@ -65,14 +67,6 @@ void force_emif_self_refresh(void); void get_ioregs(const struct ctrl_ioregs **regs); void srcomp_enable(void);
-/* - * This is used to verify if the configuration header - * was executed by Romcode prior to control of transfer - * to the bootloader. SPL is responsible for saving and - * passing this to the u-boot. - */ -extern struct omap_boot_parameters boot_params; - static inline u32 running_from_sdram(void) { u32 pc; @@ -91,7 +85,7 @@ static inline u8 uboot_loaded_by_spl(void) * variable by both SPL and u-boot.Check out for CHSETTINGS, which is a * mandatory section if CH is present. */ - if ((boot_params.ch_flags) & (CH_FLAGS_CHSETTINGS)) + if ((gd->arch.omap_boot_params.ch_flags) & (CH_FLAGS_CHSETTINGS)) return 0; else return running_from_sdram(); diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 6b73d86..9db4b1b 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,8 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+#ifndef __ASSEMBLY__ + #include <common.h>
#define NUM_SYS_CLKS 8 @@ -557,6 +559,7 @@ static inline u32 omap_revision(void) extern u32 *const omap_si_rev; return *omap_si_rev; } +#endif
/* * silicon revisions. diff --git a/common/spl/spl.c b/common/spl/spl.c index 6715e0d..e6aa89b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -125,17 +125,13 @@ void spl_parse_image_header(const struct image_header *header)
__weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { - typedef void __noreturn (*image_entry_noargs_t)(u32 *); + typedef void __noreturn (*image_entry_noargs_t)(void); + image_entry_noargs_t image_entry = (image_entry_noargs_t) spl_image->entry_point;
debug("image entry point: 0x%X\n", spl_image->entry_point); - /* Pass the saved boot_params from rom code */ -#if defined(CONFIG_VIRTIO) || defined(CONFIG_ZEBU) - image_entry = (image_entry_noargs_t)0x80100000; -#endif - u32 boot_params_ptr_addr = (u32)&boot_params_ptr; - image_entry((u32 *)boot_params_ptr_addr); + image_entry(); }
#ifdef CONFIG_SPL_RAM_DEVICE diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ef00306..ddfd52e 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -17,6 +17,7 @@ #define __CONFIG_AM335X_EVM_H
#define CONFIG_AM33XX +#define CONFIG_OMAP
diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index d0ea74e..5e5fab1 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -20,6 +20,7 @@ #define __CONFIG_PCM051_H
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 16547e3..68a7307 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -19,6 +19,7 @@ #define CONFIG_TI81XX #define CONFIG_TI814X #define CONFIG_SYS_NO_FLASH +#define CONFIG_OMAP
diff --git a/include/spl.h b/include/spl.h index b40be80..4bc1dd1 100644 --- a/include/spl.h +++ b/include/spl.h @@ -44,7 +44,6 @@ struct spl_image_info { #define SPL_COPY_PAYLOAD_ONLY 1
extern struct spl_image_info spl_image; -extern u32 *boot_params_ptr;
/* SPL common functions */ void preloader_console_init(void);
With the following change, applied to u-boot-ti/master, thanks!
diff --git a/include/configs/igep0033.h b/include/configs/igep0033.h index 50eafdf..14063a8 100644 --- a/include/configs/igep0033.h +++ b/include/configs/igep0033.h @@ -15,6 +15,7 @@ #define __CONFIG_IGEP0033_H
The boot parameters passed from SPL to UBOOT must be saved as a part of uboot's gd data as early as possible, before we will inadvertently overwrite it. So adding a arch_cpu_init for the required Socs to save it.
arch/arm/cpu/armv7/omap-common/hwinit-common.c | 11 +++++++++++ include/configs/am335x_evm.h | 3 +++ include/configs/omap4_common.h | 4 ++++ include/configs/omap5_common.h | 3 +++ include/configs/pcm051.h | 3 +++ include/configs/ti814x_evm.h | 3 +++ 6 files changed, 27 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index c710784..1645120 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -147,6 +147,17 @@ static void save_omap_boot_params(void) } }
+#ifdef CONFIG_ARCH_CPU_INIT +/* + * SOC specific cpu init + */ +int arch_cpu_init(void) +{ + save_omap_boot_params(); + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + /* * Routine: s_init * Description: Does early system init of watchdog, muxing, andclocks diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ddfd52e..e5da51c 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -296,6 +296,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 110, 300, 600, 1200, 2400, \ 4800, 9600, 14400, 19200, 28800, 38400, 56000, 57600, 115200 }
+/* CPU */ +#define CONFIG_ARCH_CPU_INIT + #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_SYS_CONSOLE_INFO_QUIET
diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index 1fd3097..2871d87 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -87,6 +87,10 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} + +/* CPU */ +#define CONFIG_ARCH_CPU_INIT + /* I2C */ #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 diff --git a/include/configs/omap5_common.h b/include/configs/omap5_common.h index c21c387..32c113e 100644 --- a/include/configs/omap5_common.h +++ b/include/configs/omap5_common.h @@ -86,6 +86,9 @@
+/* CPU */ +#define CONFIG_ARCH_CPU_INIT + /* I2C */ #define CONFIG_HARD_I2C #define CONFIG_SYS_I2C_SPEED 100000 diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 5e5fab1..9614f70 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -195,6 +195,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 110, 300, 600, 1200, 2400, \ 4800, 9600, 14400, 19200, 28800, 38400, 56000, 57600, 115200 }
+/* CPU */ +#define CONFIG_ARCH_CPU_INIT + #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_CONSOLE_INFO_QUIET
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 68a7307..8ba1e1b 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -163,6 +163,9 @@
+/* CPU */ +#define CONFIG_ARCH_CPU_INIT + #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_CONSOLE_INFO_QUIET
diff --git a/include/configs/igep0033.h b/include/configs/igep0033.h index 50eafdf..38a2755 100644 --- a/include/configs/igep0033.h +++ b/include/configs/igep0033.h @@ -156,6 +156,9 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200
Tom,
Does this look ok, go to get in ?
Regards, Sricharan
On Wed, May 08, 2013 at 02:50:14PM +0530, Sricharan R wrote:
Tom,
With the posted changes to 4 and 5 (for platforms that are new to u-boot-ti/master), applied, thanks for the reminder!
Hi Tom,
Tom,
Thanks for it !!
Regards, Sricharan
OK, do you have a beaglebone or am335x_evm around? This switch up breaks them, and I'm not sure what's going on. Part of the issue is that the NON_SECURE_SRAM_START/END weren't quite right, but they weren't so wrong as to be a problem (END wasn't quite the end, and start was in the middle of our image, but we didn't reference it). I'm going to keep poking at this as well. Thanks!
Answered my own question now, am33xx (andti81xx) doesn't opt-in for omap-common/hwinit-common.c
Hi Tom,
Ok, Thanks for the pointer. So i will add this in the series. and boot test once on am33xx
Regards, Sricharan
On Monday 03 June 2013 11:39 AM, Sricharan R wrote:
Hi Tom,
Ok, you have already addressed this . Thanks a lot..
Regards, Sricharan
Sricharan R
