[U-Boot-Users] [PATCH 04/18] include/configs: Use new CONFIG_CMD_* in various D* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/DASA_SIM.h | 26 ++++++--------- include/configs/DB64360.h | 29 +++++++++------- include/configs/DB64460.h | 29 +++++++++------- include/configs/DK1C20.h | 76 ++++++++++++++++++++++---------------------- include/configs/DK1S10.h | 73 +++++++++++++++++++++--------------------- include/configs/DP405.h | 29 +++++++++------- include/configs/DU405.h | 29 +++++++++------- 7 files changed, 148 insertions(+), 143 deletions(-)
diff --git a/include/configs/DASA_SIM.h b/include/configs/DASA_SIM.h index 997e1ba..b1638ce 100644 --- a/include/configs/DASA_SIM.h +++ b/include/configs/DASA_SIM.h @@ -57,32 +57,26 @@ #define CONFIG_IPADDR 10.0.18.222 #define CONFIG_SERVERIP 10.0.18.190
-#if 0 -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_IRQ | \ - CFG_CMD_BSP | \ - CFG_CMD_ASKENV | \ - CFG_CMD_ELF ) -#else -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_BSP ) -#endif + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +
#if 0 /* Does not appear to be used?! If it is used, needs to be fixed */ #define CONFIG_SOFT_I2C /* Software I2C support enabled */ #endif #define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -184,7 +178,7 @@ */ #define CFG_DCACHE_SIZE 2048 /* For PLX IOP480 */ #define CFG_CACHELINE_SIZE 16 /* For AMCC 401/403 CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/DB64360.h b/include/configs/DB64360.h index bd7aff1..f7e1c4d 100644 --- a/include/configs/DB64360.h +++ b/include/configs/DB64360.h @@ -239,17 +239,20 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" #define MTDPARTS_DEFAULT "mtdparts=db64360-1:-(jffs2)" */
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_ASKENV \ - | CFG_CMD_I2C \ - | CFG_CMD_EEPROM \ - | CFG_CMD_CACHE \ - | CFG_CMD_JFFS2 \ - | CFG_CMD_PCI \ - | CFG_CMD_NET ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +
/* * Miscellaneous configurable options @@ -261,7 +264,7 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" /* #define CFG_GT_DUAL_CPU also for JTAG even with one cpu */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -558,7 +561,7 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For all MPC74xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/DB64460.h b/include/configs/DB64460.h index 4b72e9b..8cba0b2 100644 --- a/include/configs/DB64460.h +++ b/include/configs/DB64460.h @@ -177,17 +177,20 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" #define MTDPARTS_DEFAULT "mtdparts=db64460-1:-(jffs2)" */
/* * Miscellaneous configurable options @@ -199,7 +202,7 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" /* #define CFG_GT_DUAL_CPU also for JTAG even with one cpu */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -496,7 +499,7 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For all MPC74xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/DK1C20.h b/include/configs/DK1C20.h index b58846d..c3bd2cb 100644 --- a/include/configs/DK1C20.h +++ b/include/configs/DK1C20.h @@ -446,46 +446,46 @@ #define CONFIG_NIOS_ASMI /* Enable ASMI */ #define CFG_NIOS_ASMIBASE CFG_NIOS_CPU_ASMI0 /* ASMI base address */
-/*------------------------------------------------------------------------ - * COMMANDS - *----------------------------------------------------------------------*/ -#define CONFIG_COMMANDS (CFG_CMD_ALL & ~( \ - CFG_CMD_ASKENV | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_BMP | \ - CFG_CMD_BSP | \ - CFG_CMD_CACHE | \ - CFG_CMD_DATE | \ - CFG_CMD_DOC | \ - CFG_CMD_DTT | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_FDC | \ - CFG_CMD_FDOS | \ - CFG_CMD_HWFLOW | \ - CFG_CMD_I2C | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_KGDB | \ - CFG_CMD_NAND | \ - CFG_CMD_NFS | \ - CFG_CMD_MMC | \ - CFG_CMD_MII | \ - CFG_CMD_PCI | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_REISER | \ - CFG_CMD_SCSI | \ - CFG_CMD_SPI | \ - CFG_CMD_VFD | \ - CFG_CMD_USB | \ - CFG_CMD_XIMG ) ) - - -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_all.h> + +#undef CONFIG_CMD_ASKENV +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_BMP +#undef CONFIG_CMD_BSP +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_DATE +#undef CONFIG_CMD_DOC +#undef CONFIG_CMD_DTT +#undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_ELF +#undef CONFIG_CMD_FDC +#undef CONFIG_CMD_FDOS +#undef CONFIG_CMD_HWFLOW +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_JFFS2 +#undef CONFIG_CMD_KGDB +#undef CONFIG_CMD_NAND +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_MMC +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PCI +#undef CONFIG_CMD_PCMCIA +#undef CONFIG_CMD_REISER +#undef CONFIG_CMD_SCSI +#undef CONFIG_CMD_SPI +#undef CONFIG_CMD_VFD +#undef CONFIG_CMD_USB +#undef CONFIG_CMD_XIMG +
/*------------------------------------------------------------------------ * COMPACT FLASH *----------------------------------------------------------------------*/ -#if (CONFIG_COMMANDS & CFG_CMD_IDE) +#if defined(CONFIG_CMD_IDE) #define CONFIG_IDE_PREINIT /* Implement id_preinit */ #define CFG_IDE_MAXBUS 1 /* 1 IDE bus */ #define CFG_IDE_MAXDEVICE 1 /* 1 drive per IDE bus */ @@ -503,12 +503,12 @@ #define CFG_CF_POWER 0x009209c0 /* CF Power FET PIO base*/ #define CFG_CF_ATASEL 0x009209d0 /* CF ATASEL PIO base */
-#endif /* CONFIG_COMMANDS & CFG_CMD_IDE */ +#endif
/*------------------------------------------------------------------------ * KGDB *----------------------------------------------------------------------*/ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 9600 #endif
diff --git a/include/configs/DK1S10.h b/include/configs/DK1S10.h index 3e3803c..a5530a6 100644 --- a/include/configs/DK1S10.h +++ b/include/configs/DK1S10.h @@ -454,47 +454,46 @@
#endif /* CFG_NIOS_CPU_PIO_NUMS */
-/*------------------------------------------------------------------------ - * COMMANDS - *----------------------------------------------------------------------*/ -#define CONFIG_COMMANDS (CFG_CMD_ALL & ~( \ - CFG_CMD_ASKENV | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_BMP | \ - CFG_CMD_BSP | \ - CFG_CMD_CACHE | \ - CFG_CMD_DATE | \ - CFG_CMD_DOC | \ - CFG_CMD_DTT | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_FAT | \ - CFG_CMD_FDC | \ - CFG_CMD_FDOS | \ - CFG_CMD_HWFLOW | \ - CFG_CMD_IDE | \ - CFG_CMD_I2C | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_KGDB | \ - CFG_CMD_NAND | \ - CFG_CMD_NFS | \ - CFG_CMD_MMC | \ - CFG_CMD_MII | \ - CFG_CMD_PCI | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_SCSI | \ - CFG_CMD_SPI | \ - CFG_CMD_VFD | \ - CFG_CMD_USB | \ - CFG_CMD_XIMG ) ) - - -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_all.h> + +#undef CONFIG_CMD_ASKENV +#undef COND_CMD_BEDBUG +#undef COND_CMD_BMP +#undef COND_CMD_BSP +#undef COND_CMD_CACHE +#undef COND_CMD_DATE +#undef COND_CMD_DOC +#undef COND_CMD_DTT +#undef COND_CMD_EEPROM +#undef COND_CMD_ELF +#undef COND_CMD_FAT +#undef COND_CMD_FDC +#undef COND_CMD_FDOS +#undef COND_CMD_HWFLOW +#undef COND_CMD_IDE +#undef COND_CMD_I2C +#undef COND_CMD_JFFS2 +#undef COND_CMD_KGDB +#undef COND_CMD_NAND +#undef COND_CMD_NFS +#undef COND_CMD_MMC +#undef COND_CMD_MII +#undef COND_CMD_PCI +#undef COND_CMD_PCMCIA +#undef COND_CMD_SCSI +#undef COND_CMD_SPI +#undef COND_CMD_VFD +#undef COND_CMD_USB +#undef COND_CMD_XIMG +
diff --git a/include/configs/DP405.h b/include/configs/DP405.h index 2ae794d..b50d4f9 100644 --- a/include/configs/DP405.h +++ b/include/configs/DP405.h @@ -55,17 +55,20 @@ #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_PHY_ADDR 0 /* PHY address */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_BSP | \ - CFG_CMD_DHCP | \ - CFG_CMD_IRQ | \ - CFG_CMD_ELF | \ - CFG_CMD_DATE | \ - CFG_CMD_I2C | \ - CFG_CMD_EEPROM ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ELF +#define CONFIG_CMD_DATE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +
#undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -87,7 +90,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -235,7 +238,7 @@ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ /* have only 8kB, 16kB is save here */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/DU405.h b/include/configs/DU405.h index 5489a53..2093b37 100644 --- a/include/configs/DU405.h +++ b/include/configs/DU405.h @@ -58,21 +58,24 @@ #define CONFIG_PHY_ADDR 0 /* PHY address */ #define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_IDE | \ - CFG_CMD_ELF | \ - CFG_CMD_MII | \ - CFG_CMD_DATE | \ - CFG_CMD_EEPROM ) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_IDE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MII +#define CONFIG_CMD_DATE +#define CONFIG_CMD_EEPROM +
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - #undef CONFIG_WATCHDOG /* watchdog disabled */
#define CONFIG_RTC_MC146818 /* BQ3285 is MC146818 compatible*/ @@ -85,7 +88,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -225,7 +228,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
Jon Loeliger
