[U-Boot] [PATCH] board/ti/am335x: beaglebone stop muxing i2c1_pin_mux
On the BeagleBone these i2c1 pins are routed to the expanasion header, where they can be defined as either pr1_usart0_Xxd/pwm0/spi0/i2c1, dont assume i2c1
Fixes: https://e2e.ti.com/support/arm/sitara_arm/f/791/p/313894/1387696
Signed-off-by: Robert Nelson robertcnelson@gmail.com Reported-by: Matthijs van Duin matthijsvanduin@gmail.com CC: Tom Rini trini@konsulko.com --- board/ti/am335x/mux.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 680f656..fd3da58 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -317,7 +317,6 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) /* Do board-specific muxes. */ if (board_is_bone(header)) { /* Beaglebone pinmux */ - configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); #if defined(CONFIG_NAND) @@ -356,7 +355,6 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) configure_module_pin_mux(mmc0_pin_mux_sk_evm); } else if (board_is_bone_lt(header)) { /* Beaglebone LT pinmux */ - configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(mii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); #if defined(CONFIG_NAND) && defined(CONFIG_EMMC_BOOT)
Robert Nelson
