[PATCH v2] tee: optee: sync cache on pre-reloc OP-TEE invocation
This change ensures both U-Boot and OP-TEE see the same content from shared memory when OP-TEE is invoked prior U-Boot relocation.
This change is required since U-Boot may execute with data cahce off while OP-TEE always enables cache on memory shared with U-Boot.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- Changes since v1: - Fix invocation argument buffer size in optee/core.c, using OPTEE_MSG_GET_ARG_SIZE(). - add missing #include <asm/cache.h> in tee-uclass.c --- drivers/tee/optee/core.c | 21 ++++++++++++++++++++- drivers/tee/tee-uclass.c | 19 ++++++++++++++++++- include/tee.h | 6 ++++++ 3 files changed, 44 insertions(+), 2 deletions(-)
diff --git a/drivers/tee/optee/core.c b/drivers/tee/optee/core.c index 73dbb22ba0..dad46aa388 100644 --- a/drivers/tee/optee/core.c +++ b/drivers/tee/optee/core.c @@ -1,9 +1,10 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (c) 2018 Linaro Limited + * Copyright (c) 2018-2020 Linaro Limited */
#include <common.h> +#include <cpu_func.h> #include <dm.h> #include <dm/device_compat.h> #include <log.h> @@ -295,6 +296,16 @@ static u32 call_err_to_res(u32 call_err) } }
+static void flush_shm_dcache(struct udevice *dev, struct optee_msg_arg *arg) +{ + size_t sz = OPTEE_MSG_GET_ARG_SIZE(arg->num_params); + + flush_dcache_range(rounddown((ulong)arg, CONFIG_SYS_CACHELINE_SIZE), + roundup((ulong)arg + sz, CONFIG_SYS_CACHELINE_SIZE)); + + tee_flush_all_shm_dcache(dev); +} + static u32 do_call_with_arg(struct udevice *dev, struct optee_msg_arg *arg) { struct optee_pdata *pdata = dev_get_plat(dev); @@ -305,9 +316,17 @@ static u32 do_call_with_arg(struct udevice *dev, struct optee_msg_arg *arg) while (true) { struct arm_smccc_res res;
+ /* If cache are off from U-Boot, sync the cache shared with OP-TEE */ + if (!dcache_status()) + flush_shm_dcache(dev, arg); + pdata->invoke_fn(param.a0, param.a1, param.a2, param.a3, param.a4, param.a5, param.a6, param.a7, &res);
+ /* If cache are off from U-Boot, sync the cache shared with OP-TEE */ + if (!dcache_status()) + flush_shm_dcache(dev, arg); + free(page_list); page_list = NULL;
diff --git a/drivers/tee/tee-uclass.c b/drivers/tee/tee-uclass.c index 2cc6b6c407..24321ba1d2 100644 --- a/drivers/tee/tee-uclass.c +++ b/drivers/tee/tee-uclass.c @@ -1,13 +1,15 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (c) 2018 Linaro Limited + * Copyright (c) 2018-2020 Linaro Limited */
#include <common.h> +#include <cpu_func.h> #include <dm.h> #include <log.h> #include <malloc.h> #include <tee.h> +#include <asm/cache.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h>
@@ -233,3 +235,18 @@ void tee_optee_ta_uuid_to_octets(u8 d[TEE_UUID_LEN], d[7] = s->time_hi_and_version; memcpy(d + 8, s->clock_seq_and_node, sizeof(s->clock_seq_and_node)); } + +void tee_flush_all_shm_dcache(struct udevice *dev) +{ + struct tee_uclass_priv *priv = dev_get_uclass_priv(dev); + struct tee_shm *s; + + list_for_each_entry(s, &priv->list_shm, link) { + ulong start = rounddown((ulong)s->addr, + CONFIG_SYS_CACHELINE_SIZE); + ulong end = roundup((ulong)s->addr + s->size, + CONFIG_SYS_CACHELINE_SIZE); + + flush_dcache_range(start, end); + } +} diff --git a/include/tee.h b/include/tee.h index 99367b258e..2ef29bfc8f 100644 --- a/include/tee.h +++ b/include/tee.h @@ -377,4 +377,10 @@ void tee_optee_ta_uuid_from_octets(struct tee_optee_ta_uuid *d, void tee_optee_ta_uuid_to_octets(u8 d[TEE_UUID_LEN], const struct tee_optee_ta_uuid *s);
+/** + * tee_flush_all_shm_dcache() - Flush data cache for all shared memories + * @dev: The TEE device + */ +void tee_flush_all_shm_dcache(struct udevice *dev); + #endif /* __TEE_H */
On Wed, May 19, 2021 at 4:28 PM Etienne Carriere etienne.carriere@linaro.org wrote:
cache
Changes since v1:
With the spell error in the commit message fixed: Reviewed-by: Jens Wiklander jens.wiklander@linaro.org
Cheers, Jens
Changes since v1:
- Copyright (c) 2018 Linaro Limited
- Copyright (c) 2018-2020 Linaro Limited
- size_t sz = OPTEE_MSG_GET_ARG_SIZE(arg->num_params);
- flush_dcache_range(rounddown((ulong)arg, CONFIG_SYS_CACHELINE_SIZE),
- tee_flush_all_shm_dcache(dev);
- struct tee_uclass_priv *priv = dev_get_uclass_priv(dev);
- struct tee_shm *s;
- list_for_each_entry(s, &priv->list_shm, link) {
- tee_flush_all_shm_dcache() - Flush data cache for all shared memories
- @dev: The TEE device
2.17.1
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
This change is required since U-Boot may execute with data cache off while OP-TEE always enables cache on memory shared with U-Boot.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org Reviewed-by: Jens Wiklander jens.wiklander@linaro.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Etienne Carriere
Ilias Apalodimas
Jens Wiklander
