[PATCH] riscv: ae350: Increase malloc size for binman spl flow
It will need larger heap size for u-boot-spl to load u-boot.itb which be generated from binman than USE_SPL_FIT_GENERATOR.
Signed-off-by: Rick Chen rick@andestech.com --- configs/ae350_rv32_spl_defconfig | 1 + configs/ae350_rv32_spl_xip_defconfig | 1 + configs/ae350_rv64_spl_defconfig | 1 + configs/ae350_rv64_spl_xip_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index 25b4ada..e8dc816 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -2,6 +2,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x01200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_TARGET_AX25_AE350=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index c5d7ac3..418170c 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -2,6 +2,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x01200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="ae350_32" diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 61637a9..d23b56c 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -2,6 +2,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x01200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_TARGET_AX25_AE350=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index 6c63382..7826ae4 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -2,6 +2,7 @@ CONFIG_RISCV=y CONFIG_SYS_TEXT_BASE=0x01200000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="ae350_64"
This patch seems not to apply on current u-boot/master.
But anyways, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Andes
Bin Meng
