[PATCH] ARM: dts: stm32: Configure Buck3 voltage per PMIC NVM on Avenger96
The Avenger96 board comes in multiple regulator configurations. - rev.100 or rev.200 have Buck3 preconfigured to 3V3 operation on boot and contains extra Enpirion EP53A8LQI DCDC converter which supplies the IO. Reduce Buck3 voltage to 2V9 to not waste power. - rev.200L have Buck3 preconfigured to 1V8 operation and have no Enpirion EP53A8LQI DCDC anymore, the IO is supplied from Buck3.
Configure the Buck3 voltage on this board per PMIC NVM settings and update buck3 voltage limits in DT passed to OS before booting OS to prevent potential hardware damage.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi | 2 +- board/dhelectronics/dh_stm32mp1/board.c | 109 +++++++++++++++++++++- 2 files changed, 107 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi index 9937b28548c..e20917824bf 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi @@ -19,7 +19,7 @@ };
&vdd { - regulator-min-microvolt = <2900000>; + regulator-min-microvolt = <1800000>; regulator-max-microvolt = <2900000>; };
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 67273f90992..d407f0bf592 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -594,14 +594,98 @@ static void board_init_fmc2(void) setbits_le32(STM32_FMC2_BASE + STM32_FMC2_BCR1, STM32_FMC2_BCRx_FMCEN); }
+#ifdef CONFIG_DM_REGULATOR +#define STPMIC_NVM_BUCKS_VOUT_SHR 0xfc +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V2 0 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V8 1 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V0 2 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3 3 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_MASK GENMASK(1, 0) +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_OFFSET(n) ((((n) - 1) & 3) * 2) +static int board_get_regulator_buck3_nvm_uv_av96(int *uv) +{ + const void *fdt = gd->fdt_blob; + struct udevice *dev; + u8 bucks_vout = 0; + const char *prop; + int len, ret; + + /* Check whether this is Avenger96 board. */ + prop = fdt_getprop(fdt, 0, "compatible", &len); + if (!prop || !len) + return -ENODEV; + + if (!strstr(prop, "avenger96")) + return -EINVAL; + + /* Read out STPMIC1 NVM and determine default Buck3 voltage. */ + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(stpmic1_nvm), + &dev); + if (ret) + return ret; + + ret = misc_read(dev, STPMIC_NVM_BUCKS_VOUT_SHR, &bucks_vout, 1); + if (ret != 1) + return -EINVAL; + + bucks_vout >>= STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_OFFSET(3); + bucks_vout &= STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_MASK; + + /* + * Avenger96 board comes in multiple regulator configurations: + * - rev.100 or rev.200 have Buck3 preconfigured to 3V3 operation on + * boot and contains extra Enpirion EP53A8LQI DCDC converter which + * supplies the IO. Reduce Buck3 voltage to 2V9 to not waste power. + * - rev.200L have Buck3 preconfigured to 1V8 operation and have no + * Enpirion EP53A8LQI DCDC anymore, the IO is supplied from Buck3. + */ + if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3) + *uv = 2900000; + else + *uv = 1800000; + + return 0; +} + +static void board_init_regulator_av96(void) +{ + struct udevice *rdev; + int ret, uv; + + ret = board_get_regulator_buck3_nvm_uv_av96(&uv); + if (ret) /* Not Avenger96 board. */ + return; + + ret = regulator_get_by_devname("buck3", &rdev); + if (ret) + return; + + /* Adjust Buck3 per preconfigured PMIC voltage from NVM. */ + regulator_set_value(rdev, uv); +} + +static void board_init_regulator(void) +{ + board_init_regulator_av96(); + + regulators_enable_boot_on(_DEBUG); +} +#else +static inline int board_get_regulator_buck3_nvm_uv_av96(int *uv) +{ + return -EINVAL; +} + +static inline void board_init_regulator(void) {} +#endif + /* board dependent setup after realloc */ int board_init(void) { board_key_check();
-#ifdef CONFIG_DM_REGULATOR - regulators_enable_boot_on(_DEBUG); -#endif + board_init_regulator();
sysconf_init();
@@ -721,6 +805,25 @@ int board_interface_eth_init(struct udevice *dev, #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { + const char *buck3path = "/soc/i2c@5c002000/stpmic@33/regulators/buck3"; + int buck3off, ret, uv; + + ret = board_get_regulator_buck3_nvm_uv_av96(&uv); + if (ret) /* Not Avenger96 board, do not patch Buck3 in DT. */ + return 0; + + buck3off = fdt_path_offset(blob, buck3path); + if (buck3off < 0) /* No Buck3 regulator found. */ + return 0; + + ret = fdt_setprop_u32(blob, buck3off, "regulator-min-microvolt", uv); + if (ret < 0) + return ret; + + ret = fdt_setprop_u32(blob, buck3off, "regulator-max-microvolt", uv); + if (ret < 0) + return ret; + return 0; } #endif
&vdd {http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...
- regulator-min-microvolt = <1800000>; regulator-max-microvolt = <2900000>; };
+#ifdef CONFIG_DM_REGULATOR +#define STPMIC_NVM_BUCKS_VOUT_SHR http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... 0xfc +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V2 0 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V8 1 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V0 2 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3 3 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_MASK GENMASK(1, 0) +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_OFFSET(n) ((((n) - 1) & 3) * 2) +static int board_get_regulator_buck3_nvm_uv_av96(int *uv) +{
- const void *fdt = gd->fdt_blob;
- struct udevice *dev;
- u8 bucks_vout = 0;
- const char *prop;
- int len, ret;
- /* Check whether this is Avenger96 board. */
- prop = fdt_getprop(fdt, 0, "compatible", &len);
This API is not compatible with CONFIG_OF_LIVE
consider replacement with ofnode_read_prop or with of_machine_is_compatible, for example
if (!of_machine_is_compatible(prop, "arrow,stm32mp15xx-avenger96")) return -EINVAL;
See also http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...
- if (!prop || !len)
return -ENODEV;
- if (!strstr(prop, "avenger96"))
return -EINVAL;
- /* Read out STPMIC1 NVM and determine default Buck3 voltage. */
- ret = uclass_get_device_by_driver(UCLASS_MISC,
&dev);
- if (ret)
return ret;
- ret = misc_read(dev, STPMIC_NVM_BUCKS_VOUT_SHR, &bucks_vout, 1);
- if (ret != 1)
return -EINVAL;
- bucks_vout >>= STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_OFFSET(3);
- bucks_vout &= STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_MASK;
* Enpirion EP53A8LQI DCDC anymore, http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725e965f1476b26412ed1e8329aa9ba98@changeid/the IO is supplied from Buck3.
- if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3)
*uv = 2900000;
- else
*uv = 1800000;
- struct udevice *rdev;
- int ret, uv;
- ret = board_get_regulator_buck3_nvm_uv_av96(&uv);
- if (ret) /* Not Avenger96 board. */
return;
- ret = regulator_get_by_devname("buck3", &rdev);
- if (ret)
return;
- /* Adjust Buck3 per preconfigured PMIC voltage from NVM. */
- regulator_set_value(rdev, uv);
- board_init_regulator_av96();
- regulators_enable_boot_on(_DEBUG);http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...
- return -EINVAL;
- /* board dependent setup after realloc */ int board_init(void) { board_key_check(); http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...
-#endif
sysconf_init();
- const char *buck3path = "/soc/i2c@5c002000/stpmic@33/regulators/buck3";
- int buck3off, ret, uv;
- ret = board_get_regulator_buck3_nvm_uvhttp://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...);
- if (ret) /* Not Avenger96 board, do not patch Buck3 in DT. */
- buck3off = fdt_path_offset(blob, buck3path);
- if (buck3off < 0) /* No Buck3 regulator found. */
- ret = fdt_setprop_u32(blob, buck3off, "regulator-min-microvolt", uv);
- if (ret < 0)
return ret;
- ret = fdt_setprop_u32(blob, buck3off, "regulator-max-microvolt", uv);
- if (ret < 0)
return ret;
+http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... return 0; } #endif
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
I explicitly don't want to use of_machine_is_compatible, I need to search for the avenger96 substring in the machine compatible, since the stm32mp15xx can be anything (15{1,3,7}{a,d}) and it might not even have the arrow prefix.
Ok, I check on existing DT and I found only on compatible with "avenger96" string.
arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts:15:
compatible = "arrow,stm32mp15xx-avenger96", "st,stm32mp15x";
But you can forget my proposal with of_machine_is_compatible, consider:
prop = ofnode_read_prop(ofnode_root(), "compatible", &len);
But it is just minor remark.
Do you expect this patch for next pull-request for v2022.07 or for next ?
Patrick
There are multiple other fdt_getprop() calls in both board/st/ and board/dh , maybe if you want to do OF_LIVE enablement (do you?), let's convert them all at once ?
Ideally 2022.07.
Ok. It is more a minor remark linked to checkpatch warning for all the added code:
"Use the livetree API (dev_read_...)"
I let you handle OF_LIVE for your boards (code & defconfig),
FYI: it is already enable for STMicroelectronics boards (defconfig and in driver, mach-stm32mp and board code).
Ideally 2022.07.
Ok, I plan that.
Patrick
But look:
c387e626147 ("Merge branch '2022-05-11-Kconfig-cleanups-etc'") with this patch:
u-boot$ git grep fdt_getprop.*comp board/dhelectronics/dh_stm32mp1/*c board/st/stm32mp1/*c board/dhelectronics/dh_stm32mp1/board.c: fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", board/dhelectronics/dh_stm32mp1/board.c: compat = fdt_getprop(gd->fdt_blob, 0, "compatible", NULL); board/dhelectronics/dh_stm32mp1/board.c: fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible",
board/st/stm32mp1/stm32mp1.c: fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", board/st/stm32mp1/stm32mp1.c: fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible",
Am I missing a patch or something ?
Ideally 2022.07.
Ok, I plan that.
Thank you
> +static int board_get_regulator_buck3_nvm_uv_av96(int *uv) > +{ > + const void *fdt = gd->fdt_blob; > + struct udevice *dev; > + u8 bucks_vout = 0; > + const char *prop; > + int len, ret; > + > + /* Check whether this is Avenger96 board. */ > + prop = fdt_getprop(fdt, 0, "compatible", &len);
But look:
No, it is my fault, I forget these references....
I prepare a serie to solve this issue in STMicroelectronics Boards code.
Ideally 2022.07.
Ok, I plan that.
Thank you
regards
Patrick
But look:
Hehe, glad I could help you spot it.
You can prepare very much identical series for DH and CC me on it, the changes will be very much the same and I can test the result just fine.
Hi
But look:
Applied to u-boot-stm/master, thanks!
And RFC serie to activate OF_LIVE is:
http://patchwork.ozlabs.org/project/uboot/list/?series=301157&state=*
[RFC,1/2] board: dhelectronics: stm32mp1: convert to livetree
[RFC,2/2] ARM: stm32: activate OF_LIVE for DHSOM
Regards Patrick
diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi index 9937b28548c..e20917824bf 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi @@ -19,7 +19,7 @@ }; &vdd {http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... - regulator-min-microvolt = <2900000>; + regulator-min-microvolt = <1800000>; regulator-max-microvolt = <2900000>; }; diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 67273f90992..d407f0bf592 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -594,14 +594,98 @@ static void board_init_fmc2(void) setbits_le32(STM32_FMC2_BASE + STM32_FMC2_BCR1, STM32_FMC2_BCRx_FMCEN); } +#ifdef CONFIG_DM_REGULATOR +#define STPMIC_NVM_BUCKS_VOUT_SHR http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... 0xfc +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V2 0 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V8 1 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V0 2 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3 3 +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_MASK GENMASK(1, 0) +#define STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_OFFSET(n) ((((n) - 1) & 3)
+ /* + * Avenger96 board comes in multiple regulator configurations: + * - rev.100 or rev.200 have Buck3 preconfigured to 3V3 operation on + * boot and contains extra Enpirion EP53A8LQI DCDC converter which + * supplies the IO. Reduce Buck3 voltage to 2V9 to not waste power. + * - rev.200L have Buck3 preconfigured to 1V8 operation and have no + * Enpirion EP53A8LQI DCDC anymore, http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... IO is supplied from Buck3. + */ + if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3) + *uv = 2900000; + else + *uv = 1800000;
+ return 0; +}
regulators_enable_boot_on(_DEBUG);http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... +} +#else +static inline int board_get_regulator_buck3_nvm_uv_av96(int *uv) +{ + return -EINVAL; +}
/* board dependent setup after realloc */ int board_init(void) { board_key_check(); http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725... -#ifdef CONFIG_DM_REGULATOR - regulators_enable_boot_on(_DEBUG); -#endif + board_init_regulator(); sysconf_init(); @@ -721,6 +805,25 @@ int board_interface_eth_init(struct udevice *dev, #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { + const char *buck3path = "/soc/i2c@5c002000/stpmic@33/regulators/buck3"; + int buck3off, ret, uv;
+ ret = board_get_regulator_buck3_nvm_uvhttp://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...); + if (ret) /* Not Avenger96 board, do not patch Buck3 in DT. */ + return 0;
+ ret = fdt_setprop_u32(blob, buck3off, "regulator-max-microvolt", uv); + if (ret < 0) + return ret; +http://patchwork.ozlabs.org/project/uboot/patch/20220517143655.1.I4d61d5a725...
return 0; } #endif
Thanks Patrick
Regards Patrick
Patrick DELAUNAY
