[U-Boot] [PATCH] omap3evm: Fix mechanism to identify board revision
Function omap3_evm_get_revision() - to identify the board revision was called at end of setup_net_chip().
Board revision can be ascertained only by identifying the Ethernet chipset - but combining setup operations with revision detection isn't a good idea. So, moved the function after call to setup_net_chip().
Function setup_net_chip() should be ideally be called only when CONFIG_CMD_NET is defined. But this leaves the board revision "undetected". This patch allows static definition of revision or default fallback to the latest revision.
Signed-off-by: Sanjeev Premi premi@ti.com --- board/ti/evm/evm.c | 22 +++++++++++++++++++--- board/ti/evm/evm.h | 2 ++ include/configs/omap3_evm.h | 5 +++++ 3 files changed, 26 insertions(+), 3 deletions(-)
diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 73330db..09d14f7 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -46,6 +46,11 @@ u8 get_omap3_evm_rev(void)
static void omap3_evm_get_revision(void) { +#if defined(CONFIG_CMD_NET) + /* + * Board revision can be ascertained only by identifying + * the Ethernet chipset. + */ unsigned int smsc_id;
/* Ethernet PHY ID is stored at ID_REV register */ @@ -62,6 +67,19 @@ static void omap3_evm_get_revision(void) default: omap3_evm_version = OMAP3EVM_BOARD_GEN_2; } +#else +#if defined(CONFIG_STATIC_BOARD_REV) + /* + * Look for static defintion of the board revision + */ + omap3_evm_version = CONFIG_STATIC_BOARD_REV; +#else + /* + * Fallback to the default above. + */ + omap3_evm_version = OMAP3EVM_BOARD_GEN_2; +#endif +#endif /* CONFIG_CMD_NET */ }
#ifdef CONFIG_USB_OMAP3 @@ -110,6 +128,7 @@ int misc_init_r(void) #if defined(CONFIG_CMD_NET) setup_net_chip(); #endif + omap3_evm_get_revision();
dieid_num_r();
@@ -163,9 +182,6 @@ static void setup_net_chip(void) writel(GPIO0, &gpio3_base->cleardataout); udelay(1); writel(GPIO0, &gpio3_base->setdataout); - - /* determine omap3evm revision */ - omap3_evm_get_revision(); }
int board_eth_init(bd_t *bis) diff --git a/board/ti/evm/evm.h b/board/ti/evm/evm.h index e2581f6..a76deb8 100644 --- a/board/ti/evm/evm.h +++ b/board/ti/evm/evm.h @@ -47,7 +47,9 @@ enum {
u8 get_omap3_evm_rev(void);
+#if defined(CONFIG_CMD_NET) static void setup_net_chip(void); +#endif
/* * IEN - Input Enable diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index cd38698..271c985 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -351,6 +351,11 @@ extern unsigned int boot_flash_type; #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - CONFIG_SYS_GBL_DATA_SIZE)
+/* + * Define the board revision statically + */ +/* #define CONFIG_STATIC_BOARD_REV OMAP3EVM_BOARD_GEN_2 */ + /*---------------------------------------------------------------------------- * SMSC9115 Ethernet from SMSC9118 family *----------------------------------------------------------------------------
-----Original Message----- From: Premi, Sanjeev Sent: Wednesday, October 20, 2010 4:21 PM To: u-boot@lists.denx.de Cc: Premi, Sanjeev Subject: [PATCH] omap3evm: Fix mechanism to identify board revision
[snip]
Sandeep,
Pinging for status...
~sanjeev
Premi, Sanjeev
Sanjeev Premi
