[PATCH v2] dfu: mtd: mark bad the MTD block on erase error
In the MTD DFU backend, it is needed to mark the NAND block bad when the erase failed with the -EIO error, as it is done in UBI and JFFS2 code.
This operation is not done in the MTD framework, but the bad block tag (in BBM or in BBT) is required to avoid to write data on this block in the next DFU_OP_WRITE loop in mtd_block_op(): the code skip the bad blocks, tested by mtd_block_isbad().
Without this patch, when the NAND block become bad on DFU write operation - low probability on new NAND - the DFU write operation will always failed because the failing block is never marked bad.
This patch also adds a test to avoid to request an erase operation on a block already marked bad; this test is not performed in MTD framework in mtd_erase().
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
Changes in v2: - fixe mtd_block_isbad offset parameter for erase check - Add trace when bad block are skipped in erase loop - Add remaining byte in trace "Limit reached"
drivers/dfu/dfu_mtd.c | 32 ++++++++++++++++++++++---------- 1 file changed, 22 insertions(+), 10 deletions(-)
diff --git a/drivers/dfu/dfu_mtd.c b/drivers/dfu/dfu_mtd.c index c7075f12eca9..a4a3e91be23e 100644 --- a/drivers/dfu/dfu_mtd.c +++ b/drivers/dfu/dfu_mtd.c @@ -86,27 +86,39 @@ static int mtd_block_op(enum dfu_op op, struct dfu_entity *dfu,
while (remaining) { if (erase_op.addr + remaining > lim) { - printf("Limit reached 0x%llx while erasing at offset 0x%llx\n", - lim, off); + printf("Limit reached 0x%llx while erasing at offset 0x%llx, remaining 0x%llx\n", + lim, erase_op.addr, remaining); return -EIO; }
+ /* Skip the block if it is bad, don't erase it again */ + if (mtd_block_isbad(mtd, erase_op.addr)) { + printf("Skipping bad block at 0x%08llx\n", + erase_op.addr); + erase_op.addr += mtd->erasesize; + continue; + } + ret = mtd_erase(mtd, &erase_op);
if (ret) { - /* Abort if its not a bad block error */ - if (ret != -EIO) { - printf("Failure while erasing at offset 0x%llx\n", - erase_op.fail_addr); - return 0; + /* If this is not -EIO, we have no idea what to do. */ + if (ret == -EIO) { + printf("Marking bad block at 0x%08llx (%d)\n", + erase_op.fail_addr, ret); + ret = mtd_block_markbad(mtd, erase_op.addr); + } + /* Abort if it is not -EIO or can't mark bad */ + if (ret) { + printf("Failure while erasing at offset 0x%llx (%d)\n", + erase_op.fail_addr, ret); + return ret; } - printf("Skipping bad block at 0x%08llx\n", - erase_op.addr); } else { remaining -= mtd->erasesize; }
- /* Continue erase behind bad block */ + /* Continue erase behind the current block */ erase_op.addr += mtd->erasesize; } }
Hi
On Fri, Jun 2, 2023 at 3:23 PM Patrick Delaunay patrick.delaunay@foss.st.com wrote:
Changes in v2:
lim, off);
This can be in a different change
return -EIO; }
erase_op.addr);
This print is wrong. If ret is 1 it's a bad block if it's 2 the block is reserved
continue;
ret = mtd_erase(mtd, &erase_op); if (ret) {
if (ret != -EIO) {
if (ret == -EIO) {
if (ret) {
return ret; }
Otherwise Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
-- 2.25.1
On 6/2/23 17:27, Michael Nazzareno Trimarchi wrote:
Hi
Changes in v2:
ok
return -EIO; }
Ok
I did the same trace than
drivers/mtd/nand/raw/nand_util.c:nand_erase_opts()
cmd/mtd.c:do_mtd_bad()
but on old branch before you commits
d9fa61f54e7f9a ("mtd: nand: Show reserved block in chip.erase")
cfb82f7c123e4 ("mtd: nand: Mark reserved blocks")
thanks to point it, I prepare a V3
- erase_op.addr += mtd->erasesize;
+ continue; + }
- erase_op.fail_addr, ret);
-- 2.25.1
Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Patrick DELAUNAY
Patrick Delaunay
