[U-Boot] [PATCH v2] powerpc/fsl-pci: Determine pci_controller based on cfg addr for dts fixup
Previously we passed in a specifically named struct pci_controller to determine if we had setup the particular PCI bus. Now we can search for the struct so we dont have to depend on the name or the struct being statically allocated.
Introduced new find_hose_by_cfg_addr() to get back a pci_controller struct back by searching for it means we can do things like dynamically allocate them or not have to expose the static structures to all users.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Merged with find_hose_by_cfg_addr patch * Fixed find_hose_by_cfg_addr to have { } for multiline for
arch/powerpc/include/asm/fsl_pci.h | 43 ++--------------------------------- drivers/pci/fsl_pci_init.c | 5 +++- drivers/pci/pci.c | 12 ++++++++++ include/pci.h | 1 + 4 files changed, 20 insertions(+), 41 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_pci.h b/arch/powerpc/include/asm/fsl_pci.h index dc5c579..ab0f3ee 100644 --- a/arch/powerpc/include/asm/fsl_pci.h +++ b/arch/powerpc/include/asm/fsl_pci.h @@ -29,8 +29,7 @@ int fsl_setup_hose(struct pci_controller *hose, unsigned long addr); int fsl_is_pci_agent(struct pci_controller *hose); void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data); void fsl_pci_config_unlock(struct pci_controller *hose); -void ft_fsl_pci_setup(void *blob, const char *pci_compat, - struct pci_controller *hose, unsigned long ctrl_addr); +void ft_fsl_pci_setup(void *blob, const char *compat, unsigned long ctrl_addr);
/* * Common PCI/PCIE Register structure for mpc85xx and mpc86xx @@ -203,54 +202,18 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, }
#define __FT_FSL_PCI_SETUP(blob, compat, num) \ - ft_fsl_pci_setup(blob, compat, &pci##num##_hose, \ - CONFIG_SYS_PCI##num##_ADDR) - -#define __FT_FSL_PCI_DEL(blob, compat, num) \ - ft_fsl_pci_setup(blob, compat, NULL, CONFIG_SYS_PCI##num##_ADDR) + ft_fsl_pci_setup(blob, compat, CONFIG_SYS_PCI##num##_ADDR)
#define __FT_FSL_PCIE_SETUP(blob, compat, num) \ - ft_fsl_pci_setup(blob, compat, &pcie##num##_hose, \ - CONFIG_SYS_PCIE##num##_ADDR) - -#define __FT_FSL_PCIE_DEL(blob, compat, num) \ - ft_fsl_pci_setup(blob, compat, NULL, CONFIG_SYS_PCIE##num##_ADDR) + ft_fsl_pci_setup(blob, compat, CONFIG_SYS_PCIE##num##_ADDR)
-#ifdef CONFIG_PCI1 #define FT_FSL_PCI1_SETUP __FT_FSL_PCI_SETUP(blob, FSL_PCI_COMPAT, 1) -#else -#define FT_FSL_PCI1_SETUP __FT_FSL_PCI_DEL(blob, FSL_PCI_COMPAT, 1) -#endif - -#ifdef CONFIG_PCI2 #define FT_FSL_PCI2_SETUP __FT_FSL_PCI_SETUP(blob, FSL_PCI_COMPAT, 2) -#else -#define FT_FSL_PCI2_SETUP __FT_FSL_PCI_DEL(blob, FSL_PCI_COMPAT, 2) -#endif
-#ifdef CONFIG_PCIE1 #define FT_FSL_PCIE1_SETUP __FT_FSL_PCIE_SETUP(blob, FSL_PCIE_COMPAT, 1) -#else -#define FT_FSL_PCIE1_SETUP __FT_FSL_PCIE_DEL(blob, FSL_PCIE_COMPAT, 1) -#endif - -#ifdef CONFIG_PCIE2 #define FT_FSL_PCIE2_SETUP __FT_FSL_PCIE_SETUP(blob, FSL_PCIE_COMPAT, 2) -#else -#define FT_FSL_PCIE2_SETUP __FT_FSL_PCIE_DEL(blob, FSL_PCIE_COMPAT, 2) -#endif - -#ifdef CONFIG_PCIE3 #define FT_FSL_PCIE3_SETUP __FT_FSL_PCIE_SETUP(blob, FSL_PCIE_COMPAT, 3) -#else -#define FT_FSL_PCIE3_SETUP __FT_FSL_PCIE_DEL(blob, FSL_PCIE_COMPAT, 3) -#endif - -#ifdef CONFIG_PCIE4 #define FT_FSL_PCIE4_SETUP __FT_FSL_PCIE_SETUP(blob, FSL_PCIE_COMPAT, 4) -#else -#define FT_FSL_PCIE4_SETUP __FT_FSL_PCIE_DEL(blob, FSL_PCIE_COMPAT, 4) -#endif
#if defined(CONFIG_FSL_CORENET) #define FSL_PCIE_COMPAT "fsl,p4080-pcie" diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 5b34dcb..71ab02b 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -518,11 +518,14 @@ void fsl_pci_config_unlock(struct pci_controller *hose) #include <fdt_support.h>
void ft_fsl_pci_setup(void *blob, const char *pci_compat, - struct pci_controller *hose, unsigned long ctrl_addr) + unsigned long ctrl_addr) { int off; u32 bus_range[2]; phys_addr_t p_ctrl_addr = (phys_addr_t)ctrl_addr; + struct pci_controller *hose; + + hose = find_hose_by_cfg_addr((void *)(ctrl_addr));
/* convert ctrl_addr to true physical address */ p_ctrl_addr = (phys_addr_t)ctrl_addr - CONFIG_SYS_CCSRBAR; diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 702ac67..cdfc4fb 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -165,6 +165,18 @@ struct pci_controller *pci_bus_to_hose (int bus) return NULL; }
+struct pci_controller *find_hose_by_cfg_addr(void *cfg_addr) +{ + struct pci_controller *hose; + + for (hose = hose_head; hose; hose = hose->next) { + if (hose->cfg_addr == cfg_addr) + return hose; + } + + return NULL; +} + int pci_last_busno(void) { struct pci_controller *hose = hose_head; diff --git a/include/pci.h b/include/pci.h index c456006..e80b6bd 100644 --- a/include/pci.h +++ b/include/pci.h @@ -511,6 +511,7 @@ extern int pci_hose_write_config_word_via_dword(struct pci_controller *hose, extern void *pci_map_bar(pci_dev_t pdev, int bar, int flags); extern void pci_register_hose(struct pci_controller* hose); extern struct pci_controller* pci_bus_to_hose(int bus); +extern struct pci_controller *find_hose_by_cfg_addr(void *cfg_addr);
extern int pci_hose_scan(struct pci_controller *hose); extern int pci_hose_scan_bus(struct pci_controller *hose, int bus);
Dear Kumar Gala,
In message 1294183251-4905-1-git-send-email-galak@kernel.crashing.org you wrote:
- Merged with find_hose_by_cfg_addr patch
- Fixed find_hose_by_cfg_addr to have { } for multiline for
Acked-by: Wolfgang Denk wd@denx.de
On Jan 9, 2011, at 2:01 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
applied to 85xx
- k
Kumar Gala
