[U-Boot] [PATCH 2/6] mips: ath79: ap121: Enable ethernet
This patch enable network function for ap121 board.
Signed-off-by: Wills Wang wills.wang@live.com Acked-by: Marek Vasut marex@denx.de ---
arch/mips/dts/ap121.dts | 5 +++++ arch/mips/dts/ar933x.dtsi | 4 ++-- board/qca/ap121/ap121.c | 2 ++ configs/ap121_defconfig | 9 +++++++-- 4 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/arch/mips/dts/ap121.dts b/arch/mips/dts/ap121.dts index e31f601..a934a58 100644 --- a/arch/mips/dts/ap121.dts +++ b/arch/mips/dts/ap121.dts @@ -41,3 +41,8 @@ reg = <0>; }; }; + +&gmac0 { + phy-mode = "rmii"; + status = "okay"; +}; diff --git a/arch/mips/dts/ar933x.dtsi b/arch/mips/dts/ar933x.dtsi index 00896b2..971f13e 100644 --- a/arch/mips/dts/ar933x.dtsi +++ b/arch/mips/dts/ar933x.dtsi @@ -75,7 +75,7 @@ };
gmac0: eth@0x19000000 { - compatible = "qca,ag7240-mac"; + compatible = "qca,ag933x-mac"; reg = <0x19000000 0x200>; phy = <&phy0>; phy-mode = "rmii"; @@ -92,7 +92,7 @@ };
gmac1: eth@0x1a000000 { - compatible = "qca,ag7240-mac"; + compatible = "qca,ag933x-mac"; reg = <0x1a000000 0x200>; phy = <&phy0>; phy-mode = "rgmii"; diff --git a/board/qca/ap121/ap121.c b/board/qca/ap121/ap121.c index d6c60fe..e245faa 100644 --- a/board/qca/ap121/ap121.c +++ b/board/qca/ap121/ap121.c @@ -10,6 +10,7 @@ #include <asm/types.h> #include <mach/ar71xx_regs.h> #include <mach/ddr.h> +#include <mach/ath79.h> #include <debug_uart.h>
DECLARE_GLOBAL_DATA_PTR; @@ -46,5 +47,6 @@ int board_early_init_f(void) debug_uart_init(); #endif ddr_init(); + ath79_eth_reset(); return 0; } diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index 7604e2e..91fa734 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -19,8 +19,13 @@ CONFIG_SYS_PROMPT="ap121 # " CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set +CONFIG_CMD_NET=y +CONFIG_CMD_NFS=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_ETH=y +CONFIG_AG7XXX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_ATMEL=y
Am 30.05.2016 um 16:54 schrieb Wills Wang:
applied to u-boot-mips, thanks!
Daniel Schwierzeck
Wills Wang
