[U-Boot] [PATCH] env: Setup GD_FLG_ENV_DEFAULT flag when default environment are used
Setup flag when default environment are used to be able to rewrite default distro boot variables based on SoC boot mode.
I didn't find any way how to detect that default or saved variables are used. I want to have a flag to be able to rewrite boot_targets variable based on boot mode. Especially when SD boot mode is setup than SD should be primary boot devices, etc. When variables are saved boot_targets will be restored and SoC boot mode will be ignored. If you know better way how to do it, please let me know.
--- common/env_common.c | 1 + include/asm-generic/global_data.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/common/env_common.c b/common/env_common.c index af59c72e1fd7..13db7dc3f755 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -123,6 +123,7 @@ void set_default_env(const char *s) error("Environment import failed: errno = %d\n", errno);
gd->flags |= GD_FLG_ENV_READY; + gd->flags |= GD_FLG_ENV_DEFAULT; }
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index f2810a1bd75f..0abcbe4c0b3a 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -141,5 +141,6 @@ typedef struct global_data { #define GD_FLG_SPL_INIT 0x00400 /* spl_init() has been called */ #define GD_FLG_SKIP_RELOC 0x00800 /* Don't relocate */ #define GD_FLG_RECORD 0x01000 /* Record console */ +#define GD_FLG_ENV_DEFAULT 0x02000 /* Default variable flag */
#endif /* __ASM_GENERIC_GBL_DATA_H */
You may want to be able to do the same from inside a script, so I guess we should better have this as an environment variable itself again.
There was a way to have environment variable reads return a value directly from code rather than go via environment storage. I guess we could expose the flag through that?
Or add an environment variable that we set in set_default_env() and ignore that variable on saveenv. I'm not sure I like that option better than your current one though.
Alex
- gd->flags |= GD_FLG_ENV_DEFAULT; }
Was there any environment in past?
If you expose environment variable and then run saveenv this variable will be saved and restored again and your script behaves the same.
Yes this should work but sounds pretty hacky.
Just and example of usage which I have tested on ZynqMP. Based on bootmode different boot_targets are setup and this setting is blocked for saved environment detected via this flag.
Thanks, Michal
224 int board_late_init(void) 225 { 226 u32 reg = 0; 227 u8 bootmode; 228 229 if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { 230 debug("Saved variables - Skipping\n"); 231 return 0; 232 } 233 234 reg = readl(&crlapb_base->boot_mode); 235 bootmode = reg & BOOT_MODES_MASK; 236 237 puts("Bootmode: "); 238 switch (bootmode) { 239 case JTAG_MODE: 240 puts("JTAG_MODE\n"); 241 setenv("boot_targets", "pxe dhcp"); 242 break; 243 case QSPI_MODE_24BIT: 244 case QSPI_MODE_32BIT: 245 setenv("boot_targets", "qspi0"); 246 puts("QSPI_MODE\n"); 247 break; 248 case EMMC_MODE: 249 puts("EMMC_MODE\n"); 250 setenv("boot_targets", "mmc0 mmc1"); 251 break; 252 case SD_MODE: 253 puts("SD_MODE\n"); 254 setenv("boot_targets", "mmc0 mmc1"); 255 break; 256 case SD_MODE1: 257 puts("SD_MODE1\n"); 258 setenv("boot_targets", "mmc0 mmc1"); 259 break; 260 case NAND_MODE: 261 puts("NAND_MODE\n"); 262 setenv("boot_targets", "nand0"); 263 break; 264 default: 265 printf("Invalid Boot Mode:0x%x\n", bootmode); 266 break; 267 } 268 269 return 0; 270 }
Am 31.05.2016 um 07:04 schrieb Michal Simek michal.simek@xilinx.com:
On 05/30/2016 04:11 PM, Michal Simek wrote: Setup flag when default environment are used to be able to rewrite default distro boot variables based on SoC boot mode.
With again I meant "from C as well as from script".
Not if we declare the environment variable read as callback ;).
Alex
What do you mean?
It is kind of interesting that this is not done already for others SoCs when you want to use distro config. :-)
Cheers, Michal
What do you mean?
Meh, apparently I misremembered.
Well, there's always a first :).
Either way, I guess your patch is perfectly fine as a first step. It would be nice to also introduce some way for scripts to evaluate whether the environment is the default environment, but we can always add that later.
Alex
What do you mean?
Does this mean your Acked-by line?
Cheers, Michal
> On 05/30/2016 04:11 PM, Michal Simek wrote: > Setup flag when default environment are used to be able to > rewrite default distro boot variables based on SoC boot mode. > > Signed-off-by: Michal Simek michal.simek@xilinx.com > --- > > I didn't find any way how to detect that default or saved variables are > used. I want to have a flag to be able to rewrite boot_targets variable > based on boot mode. Especially when SD boot mode is setup than SD should > be primary boot devices, etc. > When variables are saved boot_targets will be restored and SoC boot mode > will be ignored. > If you know better way how to do it, please let me know.
What do you mean?
Reviewed-by: Alexander Graf agraf@suse.de
(IIRC Reviewed-by is stronger than Acked-by)
Alex
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Alexander Graf agraf@suse.de
... yes, this was already in via Michal's tree, it didn't get applied twice, I just didn't delete it from my bundle.
Alexander Graf
Michal Simek
