[PATCH] arm: mach-k3: am625_init: Add Erratum WA for RTC startup
Add erratum i2327 work around for initialization for RTC interrupt where interrupt is stuck for ever at startup. Unfortunately, this workaround needs to be applied under 1 second of boot.
Signed-off-by: Nishanth Menon nm@ti.com [bb@ti.com: rebased from 2021.01] Signed-off-by: Bryan Brattlof bb@ti.com --- arch/arm/mach-k3/am625_init.c | 44 +++++++++++++++++++++++++++++++++++ 1 file changed, 44 insertions(+)
diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index a91c15ca4e188..e90c18fdcc118 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -15,6 +15,15 @@ #include <dm/uclass-internal.h> #include <dm/pinctrl.h>
+#define RTC_BASE_ADDRESS 0x2b1f0000 +#define REG_K3RTC_S_CNT_LSW (RTC_BASE_ADDRESS + 0x18) +#define REG_K3RTC_KICK0 (RTC_BASE_ADDRESS + 0x70) +#define REG_K3RTC_KICK1 (RTC_BASE_ADDRESS + 0x74) + +/* Magic values for lock/unlock */ +#define K3RTC_KICK0_UNLOCK_VALUE 0x83e70b13 +#define K3RTC_KICK1_UNLOCK_VALUE 0x95a4f1e0 + /* * This uninitialized global variable would normal end up in the .bss section, * but the .bss is cleared between writing and reading this variable, so move @@ -71,6 +80,40 @@ static __maybe_unused void enable_mcu_esm_reset(void) writel(stat, CTRLMMR_MCU_RST_CTRL); }
+#if defined(CONFIG_CPU_V7R) + +/* + * RTC Erratum i2327 Workaround + * Due to a bug in initial synchronization out of cold power on, + * IRQ status can get locked infinitely if we do not: + * a) unlock RTC + * + * This workaround *must* be applied within 1 second of power on, + * So, this is closest point to be able to guarantee the max + * timing. + */ +void rtc_erratumi2327_init(void) +{ + u32 counter; + + /* + * If counter has gone past 1, nothing we can do, leave + * system locked! This is the only way we know if RTC + * can be used for all practical purposes. + */ + counter = readl(REG_K3RTC_S_CNT_LSW); + if (counter > 1) + return; + /* + * Need to set this up at the very start + * MUST BE DONE under 1 second of boot. + */ + writel(K3RTC_KICK0_UNLOCK_VALUE, REG_K3RTC_KICK0); + writel(K3RTC_KICK1_UNLOCK_VALUE, REG_K3RTC_KICK1); + return; +} +#endif + void board_init_f(ulong dummy) { struct udevice *dev; @@ -78,6 +121,7 @@ void board_init_f(ulong dummy)
#if defined(CONFIG_CPU_V7R) setup_k3_mpu_regions(); + rtc_erratumi2327_init(); #endif
base-commit: a25dcda452bf6a6de72764a8d990d72e5def643d
It will be good to state in the diffstat that am62a7 or other k3 SoCs are not impacted: am62a7 has the hardware fix and other SoCs do not have this rtc.
I dont think there is a need to respin the patch for that - just clarifying.
- This uninitialized global variable would normal end up in the .bss section,
- but the .bss is cleared between writing and reading this variable, so move
- RTC Erratum i2327 Workaround
- Due to a bug in initial synchronization out of cold power on,
- IRQ status can get locked infinitely if we do not:
- a) unlock RTC
- This workaround *must* be applied within 1 second of power on,
- So, this is closest point to be able to guarantee the max
- timing.
- u32 counter;
- counter = readl(REG_K3RTC_S_CNT_LSW);
- if (counter > 1)
return;
- writel(K3RTC_KICK0_UNLOCK_VALUE, REG_K3RTC_KICK0);
- writel(K3RTC_KICK1_UNLOCK_VALUE, REG_K3RTC_KICK1);
- return;
+} +#endif
- rtc_erratumi2327_init();
#endif
2.40.0
Bryan Brattlof
Nishanth Menon
